Chris4arm Posted June 2, 2022 Posted June 2, 2022 Hi, I tried the new Bullseye image from https://www.armbian.com/station-m1/ to check bluetooth support but nothing is displayed on the screen at boot. No video signal come from the Station M1. The TF card used works with other images. Any hints ? Chris 0 Quote
balbes150 Posted June 2, 2022 Posted June 2, 2022 Bullseye XFCE stable 5.18.y 250M May 28, 2022 @Igor Strange size, is there a problem with the assembly ? 0 Quote
Chris4arm Posted June 2, 2022 Author Posted June 2, 2022 12 minutes ago, balbes150 said: Bullseye XFCE stable 5.18.y 250M May 28, 2022 @Igor Strange size, is there a problem with the assembly ? this one is obviously truncated. The one without video I tried is Armbian_22.05.1_Station-m1_bullseye_current_5.17.9.img.xz (415M) 0 Quote
Chris4arm Posted June 2, 2022 Author Posted June 2, 2022 20 minutes ago, Chris4arm said: this one is obviously truncated. The one without video I tried is Armbian_22.05.1_Station-m1_bullseye_current_5.17.9.img.xz (415M) No more video with Armbian_22.05.1_Station-m1_jammy_current_5.17.9.img.xz but a ssh connection is possible ! Unfortunately "armbianmonitor -u" gives "System diagnosis information will now be uploaded to no results to fetchPlease post the URL in the forum where you've been asked for." 0 Quote
balbes150 Posted June 2, 2022 Posted June 2, 2022 5 часов назад, Chris4arm сказал: No more video with Armbian_22.05.1_Station-m1_jammy_current_5.17.9.img.xz but a ssh connection is possible ! I checked this image, downloaded the image from the download site, unpacked it, recorded it on the SD carde verything works as before, the HDMI output works 0 Quote
Igor Posted June 2, 2022 Posted June 2, 2022 5 hours ago, balbes150 said: Strange size, is there a problem with the assembly ? Assembly is software and software breaks down. I will not even record this problem since there are no resources. OP can build from sources. 0 Quote
Chris4arm Posted June 2, 2022 Author Posted June 2, 2022 7 minutes ago, balbes150 said: I checked this image, downloaded the image from the download site, unpacked it, recorded it on the SD carde verything works as before, the HDMI output works No signal on mine and my logs are full of Jun 02 15:37:27 station-m1 agetty[2704]: /dev/ttyS0: not a tty Jun 02 15:37:31 station-m1 kernel: ------------[ cut here ]------------ Jun 02 15:37:31 station-m1 kernel: [CRTC:37:crtc-0] vblank wait timed out Jun 02 15:37:31 station-m1 kernel: WARNING: CPU: 3 PID: 2400 at drivers/gpu/drm/drm_atomic_helper.c:1530 drm_atomic_helper_wait_for_vblanks.part.23+0x274/0x290 [drm_kms_helper] Jun 02 15:37:31 station-m1 kernel: Modules linked in: tls bnep 8723ds snd_soc_hdmi_codec crct10dif_ce gpio_ir_recv snd_soc_simple_card cfg80211 snd_soc_simple_card_utils hci_uart snd_soc_rk3328 hantro_vpu(C) btqca btrtl v4l2_vp9 snd_soc_rockchip_i2s btbcm v4l2_h264 btintel snd_soc_core v4l2_mem2mem videobuf2_dma_contig videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 bluetooth videobuf2_common snd_compress ac97_bus snd_pcm_dmaengine videodev snd_pcm lima mc snd_timer dw_hdmi_i2s_audio dw_hdmi_cec ecdh_generic gpu_sched snd rfkill drm_shmem_helper ecc soundcore zram sch_fq_codel nfsd auth_rpcgss nfs_acl lockd grace sunrpc ip_tables x_tables autofs4 rockchipdrm drm_cma_helper dw_hdmi dw_mipi_dsi analogix_dp drm_kms_helper cec rc_core drm adc_keys Jun 02 15:37:31 station-m1 kernel: CPU: 3 PID: 2400 Comm: kworker/3:1 Tainted: G WC 5.17.9-media #22.05.1 Jun 02 15:37:31 station-m1 kernel: Hardware name: Firefly ROC-RK3328-PC (DT) Jun 02 15:37:31 station-m1 kernel: Workqueue: events drm_fb_helper_damage_work [drm_kms_helper] Jun 02 15:37:31 station-m1 kernel: pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) Jun 02 15:37:31 station-m1 kernel: pc : drm_atomic_helper_wait_for_vblanks.part.23+0x274/0x290 [drm_kms_helper] Jun 02 15:37:31 station-m1 kernel: lr : drm_atomic_helper_wait_for_vblanks.part.23+0x274/0x290 [drm_kms_helper] Jun 02 15:37:31 station-m1 kernel: sp : ffff80000a743b40 Jun 02 15:37:31 station-m1 kernel: x29: ffff80000a743b40 x28: 0000000000000000 x27: 0000000000003a35 Jun 02 15:37:31 station-m1 kernel: x26: ffff0000090e5800 x25: 0000000000000000 x24: 0000000000000001 Jun 02 15:37:31 station-m1 kernel: x23: 0000000000000038 x22: 0000000000000001 x21: ffff00000887c180 Jun 02 15:37:31 station-m1 kernel: x20: ffff00007d597080 x19: 0000000000000000 x18: 0000000000000001 Jun 02 15:37:31 station-m1 kernel: x17: 00480144020604d3 x16: 04b904b304d304b0 x15: 000000000000291c Jun 02 15:37:31 station-m1 kernel: x14: ffff80000a743850 x13: 00000000ffffffea x12: ffff800009c5c150 Jun 02 15:37:31 station-m1 kernel: x11: 0000000000000003 x10: ffff800009bd0850 x9 : ffff800009c4e6b0 Jun 02 15:37:31 station-m1 kernel: x8 : 000000000000daa0 x7 : c0000000ffffe91c x6 : fffffffffffec548 Jun 02 15:37:31 station-m1 kernel: x5 : ffff800076338000 x4 : 0000000000000000 x3 : 0000000000000001 Jun 02 15:37:31 station-m1 kernel: x2 : 0000000000000000 x1 : 90b9856759b7b800 x0 : 0000000000000000 Jun 02 15:37:31 station-m1 kernel: Call trace: Jun 02 15:37:31 station-m1 kernel: drm_atomic_helper_wait_for_vblanks.part.23+0x274/0x290 [drm_kms_helper] Jun 02 15:37:31 station-m1 kernel: drm_atomic_helper_commit_tail_rpm+0x64/0x80 [drm_kms_helper] Jun 02 15:37:31 station-m1 kernel: commit_tail+0xa4/0x198 [drm_kms_helper] Jun 02 15:37:31 station-m1 kernel: drm_atomic_helper_commit+0x160/0x370 [drm_kms_helper] Jun 02 15:37:31 station-m1 kernel: drm_atomic_commit+0x58/0x68 [drm] Jun 02 15:37:31 station-m1 kernel: drm_atomic_helper_dirtyfb+0x190/0x2d0 [drm_kms_helper] Jun 02 15:37:31 station-m1 kernel: drm_fb_helper_damage_work+0x194/0x2f0 [drm_kms_helper] Jun 02 15:37:31 station-m1 kernel: process_one_work+0x20c/0x4c0 Jun 02 15:37:31 station-m1 kernel: worker_thread+0x48/0x478 Jun 02 15:37:31 station-m1 kernel: kthread+0xf8/0x110 Jun 02 15:37:31 station-m1 kernel: ret_from_fork+0x10/0x20 Jun 02 15:37:31 station-m1 kernel: ---[ end trace 0000000000000000 ]--- An idea ? 0 Quote
balbes150 Posted June 2, 2022 Posted June 2, 2022 3 минуты назад, Chris4arm сказал: No signal on mine and my logs are full of The check was completed and it was successful (there are no problems with the operation of the entire system, including HDMI), deal with your equipment (SD card, recording programs, etc.). 0 Quote
balbes150 Posted June 2, 2022 Posted June 2, 2022 I also checked the official Bullseye image with the 5.17.9 kernel, everything works, including HDMI. 0 Quote
Chris4arm Posted June 2, 2022 Author Posted June 2, 2022 46 minutes ago, balbes150 said: The check was completed and it was successful (there are no problems with the operation of the entire system, including HDMI), deal with your equipment (SD card, recording programs, etc.). thanks for your tests but if I rewrite one of previous tested images, Armbian_22.02.0-trunk_Station-m1_bullseye_current_5.15.18.img.xz for example, it displays on the screen as before. Is there differences between your M1 and mine ? Mine is 2G/16G. 0 Quote
Chris4arm Posted June 2, 2022 Author Posted June 2, 2022 2 hours ago, balbes150 said: The check was completed and it was successful (there are no problems with the operation of the entire system, including HDMI), deal with your equipment (SD card, recording programs, etc.). in fact it depends on the screen used ! I connected the M1 on a TV screen and the display was ok (Armbian_22.05.1_Station-m1_jammy_current_5.17.9.img.xz). Bug in the mali driver ? Is it possible to boot in a video safe mode ? 0 Quote
balbes150 Posted June 3, 2022 Posted June 3, 2022 18 часов назад, Chris4arm сказал: in fact it depends on the screen used ! I connected the M1 on a TV screen and the display was ok (Armbian_22.05.1_Station-m1_jammy_current_5.17.9.img.xz). Bug in the mali driver ? Is it possible to boot in a video safe mode ? If you use non-standard equipment (and do not even describe the details), you should solve all the problems yourself and not mislead people by taking time for useless work. There are no "Mali drivers" in the main core for a long time. 0 Quote
Chris4arm Posted June 3, 2022 Author Posted June 3, 2022 8 hours ago, balbes150 said: If you use non-standard equipment (and do not even describe the details), you should solve all the problems yourself and not mislead people by taking time for useless work. There are no "Mali drivers" in the main core for a long time. Hmm, do you think a Dell U2415 and a Logitech 350 keyboard are non-standard equipments ? Previous images tested on this M1 (same SD card, same cable, same monitor,...) had no display issues. Among : Armbian_21.08.1_Station-m1_bullseye_current_5.10.60.img.xz Armbian_22.02.0-trunk_Station-m1_bullseye_edge_5.16.8.img.xz Armbian_22.02.0-trunk_Station-m1_bullseye_current_5.15.18.img.xz Armbian_22.02.0-trunk_Station-m1_buster_legacy_4.4.213_xfce_desktop.img.xz Armbian_21.08.1_Station-m1_buster_current_5.10.60.img.xz Armbian_22.02.1_Station-m1_bullseye_current_5.15.25.img.xz Armbian_22.05.1_Station-m1_bullseye_current_5.17.9.img.xz LibreELEC-ARMv8.aarch64-11.0-devel-20220217100543-8bd19d9-rk3328-roc-pc.img ... The new ones have problem posted above, so I suspected they were faulty. Maybe it has to do with screen resolution (1920x1200 for the Dell, 1920x1080 for the TV), hdmi version,... ?? I got (with difficulty) a "armbianmonitor -u" (from Armbian_22.05.1_Station-m1_jammy_current_5.17.9.img.xz) at http://ix.io/3Zik If you think exposing that is misleading people I'm sorry and you may delete this thread. Chris 0 Quote
camstar Posted August 6, 2022 Posted August 6, 2022 Maybe it's in the name (also Chris), but I have the same problem. Can't get HDMI out on the new images on a nanopim4v2. I will try another monitor (mine is a ultrawide 5K). Never had a problem with the previous images (though never could get the edid resolutions to work), but 1920 x 1080 did work. I also think the reaction of balbes150 is quite harsh. It's sad that we have to communicate this way between forum members. 0 Quote
