Hayotbek Xasanboyev Posted June 2, 2022 Posted June 2, 2022 Sorry for my stupid question. If I connect by TTL to USB adapter, after setting up login/password, terminal is freezing. Board is Nanopi NOE2. I think this is due to the fact that my adapter is warm or not of poor quality. While I order a new one, is there a way to enable ssh access over the lan network?
Werner Posted June 2, 2022 Posted June 2, 2022 SSH is enabled oob on all Armbian images. When connecting to a wired network it will look for a dhcp server and aquire a lease. Check your dhcp (usually your router) interface to know the IP address.
Hayotbek Xasanboyev Posted June 2, 2022 Author Posted June 2, 2022 1 минуту назад, Werner сказал: SSH is enabled oob on all Armbian images. When connecting to a wired network it will look for a dhcp server and aquire a lease. Check your dhcp (usually your router) interface to know the IP address. I already set static ip for my board. But on Kitty I get connection error. Later I send error screen.
Werner Posted June 2, 2022 Posted June 2, 2022 So probably misconfiguration. Other solution would be to simply remove the SD card from the board and mount it on a random lijux machine and edit the network config there.
