Orange Pi PC can't install updates - 404 file not found
Go to solution Solved by Werner,
I get these errors when I try to "apt-get upgrade"
Err:1 http://mirrors.xtom.de/armbian bullseye/main armhf linux-dtb-current-sunxi armhf 22.05.3
  404  Not Found [IP: 2a09:0:8::14 80]
E: Failed to fetch http://mirrors.xtom.de/armbian/pool/main/l/linux-5.15.48-sunxi/linux-dtb-current-sunxi_22.05.3_armhf.deb  404  Not Found [IP: 2a09:0:8::14 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Is Orange Pi PC still supported by Armbian?
Btw I'm using "Armbian 22.02.2 Bullseye"
Thank you,
Regards,
dhr
5 minutes ago, dusthillresident said:
Thank you a lot! This fixed the issue for me, it's all fully updated now
This mirror is out of sync and was disabled temporally.
14 minutes ago, dusthillresident said:
Ohh, should I manually change the mirrors in my sources.list or is it okay to just leave it as it is?
No. You don't need to do anything. We are in control ;)
https://github.com/armbian/dl-router (newer version of this is currently in operations)
