Kaosheng Posted June 28, 2022 Posted June 28, 2022 Orangepi 3 LTS Armbian 22.05 Jammy XFCE CAN'T CONNECT WITH WIFI 0 Quote
Werner Posted June 28, 2022 Posted June 28, 2022 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Kaosheng Posted June 28, 2022 Author Posted June 28, 2022 On 6/28/2022 at 5:09 AM, Werner said: Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. Expand kao@orangepi3-lts:~$ armbianmonitor -u Network/firewall problem detected. Not able to upload debug info. Please fix this or use "-U" instead and upload whole output manually kao@orangepi3-lts:~$ armbianmonitor -U armbian-hardware-monitor.log ### Activated 1 lzo-rle zram swap devices with 994MB each. ### Activated Armbian ramlog partition with zstd compression Thu Jun 23 03:13:46 AM UTC 2022 | Orange Pi 3 LTS | 22.05.3 | arm64 | aarch64 | 5.15.48-sunxi64 ### dmesg: [ 1.271389] ohci-platform: OHCI generic platform driver [ 1.271884] usbcore: registered new interface driver usb-storage [ 1.272440] mousedev: PS/2 mouse device common for all mice [ 1.273452] sun6i-rtc 7000000.rtc: registered as rtc0 [ 1.273485] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4) [ 1.273599] sun6i-rtc 7000000.rtc: RTC enabled [ 1.273742] i2c_dev: i2c /dev entries driver [ 1.274541] sunxi-wdt 7020400.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 1.276070] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pm not found, using dummy regulator [ 1.276491] sdhci: Secure Digital Host Controller Interface driver [ 1.276500] sdhci: Copyright(c) Pierre Ossman [ 1.276524] Synopsys Designware Multimedia Card Interface Driver [ 1.277348] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.277525] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator [ 1.278836] ledtrig-cpu: registered to indicate activity on CPUs [ 1.279412] sun8i-ce 1904000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz) [ 1.279723] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.279850] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.279963] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.280080] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.280162] sun8i-ce 1904000.crypto: Register cbc(aes) [ 1.280314] sun8i-ce 1904000.crypto: Register ecb(aes) [ 1.280452] sun8i-ce 1904000.crypto: Register cbc(des3_ede) [ 1.280568] sun8i-ce 1904000.crypto: Register ecb(des3_ede) [ 1.280687] sun8i-ce 1904000.crypto: Register md5 [ 1.280795] sun8i-ce 1904000.crypto: Register sha1 [ 1.280905] sun8i-ce 1904000.crypto: Register sha224 [ 1.281020] sun8i-ce 1904000.crypto: Register sha256 [ 1.281127] sun8i-ce 1904000.crypto: Register sha384 [ 1.281232] sun8i-ce 1904000.crypto: Register sha512 [ 1.281398] sun8i-ce 1904000.crypto: Register stdrng [ 1.282121] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0 [ 1.282719] hid: raw HID events driver (C) Jiri Kosina [ 1.282852] usbcore: registered new interface driver usbhid [ 1.282859] usbhid: USB HID core driver [ 1.283588] random: crng init done [ 1.285840] NET: Registered PF_INET6 protocol family [ 1.870798] Freeing initrd memory: 12684K [ 1.899454] Segment Routing with IPv6 [ 1.899519] In-situ OAM (IOAM) with IPv6 [ 1.899604] NET: Registered PF_PACKET protocol family [ 1.899720] 8021q: 802.1Q VLAN Support v1.8 [ 1.899880] 9pnet: Installing 9P2000 support [ 1.899952] Key type dns_resolver registered [ 1.900422] registered taskstats version 1 [ 1.900443] Loading compiled-in X.509 certificates [ 1.904300] Loaded X.509 cert 'Build time autogenerated kernel key: 32330adefd2da02e444296fafd37464380789679' [ 1.907185] zswap: loaded using pool zstd/z3fold [ 1.907825] Key type ._fscrypt registered [ 1.907833] Key type .fscrypt registered [ 1.907837] Key type fscrypt-provisioning registered [ 1.908859] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no [ 1.922659] Key type encrypted registered [ 1.922691] AppArmor: AppArmor sha1 policy hashing enabled [ 1.922730] ima: No TPM chip found, activating TPM-bypass! [ 1.922775] ima: Allocated hash algorithm: sha1 [ 1.922808] ima: No architecture policies found [ 1.922878] evm: Initialising EVM extended attributes: [ 1.922883] evm: security.selinux [ 1.922888] evm: security.SMACK64 [ 1.922892] evm: security.SMACK64EXEC [ 1.922897] evm: security.SMACK64TRANSMUTE [ 1.922901] evm: security.SMACK64MMAP [ 1.922905] evm: security.apparmor [ 1.922909] evm: security.ima [ 1.922913] evm: security.capability [ 1.922917] evm: HMAC attrs: 0x1 [ 1.935969] platform 1100000.mixer: Fixing up cyclic dependency with 6510000.tcon-top [ 1.936305] sun8i-mixer 1100000.mixer: Adding to iommu group 0 [ 1.938389] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 1.938422] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 1.938574] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f064 hci version 0x100 quirks 0x0000000002010010 [ 1.938635] xhci-hcd xhci-hcd.1.auto: irq 43, io mem 0x05200000 [ 1.939086] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 1.939102] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.939113] usb usb1: Product: xHCI Host Controller [ 1.939122] usb usb1: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd [ 1.939130] usb usb1: SerialNumber: xhci-hcd.1.auto [ 1.939679] hub 1-0:1.0: USB hub found [ 1.939724] hub 1-0:1.0: 1 port detected [ 1.940079] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 1.940099] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2 [ 1.940117] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 1.940231] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.940397] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15 [ 1.940410] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.940420] usb usb2: Product: xHCI Host Controller [ 1.940428] usb usb2: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd [ 1.940436] usb usb2: SerialNumber: xhci-hcd.1.auto [ 1.940851] hub 2-0:1.0: USB hub found [ 1.940889] hub 2-0:1.0: 1 port detected [ 1.943532] sun50i_cpufreq_nvmem: Using CPU speed bin speed0 [ 1.945371] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version [ 1.951715] of_cfs_init [ 1.951850] of_cfs_init: OK [ 1.952183] ALSA device list: [ 1.952189] No soundcards found. [ 1.953328] Freeing unused kernel memory: 2496K [ 1.965392] Run /init as init process [ 1.965399] with arguments: [ 1.965405] /init [ 1.965410] with environment: [ 1.965415] HOME=/ [ 1.965419] TERM=linux [ 1.965424] ubootpart=ce3dfe46-01 [ 1.965430] cgroup_enable=memory [ 2.197360] usb 1-1: new full-speed USB device number 2 using xhci-hcd [ 2.352212] usb 1-1: New USB device found, idVendor=045e, idProduct=0745, bcdDevice= 6.33 [ 2.352245] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.352256] usb 1-1: Product: Microsoft® 2.4GHz Transceiver v7.0 [ 2.352264] usb 1-1: Manufacturer: Microsoft [ 2.371628] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.0/0003:045E:0745.0001/input/input0 [ 2.397833] axp20x-i2c 0-0036: AXP20x variant AXP806 found [ 2.406456] input: axp20x-pek as /devices/platform/soc/7081400.i2c/i2c-0/0-0036/axp221-pek/input/input1 [ 2.430062] hid-generic 0003:045E:0745.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input0 [ 2.434077] vdd-cpu: supplied by vcc-5v [ 2.439356] vdd-gpu: supplied by vcc-5v [ 2.440064] vdd-sys: Bringing 900000uV into 960000-960000uV [ 2.440498] vdd-sys: supplied by vcc-5v [ 2.441417] vcc-dram: supplied by vcc-5v [ 2.442291] vcc-pl-led-ir: supplied by vcc-5v [ 2.443422] vcc33-audio-tv-ephy-mac: Bringing 700000uV into 3300000-3300000uV [ 2.443821] vcc33-audio-tv-ephy-mac: supplied by vcc-5v [ 2.444503] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Mouse as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input2 [ 2.444994] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input3 [ 2.501752] hid-generic 0003:045E:0745.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input1 [ 2.511185] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input4 [ 2.550092] vcc33-io-pd-emmc-sd-usb-uart-1: Bringing 700000uV into 3300000-3300000uV [ 2.550453] vcc33-io-pd-emmc-sd-usb-uart-1: supplied by vcc-5v [ 2.551481] vcc18-dram-bias-pll: supplied by vcc-5v [ 2.552559] vcc-efuse-pcie-hdmi-pc: supplied by vcc-5v [ 2.553234] vcc-wifi-io-pm-pg: Bringing 700000uV into 1800000-1800000uV [ 2.553572] vcc-wifi-io-pm-pg: supplied by vcc-5v [ 2.554668] bldo4: supplied by vcc-5v [ 2.555185] vcc33-io-pd-emmc-sd-usb-uart-2: supplied by vcc-5v [ 2.555987] cldo2: supplied by vcc-5v [ 2.556633] cldo3: supplied by vcc-5v [ 2.556863] sw: supplied by regulator-dummy [ 2.557449] axp20x-i2c 0-0036: AXP20X driver loaded [ 2.570248] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 System Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input6 [ 2.570764] hid-generic 0003:045E:0745.0003: input,hiddev96,hidraw2: USB HID v1.11 Device [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input2 [ 2.574626] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver [ 2.575152] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pb not found, using dummy regulator [ 2.576079] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator [ 2.581609] printk: console [ttyS0] disabled [ 2.581741] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 35, base_baud = 1500000) is a 16550A [ 2.581965] printk: console [ttyS0] enabled [ 2.583370] sun4i-drm display-engine: Adding to iommu group 0 [ 2.602997] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e16990) [ 2.603353] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800008e1abb8) [ 2.603765] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff800008e11ba0) [ 2.603887] sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator [ 2.604602] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY) [ 2.604931] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 2.605461] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver [ 2.610057] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff800008e15cc8) [ 2.610881] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 [ 2.610942] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 1 [ 2.765113] Console: switching to colour frame buffer device 240x67 [ 2.814958] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device [ 2.839020] acx00-codec acx00-codec: DMA mask not set [ 2.842787] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator [ 2.844953] sunxi-mmc 4020000.mmc: Got CD GPIO [ 2.845563] vcc-wifi-io: supplied by vcc33-wifi [ 2.847905] ehci-platform 5101000.usb: EHCI Host Controller [ 2.847948] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 3 [ 2.848105] ehci-platform 5101000.usb: irq 41, io mem 0x05101000 [ 2.857343] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 2.861347] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00 [ 2.861683] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 2.861698] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.861709] usb usb3: Product: EHCI Host Controller [ 2.861717] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd [ 2.861726] usb usb3: SerialNumber: 5101000.usb [ 2.862270] hub 3-0:1.0: USB hub found [ 2.862312] hub 3-0:1.0: 1 port detected [ 2.863447] ehci-platform 5311000.usb: EHCI Host Controller [ 2.863501] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 4 [ 2.863651] ehci-platform 5311000.usb: irq 44, io mem 0x05311000 [ 2.869618] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 2.877334] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00 [ 2.877662] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 2.877677] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.877687] usb usb4: Product: EHCI Host Controller [ 2.877696] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd [ 2.877704] usb usb4: SerialNumber: 5311000.usb [ 2.878275] hub 4-0:1.0: USB hub found [ 2.878317] hub 4-0:1.0: 1 port detected [ 2.879527] ohci-platform 5101400.usb: Generic Platform OHCI controller [ 2.879591] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 5 [ 2.879731] ohci-platform 5101400.usb: irq 42, io mem 0x05101400 [ 2.904258] mmc0: host does not support reading read-only switch, assuming write-enable [ 2.906028] mmc0: Problem switching card into high-speed mode! [ 2.906141] mmc0: new SDHC card at address 0001 [ 2.907012] mmcblk0: mmc0:0001 USD 29.8 GiB [ 2.909094] mmcblk0: p1 [ 2.941592] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15 [ 2.941618] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.941629] usb usb5: Product: Generic Platform OHCI controller [ 2.941637] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd [ 2.941646] usb usb5: SerialNumber: 5101400.usb [ 2.942382] hub 5-0:1.0: USB hub found [ 2.942478] hub 5-0:1.0: 1 port detected [ 2.943732] ohci-platform 5311400.usb: Generic Platform OHCI controller [ 2.943797] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 6 [ 2.943945] ohci-platform 5311400.usb: irq 45, io mem 0x05311400 [ 2.997466] mmc2: new HS200 MMC card at address 0001 [ 2.998519] mmcblk2: mmc2:0001 8GTF4R 7.28 GiB [ 3.000828] mmcblk2boot0: mmc2:0001 8GTF4R 4.00 MiB [ 3.002395] mmcblk2boot1: mmc2:0001 8GTF4R 4.00 MiB [ 3.005697] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15 [ 3.005727] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.005738] usb usb6: Product: Generic Platform OHCI controller [ 3.005746] usb usb6: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd [ 3.005755] usb usb6: SerialNumber: 5311400.usb [ 3.006413] hub 6-0:1.0: USB hub found [ 3.006468] hub 6-0:1.0: 1 port detected [ 3.007749] usb_phy_generic usb_phy_generic.4.auto: supply vcc not found, using dummy regulator [ 3.007972] usb_phy_generic usb_phy_generic.4.auto: dummy supplies not allowed for exclusive requests [ 3.109696] musb-hdrc musb-hdrc.5.auto: MUSB HDRC host driver [ 3.109741] musb-hdrc musb-hdrc.5.auto: new USB bus registered, assigned bus number 7 [ 3.110006] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 3.110022] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.110032] usb usb7: Product: MUSB HDRC host driver [ 3.110041] usb usb7: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd [ 3.110049] usb usb7: SerialNumber: musb-hdrc.5.auto [ 3.110654] hub 7-0:1.0: USB hub found [ 3.110724] hub 7-0:1.0: 1 port detected [ 3.130721] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found [ 3.130747] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found [ 3.131045] dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator [ 3.131271] dwmac-sun8i 5020000.ethernet: PTP uses main clock [ 3.131313] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 50000) [ 3.237621] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported [ 3.237647] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported [ 3.237655] dwmac-sun8i 5020000.ethernet: COE Type 2 [ 3.237666] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported [ 3.237673] dwmac-sun8i 5020000.ethernet: Normal descriptors [ 3.237680] dwmac-sun8i 5020000.ethernet: Chain mode enabled [ 3.478371] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none. [ 3.673352] usb 5-1: new full-speed USB device number 2 using ohci-platform [ 3.910374] usb 5-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.10 [ 3.910404] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.910415] usb 5-1: Product: USB Receiver [ 3.910424] usb 5-1: Manufacturer: Logitech [ 3.919527] input: Logitech USB Receiver as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.0/0003:046D:C52B.0004/input/input7 [ 3.977996] hid-generic 0003:046D:C52B.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-5101400.usb-1/input0 [ 3.984266] input: Logitech USB Receiver Mouse as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input8 [ 3.984724] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input9 [ 4.041716] input: Logitech USB Receiver System Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input10 [ 4.042095] hid-generic 0003:046D:C52B.0005: input,hiddev97,hidraw4: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-5101400.usb-1/input1 [ 4.046730] hid-generic 0003:046D:C52B.0006: hiddev98,hidraw5: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2 [ 4.781944] systemd[1]: System time before build time, advancing clock. [ 4.870091] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq [ 4.879064] systemd[1]: systemd 249.11-0ubuntu3.1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS -OPENSSL +ACL +BLKID +CURL +ELFUTILS -FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP -LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 4.879739] systemd[1]: Detected architecture arm64. [ 4.883086] systemd[1]: Hostname set to <orangepi3-lts>. [ 5.105388] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 5.122726] mmc1: new high speed SDIO card at address 8800 [ 6.193555] systemd[1]: Queued start job for default target Graphical Interface. [ 6.199452] systemd[1]: Created slice Slice /system/modprobe. [ 6.202231] systemd[1]: Created slice Slice /system/serial-getty. [ 6.204080] systemd[1]: Created slice User and Session Slice. [ 6.204943] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 6.206453] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 6.207405] systemd[1]: Reached target Remote File Systems. [ 6.207760] systemd[1]: Reached target Slice Units. [ 6.208108] systemd[1]: Reached target Swaps. [ 6.208409] systemd[1]: Reached target System Time Set. [ 6.208987] systemd[1]: Reached target Local Verity Protected Volumes. [ 6.210061] systemd[1]: Listening on Syslog Socket. [ 6.210934] systemd[1]: Listening on fsck to fsckd communication Socket. [ 6.211571] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 6.212959] systemd[1]: Listening on Journal Audit Socket. [ 6.213968] systemd[1]: Listening on Journal Socket (/dev/log). [ 6.215050] systemd[1]: Listening on Journal Socket. [ 6.226846] systemd[1]: Listening on udev Control Socket. [ 6.227964] systemd[1]: Listening on udev Kernel Socket. [ 6.232507] systemd[1]: Mounting Huge Pages File System... [ 6.237816] systemd[1]: Mounting POSIX Message Queue File System... [ 6.243581] systemd[1]: Mounting Kernel Debug File System... [ 6.244898] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 6.252149] systemd[1]: Starting Restore / save the current clock... [ 6.257902] systemd[1]: Starting Set the console keyboard layout... [ 6.264301] systemd[1]: Starting Create List of Static Device Nodes... [ 6.270918] systemd[1]: Starting Load Kernel Module configfs... [ 6.277786] systemd[1]: Starting Load Kernel Module drm... [ 6.284675] systemd[1]: Starting Load Kernel Module fuse... [ 6.292060] systemd[1]: Started Nameserver information manager. [ 6.293725] systemd[1]: Reached target Preparation for Network. [ 6.294932] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 6.306924] systemd[1]: Starting Load Kernel Modules... [ 6.312706] systemd[1]: Starting Remount Root and Kernel File Systems... [ 6.318432] systemd[1]: Starting Coldplug All udev Devices... [ 6.328490] systemd[1]: Mounted Huge Pages File System. [ 6.329589] fuse: init (API version 7.34) [ 6.330211] systemd[1]: Mounted POSIX Message Queue File System. [ 6.331670] systemd[1]: Mounted Kernel Debug File System. [ 6.334979] systemd[1]: Finished Restore / save the current clock. [ 6.338419] systemd[1]: Finished Create List of Static Device Nodes. [ 6.340843] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 6.342500] systemd[1]: Finished Load Kernel Module configfs. [ 6.344775] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 6.346521] systemd[1]: Finished Load Kernel Module drm. [ 6.348776] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 6.350118] systemd[1]: Finished Load Kernel Module fuse. [ 6.357102] systemd[1]: Mounting FUSE Control File System... [ 6.363222] systemd[1]: Mounting Kernel Configuration File System... [ 6.371020] systemd[1]: Mounted FUSE Control File System. [ 6.374967] systemd[1]: Mounted Kernel Configuration File System. [ 6.387839] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none. [ 6.393209] systemd[1]: Finished Remount Root and Kernel File Systems. [ 6.394291] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 6.398918] systemd[1]: Starting Load/Save Random Seed... [ 6.404754] systemd[1]: Starting Create System Users... [ 6.605011] WCN: marlin_init entry! [ 6.605666] WCN: wcn config bt wake host [ 6.605940] WCN_ERR: dts node for bt_wake not found [ 6.605943] WCN: marlin2 parse_dt some para not config [ 6.605957] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840 [ 6.613551] sdiohal:sdiohal_init ok [ 6.614342] WCN: marlin_probe ok! [ 6.615383] systemd[1]: Finished Load/Save Random Seed. [ 6.616503] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 6.629638] mtty_probe init device addr: 0x00000000e4ddf53f [ 6.629847] -->rfkill_bluetooth_init [ 6.629985] bluetooth_set_power: start_block=1 [ 6.629996] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0 [ 6.630006] bluetooth_set_power: end_block=1 [ 6.630024] <--rfkill_bluetooth_init [ 6.642377] systemd[1]: Finished Create System Users. [ 6.648577] systemd[1]: Starting Create Static Device Nodes in /dev... [ 6.718136] systemd[1]: Finished Set the console keyboard layout. [ 6.724088] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 6.725783] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 6.746999] [ADDR_MGT] addr_mgt_probe: module version: v1.0.9 [ 6.747155] [ADDR_MGT] addr_mgt_probe: success. [ 6.812225] WCN: start_marlin [MARLIN_WIFI] [ 6.812252] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1 [ 6.812260] WCN: the first power on start [ 6.818045] systemd[1]: Finished Create Static Device Nodes in /dev. [ 6.825520] systemd[1]: Reached target Preparation for Local File Systems. [ 6.837722] systemd[1]: Mounting /tmp... [ 6.851964] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 6.862991] systemd[1]: Mounted /tmp. [ 6.870324] systemd[1]: Reached target Local File Systems. [ 6.882576] systemd[1]: Starting Armbian leds state... [ 6.895047] systemd[1]: Starting Armbian ZRAM config... [ 6.907291] systemd[1]: Starting Set console font and keymap... [ 6.917410] WCN: marlin chip en dummy pull up -- need manually set GPIO [ 6.919805] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 6.943858] systemd[1]: Starting Set Up Additional Binary Formats... [ 6.945374] sdiohal:sdiohal_scan_card [ 6.945565] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=50000000 [ 6.945658] WCN: marlin_scan_finish! [ 6.945663] sdiohal:probe ok [ 6.945774] sdiohal:scan end! [ 6.945780] WCN: then marlin start to download [ 6.946019] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001 [ 6.946032] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start! [ 6.952293] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 6.952618] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 6.955861] systemd[1]: Finished Set console font and keymap. [ 6.968835] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 362 (systemd-binfmt) [ 6.974598] systemd[1]: Mounting Arbitrary Executable File Formats File System... [ 6.993966] systemd[1]: Finished Coldplug All udev Devices. [ 7.002822] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 7.098961] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 7.109231] systemd[1]: Mounted Arbitrary Executable File Formats File System. [ 7.132532] systemd[1]: Finished Set Up Additional Binary Formats. [ 7.160398] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 7.209436] systemd[1]: Finished Armbian leds state. [ 7.513983] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 7.521754] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 7.522417] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active. [ 7.533479] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 7.533648] systemd[1]: Reached target Local Encrypted Volumes. [ 7.575897] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 7.627231] systemd[1]: Starting Load/Save RF Kill Switch Status... [ 7.777051] systemd[1]: Started Load/Save RF Kill Switch Status. [ 7.954890] systemd[1]: Found device /dev/ttyS0. [ 8.014195] panfrost 1800000.gpu: clock rate = 432000000 [ 8.014230] panfrost 1800000.gpu: bus_clock rate = 100000000 [ 8.014548] panfrost 1800000.gpu: mali-t720 id 0x720 major 0x1 minor 0x1 status 0x0 [ 8.014559] panfrost 1800000.gpu: features: 00000000,10309e40, issues: 00000000,21054400 [ 8.014566] panfrost 1800000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002821 AS:0xf JS:0x7 [ 8.014573] panfrost 1800000.gpu: shader_present=0x3 l2_present=0x1 [ 8.014613] WCN: combin_img 0 marlin_firmware_write finish and successful [ 8.014901] WCN: marlin_start_run read reset reg val:0x1 [ 8.014906] WCN: after do marlin_start_run reset reg val:0x0 [ 8.015080] WCN: s_marlin_bootup_time=8015079802 [ 8.015466] [drm] Initialized panfrost 1.2.0 20180908 for 1800000.gpu on minor 1 [ 8.021616] WCN: clock mode: TSX [ 8.021814] WCN: marlin_write_cali_data sync init_state:0x91036042 [ 8.049599] WCN: marlin_write_cali_data sync init_state:0x91036042 [ 8.068392] mc: Linux media interface: v0.10 [ 8.077689] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1 [ 8.077720] WCN: sdio_config bt_wake_host trigger:[high] [ 8.077723] WCN: sdio_config irq:[inband] [ 8.077725] WCN: sdio_config wake_host_level_duration_time:[20ms] [ 8.077731] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse] [ 8.077733] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config) [ 8.078060] WCN: marlin_write_cali_data finish [ 8.078227] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.105573] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.137562] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.165584] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.184903] videodev: Linux video capture interface: v2.00 [ 8.193587] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0 [ 8.193612] WCN: marlin_bind_verify confuse data: 0x33fea07bef5424afb3eb92a5307b8c0e [ 8.193627] WCN: marlin_bind_verify verify data: 0xbe88975721254815cb97ad470d21e601 [ 8.194121] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0 [ 8.221621] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0 [ 8.221645] sdiohal:sdiohal_runtime_get entry [ 8.224117] WCN: get_cp2_version entry! [ 8.268773] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~ [ 8.268824] WCN: switch_cp2_log - close entry! [ 8.270121] WCN: WCND at cmd read:OK [ 8.270208] WCN: then marlin download finished and run ok [ 8.270214] WCN: start_loopcheck [ 8.288538] WCN: get_board_ant_num [one_ant] [ 8.288563] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini [ 8.357396] Registered IR keymap rc-empty [ 8.357535] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0 [ 8.358087] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter [ 8.358296] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input12 [ 8.358715] sunxi-ir 7040000.ir: initialized sunXi IR driver [ 8.379249] zram: Added device: zram0 [ 8.379675] zram: Added device: zram1 [ 8.380117] zram: Added device: zram2 [ 8.410616] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings. [ 8.416810] systemd[1]: Finished Load Kernel Modules. [ 8.425572] systemd[1]: Starting Apply Kernel Variables... [ 8.502238] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. [ 8.503493] cedrus 1c0e000.video-codec: Adding to iommu group 0 [ 8.509361] cedrus 1c0e000.video-codec: Device registered as /dev/video0 [ 8.569078] systemd[1]: Finished Apply Kernel Variables. [ 8.615426] zram0: detected capacity change from 0 to 2037304 [ 8.633094] systemd[1]: Starting Raise network interfaces... [ 8.650146] Adding 1018648k swap on /dev/zram0. Priority:5 extents:1 across:1018648k SSFS [ 8.824826] logitech-djreceiver 0003:046D:C52B.0006: hiddev97,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2 [ 8.894117] zram1: detected capacity change from 0 to 102400 [ 8.958383] input: Logitech Wireless Device PID:4004 Keyboard as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input13 [ 9.009858] hid-generic 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4004] on usb-5101400.usb-1/input2:1 [ 9.036255] systemd[1]: Finished Armbian ZRAM config. [ 9.044253] systemd[1]: Starting Armbian memory supported logging... [ 9.171018] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none. [ 9.198787] input: Logitech K360 as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input17 [ 9.199362] logitech-hidpp-device 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K360] on usb-5101400.usb-1/input2:1 [ 9.697942] systemd[1]: Finished Raise network interfaces. [ 9.704493] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 9.704773] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 9.705128] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 9.710522] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 9.710654] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 9.710772] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 9.710855] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 9.857115] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 9.857354] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 9.857432] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 9.857521] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 9.857622] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 9.857735] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 11.391375] systemd[1]: Finished Armbian memory supported logging. [ 11.400571] systemd[1]: Starting Journal Service... [ 11.544107] systemd[1]: Started Journal Service. [ 11.573374] systemd-journald[677]: Received client request to flush runtime journal. ### armbian-release: # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi3-lts BOARD_NAME="Orange Pi 3 LTS" BOARDFAMILY=sun50iw6 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=13f5fba13c VERSION=22.05.3 LINUXFAMILY=sunxi64 ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=stable ### boot environment: verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun50i-h6 rootdev=UUID=71b44a6c-5bb8-4352-afe7-d22b8e62de4c rootfstype=ext4 ### lsusb: Thu Jun 23 03:13:46 AM UTC 2022 | Orange Pi 3 LTS | 22.05.3 | arm64 | aarch64 | 5.15.48-sunxi64 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ### lscpu: Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 4 On-line CPU(s) list: 0-3 Vendor ID: ARM Model name: Cortex-A53 Model: 4 Thread(s) per core: 1 Core(s) per cluster: 4 Socket(s): - Cluster(s): 1 Stepping: r0p4 CPU max MHz: 1800.0000 CPU min MHz: 480.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid NUMA node(s): 1 NUMA node0 CPU(s): 0-3 Vulnerability Itlb multihit: Not affected Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Spec store bypass: Not affected Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Not affected Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected ### cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 1 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 2 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 3 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 ### meminfo: MemTotal: 2037300 kB MemFree: 1849616 kB MemAvailable: 1851652 kB Buffers: 11672 kB Cached: 50624 kB SwapCached: 0 kB Active: 31520 kB Inactive: 51264 kB Active(anon): 444 kB Inactive(anon): 23568 kB Active(file): 31076 kB Inactive(file): 27696 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 1018648 kB SwapFree: 1018648 kB Dirty: 1676 kB Writeback: 0 kB AnonPages: 20500 kB Mapped: 16968 kB Shmem: 3392 kB KReclaimable: 10432 kB Slab: 45848 kB SReclaimable: 10432 kB SUnreclaim: 35416 kB KernelStack: 2512 kB PageTables: 1688 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 2037296 kB Committed_AS: 43924 kB VmallocTotal: 133143592960 kB VmallocUsed: 22764 kB VmallocChunk: 0 kB Percpu: 976 kB AnonHugePages: 0 kB ShmemHugePages: 0 kB ShmemPmdMapped: 0 kB FileHugePages: 0 kB FilePmdMapped: 0 kB CmaTotal: 131072 kB CmaFree: 128768 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB ### virtual memory: vm.admin_reserve_kbytes = 8192 vm.compaction_proactiveness = 20 vm.compact_unevictable_allowed = 1 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 vm.extfrag_threshold = 500 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 vm.min_free_kbytes = 22528 vm.min_slab_ratio = 5 vm.min_unmapped_ratio = 1 vm.mmap_min_addr = 32768 vm.mmap_rnd_bits = 18 vm.mmap_rnd_compat_bits = 11 vm.nr_hugepages = 0 vm.nr_hugepages_mempolicy = 0 vm.nr_overcommit_hugepages = 0 vm.numa_stat = 1 vm.numa_zonelist_order = Node vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 vm.panic_on_oom = 0 vm.percpu_pagelist_high_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 63009 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 vm.zone_reclaim_mode = 0 ### ip addr: 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 02:07:29:30:86:8c brd ff:ff:ff:ff:ff:ff 3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 00:32:c3:9f:6a:08 brd ff:ff:ff:ff:ff:ff ### partitions: major minor #blocks name 179 0 31205376 mmcblk0 179 1 6500352 mmcblk0p1 179 32 7634944 mmcblk2 252 0 1018652 zram0 252 1 51200 zram1 ### df: tmpfs 199M 3.4M 196M 2% /run /dev/mmcblk0p1 6.0G 4.9G 1.1G 83% / tmpfs 995M 0 995M 0% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 995M 0 995M 0% /tmp /dev/zram1 47M 1.6M 42M 4% /var/log ### lsblk: NAME FSTYPE SIZE MOUNTPOINT UUID mmcblk0 29.8G └─mmcblk0p1 ext4 6.2G / 71b44a6c-5bb8-4352-afe7-d22b8e62de4c mmcblk2 swap 7.3G 6a6f4ef8-bcc6-4021-a70f-de04ada07a25 mmcblk2boot0 swap 4M 6a6f4ef8-bcc6-4021-a70f-de04ada07a25 mmcblk2boot1 swap 4M 6a6f4ef8-bcc6-4021-a70f-de04ada07a25 zram1 50M /var/log zram2 0B ### zramctl: NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 50M 68K 728B 44K 4 /var/log /dev/zram0 lzo-rle 994.8M 4K 74B 12K 4 [SWAP] ### mtab: /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 ### [resize2fs] Leaving 1% spare area. Start resizing partition /dev/mmcblk0p1 now: major minor #blocks name 179 0 31205376 mmcblk0 179 1 6500352 mmcblk0p1 179 32 7634944 mmcblk2 252 0 1018652 zram0 252 1 51200 zram1 Executing fdisk, fsck and partprobe: Welcome to fdisk (util-linux 2.37.2). Changes will remain in memory only, until you decide to write them. Be careful before using the write command. This disk is currently in use - repartitioning is probably a bad idea. It's recommended to umount all file systems, and swapoff all swap partitions on this disk. Command (m for help): Selected partition 1 Partition 1 has been deleted. Command (m for help): Partition type p primary (0 primary, 0 extended, 4 free) e extended (container for logical partitions) Select (default p): Partition number (1-4, default 1): First sector (2048-62410751, default 2048): Last sector, +/-sectors or +/-size{K,M,G,T,P} (8192-62410751, default 62410751): Created a new partition 1 of type 'Linux' and of size 29.4 GiB. Partition #1 contains a ext4 signature. Command (m for help): ### mmc0:0001 info: fwrev: 0x0 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=USD MODALIAS=mmc:block cid: 1d414455534400001000005ae0016181 rca: 0x0001 csd: 400e00325b590000ee137f800a40004d manfid: 0x00001d ocr: 0x00200000 preferred_erase_size: 4194304 type: SD hwrev: 0x1 date: 01/2022 dsr: 0x404 The partition table has been altered. Syncing disks. erase_size: 512 oemid: 0x4144 serial: 0x00005ae0 ssr: 000000000500000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000 scr: 02b5808200000000 name: USD ### mmc2:0001 info: fwrev: 0x0600000000000000 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=8GTF4R MODALIAS=mmc:block New partition table: cid: 15010038475446345206d410e21fc801 major minor #blocks name 179 0 31205376 mmcblk0 179 1 30879744 mmcblk0p1 179 32 7634944 mmcblk2 252 0 1018652 zram0 252 1 51200 zram1 Now trying to resize ext4 filesystem on /dev/mmcblk0p1 to the limits: rel_sectors: 0x1 resize2fs 1.46.5 (30-Dec-2021) enhanced_rpmb_supported: 0x1 rca: 0x0001 pre_eol_info: 0x01 csd: d02701320f5903fff6dbffef8e40400d manfid: 0x000015 ocr: 0x00200000 preferred_erase_size: 4194304 enhanced_area_offset: 18446744073709551594 raw_rpmb_size_mult: 0x4 type: MMC hwrev: 0x0 date: 12/2021 prv: 0x6 ffu_capable: 1 dsr: 0x404 erase_size: 524288 life_time: 0x01 0x01 enhanced_area_size: 4294967274 oemid: 0x0100 serial: 0xd410e21f cmdq_en: 0 rev: 0x8 name: 8GTF4R ### Boot system health: Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 03:13:49: 1080MHz 1.34 51% 19% 13% 0% 18% 0% 49.3°C 0/9 03:13:50: 1080MHz 1.71 53% 7% 3% 0% 42% 0% 48.5°C 0/9 03:13:50: 1488MHz 1.71 35% 9% 2% 0% 22% 0% 48.7°C 0/9 03:13:50: 1080MHz 1.71 32% 8% 2% 0% 20% 0% 48.7°C 0/9 03:13:51: 1080MHz 1.71 35% 8% 4% 1% 21% 0% 49.1°C 0/9 Filesystem at /dev/mmcblk0p1 is mounted on /; on-line resizing required old_desc_blocks = 1, new_desc_blocks = 2 The filesystem on /dev/mmcblk0p1 is now 7719936 (4k) blocks long. ### [resize2fs] Start resizing ext4 partition /dev/mmcblk0p1 now resize2fs 1.46.5 (30-Dec-2021) The filesystem is already 7719936 (4k) blocks long. Nothing to do! ### quick iozone test: 4 144 824 6811 6817 6446 2242 ### [firstrun] Recreated SSH keys (entropy: 256 256) ### Activated 1 lzo-rle zram swap devices with 994MB each. ### Activated Armbian ramlog partition with zstd compression Thu Jun 23 11:40:42 AM CST 2022 | Orange Pi 3 LTS | 22.05.3 | arm64 | aarch64 | 5.15.48-sunxi64 ### dmesg: [ 1.272840] i2c_dev: i2c /dev entries driver [ 1.273687] sunxi-wdt 7020400.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 1.275263] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pm not found, using dummy regulator [ 1.275681] sdhci: Secure Digital Host Controller Interface driver [ 1.275689] sdhci: Copyright(c) Pierre Ossman [ 1.275714] Synopsys Designware Multimedia Card Interface Driver [ 1.276505] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.276668] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator [ 1.277837] ledtrig-cpu: registered to indicate activity on CPUs [ 1.278440] sun8i-ce 1904000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz) [ 1.278705] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.278843] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.278941] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.279034] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.279118] sun8i-ce 1904000.crypto: Register cbc(aes) [ 1.279270] sun8i-ce 1904000.crypto: Register ecb(aes) [ 1.279382] sun8i-ce 1904000.crypto: Register cbc(des3_ede) [ 1.279491] sun8i-ce 1904000.crypto: Register ecb(des3_ede) [ 1.279598] sun8i-ce 1904000.crypto: Register md5 [ 1.279710] sun8i-ce 1904000.crypto: Register sha1 [ 1.279822] sun8i-ce 1904000.crypto: Register sha224 [ 1.279933] sun8i-ce 1904000.crypto: Register sha256 [ 1.280039] sun8i-ce 1904000.crypto: Register sha384 [ 1.280147] sun8i-ce 1904000.crypto: Register sha512 [ 1.280254] sun8i-ce 1904000.crypto: Register stdrng [ 1.280979] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0 [ 1.281617] hid: raw HID events driver (C) Jiri Kosina [ 1.281760] usbcore: registered new interface driver usbhid [ 1.281768] usbhid: USB HID core driver [ 1.282505] random: crng init done [ 1.284692] NET: Registered PF_INET6 protocol family [ 1.870669] Freeing initrd memory: 12684K [ 1.899337] Segment Routing with IPv6 [ 1.899410] In-situ OAM (IOAM) with IPv6 [ 1.899505] NET: Registered PF_PACKET protocol family [ 1.899615] 8021q: 802.1Q VLAN Support v1.8 [ 1.899772] 9pnet: Installing 9P2000 support [ 1.899846] Key type dns_resolver registered [ 1.900287] registered taskstats version 1 [ 1.900304] Loading compiled-in X.509 certificates [ 1.904160] Loaded X.509 cert 'Build time autogenerated kernel key: 32330adefd2da02e444296fafd37464380789679' [ 1.907062] zswap: loaded using pool zstd/z3fold [ 1.907708] Key type ._fscrypt registered [ 1.907716] Key type .fscrypt registered [ 1.907721] Key type fscrypt-provisioning registered [ 1.908736] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no [ 1.922610] Key type encrypted registered [ 1.922643] AppArmor: AppArmor sha1 policy hashing enabled [ 1.922683] ima: No TPM chip found, activating TPM-bypass! [ 1.922711] ima: Allocated hash algorithm: sha1 [ 1.922743] ima: No architecture policies found [ 1.922791] evm: Initialising EVM extended attributes: [ 1.922796] evm: security.selinux [ 1.922800] evm: security.SMACK64 [ 1.922805] evm: security.SMACK64EXEC [ 1.922809] evm: security.SMACK64TRANSMUTE [ 1.922813] evm: security.SMACK64MMAP [ 1.922818] evm: security.apparmor [ 1.922822] evm: security.ima [ 1.922826] evm: security.capability [ 1.922830] evm: HMAC attrs: 0x1 [ 1.935894] platform 1100000.mixer: Fixing up cyclic dependency with 6510000.tcon-top [ 1.936246] sun8i-mixer 1100000.mixer: Adding to iommu group 0 [ 1.938307] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 1.938338] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 1.938483] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f064 hci version 0x100 quirks 0x0000000002010010 [ 1.938551] xhci-hcd xhci-hcd.1.auto: irq 43, io mem 0x05200000 [ 1.939042] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 1.939058] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.939069] usb usb1: Product: xHCI Host Controller [ 1.939077] usb usb1: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd [ 1.939086] usb usb1: SerialNumber: xhci-hcd.1.auto [ 1.939617] hub 1-0:1.0: USB hub found [ 1.939666] hub 1-0:1.0: 1 port detected [ 1.940002] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 1.940022] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2 [ 1.940045] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 1.940139] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.940297] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15 [ 1.940310] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.940321] usb usb2: Product: xHCI Host Controller [ 1.940329] usb usb2: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd [ 1.940337] usb usb2: SerialNumber: xhci-hcd.1.auto [ 1.940741] hub 2-0:1.0: USB hub found [ 1.940778] hub 2-0:1.0: 1 port detected [ 1.943495] sun50i_cpufreq_nvmem: Using CPU speed bin speed0 [ 1.945277] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version [ 1.951649] of_cfs_init [ 1.951764] of_cfs_init: OK [ 1.952094] ALSA device list: [ 1.952101] No soundcards found. [ 1.953207] Freeing unused kernel memory: 2496K [ 1.977591] Run /init as init process [ 1.977600] with arguments: [ 1.977606] /init [ 1.977612] with environment: [ 1.977616] HOME=/ [ 1.977621] TERM=linux [ 1.977626] ubootpart=ce3dfe46-01 [ 1.977631] cgroup_enable=memory [ 2.193555] usb 1-1: new full-speed USB device number 2 using xhci-hcd [ 2.359296] usb 1-1: New USB device found, idVendor=045e, idProduct=0745, bcdDevice= 6.33 [ 2.359334] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.359345] usb 1-1: Product: Microsoft® 2.4GHz Transceiver v7.0 [ 2.359353] usb 1-1: Manufacturer: Microsoft [ 2.380572] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.0/0003:045E:0745.0001/input/input0 [ 2.405951] axp20x-i2c 0-0036: AXP20x variant AXP806 found [ 2.416250] input: axp20x-pek as /devices/platform/soc/7081400.i2c/i2c-0/0-0036/axp221-pek/input/input1 [ 2.440095] hid-generic 0003:045E:0745.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input0 [ 2.444209] vdd-cpu: supplied by vcc-5v [ 2.445995] vdd-gpu: supplied by vcc-5v [ 2.446737] vdd-sys: Bringing 900000uV into 960000-960000uV [ 2.447163] vdd-sys: supplied by vcc-5v [ 2.448220] vcc-dram: supplied by vcc-5v [ 2.449137] vcc-pl-led-ir: supplied by vcc-5v [ 2.450174] vcc33-audio-tv-ephy-mac: Bringing 700000uV into 3300000-3300000uV [ 2.450587] vcc33-audio-tv-ephy-mac: supplied by vcc-5v [ 2.457417] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Mouse as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input2 [ 2.458172] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input3 [ 2.517969] hid-generic 0003:045E:0745.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input1 [ 2.530047] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input4 [ 2.558277] vcc33-io-pd-emmc-sd-usb-uart-1: Bringing 700000uV into 3300000-3300000uV [ 2.558638] vcc33-io-pd-emmc-sd-usb-uart-1: supplied by vcc-5v [ 2.559627] vcc18-dram-bias-pll: supplied by vcc-5v [ 2.560734] vcc-efuse-pcie-hdmi-pc: supplied by vcc-5v [ 2.561386] vcc-wifi-io-pm-pg: Bringing 700000uV into 1800000-1800000uV [ 2.561719] vcc-wifi-io-pm-pg: supplied by vcc-5v [ 2.562819] bldo4: supplied by vcc-5v [ 2.563341] vcc33-io-pd-emmc-sd-usb-uart-2: supplied by vcc-5v [ 2.564136] cldo2: supplied by vcc-5v [ 2.564801] cldo3: supplied by vcc-5v [ 2.565035] sw: supplied by regulator-dummy [ 2.565598] axp20x-i2c 0-0036: AXP20X driver loaded [ 2.579120] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver [ 2.579642] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pb not found, using dummy regulator [ 2.580524] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator [ 2.581205] printk: console [ttyS0] disabled [ 2.581316] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 35, base_baud = 1500000) is a 16550A [ 2.581600] printk: console [ttyS0] enabled [ 2.582895] sun4i-drm display-engine: Adding to iommu group 0 [ 2.589957] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 System Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input6 [ 2.590397] hid-generic 0003:045E:0745.0003: input,hiddev96,hidraw2: USB HID v1.11 Device [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input2 [ 2.602524] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e16990) [ 2.602880] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800008e1abb8) [ 2.603276] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff800008e11ba0) [ 2.603403] sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator [ 2.603905] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY) [ 2.604269] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 2.608442] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver [ 2.608956] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff800008e15cc8) [ 2.609998] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 [ 2.610059] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 1 [ 2.766758] Console: switching to colour frame buffer device 240x67 [ 2.816582] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device [ 2.837317] acx00-codec acx00-codec: DMA mask not set [ 2.841040] vcc-wifi-io: supplied by vcc33-wifi [ 2.841454] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator [ 2.842711] sunxi-mmc 4020000.mmc: Got CD GPIO [ 2.846375] ehci-platform 5101000.usb: EHCI Host Controller [ 2.846421] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 3 [ 2.846575] ehci-platform 5101000.usb: irq 41, io mem 0x05101000 [ 2.848622] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq [ 2.865562] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00 [ 2.865575] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 2.865860] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 2.865911] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 2.865925] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.865936] usb usb3: Product: EHCI Host Controller [ 2.865945] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd [ 2.865953] usb usb3: SerialNumber: 5101000.usb [ 2.866566] hub 3-0:1.0: USB hub found [ 2.866635] hub 3-0:1.0: 1 port detected [ 2.867969] ehci-platform 5311000.usb: EHCI Host Controller [ 2.868052] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 4 [ 2.868209] ehci-platform 5311000.usb: irq 44, io mem 0x05311000 [ 2.881527] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00 [ 2.881876] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 2.881891] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.881901] usb usb4: Product: EHCI Host Controller [ 2.881914] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd [ 2.881923] usb usb4: SerialNumber: 5311000.usb [ 2.882497] hub 4-0:1.0: USB hub found [ 2.882543] hub 4-0:1.0: 1 port detected [ 2.883659] ohci-platform 5101400.usb: Generic Platform OHCI controller [ 2.883696] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 5 [ 2.883846] ohci-platform 5101400.usb: irq 42, io mem 0x05101400 [ 2.901121] mmc0: host does not support reading read-only switch, assuming write-enable [ 2.902890] mmc0: Problem switching card into high-speed mode! [ 2.903010] mmc0: new SDHC card at address 0001 [ 2.903892] mmcblk0: mmc0:0001 USD 29.8 GiB [ 2.905998] mmcblk0: p1 [ 2.945815] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15 [ 2.945843] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.945853] usb usb5: Product: Generic Platform OHCI controller [ 2.945862] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd [ 2.945870] usb usb5: SerialNumber: 5101400.usb [ 2.946508] hub 5-0:1.0: USB hub found [ 2.946564] hub 5-0:1.0: 1 port detected [ 2.947693] ohci-platform 5311400.usb: Generic Platform OHCI controller [ 2.947732] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 6 [ 2.947873] ohci-platform 5311400.usb: irq 45, io mem 0x05311400 [ 3.005682] mmc2: new HS200 MMC card at address 0001 [ 3.006689] mmcblk2: mmc2:0001 8GTF4R 7.28 GiB [ 3.009191] mmcblk2boot0: mmc2:0001 8GTF4R 4.00 MiB [ 3.009899] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15 [ 3.009929] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.009940] usb usb6: Product: Generic Platform OHCI controller [ 3.009949] usb usb6: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd [ 3.009957] usb usb6: SerialNumber: 5311400.usb [ 3.010742] hub 6-0:1.0: USB hub found [ 3.010820] hub 6-0:1.0: 1 port detected [ 3.011003] mmcblk2boot1: mmc2:0001 8GTF4R 4.00 MiB [ 3.012287] usb_phy_generic usb_phy_generic.4.auto: supply vcc not found, using dummy regulator [ 3.012471] usb_phy_generic usb_phy_generic.4.auto: dummy supplies not allowed for exclusive requests [ 3.078113] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 3.095714] mmc1: new high speed SDIO card at address 8800 [ 3.109911] musb-hdrc musb-hdrc.5.auto: MUSB HDRC host driver [ 3.109956] musb-hdrc musb-hdrc.5.auto: new USB bus registered, assigned bus number 7 [ 3.110288] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 3.110305] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.110316] usb usb7: Product: MUSB HDRC host driver [ 3.110324] usb usb7: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd [ 3.110333] usb usb7: SerialNumber: musb-hdrc.5.auto [ 3.110923] hub 7-0:1.0: USB hub found [ 3.110989] hub 7-0:1.0: 1 port detected [ 3.127115] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found [ 3.127143] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found [ 3.127455] dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator [ 3.127695] dwmac-sun8i 5020000.ethernet: PTP uses main clock [ 3.127740] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 50000) [ 3.233767] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported [ 3.233793] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported [ 3.233800] dwmac-sun8i 5020000.ethernet: COE Type 2 [ 3.233809] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported [ 3.233817] dwmac-sun8i 5020000.ethernet: Normal descriptors [ 3.233824] dwmac-sun8i 5020000.ethernet: Chain mode enabled [ 3.470451] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none. [ 3.693548] usb 5-1: new full-speed USB device number 2 using ohci-platform [ 3.934574] usb 5-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.10 [ 3.934605] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.934616] usb 5-1: Product: USB Receiver [ 3.934624] usb 5-1: Manufacturer: Logitech [ 3.943645] input: Logitech USB Receiver as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.0/0003:046D:C52B.0004/input/input7 [ 4.002215] hid-generic 0003:046D:C52B.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-5101400.usb-1/input0 [ 4.008419] input: Logitech USB Receiver Mouse as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input8 [ 4.008877] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input9 [ 4.065886] input: Logitech USB Receiver System Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input10 [ 4.066269] hid-generic 0003:046D:C52B.0005: input,hiddev97,hidraw4: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-5101400.usb-1/input1 [ 4.070836] hid-generic 0003:046D:C52B.0006: hiddev98,hidraw5: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2 [ 4.842234] systemd[1]: System time before build time, advancing clock. [ 4.939393] systemd[1]: systemd 249.11-0ubuntu3.1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS -OPENSSL +ACL +BLKID +CURL +ELFUTILS -FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP -LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 4.940061] systemd[1]: Detected architecture arm64. [ 4.943463] systemd[1]: Hostname set to <orangepi3-lts>. [ 6.280645] systemd[1]: Queued start job for default target Graphical Interface. [ 6.286592] systemd[1]: Created slice Slice /system/modprobe. [ 6.289331] systemd[1]: Created slice Slice /system/serial-getty. [ 6.291295] systemd[1]: Created slice User and Session Slice. [ 6.292193] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 6.293712] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 6.294623] systemd[1]: Reached target Remote File Systems. [ 6.294972] systemd[1]: Reached target Slice Units. [ 6.295321] systemd[1]: Reached target Swaps. [ 6.295639] systemd[1]: Reached target System Time Set. [ 6.296162] systemd[1]: Reached target Local Verity Protected Volumes. [ 6.297245] systemd[1]: Listening on Syslog Socket. [ 6.298236] systemd[1]: Listening on fsck to fsckd communication Socket. [ 6.298936] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 6.300397] systemd[1]: Listening on Journal Audit Socket. [ 6.301308] systemd[1]: Listening on Journal Socket (/dev/log). [ 6.302450] systemd[1]: Listening on Journal Socket. [ 6.314214] systemd[1]: Listening on udev Control Socket. [ 6.315305] systemd[1]: Listening on udev Kernel Socket. [ 6.319750] systemd[1]: Mounting Huge Pages File System... [ 6.324879] systemd[1]: Mounting POSIX Message Queue File System... [ 6.330662] systemd[1]: Mounting Kernel Debug File System... [ 6.331975] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 6.339409] systemd[1]: Starting Restore / save the current clock... [ 6.345147] systemd[1]: Starting Set the console keyboard layout... [ 6.351732] systemd[1]: Starting Create List of Static Device Nodes... [ 6.358465] systemd[1]: Starting Load Kernel Module configfs... [ 6.365077] systemd[1]: Starting Load Kernel Module drm... [ 6.371961] systemd[1]: Starting Load Kernel Module fuse... [ 6.379481] systemd[1]: Started Nameserver information manager. [ 6.380900] systemd[1]: Reached target Preparation for Network. [ 6.382190] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 6.395121] systemd[1]: Starting Load Kernel Modules... [ 6.401214] systemd[1]: Starting Remount Root and Kernel File Systems... [ 6.407382] systemd[1]: Starting Coldplug All udev Devices... [ 6.419152] systemd[1]: Mounted Huge Pages File System. [ 6.420837] systemd[1]: Mounted POSIX Message Queue File System. [ 6.422359] systemd[1]: Mounted Kernel Debug File System. [ 6.425432] systemd[1]: Finished Restore / save the current clock. [ 6.425773] fuse: init (API version 7.34) [ 6.428513] systemd[1]: Finished Create List of Static Device Nodes. [ 6.431938] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 6.433283] systemd[1]: Finished Load Kernel Module configfs. [ 6.435491] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 6.436886] systemd[1]: Finished Load Kernel Module drm. [ 6.439563] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 6.440948] systemd[1]: Finished Load Kernel Module fuse. [ 6.447052] systemd[1]: Mounting FUSE Control File System... [ 6.452353] systemd[1]: Mounting Kernel Configuration File System... [ 6.459715] systemd[1]: Mounted FUSE Control File System. [ 6.466857] systemd[1]: Mounted Kernel Configuration File System. [ 6.475597] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none. [ 6.481220] systemd[1]: Finished Remount Root and Kernel File Systems. [ 6.482545] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 6.487218] systemd[1]: Starting Load/Save Random Seed... [ 6.493049] systemd[1]: Starting Create System Users... [ 6.672733] WCN: marlin_init entry! [ 6.673295] WCN: wcn config bt wake host [ 6.673640] WCN_ERR: dts node for bt_wake not found [ 6.673650] WCN: marlin2 parse_dt some para not config [ 6.673674] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840 [ 6.678896] sdiohal:sdiohal_init ok [ 6.679750] systemd[1]: Finished Load/Save Random Seed. [ 6.679837] WCN: marlin_probe ok! [ 6.680959] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 6.701362] systemd[1]: Finished Create System Users. [ 6.703749] mtty_probe init device addr: 0x00000000fe1f7fb4 [ 6.703958] -->rfkill_bluetooth_init [ 6.704103] bluetooth_set_power: start_block=1 [ 6.704117] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0 [ 6.704127] bluetooth_set_power: end_block=1 [ 6.704144] <--rfkill_bluetooth_init [ 6.708485] systemd[1]: Starting Create Static Device Nodes in /dev... [ 6.792500] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 6.794213] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 6.815600] [ADDR_MGT] addr_mgt_probe: module version: v1.0.9 [ 6.815713] [ADDR_MGT] addr_mgt_probe: success. [ 6.820941] systemd[1]: Finished Set the console keyboard layout. [ 6.882354] WCN: start_marlin [MARLIN_WIFI] [ 6.882379] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1 [ 6.882388] WCN: the first power on start [ 6.885320] systemd[1]: Finished Create Static Device Nodes in /dev. [ 6.892712] systemd[1]: Reached target Preparation for Local File Systems. [ 6.905003] systemd[1]: Mounting /tmp... [ 6.919680] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 6.930260] systemd[1]: Mounted /tmp. [ 6.937592] systemd[1]: Reached target Local File Systems. [ 6.949729] systemd[1]: Starting Armbian leds state... [ 6.962125] systemd[1]: Starting Armbian ZRAM config... [ 6.974560] systemd[1]: Starting Set console font and keymap... [ 6.986826] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 6.989569] WCN: marlin chip en dummy pull up -- need manually set GPIO [ 7.012697] systemd[1]: Starting Set Up Additional Binary Formats... [ 7.017639] sdiohal:sdiohal_scan_card [ 7.017848] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=50000000 [ 7.017940] WCN: marlin_scan_finish! [ 7.017944] sdiohal:probe ok [ 7.018067] sdiohal:scan end! [ 7.018073] WCN: then marlin start to download [ 7.018305] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001 [ 7.018318] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start! [ 7.021202] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 7.021629] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 7.024765] systemd[1]: Finished Set console font and keymap. [ 7.035619] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 366 (systemd-binfmt) [ 7.043152] systemd[1]: Mounting Arbitrary Executable File Formats File System... [ 7.060577] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 7.072721] systemd[1]: Finished Coldplug All udev Devices. [ 7.167303] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 7.177862] systemd[1]: Mounted Arbitrary Executable File Formats File System. [ 7.199741] systemd[1]: Finished Set Up Additional Binary Formats. [ 7.228170] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 7.301685] systemd[1]: Finished Armbian leds state. [ 7.582111] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 7.589917] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 7.590620] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active. [ 7.601725] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 7.601909] systemd[1]: Reached target Local Encrypted Volumes. [ 7.649290] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 7.693825] systemd[1]: Starting Load/Save RF Kill Switch Status... [ 7.870964] bluetooth_set_power: start_block=0 [ 7.870991] WCN: start_marlin [MARLIN_BLUETOOTH] [ 8.041648] systemd[1]: Found device /dev/ttyS0. [ 8.075381] WCN: combin_img 0 marlin_firmware_write finish and successful [ 8.075778] WCN: marlin_start_run read reset reg val:0x1 [ 8.075797] WCN: after do marlin_start_run reset reg val:0x0 [ 8.076026] WCN: s_marlin_bootup_time=8076026176 [ 8.081928] WCN: clock mode: TSX [ 8.082132] WCN: marlin_write_cali_data sync init_state:0x0 [ 8.109796] WCN: marlin_write_cali_data sync init_state:0x0 [ 8.137839] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1 [ 8.137866] WCN: sdio_config bt_wake_host trigger:[high] [ 8.137869] WCN: sdio_config irq:[inband] [ 8.137871] WCN: sdio_config wake_host_level_duration_time:[20ms] [ 8.137876] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse] [ 8.137878] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config) [ 8.138205] WCN: marlin_write_cali_data finish [ 8.138370] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.157809] panfrost 1800000.gpu: clock rate = 432000000 [ 8.157843] panfrost 1800000.gpu: bus_clock rate = 100000000 [ 8.158153] panfrost 1800000.gpu: mali-t720 id 0x720 major 0x1 minor 0x1 status 0x0 [ 8.158164] panfrost 1800000.gpu: features: 00000000,10309e40, issues: 00000000,21054400 [ 8.158170] panfrost 1800000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002821 AS:0xf JS:0x7 [ 8.158178] panfrost 1800000.gpu: shader_present=0x3 l2_present=0x1 [ 8.159096] [drm] Initialized panfrost 1.2.0 20180908 for 1800000.gpu on minor 1 [ 8.165839] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.179510] mc: Linux media interface: v0.10 [ 8.193765] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.221809] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.249807] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0 [ 8.249830] WCN: marlin_bind_verify confuse data: 0x70f591d68e01b18d315da6e670879a4a [ 8.249845] WCN: marlin_bind_verify verify data: 0xa5709470f0031226394ebee725230b0c [ 8.250344] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0 [ 8.277783] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0 [ 8.277802] sdiohal:sdiohal_runtime_get entry [ 8.277980] WCN: get_cp2_version entry! [ 8.299009] videodev: Linux video capture interface: v2.00 [ 8.317158] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~ [ 8.317230] WCN: switch_cp2_log - close entry! [ 8.318674] WCN: WCND at cmd read:OK [ 8.318761] WCN: then marlin download finished and run ok [ 8.318778] WCN: start_loopcheck [ 8.318884] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1 [ 8.318895] WCN: marlin have open, GNSS is closed [ 8.318899] bluetooth_set_power: end_block=0 [ 8.320107] systemd[1]: Started Load/Save RF Kill Switch Status. [ 8.324478] zram: Added device: zram0 [ 8.325230] zram: Added device: zram1 [ 8.326075] zram: Added device: zram2 [ 8.354162] WCN: get_board_ant_num [one_ant] [ 8.354186] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini [ 8.365170] Registered IR keymap rc-empty [ 8.365298] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0 [ 8.366074] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter [ 8.366236] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input12 [ 8.378494] sunxi-ir 7040000.ir: initialized sunXi IR driver [ 8.434915] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings. [ 8.448849] systemd[1]: Finished Load Kernel Modules. [ 8.458292] systemd[1]: Starting Apply Kernel Variables... [ 8.514088] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. [ 8.515483] cedrus 1c0e000.video-codec: Adding to iommu group 0 [ 8.518502] cedrus 1c0e000.video-codec: Device registered as /dev/video0 [ 8.567882] zram0: detected capacity change from 0 to 2037304 [ 8.631035] Adding 1018648k swap on /dev/zram0. Priority:5 extents:1 across:1018648k SSFS [ 8.653605] systemd[1]: Finished Apply Kernel Variables. [ 8.681160] systemd[1]: Starting Raise network interfaces... [ 8.791511] logitech-djreceiver 0003:046D:C52B.0006: hiddev97,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2 [ 8.853254] zram1: detected capacity change from 0 to 102400 [ 8.977295] input: Logitech Wireless Device PID:4004 Keyboard as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input13 [ 9.045252] systemd[1]: Finished Armbian ZRAM config. [ 9.054870] hid-generic 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4004] on usb-5101400.usb-1/input2:1 [ 9.055168] systemd[1]: Starting Armbian memory supported logging... [ 9.169531] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none. [ 9.215009] input: Logitech K360 as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input17 [ 9.215550] logitech-hidpp-device 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K360] on usb-5101400.usb-1/input2:1 [ 9.699754] systemd[1]: Finished Raise network interfaces. [ 9.731709] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 9.732012] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 9.732412] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 9.738645] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 9.738778] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 9.738913] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 9.739051] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 9.894684] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 9.894922] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 9.894994] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 9.895091] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 9.895204] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 9.895323] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 11.563278] systemd[1]: Finished Armbian memory supported logging. [ 11.572525] systemd[1]: Starting Journal Service... [ 11.714105] systemd[1]: Started Journal Service. [ 11.743225] systemd-journald[691]: Received client request to flush runtime journal. ### armbian-release: # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi3-lts BOARD_NAME="Orange Pi 3 LTS" BOARDFAMILY=sun50iw6 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=13f5fba13c VERSION=22.05.3 LINUXFAMILY=sunxi64 ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=stable BRANCH=current ### boot environment: verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun50i-h6 rootdev=UUID=71b44a6c-5bb8-4352-afe7-d22b8e62de4c rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u ### lsusb: Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ### lscpu: Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 4 On-line CPU(s) list: 0-3 Vendor ID: ARM Model name: Cortex-A53 Model: 4 Thread(s) per core: 1 Core(s) per cluster: 4 Socket(s): - Cluster(s): 1 Stepping: r0p4 CPU max MHz: 1800.0000 CPU min MHz: 480.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid NUMA node(s): 1 NUMA node0 CPU(s): 0-3 Vulnerability Itlb multihit: Not affected Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Spec store bypass: Not affected Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Not affected Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected ### cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 1 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 2 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 3 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 ### meminfo: MemTotal: 2037300 kB MemFree: 1847312 kB MemAvailable: 1852580 kB Buffers: 12528 kB Cached: 52716 kB SwapCached: 0 kB Active: 32252 kB Inactive: 53072 kB Active(anon): 440 kB Inactive(anon): 22936 kB Active(file): 31812 kB Inactive(file): 30136 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 1018648 kB SwapFree: 1018648 kB Dirty: 2404 kB Writeback: 0 kB AnonPages: 20120 kB Mapped: 16908 kB Shmem: 3384 kB KReclaimable: 10544 kB Slab: 46252 kB SReclaimable: 10544 kB SUnreclaim: 35708 kB KernelStack: 2480 kB PageTables: 1508 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 2037296 kB Committed_AS: 42864 kB VmallocTotal: 133143592960 kB VmallocUsed: 22732 kB VmallocChunk: 0 kB Percpu: 976 kB AnonHugePages: 0 kB ShmemHugePages: 0 kB ShmemPmdMapped: 0 kB FileHugePages: 0 kB FilePmdMapped: 0 kB CmaTotal: 131072 kB CmaFree: 128768 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB ### virtual memory: vm.admin_reserve_kbytes = 8192 vm.compaction_proactiveness = 20 vm.compact_unevictable_allowed = 1 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 vm.extfrag_threshold = 500 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 vm.min_free_kbytes = 22528 vm.min_slab_ratio = 5 vm.min_unmapped_ratio = 1 vm.mmap_min_addr = 32768 vm.mmap_rnd_bits = 18 vm.mmap_rnd_compat_bits = 11 vm.nr_hugepages = 0 vm.nr_hugepages_mempolicy = 0 vm.nr_overcommit_hugepages = 0 vm.numa_stat = 1 vm.numa_zonelist_order = Node vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 vm.panic_on_oom = 0 vm.percpu_pagelist_high_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 63007 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 vm.zone_reclaim_mode = 0 ### ip addr: 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 02:07:29:30:86:8c brd ff:ff:ff:ff:ff:ff 3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 00:32:c3:9f:6a:08 brd ff:ff:ff:ff:ff:ff ### partitions: major minor #blocks name 179 0 31205376 mmcblk0 179 1 30879744 mmcblk0p1 179 32 7634944 mmcblk2 252 0 1018652 zram0 252 1 51200 zram1 ### df: tmpfs 199M 3.4M 196M 2% /run /dev/mmcblk0p1 29G 4.9G 24G 18% / tmpfs 995M 0 995M 0% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 995M 0 995M 0% /tmp /dev/zram1 47M 2.4M 42M 6% /var/log ### lsblk: NAME FSTYPE SIZE MOUNTPOINT UUID mmcblk0 29.8G └─mmcblk0p1 ext4 29.4G / 71b44a6c-5bb8-4352-afe7-d22b8e62de4c mmcblk2 swap 7.3G 6a6f4ef8-bcc6-4021-a70f-de04ada07a25 mmcblk2boot0 swap 4M 6a6f4ef8-bcc6-4021-a70f-de04ada07a25 mmcblk2boot1 swap 4M 6a6f4ef8-bcc6-4021-a70f-de04ada07a25 zram1 50M /var/log zram2 0B ### zramctl: NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 50M 68K 721B 44K 4 /var/log /dev/zram0 lzo-rle 994.8M 4K 74B 12K 4 [SWAP] ### mtab: /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 ### mmc0:0001 info: fwrev: 0x0 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=USD MODALIAS=mmc:block cid: 1d414455534400001000005ae0016181 rca: 0x0001 csd: 400e00325b590000ee137f800a40004d manfid: 0x00001d ocr: 0x00200000 preferred_erase_size: 4194304 type: SD hwrev: 0x1 date: 01/2022 dsr: 0x404 erase_size: 512 oemid: 0x4144 serial: 0x00005ae0 ssr: 000000000500000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000 scr: 02b5808200000000 name: USD ### mmc2:0001 info: fwrev: 0x0600000000000000 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=8GTF4R MODALIAS=mmc:block cid: 15010038475446345206d410e21fc801 rel_sectors: 0x1 enhanced_rpmb_supported: 0x1 rca: 0x0001 pre_eol_info: 0x01 csd: d02701320f5903fff6dbffef8e40400d manfid: 0x000015 ocr: 0x00200000 preferred_erase_size: 4194304 enhanced_area_offset: 18446744073709551594 raw_rpmb_size_mult: 0x4 type: MMC hwrev: 0x0 date: 12/2021 prv: 0x6 ffu_capable: 1 dsr: 0x404 erase_size: 524288 life_time: 0x01 0x01 enhanced_area_size: 4294967274 oemid: 0x0100 serial: 0xd410e21f cmdq_en: 0 rev: 0x8 name: 8GTF4R ### Boot system health: Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 11:40:44: 1320MHz 0.23 46% 19% 13% 0% 12% 0% 63.6°C 0/9 11:40:44: 888MHz 0.23 12% 8% 2% 1% 0% 0% 63.6°C 0/9 11:40:44: 1080MHz 0.23 12% 9% 2% 0% 0% 0% 58.2°C 0/9 11:40:45: 1800MHz 0.23 12% 6% 4% 1% 0% 0% 58.3°C 0/9 11:40:45: 1800MHz 0.23 14% 9% 2% 1% 0% 0% 59.3°C 0/9 ### Activated 1 lzo-rle zram swap devices with 994MB each. ### Activated Armbian ramlog partition with zstd compression Thu Jun 23 11:48:16 AM CST 2022 | Orange Pi 3 LTS | 22.05.3 | arm64 | aarch64 | 5.15.48-sunxi64 ### dmesg: [ 1.272120] ohci-platform: OHCI generic platform driver [ 1.272614] usbcore: registered new interface driver usb-storage [ 1.273128] mousedev: PS/2 mouse device common for all mice [ 1.274160] sun6i-rtc 7000000.rtc: registered as rtc0 [ 1.274198] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-01T00:07:55 UTC (475) [ 1.274306] sun6i-rtc 7000000.rtc: RTC enabled [ 1.274449] i2c_dev: i2c /dev entries driver [ 1.275241] sunxi-wdt 7020400.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 1.276799] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pm not found, using dummy regulator [ 1.277224] sdhci: Secure Digital Host Controller Interface driver [ 1.277234] sdhci: Copyright(c) Pierre Ossman [ 1.277258] Synopsys Designware Multimedia Card Interface Driver [ 1.278091] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.278268] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator [ 1.279331] ledtrig-cpu: registered to indicate activity on CPUs [ 1.279930] sun8i-ce 1904000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz) [ 1.280188] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.280330] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.280432] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.280526] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.280606] sun8i-ce 1904000.crypto: Register cbc(aes) [ 1.280754] sun8i-ce 1904000.crypto: Register ecb(aes) [ 1.280864] sun8i-ce 1904000.crypto: Register cbc(des3_ede) [ 1.280972] sun8i-ce 1904000.crypto: Register ecb(des3_ede) [ 1.281079] sun8i-ce 1904000.crypto: Register md5 [ 1.281186] sun8i-ce 1904000.crypto: Register sha1 [ 1.281293] sun8i-ce 1904000.crypto: Register sha224 [ 1.281401] sun8i-ce 1904000.crypto: Register sha256 [ 1.281507] sun8i-ce 1904000.crypto: Register sha384 [ 1.281665] sun8i-ce 1904000.crypto: Register sha512 [ 1.281777] sun8i-ce 1904000.crypto: Register stdrng [ 1.282517] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0 [ 1.283115] hid: raw HID events driver (C) Jiri Kosina [ 1.283240] usbcore: registered new interface driver usbhid [ 1.283247] usbhid: USB HID core driver [ 1.284060] random: crng init done [ 1.286213] NET: Registered PF_INET6 protocol family [ 1.870216] Freeing initrd memory: 12684K [ 1.898965] Segment Routing with IPv6 [ 1.899073] In-situ OAM (IOAM) with IPv6 [ 1.899164] NET: Registered PF_PACKET protocol family [ 1.899302] 8021q: 802.1Q VLAN Support v1.8 [ 1.899459] 9pnet: Installing 9P2000 support [ 1.899532] Key type dns_resolver registered [ 1.899974] registered taskstats version 1 [ 1.899990] Loading compiled-in X.509 certificates [ 1.903826] Loaded X.509 cert 'Build time autogenerated kernel key: 32330adefd2da02e444296fafd37464380789679' [ 1.906701] zswap: loaded using pool zstd/z3fold [ 1.907326] Key type ._fscrypt registered [ 1.907334] Key type .fscrypt registered [ 1.907338] Key type fscrypt-provisioning registered [ 1.908346] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no [ 1.922075] Key type encrypted registered [ 1.922109] AppArmor: AppArmor sha1 policy hashing enabled [ 1.922149] ima: No TPM chip found, activating TPM-bypass! [ 1.922177] ima: Allocated hash algorithm: sha1 [ 1.922209] ima: No architecture policies found [ 1.922282] evm: Initialising EVM extended attributes: [ 1.922286] evm: security.selinux [ 1.922291] evm: security.SMACK64 [ 1.922296] evm: security.SMACK64EXEC [ 1.922300] evm: security.SMACK64TRANSMUTE [ 1.922304] evm: security.SMACK64MMAP [ 1.922308] evm: security.apparmor [ 1.922312] evm: security.ima [ 1.922316] evm: security.capability [ 1.922320] evm: HMAC attrs: 0x1 [ 1.935478] platform 1100000.mixer: Fixing up cyclic dependency with 6510000.tcon-top [ 1.935838] sun8i-mixer 1100000.mixer: Adding to iommu group 0 [ 1.937884] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 1.937915] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 1.938068] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f064 hci version 0x100 quirks 0x0000000002010010 [ 1.938129] xhci-hcd xhci-hcd.1.auto: irq 43, io mem 0x05200000 [ 1.938581] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 1.938597] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.938607] usb usb1: Product: xHCI Host Controller [ 1.938615] usb usb1: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd [ 1.938624] usb usb1: SerialNumber: xhci-hcd.1.auto [ 1.939157] hub 1-0:1.0: USB hub found [ 1.939202] hub 1-0:1.0: 1 port detected [ 1.939537] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 1.939557] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2 [ 1.939576] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 1.939668] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.939826] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15 [ 1.939839] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.939849] usb usb2: Product: xHCI Host Controller [ 1.939857] usb usb2: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd [ 1.939866] usb usb2: SerialNumber: xhci-hcd.1.auto [ 1.940303] hub 2-0:1.0: USB hub found [ 1.940340] hub 2-0:1.0: 1 port detected [ 1.942990] sun50i_cpufreq_nvmem: Using CPU speed bin speed0 [ 1.944802] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version [ 1.951206] of_cfs_init [ 1.951337] of_cfs_init: OK [ 1.951677] ALSA device list: [ 1.951684] No soundcards found. [ 1.952785] Freeing unused kernel memory: 2496K [ 1.973623] Run /init as init process [ 1.973631] with arguments: [ 1.973637] /init [ 1.973643] with environment: [ 1.973647] HOME=/ [ 1.973652] TERM=linux [ 1.973657] ubootpart=ce3dfe46-01 [ 1.973662] cgroup_enable=memory [ 2.193601] usb 1-1: new full-speed USB device number 2 using xhci-hcd [ 2.346592] usb 1-1: New USB device found, idVendor=045e, idProduct=0745, bcdDevice= 6.33 [ 2.346627] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.346638] usb 1-1: Product: Microsoft® 2.4GHz Transceiver v7.0 [ 2.346646] usb 1-1: Manufacturer: Microsoft [ 2.367970] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.0/0003:045E:0745.0001/input/input0 [ 2.416093] axp20x-i2c 0-0036: AXP20x variant AXP806 found [ 2.429907] hid-generic 0003:045E:0745.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input0 [ 2.437381] input: axp20x-pek as /devices/platform/soc/7081400.i2c/i2c-0/0-0036/axp221-pek/input/input1 [ 2.446665] vdd-cpu: supplied by vcc-5v [ 2.449719] vdd-gpu: supplied by vcc-5v [ 2.450579] vdd-sys: supplied by vcc-5v [ 2.451449] vcc-dram: supplied by vcc-5v [ 2.453703] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Mouse as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input2 [ 2.454269] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input3 [ 2.456626] vcc-pl-led-ir: supplied by vcc-5v [ 2.457495] vcc33-audio-tv-ephy-mac: supplied by vcc-5v [ 2.513978] hid-generic 0003:045E:0745.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input1 [ 2.527597] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input4 [ 2.566336] vcc33-io-pd-emmc-sd-usb-uart-1: supplied by vcc-5v [ 2.567031] vcc18-dram-bias-pll: supplied by vcc-5v [ 2.568106] vcc-efuse-pcie-hdmi-pc: supplied by vcc-5v [ 2.568777] vcc-wifi-io-pm-pg: supplied by vcc-5v [ 2.569573] bldo4: supplied by vcc-5v [ 2.570101] vcc33-io-pd-emmc-sd-usb-uart-2: supplied by vcc-5v [ 2.570919] cldo2: supplied by vcc-5v [ 2.571561] cldo3: supplied by vcc-5v [ 2.571822] sw: supplied by regulator-dummy [ 2.572376] axp20x-i2c 0-0036: AXP20X driver loaded [ 2.578873] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver [ 2.579353] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pb not found, using dummy regulator [ 2.580357] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator [ 2.581186] printk: console [ttyS0] disabled [ 2.581302] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 35, base_baud = 1500000) is a 16550A [ 2.581573] printk: console [ttyS0] enabled [ 2.582872] sun4i-drm display-engine: Adding to iommu group 0 [ 2.587091] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 System Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input6 [ 2.588237] hid-generic 0003:045E:0745.0003: input,hiddev96,hidraw2: USB HID v1.11 Device [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input2 [ 2.602484] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e16990) [ 2.602783] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800008e1abb8) [ 2.603132] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff800008e11ba0) [ 2.603237] sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator [ 2.607552] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY) [ 2.610193] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 2.611789] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver [ 2.612790] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff800008e15cc8) [ 2.614453] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 [ 2.614521] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 1 [ 2.770264] Console: switching to colour frame buffer device 240x67 [ 2.820085] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device [ 2.841915] acx00-codec acx00-codec: DMA mask not set [ 2.844695] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator [ 2.846014] sunxi-mmc 4020000.mmc: Got CD GPIO [ 2.846566] vcc-wifi-io: supplied by vcc33-wifi [ 2.848944] ehci-platform 5101000.usb: EHCI Host Controller [ 2.849108] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 3 [ 2.849277] ehci-platform 5101000.usb: irq 41, io mem 0x05101000 [ 2.861619] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00 [ 2.861961] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 2.861976] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.861987] usb usb3: Product: EHCI Host Controller [ 2.861995] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd [ 2.862004] usb usb3: SerialNumber: 5101000.usb [ 2.862573] hub 3-0:1.0: USB hub found [ 2.862616] hub 3-0:1.0: 1 port detected [ 2.863716] ehci-platform 5311000.usb: EHCI Host Controller [ 2.863754] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 4 [ 2.863897] ehci-platform 5311000.usb: irq 44, io mem 0x05311000 [ 2.869591] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 2.869910] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 2.877571] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00 [ 2.877916] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 2.877932] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.877943] usb usb4: Product: EHCI Host Controller [ 2.877951] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd [ 2.877960] usb usb4: SerialNumber: 5311000.usb [ 2.878516] hub 4-0:1.0: USB hub found [ 2.878560] hub 4-0:1.0: 1 port detected [ 2.879652] ohci-platform 5101400.usb: Generic Platform OHCI controller [ 2.879690] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 5 [ 2.879830] ohci-platform 5101400.usb: irq 42, io mem 0x05101400 [ 2.904492] mmc0: host does not support reading read-only switch, assuming write-enable [ 2.906262] mmc0: Problem switching card into high-speed mode! [ 2.906374] mmc0: new SDHC card at address 0001 [ 2.907229] mmcblk0: mmc0:0001 USD 29.8 GiB [ 2.909255] mmcblk0: p1 [ 2.941827] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15 [ 2.941852] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.941862] usb usb5: Product: Generic Platform OHCI controller [ 2.941871] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd [ 2.941879] usb usb5: SerialNumber: 5101400.usb [ 2.942627] hub 5-0:1.0: USB hub found [ 2.942693] hub 5-0:1.0: 1 port detected [ 2.943898] ohci-platform 5311400.usb: Generic Platform OHCI controller [ 2.943950] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 6 [ 2.944086] ohci-platform 5311400.usb: irq 45, io mem 0x05311400 [ 2.997703] mmc2: new HS200 MMC card at address 0001 [ 2.998755] mmcblk2: mmc2:0001 8GTF4R 7.28 GiB [ 3.001037] mmcblk2boot0: mmc2:0001 8GTF4R 4.00 MiB [ 3.002672] mmcblk2boot1: mmc2:0001 8GTF4R 4.00 MiB [ 3.005930] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15 [ 3.005972] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.005984] usb usb6: Product: Generic Platform OHCI controller [ 3.005992] usb usb6: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd [ 3.006001] usb usb6: SerialNumber: 5311400.usb [ 3.006674] hub 6-0:1.0: USB hub found [ 3.006731] hub 6-0:1.0: 1 port detected [ 3.008066] usb_phy_generic usb_phy_generic.4.auto: supply vcc not found, using dummy regulator [ 3.008361] usb_phy_generic usb_phy_generic.4.auto: dummy supplies not allowed for exclusive requests [ 3.113914] musb-hdrc musb-hdrc.5.auto: MUSB HDRC host driver [ 3.113960] musb-hdrc musb-hdrc.5.auto: new USB bus registered, assigned bus number 7 [ 3.114250] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 3.114265] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.114276] usb usb7: Product: MUSB HDRC host driver [ 3.114284] usb usb7: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd [ 3.114293] usb usb7: SerialNumber: musb-hdrc.5.auto [ 3.114896] hub 7-0:1.0: USB hub found [ 3.114955] hub 7-0:1.0: 1 port detected [ 3.135122] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found [ 3.135149] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found [ 3.135453] dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator [ 3.135754] dwmac-sun8i 5020000.ethernet: PTP uses main clock [ 3.135801] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 50000) [ 3.241842] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported [ 3.241868] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported [ 3.241876] dwmac-sun8i 5020000.ethernet: COE Type 2 [ 3.241886] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported [ 3.241894] dwmac-sun8i 5020000.ethernet: Normal descriptors [ 3.241901] dwmac-sun8i 5020000.ethernet: Chain mode enabled [ 3.460812] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none. [ 3.685578] usb 5-1: new full-speed USB device number 2 using ohci-platform [ 3.922615] usb 5-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.10 [ 3.922646] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.922656] usb 5-1: Product: USB Receiver [ 3.922665] usb 5-1: Manufacturer: Logitech [ 3.931703] input: Logitech USB Receiver as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.0/0003:046D:C52B.0004/input/input7 [ 3.990240] hid-generic 0003:046D:C52B.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-5101400.usb-1/input0 [ 3.996409] input: Logitech USB Receiver Mouse as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input8 [ 3.996878] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input9 [ 4.053923] input: Logitech USB Receiver System Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input10 [ 4.054273] hid-generic 0003:046D:C52B.0005: input,hiddev97,hidraw4: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-5101400.usb-1/input1 [ 4.058954] hid-generic 0003:046D:C52B.0006: hiddev98,hidraw5: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2 [ 4.755008] systemd[1]: System time before build time, advancing clock. [ 4.843289] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq [ 4.852360] systemd[1]: systemd 249.11-0ubuntu3.1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS -OPENSSL +ACL +BLKID +CURL +ELFUTILS -FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP -LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 4.853031] systemd[1]: Detected architecture arm64. [ 4.856401] systemd[1]: Hostname set to <orangepi3-lts>. [ 5.073589] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 5.093717] mmc1: new high speed SDIO card at address 8800 [ 6.193792] systemd[1]: Queued start job for default target Graphical Interface. [ 6.199673] systemd[1]: Created slice Slice /system/modprobe. [ 6.202438] systemd[1]: Created slice Slice /system/serial-getty. [ 6.204317] systemd[1]: Created slice User and Session Slice. [ 6.205203] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 6.206686] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 6.207616] systemd[1]: Reached target Remote File Systems. [ 6.207972] systemd[1]: Reached target Slice Units. [ 6.208316] systemd[1]: Reached target Swaps. [ 6.208615] systemd[1]: Reached target System Time Set. [ 6.209148] systemd[1]: Reached target Local Verity Protected Volumes. [ 6.210233] systemd[1]: Listening on Syslog Socket. [ 6.211099] systemd[1]: Listening on fsck to fsckd communication Socket. [ 6.211773] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 6.213196] systemd[1]: Listening on Journal Audit Socket. [ 6.214166] systemd[1]: Listening on Journal Socket (/dev/log). [ 6.215189] systemd[1]: Listening on Journal Socket. [ 6.226972] systemd[1]: Listening on udev Control Socket. [ 6.228070] systemd[1]: Listening on udev Kernel Socket. [ 6.232463] systemd[1]: Mounting Huge Pages File System... [ 6.237480] systemd[1]: Mounting POSIX Message Queue File System... [ 6.243196] systemd[1]: Mounting Kernel Debug File System... [ 6.244530] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 6.251806] systemd[1]: Starting Restore / save the current clock... [ 6.257507] systemd[1]: Starting Set the console keyboard layout... [ 6.264010] systemd[1]: Starting Create List of Static Device Nodes... [ 6.270697] systemd[1]: Starting Load Kernel Module configfs... [ 6.277248] systemd[1]: Starting Load Kernel Module drm... [ 6.284225] systemd[1]: Starting Load Kernel Module fuse... [ 6.290950] systemd[1]: Started Nameserver information manager. [ 6.293372] systemd[1]: Reached target Preparation for Network. [ 6.294676] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 6.305486] systemd[1]: Starting Load Kernel Modules... [ 6.311575] systemd[1]: Starting Remount Root and Kernel File Systems... [ 6.318055] systemd[1]: Starting Coldplug All udev Devices... [ 6.329070] systemd[1]: Mounted Huge Pages File System. [ 6.330531] systemd[1]: Mounted POSIX Message Queue File System. [ 6.331866] systemd[1]: Mounted Kernel Debug File System. [ 6.334637] systemd[1]: Finished Restore / save the current clock. [ 6.337208] fuse: init (API version 7.34) [ 6.338287] systemd[1]: Finished Create List of Static Device Nodes. [ 6.340802] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 6.342196] systemd[1]: Finished Load Kernel Module configfs. [ 6.344794] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 6.346196] systemd[1]: Finished Load Kernel Module drm. [ 6.348702] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 6.350366] systemd[1]: Finished Load Kernel Module fuse. [ 6.358420] systemd[1]: Mounting FUSE Control File System... [ 6.363565] systemd[1]: Mounting Kernel Configuration File System... [ 6.370549] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none. [ 6.378619] systemd[1]: Finished Remount Root and Kernel File Systems. [ 6.380232] systemd[1]: Mounted FUSE Control File System. [ 6.381348] systemd[1]: Mounted Kernel Configuration File System. [ 6.382326] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 6.387071] systemd[1]: Starting Load/Save Random Seed... [ 6.392540] systemd[1]: Starting Create System Users... [ 6.586419] WCN: marlin_init entry! [ 6.586991] WCN: wcn config bt wake host [ 6.587221] WCN_ERR: dts node for bt_wake not found [ 6.587225] WCN: marlin2 parse_dt some para not config [ 6.587238] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840 [ 6.592123] sdiohal:sdiohal_init ok [ 6.592878] WCN: marlin_probe ok! [ 6.620583] mtty_probe init device addr: 0x00000000e28a0d2b [ 6.620797] -->rfkill_bluetooth_init [ 6.620939] bluetooth_set_power: start_block=1 [ 6.620953] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0 [ 6.620964] bluetooth_set_power: end_block=1 [ 6.620984] <--rfkill_bluetooth_init [ 6.623689] systemd[1]: Finished Load/Save Random Seed. [ 6.626442] systemd[1]: Finished Create System Users. [ 6.627758] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 6.634972] systemd[1]: Starting Create Static Device Nodes in /dev... [ 6.763812] systemd[1]: Finished Set the console keyboard layout. [ 6.786911] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 6.788524] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 6.809385] [ADDR_MGT] addr_mgt_probe: module version: v1.0.9 [ 6.809498] [ADDR_MGT] addr_mgt_probe: success. [ 6.875323] WCN: start_marlin [MARLIN_WIFI] [ 6.875350] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1 [ 6.875357] WCN: the first power on start [ 6.882798] systemd[1]: Finished Create Static Device Nodes in /dev. [ 6.890198] systemd[1]: Reached target Preparation for Local File Systems. [ 6.902433] systemd[1]: Mounting /tmp... [ 6.917110] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 6.928017] systemd[1]: Mounted /tmp. [ 6.935371] systemd[1]: Reached target Local File Systems. [ 6.947700] systemd[1]: Starting Armbian leds state... [ 6.960150] systemd[1]: Starting Armbian ZRAM config... [ 6.973058] systemd[1]: Starting Set console font and keymap... [ 6.981654] WCN: marlin chip en dummy pull up -- need manually set GPIO [ 6.985303] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 7.009278] systemd[1]: Starting Set Up Additional Binary Formats... [ 7.009633] sdiohal:sdiohal_scan_card [ 7.009865] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=50000000 [ 7.009980] WCN: marlin_scan_finish! [ 7.009984] sdiohal:probe ok [ 7.010121] sdiohal:scan end! [ 7.010127] WCN: then marlin start to download [ 7.010352] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001 [ 7.010365] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start! [ 7.016147] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 7.016455] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 7.019509] systemd[1]: Finished Coldplug All udev Devices. [ 7.028350] systemd[1]: Finished Set console font and keymap. [ 7.059177] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 7.068115] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 7.075631] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 363 (systemd-binfmt) [ 7.080419] systemd[1]: Mounting Arbitrary Executable File Formats File System... [ 7.176429] systemd[1]: Mounted Arbitrary Executable File Formats File System. [ 7.195698] systemd[1]: Finished Set Up Additional Binary Formats. [ 7.204781] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 7.302466] systemd[1]: Finished Armbian leds state. [ 7.578280] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 7.586089] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 7.586742] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active. [ 7.594078] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 7.594232] systemd[1]: Reached target Local Encrypted Volumes. [ 7.650629] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 7.690721] systemd[1]: Starting Load/Save RF Kill Switch Status... [ 7.861430] bluetooth_set_power: start_block=0 [ 7.861457] WCN: start_marlin [MARLIN_BLUETOOTH] [ 8.022021] WCN: combin_img 0 marlin_firmware_write finish and successful [ 8.022313] WCN: marlin_start_run read reset reg val:0x1 [ 8.022320] WCN: after do marlin_start_run reset reg val:0x0 [ 8.022497] WCN: s_marlin_bootup_time=8022497218 [ 8.027371] mc: Linux media interface: v0.10 [ 8.029116] WCN: clock mode: TSX [ 8.029325] WCN: marlin_write_cali_data sync init_state:0x0 [ 8.042428] panfrost 1800000.gpu: clock rate = 432000000 [ 8.042461] panfrost 1800000.gpu: bus_clock rate = 100000000 [ 8.048008] panfrost 1800000.gpu: mali-t720 id 0x720 major 0x1 minor 0x1 status 0x0 [ 8.048034] panfrost 1800000.gpu: features: 00000000,10309e40, issues: 00000000,21054400 [ 8.048042] panfrost 1800000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002821 AS:0xf JS:0x7 [ 8.048050] panfrost 1800000.gpu: shader_present=0x3 l2_present=0x1 [ 8.053842] WCN: marlin_write_cali_data sync init_state:0x0 [ 8.078362] videodev: Linux video capture interface: v2.00 [ 8.079820] systemd[1]: Found device /dev/ttyS0. [ 8.081868] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1 [ 8.081894] WCN: sdio_config bt_wake_host trigger:[high] [ 8.081897] WCN: sdio_config irq:[inband] [ 8.081899] WCN: sdio_config wake_host_level_duration_time:[20ms] [ 8.081903] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse] [ 8.081906] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config) [ 8.082330] WCN: marlin_write_cali_data finish [ 8.082591] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.083099] [drm] Initialized panfrost 1.2.0 20180908 for 1800000.gpu on minor 1 [ 8.109908] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.130243] zram: Added device: zram0 [ 8.137813] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.165793] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.181921] zram: Added device: zram1 [ 8.193819] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0 [ 8.193843] WCN: marlin_bind_verify confuse data: 0x2e197f4f5a1107df30c640a9405a3d69 [ 8.193860] WCN: marlin_bind_verify verify data: 0x016d6ab91e1d071b3ae4604f224021aa [ 8.194409] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0 [ 8.198061] zram: Added device: zram2 [ 8.227589] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0 [ 8.227616] sdiohal:sdiohal_runtime_get entry [ 8.233394] WCN: get_cp2_version entry! [ 8.280833] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~ [ 8.280868] WCN: switch_cp2_log - close entry! [ 8.282187] WCN: WCND at cmd read:OK [ 8.282244] WCN: then marlin download finished and run ok [ 8.282258] WCN: start_loopcheck [ 8.282550] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1 [ 8.282561] WCN: marlin have open, GNSS is closed [ 8.282565] bluetooth_set_power: end_block=0 [ 8.288920] systemd[1]: Started Load/Save RF Kill Switch Status. [ 8.306629] WCN: get_board_ant_num [one_ant] [ 8.306654] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini [ 8.380720] Registered IR keymap rc-empty [ 8.380846] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0 [ 8.381036] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter [ 8.381128] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input12 [ 8.381466] sunxi-ir 7040000.ir: initialized sunXi IR driver [ 8.387814] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings. [ 8.392387] systemd[1]: Finished Load Kernel Modules. [ 8.402147] systemd[1]: Starting Apply Kernel Variables... [ 8.499610] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. [ 8.500798] cedrus 1c0e000.video-codec: Adding to iommu group 0 [ 8.501857] cedrus 1c0e000.video-codec: Device registered as /dev/video0 [ 8.621340] zram0: detected capacity change from 0 to 2037304 [ 8.651781] Adding 1018648k swap on /dev/zram0. Priority:5 extents:1 across:1018648k SSFS [ 8.687059] systemd[1]: Finished Apply Kernel Variables. [ 8.716975] systemd[1]: Starting Raise network interfaces... [ 8.871439] zram1: detected capacity change from 0 to 102400 [ 8.949631] logitech-djreceiver 0003:046D:C52B.0006: hiddev97,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2 [ 9.026075] systemd[1]: Finished Armbian ZRAM config. [ 9.036822] systemd[1]: Starting Armbian memory supported logging... [ 9.110343] input: Logitech Wireless Device PID:4004 Keyboard as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input13 [ 9.157338] hid-generic 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4004] on usb-5101400.usb-1/input2:1 [ 9.171004] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none. [ 9.327377] input: Logitech K360 as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input17 [ 9.328295] logitech-hidpp-device 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K360] on usb-5101400.usb-1/input2:1 [ 9.690644] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 9.691310] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 9.692362] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 9.697275] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 9.697501] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 9.697835] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 9.697994] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 9.755895] systemd[1]: Finished Raise network interfaces. [ 9.998313] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 9.998546] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 9.998617] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 9.998708] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 9.998815] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 9.998931] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 11.573639] systemd[1]: Finished Armbian memory supported logging. [ 11.584810] systemd[1]: Starting Journal Service... [ 11.722369] systemd[1]: Started Journal Service. [ 11.750846] systemd-journald[690]: Received client request to flush runtime journal. ### armbian-release: # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi3-lts BOARD_NAME="Orange Pi 3 LTS" BOARDFAMILY=sun50iw6 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=13f5fba13c VERSION=22.05.3 LINUXFAMILY=sunxi64 ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=stable BRANCH=current ### boot environment: verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun50i-h6 rootdev=UUID=71b44a6c-5bb8-4352-afe7-d22b8e62de4c rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u ### lsusb: Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ### lscpu: Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 4 On-line CPU(s) list: 0-3 Vendor ID: ARM Model name: Cortex-A53 Model: 4 Thread(s) per core: 1 Core(s) per cluster: 4 Socket(s): - Cluster(s): 1 Stepping: r0p4 CPU max MHz: 1800.0000 CPU min MHz: 480.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid NUMA node(s): 1 NUMA node0 CPU(s): 0-3 Vulnerability Itlb multihit: Not affected Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Spec store bypass: Not affected Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Not affected Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected ### cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 1 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 2 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 3 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 ### meminfo: MemTotal: 2037300 kB MemFree: 1845772 kB MemAvailable: 1851244 kB Buffers: 12532 kB Cached: 52908 kB SwapCached: 0 kB Active: 32344 kB Inactive: 52708 kB Active(anon): 428 kB Inactive(anon): 22452 kB Active(file): 31916 kB Inactive(file): 30256 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 1018648 kB SwapFree: 1018648 kB Dirty: 2836 kB Writeback: 0 kB AnonPages: 19400 kB Mapped: 16772 kB Shmem: 3376 kB KReclaimable: 10500 kB Slab: 45964 kB SReclaimable: 10500 kB SUnreclaim: 35464 kB KernelStack: 2448 kB PageTables: 1528 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 2037296 kB Committed_AS: 42340 kB VmallocTotal: 133143592960 kB VmallocUsed: 22684 kB VmallocChunk: 0 kB Percpu: 976 kB AnonHugePages: 0 kB ShmemHugePages: 0 kB ShmemPmdMapped: 0 kB FileHugePages: 0 kB FilePmdMapped: 0 kB CmaTotal: 131072 kB CmaFree: 128768 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB ### virtual memory: vm.admin_reserve_kbytes = 8192 vm.compaction_proactiveness = 20 vm.compact_unevictable_allowed = 1 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 vm.extfrag_threshold = 500 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 vm.min_free_kbytes = 22528 vm.min_slab_ratio = 5 vm.min_unmapped_ratio = 1 vm.mmap_min_addr = 32768 vm.mmap_rnd_bits = 18 vm.mmap_rnd_compat_bits = 11 vm.nr_hugepages = 0 vm.nr_hugepages_mempolicy = 0 vm.nr_overcommit_hugepages = 0 vm.numa_stat = 1 vm.numa_zonelist_order = Node vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 vm.panic_on_oom = 0 vm.percpu_pagelist_high_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 63011 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 vm.zone_reclaim_mode = 0 ### ip addr: 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 02:07:29:30:86:8c brd ff:ff:ff:ff:ff:ff 3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 00:32:c3:9f:6a:08 brd ff:ff:ff:ff:ff:ff ### partitions: major minor #blocks name 179 0 31205376 mmcblk0 179 1 30879744 mmcblk0p1 179 32 7634944 mmcblk2 252 0 1018652 zram0 252 1 51200 zram1 ### df: tmpfs 199M 3.4M 196M 2% /run /dev/mmcblk0p1 29G 4.9G 24G 18% / tmpfs 995M 0 995M 0% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 995M 0 995M 0% /tmp /dev/zram1 47M 2.8M 41M 7% /var/log ### lsblk: NAME FSTYPE SIZE MOUNTPOINT UUID mmcblk0 29.8G └─mmcblk0p1 ext4 29.4G / 71b44a6c-5bb8-4352-afe7-d22b8e62de4c mmcblk2 swap 7.3G 6a6f4ef8-bcc6-4021-a70f-de04ada07a25 mmcblk2boot0 swap 4M 6a6f4ef8-bcc6-4021-a70f-de04ada07a25 mmcblk2boot1 swap 4M 6a6f4ef8-bcc6-4021-a70f-de04ada07a25 zram1 50M /var/log zram2 0B ### zramctl: NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 50M 68K 728B 44K 4 /var/log /dev/zram0 lzo-rle 994.8M 4K 74B 12K 4 [SWAP] ### mtab: /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 ### mmc0:0001 info: fwrev: 0x0 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=USD MODALIAS=mmc:block cid: 1d414455534400001000005ae0016181 rca: 0x0001 csd: 400e00325b590000ee137f800a40004d manfid: 0x00001d ocr: 0x00200000 preferred_erase_size: 4194304 type: SD hwrev: 0x1 date: 01/2022 dsr: 0x404 erase_size: 512 oemid: 0x4144 serial: 0x00005ae0 ssr: 000000000500000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000 scr: 02b5808200000000 name: USD ### mmc2:0001 info: fwrev: 0x0600000000000000 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=8GTF4R MODALIAS=mmc:block cid: 15010038475446345206d410e21fc801 rel_sectors: 0x1 enhanced_rpmb_supported: 0x1 rca: 0x0001 pre_eol_info: 0x01 csd: d02701320f5903fff6dbffef8e40400d manfid: 0x000015 ocr: 0x00200000 preferred_erase_size: 4194304 enhanced_area_offset: 18446744073709551594 raw_rpmb_size_mult: 0x4 type: MMC hwrev: 0x0 date: 12/2021 prv: 0x6 ffu_capable: 1 dsr: 0x404 erase_size: 524288 life_time: 0x01 0x01 enhanced_area_size: 4294967274 oemid: 0x0100 serial: 0xd410e21f cmdq_en: 0 rev: 0x8 name: 8GTF4R ### Boot system health: Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 11:48:18: 1608MHz 1.34 46% 19% 13% 0% 12% 0% 65.9°C 0/9 11:48:18: 1080MHz 1.34 11% 6% 4% 1% 0% 0% 65.9°C 0/9 11:48:18: 816MHz 1.34 12% 7% 3% 1% 0% 0% 61.8°C 0/9 11:48:19: 888MHz 1.34 13% 9% 2% 1% 0% 0% 60.3°C 0/9 11:48:19: 1800MHz 1.34 12% 10% 2% 0% 0% 0% 62.2°C 0/9 ### Activated 1 lzo-rle zram swap devices with 994MB each. ### Activated Armbian ramlog partition with zstd compression Tue Jun 28 07:44:49 AM CST 2022 | Orange Pi 3 LTS | 22.05.3 | arm64 | aarch64 | 5.15.48-sunxi64 ### dmesg: [ 1.271004] i2c_dev: i2c /dev entries driver [ 1.271798] sunxi-wdt 7020400.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 1.273360] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pm not found, using dummy regulator [ 1.273780] sdhci: Secure Digital Host Controller Interface driver [ 1.273788] sdhci: Copyright(c) Pierre Ossman [ 1.273812] Synopsys Designware Multimedia Card Interface Driver [ 1.274605] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.274770] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator [ 1.276126] ledtrig-cpu: registered to indicate activity on CPUs [ 1.276686] sun8i-ce 1904000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz) [ 1.276980] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.277121] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.277218] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.277342] sun8i-ce 1904000.crypto: will run requests pump with realtime priority [ 1.277430] sun8i-ce 1904000.crypto: Register cbc(aes) [ 1.277588] sun8i-ce 1904000.crypto: Register ecb(aes) [ 1.277706] sun8i-ce 1904000.crypto: Register cbc(des3_ede) [ 1.277822] sun8i-ce 1904000.crypto: Register ecb(des3_ede) [ 1.277932] sun8i-ce 1904000.crypto: Register md5 [ 1.278040] sun8i-ce 1904000.crypto: Register sha1 [ 1.278147] sun8i-ce 1904000.crypto: Register sha224 [ 1.278256] sun8i-ce 1904000.crypto: Register sha256 [ 1.278363] sun8i-ce 1904000.crypto: Register sha384 [ 1.278481] sun8i-ce 1904000.crypto: Register sha512 [ 1.278588] sun8i-ce 1904000.crypto: Register stdrng [ 1.279328] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0 [ 1.279920] hid: raw HID events driver (C) Jiri Kosina [ 1.280051] usbcore: registered new interface driver usbhid [ 1.280059] usbhid: USB HID core driver [ 1.280834] random: crng init done [ 1.283096] NET: Registered PF_INET6 protocol family [ 1.870220] Freeing initrd memory: 12684K [ 1.898842] Segment Routing with IPv6 [ 1.898907] In-situ OAM (IOAM) with IPv6 [ 1.898991] NET: Registered PF_PACKET protocol family [ 1.899097] 8021q: 802.1Q VLAN Support v1.8 [ 1.899247] 9pnet: Installing 9P2000 support [ 1.899322] Key type dns_resolver registered [ 1.899785] registered taskstats version 1 [ 1.899801] Loading compiled-in X.509 certificates [ 1.903658] Loaded X.509 cert 'Build time autogenerated kernel key: 32330adefd2da02e444296fafd37464380789679' [ 1.906608] zswap: loaded using pool zstd/z3fold [ 1.907226] Key type ._fscrypt registered [ 1.907235] Key type .fscrypt registered [ 1.907240] Key type fscrypt-provisioning registered [ 1.908245] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no [ 1.922095] Key type encrypted registered [ 1.922126] AppArmor: AppArmor sha1 policy hashing enabled [ 1.922166] ima: No TPM chip found, activating TPM-bypass! [ 1.922195] ima: Allocated hash algorithm: sha1 [ 1.922227] ima: No architecture policies found [ 1.922282] evm: Initialising EVM extended attributes: [ 1.922287] evm: security.selinux [ 1.922292] evm: security.SMACK64 [ 1.922296] evm: security.SMACK64EXEC [ 1.922300] evm: security.SMACK64TRANSMUTE [ 1.922304] evm: security.SMACK64MMAP [ 1.922308] evm: security.apparmor [ 1.922313] evm: security.ima [ 1.922317] evm: security.capability [ 1.922321] evm: HMAC attrs: 0x1 [ 1.935406] platform 1100000.mixer: Fixing up cyclic dependency with 6510000.tcon-top [ 1.935756] sun8i-mixer 1100000.mixer: Adding to iommu group 0 [ 1.937838] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 1.937871] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 1.938040] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f064 hci version 0x100 quirks 0x0000000002010010 [ 1.938102] xhci-hcd xhci-hcd.1.auto: irq 43, io mem 0x05200000 [ 1.938567] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 1.938584] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.938594] usb usb1: Product: xHCI Host Controller [ 1.938603] usb usb1: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd [ 1.938611] usb usb1: SerialNumber: xhci-hcd.1.auto [ 1.939145] hub 1-0:1.0: USB hub found [ 1.939190] hub 1-0:1.0: 1 port detected [ 1.939527] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 1.939547] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2 [ 1.939567] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 1.939664] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.939823] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15 [ 1.939836] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.939846] usb usb2: Product: xHCI Host Controller [ 1.939854] usb usb2: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd [ 1.939863] usb usb2: SerialNumber: xhci-hcd.1.auto [ 1.940275] hub 2-0:1.0: USB hub found [ 1.940310] hub 2-0:1.0: 1 port detected [ 1.942951] sun50i_cpufreq_nvmem: Using CPU speed bin speed0 [ 1.944731] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version [ 1.951102] of_cfs_init [ 1.951222] of_cfs_init: OK [ 1.951547] ALSA device list: [ 1.951553] No soundcards found. [ 1.952660] Freeing unused kernel memory: 2496K [ 1.985358] Run /init as init process [ 1.985366] with arguments: [ 1.985373] /init [ 1.985378] with environment: [ 1.985383] HOME=/ [ 1.985388] TERM=linux [ 1.985393] ubootpart=ce3dfe46-01 [ 1.985398] cgroup_enable=memory [ 2.197340] usb 1-1: new full-speed USB device number 2 using xhci-hcd [ 2.350433] usb 1-1: New USB device found, idVendor=045e, idProduct=0745, bcdDevice= 6.33 [ 2.350464] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.350474] usb 1-1: Product: Microsoft® 2.4GHz Transceiver v7.0 [ 2.350483] usb 1-1: Manufacturer: Microsoft [ 2.375225] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.0/0003:045E:0745.0001/input/input0 [ 2.438207] hid-generic 0003:045E:0745.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input0 [ 2.442434] axp20x-i2c 0-0036: AXP20x variant AXP806 found [ 2.450726] input: axp20x-pek as /devices/platform/soc/7081400.i2c/i2c-0/0-0036/axp221-pek/input/input1 [ 2.454955] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Mouse as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input2 [ 2.460662] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input3 [ 2.462363] vdd-cpu: supplied by vcc-5v [ 2.463981] vdd-gpu: supplied by vcc-5v [ 2.464566] vdd-sys: Bringing 900000uV into 960000-960000uV [ 2.464950] vdd-sys: supplied by vcc-5v [ 2.465877] vcc-dram: supplied by vcc-5v [ 2.466667] vcc-pl-led-ir: supplied by vcc-5v [ 2.467435] vcc33-audio-tv-ephy-mac: Bringing 700000uV into 3300000-3300000uV [ 2.467815] vcc33-audio-tv-ephy-mac: supplied by vcc-5v [ 2.517838] hid-generic 0003:045E:0745.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input1 [ 2.526830] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input4 [ 2.574062] vcc33-io-pd-emmc-sd-usb-uart-1: Bringing 700000uV into 3300000-3300000uV [ 2.574423] vcc33-io-pd-emmc-sd-usb-uart-1: supplied by vcc-5v [ 2.575457] vcc18-dram-bias-pll: supplied by vcc-5v [ 2.576536] vcc-efuse-pcie-hdmi-pc: supplied by vcc-5v [ 2.577198] vcc-wifi-io-pm-pg: Bringing 700000uV into 1800000-1800000uV [ 2.577534] vcc-wifi-io-pm-pg: supplied by vcc-5v [ 2.578659] bldo4: supplied by vcc-5v [ 2.579187] vcc33-io-pd-emmc-sd-usb-uart-2: supplied by vcc-5v [ 2.580004] cldo2: supplied by vcc-5v [ 2.580651] cldo3: supplied by vcc-5v [ 2.580881] sw: supplied by regulator-dummy [ 2.581462] axp20x-i2c 0-0036: AXP20X driver loaded [ 2.587289] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 System Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input6 [ 2.587787] hid-generic 0003:045E:0745.0003: input,hiddev96,hidraw2: USB HID v1.11 Device [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input2 [ 2.590166] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver [ 2.590661] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pb not found, using dummy regulator [ 2.591648] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator [ 2.592259] printk: console [ttyS0] disabled [ 2.592370] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 35, base_baud = 1500000) is a 16550A [ 2.592603] printk: console [ttyS0] enabled [ 2.594026] sun4i-drm display-engine: Adding to iommu group 0 [ 2.614241] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e16990) [ 2.614521] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800008e1abb8) [ 2.614859] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff800008e11ba0) [ 2.614950] sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator [ 2.615547] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY) [ 2.615931] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin [ 2.616321] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver [ 2.616766] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff800008e15cc8) [ 2.627717] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 [ 2.627781] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 1 [ 2.785963] Console: switching to colour frame buffer device 240x67 [ 2.835811] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device [ 2.857467] acx00-codec acx00-codec: DMA mask not set [ 2.859822] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator [ 2.862436] sunxi-mmc 4020000.mmc: Got CD GPIO [ 2.862855] vcc-wifi-io: supplied by vcc33-wifi [ 2.865691] ehci-platform 5101000.usb: EHCI Host Controller [ 2.865735] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 3 [ 2.865880] ehci-platform 5101000.usb: irq 41, io mem 0x05101000 [ 2.885309] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00 [ 2.885313] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 2.885574] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 2.885643] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 2.885658] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.885669] usb usb3: Product: EHCI Host Controller [ 2.885677] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd [ 2.885686] usb usb3: SerialNumber: 5101000.usb [ 2.886286] hub 3-0:1.0: USB hub found [ 2.886349] hub 3-0:1.0: 1 port detected [ 2.887655] ehci-platform 5311000.usb: EHCI Host Controller [ 2.887708] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 4 [ 2.887848] ehci-platform 5311000.usb: irq 44, io mem 0x05311000 [ 2.905298] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00 [ 2.905653] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 2.905668] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.905678] usb usb4: Product: EHCI Host Controller [ 2.905687] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd [ 2.905695] usb usb4: SerialNumber: 5311000.usb [ 2.906266] hub 4-0:1.0: USB hub found [ 2.906311] hub 4-0:1.0: 1 port detected [ 2.907463] ohci-platform 5101400.usb: Generic Platform OHCI controller [ 2.907502] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 5 [ 2.907639] ohci-platform 5101400.usb: irq 42, io mem 0x05101400 [ 2.920322] mmc0: host does not support reading read-only switch, assuming write-enable [ 2.922092] mmc0: Problem switching card into high-speed mode! [ 2.922211] mmc0: new SDHC card at address 0001 [ 2.923101] mmcblk0: mmc0:0001 USD 29.8 GiB [ 2.925179] mmcblk0: p1 [ 2.969595] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15 [ 2.969624] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.969635] usb usb5: Product: Generic Platform OHCI controller [ 2.969643] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd [ 2.969652] usb usb5: SerialNumber: 5101400.usb [ 2.970330] hub 5-0:1.0: USB hub found [ 2.970383] hub 5-0:1.0: 1 port detected [ 2.971617] ohci-platform 5311400.usb: Generic Platform OHCI controller [ 2.971660] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 6 [ 2.971801] ohci-platform 5311400.usb: irq 45, io mem 0x05311400 [ 3.017445] mmc2: new HS200 MMC card at address 0001 [ 3.018424] mmcblk2: mmc2:0001 8GTF4R 7.28 GiB [ 3.020685] mmcblk2boot0: mmc2:0001 8GTF4R 4.00 MiB [ 3.022339] mmcblk2boot1: mmc2:0001 8GTF4R 4.00 MiB [ 3.033624] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15 [ 3.033662] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.033673] usb usb6: Product: Generic Platform OHCI controller [ 3.033682] usb usb6: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd [ 3.033690] usb usb6: SerialNumber: 5311400.usb [ 3.034410] hub 6-0:1.0: USB hub found [ 3.034470] hub 6-0:1.0: 1 port detected [ 3.035805] usb_phy_generic usb_phy_generic.4.auto: supply vcc not found, using dummy regulator [ 3.036009] usb_phy_generic usb_phy_generic.4.auto: dummy supplies not allowed for exclusive requests [ 3.133661] musb-hdrc musb-hdrc.5.auto: MUSB HDRC host driver [ 3.133704] musb-hdrc musb-hdrc.5.auto: new USB bus registered, assigned bus number 7 [ 3.133977] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 3.133993] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.134004] usb usb7: Product: MUSB HDRC host driver [ 3.134012] usb usb7: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd [ 3.134020] usb usb7: SerialNumber: musb-hdrc.5.auto [ 3.134715] hub 7-0:1.0: USB hub found [ 3.134773] hub 7-0:1.0: 1 port detected [ 3.150722] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found [ 3.150748] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found [ 3.151052] dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator [ 3.151322] dwmac-sun8i 5020000.ethernet: PTP uses main clock [ 3.151370] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 50000) [ 3.257560] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported [ 3.257587] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported [ 3.257594] dwmac-sun8i 5020000.ethernet: COE Type 2 [ 3.257604] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported [ 3.257612] dwmac-sun8i 5020000.ethernet: Normal descriptors [ 3.257619] dwmac-sun8i 5020000.ethernet: Chain mode enabled [ 3.485042] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none. [ 3.701321] usb 5-1: new full-speed USB device number 2 using ohci-platform [ 3.938354] usb 5-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.10 [ 3.938383] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.938394] usb 5-1: Product: USB Receiver [ 3.938402] usb 5-1: Manufacturer: Logitech [ 3.947518] input: Logitech USB Receiver as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.0/0003:046D:C52B.0004/input/input7 [ 4.006002] hid-generic 0003:046D:C52B.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-5101400.usb-1/input0 [ 4.012208] input: Logitech USB Receiver Mouse as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input8 [ 4.012665] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input9 [ 4.069662] input: Logitech USB Receiver System Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input10 [ 4.070031] hid-generic 0003:046D:C52B.0005: input,hiddev97,hidraw4: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-5101400.usb-1/input1 [ 4.074797] hid-generic 0003:046D:C52B.0006: hiddev98,hidraw5: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2 [ 4.780230] systemd[1]: System time before build time, advancing clock. [ 4.868365] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq [ 4.877545] systemd[1]: systemd 249.11-0ubuntu3.1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS -OPENSSL +ACL +BLKID +CURL +ELFUTILS -FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP -LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 4.878226] systemd[1]: Detected architecture arm64. [ 4.881592] systemd[1]: Hostname set to <orangepi3-lts>. [ 5.101862] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 5.119516] mmc1: new high speed SDIO card at address 8800 [ 6.293876] systemd[1]: Queued start job for default target Graphical Interface. [ 6.299750] systemd[1]: Created slice Slice /system/modprobe. [ 6.302537] systemd[1]: Created slice Slice /system/serial-getty. [ 6.304385] systemd[1]: Created slice User and Session Slice. [ 6.305369] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 6.306819] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 6.307696] systemd[1]: Reached target Remote File Systems. [ 6.308041] systemd[1]: Reached target Slice Units. [ 6.308380] systemd[1]: Reached target Swaps. [ 6.308677] systemd[1]: Reached target System Time Set. [ 6.309210] systemd[1]: Reached target Local Verity Protected Volumes. [ 6.310301] systemd[1]: Listening on Syslog Socket. [ 6.311159] systemd[1]: Listening on fsck to fsckd communication Socket. [ 6.311801] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 6.313180] systemd[1]: Listening on Journal Audit Socket. [ 6.314227] systemd[1]: Listening on Journal Socket (/dev/log). [ 6.315211] systemd[1]: Listening on Journal Socket. [ 6.326975] systemd[1]: Listening on udev Control Socket. [ 6.328076] systemd[1]: Listening on udev Kernel Socket. [ 6.332683] systemd[1]: Mounting Huge Pages File System... [ 6.338074] systemd[1]: Mounting POSIX Message Queue File System... [ 6.343823] systemd[1]: Mounting Kernel Debug File System... [ 6.345097] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 6.352304] systemd[1]: Starting Restore / save the current clock... [ 6.358015] systemd[1]: Starting Set the console keyboard layout... [ 6.364390] systemd[1]: Starting Create List of Static Device Nodes... [ 6.371017] systemd[1]: Starting Load Kernel Module configfs... [ 6.377727] systemd[1]: Starting Load Kernel Module drm... [ 6.384315] systemd[1]: Starting Load Kernel Module fuse... [ 6.391403] systemd[1]: Started Nameserver information manager. [ 6.392936] systemd[1]: Reached target Preparation for Network. [ 6.394122] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 6.406943] systemd[1]: Starting Load Kernel Modules... [ 6.412637] systemd[1]: Starting Remount Root and Kernel File Systems... [ 6.418869] systemd[1]: Starting Coldplug All udev Devices... [ 6.429912] systemd[1]: Mounted Huge Pages File System. [ 6.431274] systemd[1]: Mounted POSIX Message Queue File System. [ 6.432661] systemd[1]: Mounted Kernel Debug File System. [ 6.435426] systemd[1]: Finished Restore / save the current clock. [ 6.438862] systemd[1]: Finished Create List of Static Device Nodes. [ 6.439496] fuse: init (API version 7.34) [ 6.441770] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 6.443183] systemd[1]: Finished Load Kernel Module configfs. [ 6.446061] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 6.447247] systemd[1]: Finished Load Kernel Module drm. [ 6.449663] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 6.450951] systemd[1]: Finished Load Kernel Module fuse. [ 6.458776] systemd[1]: Mounting FUSE Control File System... [ 6.464040] systemd[1]: Mounting Kernel Configuration File System... [ 6.474677] systemd[1]: Mounted FUSE Control File System. [ 6.475071] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none. [ 6.481615] systemd[1]: Finished Remount Root and Kernel File Systems. [ 6.483009] systemd[1]: Mounted Kernel Configuration File System. [ 6.483907] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 6.488816] systemd[1]: Starting Load/Save Random Seed... [ 6.494729] systemd[1]: Starting Create System Users... [ 6.660140] WCN: marlin_init entry! [ 6.660666] WCN: wcn config bt wake host [ 6.660887] WCN_ERR: dts node for bt_wake not found [ 6.660891] WCN: marlin2 parse_dt some para not config [ 6.660903] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840 [ 6.665745] sdiohal:sdiohal_init ok [ 6.666445] WCN: marlin_probe ok! [ 6.691458] mtty_probe init device addr: 0x00000000009926d4 [ 6.691698] -->rfkill_bluetooth_init [ 6.691861] bluetooth_set_power: start_block=1 [ 6.691875] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0 [ 6.691886] bluetooth_set_power: end_block=1 [ 6.691905] <--rfkill_bluetooth_init [ 6.715886] systemd[1]: Finished Load/Save Random Seed. [ 6.718379] systemd[1]: Finished Create System Users. [ 6.719559] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 6.724878] systemd[1]: Starting Create Static Device Nodes in /dev... [ 6.796727] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 6.798565] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 6.819533] [ADDR_MGT] addr_mgt_probe: module version: v1.0.9 [ 6.819648] [ADDR_MGT] addr_mgt_probe: success. [ 6.863106] systemd[1]: Finished Set the console keyboard layout. [ 6.887348] WCN: start_marlin [MARLIN_WIFI] [ 6.887375] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1 [ 6.887385] WCN: the first power on start [ 6.894415] systemd[1]: Finished Create Static Device Nodes in /dev. [ 6.901977] systemd[1]: Reached target Preparation for Local File Systems. [ 6.914256] systemd[1]: Mounting /tmp... [ 6.928825] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 6.939787] systemd[1]: Mounted /tmp. [ 6.947152] systemd[1]: Reached target Local File Systems. [ 6.959184] systemd[1]: Starting Armbian leds state... [ 6.971551] systemd[1]: Starting Armbian ZRAM config... [ 6.984210] systemd[1]: Starting Set console font and keymap... [ 6.993355] WCN: marlin chip en dummy pull up -- need manually set GPIO [ 6.996364] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 7.021397] sdiohal:sdiohal_scan_card [ 7.021668] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=50000000 [ 7.021795] systemd[1]: Starting Set Up Additional Binary Formats... [ 7.021816] WCN: marlin_scan_finish! [ 7.021823] sdiohal:probe ok [ 7.021979] sdiohal:scan end! [ 7.021987] WCN: then marlin start to download [ 7.022257] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001 [ 7.022272] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start! [ 7.029127] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 7.029487] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 7.032823] systemd[1]: Finished Set console font and keymap. [ 7.046131] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 365 (systemd-binfmt) [ 7.052057] systemd[1]: Mounting Arbitrary Executable File Formats File System... [ 7.083231] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 7.134889] systemd[1]: Finished Coldplug All udev Devices. [ 7.189454] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 7.200737] systemd[1]: Mounted Arbitrary Executable File Formats File System. [ 7.220106] systemd[1]: Finished Set Up Additional Binary Formats. [ 7.250460] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 7.311656] systemd[1]: Finished Armbian leds state. [ 7.592733] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 7.600572] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 7.601200] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active. [ 7.616428] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 7.616576] systemd[1]: Reached target Local Encrypted Volumes. [ 7.674195] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 7.714809] systemd[1]: Starting Load/Save RF Kill Switch Status... [ 7.775762] bluetooth_set_power: start_block=0 [ 7.775792] WCN: start_marlin [MARLIN_BLUETOOTH] [ 7.975324] zram: Added device: zram0 [ 7.975654] zram: Added device: zram1 [ 7.976033] zram: Added device: zram2 [ 8.094917] WCN: combin_img 0 marlin_firmware_write finish and successful [ 8.095242] WCN: marlin_start_run read reset reg val:0x1 [ 8.095250] WCN: after do marlin_start_run reset reg val:0x0 [ 8.095433] WCN: s_marlin_bootup_time=8095432843 [ 8.101544] WCN: clock mode: TSX [ 8.101736] WCN: marlin_write_cali_data sync init_state:0x0 [ 8.132768] WCN: marlin_write_cali_data sync init_state:0x0 [ 8.159666] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1 [ 8.159698] WCN: sdio_config bt_wake_host trigger:[high] [ 8.159701] WCN: sdio_config irq:[inband] [ 8.159703] WCN: sdio_config wake_host_level_duration_time:[20ms] [ 8.159708] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse] [ 8.159710] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config) [ 8.160558] WCN: marlin_write_cali_data finish [ 8.161314] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.177333] mc: Linux media interface: v0.10 [ 8.190592] panfrost 1800000.gpu: clock rate = 432000000 [ 8.190630] panfrost 1800000.gpu: bus_clock rate = 100000000 [ 8.191105] panfrost 1800000.gpu: mali-t720 id 0x720 major 0x1 minor 0x1 status 0x0 [ 8.191128] panfrost 1800000.gpu: features: 00000000,10309e40, issues: 00000000,21054400 [ 8.191136] panfrost 1800000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002821 AS:0xf JS:0x7 [ 8.191144] panfrost 1800000.gpu: shader_present=0x3 l2_present=0x1 [ 8.191541] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.192979] [drm] Initialized panfrost 1.2.0 20180908 for 1800000.gpu on minor 1 [ 8.217760] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.228323] videodev: Linux video capture interface: v2.00 [ 8.248869] zram0: detected capacity change from 0 to 2037304 [ 8.249575] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0 [ 8.279502] systemd[1]: Found device /dev/ttyS0. [ 8.287283] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0 [ 8.287302] WCN: marlin_bind_verify confuse data: 0xe5ae06b9a313020e4477650022a32ad5 [ 8.287317] WCN: marlin_bind_verify verify data: 0xa5ab8048e6a32ce226d910652b504834 [ 8.288057] WCN: check_cp_ready sync val:0xf0f0f0f8, prj_type val:0x0 [ 8.313569] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0 [ 8.313595] sdiohal:sdiohal_runtime_get entry [ 8.317949] WCN: get_cp2_version entry! [ 8.337651] Adding 1018648k swap on /dev/zram0. Priority:5 extents:1 across:1018648k SSFS [ 8.357401] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~ [ 8.358024] WCN: switch_cp2_log - close entry! [ 8.359418] WCN: WCND at cmd read:OK [ 8.359553] WCN: then marlin download finished and run ok [ 8.359585] WCN: start_loopcheck [ 8.359607] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1 [ 8.359615] WCN: marlin have open, GNSS is closed [ 8.359620] bluetooth_set_power: end_block=0 [ 8.377701] systemd[1]: Started Load/Save RF Kill Switch Status. [ 8.392873] WCN: get_board_ant_num [one_ant] [ 8.392894] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini [ 8.421557] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. [ 8.426838] cedrus 1c0e000.video-codec: Adding to iommu group 0 [ 8.435265] cedrus 1c0e000.video-codec: Device registered as /dev/video0 [ 8.475450] Registered IR keymap rc-empty [ 8.493733] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0 [ 8.508606] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter [ 8.514745] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input12 [ 8.515268] sunxi-ir 7040000.ir: initialized sunXi IR driver [ 8.558655] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings. [ 8.571387] zram1: detected capacity change from 0 to 102400 [ 8.589949] systemd[1]: Finished Load Kernel Modules. [ 8.626023] systemd[1]: Starting Apply Kernel Variables... [ 8.701400] systemd[1]: Finished Armbian ZRAM config. [ 8.724623] systemd[1]: Starting Armbian memory supported logging... [ 8.741406] systemd[1]: Finished Apply Kernel Variables. [ 8.759248] systemd[1]: Starting Raise network interfaces... [ 8.928132] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none. [ 9.050204] logitech-djreceiver 0003:046D:C52B.0006: hiddev97,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2 [ 9.206494] input: Logitech Wireless Device PID:4004 Keyboard as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input13 [ 9.274225] hid-generic 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4004] on usb-5101400.usb-1/input2:1 [ 9.465060] input: Logitech K360 as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input17 [ 9.465977] logitech-hidpp-device 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K360] on usb-5101400.usb-1/input2:1 [ 9.758059] systemd[1]: Finished Raise network interfaces. [ 9.909199] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 9.909534] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 9.909890] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 9.913981] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 9.914092] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 9.914197] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 9.914269] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 9.998835] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 9.999036] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 9.999099] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 9.999176] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 9.999275] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 9.999378] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 11.570712] systemd[1]: Finished Armbian memory supported logging. [ 11.580348] systemd[1]: Starting Journal Service... [ 11.722747] systemd[1]: Started Journal Service. [ 11.751364] systemd-journald[691]: Received client request to flush runtime journal. ### armbian-release: # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi3-lts BOARD_NAME="Orange Pi 3 LTS" BOARDFAMILY=sun50iw6 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=13f5fba13c VERSION=22.05.3 LINUXFAMILY=sunxi64 ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=stable BRANCH=current ### boot environment: verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun50i-h6 rootdev=UUID=71b44a6c-5bb8-4352-afe7-d22b8e62de4c rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u ### lsusb: Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ### lscpu: Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 4 On-line CPU(s) list: 0-3 Vendor ID: ARM Model name: Cortex-A53 Model: 4 Thread(s) per core: 1 Core(s) per cluster: 4 Socket(s): - Cluster(s): 1 Stepping: r0p4 CPU max MHz: 1800.0000 CPU min MHz: 480.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid NUMA node(s): 1 NUMA node0 CPU(s): 0-3 Vulnerability Itlb multihit: Not affected Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Spec store bypass: Not affected Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Not affected Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected ### cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 1 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 2 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 processor : 3 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 ### meminfo: MemTotal: 2037300 kB MemFree: 1845816 kB MemAvailable: 1851728 kB Buffers: 12532 kB Cached: 53568 kB SwapCached: 0 kB Active: 32208 kB Inactive: 52908 kB Active(anon): 444 kB Inactive(anon): 22100 kB Active(file): 31764 kB Inactive(file): 30808 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 1018648 kB SwapFree: 1018648 kB Dirty: 3392 kB Writeback: 0 kB AnonPages: 19056 kB Mapped: 16768 kB Shmem: 3388 kB KReclaimable: 10580 kB Slab: 45824 kB SReclaimable: 10580 kB SUnreclaim: 35244 kB KernelStack: 2464 kB PageTables: 1652 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 2037296 kB Committed_AS: 42432 kB VmallocTotal: 133143592960 kB VmallocUsed: 22700 kB VmallocChunk: 0 kB Percpu: 976 kB AnonHugePages: 0 kB ShmemHugePages: 0 kB ShmemPmdMapped: 0 kB FileHugePages: 0 kB FilePmdMapped: 0 kB CmaTotal: 131072 kB CmaFree: 128768 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 2048 kB Hugetlb: 0 kB ### virtual memory: vm.admin_reserve_kbytes = 8192 vm.compaction_proactiveness = 20 vm.compact_unevictable_allowed = 1 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 vm.extfrag_threshold = 500 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 vm.min_free_kbytes = 22528 vm.min_slab_ratio = 5 vm.min_unmapped_ratio = 1 vm.mmap_min_addr = 32768 vm.mmap_rnd_bits = 18 vm.mmap_rnd_compat_bits = 11 vm.nr_hugepages = 0 vm.nr_hugepages_mempolicy = 0 vm.nr_overcommit_hugepages = 0 vm.numa_stat = 1 vm.numa_zonelist_order = Node vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 vm.panic_on_oom = 0 vm.percpu_pagelist_high_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 63004 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 vm.zone_reclaim_mode = 0 ### ip addr: 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 02:07:29:30:86:8c brd ff:ff:ff:ff:ff:ff 3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 00:32:c3:9f:6a:08 brd ff:ff:ff:ff:ff:ff ### partitions: major minor #blocks name 179 0 31205376 mmcblk0 179 1 30879744 mmcblk0p1 179 32 7634944 mmcblk2 252 0 1018652 zram0 252 1 51200 zram1 ### df: tmpfs 199M 3.4M 196M 2% /run /dev/mmcblk0p1 29G 5.1G 24G 18% / tmpfs 995M 0 995M 0% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 995M 0 995M 0% /tmp /dev/zram1 47M 3.3M 41M 8% /var/log ### lsblk: NAME FSTYPE SIZE MOUNTPOINT UUID mmcblk0 29.8G └─mmcblk0p1 ext4 29.4G / 71b44a6c-5bb8-4352-afe7-d22b8e62de4c mmcblk2 swap 7.3G 6a6f4ef8-bcc6-4021-a70f-de04ada07a25 mmcblk2boot0 swap 4M 6a6f4ef8-bcc6-4021-a70f-de04ada07a25 mmcblk2boot1 swap 4M 6a6f4ef8-bcc6-4021-a70f-de04ada07a25 zram1 50M /var/log zram2 0B ### zramctl: NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram1 zstd 50M 68K 728B 44K 4 /var/log /dev/zram0 lzo-rle 994.8M 4K 74B 12K 4 [SWAP] ### mtab: /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 ### mmc0:0001 info: fwrev: 0x0 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=USD MODALIAS=mmc:block cid: 1d414455534400001000005ae0016181 rca: 0x0001 csd: 400e00325b590000ee137f800a40004d manfid: 0x00001d ocr: 0x00200000 preferred_erase_size: 4194304 type: SD hwrev: 0x1 date: 01/2022 dsr: 0x404 erase_size: 512 oemid: 0x4144 serial: 0x00005ae0 ssr: 000000000500000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000 scr: 02b5808200000000 name: USD ### mmc2:0001 info: fwrev: 0x0600000000000000 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=8GTF4R MODALIAS=mmc:block cid: 15010038475446345206d410e21fc801 rel_sectors: 0x1 enhanced_rpmb_supported: 0x1 rca: 0x0001 pre_eol_info: 0x01 csd: d02701320f5903fff6dbffef8e40400d manfid: 0x000015 ocr: 0x00200000 preferred_erase_size: 4194304 enhanced_area_offset: 18446744073709551594 raw_rpmb_size_mult: 0x4 type: MMC hwrev: 0x0 date: 12/2021 prv: 0x6 ffu_capable: 1 dsr: 0x404 erase_size: 524288 life_time: 0x01 0x01 enhanced_area_size: 4294967274 oemid: 0x0100 serial: 0xd410e21f cmdq_en: 0 rev: 0x8 name: 8GTF4R ### Boot system health: Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 07:44:50: 1704MHz 1.34 47% 20% 14% 0% 12% 0% 59.7°C 0/9 07:44:51: 1320MHz 1.34 11% 6% 3% 1% 0% 0% 59.7°C 0/9 07:44:51: 1080MHz 1.34 18% 11% 4% 1% 0% 0% 55.4°C 0/9 07:44:52: 1080MHz 1.34 11% 7% 2% 1% 0% 0% 54.6°C 0/9 07:44:52: 1080MHz 1.34 19% 15% 2% 0% 0% 0% 54.6°C 0/9 0 Quote
Werner Posted June 28, 2022 Posted June 28, 2022 @Ukhellfire what's the status of WiFi on this board? From a quick search it seems like the firmware or drive for uwe6522 may need an update 0 Quote
Luc Posted July 11, 2022 Posted July 11, 2022 My Orange PI 3 LTS with Armbian 22.05 Jammy also failed to connect to WiFi. It works for me with Bullseye (https://www.armbian.com/orangepi3-lts/#kernels-archive-all). 0 Quote
Yuzu Posted July 20, 2022 Posted July 20, 2022 Yeah I can confirm wifi works with debian bullseye but not ubuntu. I tried with my home network and my phone's access point. 0 Quote
Cryptimo Posted July 21, 2022 Posted July 21, 2022 My OrangePi 3 LTs with Armbian Jammy failed to connect wifi also. Ubuntu 22.04 works just fine. 0 Quote
trixbox Posted September 1, 2022 Posted September 1, 2022 (edited) Same problem, anyone could fix this? Edited September 1, 2022 by trixbox 0 Quote
Joe5150 Posted September 13, 2022 Posted September 13, 2022 (edited) Wifi does not work on Orange Pi 3 LTS. Armbian boots but no wifi detected. If I install the official Ubuntu from Orange Pi, it does work normally. I believe that this version of Armbian does not contain correct Wifi drivers for this board. There is no feasible way to post the logs at this time. Upon further research, it appears that without significant effort to troubleshoot and fix (at the expert level) , people should not expect that the current (September 2022) release of Armbian for Orange Pi 3 LTS to work. This board is not supported. Edited September 13, 2022 by Joe5150 updated formation 0 Quote
Werner Posted September 13, 2022 Posted September 13, 2022 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Joe5150 Posted September 13, 2022 Posted September 13, 2022 I am having the same issue. Wifi works with Debian and Ubuntu but not Ambian. This board does not seem to be supported. 0 Quote
OmgItsKB Posted September 15, 2022 Posted September 15, 2022 exact same problem here, I'll try to upload logs in a bit 0 Quote
Igor Posted September 15, 2022 Posted September 15, 2022 On 9/13/2022 at 1:45 PM, Joe5150 said: This board is not supported. Expand Board is supported if there are volunteer maintainers which are suppose to help this way. I can personally assure you that WiFi on 3 LTS was tested (at least on 2.4G network) and it works. I am not saying it works pitch perfect yet, but it works good enough for amateur use. More then this we can't provide as there is absolutely no interest from your side to compensate time lost working on things in your interest. Since this is open source and since we provide perfectly supported SDK, nobody prevents anyone to fix problems. On 9/13/2022 at 1:45 PM, Joe5150 said: If I install the official Ubuntu from Orange Pi, it does work normally. Expand Its always a trade. That kernel will probably never receive any update. If that suits you and if you trust that vendor private kernel which nobody else uses with random hacks and random hacks on top of Armbian (yes, they use Armbian as a base, not Ubuntu. Ubuntu is only to make sales association), use that. On 9/13/2022 at 1:45 PM, Joe5150 said: I believe that this version of Armbian does not contain correct Wifi drivers for this board. Expand Usually there is just one version that is ported to the new kernel with minimum efforts. Mainlining drivers is epic and expensive project which is difficult to run if clients are not paying anything and all benefits also goes to your competition. https://docs.armbian.com/User-Guide_FAQ/#development-time (check other FAQ points) Possible workarounds: try connecting with other tools, twice, try rfkill list / block / unblock, reboot, ... 0 Quote
bonfire62 Posted September 15, 2022 Posted September 15, 2022 just FYI the Bullseye LTS version DOES work 2 Quote
Dancp Posted September 17, 2022 Posted September 17, 2022 Same issue. Im using jammy newest version. :'-( 0 Quote
boztech25 Posted November 6, 2022 Posted November 6, 2022 armbian on the orangepi 3 lts DOES NOT WORK!!! Who the hell compiled this POS? Must use Debian. OMG! Kevin 0 Quote
osmancik Posted November 11, 2022 Posted November 11, 2022 Wifi and ethernet not working. I can do any tests if you want. armbianmonitorFetching info... 0 Quote
Timo12357 Posted December 18, 2022 Posted December 18, 2022 Has anyone tested the 5.15y kernel released 30th of November 2022? Does wifi work with it? 0 Quote
Igor Posted December 18, 2022 Posted December 18, 2022 On 12/18/2022 at 5:44 PM, Timo12357 said: Has anyone tested the 5.15y kernel released 30th of November 2022? Does wifi work with it? Expand Armbian automated testings shows no problems with WiFi https://paste.armbian.com/yaqokonipe But this image is little further then released, made from latest sources (nightly). You can switch to the same firmware via armbian-config. 0 Quote
mar0ni Posted December 21, 2022 Posted December 21, 2022 I received my Orange PI 3 LTS and can also confirm, that WiFi is not working. Is there anything else besides the already posted armbian monitor output above to support fixing this issue? 0 Quote
Whoo Posted December 26, 2022 Posted December 26, 2022 I have the same problem Kernel info: Linux OrPi 5.15.80-sunxi64 #22.11.1 SMP Wed Nov 30 11:23:00 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux armbianmonitor -u output: https://paste.armbian.com/okifayides Sometimes the wifi shown and after I clicked connect is disappeared, really weird. I have to use ethernet cable and client router. 0 Quote
Voronklipper Posted December 27, 2022 Posted December 27, 2022 I have the exact same problem Orpi 3 lts, 22.11.1 jammy. I find the networks, then when i connect it says it could not find the network. I have tested with pass and without pass on 5Ghz and 2.4Ghz with no luck. And after i tried to connect to the network they just dissaper from the search list, and i have to go to the edit connection and delete the wifi networks from there and reboot the device to get them up again on the search list. Im using the nmtui tool. 0 Quote
Whoo Posted December 27, 2022 Posted December 27, 2022 Yeah the same problem, tried using nmtui, nmcli, GUI directly, and armbian-config, none works. Contributors when fix will be released? 0 Quote
Ne0shka Posted January 1, 2023 Posted January 1, 2023 Actual: https://paste.armbian.com/tibanulese 0 Quote
Jotaan Posted January 26, 2023 Posted January 26, 2023 so with a hardwire ethernet connection it works and also with an external usb to wifi adapter it works but there is an onboard wifi antenna that does not 0 Quote
Artenverho Posted February 9, 2023 Posted February 9, 2023 (edited) Hi, I purchased a Orangi Pi 3 LTS but indeed I have the same problem as described here. Ive run armbianmonitor: https://paste.armbian.com/ojizomeqot At first glance I do not see any clear issues that stand out. I seem to have the same WIFI chip as mentioned here: And the image I used is the newest one. Any solution for this problem yet? Edited February 9, 2023 by Artenverho 0 Quote
Igor Posted February 9, 2023 Posted February 9, 2023 On 2/9/2023 at 8:19 AM, Artenverho said: And the image I used is the newest one. Any solution for this problem yet? Expand Some problems has been solved, but not all. Switch to nightly beta repository that is tied to development and see if it helps. Otherwise we invested our private time to research paths that might get us to the solution or at least to the better state, but we also face problems our "customers" don't want to hear about: - we don't have resources for integration or help on integrating this. Voolonteers are scarse and overloaded. We are already over the limits, - with donations https://liberapay.com/armbian hiring help is not possible. Who wants to work for free, already works, others can't afford, - we are also under constant attack by swindlers which waits we solve this so they can take credits or sell it to someone. Remember that its a big difference helping you or helping someone that is making profits out of our generocity. What would you do? 0 Quote
Artenverho Posted February 10, 2023 Posted February 10, 2023 Very reasonable that you are not the ones that are willing (or have resources) to specifically solve problems that occur for each individual systems. I just noticed that image from OrangePi themselves has the same issue. Unfortunately my knowledge on debugging hardware issues is limited but please let me know if I can be of any assistance to test and send back logs. I have been using Armbian for many years and consider it one of the finest pieces of software developed. Ps. I tried the nightly build but it unfortunately did not fix the problem, in the meantime I will be using a USB WIFI dongle as replacement. 0 Quote
