Sakuraa Posted August 23, 2022 Posted August 23, 2022 Is there any way to enable Wake on Lan? As far as I know the Odroid-HC4 Supports WoL but I can't get it to work
Igor Posted August 23, 2022 Posted August 23, 2022 Can you perhaps elaborate in detail what have you tried so far? And supplying all the logs. If feature works on hardware and with their legacy kernel, this doesn't mean it works elsewhere right away. We ditched old and security highly problematic legacy code long time ago. But the price is that not all functions work yet. Here its not mentioned https://linux-meson.com/mainlining.html# and I don't recall if we have this working or not. 1
Sakuraa Posted August 24, 2022 Author Posted August 24, 2022 I didn't really do much except for searching for an option to enable it but I found nothing yet. I also noticed that I can't reboot the board, it just stays off except for the LAN port which blinks slowly.
Sakuraa Posted September 3, 2022 Author Posted September 3, 2022 I read about using hardkernel's kernel with armbian to use the WOL feature here. Are there any guides to switch the kernel to hardkernel's one? Also would this remove any Armbian features?
Sakuraa Posted September 13, 2022 Author Posted September 13, 2022 @Igor sorry for the ping but I didn't found any docs and build options about this topic. Is this even possible?
