Orange Pi 3 LTS - No WIFI
Kaosheng
46 minutes ago, Werner said:
Providing logs with
armbianmonitor -u
 helps with troubleshooting and significantly raises chances that issue gets addressed.
kao@orangepi3-lts:~$ armbianmonitor -u
Network/firewall problem detected. Not able to upload debug info.
Please fix this or use "-U" instead and upload whole output manually
kao@orangepi3-lts:~$ armbianmonitor -U
armbian-hardware-monitor.log
### Activated 1 lzo-rle zram swap devices with 994MB each.
### Activated Armbian ramlog partition with zstd compression
Thu Jun 23 03:13:46 AM UTC 2022 | Orange Pi 3 LTS | 22.05.3 | arm64 | aarch64 | 5.15.48-sunxi64
### dmesg:
[ 1.271389] ohci-platform: OHCI generic platform driver
[ 1.271884] usbcore: registered new interface driver usb-storage
[ 1.272440] mousedev: PS/2 mouse device common for all mice
[ 1.273452] sun6i-rtc 7000000.rtc: registered as rtc0
[ 1.273485] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4)
[ 1.273599] sun6i-rtc 7000000.rtc: RTC enabled
[ 1.273742] i2c_dev: i2c /dev entries driver
[ 1.274541] sunxi-wdt 7020400.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.276070] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pm not found, using dummy regulator
[ 1.276491] sdhci: Secure Digital Host Controller Interface driver
[ 1.276500] sdhci: Copyright(c) Pierre Ossman
[ 1.276524] Synopsys Designware Multimedia Card Interface Driver
[ 1.277348] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.277525] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
[ 1.278836] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.279412] sun8i-ce 1904000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
[ 1.279723] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.279850] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.279963] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.280080] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.280162] sun8i-ce 1904000.crypto: Register cbc(aes)
[ 1.280314] sun8i-ce 1904000.crypto: Register ecb(aes)
[ 1.280452] sun8i-ce 1904000.crypto: Register cbc(des3_ede)
[ 1.280568] sun8i-ce 1904000.crypto: Register ecb(des3_ede)
[ 1.280687] sun8i-ce 1904000.crypto: Register md5
[ 1.280795] sun8i-ce 1904000.crypto: Register sha1
[ 1.280905] sun8i-ce 1904000.crypto: Register sha224
[ 1.281020] sun8i-ce 1904000.crypto: Register sha256
[ 1.281127] sun8i-ce 1904000.crypto: Register sha384
[ 1.281232] sun8i-ce 1904000.crypto: Register sha512
[ 1.281398] sun8i-ce 1904000.crypto: Register stdrng
[ 1.282121] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0
[ 1.282719] hid: raw HID events driver (C) Jiri Kosina
[ 1.282852] usbcore: registered new interface driver usbhid
[ 1.282859] usbhid: USB HID core driver
[ 1.283588] random: crng init done
[ 1.285840] NET: Registered PF_INET6 protocol family
[ 1.870798] Freeing initrd memory: 12684K
[ 1.899454] Segment Routing with IPv6
[ 1.899519] In-situ OAM (IOAM) with IPv6
[ 1.899604] NET: Registered PF_PACKET protocol family
[ 1.899720] 8021q: 802.1Q VLAN Support v1.8
[ 1.899880] 9pnet: Installing 9P2000 support
[ 1.899952] Key type dns_resolver registered
[ 1.900422] registered taskstats version 1
[ 1.900443] Loading compiled-in X.509 certificates
[ 1.904300] Loaded X.509 cert 'Build time autogenerated kernel key: 32330adefd2da02e444296fafd37464380789679'
[ 1.907185] zswap: loaded using pool zstd/z3fold
[ 1.907825] Key type ._fscrypt registered
[ 1.907833] Key type .fscrypt registered
[ 1.907837] Key type fscrypt-provisioning registered
[ 1.908859] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
[ 1.922659] Key type encrypted registered
[ 1.922691] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.922730] ima: No TPM chip found, activating TPM-bypass!
[ 1.922775] ima: Allocated hash algorithm: sha1
[ 1.922808] ima: No architecture policies found
[ 1.922878] evm: Initialising EVM extended attributes:
[ 1.922883] evm: security.selinux
[ 1.922888] evm: security.SMACK64
[ 1.922892] evm: security.SMACK64EXEC
[ 1.922897] evm: security.SMACK64TRANSMUTE
[ 1.922901] evm: security.SMACK64MMAP
[ 1.922905] evm: security.apparmor
[ 1.922909] evm: security.ima
[ 1.922913] evm: security.capability
[ 1.922917] evm: HMAC attrs: 0x1
[ 1.935969] platform 1100000.mixer: Fixing up cyclic dependency with 6510000.tcon-top
[ 1.936305] sun8i-mixer 1100000.mixer: Adding to iommu group 0
[ 1.938389] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 1.938422] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 1.938574] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f064 hci version 0x100 quirks 0x0000000002010010
[ 1.938635] xhci-hcd xhci-hcd.1.auto: irq 43, io mem 0x05200000
[ 1.939086] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.939102] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.939113] usb usb1: Product: xHCI Host Controller
[ 1.939122] usb usb1: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd
[ 1.939130] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 1.939679] hub 1-0:1.0: USB hub found
[ 1.939724] hub 1-0:1.0: 1 port detected
[ 1.940079] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 1.940099] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 1.940117] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 1.940231] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.940397] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.940410] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.940420] usb usb2: Product: xHCI Host Controller
[ 1.940428] usb usb2: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd
[ 1.940436] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 1.940851] hub 2-0:1.0: USB hub found
[ 1.940889] hub 2-0:1.0: 1 port detected
[ 1.943532] sun50i_cpufreq_nvmem: Using CPU speed bin speed0
[ 1.945371] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
[ 1.951715] of_cfs_init
[ 1.951850] of_cfs_init: OK
[ 1.952183] ALSA device list:
[ 1.952189] No soundcards found.
[ 1.953328] Freeing unused kernel memory: 2496K
[ 1.965392] Run /init as init process
[ 1.965399] with arguments:
[ 1.965405] /init
[ 1.965410] with environment:
[ 1.965415] HOME=/
[ 1.965419] TERM=linux
[ 1.965424] ubootpart=ce3dfe46-01
[ 1.965430] cgroup_enable=memory
[ 2.197360] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[ 2.352212] usb 1-1: New USB device found, idVendor=045e, idProduct=0745, bcdDevice= 6.33
[ 2.352245] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.352256] usb 1-1: Product: Microsoft® 2.4GHz Transceiver v7.0
[ 2.352264] usb 1-1: Manufacturer: Microsoft
[ 2.371628] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.0/0003:045E:0745.0001/input/input0
[ 2.397833] axp20x-i2c 0-0036: AXP20x variant AXP806 found
[ 2.406456] input: axp20x-pek as /devices/platform/soc/7081400.i2c/i2c-0/0-0036/axp221-pek/input/input1
[ 2.430062] hid-generic 0003:045E:0745.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input0
[ 2.434077] vdd-cpu: supplied by vcc-5v
[ 2.439356] vdd-gpu: supplied by vcc-5v
[ 2.440064] vdd-sys: Bringing 900000uV into 960000-960000uV
[ 2.440498] vdd-sys: supplied by vcc-5v
[ 2.441417] vcc-dram: supplied by vcc-5v
[ 2.442291] vcc-pl-led-ir: supplied by vcc-5v
[ 2.443422] vcc33-audio-tv-ephy-mac: Bringing 700000uV into 3300000-3300000uV
[ 2.443821] vcc33-audio-tv-ephy-mac: supplied by vcc-5v
[ 2.444503] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Mouse as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input2
[ 2.444994] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input3
[ 2.501752] hid-generic 0003:045E:0745.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input1
[ 2.511185] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input4
[ 2.550092] vcc33-io-pd-emmc-sd-usb-uart-1: Bringing 700000uV into 3300000-3300000uV
[ 2.550453] vcc33-io-pd-emmc-sd-usb-uart-1: supplied by vcc-5v
[ 2.551481] vcc18-dram-bias-pll: supplied by vcc-5v
[ 2.552559] vcc-efuse-pcie-hdmi-pc: supplied by vcc-5v
[ 2.553234] vcc-wifi-io-pm-pg: Bringing 700000uV into 1800000-1800000uV
[ 2.553572] vcc-wifi-io-pm-pg: supplied by vcc-5v
[ 2.554668] bldo4: supplied by vcc-5v
[ 2.555185] vcc33-io-pd-emmc-sd-usb-uart-2: supplied by vcc-5v
[ 2.555987] cldo2: supplied by vcc-5v
[ 2.556633] cldo3: supplied by vcc-5v
[ 2.556863] sw: supplied by regulator-dummy
[ 2.557449] axp20x-i2c 0-0036: AXP20X driver loaded
[ 2.570248] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 System Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input6
[ 2.570764] hid-generic 0003:045E:0745.0003: input,hiddev96,hidraw2: USB HID v1.11 Device [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input2
[ 2.574626] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[ 2.575152] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pb not found, using dummy regulator
[ 2.576079] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator
[ 2.581609] printk: console [ttyS0] disabled
[ 2.581741] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 35, base_baud = 1500000) is a 16550A
[ 2.581965] printk: console [ttyS0] enabled
[ 2.583370] sun4i-drm display-engine: Adding to iommu group 0
[ 2.602997] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e16990)
[ 2.603353] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800008e1abb8)
[ 2.603765] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff800008e11ba0)
[ 2.603887] sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator
[ 2.604602] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.604931] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin
[ 2.605461] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.610057] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff800008e15cc8)
[ 2.610881] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 2.610942] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 1
[ 2.765113] Console: switching to colour frame buffer device 240x67
[ 2.814958] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device
[ 2.839020] acx00-codec acx00-codec: DMA mask not set
[ 2.842787] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[ 2.844953] sunxi-mmc 4020000.mmc: Got CD GPIO
[ 2.845563] vcc-wifi-io: supplied by vcc33-wifi
[ 2.847905] ehci-platform 5101000.usb: EHCI Host Controller
[ 2.847948] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 3
[ 2.848105] ehci-platform 5101000.usb: irq 41, io mem 0x05101000
[ 2.857343] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[ 2.861347] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00
[ 2.861683] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.861698] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.861709] usb usb3: Product: EHCI Host Controller
[ 2.861717] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
[ 2.861726] usb usb3: SerialNumber: 5101000.usb
[ 2.862270] hub 3-0:1.0: USB hub found
[ 2.862312] hub 3-0:1.0: 1 port detected
[ 2.863447] ehci-platform 5311000.usb: EHCI Host Controller
[ 2.863501] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 4
[ 2.863651] ehci-platform 5311000.usb: irq 44, io mem 0x05311000
[ 2.869618] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[ 2.877334] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00
[ 2.877662] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.877677] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.877687] usb usb4: Product: EHCI Host Controller
[ 2.877696] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
[ 2.877704] usb usb4: SerialNumber: 5311000.usb
[ 2.878275] hub 4-0:1.0: USB hub found
[ 2.878317] hub 4-0:1.0: 1 port detected
[ 2.879527] ohci-platform 5101400.usb: Generic Platform OHCI controller
[ 2.879591] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 5
[ 2.879731] ohci-platform 5101400.usb: irq 42, io mem 0x05101400
[ 2.904258] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.906028] mmc0: Problem switching card into high-speed mode!
[ 2.906141] mmc0: new SDHC card at address 0001
[ 2.907012] mmcblk0: mmc0:0001 USD 29.8 GiB
[ 2.909094] mmcblk0: p1
[ 2.941592] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 2.941618] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.941629] usb usb5: Product: Generic Platform OHCI controller
[ 2.941637] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
[ 2.941646] usb usb5: SerialNumber: 5101400.usb
[ 2.942382] hub 5-0:1.0: USB hub found
[ 2.942478] hub 5-0:1.0: 1 port detected
[ 2.943732] ohci-platform 5311400.usb: Generic Platform OHCI controller
[ 2.943797] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 6
[ 2.943945] ohci-platform 5311400.usb: irq 45, io mem 0x05311400
[ 2.997466] mmc2: new HS200 MMC card at address 0001
[ 2.998519] mmcblk2: mmc2:0001 8GTF4R 7.28 GiB
[ 3.000828] mmcblk2boot0: mmc2:0001 8GTF4R 4.00 MiB
[ 3.002395] mmcblk2boot1: mmc2:0001 8GTF4R 4.00 MiB
[ 3.005697] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 3.005727] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.005738] usb usb6: Product: Generic Platform OHCI controller
[ 3.005746] usb usb6: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
[ 3.005755] usb usb6: SerialNumber: 5311400.usb
[ 3.006413] hub 6-0:1.0: USB hub found
[ 3.006468] hub 6-0:1.0: 1 port detected
[ 3.007749] usb_phy_generic usb_phy_generic.4.auto: supply vcc not found, using dummy regulator
[ 3.007972] usb_phy_generic usb_phy_generic.4.auto: dummy supplies not allowed for exclusive requests
[ 3.109696] musb-hdrc musb-hdrc.5.auto: MUSB HDRC host driver
[ 3.109741] musb-hdrc musb-hdrc.5.auto: new USB bus registered, assigned bus number 7
[ 3.110006] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 3.110022] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.110032] usb usb7: Product: MUSB HDRC host driver
[ 3.110041] usb usb7: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd
[ 3.110049] usb usb7: SerialNumber: musb-hdrc.5.auto
[ 3.110654] hub 7-0:1.0: USB hub found
[ 3.110724] hub 7-0:1.0: 1 port detected
[ 3.130721] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found
[ 3.130747] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found
[ 3.131045] dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator
[ 3.131271] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[ 3.131313] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 50000)
[ 3.237621] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
[ 3.237647] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
[ 3.237655] dwmac-sun8i 5020000.ethernet: COE Type 2
[ 3.237666] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
[ 3.237673] dwmac-sun8i 5020000.ethernet: Normal descriptors
[ 3.237680] dwmac-sun8i 5020000.ethernet: Chain mode enabled
[ 3.478371] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none.
[ 3.673352] usb 5-1: new full-speed USB device number 2 using ohci-platform
[ 3.910374] usb 5-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.10
[ 3.910404] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.910415] usb 5-1: Product: USB Receiver
[ 3.910424] usb 5-1: Manufacturer: Logitech
[ 3.919527] input: Logitech USB Receiver as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.0/0003:046D:C52B.0004/input/input7
[ 3.977996] hid-generic 0003:046D:C52B.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-5101400.usb-1/input0
[ 3.984266] input: Logitech USB Receiver Mouse as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input8
[ 3.984724] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input9
[ 4.041716] input: Logitech USB Receiver System Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input10
[ 4.042095] hid-generic 0003:046D:C52B.0005: input,hiddev97,hidraw4: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-5101400.usb-1/input1
[ 4.046730] hid-generic 0003:046D:C52B.0006: hiddev98,hidraw5: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2
[ 4.781944] systemd[1]: System time before build time, advancing clock.
[ 4.870091] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq
[ 4.879064] systemd[1]: systemd 249.11-0ubuntu3.1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS -OPENSSL +ACL +BLKID +CURL +ELFUTILS -FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP -LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 4.879739] systemd[1]: Detected architecture arm64.
[ 4.883086] systemd[1]: Hostname set to <orangepi3-lts>.
[ 5.105388] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[ 5.122726] mmc1: new high speed SDIO card at address 8800
[ 6.193555] systemd[1]: Queued start job for default target Graphical Interface.
[ 6.199452] systemd[1]: Created slice Slice /system/modprobe.
[ 6.202231] systemd[1]: Created slice Slice /system/serial-getty.
[ 6.204080] systemd[1]: Created slice User and Session Slice.
[ 6.204943] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.206453] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.207405] systemd[1]: Reached target Remote File Systems.
[ 6.207760] systemd[1]: Reached target Slice Units.
[ 6.208108] systemd[1]: Reached target Swaps.
[ 6.208409] systemd[1]: Reached target System Time Set.
[ 6.208987] systemd[1]: Reached target Local Verity Protected Volumes.
[ 6.210061] systemd[1]: Listening on Syslog Socket.
[ 6.210934] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.211571] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 6.212959] systemd[1]: Listening on Journal Audit Socket.
[ 6.213968] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.215050] systemd[1]: Listening on Journal Socket.
[ 6.226846] systemd[1]: Listening on udev Control Socket.
[ 6.227964] systemd[1]: Listening on udev Kernel Socket.
[ 6.232507] systemd[1]: Mounting Huge Pages File System...
[ 6.237816] systemd[1]: Mounting POSIX Message Queue File System...
[ 6.243581] systemd[1]: Mounting Kernel Debug File System...
[ 6.244898] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 6.252149] systemd[1]: Starting Restore / save the current clock...
[ 6.257902] systemd[1]: Starting Set the console keyboard layout...
[ 6.264301] systemd[1]: Starting Create List of Static Device Nodes...
[ 6.270918] systemd[1]: Starting Load Kernel Module configfs...
[ 6.277786] systemd[1]: Starting Load Kernel Module drm...
[ 6.284675] systemd[1]: Starting Load Kernel Module fuse...
[ 6.292060] systemd[1]: Started Nameserver information manager.
[ 6.293725] systemd[1]: Reached target Preparation for Network.
[ 6.294932] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 6.306924] systemd[1]: Starting Load Kernel Modules...
[ 6.312706] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.318432] systemd[1]: Starting Coldplug All udev Devices...
[ 6.328490] systemd[1]: Mounted Huge Pages File System.
[ 6.329589] fuse: init (API version 7.34)
[ 6.330211] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.331670] systemd[1]: Mounted Kernel Debug File System.
[ 6.334979] systemd[1]: Finished Restore / save the current clock.
[ 6.338419] systemd[1]: Finished Create List of Static Device Nodes.
[ 6.340843] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 6.342500] systemd[1]: Finished Load Kernel Module configfs.
[ 6.344775] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 6.346521] systemd[1]: Finished Load Kernel Module drm.
[ 6.348776] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 6.350118] systemd[1]: Finished Load Kernel Module fuse.
[ 6.357102] systemd[1]: Mounting FUSE Control File System...
[ 6.363222] systemd[1]: Mounting Kernel Configuration File System...
[ 6.371020] systemd[1]: Mounted FUSE Control File System.
[ 6.374967] systemd[1]: Mounted Kernel Configuration File System.
[ 6.387839] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
[ 6.393209] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 6.394291] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 6.398918] systemd[1]: Starting Load/Save Random Seed...
[ 6.404754] systemd[1]: Starting Create System Users...
[ 6.605011] WCN: marlin_init entry!
[ 6.605666] WCN: wcn config bt wake host
[ 6.605940] WCN_ERR: dts node for bt_wake not found
[ 6.605943] WCN: marlin2 parse_dt some para not config
[ 6.605957] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
[ 6.613551] sdiohal:sdiohal_init ok
[ 6.614342] WCN: marlin_probe ok!
[ 6.615383] systemd[1]: Finished Load/Save Random Seed.
[ 6.616503] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[ 6.629638] mtty_probe init device addr: 0x00000000e4ddf53f
[ 6.629847] -->rfkill_bluetooth_init
[ 6.629985] bluetooth_set_power: start_block=1
[ 6.629996] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0
[ 6.630006] bluetooth_set_power: end_block=1
[ 6.630024] <--rfkill_bluetooth_init
[ 6.642377] systemd[1]: Finished Create System Users.
[ 6.648577] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 6.718136] systemd[1]: Finished Set the console keyboard layout.
[ 6.724088] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.725783] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.746999] [ADDR_MGT] addr_mgt_probe: module version: v1.0.9
[ 6.747155] [ADDR_MGT] addr_mgt_probe: success.
[ 6.812225] WCN: start_marlin [MARLIN_WIFI]
[ 6.812252] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
[ 6.812260] WCN: the first power on start
[ 6.818045] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 6.825520] systemd[1]: Reached target Preparation for Local File Systems.
[ 6.837722] systemd[1]: Mounting /tmp...
[ 6.851964] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 6.862991] systemd[1]: Mounted /tmp.
[ 6.870324] systemd[1]: Reached target Local File Systems.
[ 6.882576] systemd[1]: Starting Armbian leds state...
[ 6.895047] systemd[1]: Starting Armbian ZRAM config...
[ 6.907291] systemd[1]: Starting Set console font and keymap...
[ 6.917410] WCN: marlin chip en dummy pull up -- need manually set GPIO
[ 6.919805] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[ 6.943858] systemd[1]: Starting Set Up Additional Binary Formats...
[ 6.945374] sdiohal:sdiohal_scan_card
[ 6.945565] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=50000000
[ 6.945658] WCN: marlin_scan_finish!
[ 6.945663] sdiohal:probe ok
[ 6.945774] sdiohal:scan end!
[ 6.945780] WCN: then marlin start to download
[ 6.946019] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
[ 6.946032] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
[ 6.952293] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 6.952618] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 6.955861] systemd[1]: Finished Set console font and keymap.
[ 6.968835] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 362 (systemd-binfmt)
[ 6.974598] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 6.993966] systemd[1]: Finished Coldplug All udev Devices.
[ 7.002822] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[ 7.098961] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[ 7.109231] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 7.132532] systemd[1]: Finished Set Up Additional Binary Formats.
[ 7.160398] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[ 7.209436] systemd[1]: Finished Armbian leds state.
[ 7.513983] systemd[1]: Started Rule-based Manager for Device Events and Files.
[ 7.521754] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[ 7.522417] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active.
[ 7.533479] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[ 7.533648] systemd[1]: Reached target Local Encrypted Volumes.
[ 7.575897] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ 7.627231] systemd[1]: Starting Load/Save RF Kill Switch Status...
[ 7.777051] systemd[1]: Started Load/Save RF Kill Switch Status.
[ 7.954890] systemd[1]: Found device /dev/ttyS0.
[ 8.014195] panfrost 1800000.gpu: clock rate = 432000000
[ 8.014230] panfrost 1800000.gpu: bus_clock rate = 100000000
[ 8.014548] panfrost 1800000.gpu: mali-t720 id 0x720 major 0x1 minor 0x1 status 0x0
[ 8.014559] panfrost 1800000.gpu: features: 00000000,10309e40, issues: 00000000,21054400
[ 8.014566] panfrost 1800000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002821 AS:0xf JS:0x7
[ 8.014573] panfrost 1800000.gpu: shader_present=0x3 l2_present=0x1
[ 8.014613] WCN: combin_img 0 marlin_firmware_write finish and successful
[ 8.014901] WCN: marlin_start_run read reset reg val:0x1
[ 8.014906] WCN: after do marlin_start_run reset reg val:0x0
[ 8.015080] WCN: s_marlin_bootup_time=8015079802
[ 8.015466] [drm] Initialized panfrost 1.2.0 20180908 for 1800000.gpu on minor 1
[ 8.021616] WCN: clock mode: TSX
[ 8.021814] WCN: marlin_write_cali_data sync init_state:0x91036042
[ 8.049599] WCN: marlin_write_cali_data sync init_state:0x91036042
[ 8.068392] mc: Linux media interface: v0.10
[ 8.077689] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
[ 8.077720] WCN: sdio_config bt_wake_host trigger:[high]
[ 8.077723] WCN: sdio_config irq:[inband]
[ 8.077725] WCN: sdio_config wake_host_level_duration_time:[20ms]
[ 8.077731] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
[ 8.077733] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config)
[ 8.078060] WCN: marlin_write_cali_data finish
[ 8.078227] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.105573] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.137562] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.165584] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.184903] videodev: Linux video capture interface: v2.00
[ 8.193587] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
[ 8.193612] WCN: marlin_bind_verify confuse data: 0x33fea07bef5424afb3eb92a5307b8c0e
[ 8.193627] WCN: marlin_bind_verify verify data: 0xbe88975721254815cb97ad470d21e601
[ 8.194121] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
[ 8.221621] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
[ 8.221645] sdiohal:sdiohal_runtime_get entry
[ 8.224117] WCN: get_cp2_version entry!
[ 8.268773] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
[ 8.268824] WCN: switch_cp2_log - close entry!
[ 8.270121] WCN: WCND at cmd read:OK
[ 8.270208] WCN: then marlin download finished and run ok
[ 8.270214] WCN: start_loopcheck
[ 8.288538] WCN: get_board_ant_num [one_ant]
[ 8.288563] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
[ 8.357396] Registered IR keymap rc-empty
[ 8.357535] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0
[ 8.358087] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
[ 8.358296] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input12
[ 8.358715] sunxi-ir 7040000.ir: initialized sunXi IR driver
[ 8.379249] zram: Added device: zram0
[ 8.379675] zram: Added device: zram1
[ 8.380117] zram: Added device: zram2
[ 8.410616] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
[ 8.416810] systemd[1]: Finished Load Kernel Modules.
[ 8.425572] systemd[1]: Starting Apply Kernel Variables...
[ 8.502238] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.503493] cedrus 1c0e000.video-codec: Adding to iommu group 0
[ 8.509361] cedrus 1c0e000.video-codec: Device registered as /dev/video0
[ 8.569078] systemd[1]: Finished Apply Kernel Variables.
[ 8.615426] zram0: detected capacity change from 0 to 2037304
[ 8.633094] systemd[1]: Starting Raise network interfaces...
[ 8.650146] Adding 1018648k swap on /dev/zram0. Priority:5 extents:1 across:1018648k SSFS
[ 8.824826] logitech-djreceiver 0003:046D:C52B.0006: hiddev97,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2
[ 8.894117] zram1: detected capacity change from 0 to 102400
[ 8.958383] input: Logitech Wireless Device PID:4004 Keyboard as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input13
[ 9.009858] hid-generic 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4004] on usb-5101400.usb-1/input2:1
[ 9.036255] systemd[1]: Finished Armbian ZRAM config.
[ 9.044253] systemd[1]: Starting Armbian memory supported logging...
[ 9.171018] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none.
[ 9.198787] input: Logitech K360 as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input17
[ 9.199362] logitech-hidpp-device 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K360] on usb-5101400.usb-1/input2:1
[ 9.697942] systemd[1]: Finished Raise network interfaces.
[ 9.704493] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 9.704773] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[ 9.705128] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 9.710522] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[ 9.710654] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 9.710772] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 9.710855] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 9.857115] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 9.857354] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[ 9.857432] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[ 9.857521] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 9.857622] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 9.857735] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 11.391375] systemd[1]: Finished Armbian memory supported logging.
[ 11.400571] systemd[1]: Starting Journal Service...
[ 11.544107] systemd[1]: Started Journal Service.
[ 11.573374] systemd-journald[677]: Received client request to flush runtime journal.
### armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD=orangepi3-lts
BOARD_NAME="Orange Pi 3 LTS"
BOARDFAMILY=sun50iw6
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=13f5fba13c
VERSION=22.05.3
LINUXFAMILY=sunxi64
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm64
KERNEL_IMAGE_TYPE=stable
### boot environment:
verbosity=1
bootlogo=false
console=both
disp_mode=1920x1080p60
overlay_prefix=sun50i-h6
rootdev=UUID=71b44a6c-5bb8-4352-afe7-d22b8e62de4c
rootfstype=ext4
### lsusb:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 005 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
### lscpu:
Architecture: aarch64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Vendor ID: ARM
Model name: Cortex-A53
Model: 4
Thread(s) per core: 1
Core(s) per cluster: 4
Socket(s): -
Cluster(s): 1
Stepping: r0p4
CPU max MHz: 1800.0000
CPU min MHz: 480.0000
BogoMIPS: 48.00
Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
NUMA node(s): 1
NUMA node0 CPU(s): 0-3
Vulnerability Itlb multihit: Not affected
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Mmio stale data: Not affected
Vulnerability Spec store bypass: Not affected
Vulnerability Spectre v1: Mitigation; __user pointer sanitization
Vulnerability Spectre v2: Not affected
Vulnerability Srbds: Not affected
Vulnerability Tsx async abort: Not affected
### cpuinfo:
processor : 0
BogoMIPS : 48.00
Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
CPU implementer : 0x41
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
### meminfo:
MemTotal: 2037300 kB
MemFree: 1849616 kB
MemAvailable: 1851652 kB
Buffers: 11672 kB
Cached: 50624 kB
SwapCached: 0 kB
Active: 31520 kB
Inactive: 51264 kB
Active(anon): 444 kB
Inactive(anon): 23568 kB
Active(file): 31076 kB
Inactive(file): 27696 kB
Unevictable: 0 kB
Mlocked: 0 kB
SwapTotal: 1018648 kB
SwapFree: 1018648 kB
Dirty: 1676 kB
Writeback: 0 kB
AnonPages: 20500 kB
Mapped: 16968 kB
Shmem: 3392 kB
KReclaimable: 10432 kB
Slab: 45848 kB
SReclaimable: 10432 kB
SUnreclaim: 35416 kB
KernelStack: 2512 kB
PageTables: 1688 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 2037296 kB
Committed_AS: 43924 kB
VmallocTotal: 133143592960 kB
VmallocUsed: 22764 kB
VmallocChunk: 0 kB
Percpu: 976 kB
AnonHugePages: 0 kB
ShmemHugePages: 0 kB
ShmemPmdMapped: 0 kB
FileHugePages: 0 kB
FilePmdMapped: 0 kB
CmaTotal: 131072 kB
CmaFree: 128768 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
Hugetlb: 0 kB
### virtual memory:
vm.admin_reserve_kbytes = 8192
vm.compaction_proactiveness = 20
vm.compact_unevictable_allowed = 1
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirtytime_expire_seconds = 43200
vm.dirty_writeback_centisecs = 500
vm.extfrag_threshold = 500
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256 256 32 0
vm.max_map_count = 65530
vm.min_free_kbytes = 22528
vm.min_slab_ratio = 5
vm.min_unmapped_ratio = 1
vm.mmap_min_addr = 32768
vm.mmap_rnd_bits = 18
vm.mmap_rnd_compat_bits = 11
vm.nr_hugepages = 0
vm.nr_hugepages_mempolicy = 0
vm.nr_overcommit_hugepages = 0
vm.numa_stat = 1
vm.numa_zonelist_order = Node
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_kbytes = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 0
vm.page_lock_unfairness = 5
vm.panic_on_oom = 0
vm.percpu_pagelist_high_fraction = 0
vm.stat_interval = 1
vm.swappiness = 100
vm.user_reserve_kbytes = 63009
vm.vfs_cache_pressure = 100
vm.watermark_boost_factor = 15000
vm.watermark_scale_factor = 10
vm.zone_reclaim_mode = 0
### ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 02:07:29:30:86:8c brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 00:32:c3:9f:6a:08 brd ff:ff:ff:ff:ff:ff
### partitions:
major minor #blocks name
179 0 31205376 mmcblk0
179 1 6500352 mmcblk0p1
179 32 7634944 mmcblk2
252 0 1018652 zram0
252 1 51200 zram1
### df:
tmpfs 199M 3.4M 196M 2% /run
/dev/mmcblk0p1 6.0G 4.9G 1.1G 83% /
tmpfs 995M 0 995M 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 995M 0 995M 0% /tmp
/dev/zram1 47M 1.6M 42M 4% /var/log
### lsblk:
NAME FSTYPE SIZE MOUNTPOINT UUID
mmcblk0 29.8G
└─mmcblk0p1 ext4 6.2G / 71b44a6c-5bb8-4352-afe7-d22b8e62de4c
mmcblk2 swap 7.3G 6a6f4ef8-bcc6-4021-a70f-de04ada07a25
mmcblk2boot0 swap 4M 6a6f4ef8-bcc6-4021-a70f-de04ada07a25
mmcblk2boot1 swap 4M 6a6f4ef8-bcc6-4021-a70f-de04ada07a25
zram1 50M /var/log
zram2 0B
### zramctl:
NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram1 zstd 50M 68K 728B 44K 4 /var/log
/dev/zram0 lzo-rle 994.8M 4K 74B 12K 4 [SWAP]
### mtab:
/dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
### [resize2fs] Leaving 1% spare area. Start resizing partition /dev/mmcblk0p1 now:
252 0 1018652 zram0
252 1 51200 zram1
Executing fdisk, fsck and partprobe:
Welcome to fdisk (util-linux 2.37.2).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
This disk is currently in use - repartitioning is probably a bad idea.
It's recommended to umount all file systems, and swapoff all swap
partitions on this disk.
Command (m for help):
Selected partition 1
Partition 1 has been deleted.
Command (m for help): Partition type
p primary (0 primary, 0 extended, 4 free)
e extended (container for logical partitions)
Select (default p): Partition number (1-4, default 1): First sector (2048-62410751, default 2048): Last sector, +/-sectors or +/-size{K,M,G,T,P} (8192-62410751, default 62410751):
Created a new partition 1 of type 'Linux' and of size 29.4 GiB.
Partition #1 contains a ext4 signature.
### mmc0:0001 info:
fwrev: 0x0
uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=USD MODALIAS=mmc:block
cid: 1d414455534400001000005ae0016181
rca: 0x0001
csd: 400e00325b590000ee137f800a40004d
manfid: 0x00001d
ocr: 0x00200000
preferred_erase_size: 4194304
type: SD
hwrev: 0x1
date: 01/2022
dsr: 0x404
The partition table has been altered.
Syncing disks.
erase_size: 512
oemid: 0x4144
serial: 0x00005ae0
ssr: 000000000500000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
scr: 02b5808200000000
### mmc2:0001 info:
fwrev: 0x0600000000000000
uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=8GTF4R MODALIAS=mmc:block
New partition table:
cid: 15010038475446345206d410e21fc801
179 1 30879744 mmcblk0p1
252 0 1018652 zram0
252 1 51200 zram1
Now trying to resize ext4 filesystem on /dev/mmcblk0p1 to the limits:
rel_sectors: 0x1
resize2fs 1.46.5 (30-Dec-2021)
enhanced_rpmb_supported: 0x1
rca: 0x0001
pre_eol_info: 0x01
csd: d02701320f5903fff6dbffef8e40400d
manfid: 0x000015
ocr: 0x00200000
enhanced_area_offset: 18446744073709551594
raw_rpmb_size_mult: 0x4
type: MMC
hwrev: 0x0
date: 12/2021
prv: 0x6
ffu_capable: 1
dsr: 0x404
erase_size: 524288
life_time: 0x01 0x01
enhanced_area_size: 4294967274
oemid: 0x0100
serial: 0xd410e21f
cmdq_en: 0
rev: 0x8
### Boot system health:
Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St.
03:13:49: 1080MHz 1.34 51% 19% 13% 0% 18% 0% 49.3°C 0/9
03:13:50: 1080MHz 1.71 53% 7% 3% 0% 42% 0% 48.5°C 0/9
03:13:50: 1488MHz 1.71 35% 9% 2% 0% 22% 0% 48.7°C 0/9
03:13:50: 1080MHz 1.71 32% 8% 2% 0% 20% 0% 48.7°C 0/9
03:13:51: 1080MHz 1.71 35% 8% 4% 1% 21% 0% 49.1°C 0/9
Filesystem at /dev/mmcblk0p1 is mounted on /; on-line resizing required
old_desc_blocks = 1, new_desc_blocks = 2
The filesystem on /dev/mmcblk0p1 is now 7719936 (4k) blocks long.
### [resize2fs] Start resizing ext4 partition /dev/mmcblk0p1 now
The filesystem is already 7719936 (4k) blocks long. Nothing to do!
### quick iozone test: 4 144 824 6811 6817 6446 2242
### [firstrun] Recreated SSH keys (entropy: 256 256)
Thu Jun 23 11:40:42 AM CST 2022 | Orange Pi 3 LTS | 22.05.3 | arm64 | aarch64 | 5.15.48-sunxi64
### dmesg:
[ 1.272840] i2c_dev: i2c /dev entries driver
[ 1.273687] sunxi-wdt 7020400.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.275263] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pm not found, using dummy regulator
[ 1.275681] sdhci: Secure Digital Host Controller Interface driver
[ 1.275689] sdhci: Copyright(c) Pierre Ossman
[ 1.275714] Synopsys Designware Multimedia Card Interface Driver
[ 1.276505] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.276668] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
[ 1.277837] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.278440] sun8i-ce 1904000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
[ 1.278705] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.278843] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.278941] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.279034] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.279118] sun8i-ce 1904000.crypto: Register cbc(aes)
[ 1.279270] sun8i-ce 1904000.crypto: Register ecb(aes)
[ 1.279382] sun8i-ce 1904000.crypto: Register cbc(des3_ede)
[ 1.279491] sun8i-ce 1904000.crypto: Register ecb(des3_ede)
[ 1.279598] sun8i-ce 1904000.crypto: Register md5
[ 1.279710] sun8i-ce 1904000.crypto: Register sha1
[ 1.279822] sun8i-ce 1904000.crypto: Register sha224
[ 1.279933] sun8i-ce 1904000.crypto: Register sha256
[ 1.280039] sun8i-ce 1904000.crypto: Register sha384
[ 1.280147] sun8i-ce 1904000.crypto: Register sha512
[ 1.280254] sun8i-ce 1904000.crypto: Register stdrng
[ 1.280979] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0
[ 1.281617] hid: raw HID events driver (C) Jiri Kosina
[ 1.281760] usbcore: registered new interface driver usbhid
[ 1.281768] usbhid: USB HID core driver
[ 1.282505] random: crng init done
[ 1.284692] NET: Registered PF_INET6 protocol family
[ 1.870669] Freeing initrd memory: 12684K
[ 1.899337] Segment Routing with IPv6
[ 1.899410] In-situ OAM (IOAM) with IPv6
[ 1.899505] NET: Registered PF_PACKET protocol family
[ 1.899615] 8021q: 802.1Q VLAN Support v1.8
[ 1.899772] 9pnet: Installing 9P2000 support
[ 1.899846] Key type dns_resolver registered
[ 1.900287] registered taskstats version 1
[ 1.900304] Loading compiled-in X.509 certificates
[ 1.904160] Loaded X.509 cert 'Build time autogenerated kernel key: 32330adefd2da02e444296fafd37464380789679'
[ 1.907062] zswap: loaded using pool zstd/z3fold
[ 1.907708] Key type ._fscrypt registered
[ 1.907716] Key type .fscrypt registered
[ 1.907721] Key type fscrypt-provisioning registered
[ 1.908736] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
[ 1.922610] Key type encrypted registered
[ 1.922643] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.922683] ima: No TPM chip found, activating TPM-bypass!
[ 1.922711] ima: Allocated hash algorithm: sha1
[ 1.922743] ima: No architecture policies found
[ 1.922791] evm: Initialising EVM extended attributes:
[ 1.922796] evm: security.selinux
[ 1.922800] evm: security.SMACK64
[ 1.922805] evm: security.SMACK64EXEC
[ 1.922809] evm: security.SMACK64TRANSMUTE
[ 1.922813] evm: security.SMACK64MMAP
[ 1.922818] evm: security.apparmor
[ 1.922822] evm: security.ima
[ 1.922826] evm: security.capability
[ 1.922830] evm: HMAC attrs: 0x1
[ 1.935894] platform 1100000.mixer: Fixing up cyclic dependency with 6510000.tcon-top
[ 1.936246] sun8i-mixer 1100000.mixer: Adding to iommu group 0
[ 1.938307] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 1.938338] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 1.938483] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f064 hci version 0x100 quirks 0x0000000002010010
[ 1.938551] xhci-hcd xhci-hcd.1.auto: irq 43, io mem 0x05200000
[ 1.939042] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.939058] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.939069] usb usb1: Product: xHCI Host Controller
[ 1.939077] usb usb1: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd
[ 1.939086] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 1.939617] hub 1-0:1.0: USB hub found
[ 1.939666] hub 1-0:1.0: 1 port detected
[ 1.940002] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 1.940022] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 1.940045] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 1.940139] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.940297] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.940310] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.940321] usb usb2: Product: xHCI Host Controller
[ 1.940329] usb usb2: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd
[ 1.940337] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 1.940741] hub 2-0:1.0: USB hub found
[ 1.940778] hub 2-0:1.0: 1 port detected
[ 1.943495] sun50i_cpufreq_nvmem: Using CPU speed bin speed0
[ 1.945277] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
[ 1.951649] of_cfs_init
[ 1.951764] of_cfs_init: OK
[ 1.952094] ALSA device list:
[ 1.952101] No soundcards found.
[ 1.953207] Freeing unused kernel memory: 2496K
[ 1.977591] Run /init as init process
[ 1.977600] with arguments:
[ 1.977606] /init
[ 1.977612] with environment:
[ 1.977616] HOME=/
[ 1.977621] TERM=linux
[ 1.977626] ubootpart=ce3dfe46-01
[ 1.977631] cgroup_enable=memory
[ 2.193555] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[ 2.359296] usb 1-1: New USB device found, idVendor=045e, idProduct=0745, bcdDevice= 6.33
[ 2.359334] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.359345] usb 1-1: Product: Microsoft® 2.4GHz Transceiver v7.0
[ 2.359353] usb 1-1: Manufacturer: Microsoft
[ 2.380572] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.0/0003:045E:0745.0001/input/input0
[ 2.405951] axp20x-i2c 0-0036: AXP20x variant AXP806 found
[ 2.416250] input: axp20x-pek as /devices/platform/soc/7081400.i2c/i2c-0/0-0036/axp221-pek/input/input1
[ 2.440095] hid-generic 0003:045E:0745.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input0
[ 2.444209] vdd-cpu: supplied by vcc-5v
[ 2.445995] vdd-gpu: supplied by vcc-5v
[ 2.446737] vdd-sys: Bringing 900000uV into 960000-960000uV
[ 2.447163] vdd-sys: supplied by vcc-5v
[ 2.448220] vcc-dram: supplied by vcc-5v
[ 2.449137] vcc-pl-led-ir: supplied by vcc-5v
[ 2.450174] vcc33-audio-tv-ephy-mac: Bringing 700000uV into 3300000-3300000uV
[ 2.450587] vcc33-audio-tv-ephy-mac: supplied by vcc-5v
[ 2.457417] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Mouse as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input2
[ 2.458172] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input3
[ 2.517969] hid-generic 0003:045E:0745.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input1
[ 2.530047] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input4
[ 2.558277] vcc33-io-pd-emmc-sd-usb-uart-1: Bringing 700000uV into 3300000-3300000uV
[ 2.558638] vcc33-io-pd-emmc-sd-usb-uart-1: supplied by vcc-5v
[ 2.559627] vcc18-dram-bias-pll: supplied by vcc-5v
[ 2.560734] vcc-efuse-pcie-hdmi-pc: supplied by vcc-5v
[ 2.561386] vcc-wifi-io-pm-pg: Bringing 700000uV into 1800000-1800000uV
[ 2.561719] vcc-wifi-io-pm-pg: supplied by vcc-5v
[ 2.562819] bldo4: supplied by vcc-5v
[ 2.563341] vcc33-io-pd-emmc-sd-usb-uart-2: supplied by vcc-5v
[ 2.564136] cldo2: supplied by vcc-5v
[ 2.564801] cldo3: supplied by vcc-5v
[ 2.565035] sw: supplied by regulator-dummy
[ 2.565598] axp20x-i2c 0-0036: AXP20X driver loaded
[ 2.579120] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[ 2.579642] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pb not found, using dummy regulator
[ 2.580524] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator
[ 2.581205] printk: console [ttyS0] disabled
[ 2.581316] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 35, base_baud = 1500000) is a 16550A
[ 2.581600] printk: console [ttyS0] enabled
[ 2.582895] sun4i-drm display-engine: Adding to iommu group 0
[ 2.589957] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 System Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input6
[ 2.590397] hid-generic 0003:045E:0745.0003: input,hiddev96,hidraw2: USB HID v1.11 Device [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input2
[ 2.602524] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e16990)
[ 2.602880] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800008e1abb8)
[ 2.603276] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff800008e11ba0)
[ 2.603403] sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator
[ 2.603905] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.604269] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin
[ 2.608442] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.608956] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff800008e15cc8)
[ 2.609998] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 2.610059] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 1
[ 2.766758] Console: switching to colour frame buffer device 240x67
[ 2.816582] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device
[ 2.837317] acx00-codec acx00-codec: DMA mask not set
[ 2.841040] vcc-wifi-io: supplied by vcc33-wifi
[ 2.841454] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[ 2.842711] sunxi-mmc 4020000.mmc: Got CD GPIO
[ 2.846375] ehci-platform 5101000.usb: EHCI Host Controller
[ 2.846421] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 3
[ 2.846575] ehci-platform 5101000.usb: irq 41, io mem 0x05101000
[ 2.848622] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq
[ 2.865562] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00
[ 2.865575] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[ 2.865860] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[ 2.865911] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.865925] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.865936] usb usb3: Product: EHCI Host Controller
[ 2.865945] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
[ 2.865953] usb usb3: SerialNumber: 5101000.usb
[ 2.866566] hub 3-0:1.0: USB hub found
[ 2.866635] hub 3-0:1.0: 1 port detected
[ 2.867969] ehci-platform 5311000.usb: EHCI Host Controller
[ 2.868052] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 4
[ 2.868209] ehci-platform 5311000.usb: irq 44, io mem 0x05311000
[ 2.881527] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00
[ 2.881876] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.881891] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.881901] usb usb4: Product: EHCI Host Controller
[ 2.881914] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
[ 2.881923] usb usb4: SerialNumber: 5311000.usb
[ 2.882497] hub 4-0:1.0: USB hub found
[ 2.882543] hub 4-0:1.0: 1 port detected
[ 2.883659] ohci-platform 5101400.usb: Generic Platform OHCI controller
[ 2.883696] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 5
[ 2.883846] ohci-platform 5101400.usb: irq 42, io mem 0x05101400
[ 2.901121] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.902890] mmc0: Problem switching card into high-speed mode!
[ 2.903010] mmc0: new SDHC card at address 0001
[ 2.903892] mmcblk0: mmc0:0001 USD 29.8 GiB
[ 2.905998] mmcblk0: p1
[ 2.945815] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 2.945843] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.945853] usb usb5: Product: Generic Platform OHCI controller
[ 2.945862] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
[ 2.945870] usb usb5: SerialNumber: 5101400.usb
[ 2.946508] hub 5-0:1.0: USB hub found
[ 2.946564] hub 5-0:1.0: 1 port detected
[ 2.947693] ohci-platform 5311400.usb: Generic Platform OHCI controller
[ 2.947732] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 6
[ 2.947873] ohci-platform 5311400.usb: irq 45, io mem 0x05311400
[ 3.005682] mmc2: new HS200 MMC card at address 0001
[ 3.006689] mmcblk2: mmc2:0001 8GTF4R 7.28 GiB
[ 3.009191] mmcblk2boot0: mmc2:0001 8GTF4R 4.00 MiB
[ 3.009899] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 3.009929] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.009940] usb usb6: Product: Generic Platform OHCI controller
[ 3.009949] usb usb6: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
[ 3.009957] usb usb6: SerialNumber: 5311400.usb
[ 3.010742] hub 6-0:1.0: USB hub found
[ 3.010820] hub 6-0:1.0: 1 port detected
[ 3.011003] mmcblk2boot1: mmc2:0001 8GTF4R 4.00 MiB
[ 3.012287] usb_phy_generic usb_phy_generic.4.auto: supply vcc not found, using dummy regulator
[ 3.012471] usb_phy_generic usb_phy_generic.4.auto: dummy supplies not allowed for exclusive requests
[ 3.078113] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[ 3.095714] mmc1: new high speed SDIO card at address 8800
[ 3.109911] musb-hdrc musb-hdrc.5.auto: MUSB HDRC host driver
[ 3.109956] musb-hdrc musb-hdrc.5.auto: new USB bus registered, assigned bus number 7
[ 3.110288] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 3.110305] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.110316] usb usb7: Product: MUSB HDRC host driver
[ 3.110324] usb usb7: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd
[ 3.110333] usb usb7: SerialNumber: musb-hdrc.5.auto
[ 3.110923] hub 7-0:1.0: USB hub found
[ 3.110989] hub 7-0:1.0: 1 port detected
[ 3.127115] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found
[ 3.127143] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found
[ 3.127455] dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator
[ 3.127695] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[ 3.127740] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 50000)
[ 3.233767] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
[ 3.233793] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
[ 3.233800] dwmac-sun8i 5020000.ethernet: COE Type 2
[ 3.233809] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
[ 3.233817] dwmac-sun8i 5020000.ethernet: Normal descriptors
[ 3.233824] dwmac-sun8i 5020000.ethernet: Chain mode enabled
[ 3.470451] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none.
[ 3.693548] usb 5-1: new full-speed USB device number 2 using ohci-platform
[ 3.934574] usb 5-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.10
[ 3.934605] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.934616] usb 5-1: Product: USB Receiver
[ 3.934624] usb 5-1: Manufacturer: Logitech
[ 3.943645] input: Logitech USB Receiver as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.0/0003:046D:C52B.0004/input/input7
[ 4.002215] hid-generic 0003:046D:C52B.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-5101400.usb-1/input0
[ 4.008419] input: Logitech USB Receiver Mouse as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input8
[ 4.008877] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input9
[ 4.065886] input: Logitech USB Receiver System Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input10
[ 4.066269] hid-generic 0003:046D:C52B.0005: input,hiddev97,hidraw4: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-5101400.usb-1/input1
[ 4.070836] hid-generic 0003:046D:C52B.0006: hiddev98,hidraw5: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2
[ 4.842234] systemd[1]: System time before build time, advancing clock.
[ 4.939393] systemd[1]: systemd 249.11-0ubuntu3.1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS -OPENSSL +ACL +BLKID +CURL +ELFUTILS -FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP -LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 4.940061] systemd[1]: Detected architecture arm64.
[ 4.943463] systemd[1]: Hostname set to <orangepi3-lts>.
[ 6.280645] systemd[1]: Queued start job for default target Graphical Interface.
[ 6.286592] systemd[1]: Created slice Slice /system/modprobe.
[ 6.289331] systemd[1]: Created slice Slice /system/serial-getty.
[ 6.291295] systemd[1]: Created slice User and Session Slice.
[ 6.292193] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.293712] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.294623] systemd[1]: Reached target Remote File Systems.
[ 6.294972] systemd[1]: Reached target Slice Units.
[ 6.295321] systemd[1]: Reached target Swaps.
[ 6.295639] systemd[1]: Reached target System Time Set.
[ 6.296162] systemd[1]: Reached target Local Verity Protected Volumes.
[ 6.297245] systemd[1]: Listening on Syslog Socket.
[ 6.298236] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.298936] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 6.300397] systemd[1]: Listening on Journal Audit Socket.
[ 6.301308] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.302450] systemd[1]: Listening on Journal Socket.
[ 6.314214] systemd[1]: Listening on udev Control Socket.
[ 6.315305] systemd[1]: Listening on udev Kernel Socket.
[ 6.319750] systemd[1]: Mounting Huge Pages File System...
[ 6.324879] systemd[1]: Mounting POSIX Message Queue File System...
[ 6.330662] systemd[1]: Mounting Kernel Debug File System...
[ 6.331975] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 6.339409] systemd[1]: Starting Restore / save the current clock...
[ 6.345147] systemd[1]: Starting Set the console keyboard layout...
[ 6.351732] systemd[1]: Starting Create List of Static Device Nodes...
[ 6.358465] systemd[1]: Starting Load Kernel Module configfs...
[ 6.365077] systemd[1]: Starting Load Kernel Module drm...
[ 6.371961] systemd[1]: Starting Load Kernel Module fuse...
[ 6.379481] systemd[1]: Started Nameserver information manager.
[ 6.380900] systemd[1]: Reached target Preparation for Network.
[ 6.382190] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 6.395121] systemd[1]: Starting Load Kernel Modules...
[ 6.401214] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.407382] systemd[1]: Starting Coldplug All udev Devices...
[ 6.419152] systemd[1]: Mounted Huge Pages File System.
[ 6.420837] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.422359] systemd[1]: Mounted Kernel Debug File System.
[ 6.425432] systemd[1]: Finished Restore / save the current clock.
[ 6.425773] fuse: init (API version 7.34)
[ 6.428513] systemd[1]: Finished Create List of Static Device Nodes.
[ 6.431938] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 6.433283] systemd[1]: Finished Load Kernel Module configfs.
[ 6.435491] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 6.436886] systemd[1]: Finished Load Kernel Module drm.
[ 6.439563] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 6.440948] systemd[1]: Finished Load Kernel Module fuse.
[ 6.447052] systemd[1]: Mounting FUSE Control File System...
[ 6.452353] systemd[1]: Mounting Kernel Configuration File System...
[ 6.459715] systemd[1]: Mounted FUSE Control File System.
[ 6.466857] systemd[1]: Mounted Kernel Configuration File System.
[ 6.475597] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
[ 6.481220] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 6.482545] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 6.487218] systemd[1]: Starting Load/Save Random Seed...
[ 6.493049] systemd[1]: Starting Create System Users...
[ 6.672733] WCN: marlin_init entry!
[ 6.673295] WCN: wcn config bt wake host
[ 6.673640] WCN_ERR: dts node for bt_wake not found
[ 6.673650] WCN: marlin2 parse_dt some para not config
[ 6.673674] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
[ 6.678896] sdiohal:sdiohal_init ok
[ 6.679750] systemd[1]: Finished Load/Save Random Seed.
[ 6.679837] WCN: marlin_probe ok!
[ 6.680959] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[ 6.701362] systemd[1]: Finished Create System Users.
[ 6.703749] mtty_probe init device addr: 0x00000000fe1f7fb4
[ 6.703958] -->rfkill_bluetooth_init
[ 6.704103] bluetooth_set_power: start_block=1
[ 6.704117] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0
[ 6.704127] bluetooth_set_power: end_block=1
[ 6.704144] <--rfkill_bluetooth_init
[ 6.708485] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 6.792500] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.794213] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.815600] [ADDR_MGT] addr_mgt_probe: module version: v1.0.9
[ 6.815713] [ADDR_MGT] addr_mgt_probe: success.
[ 6.820941] systemd[1]: Finished Set the console keyboard layout.
[ 6.882354] WCN: start_marlin [MARLIN_WIFI]
[ 6.882379] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
[ 6.882388] WCN: the first power on start
[ 6.885320] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 6.892712] systemd[1]: Reached target Preparation for Local File Systems.
[ 6.905003] systemd[1]: Mounting /tmp...
[ 6.919680] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 6.930260] systemd[1]: Mounted /tmp.
[ 6.937592] systemd[1]: Reached target Local File Systems.
[ 6.949729] systemd[1]: Starting Armbian leds state...
[ 6.962125] systemd[1]: Starting Armbian ZRAM config...
[ 6.974560] systemd[1]: Starting Set console font and keymap...
[ 6.986826] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[ 6.989569] WCN: marlin chip en dummy pull up -- need manually set GPIO
[ 7.012697] systemd[1]: Starting Set Up Additional Binary Formats...
[ 7.017639] sdiohal:sdiohal_scan_card
[ 7.017848] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=50000000
[ 7.017940] WCN: marlin_scan_finish!
[ 7.017944] sdiohal:probe ok
[ 7.018067] sdiohal:scan end!
[ 7.018073] WCN: then marlin start to download
[ 7.018305] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
[ 7.018318] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
[ 7.021202] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 7.021629] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 7.024765] systemd[1]: Finished Set console font and keymap.
[ 7.035619] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 366 (systemd-binfmt)
[ 7.043152] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 7.060577] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[ 7.072721] systemd[1]: Finished Coldplug All udev Devices.
[ 7.167303] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[ 7.177862] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 7.199741] systemd[1]: Finished Set Up Additional Binary Formats.
[ 7.228170] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[ 7.301685] systemd[1]: Finished Armbian leds state.
[ 7.582111] systemd[1]: Started Rule-based Manager for Device Events and Files.
[ 7.589917] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[ 7.590620] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active.
[ 7.601725] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[ 7.601909] systemd[1]: Reached target Local Encrypted Volumes.
[ 7.649290] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ 7.693825] systemd[1]: Starting Load/Save RF Kill Switch Status...
[ 7.870964] bluetooth_set_power: start_block=0
[ 7.870991] WCN: start_marlin [MARLIN_BLUETOOTH]
[ 8.041648] systemd[1]: Found device /dev/ttyS0.
[ 8.075381] WCN: combin_img 0 marlin_firmware_write finish and successful
[ 8.075778] WCN: marlin_start_run read reset reg val:0x1
[ 8.075797] WCN: after do marlin_start_run reset reg val:0x0
[ 8.076026] WCN: s_marlin_bootup_time=8076026176
[ 8.081928] WCN: clock mode: TSX
[ 8.082132] WCN: marlin_write_cali_data sync init_state:0x0
[ 8.109796] WCN: marlin_write_cali_data sync init_state:0x0
[ 8.137839] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
[ 8.137866] WCN: sdio_config bt_wake_host trigger:[high]
[ 8.137869] WCN: sdio_config irq:[inband]
[ 8.137871] WCN: sdio_config wake_host_level_duration_time:[20ms]
[ 8.137876] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
[ 8.137878] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config)
[ 8.138205] WCN: marlin_write_cali_data finish
[ 8.138370] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.157809] panfrost 1800000.gpu: clock rate = 432000000
[ 8.157843] panfrost 1800000.gpu: bus_clock rate = 100000000
[ 8.158153] panfrost 1800000.gpu: mali-t720 id 0x720 major 0x1 minor 0x1 status 0x0
[ 8.158164] panfrost 1800000.gpu: features: 00000000,10309e40, issues: 00000000,21054400
[ 8.158170] panfrost 1800000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002821 AS:0xf JS:0x7
[ 8.158178] panfrost 1800000.gpu: shader_present=0x3 l2_present=0x1
[ 8.159096] [drm] Initialized panfrost 1.2.0 20180908 for 1800000.gpu on minor 1
[ 8.165839] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.179510] mc: Linux media interface: v0.10
[ 8.193765] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.221809] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.249807] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
[ 8.249830] WCN: marlin_bind_verify confuse data: 0x70f591d68e01b18d315da6e670879a4a
[ 8.249845] WCN: marlin_bind_verify verify data: 0xa5709470f0031226394ebee725230b0c
[ 8.250344] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
[ 8.277783] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
[ 8.277802] sdiohal:sdiohal_runtime_get entry
[ 8.277980] WCN: get_cp2_version entry!
[ 8.299009] videodev: Linux video capture interface: v2.00
[ 8.317158] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
[ 8.317230] WCN: switch_cp2_log - close entry!
[ 8.318674] WCN: WCND at cmd read:OK
[ 8.318761] WCN: then marlin download finished and run ok
[ 8.318778] WCN: start_loopcheck
[ 8.318884] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1
[ 8.318895] WCN: marlin have open, GNSS is closed
[ 8.318899] bluetooth_set_power: end_block=0
[ 8.320107] systemd[1]: Started Load/Save RF Kill Switch Status.
[ 8.324478] zram: Added device: zram0
[ 8.325230] zram: Added device: zram1
[ 8.326075] zram: Added device: zram2
[ 8.354162] WCN: get_board_ant_num [one_ant]
[ 8.354186] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
[ 8.365170] Registered IR keymap rc-empty
[ 8.365298] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0
[ 8.366074] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
[ 8.366236] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input12
[ 8.378494] sunxi-ir 7040000.ir: initialized sunXi IR driver
[ 8.434915] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
[ 8.448849] systemd[1]: Finished Load Kernel Modules.
[ 8.458292] systemd[1]: Starting Apply Kernel Variables...
[ 8.514088] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.515483] cedrus 1c0e000.video-codec: Adding to iommu group 0
[ 8.518502] cedrus 1c0e000.video-codec: Device registered as /dev/video0
[ 8.567882] zram0: detected capacity change from 0 to 2037304
[ 8.631035] Adding 1018648k swap on /dev/zram0. Priority:5 extents:1 across:1018648k SSFS
[ 8.653605] systemd[1]: Finished Apply Kernel Variables.
[ 8.681160] systemd[1]: Starting Raise network interfaces...
[ 8.791511] logitech-djreceiver 0003:046D:C52B.0006: hiddev97,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2
[ 8.853254] zram1: detected capacity change from 0 to 102400
[ 8.977295] input: Logitech Wireless Device PID:4004 Keyboard as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input13
[ 9.045252] systemd[1]: Finished Armbian ZRAM config.
[ 9.054870] hid-generic 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4004] on usb-5101400.usb-1/input2:1
[ 9.055168] systemd[1]: Starting Armbian memory supported logging...
[ 9.169531] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none.
[ 9.215009] input: Logitech K360 as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input17
[ 9.215550] logitech-hidpp-device 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K360] on usb-5101400.usb-1/input2:1
[ 9.699754] systemd[1]: Finished Raise network interfaces.
[ 9.731709] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 9.732012] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[ 9.732412] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 9.738645] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[ 9.738778] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 9.738913] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 9.739051] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 9.894684] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 9.894922] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[ 9.894994] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[ 9.895091] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 9.895204] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 9.895323] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 11.563278] systemd[1]: Finished Armbian memory supported logging.
[ 11.572525] systemd[1]: Starting Journal Service...
[ 11.714105] systemd[1]: Started Journal Service.
[ 11.743225] systemd-journald[691]: Received client request to flush runtime journal.
BOARD=orangepi3-lts
VERSION=22.05.3
LINUXFAMILY=sunxi64
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm64
BRANCH=current
verbosity=1
bootlogo=false
console=both
rootfstype=ext4
### lsusb:
### lscpu:
CPU(s): 4
Vendor ID: ARM
Model: 4
Socket(s): -
Cluster(s): 1
Stepping: r0p4
BogoMIPS: 48.00
NUMA node(s): 1
### cpuinfo:
processor : 0
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
### meminfo:
MemFree: 1847312 kB
MemAvailable: 1852580 kB
Buffers: 12528 kB
Cached: 52716 kB
SwapCached: 0 kB
Active: 32252 kB
Inactive: 53072 kB
Active(anon): 440 kB
Inactive(anon): 22936 kB
Active(file): 31812 kB
Inactive(file): 30136 kB
Unevictable: 0 kB
Mlocked: 0 kB
Dirty: 2404 kB
Writeback: 0 kB
AnonPages: 20120 kB
Mapped: 16908 kB
Shmem: 3384 kB
KReclaimable: 10544 kB
Slab: 46252 kB
SReclaimable: 10544 kB
SUnreclaim: 35708 kB
KernelStack: 2480 kB
PageTables: 1508 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
Committed_AS: 42864 kB
VmallocUsed: 22732 kB
VmallocChunk: 0 kB
Percpu: 976 kB
AnonHugePages: 0 kB
FileHugePages: 0 kB
FilePmdMapped: 0 kB
CmaTotal: 131072 kB
CmaFree: 128768 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugetlb: 0 kB
### virtual memory:
vm.dirty_bytes = 0
vm.dirty_ratio = 20
vm.laptop_mode = 0
vm.nr_hugepages = 0
vm.numa_stat = 1
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.swappiness = 100
vm.user_reserve_kbytes = 63007
### ip addr:
### partitions:
252 0 1018652 zram0
252 1 51200 zram1
### df:
/dev/mmcblk0p1 29G 4.9G 24G 18% /
/dev/zram1 47M 2.4M 42M 6% /var/log
### lsblk:
mmcblk0 29.8G
└─mmcblk0p1 ext4 29.4G / 71b44a6c-5bb8-4352-afe7-d22b8e62de4c
zram1 50M /var/log
zram2 0B
### zramctl:
/dev/zram1 zstd 50M 68K 721B 44K 4 /var/log
### mtab:
### mmc0:0001 info:
fwrev: 0x0
rca: 0x0001
manfid: 0x00001d
ocr: 0x00200000
type: SD
hwrev: 0x1
date: 01/2022
dsr: 0x404
erase_size: 512
oemid: 0x4144
serial: 0x00005ae0
### mmc2:0001 info:
rel_sectors: 0x1
rca: 0x0001
pre_eol_info: 0x01
manfid: 0x000015
ocr: 0x00200000
type: MMC
hwrev: 0x0
date: 12/2021
prv: 0x6
ffu_capable: 1
dsr: 0x404
erase_size: 524288
oemid: 0x0100
serial: 0xd410e21f
cmdq_en: 0
rev: 0x8
11:40:44: 1320MHz 0.23 46% 19% 13% 0% 12% 0% 63.6°C 0/9
11:40:44: 888MHz 0.23 12% 8% 2% 1% 0% 0% 63.6°C 0/9
11:40:44: 1080MHz 0.23 12% 9% 2% 0% 0% 0% 58.2°C 0/9
11:40:45: 1800MHz 0.23 12% 6% 4% 1% 0% 0% 58.3°C 0/9
11:40:45: 1800MHz 0.23 14% 9% 2% 1% 0% 0% 59.3°C 0/9
### Activated 1 lzo-rle zram swap devices with 994MB each.
### Activated Armbian ramlog partition with zstd compression
Thu Jun 23 11:48:16 AM CST 2022 | Orange Pi 3 LTS | 22.05.3 | arm64 | aarch64 | 5.15.48-sunxi64
### dmesg:
[ 1.272120] ohci-platform: OHCI generic platform driver
[ 1.272614] usbcore: registered new interface driver usb-storage
[ 1.273128] mousedev: PS/2 mouse device common for all mice
[ 1.274160] sun6i-rtc 7000000.rtc: registered as rtc0
[ 1.274198] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-01T00:07:55 UTC (475)
[ 1.274306] sun6i-rtc 7000000.rtc: RTC enabled
[ 1.274449] i2c_dev: i2c /dev entries driver
[ 1.275241] sunxi-wdt 7020400.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.276799] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pm not found, using dummy regulator
[ 1.277224] sdhci: Secure Digital Host Controller Interface driver
[ 1.277234] sdhci: Copyright(c) Pierre Ossman
[ 1.277258] Synopsys Designware Multimedia Card Interface Driver
[ 1.278091] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.278268] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
[ 1.279331] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.279930] sun8i-ce 1904000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
[ 1.280188] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.280330] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.280432] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.280526] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.280606] sun8i-ce 1904000.crypto: Register cbc(aes)
[ 1.280754] sun8i-ce 1904000.crypto: Register ecb(aes)
[ 1.280864] sun8i-ce 1904000.crypto: Register cbc(des3_ede)
[ 1.280972] sun8i-ce 1904000.crypto: Register ecb(des3_ede)
[ 1.281079] sun8i-ce 1904000.crypto: Register md5
[ 1.281186] sun8i-ce 1904000.crypto: Register sha1
[ 1.281293] sun8i-ce 1904000.crypto: Register sha224
[ 1.281401] sun8i-ce 1904000.crypto: Register sha256
[ 1.281507] sun8i-ce 1904000.crypto: Register sha384
[ 1.281665] sun8i-ce 1904000.crypto: Register sha512
[ 1.281777] sun8i-ce 1904000.crypto: Register stdrng
[ 1.282517] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0
[ 1.283115] hid: raw HID events driver (C) Jiri Kosina
[ 1.283240] usbcore: registered new interface driver usbhid
[ 1.283247] usbhid: USB HID core driver
[ 1.284060] random: crng init done
[ 1.286213] NET: Registered PF_INET6 protocol family
[ 1.870216] Freeing initrd memory: 12684K
[ 1.898965] Segment Routing with IPv6
[ 1.899073] In-situ OAM (IOAM) with IPv6
[ 1.899164] NET: Registered PF_PACKET protocol family
[ 1.899302] 8021q: 802.1Q VLAN Support v1.8
[ 1.899459] 9pnet: Installing 9P2000 support
[ 1.899532] Key type dns_resolver registered
[ 1.899974] registered taskstats version 1
[ 1.899990] Loading compiled-in X.509 certificates
[ 1.903826] Loaded X.509 cert 'Build time autogenerated kernel key: 32330adefd2da02e444296fafd37464380789679'
[ 1.906701] zswap: loaded using pool zstd/z3fold
[ 1.907326] Key type ._fscrypt registered
[ 1.907334] Key type .fscrypt registered
[ 1.907338] Key type fscrypt-provisioning registered
[ 1.908346] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
[ 1.922075] Key type encrypted registered
[ 1.922109] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.922149] ima: No TPM chip found, activating TPM-bypass!
[ 1.922177] ima: Allocated hash algorithm: sha1
[ 1.922209] ima: No architecture policies found
[ 1.922282] evm: Initialising EVM extended attributes:
[ 1.922286] evm: security.selinux
[ 1.922291] evm: security.SMACK64
[ 1.922296] evm: security.SMACK64EXEC
[ 1.922300] evm: security.SMACK64TRANSMUTE
[ 1.922304] evm: security.SMACK64MMAP
[ 1.922308] evm: security.apparmor
[ 1.922312] evm: security.ima
[ 1.922316] evm: security.capability
[ 1.922320] evm: HMAC attrs: 0x1
[ 1.935478] platform 1100000.mixer: Fixing up cyclic dependency with 6510000.tcon-top
[ 1.935838] sun8i-mixer 1100000.mixer: Adding to iommu group 0
[ 1.937884] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 1.937915] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 1.938068] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f064 hci version 0x100 quirks 0x0000000002010010
[ 1.938129] xhci-hcd xhci-hcd.1.auto: irq 43, io mem 0x05200000
[ 1.938581] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.938597] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.938607] usb usb1: Product: xHCI Host Controller
[ 1.938615] usb usb1: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd
[ 1.938624] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 1.939157] hub 1-0:1.0: USB hub found
[ 1.939202] hub 1-0:1.0: 1 port detected
[ 1.939537] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 1.939557] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 1.939576] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 1.939668] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.939826] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.939839] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.939849] usb usb2: Product: xHCI Host Controller
[ 1.939857] usb usb2: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd
[ 1.939866] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 1.940303] hub 2-0:1.0: USB hub found
[ 1.940340] hub 2-0:1.0: 1 port detected
[ 1.942990] sun50i_cpufreq_nvmem: Using CPU speed bin speed0
[ 1.944802] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
[ 1.951206] of_cfs_init
[ 1.951337] of_cfs_init: OK
[ 1.951677] ALSA device list:
[ 1.951684] No soundcards found.
[ 1.952785] Freeing unused kernel memory: 2496K
[ 1.973623] Run /init as init process
[ 1.973631] with arguments:
[ 1.973637] /init
[ 1.973643] with environment:
[ 1.973647] HOME=/
[ 1.973652] TERM=linux
[ 1.973657] ubootpart=ce3dfe46-01
[ 1.973662] cgroup_enable=memory
[ 2.193601] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[ 2.346592] usb 1-1: New USB device found, idVendor=045e, idProduct=0745, bcdDevice= 6.33
[ 2.346627] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.346638] usb 1-1: Product: Microsoft® 2.4GHz Transceiver v7.0
[ 2.346646] usb 1-1: Manufacturer: Microsoft
[ 2.367970] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.0/0003:045E:0745.0001/input/input0
[ 2.416093] axp20x-i2c 0-0036: AXP20x variant AXP806 found
[ 2.429907] hid-generic 0003:045E:0745.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input0
[ 2.437381] input: axp20x-pek as /devices/platform/soc/7081400.i2c/i2c-0/0-0036/axp221-pek/input/input1
[ 2.446665] vdd-cpu: supplied by vcc-5v
[ 2.449719] vdd-gpu: supplied by vcc-5v
[ 2.450579] vdd-sys: supplied by vcc-5v
[ 2.451449] vcc-dram: supplied by vcc-5v
[ 2.453703] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Mouse as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input2
[ 2.454269] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input3
[ 2.456626] vcc-pl-led-ir: supplied by vcc-5v
[ 2.457495] vcc33-audio-tv-ephy-mac: supplied by vcc-5v
[ 2.513978] hid-generic 0003:045E:0745.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input1
[ 2.527597] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input4
[ 2.566336] vcc33-io-pd-emmc-sd-usb-uart-1: supplied by vcc-5v
[ 2.567031] vcc18-dram-bias-pll: supplied by vcc-5v
[ 2.568106] vcc-efuse-pcie-hdmi-pc: supplied by vcc-5v
[ 2.568777] vcc-wifi-io-pm-pg: supplied by vcc-5v
[ 2.569573] bldo4: supplied by vcc-5v
[ 2.570101] vcc33-io-pd-emmc-sd-usb-uart-2: supplied by vcc-5v
[ 2.570919] cldo2: supplied by vcc-5v
[ 2.571561] cldo3: supplied by vcc-5v
[ 2.571822] sw: supplied by regulator-dummy
[ 2.572376] axp20x-i2c 0-0036: AXP20X driver loaded
[ 2.578873] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[ 2.579353] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pb not found, using dummy regulator
[ 2.580357] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator
[ 2.581186] printk: console [ttyS0] disabled
[ 2.581302] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 35, base_baud = 1500000) is a 16550A
[ 2.581573] printk: console [ttyS0] enabled
[ 2.582872] sun4i-drm display-engine: Adding to iommu group 0
[ 2.587091] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 System Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input6
[ 2.588237] hid-generic 0003:045E:0745.0003: input,hiddev96,hidraw2: USB HID v1.11 Device [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input2
[ 2.602484] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e16990)
[ 2.602783] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800008e1abb8)
[ 2.603132] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff800008e11ba0)
[ 2.603237] sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator
[ 2.607552] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.610193] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin
[ 2.611789] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.612790] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff800008e15cc8)
[ 2.614453] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 2.614521] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 1
[ 2.770264] Console: switching to colour frame buffer device 240x67
[ 2.820085] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device
[ 2.841915] acx00-codec acx00-codec: DMA mask not set
[ 2.844695] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[ 2.846014] sunxi-mmc 4020000.mmc: Got CD GPIO
[ 2.846566] vcc-wifi-io: supplied by vcc33-wifi
[ 2.848944] ehci-platform 5101000.usb: EHCI Host Controller
[ 2.849108] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 3
[ 2.849277] ehci-platform 5101000.usb: irq 41, io mem 0x05101000
[ 2.861619] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00
[ 2.861961] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.861976] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.861987] usb usb3: Product: EHCI Host Controller
[ 2.861995] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
[ 2.862004] usb usb3: SerialNumber: 5101000.usb
[ 2.862573] hub 3-0:1.0: USB hub found
[ 2.862616] hub 3-0:1.0: 1 port detected
[ 2.863716] ehci-platform 5311000.usb: EHCI Host Controller
[ 2.863754] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 4
[ 2.863897] ehci-platform 5311000.usb: irq 44, io mem 0x05311000
[ 2.869591] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[ 2.869910] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[ 2.877571] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00
[ 2.877916] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.877932] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.877943] usb usb4: Product: EHCI Host Controller
[ 2.877951] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
[ 2.877960] usb usb4: SerialNumber: 5311000.usb
[ 2.878516] hub 4-0:1.0: USB hub found
[ 2.878560] hub 4-0:1.0: 1 port detected
[ 2.879652] ohci-platform 5101400.usb: Generic Platform OHCI controller
[ 2.879690] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 5
[ 2.879830] ohci-platform 5101400.usb: irq 42, io mem 0x05101400
[ 2.904492] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.906262] mmc0: Problem switching card into high-speed mode!
[ 2.906374] mmc0: new SDHC card at address 0001
[ 2.907229] mmcblk0: mmc0:0001 USD 29.8 GiB
[ 2.909255] mmcblk0: p1
[ 2.941827] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 2.941852] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.941862] usb usb5: Product: Generic Platform OHCI controller
[ 2.941871] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
[ 2.941879] usb usb5: SerialNumber: 5101400.usb
[ 2.942627] hub 5-0:1.0: USB hub found
[ 2.942693] hub 5-0:1.0: 1 port detected
[ 2.943898] ohci-platform 5311400.usb: Generic Platform OHCI controller
[ 2.943950] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 6
[ 2.944086] ohci-platform 5311400.usb: irq 45, io mem 0x05311400
[ 2.997703] mmc2: new HS200 MMC card at address 0001
[ 2.998755] mmcblk2: mmc2:0001 8GTF4R 7.28 GiB
[ 3.001037] mmcblk2boot0: mmc2:0001 8GTF4R 4.00 MiB
[ 3.002672] mmcblk2boot1: mmc2:0001 8GTF4R 4.00 MiB
[ 3.005930] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 3.005972] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.005984] usb usb6: Product: Generic Platform OHCI controller
[ 3.005992] usb usb6: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
[ 3.006001] usb usb6: SerialNumber: 5311400.usb
[ 3.006674] hub 6-0:1.0: USB hub found
[ 3.006731] hub 6-0:1.0: 1 port detected
[ 3.008066] usb_phy_generic usb_phy_generic.4.auto: supply vcc not found, using dummy regulator
[ 3.008361] usb_phy_generic usb_phy_generic.4.auto: dummy supplies not allowed for exclusive requests
[ 3.113914] musb-hdrc musb-hdrc.5.auto: MUSB HDRC host driver
[ 3.113960] musb-hdrc musb-hdrc.5.auto: new USB bus registered, assigned bus number 7
[ 3.114250] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 3.114265] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.114276] usb usb7: Product: MUSB HDRC host driver
[ 3.114284] usb usb7: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd
[ 3.114293] usb usb7: SerialNumber: musb-hdrc.5.auto
[ 3.114896] hub 7-0:1.0: USB hub found
[ 3.114955] hub 7-0:1.0: 1 port detected
[ 3.135122] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found
[ 3.135149] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found
[ 3.135453] dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator
[ 3.135754] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[ 3.135801] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 50000)
[ 3.241842] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
[ 3.241868] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
[ 3.241876] dwmac-sun8i 5020000.ethernet: COE Type 2
[ 3.241886] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
[ 3.241894] dwmac-sun8i 5020000.ethernet: Normal descriptors
[ 3.241901] dwmac-sun8i 5020000.ethernet: Chain mode enabled
[ 3.460812] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none.
[ 3.685578] usb 5-1: new full-speed USB device number 2 using ohci-platform
[ 3.922615] usb 5-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.10
[ 3.922646] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.922656] usb 5-1: Product: USB Receiver
[ 3.922665] usb 5-1: Manufacturer: Logitech
[ 3.931703] input: Logitech USB Receiver as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.0/0003:046D:C52B.0004/input/input7
[ 3.990240] hid-generic 0003:046D:C52B.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-5101400.usb-1/input0
[ 3.996409] input: Logitech USB Receiver Mouse as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input8
[ 3.996878] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input9
[ 4.053923] input: Logitech USB Receiver System Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input10
[ 4.054273] hid-generic 0003:046D:C52B.0005: input,hiddev97,hidraw4: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-5101400.usb-1/input1
[ 4.058954] hid-generic 0003:046D:C52B.0006: hiddev98,hidraw5: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2
[ 4.755008] systemd[1]: System time before build time, advancing clock.
[ 4.843289] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq
[ 4.852360] systemd[1]: systemd 249.11-0ubuntu3.1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS -OPENSSL +ACL +BLKID +CURL +ELFUTILS -FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP -LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 4.853031] systemd[1]: Detected architecture arm64.
[ 4.856401] systemd[1]: Hostname set to <orangepi3-lts>.
[ 5.073589] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[ 5.093717] mmc1: new high speed SDIO card at address 8800
[ 6.193792] systemd[1]: Queued start job for default target Graphical Interface.
[ 6.199673] systemd[1]: Created slice Slice /system/modprobe.
[ 6.202438] systemd[1]: Created slice Slice /system/serial-getty.
[ 6.204317] systemd[1]: Created slice User and Session Slice.
[ 6.205203] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.206686] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.207616] systemd[1]: Reached target Remote File Systems.
[ 6.207972] systemd[1]: Reached target Slice Units.
[ 6.208316] systemd[1]: Reached target Swaps.
[ 6.208615] systemd[1]: Reached target System Time Set.
[ 6.209148] systemd[1]: Reached target Local Verity Protected Volumes.
[ 6.210233] systemd[1]: Listening on Syslog Socket.
[ 6.211099] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.211773] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 6.213196] systemd[1]: Listening on Journal Audit Socket.
[ 6.214166] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.215189] systemd[1]: Listening on Journal Socket.
[ 6.226972] systemd[1]: Listening on udev Control Socket.
[ 6.228070] systemd[1]: Listening on udev Kernel Socket.
[ 6.232463] systemd[1]: Mounting Huge Pages File System...
[ 6.237480] systemd[1]: Mounting POSIX Message Queue File System...
[ 6.243196] systemd[1]: Mounting Kernel Debug File System...
[ 6.244530] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 6.251806] systemd[1]: Starting Restore / save the current clock...
[ 6.257507] systemd[1]: Starting Set the console keyboard layout...
[ 6.264010] systemd[1]: Starting Create List of Static Device Nodes...
[ 6.270697] systemd[1]: Starting Load Kernel Module configfs...
[ 6.277248] systemd[1]: Starting Load Kernel Module drm...
[ 6.284225] systemd[1]: Starting Load Kernel Module fuse...
[ 6.290950] systemd[1]: Started Nameserver information manager.
[ 6.293372] systemd[1]: Reached target Preparation for Network.
[ 6.294676] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 6.305486] systemd[1]: Starting Load Kernel Modules...
[ 6.311575] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.318055] systemd[1]: Starting Coldplug All udev Devices...
[ 6.329070] systemd[1]: Mounted Huge Pages File System.
[ 6.330531] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.331866] systemd[1]: Mounted Kernel Debug File System.
[ 6.334637] systemd[1]: Finished Restore / save the current clock.
[ 6.337208] fuse: init (API version 7.34)
[ 6.338287] systemd[1]: Finished Create List of Static Device Nodes.
[ 6.340802] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 6.342196] systemd[1]: Finished Load Kernel Module configfs.
[ 6.344794] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 6.346196] systemd[1]: Finished Load Kernel Module drm.
[ 6.348702] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 6.350366] systemd[1]: Finished Load Kernel Module fuse.
[ 6.358420] systemd[1]: Mounting FUSE Control File System...
[ 6.363565] systemd[1]: Mounting Kernel Configuration File System...
[ 6.370549] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
[ 6.378619] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 6.380232] systemd[1]: Mounted FUSE Control File System.
[ 6.381348] systemd[1]: Mounted Kernel Configuration File System.
[ 6.382326] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 6.387071] systemd[1]: Starting Load/Save Random Seed...
[ 6.392540] systemd[1]: Starting Create System Users...
[ 6.586419] WCN: marlin_init entry!
[ 6.586991] WCN: wcn config bt wake host
[ 6.587221] WCN_ERR: dts node for bt_wake not found
[ 6.587225] WCN: marlin2 parse_dt some para not config
[ 6.587238] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
[ 6.592123] sdiohal:sdiohal_init ok
[ 6.592878] WCN: marlin_probe ok!
[ 6.620583] mtty_probe init device addr: 0x00000000e28a0d2b
[ 6.620797] -->rfkill_bluetooth_init
[ 6.620939] bluetooth_set_power: start_block=1
[ 6.620953] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0
[ 6.620964] bluetooth_set_power: end_block=1
[ 6.620984] <--rfkill_bluetooth_init
[ 6.623689] systemd[1]: Finished Load/Save Random Seed.
[ 6.626442] systemd[1]: Finished Create System Users.
[ 6.627758] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[ 6.634972] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 6.763812] systemd[1]: Finished Set the console keyboard layout.
[ 6.786911] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.788524] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.809385] [ADDR_MGT] addr_mgt_probe: module version: v1.0.9
[ 6.809498] [ADDR_MGT] addr_mgt_probe: success.
[ 6.875323] WCN: start_marlin [MARLIN_WIFI]
[ 6.875350] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
[ 6.875357] WCN: the first power on start
[ 6.882798] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 6.890198] systemd[1]: Reached target Preparation for Local File Systems.
[ 6.902433] systemd[1]: Mounting /tmp...
[ 6.917110] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 6.928017] systemd[1]: Mounted /tmp.
[ 6.935371] systemd[1]: Reached target Local File Systems.
[ 6.947700] systemd[1]: Starting Armbian leds state...
[ 6.960150] systemd[1]: Starting Armbian ZRAM config...
[ 6.973058] systemd[1]: Starting Set console font and keymap...
[ 6.981654] WCN: marlin chip en dummy pull up -- need manually set GPIO
[ 6.985303] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[ 7.009278] systemd[1]: Starting Set Up Additional Binary Formats...
[ 7.009633] sdiohal:sdiohal_scan_card
[ 7.009865] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=50000000
[ 7.009980] WCN: marlin_scan_finish!
[ 7.009984] sdiohal:probe ok
[ 7.010121] sdiohal:scan end!
[ 7.010127] WCN: then marlin start to download
[ 7.010352] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
[ 7.010365] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
[ 7.016147] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 7.016455] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 7.019509] systemd[1]: Finished Coldplug All udev Devices.
[ 7.028350] systemd[1]: Finished Set console font and keymap.
[ 7.059177] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[ 7.068115] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[ 7.075631] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 363 (systemd-binfmt)
[ 7.080419] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 7.176429] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 7.195698] systemd[1]: Finished Set Up Additional Binary Formats.
[ 7.204781] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[ 7.302466] systemd[1]: Finished Armbian leds state.
[ 7.578280] systemd[1]: Started Rule-based Manager for Device Events and Files.
[ 7.586089] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[ 7.586742] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active.
[ 7.594078] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[ 7.594232] systemd[1]: Reached target Local Encrypted Volumes.
[ 7.650629] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ 7.690721] systemd[1]: Starting Load/Save RF Kill Switch Status...
[ 7.861430] bluetooth_set_power: start_block=0
[ 7.861457] WCN: start_marlin [MARLIN_BLUETOOTH]
[ 8.022021] WCN: combin_img 0 marlin_firmware_write finish and successful
[ 8.022313] WCN: marlin_start_run read reset reg val:0x1
[ 8.022320] WCN: after do marlin_start_run reset reg val:0x0
[ 8.022497] WCN: s_marlin_bootup_time=8022497218
[ 8.027371] mc: Linux media interface: v0.10
[ 8.029116] WCN: clock mode: TSX
[ 8.029325] WCN: marlin_write_cali_data sync init_state:0x0
[ 8.042428] panfrost 1800000.gpu: clock rate = 432000000
[ 8.042461] panfrost 1800000.gpu: bus_clock rate = 100000000
[ 8.048008] panfrost 1800000.gpu: mali-t720 id 0x720 major 0x1 minor 0x1 status 0x0
[ 8.048034] panfrost 1800000.gpu: features: 00000000,10309e40, issues: 00000000,21054400
[ 8.048042] panfrost 1800000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002821 AS:0xf JS:0x7
[ 8.048050] panfrost 1800000.gpu: shader_present=0x3 l2_present=0x1
[ 8.053842] WCN: marlin_write_cali_data sync init_state:0x0
[ 8.078362] videodev: Linux video capture interface: v2.00
[ 8.079820] systemd[1]: Found device /dev/ttyS0.
[ 8.081868] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
[ 8.081894] WCN: sdio_config bt_wake_host trigger:[high]
[ 8.081897] WCN: sdio_config irq:[inband]
[ 8.081899] WCN: sdio_config wake_host_level_duration_time:[20ms]
[ 8.081903] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
[ 8.081906] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config)
[ 8.082330] WCN: marlin_write_cali_data finish
[ 8.082591] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.083099] [drm] Initialized panfrost 1.2.0 20180908 for 1800000.gpu on minor 1
[ 8.109908] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.130243] zram: Added device: zram0
[ 8.137813] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.165793] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.181921] zram: Added device: zram1
[ 8.193819] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
[ 8.193843] WCN: marlin_bind_verify confuse data: 0x2e197f4f5a1107df30c640a9405a3d69
[ 8.193860] WCN: marlin_bind_verify verify data: 0x016d6ab91e1d071b3ae4604f224021aa
[ 8.194409] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
[ 8.198061] zram: Added device: zram2
[ 8.227589] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
[ 8.227616] sdiohal:sdiohal_runtime_get entry
[ 8.233394] WCN: get_cp2_version entry!
[ 8.280833] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
[ 8.280868] WCN: switch_cp2_log - close entry!
[ 8.282187] WCN: WCND at cmd read:OK
[ 8.282244] WCN: then marlin download finished and run ok
[ 8.282258] WCN: start_loopcheck
[ 8.282550] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1
[ 8.282561] WCN: marlin have open, GNSS is closed
[ 8.282565] bluetooth_set_power: end_block=0
[ 8.288920] systemd[1]: Started Load/Save RF Kill Switch Status.
[ 8.306629] WCN: get_board_ant_num [one_ant]
[ 8.306654] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
[ 8.380720] Registered IR keymap rc-empty
[ 8.380846] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0
[ 8.381036] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
[ 8.381128] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input12
[ 8.381466] sunxi-ir 7040000.ir: initialized sunXi IR driver
[ 8.387814] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
[ 8.392387] systemd[1]: Finished Load Kernel Modules.
[ 8.402147] systemd[1]: Starting Apply Kernel Variables...
[ 8.499610] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.500798] cedrus 1c0e000.video-codec: Adding to iommu group 0
[ 8.501857] cedrus 1c0e000.video-codec: Device registered as /dev/video0
[ 8.621340] zram0: detected capacity change from 0 to 2037304
[ 8.651781] Adding 1018648k swap on /dev/zram0. Priority:5 extents:1 across:1018648k SSFS
[ 8.687059] systemd[1]: Finished Apply Kernel Variables.
[ 8.716975] systemd[1]: Starting Raise network interfaces...
[ 8.871439] zram1: detected capacity change from 0 to 102400
[ 8.949631] logitech-djreceiver 0003:046D:C52B.0006: hiddev97,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2
[ 9.026075] systemd[1]: Finished Armbian ZRAM config.
[ 9.036822] systemd[1]: Starting Armbian memory supported logging...
[ 9.110343] input: Logitech Wireless Device PID:4004 Keyboard as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input13
[ 9.157338] hid-generic 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4004] on usb-5101400.usb-1/input2:1
[ 9.171004] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none.
[ 9.327377] input: Logitech K360 as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input17
[ 9.328295] logitech-hidpp-device 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K360] on usb-5101400.usb-1/input2:1
[ 9.690644] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 9.691310] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[ 9.692362] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 9.697275] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[ 9.697501] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 9.697835] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 9.697994] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 9.755895] systemd[1]: Finished Raise network interfaces.
[ 9.998313] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 9.998546] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[ 9.998617] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[ 9.998708] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 9.998815] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 9.998931] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 11.573639] systemd[1]: Finished Armbian memory supported logging.
[ 11.584810] systemd[1]: Starting Journal Service...
[ 11.722369] systemd[1]: Started Journal Service.
[ 11.750846] systemd-journald[690]: Received client request to flush runtime journal.
### armbian-release:
# PLEASE DO NOT EDIT THIS FILE
BOARD=orangepi3-lts
BOARD_NAME="Orange Pi 3 LTS"
BOARDFAMILY=sun50iw6
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=13f5fba13c
VERSION=22.05.3
LINUXFAMILY=sunxi64
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm64
KERNEL_IMAGE_TYPE=stable
BRANCH=current
### boot environment:
verbosity=1
bootlogo=false
console=both
disp_mode=1920x1080p60
overlay_prefix=sun50i-h6
rootdev=UUID=71b44a6c-5bb8-4352-afe7-d22b8e62de4c
rootfstype=ext4
### lsusb:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 005 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
### lscpu:
Architecture: aarch64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Vendor ID: ARM
Model name: Cortex-A53
Model: 4
Thread(s) per core: 1
Core(s) per cluster: 4
Socket(s): -
Cluster(s): 1
Stepping: r0p4
CPU max MHz: 1800.0000
CPU min MHz: 480.0000
BogoMIPS: 48.00
Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
NUMA node(s): 1
NUMA node0 CPU(s): 0-3
Vulnerability Itlb multihit: Not affected
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Mmio stale data: Not affected
Vulnerability Spec store bypass: Not affected
Vulnerability Spectre v1: Mitigation; __user pointer sanitization
Vulnerability Spectre v2: Not affected
Vulnerability Srbds: Not affected
Vulnerability Tsx async abort: Not affected
### cpuinfo:
processor : 0
BogoMIPS : 48.00
Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
CPU implementer : 0x41
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
### meminfo:
MemTotal: 2037300 kB
MemFree: 1845772 kB
MemAvailable: 1851244 kB
Buffers: 12532 kB
Cached: 52908 kB
SwapCached: 0 kB
Active: 32344 kB
Inactive: 52708 kB
Active(anon): 428 kB
Inactive(anon): 22452 kB
Active(file): 31916 kB
Inactive(file): 30256 kB
Unevictable: 0 kB
Mlocked: 0 kB
SwapTotal: 1018648 kB
SwapFree: 1018648 kB
Dirty: 2836 kB
Writeback: 0 kB
AnonPages: 19400 kB
Mapped: 16772 kB
Shmem: 3376 kB
KReclaimable: 10500 kB
Slab: 45964 kB
SReclaimable: 10500 kB
SUnreclaim: 35464 kB
KernelStack: 2448 kB
PageTables: 1528 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 2037296 kB
Committed_AS: 42340 kB
VmallocTotal: 133143592960 kB
VmallocUsed: 22684 kB
VmallocChunk: 0 kB
Percpu: 976 kB
AnonHugePages: 0 kB
ShmemHugePages: 0 kB
ShmemPmdMapped: 0 kB
FileHugePages: 0 kB
FilePmdMapped: 0 kB
CmaTotal: 131072 kB
CmaFree: 128768 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
Hugetlb: 0 kB
### virtual memory:
vm.admin_reserve_kbytes = 8192
vm.compaction_proactiveness = 20
vm.compact_unevictable_allowed = 1
vm.dirty_background_bytes = 0
vm.dirty_background_ratio = 10
vm.dirty_bytes = 0
vm.dirty_expire_centisecs = 3000
vm.dirty_ratio = 20
vm.dirtytime_expire_seconds = 43200
vm.dirty_writeback_centisecs = 500
vm.extfrag_threshold = 500
vm.hugetlb_shm_group = 0
vm.laptop_mode = 0
vm.legacy_va_layout = 0
vm.lowmem_reserve_ratio = 256 256 32 0
vm.max_map_count = 65530
vm.min_free_kbytes = 22528
vm.min_slab_ratio = 5
vm.min_unmapped_ratio = 1
vm.mmap_min_addr = 32768
vm.mmap_rnd_bits = 18
vm.mmap_rnd_compat_bits = 11
vm.nr_hugepages = 0
vm.nr_hugepages_mempolicy = 0
vm.nr_overcommit_hugepages = 0
vm.numa_stat = 1
vm.numa_zonelist_order = Node
vm.oom_dump_tasks = 1
vm.oom_kill_allocating_task = 0
vm.overcommit_kbytes = 0
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.page-cluster = 0
vm.page_lock_unfairness = 5
vm.panic_on_oom = 0
vm.percpu_pagelist_high_fraction = 0
vm.stat_interval = 1
vm.swappiness = 100
vm.user_reserve_kbytes = 63011
vm.vfs_cache_pressure = 100
vm.watermark_boost_factor = 15000
vm.watermark_scale_factor = 10
vm.zone_reclaim_mode = 0
### ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 02:07:29:30:86:8c brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 00:32:c3:9f:6a:08 brd ff:ff:ff:ff:ff:ff
### partitions:
major minor #blocks name
179 0 31205376 mmcblk0
179 1 30879744 mmcblk0p1
179 32 7634944 mmcblk2
252 0 1018652 zram0
252 1 51200 zram1
### df:
tmpfs 199M 3.4M 196M 2% /run
tmpfs 995M 0 995M 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 995M 0 995M 0% /tmp
/dev/zram1 47M 2.8M 41M 7% /var/log
### lsblk:
NAME FSTYPE SIZE MOUNTPOINT UUID
mmcblk0 29.8G
mmcblk2 swap 7.3G 6a6f4ef8-bcc6-4021-a70f-de04ada07a25
mmcblk2boot0 swap 4M 6a6f4ef8-bcc6-4021-a70f-de04ada07a25
mmcblk2boot1 swap 4M 6a6f4ef8-bcc6-4021-a70f-de04ada07a25
zram1 50M /var/log
zram2 0B
### zramctl:
NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram1 zstd 50M 68K 728B 44K 4 /var/log
/dev/zram0 lzo-rle 994.8M 4K 74B 12K 4 [SWAP]
### mtab:
/dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
### mmc0:0001 info:
fwrev: 0x0
uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=USD MODALIAS=mmc:block
cid: 1d414455534400001000005ae0016181
rca: 0x0001
csd: 400e00325b590000ee137f800a40004d
manfid: 0x00001d
ocr: 0x00200000
preferred_erase_size: 4194304
type: SD
hwrev: 0x1
date: 01/2022
dsr: 0x404
erase_size: 512
oemid: 0x4144
serial: 0x00005ae0
ssr: 000000000500000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
scr: 02b5808200000000
### mmc2:0001 info:
fwrev: 0x0600000000000000
uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=8GTF4R MODALIAS=mmc:block
cid: 15010038475446345206d410e21fc801
rel_sectors: 0x1
enhanced_rpmb_supported: 0x1
rca: 0x0001
pre_eol_info: 0x01
csd: d02701320f5903fff6dbffef8e40400d
manfid: 0x000015
ocr: 0x00200000
enhanced_area_offset: 18446744073709551594
raw_rpmb_size_mult: 0x4
type: MMC
hwrev: 0x0
date: 12/2021
prv: 0x6
ffu_capable: 1
dsr: 0x404
erase_size: 524288
life_time: 0x01 0x01
enhanced_area_size: 4294967274
oemid: 0x0100
serial: 0xd410e21f
cmdq_en: 0
rev: 0x8
### Boot system health:
Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St.
11:48:18: 1608MHz 1.34 46% 19% 13% 0% 12% 0% 65.9°C 0/9
11:48:18: 1080MHz 1.34 11% 6% 4% 1% 0% 0% 65.9°C 0/9
11:48:18: 816MHz 1.34 12% 7% 3% 1% 0% 0% 61.8°C 0/9
11:48:19: 888MHz 1.34 13% 9% 2% 1% 0% 0% 60.3°C 0/9
11:48:19: 1800MHz 1.34 12% 10% 2% 0% 0% 0% 62.2°C 0/9
Tue Jun 28 07:44:49 AM CST 2022 | Orange Pi 3 LTS | 22.05.3 | arm64 | aarch64 | 5.15.48-sunxi64
### dmesg:
[ 1.271004] i2c_dev: i2c /dev entries driver
[ 1.271798] sunxi-wdt 7020400.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.273360] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pm not found, using dummy regulator
[ 1.273780] sdhci: Secure Digital Host Controller Interface driver
[ 1.273788] sdhci: Copyright(c) Pierre Ossman
[ 1.273812] Synopsys Designware Multimedia Card Interface Driver
[ 1.274605] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.274770] sun50i-h6-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
[ 1.276126] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.276686] sun8i-ce 1904000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
[ 1.276980] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.277121] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.277218] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.277342] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 1.277430] sun8i-ce 1904000.crypto: Register cbc(aes)
[ 1.277588] sun8i-ce 1904000.crypto: Register ecb(aes)
[ 1.277706] sun8i-ce 1904000.crypto: Register cbc(des3_ede)
[ 1.277822] sun8i-ce 1904000.crypto: Register ecb(des3_ede)
[ 1.277932] sun8i-ce 1904000.crypto: Register md5
[ 1.278040] sun8i-ce 1904000.crypto: Register sha1
[ 1.278147] sun8i-ce 1904000.crypto: Register sha224
[ 1.278256] sun8i-ce 1904000.crypto: Register sha256
[ 1.278363] sun8i-ce 1904000.crypto: Register sha384
[ 1.278481] sun8i-ce 1904000.crypto: Register sha512
[ 1.278588] sun8i-ce 1904000.crypto: Register stdrng
[ 1.279328] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0
[ 1.279920] hid: raw HID events driver (C) Jiri Kosina
[ 1.280051] usbcore: registered new interface driver usbhid
[ 1.280059] usbhid: USB HID core driver
[ 1.280834] random: crng init done
[ 1.283096] NET: Registered PF_INET6 protocol family
[ 1.870220] Freeing initrd memory: 12684K
[ 1.898842] Segment Routing with IPv6
[ 1.898907] In-situ OAM (IOAM) with IPv6
[ 1.898991] NET: Registered PF_PACKET protocol family
[ 1.899097] 8021q: 802.1Q VLAN Support v1.8
[ 1.899247] 9pnet: Installing 9P2000 support
[ 1.899322] Key type dns_resolver registered
[ 1.899785] registered taskstats version 1
[ 1.899801] Loading compiled-in X.509 certificates
[ 1.903658] Loaded X.509 cert 'Build time autogenerated kernel key: 32330adefd2da02e444296fafd37464380789679'
[ 1.906608] zswap: loaded using pool zstd/z3fold
[ 1.907226] Key type ._fscrypt registered
[ 1.907235] Key type .fscrypt registered
[ 1.907240] Key type fscrypt-provisioning registered
[ 1.908245] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
[ 1.922095] Key type encrypted registered
[ 1.922126] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.922166] ima: No TPM chip found, activating TPM-bypass!
[ 1.922195] ima: Allocated hash algorithm: sha1
[ 1.922227] ima: No architecture policies found
[ 1.922287] evm: security.selinux
[ 1.922292] evm: security.SMACK64
[ 1.922313] evm: security.ima
[ 1.922317] evm: security.capability
[ 1.922321] evm: HMAC attrs: 0x1
[ 1.935406] platform 1100000.mixer: Fixing up cyclic dependency with 6510000.tcon-top
[ 1.935756] sun8i-mixer 1100000.mixer: Adding to iommu group 0
[ 1.937838] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 1.937871] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 1.938040] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f064 hci version 0x100 quirks 0x0000000002010010
[ 1.938102] xhci-hcd xhci-hcd.1.auto: irq 43, io mem 0x05200000
[ 1.938567] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.938584] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.938594] usb usb1: Product: xHCI Host Controller
[ 1.938603] usb usb1: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd
[ 1.938611] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 1.939145] hub 1-0:1.0: USB hub found
[ 1.939190] hub 1-0:1.0: 1 port detected
[ 1.939527] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 1.939547] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 1.939567] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 1.939664] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.939823] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.939836] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.939846] usb usb2: Product: xHCI Host Controller
[ 1.939854] usb usb2: Manufacturer: Linux 5.15.48-sunxi64 xhci-hcd
[ 1.939863] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 1.940275] hub 2-0:1.0: USB hub found
[ 1.940310] hub 2-0:1.0: 1 port detected
[ 1.942951] sun50i_cpufreq_nvmem: Using CPU speed bin speed0
[ 1.944731] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
[ 1.951102] of_cfs_init
[ 1.951222] of_cfs_init: OK
[ 1.951547] ALSA device list:
[ 1.951553] No soundcards found.
[ 1.952660] Freeing unused kernel memory: 2496K
[ 1.985358] Run /init as init process
[ 1.985366] with arguments:
[ 1.985373] /init
[ 1.985378] with environment:
[ 1.985383] HOME=/
[ 1.985388] TERM=linux
[ 1.985393] ubootpart=ce3dfe46-01
[ 1.985398] cgroup_enable=memory
[ 2.197340] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[ 2.350433] usb 1-1: New USB device found, idVendor=045e, idProduct=0745, bcdDevice= 6.33
[ 2.350464] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.350474] usb 1-1: Product: Microsoft® 2.4GHz Transceiver v7.0
[ 2.350483] usb 1-1: Manufacturer: Microsoft
[ 2.375225] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.0/0003:045E:0745.0001/input/input0
[ 2.438207] hid-generic 0003:045E:0745.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input0
[ 2.442434] axp20x-i2c 0-0036: AXP20x variant AXP806 found
[ 2.450726] input: axp20x-pek as /devices/platform/soc/7081400.i2c/i2c-0/0-0036/axp221-pek/input/input1
[ 2.454955] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Mouse as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input2
[ 2.460662] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.1/0003:045E:0745.0002/input/input3
[ 2.462363] vdd-cpu: supplied by vcc-5v
[ 2.463981] vdd-gpu: supplied by vcc-5v
[ 2.464566] vdd-sys: Bringing 900000uV into 960000-960000uV
[ 2.464950] vdd-sys: supplied by vcc-5v
[ 2.465877] vcc-dram: supplied by vcc-5v
[ 2.466667] vcc-pl-led-ir: supplied by vcc-5v
[ 2.467435] vcc33-audio-tv-ephy-mac: Bringing 700000uV into 3300000-3300000uV
[ 2.467815] vcc33-audio-tv-ephy-mac: supplied by vcc-5v
[ 2.517838] hid-generic 0003:045E:0745.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input1
[ 2.526830] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 Consumer Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input4
[ 2.574062] vcc33-io-pd-emmc-sd-usb-uart-1: Bringing 700000uV into 3300000-3300000uV
[ 2.574423] vcc33-io-pd-emmc-sd-usb-uart-1: supplied by vcc-5v
[ 2.575457] vcc18-dram-bias-pll: supplied by vcc-5v
[ 2.576536] vcc-efuse-pcie-hdmi-pc: supplied by vcc-5v
[ 2.577198] vcc-wifi-io-pm-pg: Bringing 700000uV into 1800000-1800000uV
[ 2.577534] vcc-wifi-io-pm-pg: supplied by vcc-5v
[ 2.578659] bldo4: supplied by vcc-5v
[ 2.579187] vcc33-io-pd-emmc-sd-usb-uart-2: supplied by vcc-5v
[ 2.580004] cldo2: supplied by vcc-5v
[ 2.580651] cldo3: supplied by vcc-5v
[ 2.580881] sw: supplied by regulator-dummy
[ 2.581462] axp20x-i2c 0-0036: AXP20X driver loaded
[ 2.587289] input: Microsoft Microsoft® 2.4GHz Transceiver v7.0 System Control as /devices/platform/soc/5200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.2/0003:045E:0745.0003/input/input6
[ 2.587787] hid-generic 0003:045E:0745.0003: input,hiddev96,hidraw2: USB HID v1.11 Device [Microsoft Microsoft® 2.4GHz Transceiver v7.0] on usb-xhci-hcd.1.auto-1/input2
[ 2.590166] sun50i-h6-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[ 2.590661] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pb not found, using dummy regulator
[ 2.591648] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator
[ 2.592259] printk: console [ttyS0] disabled
[ 2.592370] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 35, base_baud = 1500000) is a 16550A
[ 2.592603] printk: console [ttyS0] enabled
[ 2.594026] sun4i-drm display-engine: Adding to iommu group 0
[ 2.614241] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e16990)
[ 2.614521] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800008e1abb8)
[ 2.614859] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff800008e11ba0)
[ 2.614950] sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator
[ 2.615547] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.615931] sun8i-dw-hdmi 6000000.hdmi: EVENT=plugin
[ 2.616321] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.616766] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff800008e15cc8)
[ 2.627717] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 2.627781] sun8i-dw-hdmi 6000000.hdmi: read_hpd result: 1
[ 2.785963] Console: switching to colour frame buffer device 240x67
[ 2.835811] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device
[ 2.857467] acx00-codec acx00-codec: DMA mask not set
[ 2.859822] sun50i-h6-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[ 2.862436] sunxi-mmc 4020000.mmc: Got CD GPIO
[ 2.862855] vcc-wifi-io: supplied by vcc33-wifi
[ 2.865691] ehci-platform 5101000.usb: EHCI Host Controller
[ 2.865735] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 3
[ 2.865880] ehci-platform 5101000.usb: irq 41, io mem 0x05101000
[ 2.885309] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00
[ 2.885313] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[ 2.885574] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[ 2.885643] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.885658] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.885669] usb usb3: Product: EHCI Host Controller
[ 2.885677] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
[ 2.885686] usb usb3: SerialNumber: 5101000.usb
[ 2.886286] hub 3-0:1.0: USB hub found
[ 2.886349] hub 3-0:1.0: 1 port detected
[ 2.887655] ehci-platform 5311000.usb: EHCI Host Controller
[ 2.887708] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 4
[ 2.887848] ehci-platform 5311000.usb: irq 44, io mem 0x05311000
[ 2.905298] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00
[ 2.905653] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.905668] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.905678] usb usb4: Product: EHCI Host Controller
[ 2.905687] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
[ 2.905695] usb usb4: SerialNumber: 5311000.usb
[ 2.906266] hub 4-0:1.0: USB hub found
[ 2.906311] hub 4-0:1.0: 1 port detected
[ 2.907463] ohci-platform 5101400.usb: Generic Platform OHCI controller
[ 2.907502] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 5
[ 2.907639] ohci-platform 5101400.usb: irq 42, io mem 0x05101400
[ 2.920322] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.922092] mmc0: Problem switching card into high-speed mode!
[ 2.922211] mmc0: new SDHC card at address 0001
[ 2.923101] mmcblk0: mmc0:0001 USD 29.8 GiB
[ 2.925179] mmcblk0: p1
[ 2.969595] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 2.969624] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.969635] usb usb5: Product: Generic Platform OHCI controller
[ 2.969643] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
[ 2.969652] usb usb5: SerialNumber: 5101400.usb
[ 2.970330] hub 5-0:1.0: USB hub found
[ 2.970383] hub 5-0:1.0: 1 port detected
[ 2.971617] ohci-platform 5311400.usb: Generic Platform OHCI controller
[ 2.971660] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 6
[ 2.971801] ohci-platform 5311400.usb: irq 45, io mem 0x05311400
[ 3.017445] mmc2: new HS200 MMC card at address 0001
[ 3.018424] mmcblk2: mmc2:0001 8GTF4R 7.28 GiB
[ 3.020685] mmcblk2boot0: mmc2:0001 8GTF4R 4.00 MiB
[ 3.022339] mmcblk2boot1: mmc2:0001 8GTF4R 4.00 MiB
[ 3.033624] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 3.033662] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.033673] usb usb6: Product: Generic Platform OHCI controller
[ 3.033682] usb usb6: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
[ 3.033690] usb usb6: SerialNumber: 5311400.usb
[ 3.034410] hub 6-0:1.0: USB hub found
[ 3.034470] hub 6-0:1.0: 1 port detected
[ 3.035805] usb_phy_generic usb_phy_generic.4.auto: supply vcc not found, using dummy regulator
[ 3.036009] usb_phy_generic usb_phy_generic.4.auto: dummy supplies not allowed for exclusive requests
[ 3.133661] musb-hdrc musb-hdrc.5.auto: MUSB HDRC host driver
[ 3.133704] musb-hdrc musb-hdrc.5.auto: new USB bus registered, assigned bus number 7
[ 3.133977] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 3.133993] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.134004] usb usb7: Product: MUSB HDRC host driver
[ 3.134012] usb usb7: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd
[ 3.134020] usb usb7: SerialNumber: musb-hdrc.5.auto
[ 3.134715] hub 7-0:1.0: USB hub found
[ 3.134773] hub 7-0:1.0: 1 port detected
[ 3.150722] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found
[ 3.150748] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found
[ 3.151052] dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator
[ 3.151322] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[ 3.151370] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 50000)
[ 3.257560] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
[ 3.257587] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
[ 3.257594] dwmac-sun8i 5020000.ethernet: COE Type 2
[ 3.257604] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
[ 3.257612] dwmac-sun8i 5020000.ethernet: Normal descriptors
[ 3.257619] dwmac-sun8i 5020000.ethernet: Chain mode enabled
[ 3.485042] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none.
[ 3.701321] usb 5-1: new full-speed USB device number 2 using ohci-platform
[ 3.938354] usb 5-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.10
[ 3.938383] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.938394] usb 5-1: Product: USB Receiver
[ 3.938402] usb 5-1: Manufacturer: Logitech
[ 3.947518] input: Logitech USB Receiver as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.0/0003:046D:C52B.0004/input/input7
[ 4.006002] hid-generic 0003:046D:C52B.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-5101400.usb-1/input0
[ 4.012208] input: Logitech USB Receiver Mouse as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input8
[ 4.012665] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input9
[ 4.069662] input: Logitech USB Receiver System Control as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.1/0003:046D:C52B.0005/input/input10
[ 4.070031] hid-generic 0003:046D:C52B.0005: input,hiddev97,hidraw4: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-5101400.usb-1/input1
[ 4.074797] hid-generic 0003:046D:C52B.0006: hiddev98,hidraw5: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2
[ 4.780230] systemd[1]: System time before build time, advancing clock.
[ 4.868365] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq
[ 4.877545] systemd[1]: systemd 249.11-0ubuntu3.1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS -OPENSSL +ACL +BLKID +CURL +ELFUTILS -FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP -LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 4.878226] systemd[1]: Detected architecture arm64.
[ 4.881592] systemd[1]: Hostname set to <orangepi3-lts>.
[ 5.101862] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[ 5.119516] mmc1: new high speed SDIO card at address 8800
[ 6.293876] systemd[1]: Queued start job for default target Graphical Interface.
[ 6.299750] systemd[1]: Created slice Slice /system/modprobe.
[ 6.302537] systemd[1]: Created slice Slice /system/serial-getty.
[ 6.304385] systemd[1]: Created slice User and Session Slice.
[ 6.305369] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.306819] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.307696] systemd[1]: Reached target Remote File Systems.
[ 6.308041] systemd[1]: Reached target Slice Units.
[ 6.308380] systemd[1]: Reached target Swaps.
[ 6.308677] systemd[1]: Reached target System Time Set.
[ 6.309210] systemd[1]: Reached target Local Verity Protected Volumes.
[ 6.310301] systemd[1]: Listening on Syslog Socket.
[ 6.311159] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.311801] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 6.313180] systemd[1]: Listening on Journal Audit Socket.
[ 6.314227] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.315211] systemd[1]: Listening on Journal Socket.
[ 6.326975] systemd[1]: Listening on udev Control Socket.
[ 6.328076] systemd[1]: Listening on udev Kernel Socket.
[ 6.332683] systemd[1]: Mounting Huge Pages File System...
[ 6.338074] systemd[1]: Mounting POSIX Message Queue File System...
[ 6.343823] systemd[1]: Mounting Kernel Debug File System...
[ 6.345097] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 6.352304] systemd[1]: Starting Restore / save the current clock...
[ 6.358015] systemd[1]: Starting Set the console keyboard layout...
[ 6.364390] systemd[1]: Starting Create List of Static Device Nodes...
[ 6.371017] systemd[1]: Starting Load Kernel Module configfs...
[ 6.377727] systemd[1]: Starting Load Kernel Module drm...
[ 6.384315] systemd[1]: Starting Load Kernel Module fuse...
[ 6.391403] systemd[1]: Started Nameserver information manager.
[ 6.392936] systemd[1]: Reached target Preparation for Network.
[ 6.394122] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 6.406943] systemd[1]: Starting Load Kernel Modules...
[ 6.412637] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.418869] systemd[1]: Starting Coldplug All udev Devices...
[ 6.429912] systemd[1]: Mounted Huge Pages File System.
[ 6.431274] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.432661] systemd[1]: Mounted Kernel Debug File System.
[ 6.435426] systemd[1]: Finished Restore / save the current clock.
[ 6.438862] systemd[1]: Finished Create List of Static Device Nodes.
[ 6.439496] fuse: init (API version 7.34)
[ 6.441770] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 6.443183] systemd[1]: Finished Load Kernel Module configfs.
[ 6.446061] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 6.447247] systemd[1]: Finished Load Kernel Module drm.
[ 6.449663] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 6.450951] systemd[1]: Finished Load Kernel Module fuse.
[ 6.458776] systemd[1]: Mounting FUSE Control File System...
[ 6.464040] systemd[1]: Mounting Kernel Configuration File System...
[ 6.474677] systemd[1]: Mounted FUSE Control File System.
[ 6.475071] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
[ 6.481615] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 6.483009] systemd[1]: Mounted Kernel Configuration File System.
[ 6.483907] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 6.488816] systemd[1]: Starting Load/Save Random Seed...
[ 6.494729] systemd[1]: Starting Create System Users...
[ 6.660140] WCN: marlin_init entry!
[ 6.660666] WCN: wcn config bt wake host
[ 6.660887] WCN_ERR: dts node for bt_wake not found
[ 6.660891] WCN: marlin2 parse_dt some para not config
[ 6.660903] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
[ 6.665745] sdiohal:sdiohal_init ok
[ 6.666445] WCN: marlin_probe ok!
[ 6.691458] mtty_probe init device addr: 0x00000000009926d4
[ 6.691698] -->rfkill_bluetooth_init
[ 6.691861] bluetooth_set_power: start_block=1
[ 6.691875] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0
[ 6.691886] bluetooth_set_power: end_block=1
[ 6.691905] <--rfkill_bluetooth_init
[ 6.715886] systemd[1]: Finished Load/Save Random Seed.
[ 6.718379] systemd[1]: Finished Create System Users.
[ 6.719559] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[ 6.724878] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 6.796727] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.798565] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.819533] [ADDR_MGT] addr_mgt_probe: module version: v1.0.9
[ 6.819648] [ADDR_MGT] addr_mgt_probe: success.
[ 6.863106] systemd[1]: Finished Set the console keyboard layout.
[ 6.887348] WCN: start_marlin [MARLIN_WIFI]
[ 6.887375] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
[ 6.887385] WCN: the first power on start
[ 6.894415] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 6.901977] systemd[1]: Reached target Preparation for Local File Systems.
[ 6.914256] systemd[1]: Mounting /tmp...
[ 6.928825] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 6.939787] systemd[1]: Mounted /tmp.
[ 6.947152] systemd[1]: Reached target Local File Systems.
[ 6.959184] systemd[1]: Starting Armbian leds state...
[ 6.971551] systemd[1]: Starting Armbian ZRAM config...
[ 6.984210] systemd[1]: Starting Set console font and keymap...
[ 6.993355] WCN: marlin chip en dummy pull up -- need manually set GPIO
[ 6.996364] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[ 7.021397] sdiohal:sdiohal_scan_card
[ 7.021668] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=50000000
[ 7.021795] systemd[1]: Starting Set Up Additional Binary Formats...
[ 7.021816] WCN: marlin_scan_finish!
[ 7.021823] sdiohal:probe ok
[ 7.021979] sdiohal:scan end!
[ 7.021987] WCN: then marlin start to download
[ 7.022257] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
[ 7.022272] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
[ 7.029127] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 7.029487] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 7.032823] systemd[1]: Finished Set console font and keymap.
[ 7.046131] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 365 (systemd-binfmt)
[ 7.052057] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 7.083231] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[ 7.134889] systemd[1]: Finished Coldplug All udev Devices.
[ 7.189454] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[ 7.200737] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 7.220106] systemd[1]: Finished Set Up Additional Binary Formats.
[ 7.250460] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[ 7.311656] systemd[1]: Finished Armbian leds state.
[ 7.592733] systemd[1]: Started Rule-based Manager for Device Events and Files.
[ 7.600572] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[ 7.601200] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active.
[ 7.616428] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[ 7.616576] systemd[1]: Reached target Local Encrypted Volumes.
[ 7.674195] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ 7.714809] systemd[1]: Starting Load/Save RF Kill Switch Status...
[ 7.775762] bluetooth_set_power: start_block=0
[ 7.775792] WCN: start_marlin [MARLIN_BLUETOOTH]
[ 7.975324] zram: Added device: zram0
[ 7.975654] zram: Added device: zram1
[ 7.976033] zram: Added device: zram2
[ 8.094917] WCN: combin_img 0 marlin_firmware_write finish and successful
[ 8.095242] WCN: marlin_start_run read reset reg val:0x1
[ 8.095250] WCN: after do marlin_start_run reset reg val:0x0
[ 8.095433] WCN: s_marlin_bootup_time=8095432843
[ 8.101544] WCN: clock mode: TSX
[ 8.101736] WCN: marlin_write_cali_data sync init_state:0x0
[ 8.132768] WCN: marlin_write_cali_data sync init_state:0x0
[ 8.159666] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
[ 8.159698] WCN: sdio_config bt_wake_host trigger:[high]
[ 8.159701] WCN: sdio_config irq:[inband]
[ 8.159703] WCN: sdio_config wake_host_level_duration_time:[20ms]
[ 8.159708] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
[ 8.159710] WCN: marlin_send_sdio_config_to_cp sdio_config:0x80f01 (enable config)
[ 8.160558] WCN: marlin_write_cali_data finish
[ 8.161314] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.177333] mc: Linux media interface: v0.10
[ 8.190592] panfrost 1800000.gpu: clock rate = 432000000
[ 8.190630] panfrost 1800000.gpu: bus_clock rate = 100000000
[ 8.191105] panfrost 1800000.gpu: mali-t720 id 0x720 major 0x1 minor 0x1 status 0x0
[ 8.191128] panfrost 1800000.gpu: features: 00000000,10309e40, issues: 00000000,21054400
[ 8.191136] panfrost 1800000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002821 AS:0xf JS:0x7
[ 8.191144] panfrost 1800000.gpu: shader_present=0x3 l2_present=0x1
[ 8.191541] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.192979] [drm] Initialized panfrost 1.2.0 20180908 for 1800000.gpu on minor 1
[ 8.217760] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.228323] videodev: Linux video capture interface: v2.00
[ 8.248869] zram0: detected capacity change from 0 to 2037304
[ 8.249575] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
[ 8.279502] systemd[1]: Found device /dev/ttyS0.
[ 8.287283] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
[ 8.287302] WCN: marlin_bind_verify confuse data: 0xe5ae06b9a313020e4477650022a32ad5
[ 8.287317] WCN: marlin_bind_verify verify data: 0xa5ab8048e6a32ce226d910652b504834
[ 8.288057] WCN: check_cp_ready sync val:0xf0f0f0f8, prj_type val:0x0
[ 8.313569] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
[ 8.313595] sdiohal:sdiohal_runtime_get entry
[ 8.317949] WCN: get_cp2_version entry!
[ 8.337651] Adding 1018648k swap on /dev/zram0. Priority:5 extents:1 across:1018648k SSFS
[ 8.357401] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
[ 8.358024] WCN: switch_cp2_log - close entry!
[ 8.359418] WCN: WCND at cmd read:OK
[ 8.359553] WCN: then marlin download finished and run ok
[ 8.359585] WCN: start_loopcheck
[ 8.359607] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1
[ 8.359615] WCN: marlin have open, GNSS is closed
[ 8.359620] bluetooth_set_power: end_block=0
[ 8.377701] systemd[1]: Started Load/Save RF Kill Switch Status.
[ 8.392873] WCN: get_board_ant_num [one_ant]
[ 8.392894] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
[ 8.421557] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.426838] cedrus 1c0e000.video-codec: Adding to iommu group 0
[ 8.435265] cedrus 1c0e000.video-codec: Device registered as /dev/video0
[ 8.475450] Registered IR keymap rc-empty
[ 8.493733] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0
[ 8.508606] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
[ 8.514745] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input12
[ 8.515268] sunxi-ir 7040000.ir: initialized sunXi IR driver
[ 8.558655] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
[ 8.571387] zram1: detected capacity change from 0 to 102400
[ 8.589949] systemd[1]: Finished Load Kernel Modules.
[ 8.626023] systemd[1]: Starting Apply Kernel Variables...
[ 8.701400] systemd[1]: Finished Armbian ZRAM config.
[ 8.724623] systemd[1]: Starting Armbian memory supported logging...
[ 8.741406] systemd[1]: Finished Apply Kernel Variables.
[ 8.759248] systemd[1]: Starting Raise network interfaces...
[ 8.928132] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none.
[ 9.050204] logitech-djreceiver 0003:046D:C52B.0006: hiddev97,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-5101400.usb-1/input2
[ 9.206494] input: Logitech Wireless Device PID:4004 Keyboard as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input13
[ 9.274225] hid-generic 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4004] on usb-5101400.usb-1/input2:1
[ 9.465060] input: Logitech K360 as /devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.2/0003:046D:C52B.0006/0003:046D:4004.0007/input/input17
[ 9.465977] logitech-hidpp-device 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K360] on usb-5101400.usb-1/input2:1
[ 9.758059] systemd[1]: Finished Raise network interfaces.
[ 9.909199] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 9.909534] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[ 9.909890] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 9.913981] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[ 9.914092] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 9.914197] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 9.914269] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 9.998835] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 9.999036] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[ 9.999099] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[ 9.999176] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 9.999275] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 9.999378] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 11.570712] systemd[1]: Finished Armbian memory supported logging.
[ 11.580348] systemd[1]: Starting Journal Service...
[ 11.722747] systemd[1]: Started Journal Service.
[ 11.751364] systemd-journald[691]: Received client request to flush runtime journal.
BOARD=orangepi3-lts
VERSION=22.05.3
LINUXFAMILY=sunxi64
ARCH=arm64
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm64
BRANCH=current
verbosity=1
bootlogo=false
console=both
rootfstype=ext4
### lsusb:
### lscpu:
CPU(s): 4
Vendor ID: ARM
Model: 4
Socket(s): -
Cluster(s): 1
Stepping: r0p4
BogoMIPS: 48.00
NUMA node(s): 1
### cpuinfo:
processor : 0
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 48.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
### meminfo:
MemFree: 1845816 kB
MemAvailable: 1851728 kB
Buffers: 12532 kB
Cached: 53568 kB
SwapCached: 0 kB
Active: 32208 kB
Inactive: 52908 kB
Active(anon): 444 kB
Inactive(anon): 22100 kB
Active(file): 31764 kB
Inactive(file): 30808 kB
Unevictable: 0 kB
Mlocked: 0 kB
Dirty: 3392 kB
Writeback: 0 kB
AnonPages: 19056 kB
Mapped: 16768 kB
Shmem: 3388 kB
KReclaimable: 10580 kB
Slab: 45824 kB
SReclaimable: 10580 kB
SUnreclaim: 35244 kB
KernelStack: 2464 kB
PageTables: 1652 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
Committed_AS: 42432 kB
VmallocUsed: 22700 kB
VmallocChunk: 0 kB
Percpu: 976 kB
AnonHugePages: 0 kB
FileHugePages: 0 kB
FilePmdMapped: 0 kB
CmaTotal: 131072 kB
CmaFree: 128768 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugetlb: 0 kB
### virtual memory:
vm.dirty_bytes = 0
vm.dirty_ratio = 20
vm.laptop_mode = 0
vm.nr_hugepages = 0
vm.numa_stat = 1
vm.page-cluster = 0
vm.panic_on_oom = 0
vm.swappiness = 100
vm.user_reserve_kbytes = 63004
### ip addr:
### partitions:
252 0 1018652 zram0
252 1 51200 zram1
### df:
/dev/mmcblk0p1 29G 5.1G 24G 18% /
/dev/zram1 47M 3.3M 41M 8% /var/log
### lsblk:
mmcblk0 29.8G
└─mmcblk0p1 ext4 29.4G / 71b44a6c-5bb8-4352-afe7-d22b8e62de4c
zram1 50M /var/log
zram2 0B
### zramctl:
### mtab:
### mmc0:0001 info:
fwrev: 0x0
rca: 0x0001
manfid: 0x00001d
ocr: 0x00200000
type: SD
hwrev: 0x1
date: 01/2022
dsr: 0x404
erase_size: 512
oemid: 0x4144
serial: 0x00005ae0
### mmc2:0001 info:
rel_sectors: 0x1
rca: 0x0001
pre_eol_info: 0x01
manfid: 0x000015
ocr: 0x00200000
type: MMC
hwrev: 0x0
date: 12/2021
prv: 0x6
ffu_capable: 1
dsr: 0x404
erase_size: 524288
oemid: 0x0100
serial: 0xd410e21f
cmdq_en: 0
rev: 0x8
07:44:50: 1704MHz 1.34 47% 20% 14% 0% 12% 0% 59.7°C 0/9
07:44:51: 1320MHz 1.34 11% 6% 3% 1% 0% 0% 59.7°C 0/9
07:44:51: 1080MHz 1.34 18% 11% 4% 1% 0% 0% 55.4°C 0/9
07:44:52: 1080MHz 1.34 11% 7% 2% 1% 0% 0% 54.6°C 0/9
07:44:52: 1080MHz 1.34 19% 15% 2% 0% 0% 0% 54.6°C 0/9
Link to comment
Share on other sites
Wifi does not work on Orange Pi 3 LTS.   Armbian boots but no wifi detected.   If I install the official Ubuntu from Orange Pi,  it does work normally.  I believe that this version of Armbian does not contain correct Wifi drivers for this board.
There is no feasible way to post the logs at this time.
Upon further research, it appears that without significant effort to troubleshoot and fix (at the expert level) ,  people should not expect that the current (September 2022) release of Armbian for Orange Pi 3 LTS to work.   This board is not supported.
Edited by Joe5150
updated formation
Link to comment
Board is supported if there are volunteer maintainers which are suppose to help this way.
I can personally assure you that WiFi on 3 LTS was tested (at least on 2.4G network) and it works. I am not saying it works pitch perfect yet, but it works good enough for amateur use. More then this we can't provide as there is absolutely no interest from your side to compensate time lost working on things in your interest.
Since this is open source and since we provide perfectly supported SDK, nobody prevents anyone to fix problems.
Its always a trade. That kernel will probably never receive any update. If that suits you and if you trust that vendor private kernel which nobody else uses with random hacks and random hacks on top of Armbian (yes, they use Armbian as a base, not Ubuntu. Ubuntu is only to make sales association), use that.
Usually there is just one version that is ported to the new kernel with minimum efforts. Mainlining drivers is epic and expensive project which is difficult to run if clients are not paying anything and all benefits also goes to your competition. https://docs.armbian.com/User-Guide_FAQ/#development-time (check other FAQ points)
Possible workarounds: try connecting with other tools, twice, try rfkill list / block / unblock, reboot, ...
Link to comment
2 hours ago, Timo12357 said:
Has anyone tested the 5.15y kernel released 30th of November 2022? Does wifi work with it?
Armbian automated testings shows no problems with WiFi https://paste.armbian.com/yaqokonipe But this image is little further then released, made from latest sources (nightly). You can switch to the same firmware via armbian-config.
Link to comment
I have the same problem
Kernel info: Linux OrPi 5.15.80-sunxi64 #22.11.1 SMP Wed Nov 30 11:23:00 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
armbianmonitor -u output: https://paste.armbian.com/okifayides
Sometimes the wifi shown and after I clicked connect is disappeared, really weird. I have to use ethernet cable and client router.
Link to comment
I have the exact same problem
 Orpi 3 lts, 22.11.1 jammy.
I find the networks, then when i connect it says it could not find the network.
I have tested with pass and without pass on 5Ghz and 2.4Ghz with no luck. And after i tried to connect to the network they just dissaper from the search list, and i have to go to the edit connection and delete the wifi networks from there and reboot the device to get them up again on the search list.
Im using the nmtui tool.
Link to comment
Hi, I purchased a Orangi Pi 3 LTS but indeed I have the same problem as described here. Ive run armbianmonitor: https://paste.armbian.com/ojizomeqot
At first glance I do not see any clear issues that stand out. I seem to have the same WIFI chip as mentioned here:
And the image I used is the newest one. Any solution for this problem yet?
Edited by Artenverho
Link to comment
Some problems has been solved, but not all. Switch to nightly beta repository that is tied to development and see if it helps.
Otherwise we invested our private time to research paths that might get us to the solution or at least to the better state, but we also face problems our "customers" don't want to hear about:
- we don't have resources for integration or help on integrating this. Voolonteers are scarse and overloaded. We are already over the limits,
- with donations https://liberapay.com/armbian hiring help is not possible. Who wants to work for free, already works, others can't afford,
- we are also under constant attack by swindlers which waits we solve this so they can take credits or sell it to someone. Remember that its a big difference helping you or helping someone that is making profits out of our generocity.
What would you do?
Link to comment
Very reasonable that you are not the ones that are willing (or have resources) to specifically solve problems that occur for each individual systems. I just noticed that image from OrangePi themselves has the same issue. Unfortunately my knowledge on debugging hardware issues is limited but please let me know if I can be of any assistance to test and send back logs.
I have been using Armbian for many years and consider it one of the finest pieces of software developed.
Ps. I tried the nightly build but it unfortunately did not fix the problem, in the meantime I will be using a USB WIFI dongle as replacement.
Link to comment
