zogu Posted November 6, 2018 Posted November 6, 2018 2 hours ago, Saurabh said: Hi, I was trying armbian images with 4.18 and 4.19 kernel on my s905w 2G/16 board. It's working fine but I facing 2 issues: 1. The board has wifi chip of sv6051p chip and doing modprobe “dhd” or “wifi_dummy” or "ssv6051" or "wlan" doesn't work. Always says module not found. 2. The default sound output is HDMI , so is there anyway by which we can change it to Av output ? You have to compile wifi driver by yourself, mainstream kernel has very bad support for wifi chips. For sound output use alsa mixer to configure. Or make dtb file for exactly your model. Also there is separate topic for Armbian build with mainstream kernel: 1
lizzacore Posted November 9, 2018 Posted November 9, 2018 On 11/4/2018 at 11:12 PM, lizzacore said: I have 5.59 with 4.18 kernel. which are the changes to 5.64 with kernel 4.19 ? Can anybody say what’s new ? may I can see somewhere the changelog for the future ? Nice help, thanks to all.
jluc Posted November 10, 2018 Posted November 10, 2018 Bonjour, Excuse me for my poor English language; i'm french ! I just installed Armbian_5.37_S9xxx_Debian_stretch_3.14.29_server_20171226.img in dual-boot in my Mecool M8s-pro+ (4.xx) not boot. But i have a problem, the owner and group of files and directory are "1023" (a user who does not exist)=>screen of /etc directory: etc directory When I add users in home directory (adduser command), the owner and the group of the users created are good (1001 and 1002) ; but after restarting, owner and group of users become "1023"=> like screen home directory I do not understand what it can come ; this is very annoying for ssh key connection. If you can help me, thank you. Merci d'avance pour votre aide.
briand123 Posted November 12, 2018 Posted November 12, 2018 I have a mecool bb2 pro which is a powerful 8 core s912 box. I'm using it for real-time FFMPEG transcoding and re-streaming and it's able to do this for HD with this number of core w/o GPU. The problem I have is I need to make the wifi work on this box. The install of Armbian is not finding the wifi hardware and installing drivers. I tried the methods at the top of this post for wifi and none of them work on this box. Maybe I need to build drivers for it myself? Does anyone know the wifi chip used on the mecool bb2 pro and/or if there is a way to detect and dump that info from Armbian command line tools?
dbsharpe Posted November 12, 2018 Posted November 12, 2018 1 hour ago, briand123 said: I have a mecool bb2 pro which is a powerful 8 core s912 box. I'm using it for real-time FFMPEG transcoding and re- Sorry, not familiar with mecool bb2 pro but as a general tip when debugging wifi problems, I found kernel 3.x Armbian builds supported wifi but the 4.x kernels did not work even though a module was loaded. Having got the correct dtb file, I had a poke around in /sys/class/net/wlan0/device/modalias & uevent I compared this to what android had and also made sure the files being used by android /lib/firmware/ and Armbian where correct.
lizzacore Posted November 12, 2018 Posted November 12, 2018 On 11/9/2018 at 7:59 AM, lizzacore said: Nice help, thanks to all. No one can help me with this question ??
Francisco Aarón Posted November 13, 2018 Posted November 13, 2018 (edited) Hi! I can't boot the Armbian image in a Mecool Ki Pro, at least from USB. I tried changing in uEnv.ini the DTB to "dtb/meson-gxl-s905d-p230.dtb" and copying it as "dtb.img" in root of the BOOT partition without success, even I created my own aml_autoscript based in the original but haven't luck. Here is my aml_autoscript after many modifications trying to get it work: defenv setenv env_addr 0x10400000 setenv kernel_addr 0x11000000 setenv initrd_addr 0x13000000 setenv bootargs 'root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0' setenv boot_start 'booti ${kernel_addr} ${initrd_addr} ${dtb_mem_addr}' setenv sdload 'if fatload mmc 0 ${kernel_addr} zImage; \ then \ if fatload mmc 0 ${initrd_addr} uInitrd; \ then \ if fatload mmc 0 ${env_addr} uEnv.ini; \ then \ env import -t ${env_addr} ${filesize}; \ fi; \ if fatload mmc 0 ${dtb_mem_addr} dtb.img; \ then \ #run boot_start; \ setenv bootargs ${bootargs} sdload \ booti ${kernel_addr} ${initrd_addr} ${dtb_mem_addr}; \ else \ store dtb read ${dtb_mem_addr}; \ #run boot_start; \ booti ${kernel_addr} ${initrd_addr} ${dtb_mem_addr}; \ fi; \ fi; \ fi;' setenv usbload 'if fatload usb 0 ${kernel_addr} zImage; \ then \ if fatload usb 0 ${initrd_addr} uInitrd; \ then \ if fatload usb 0 ${env_addr} uEnv.ini; \ then \ env import -t ${env_addr} ${filesize}; \ fi; \ if fatload usb 0 ${dtb_mem_addr} dtb.img; \ then \ #run boot_start; \ setenv bootargs ${bootargs} usbload \ booti ${kernel_addr} ${initrd_addr} ${dtb_mem_addr}; \ else \ store dtb read ${dtb_mem_addr}; \ #run boot_start; \ booti ${kernel_addr} ${initrd_addr} ${dtb_mem_addr}; \ fi; \ fi; \ fi;' setenv bootcmd 'run sdload; run usbload; run storeboot;' #setenv upgrade_step 2 saveenv #run storeargs # desactivar si da problemas run sdload run usbload run storeboot #run bootcmd #sleep 1 #reboot PD: The image I have is "Armbian_5.60_Aml-s9xxx_Ubuntu_bionic_default_4.18.7_desktop_20180928.img" Edited November 13, 2018 by Francisco Aarón
briand123 Posted November 13, 2018 Posted November 13, 2018 10 hours ago, dbsharpe said: Sorry, not familiar with mecool bb2 pro but as a general tip when debugging wifi problems, I found kernel 3.x Armbian builds supported wifi but the 4.x kernels did not work even though a module was loaded. Having got the correct dtb file, I had a poke around in /sys/class/net/wlan0/device/modalias & uevent I compared this to what android had and also made sure the files being used by android /lib/firmware/ and Armbian where correct. Fwiw, I had to use the 3.x kernel to get the mecool bb2 pro s912 to boot. This build: Armbian_5.44_S9xxx_Ubuntu_xenial_3.14.29_mate_20180515.img But no wifi KLM is loaded for the wireless hardware. Maybe I need to try another dtb file in that build.
ster Posted November 13, 2018 Posted November 13, 2018 (edited) hi all, same kind of problem for few days, trying to make wifi & bt to work on several boxes i have here : mini m8s (s905) , x96 mini (s905w), i have mecool and beelikn minimx too No luck for the moment, i'm going to try to use the box for Domoticz usage (installed it and had the webpage working but i have trouble with armbian and internal box hw) i bought them long time ago, not very sure if each of them support wifi (i think so ) and Bluetooth (not sure, at least x96mini doesn't) Armbian worked well (i found the correct dtb fil for each box) so i parsed alors of pages from this forum, and tried few things for wifi , i'm on the mini m8s classic box and hope some advices : i think the mini m8s s905 box has 8723bs so i tried "modprobe 8723bs" i tried first : 5.64 image but after few reading i got the point i needed to go to a 3.14 kernel and now sd card has it : took from mali6/5.41.1_KODI-17.6 image Linux amlogic 3.14.29 #24 SMP PREEMPT Fri Apr 6 18:56:07 MSK 2018 aarch64 GNU/Linux after a reboot : root@amlogic:~# lsmod Module Size Used by aml_nftl_dev 95108 0 root@amlogic:~# modprobe 8723bs root@amlogic:~# lsmod Module Size Used by 8723bs 1321264 0 cfg80211 415017 1 8723bs aml_nftl_dev 95108 0 Spoiler [ 20.013633] aml_audio_i2s_mute_flag: flag=0 [ 20.013655] aml_audio_set_spdif_mute: flag=0 [ 20.013667] aml_snd_card: aml_m8_set_spk: aml_m8_spk_enabled=0 [ 21.110814] input: lircd-uinput as /devices/virtual/input/input3 [ 21.384074] libphy: stmmac-0:08 - Link is Up - 100/Full [ 23.029943] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200 [ 23.030331] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200 [ 23.055156] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200 [ 23.055530] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200 [ 46.137792] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead. [ 200.932568] cfg80211: Calling CRDA to update world regulatory domain [ 201.069037] RTL871X: module init start [ 201.069051] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844 [ 201.069055] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844 [ 201.069058] ######platform_wifi_power_on: [ 201.069079] aml_wifi wifi.32: [extern_wifi_set_enable] WIFI Disable! 240 [ 201.102972] cfg80211: World regulatory domain updated: [ 201.102989] cfg80211: DFS Master region: unset [ 201.102994] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 201.102999] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 201.103003] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 201.103008] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 201.103012] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 201.103016] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 201.103020] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm) [ 201.103024] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 201.103028] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm) [ 201.573756] aml_wifi wifi.32: [extern_wifi_set_enable] WIFI Enable! 240 [ 202.089687] [aml_sd_emmc_irq] sdio: resp_timeout,vstat:0xa3ff2800,virqc:3fff [ 202.089713] [aml_host_bus_fsm_show] sdio: err: wait for irq service, bus_fsm:0x8 [ 202.089759] aml_sd_emmc_data_thread 2639 sdio: cmd:8 [ 202.091790] aml_sd_emmc d0070000.sdio: card claims to support voltages below defined range [ 202.109793] sdio: new high speed SDIO card at address 0001 [ 202.109817] sdio: clock 50000000, 4-bit-bus-width [ 202.110252] [sdio_reinit] finish [ 202.110407] RTL871X: module init ret=0 root@amlogic:~# iwconfig eth0 no wireless extensions. ip6tnl0 no wireless extensions. sit0 no wireless extensions. lo no wireless extensions. tunl0 no wireless extensions. any ideas? thanks alot! (will try bluetooth afterward) Edited November 13, 2018 by ster
Reddwarf Posted November 14, 2018 Posted November 14, 2018 17 hours ago, ster said: hi all, same kind of problem for few days, trying to make wifi & bt to work on several boxes i have here : mini m8s (s905) , x96 mini (s905w), i have mecool and beelikn minimx too No luck for the moment, i'm going to try to use the box for Domoticz usage (installed it and had the webpage working but i have trouble with armbian and internal box hw) i bought them long time ago, not very sure if each of them support wifi (i think so ) and Bluetooth (not sure, at least x96mini doesn't) Armbian worked well (i found the correct dtb fil for each box) so i parsed alors of pages from this forum, and tried few things for wifi , i'm on the mini m8s classic box and hope some advices : i think the mini m8s s905 box has 8723bs so i tried "modprobe 8723bs" i tried first : 5.64 image but after few reading i got the point i needed to go to a 3.14 kernel and now sd card has it : took from mali6/5.41.1_KODI-17.6 image Linux amlogic 3.14.29 #24 SMP PREEMPT Fri Apr 6 18:56:07 MSK 2018 aarch64 GNU/Linux after a reboot : root@amlogic:~# lsmod Module Size Used by aml_nftl_dev 95108 0 root@amlogic:~# modprobe 8723bs root@amlogic:~# lsmod Module Size Used by 8723bs 1321264 0 cfg80211 415017 1 8723bs aml_nftl_dev 95108 0 Reveal hidden contents [ 20.013633] aml_audio_i2s_mute_flag: flag=0 [ 20.013655] aml_audio_set_spdif_mute: flag=0 [ 20.013667] aml_snd_card: aml_m8_set_spk: aml_m8_spk_enabled=0 [ 21.110814] input: lircd-uinput as /devices/virtual/input/input3 [ 21.384074] libphy: stmmac-0:08 - Link is Up - 100/Full [ 23.029943] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200 [ 23.030331] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200 [ 23.055156] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200 [ 23.055530] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200 [ 46.137792] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead. [ 200.932568] cfg80211: Calling CRDA to update world regulatory domain [ 201.069037] RTL871X: module init start [ 201.069051] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844 [ 201.069055] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844 [ 201.069058] ######platform_wifi_power_on: [ 201.069079] aml_wifi wifi.32: [extern_wifi_set_enable] WIFI Disable! 240 [ 201.102972] cfg80211: World regulatory domain updated: [ 201.102989] cfg80211: DFS Master region: unset [ 201.102994] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 201.102999] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 201.103003] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 201.103008] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 201.103012] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 201.103016] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 201.103020] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm) [ 201.103024] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 201.103028] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm) [ 201.573756] aml_wifi wifi.32: [extern_wifi_set_enable] WIFI Enable! 240 [ 202.089687] [aml_sd_emmc_irq] sdio: resp_timeout,vstat:0xa3ff2800,virqc:3fff [ 202.089713] [aml_host_bus_fsm_show] sdio: err: wait for irq service, bus_fsm:0x8 [ 202.089759] aml_sd_emmc_data_thread 2639 sdio: cmd:8 [ 202.091790] aml_sd_emmc d0070000.sdio: card claims to support voltages below defined range [ 202.109793] sdio: new high speed SDIO card at address 0001 [ 202.109817] sdio: clock 50000000, 4-bit-bus-width [ 202.110252] [sdio_reinit] finish [ 202.110407] RTL871X: module init ret=0 root@amlogic:~# iwconfig eth0 no wireless extensions. ip6tnl0 no wireless extensions. sit0 no wireless extensions. lo no wireless extensions. tunl0 no wireless extensions. any ideas? thanks alot! (will try bluetooth afterward) I seem to remember that I had the same problem, both with the Mini M8S and a Mini MXIII (which is virtually identical), I downloaded the 8723as driver module from github, compiled and installed it and got WiFi working but never BT, until I hooked on a cheap usb-bt adapter.
Francisco Aarón Posted November 14, 2018 Posted November 14, 2018 I still can't boot Armbian in a Mecool Ki Pro. I have been using an Arch Linux image that I found on a website but it came with few things installed, and after installing more applications and configuring things now it randomly freeze. I only wanted compile applications for using in LibreElec.
ster Posted November 14, 2018 Posted November 14, 2018 Answering to myself : everything work now.. I changed boxes (i have several mini m8s) , and one is working (modprobe 8723bs display now a wlan0 in ifconfig) difference is that one box is bigger than the other, both have the same design, name and chipset serial (S905) be careful so
Reddwarf Posted November 14, 2018 Posted November 14, 2018 Just now, ster said: Answering to myself : everything work now.. I changed boxes (i have several mini m8s) , and one is working (modprobe 8723bs display now a wlan0 in ifconfig) difference is that one box is bigger than the other, both have the same design, name and chipset serial (S905) be careful so They just might have different wlan chip...
balbes150 Posted November 15, 2018 Author Posted November 15, 2018 11 hours ago, Francisco Aarón said: I still can't boot Armbian in a Mecool Ki Pro. I have been using an Arch Linux image that I found on a website but it came with few things installed, and after installing more applications and configuring things now it randomly freeze. I only wanted compile applications for using in LibreElec. If you run ArchLinux, so Armbian can start. They use close kernels (the kernel in ArchLinux is added from Armbian).
ster Posted November 15, 2018 Posted November 15, 2018 @reddward : which usb wifi/bt dongle you got that is working Under armbian ? are the drivers included in kernel compiled ?
Reddwarf Posted November 15, 2018 Posted November 15, 2018 The BT dongle had no spesifiic name, just a cheap one from the "Clas Ohlson" store here in Norway, but it worked right of of the box. WiFi worked with the built-in and the AS8723 driver module from Github.
ster Posted November 17, 2018 Posted November 17, 2018 Another question : i installés Kodi but hdmi cec is not Working , what package is needed for s905?
briand123 Posted November 17, 2018 Posted November 17, 2018 On 11/12/2018 at 1:48 PM, dbsharpe said: Sorry, not familiar with mecool bb2 pro but as a general tip when debugging wifi problems, I found kernel 3.x Armbian builds supported wifi but the 4.x kernels did not work even though a module was loaded. Having got the correct dtb file, I had a poke around in /sys/class/net/wlan0/device/modalias & uevent I compared this to what android had and also made sure the files being used by android /lib/firmware/ and Armbian where correct. So how does one know or figure out the correct dtb file to copy up to /boot/dtb.img ? Is it purely trial and error? I'm using this build: Armbian_5.44_S9xxx_Ubuntu_xenial_3.14.29_mate_20180515.img. I've modprobe xyz about everything i could find under /lib/modules/3.14.29/kernel/drivers/amlogic/wifi but no wlan0 i/f will show up. Some of these KLMs will load and show with lsmod, but no wifi. I'm motivated to make a donation armbian.com to get the wifi working on this box. It's the only 8 core box I know for under $100 so this is a great platform to support.
Reddwarf Posted November 17, 2018 Posted November 17, 2018 I can't get any of the images in 5.67 to boot on Mini M8S or Mini MXIII (S905 cpu), they seem to work fine on my MXQPro+ (S905w cpu), even video plays smoot in fullscreen/full HD. Har anyone tried this images on a S905 cpu?
balbes150 Posted November 17, 2018 Author Posted November 17, 2018 22 minutes ago, briand123 said: So how does one know or figure out the correct dtb file to copy up to /boot/dtb.img ? Is it purely trial and error? I'm using this build: Armbian_5.44_S9xxx_Ubuntu_xenial_3.14.29_mate_20180515.img. I've modprobe xyz about everything i could find under /lib/modules/3.14.29/kernel/drivers/amlogic/wifi but no wlan0 i/f will show up. Some of these KLMs will load and show with lsmod, but no wifi. I'm motivated to make a donation armbian.com to get the wifi working on this box. It's the only 8 core box I know for under $100 so this is a great platform to support.  Kernel 3.14 is no longer developing (not supported), so you will have to try to add the necessary support for WiFi in this version of the kernel or contact the manufacturer (seller) of your equipment. 21 minutes ago, Reddwarf said: Har anyone tried this images on a S905 cpu? S905 = gxbb Check all available DTB of this group.
Reddwarf Posted November 17, 2018 Posted November 17, 2018 Just now, balbes150 said: S905 = gxbb Check all available DTB of this group. I have tried all the gxbb dtb's on previous versions and the only one that works with those mentioned boxes is the p200 dtb.
venioni Posted November 18, 2018 Posted November 18, 2018 Can anyone tell me if these Armbian arm img can working on my mi tv box 3 international version ? I have try many of these rom and not worked.
Reddwarf Posted November 18, 2018 Posted November 18, 2018 Just now, venioni said: Can anyone tell me if these Armbian arm img can working on my mi tv box 3 international version ? I have try many of these rom and not worked. Which dtb did you use? If the box runs Android you can install the CPUZ app and find the board model, it will help you fint the correct dtb to use...
venioni Posted November 18, 2018 Posted November 18, 2018 1 hour ago, Reddwarf said: Which dtb did you use? If the box runs Android you can install the CPUZ app and find the board model, it will help you fint the correct dtb to use... II have tried all dtb and none working, my tv box model is Mi box 3 mdz 16-ab with S905 SoC with quad-core Cortex-A53 CPU .
Reddwarf Posted November 18, 2018 Posted November 18, 2018 Just now, venioni said: II have tried all dtb and none working, my tv box model is Mi box 3 mdz 16-ab with S905 SoC with quad-core Cortex-A53 CPU . Yeah, but if you run cpu-z you should get a board number, ie. my Mini M8S has board number p200, my MXQPro+ has board number 281, and that is what you are looking for.
venioni Posted November 18, 2018 Posted November 18, 2018 53 minutes ago, Reddwarf said: Yeah, but if you run cpu-z you should get a board number, ie. my Mini M8S has board number p200, my MXQPro+ has board number 281, and that is what you are looking for. I runned CPU-Z and dont showing nothing about board number.
balbes150 Posted November 19, 2018 Author Posted November 19, 2018 For Xiaomi https://forum.xda-developers.com/android-stick--console-computers/amlogic/xiaomi-mi-box-3-mdz-16-ab-boot-log-uart-t3702010
Reddwarf Posted November 19, 2018 Posted November 19, 2018 10 hours ago, venioni said: I runned CPU-Z and dont showing nothing about board number. No you'r right, it should have been under Device, board but it only says "once". But balbes150 has linked to a very useful thread
dbsharpe Posted November 19, 2018 Posted November 19, 2018 17 hours ago, venioni said: I runned CPU-Z and dont showing nothing about board number. Don't know if it will be more help but you can also get the hardware info from android adb shell getprop | grep -i build.product or grep -i build.product /system/build.prop Also grep for ro.build.flavor ro.product.name ro.product.device ro.product.board ro.build.product board.platform
