I would like to make myself more familiar with the early linx boot process on ARM (u-boot, device trees and co.) and my idea was that I will start tweaking with something which actually works. I tried to figure out how to obtain the source package for u-boot (in my case for linux-u-boot-orangepi3-lts-current) but the armbian package repository seem to contain obly binaries. Any idea wherethe source packages for this binaries are located (e.g. what deb-src line do I need to add to the armbian.list to make "apt-get source" to work)?
  On 11/18/2022 at 7:35 AM, abody said:
I am actually referring to package sources
Expand
If you check your /etc/apt/sources.list you can see that deb-src repository is not enabled by default. Enable it. Basically just follow instructions on this Debian wiki. We are not changing userland packages - we use Debian packages assembled in our way + additional packages. We don't build vim, but ship Debian package ... Only the critical things are ours: kernel, u-boot, hardware support package, tools for handling hardware, ZSH package, firmware, ... If you want to change ours, except kernel, you need to use build tools as those are n/a in a standard deb-src form.
  Quote
Expand
Yes, and I would like to get the source package of  linux-u-boot-orangepi3-lts-current to see how it is being built.
