Hi folks, I have a Firefly AIO-3399C which boots Armbian fine, but no USB devices besides the root devices are detected. This happens with both the kernel 5.19.170 and 6.0.7 based images, made by @balbes150, which I've downloaded from https://users.armbian.com/balbes150/firefly-rk3399/
Any advice would be appreciated.
U-Boot 2022.04-armbian (Nov 03 2022 - 17:26:20 +0300)
Linux firefly-rk3399 5.19.17-media #trunk SMP PREEMPT Thu Nov 3 17:40:36 MSK 2022 aarch64 aarch64 aarch64 GNU/Linux
In dmesg output, I see the following, which may be relevant:
[    4.616394] hub 7-0:1.0: USB hub found
[   14.296598] fusb30x: module is from the staging directory, the quality is unknown, you have been warned.
[   14.298983] fusb30x: module is from the staging directory, the quality is unknown, you have been warned.
[   14.346438] fusb302 7-0022: Can't get property of role, set role to default DRP
[   14.402787] fusb302 7-0022: Unable to request IRQ for INT_N GPIO! 0
[   14.555053] fusb302: probe of 7-0022 failed with error -22
[   14.568604] fusb302 4-0022: Can't get property of role, set role to default DRP
[   14.574971] fusb302 4-0022: Unable to request IRQ for INT_N GPIO! 0
[   14.576841] fusb302: probe of 4-0022 failed with error -22
[   14.692030] usbcore: registered new interface driver brcmfmac
7 часов назад, MrBIOS сказал:
Firefly AIO-3399C
This device is not included in the list of supported devices. Perhaps other DTBS are needed for it (I do not know which ones)
