Hello all,
I have installed the image "Armbian 23.02.0-trunk.0176 Lunar with bleeding edge Linux 6.1.6-bcm2711" on my two Raspi 4 systems.
One system runs via cable and the other via WLAN. At the beginning there were some problems with the IPv6 - kernel, if "apt update" was executed.
I got this problem under control with "disable ipv6".... Since then, both systems run flawlessly & without problems.
With the implementation of GPIO you should fall back on an existing GPIO - version, which works in any case also under this image; also for 64bit.
One small thing I would like to know very much, because on the system with the cable the WaveShare PoE - HAT is installed and I would like to monitor via software very much the FAN.
Unfortunately, this does not work because the software does not see "I2C". In the Config - File, however, you see this as "enable" -
What can I do here? Does anyone have an idea how I can enablen the I2C so that this works?
Best regards from Germany.....
Z. Matthias
i2c typically requires both config.txt entry and one or two supporting kernel modules to be loaded... When it comes to "daughter boards" and such, generally sticking to mainline / OEM roms is advised for anyone who is not out for a challenge...
