October 22Oct 22 I am using Armbian Imager. If I pre-seed a profile with WiFi credentials (SSID, Password) the Pi Zero 2W cannot connect to the SSID on the access point upon first (or any subsequent) boot. The issue seems to be that when the WiFi credentials are pre-seeded, an "auth:" stanza is not produced in the .yaml netplan configuration file and a connection cannot be made. Running armbian-config and re-configuring the network fixes the problem. Netplan .yaml from pre-seeded information (does not create a connection): network: version: 2 renderer: networkd wifis: wlan0: dhcp4: true dhcp6: true access-points: "WIFI_SSID": password: "WIFI_PASSWORD" Netplan .yaml after running armbian-config (Connection created - works): network: version: 2 renderer: networkd wifis: wlan0: dhcp4: true dhcp6: true access-points: "WIFI_SSID": auth: key-management: "psk" password: "WIFI_PASSWORD" I would have filed a bug report on github, but I was not sure what component of Armbian has the issue. Edited October 22Oct 22 by mihanson
October 23Oct 23 Tnx. It is probably a problem of 1st boot configuration. I am aware this part is not among the best parts of the code and its refactoring or at least haredening is on the 2do list for awhile.
