noob1 Posted April 8, 2023 Share Posted April 8, 2023 I have an Orange Pi Mini 2. As far as i know there is no official/ unofficial armbian build for this. there are other boards like orange pi pc, orange pi 2 and tritium h3 board whose images run fine for this board. I have also made armbian image builds with orange pi pc as target and these images work on opi mini 2. I would like to know how could i make a build exclusively for orange pi mini 2. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 8, 2023 Share Posted April 8, 2023 Try to copy this file and both rename it and adjust naming inside: https://github.com/armbian/build/blob/main/config/boards/orangepipc.conf 0 Quote Link to comment Share on other sites More sharing options...
noob1 Posted April 9, 2023 Author Share Posted April 9, 2023 Thanks a lot Werner. DId you mean that i should make a copy the .conf file, rename the file and also adjust the name inside the file too? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 9, 2023 Share Posted April 9, 2023 Yes, of course. auto-correction got me 0 Quote Link to comment Share on other sites More sharing options...
noob1 Posted April 9, 2023 Author Share Posted April 9, 2023 Thanks Werner for your support. I did make a copy renamed it and changed the name inside too. This image also works okay. one thing i did differently was to use tritium-h3 as base because i felt that it represented the hardware more accurately(please correct me if im wrong) I have a few queries: 1. How can i test that all hardware is working correctly, if not then what should i do to correct them. 2. the build currently takes more than an hour to complete. Is there any way to speed this up? 3. What more i should do so that board could be added to armbian build config. Im willing to put more work into it. Thanks again for so much help. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 10, 2023 Share Posted April 10, 2023 5 hours ago, noob1 said: 1. How can i test that all hardware is working correctly, if not then what should i do to correct them. Use it. There is such thing like self-tests. 5 hours ago, noob1 said: 2. the build currently takes more than an hour to complete. Is there any way to speed this up? Get better CPU. Building a kernel on a potato takes as long as it takes There is a reason why we collected money for something more powerful to speed builds up a while ago: 5 hours ago, noob1 said: 3. What more i should do so that board could be added to armbian build config. Im willing to put more work into it. Create a PR to the build script. https://docs.armbian.com/Process_Contribute/ https://docs.armbian.com/Developer-Guide_Adding-Board-Family/ 0 Quote Link to comment Share on other sites More sharing options...
