Bugg69s Posted November 9, 2016 Posted November 9, 2016 I have problem whit armbian i have orange pi pc plus and is load but last loaded informacion is cpu heat, memory capaciti... What i must press ? Pls help
Drakoh Posted November 9, 2016 Posted November 9, 2016 Hi there. Could you please describe you problem as much as you can? How did you burn the image to the sdcard? Do you have console access to your board? Normally you wouldn't have to press anything. Burn the image to the sdcard, boot from it, log in via SSH. 1
Bugg69s Posted November 9, 2016 Author Posted November 9, 2016 its give the qestion if i need change resolucion i presh yes but i dont now how to make this. get stuck and i turn off and on the orange pi and is normaly booting but is stop on informations ...
Drakoh Posted November 9, 2016 Posted November 9, 2016 So you want to change the display resolution. I'm using Armbian without GUI so I can't help you much, but the H3-based board have a utility called h3disp. From the documentation: # Example to set resolution to 1920 x 1080, full colour-range and DVI h3disp -m 1080p60 -d -c 1
Bugg69s Posted November 10, 2016 Author Posted November 10, 2016 Its say Script must be executed. Exiting 1
gnasch Posted November 10, 2016 Posted November 10, 2016 Maybe you cannot see the whole screen on your monitor or TV. Access your Orange Pi via its IP Address on ethernet. For this try secure shell login from another computer. if Windows user use "putty ssh client" then report *exact* behaviour of patient. Our crystal ball is currently broken ;-) best, gnasch
Bugg69s Posted November 10, 2016 Author Posted November 10, 2016 If i can i try new armbian but my sd card is dont formating it is locked i dont now how i can unformat and burn armbian again.
gnasch Posted November 10, 2016 Posted November 10, 2016 many people have problems with bad SD-Cards. Everything becomes unreliable when using a low quality SD-Card. please see here, and follow this exactly. https://docs.armbian.com/User-Guide_Getting-Started/#how-to-prepare-a-sd-card best, gnasch
Igor Posted November 11, 2016 Posted November 11, 2016 If i can i try new armbian but my sd card is dont formating it is locked i dont now how i can unformat and burn armbian again. You don't need to format a card. Just burn an image with a recommended tool.
Bugg69s Posted November 11, 2016 Author Posted November 11, 2016 My sd card is locked :/ and its not burning. Toot is stack on "starting burning" i have good card sony 8gb class 10
Bugg69s Posted November 11, 2016 Author Posted November 11, 2016 Naw its working but i have cuted of the edges i on boot i dont see [OK] only K]
