Hqnicolas Posted October 27, 2023 Author Share Posted October 27, 2023 (edited) 6 hours ago, rossbcan said: I soldered in SD Card holder. Are you sure about "Detect SD-CARD" success you reported? I don't see it. Tested on 4gb / 32gb Old board version The factory can change layout without warning nobody. This is the bad side of TV boxes, and this is why Linux on this type of devices isn't supported by community Edited October 27, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
rossbcan Posted October 27, 2023 Share Posted October 27, 2023 @hotnikq Can you please share your SD card detection messages. First establish where it is? mmcX? EG: "dmesg | grep mmcX" and "cat /var/log/syslog | grep mmcX" I believe my SD reader is at mmc0 (mmc@fe2b0000) and here's dmesg (syslog same) out: mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0) controller detected, card not. Thanks; Bill 0 Quote Link to comment Share on other sites More sharing options...
Sunil sankar Posted October 28, 2023 Share Posted October 28, 2023 @hzdm the armbian server image doesn't work it doesn't boot . @hotnikq testing it now 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted October 28, 2023 Author Share Posted October 28, 2023 @rossbcan dmesg | grep mmcblk0 Quote [6006502.273177] mmcblk0: mmc0:e624 SU08G 7.40 GiB [6006502.288263] mmcblk0: p1 [6006503.930879] mmcblk0: mmc0:e624 SU08G 7.40 GiB [6006503.945245] mmcblk0: p1 [6006506.054509] mmcblk0: mmc0:e624 SU08G 7.40 GiB [6006506.071547] mmcblk0: p1 [6006506.095914] I/O error, dev mmcblk0, sector 72 op 0x0:(READ) flags 0x80700 phys_seg 6 prio class 2 [6006506.424909] mmcblk0: mmc0:e624 SU08G 7.40 GiB [6006506.432706] mmcblk0: p1 cat /var/log/syslog | grep mmcblk0 Quote Oct 28 13:36:01 station-m2 kernel: [6006502.273177] mmcblk0: mmc0:e624 SU08G 7.40 GiB Oct 28 13:36:01 station-m2 kernel: [6006502.288263] mmcblk0: p1 Oct 28 13:36:01 station-m2 devmon[681]: added: /org/freedesktop/UDisks/devices/mmcblk0 Oct 28 13:36:01 station-m2 devmon[681]: added: /org/freedesktop/UDisks/devices/mmcblk0p1 Oct 28 13:36:01 station-m2 devmon[681]: device: [/dev/mmcblk0p1] Oct 28 13:36:01 station-m2 devmon[681]: devmon: /usr/bin/udevil --mount /dev/mmcblk0p1 --mount-options "nosuid,nodev,noatime" # (armbi_root) Oct 28 13:36:02 station-m2 devmon[681]: udevil: /dev/mmcblk0p1 is known to mount - running mount as current user Oct 28 13:36:02 station-m2 devmon[681]: devmon: error mounting /dev/mmcblk0p1 (32) Oct 28 13:36:02 station-m2 devmon[681]: removed: /org/freedesktop/UDisks/devices/mmcblk0p1 Oct 28 13:36:02 station-m2 devmon[681]: removed: /org/freedesktop/UDisks/devices/mmcblk0 Oct 28 13:36:03 station-m2 kernel: [6006503.930879] mmcblk0: mmc0:e624 SU08G 7.40 GiB Oct 28 13:36:03 station-m2 kernel: [6006503.945245] mmcblk0: p1 Oct 28 13:36:03 station-m2 devmon[681]: added: /org/freedesktop/UDisks/devices/mmcblk0 Oct 28 13:36:03 station-m2 devmon[681]: added: /org/freedesktop/UDisks/devices/mmcblk0p1 Oct 28 13:36:03 station-m2 devmon[681]: removed: /org/freedesktop/UDisks/devices/mmcblk0p1 Oct 28 13:36:03 station-m2 devmon[681]: removed: /org/freedesktop/UDisks/devices/mmcblk0 Oct 28 13:36:05 station-m2 kernel: [6006506.054509] mmcblk0: mmc0:e624 SU08G 7.40 GiB Oct 28 13:36:05 station-m2 kernel: [6006506.071547] mmcblk0: p1 Oct 28 13:36:05 station-m2 kernel: [6006506.095914] I/O error, dev mmcblk0, sector 72 op 0x0:(READ) flags 0x80700 phys_seg 6 prio class 2 Oct 28 13:36:05 station-m2 devmon[681]: added: /org/freedesktop/UDisks/devices/mmcblk0 Oct 28 13:36:05 station-m2 casaos-local-storage[1886]: /usr/sbin/smartctl -a -n standby /dev/mmcblk0 -j Oct 28 13:36:05 station-m2 casaos-local-storage[1886]: "/dev/mmcblk0", Oct 28 13:36:05 station-m2 casaos-local-storage[1886]: "string": "/dev/mmcblk0: Unable to detect device type", Oct 28 13:36:05 station-m2 devmon[681]: added: /org/freedesktop/UDisks/devices/mmcblk0p1 Oct 28 13:36:05 station-m2 devmon[681]: removed: /org/freedesktop/UDisks/devices/mmcblk0p1 Oct 28 13:36:05 station-m2 devmon[681]: removed: /org/freedesktop/UDisks/devices/mmcblk0 Oct 28 13:36:05 station-m2 kernel: [6006506.424909] mmcblk0: mmc0:e624 SU08G 7.40 GiB Oct 28 13:36:05 station-m2 kernel: [6006506.432706] mmcblk0: p1 Oct 28 13:36:05 station-m2 devmon[681]: added: /org/freedesktop/UDisks/devices/mmcblk0 Oct 28 13:36:05 station-m2 devmon[681]: added: /org/freedesktop/UDisks/devices/mmcblk0p1 Oct 28 13:36:05 station-m2 devmon[681]: device: [/dev/mmcblk0p1] Oct 28 13:36:05 station-m2 devmon[681]: devmon: /usr/bin/udevil --mount /dev/mmcblk0p1 --mount-options "nosuid,nodev,noatime" # (armbi_root) Oct 28 13:36:06 station-m2 devmon[681]: udevil: /dev/mmcblk0p1 is known to mount - running mount as current user Oct 28 13:36:06 station-m2 devmon[681]: devmon: error mounting /dev/mmcblk0p1 (32) armbianmonitor -u Result before SDcard insert: https://paste.armbian.com/qixunuqehi Quote LINE: 206 Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd mmcblk1 1,17 1,25 9,76 6,32 7503519 58613937 37952260 mmcblk1p1 0,00 0,00 0,00 0,00 216 0 0 mmcblk1p2 0,00 0,00 0,00 0,00 216 0 0 mmcblk1p3 0,00 0,00 0,00 0,00 216 0 0 mmcblk1p4 1,17 1,25 9,76 6,32 7501079 58613937 37952260 mmcblk1boot0 0,00 0,00 0,00 0,00 120 0 0 mmcblk1boot1 0,00 0,00 0,00 0,00 120 0 0 zram0 0,26 0,40 0,65 0,00 2431644 3888720 0 zram1 0,25 0,01 1,25 0,00 80668 7522996 0 zram2 0,00 0,00 0,00 0,00 0 0 0 After Connect by insert SDcard: https://paste.armbian.com/rucaleyigi Quote Line 206: Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd mmcblk1 1,17 1,27 9,76 6,32 7643011 58614277 37952260 mmcblk1p1 0,00 0,00 0,00 0,00 216 0 0 mmcblk1p2 0,00 0,00 0,00 0,00 216 0 0 mmcblk1p3 0,00 0,00 0,00 0,00 216 0 0 mmcblk1p4 1,17 1,27 9,76 6,32 7640571 58614277 37952260 mmcblk1boot0 0,00 0,00 0,00 0,00 120 0 0 mmcblk1boot1 0,00 0,00 0,00 0,00 120 0 0 zram0 0,26 0,41 0,65 0,00 2432728 3888720 0 zram1 0,25 0,01 1,25 0,00 80668 7523260 0 zram2 0,00 0,00 0,00 0,00 0 0 0 mmcblk0 0,00 0,00 0,00 0,00 5490 0 0 mmcblk0p1 0,00 0,00 0,00 0,00 3290 0 0 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted October 28, 2023 Author Share Posted October 28, 2023 (edited) 7 hours ago, Sunil sankar said: testing it now i will test the 4gb version too Please report your 8gb device by: armbianmonitor -u due to the high demand for 8gb devices I bought a unit to test the images here too, I'm going to put in a 1tb SSD with a sata adapter and create a bitcoin lightning node 1R$ = 0,20U$ 5R$ = 1U$ 54,12U$ = 271,37R$ with taxes 51,11U$ = 256,28R$ with taxes Edited October 28, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Sunil sankar Posted November 1, 2023 Share Posted November 1, 2023 @hotnikq how do I use the update.img in rktools 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 2, 2023 Author Share Posted November 2, 2023 (edited) On 11/1/2023 at 8:30 AM, Sunil sankar said: [mention=204918]hotnikq[/mention] how do I use the update.img in rktools Don't use it, I'm trying to rebuild it wait a week or two... Edited November 2, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
JarekH Posted November 2, 2023 Share Posted November 2, 2023 H96 max v56 8/64GB Custom Google store etc.....???? Really?? Jesus 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted November 2, 2023 Share Posted November 2, 2023 48 minutes ago, JarekH said: Custom Google store etc.....???? Really?? Buy crap, receive crap 🤷♂️ 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 2, 2023 Author Share Posted November 2, 2023 2 hours ago, JarekH said: Custom Google store etc.....???? 0 Quote Link to comment Share on other sites More sharing options...
Sunil sankar Posted November 2, 2023 Share Posted November 2, 2023 Yes they are infected but they are awesome for armbian thanks to @hotnikq and @hzdm . I got a good deal 43 euros equal to orangepi3 . I have got 2 more boxes going to setup k3s . Regards sunil 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 2, 2023 Author Share Posted November 2, 2023 (edited) On 10/28/2023 at 6:30 AM, Sunil sankar said: @hzdm the armbian server image doesn't work it doesn't boot . @hzdm Dear friend, Your MOD on USB2.0 doesnt boot with SERVER version of armbian!!!! for server images Please use the OLD DTB file without USB2.0 it solves the boot problem on Server images!!! @Sunil sankar i'm building updated versions from the SD-card images based on v0.5 All that you need to compile armbian: https://drive.google.com/file/d/1G5KBVq1oR-QrIKG3FoHmUTwh8OSAG018/view?usp=sharing H96MAX_DTB_DTS_WIFI_NOVEMBER_2023.zip Edited November 2, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Sunil sankar Posted November 2, 2023 Share Posted November 2, 2023 @hotnikq awesome will testit.Can you pls suggest how I can compile one with debian since I will later convert this to dietpi since it will make this cheap box super fast. May be a noob guide sorry to keep bothering with questions. 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 2, 2023 Author Share Posted November 2, 2023 23 minutes ago, Sunil sankar said: how I can compile one with debian On 6/15/2023 at 11:18 PM, hotnikq said: if you wanna do all that creepy again with other devices and images, (please do it on other devices) and topic this is all you need to create this image, first step: Compile armbian on linux desktop dont forgot to do it with modified DTS file: Select "CUSTOM KERNEL OPTION" When the wizard stop and ask for kernel modification: Drop DTS + DTB files on /build/cache/sources/linux-kernel-worktree/6.2__media__arm64/arch/arm64/boot/dts/rockchip and exit Kernel modification wizard from armbian compiler !!!!!!!NOW YOU HAVE AN SD CARD v0.5 image!!!!! 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 2, 2023 Author Share Posted November 2, 2023 (edited) 28 minutes ago, Sunil sankar said: Can you pls suggest how I can compile one with debian Take your debian SD card image and: On 6/15/2023 at 11:18 PM, hotnikq said: any resemblance to this topic is mere adaptation Mount that image virtual device like /media/armbian_boot fdisk -l your-armbian-image-for-sd-card.img mount -o loop your-armbian-image-for-sd-card.img /media/armbian_boot if you can't "like WSL2" sudo apt-get install kpartx sudo kpartx -av your-armbian-image-for-sd-card.img sudo mount -o loop /dev/mapper/loop0p1 /media/armbian_boot Second Step: prepare an sd card or usb flash dummy , can be anithing with 6gb fdisk /dev/mmcblk1 N default default (lower this value to match the size of your root image) T 1 W third step: format that flash drive for ext4 mkfs.ext4 /dev/mmcblk1p1 fourth step: mount that clear partition and copy the entire virtual drive to the flash device mount /dev/mmcblk1p1 /mnt/ rsync -avx /media/armbian_boot/ /mnt/ fifth Step: Edit your uuid From Armbian Boot config "uuid for /dev/mmcblk1p1" blkid nano -w /mnt/boot/extlinux/extlinux.conf sync umount /mnt sixth step: make an hardware RAW.img from hardware flash drive with these parameters sudo dd if=/dev/mmcblk1p1 of=~/root.img bs=4096 status=progress PS: can be /dev/SDA" I do it on my h96max" so it's mmcblk1 now you have an ROOT v0.7 IMAGE MADE BY YOURSELF! Edited November 2, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 2, 2023 Author Share Posted November 2, 2023 (edited) On 11/2/2023 at 4:27 PM, Sunil sankar said: how I can compile one with debian Combine a ROOT image with an UPDATE image and BOOM = v0.7 build firmware i will finish this step in a week or two.... if you have an 8gb device, use the @hzdm method UPDATE: H96 MAX V56 RK3566 4gb and 8gb Ram SD-Card images: Release Version v0.5DEBIAN12 BETA Release Version v0.5ARMBIAN23 BETA UPDATE: H96 MAX V56 RK3566 4gb and 8gb EMMC images: Release Version V0.7DEBIAN12 BETA Release Version V0.7ARMBIAN23 BETA Edited November 4, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 3, 2023 Author Share Posted November 3, 2023 (edited) On 10/7/2023 at 7:27 AM, hzdm said: rkdeveloptool wl 0x0 start.img @hzdm i create an Server image Based on your instructions. but my device is an 4gb 32gb device how can you change the GPT LBA from this files? there is a source of this start.img file? the initial error: Trying to boot from MMC1 GPT: last_usable_lba incorrect: X > 747bfde part_get_info_efi: *** ERROR: Invalid GPT *** part_get_info_efi: *** Using Backup GPT *** on device to repair the initial error, when "sudo gdisk /dev/mmcblk1:" it reveals the GPT partition is 57gb Disk /dev/mmcblk1: 61071360 sectors, 29.1 GiB Sector size (logical/physical): 512/512 bytes Disk identifier (GUID): EC944974-E823-4B58-AEB7-A94651D008F8 Partition table holds up to 128 entries Main partition table begins at sector 2 and ends at sector 33 First usable sector is 34, last usable sector is 122142686 Partitions will be aligned on 2048-sector boundaries Total free space is 61407 sectors (30.0 MiB) Number Start (sector) End (sector) Size Code Name 1 61440 2158590 1024.0 MiB FFFF bootfs 2 2158592 122142686 57.2 GiB FFFF rootfs Command (? for help): i 2 Partition number (1-2): 2 Partition GUID code: 1124E418-9008-41F8-9E3D-8D872216C8A1 (Unknown) Partition unique GUID: 67AD7741-4638-47C6-A488-D396583E582A First sector: 2158592 (at 1.0 GiB) Last sector: 122142686 (at 58.2 GiB) Partition size: 119984095 sectors (57.2 GiB) Attribute flags: 0000000000000000 Partition name: 'rootfs' Command (? for help): i Partition number (1-2): 1 Partition GUID code: 8DCD1602-5214-43F9-FFEF-C49A4EE450B7 (Unknown) Partition unique GUID: 5A30833F-8C43-47B1-A41D-84D40883D0C6 First sector: 61440 (at 30.0 MiB) Last sector: 2158590 (at 1.0 GiB) Partition size: 2097151 sectors (1024.0 MiB) Attribute flags: 0000000000000000 Partition name: 'bootfs' How i fix this initial problem: boot from SD card..... and: root@station-m2:~# sudo gdisk /dev/mmcblk1 GPT fdisk (gdisk) version 1.0.8 Partition table scan: MBR: protective BSD: not present APM: not present GPT: present Found valid GPT with protective MBR; using GPT. Command (? for help): p Disk /dev/mmcblk1: 61071360 sectors, 29.1 GiB Sector size (logical/physical): 512/512 bytes Disk identifier (GUID): EC944974-E823-4B58-AEB7-A94651D008F8 Partition table holds up to 128 entries Main partition table begins at sector 2 and ends at sector 33 First usable sector is 34, last usable sector is 61071326 Partitions will be aligned on 2048-sector boundaries Total free space is 58974142 sectors (28.1 GiB) Number Start (sector) End (sector) Size Code Name 1 61440 2158590 1024.0 MiB FFFF bootfs Command (? for help): n Partition number (2-128, default 2): First sector (34-61071326, default = 2158592) or {+-}size{KMGTP}: Last sector (2158592-61071326, default = 61071326) or {+-}size{KMGTP}: Current type is 8300 (Linux filesystem) Hex code or GUID (L to show codes, Enter = 8300): 1124E418-9008-41F8-9E3D-8D872216C8A1 Changed type of partition to 'Unknown' Command (? for help): x Expert command (? for help): c Partition number (1-2): 2 Enter the partition's new unique GUID ('R' to randomize): 67AD7741-4638-47C6-A488-D396583E582A New GUID is 67AD7741-4638-47C6-A488-D396583E582A Expert command (? for help): w Final checks complete. About to write GPT data. THIS WILL OVERWRITE EXISTING PARTITIONS!! Do you want to proceed? (Y/N): y After solution: root@station-m2:~# sudo gdisk /dev/mmcblk1 GPT fdisk (gdisk) version 1.0.8 Partition table scan: MBR: protective BSD: not present APM: not present GPT: present Found valid GPT with protective MBR; using GPT. Command (? for help): p Disk /dev/mmcblk1: 61071360 sectors, 29.1 GiB Sector size (logical/physical): 512/512 bytes Disk identifier (GUID): EC944974-E823-4B58-AEB7-A94651D008F8 Partition table holds up to 128 entries Main partition table begins at sector 2 and ends at sector 33 First usable sector is 34, last usable sector is 61071326 Partitions will be aligned on 2048-sector boundaries Total free space is 61407 sectors (30.0 MiB) Number Start (sector) End (sector) Size Code Name 1 61440 2158590 1024.0 MiB FFFF bootfs 2 2158592 61071326 28.1 GiB FFFF Unknown I will try soon: https://opensource.rock-chips.com/wiki_Partitions it works! to flash your method over 4gb 32gb devices Just flash the gpt.img inside the start.img located on 0x00000000 GPT 4gb to use in 8gb HZDM images gpt.img Edited November 3, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 5, 2023 Author Share Posted November 5, 2023 @hzdm The result from your post ThankYou! Keep Pushing on Arm Devices! 0 Quote Link to comment Share on other sites More sharing options...
hzdm Posted November 5, 2023 Share Posted November 5, 2023 (edited) I've been busy lately. Strange that the Armbian Server image didn't work. I tested it on my device. USB 2.0 worked. I did it in a hurry. I'll see what's wrong with it soon. Edited November 5, 2023 by hzdm 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 7, 2023 Author Share Posted November 7, 2023 (edited) Next Step to the H96 MAX v56: Using Rockchip SoCs NPU. Drivers: https://github.com/rockchip-linux/rknpu2 User Guide: https://github.com/rockchip-linux/rknpu2/blob/master/doc/Rockchip_RKNPU_User_Guide_RKNN_API_V1.4.0_EN.pdf OpenCV: https://opencv.org/blog/2022/11/29/working-with-neural-processing-units-npus-using-opencv/ A discussion on Reddit: https://www.reddit.com/r/OrangePI/comments/12b3jmj/accessing_the_npu_on_the_orange_pi/ Transformers models: https://github.com/usefulsensors/useful-transformers Usage: https://www.crowdsupply.com/useful-sensors/ai-in-a-box/ Usage: https://youtu.be/pN8mKZ5wpdQ Edited November 7, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
MeJune Posted November 8, 2023 Share Posted November 8, 2023 (edited) @hotnikq Is it possible to display a digital clock on the box? (like android mode) Thank you. Edited November 8, 2023 by MeJune 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 8, 2023 Author Share Posted November 8, 2023 (edited) 16 hours ago, MeJune said: Is it possible to display a digital clock on the box? (like android mode) On 10/8/2023 at 11:38 AM, hotnikq said: if you want this extra features, it can be solved by editing the DTB file mipi DSi, display 7seg and infrared controller, all can be translated from android DTB to Linux DTB. in my case it can be found on /boot/dtb/rockchip/rk3566-firefly-roc-pc.dtb and the setup are made by the /boot/extlinux/extlinux.conf an example how to manipulate this files Feel free to share to the community your experiences with 7seg GPIO on H96 MAX. it can be used to other things like digital output to automation! Edited November 8, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Sunil sankar Posted November 9, 2023 Share Posted November 9, 2023 @hotnikq the new images don't work .They are not getting flashed to the box. The one 0.7 beta from @hzdm works 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 9, 2023 Author Share Posted November 9, 2023 33 minutes ago, Sunil sankar said: the new images don't work . Thank you for the feedback. This is board difference, factory change components without documentation. The new images work here, but the @hzdm don't 0 Quote Link to comment Share on other sites More sharing options...
blust0ne Posted November 13, 2023 Share Posted November 13, 2023 On 10/7/2023 at 7:27 PM, hzdm said: 2. The /boot directory was moved to a separate bootfs partition. Please tell me the process of making bootfs.img in more detail. 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 13, 2023 Author Share Posted November 13, 2023 (edited) 8 hours ago, blust0ne said: Please tell me the process of making bootfs.img in more detail. @blust0ne don't use my images for safety reasons, Please to sensitive content, compile your own SD-card image from the armbian repo. if you have any doubts about the image creation process please ask. Like I said, create 2 partitions on your drive, On 10/24/2023 at 9:28 AM, hotnikq said: based on @hzdm method i will make this image using Distro Boot with Boot.scr https://wiki.trenz-electronic.de/display/PD/Distro+Boot+with+Boot.scr mount the H96MAX update.img Files that will help 1. MiniLoaderAll.bin and U-boot are taken from Armbian image from Orange Pi 3B board. 2. The /boot directory was moved to a separate bootfs partition. 3. Rename file /boot/extlinux/extlinux.conf in extlinux.conf.bak 4. In /boot directory boot.cmd and boot.scr files were created with the following contents sudo apt-get update sudo apt install u-boot-tools setenv docker_optimizations "on" setenv bootlogo "false" echo "Boot script loaded from ${devtype} ${devnum}" if test "${docker_optimizations}" = "on"; then setenv bootargs "${bootargs} cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1"; fi if test "${bootlogo}" = "true"; then setenv consoleargs "splash plymouth.ignore-serial-consoles ${consoleargs}" else setenv consoleargs "splash=verbose ${consoleargs}" fi part uuid mmc 1:2 partuuid setenv bootargs androidboot.console=ttyFIQ0 root=PARTUUID=${partuuid} rootwait rw rootfstype=ext4 ${consoleargs} no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash p> load mmc 1:1 0x42000000 Image load mmc 1:1 0x44000000 dtb/rockchip/rk3566-firefly-roc-pc.dtb load mmc 1:1 0x46000000 uInitrd booti 0x42000000 0x46000000 0x44000000 # Recompile with: # mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr fdisk /dev/mmcblk1 N default default (lower this value to match the size of your root image) T 1 W drop the content of your Armbian v0.5 SD card on it, (same as v0.7 tutorial) in the first partition, drop the boot folder content to the root of the drive. Drop on rootfs.img just the files from root of SD image (files without folder), Drop the 2 files that you create and compile it from @hzdm tutorial. And create a image with DD like the v0.7 tutorial. That's your rootfs.img sudo dd if=/dev/mmcblk1p1 of=~/root.img bs=4096 status=progress Edited November 13, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 16, 2023 Author Share Posted November 16, 2023 (edited) On 10/28/2023 at 1:46 PM, hotnikq said: due to the high demand for 8gb devices I bought a unit to test the images here too, I'm going to put in a 1tb SSD with a sata adapter and create a bitcoin lightning node @Sunil sankar @Kenneth Hidalgo @wootje @beiqidai @maka @SteeMan @paradigman The 8gb device arrived! Since my images was build on 4gb device. it doesnt works more than a single boot on 8gb device. 😅 on installation, armbian expands the EFI disk to a Linux disk. So, today i have generated a fix to v1.0 images work on 8gb devices. First Boot Comand: fdisk /dev/mmcblk1 t 4 1 w What you will see on screen if you do the First Boot Comand: fdisk Welcome to fdisk (util-linux 2.37.2). Changes will remain in memory only, until you decide to write them. Be careful before using the write command. This disk is currently in use - repartitioning is probably a bad idea. It's recommended to umount all file systems, and swapoff all swap partitions on this disk. Command (m for help): t Partition number (1-4, default 4): 4 Partition type or alias (type L to list all): 1 Changed type of partition 'Linux filesystem' to 'EFI System'. Command (m for help): w The partition table has been altered. Syncing disks. Now if you reboot the 8gb device, it will find the linux partition without problem. Edited November 16, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
hzdm Posted November 17, 2023 Share Posted November 17, 2023 (edited) Hey, everybody! I haven't replied in a while because I've been moving from one house to another. Now I have some free time and I have prepared an automatic Armbian build. You won't have to do any more extra steps with the image. You need to copy the files to the build directory with the git armbian repo ( Build Armbian ) 1. Copy the h96-max-v56 directory to build/packages/blobs/ directory 2. Copy the h96-max-v56.conf file to the build/config/boards/ directory 3. Run the image build From server ./compile.sh build BOARD=h96-max-v56 BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=jammy From Desktop cinnamon ./compile.sh build BOARD=h96-max-v56 BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=jammy DESKTOP_APPGROUPS_SELECTED='3dsupport browsers desktop_tools email multimedia internet office' DESKTOP_ENVIRONMENT=cinnamon DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base xfce ./compile.sh build BOARD=h96-max-v56 BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED='3dsupport browsers desktop_tools email multimedia internet office' DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=no RELEASE=jammy https://drive.google.com/file/d/1oYK4EhbfcThfBs3F1Ri582jf6PYYp5x2/view?usp=drive_link How to install this Armbian: On Windows OS: 1. Download, unzip and install the software: RKDevTool_Release_v3.15_and_DriverAssitant_v5.12 https://drive.google.com/file/d/14HWcHYHDrgUBFWholrDCKUWDPHw1r4F1/view?usp=drive_link 2. Run RKDevTool. Right-click in the partition list window (1). Select "Load Config". Open armbian.cfg file (2) https://drive.google.com/file/d/1MhmUJ8DaikZzwjBliY-PrOrvSrcBPwSA/view?usp=drive_link 4. Shutting down H96 MAX. Press the Reset button. Turn on the H96 MAX. The message "Found One MASKROM Device" or "Found One LOADER Device" should appear. (1) Mark all 2 sections with check marks (2) Open 2 files for each section (3) Check "Write by Address" (4). Press the "Run" button (5). The download will start. When the message "Download image OK" appears, the download is finished (6). H96 MAX will automatically reboot. Done. On Linux OS rkdeveloptool db MiniLoaderAll.bin # If this is not your first time flashing with this firmware, an error may appear here\. It\'s not a big deal rkdeveloptool wl 0x0 Armbian_23.11.0-trunk_H96-max-v56_jammy_current_6.1.62.img rkdeveloptool rd PS: This image is functionally the same as the previous ones. It is still the same Station M2 image, only it already has all the past improvements built in and is easier to install! Edited November 17, 2023 by hzdm 0 Quote Link to comment Share on other sites More sharing options...
hzdm Posted November 17, 2023 Share Posted November 17, 2023 (edited) I have collected several images using this methodology. On my 8Gb RAM - 60Gb console everything started. Check if you have other consoles. Maybe these images will work for all H96-max-v56 modifications. Server Standard - Armbian_23.11.0-trunk_H96-max-v56_jammy_current_6.1.62.zip https://drive.google.com/file/d/19jFhGDuej2k7XkAqkh7Cuz3AhWRG8C0D/view?usp=drive_link (./compile.sh build BOARD=h96-max-v56 BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=jammy) Server Minimal - Armbian_23.11.0-trunk_H96-max-v56_jammy_current_6.1.62_minimal.zip https://drive.google.com/file/d/1c0UajTtfiZ1dAcT2f4tHdxZf6sYd2r9m/view?usp=drive_link (./compile.sh build BOARD=h96-max-v56 BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=jammy) Desktop Cinnamon - Armbian_23.11.0-trunk_H96-max-v56_jammy_current_6.1.62_cinnamon_desktop.zip https://drive.google.com/file/d/1CFdI3YhHNPCXUbyXPXTdlaPZMAsrg9lv/view?usp=drive_link (./compile.sh build BOARD=h96-max-v56 BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=jammy DESKTOP_APPGROUPS_SELECTED='3dsupport browsers desktop_tools email multimedia internet office' DESKTOP_ENVIRONMENT=cinnamon DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base) Desktop XFCE - Armbian_23.11.0-trunk_H96-max-v56_jammy_current_6.1.62_xfce_desktop.zip https://drive.google.com/file/d/1yfnWlUcot578PJ2fU8khfj7TBC1kU6GU/view?usp=drive_link (./compile.sh build BOARD=h96-max-v56 BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED='3dsupport browsers desktop_tools email multimedia internet office' DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=no RELEASE=jammy) This image is functionally the same as the previous ones. It is still the same Station M2 image, only it already has all the past improvements built in and is easier to install! Edited November 18, 2023 by hzdm 0 Quote Link to comment Share on other sites More sharing options...
hzdm Posted November 17, 2023 Share Posted November 17, 2023 Eventually I plan to add H96-max-v56 to the official Armbian repository. What else doesn't work in our images? What could be made better in them? 1. VFD display. 2. Temperature is not displayed in htop. 1 Quote Link to comment Share on other sites More sharing options...
