6 hours ago, rossbcan said:
I soldered in SD Card holder. Are you sure about "Detect SD-CARD" success you reported? I don't see it.
Tested on 4gb / 32gb
Old board version
The factory can change layout without warning nobody. This is the bad side of TV boxes, and this is why Linux on this type of devices isn't supported by community
Edited by hotnikq
@hotnikq
Can you please share your SD card detection messages. First establish where it is? mmcX?
EG: "dmesg | grep mmcX" and "cat /var/log/syslog | grep mmcX"
I believe my SD reader is at mmc0 (mmc@fe2b0000) and here's dmesg (syslog same) out:
mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
controller detected, card not.
Thanks; Bill
@rossbcan
 dmesg | grep mmcblk0
[6006502.273177] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[6006502.288263]  mmcblk0: p1
[6006503.930879] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[6006503.945245]  mmcblk0: p1
[6006506.054509] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[6006506.071547]  mmcblk0: p1
[6006506.095914] I/O error, dev mmcblk0, sector 72 op 0x0:(READ) flags 0x80700 phys_seg 6 prio class 2
[6006506.424909] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[6006506.432706]  mmcblk0: p1
cat /var/log/syslog | grep mmcblk0
Oct 28 13:36:01 station-m2 kernel: [6006502.273177] mmcblk0: mmc0:e624 SU08G 7.40 GiB
Oct 28 13:36:01 station-m2 kernel: [6006502.288263]  mmcblk0: p1
Oct 28 13:36:01 station-m2 devmon[681]: added:     /org/freedesktop/UDisks/devices/mmcblk0
Oct 28 13:36:01 station-m2 devmon[681]: added:     /org/freedesktop/UDisks/devices/mmcblk0p1
Oct 28 13:36:01 station-m2 devmon[681]: device: [/dev/mmcblk0p1]
Oct 28 13:36:01 station-m2 devmon[681]: devmon: /usr/bin/udevil --mount /dev/mmcblk0p1 --mount-options "nosuid,nodev,noatime"    # (armbi_root)
Oct 28 13:36:02 station-m2 devmon[681]: udevil: /dev/mmcblk0p1 is known to mount - running mount as current user
Oct 28 13:36:02 station-m2 devmon[681]: devmon: error mounting /dev/mmcblk0p1 (32)
Oct 28 13:36:02 station-m2 devmon[681]: removed:   /org/freedesktop/UDisks/devices/mmcblk0p1
Oct 28 13:36:03 station-m2 kernel: [6006503.930879] mmcblk0: mmc0:e624 SU08G 7.40 GiB
Oct 28 13:36:03 station-m2 kernel: [6006503.945245]  mmcblk0: p1
Oct 28 13:36:03 station-m2 devmon[681]: added:     /org/freedesktop/UDisks/devices/mmcblk0
Oct 28 13:36:03 station-m2 devmon[681]: added:     /org/freedesktop/UDisks/devices/mmcblk0p1
Oct 28 13:36:03 station-m2 devmon[681]: removed:   /org/freedesktop/UDisks/devices/mmcblk0p1
Oct 28 13:36:05 station-m2 kernel: [6006506.054509] mmcblk0: mmc0:e624 SU08G 7.40 GiB
Oct 28 13:36:05 station-m2 kernel: [6006506.071547]  mmcblk0: p1
Oct 28 13:36:05 station-m2 kernel: [6006506.095914] I/O error, dev mmcblk0, sector 72 op 0x0:(READ) flags 0x80700 phys_seg 6 prio class 2
Oct 28 13:36:05 station-m2 devmon[681]: added:     /org/freedesktop/UDisks/devices/mmcblk0
Oct 28 13:36:05 station-m2 casaos-local-storage[1886]: /usr/sbin/smartctl -a -n standby /dev/mmcblk0 -j
Oct 28 13:36:05 station-m2 casaos-local-storage[1886]:       "/dev/mmcblk0",
Oct 28 13:36:05 station-m2 casaos-local-storage[1886]:         "string": "/dev/mmcblk0: Unable to detect device type",
Oct 28 13:36:05 station-m2 devmon[681]: added:     /org/freedesktop/UDisks/devices/mmcblk0p1
Oct 28 13:36:05 station-m2 devmon[681]: removed:   /org/freedesktop/UDisks/devices/mmcblk0p1
Oct 28 13:36:05 station-m2 kernel: [6006506.424909] mmcblk0: mmc0:e624 SU08G 7.40 GiB
Oct 28 13:36:05 station-m2 kernel: [6006506.432706]  mmcblk0: p1
Oct 28 13:36:05 station-m2 devmon[681]: device: [/dev/mmcblk0p1]
Oct 28 13:36:05 station-m2 devmon[681]: devmon: /usr/bin/udevil --mount /dev/mmcblk0p1 --mount-options "nosuid,nodev,noatime"    # (armbi_root)
Oct 28 13:36:06 station-m2 devmon[681]: udevil: /dev/mmcblk0p1 is known to mount - running mount as current user
Oct 28 13:36:06 station-m2 devmon[681]: devmon: error mounting /dev/mmcblk0p1 (32)
armbianmonitor -u
Result before SDcard insert:
https://paste.armbian.com/qixunuqehi
LINE: 206
Device             tps    kB_read/s    kB_wrtn/s    kB_dscd/s    kB_read    kB_wrtn    kB_dscd
mmcblk1           1,17         1,25         9,76         6,32    7503519   58613937   37952260
mmcblk1p1         0,00         0,00         0,00         0,00        216          0          0
mmcblk1p2         0,00         0,00         0,00         0,00        216          0          0
mmcblk1p3         0,00         0,00         0,00         0,00        216          0          0
mmcblk1p4         1,17         1,25         9,76         6,32    7501079   58613937   37952260
mmcblk1boot0      0,00         0,00         0,00         0,00        120          0          0
mmcblk1boot1      0,00         0,00         0,00         0,00        120          0          0
zram0             0,26         0,40         0,65         0,00    2431644    3888720          0
zram1             0,25         0,01         1,25         0,00      80668    7522996          0
zram2             0,00         0,00         0,00         0,00          0          0          0
After Connect by insert SDcard:
https://paste.armbian.com/rucaleyigi
Line 206:
mmcblk1           1,17         1,27         9,76         6,32    7643011   58614277   37952260
mmcblk1p4         1,17         1,27         9,76         6,32    7640571   58614277   37952260
zram0             0,26         0,41         0,65         0,00    2432728    3888720          0
zram1             0,25         0,01         1,25         0,00      80668    7523260          0
mmcblk0           0,00         0,00         0,00         0,00       5490          0          0
mmcblk0p1         0,00         0,00         0,00         0,00       3290          0          0
7 hours ago, Sunil sankar said:
testing it now
i will test the 4gb version too
Please report your 8gb device by:
armbianmonitor -u
due to the high demand for 8gb devices
I bought a unit to test the images here too,
I'm going to put in a 1tb SSD with a sata adapter
and create a bitcoin lightning node
1R$ = 0,20U$
5R$ = 1U$
54,12U$ = 271,37R$ with taxes
51,11U$ = 256,28R$ with taxes
Edited by hotnikq
On 11/1/2023 at 8:30 AM, Sunil sankar said:
[mention=204918]hotnikq[/mention] how do I use the update.img in rktools
Don't use it, I'm trying to rebuild it wait a week or two...
Edited by hotnikq
48 minutes ago, JarekH said:
Custom Google store etc.....???? Really??
Buy crap, receive crap 🤷‍♂️
On 10/28/2023 at 6:30 AM, Sunil sankar said:
@hzdm the armbian server image doesn't work it doesn't boot .
@hzdm Dear friend, Your MOD on USB2.0 doesnt boot with SERVER version of armbian!!!!
for server images Please use the OLD DTB file without USB2.0
it solves the boot problem on Server images!!!
@Sunil sankar i'm building updated versions from the SD-card images based on v0.5
All that you need to compile armbian:
https://drive.google.com/file/d/1G5KBVq1oR-QrIKG3FoHmUTwh8OSAG018/view?usp=sharing
H96MAX_DTB_DTS_WIFI_NOVEMBER_2023.zip
Edited by hotnikq
23 minutes ago, Sunil sankar said:
how I can compile one with debian
On 6/15/2023 at 11:18 PM, hotnikq said:
if you wanna do all that creepy again with other devices and images, (please do it on other devices) and topic
this is all you need to create this image,
first step:
Compile armbian on linux desktop
dont forgot to do it with modified DTS file:
Select "CUSTOM KERNEL OPTION"
When the wizard stop and ask for kernel modification:
Drop DTS + DTB files on /build/cache/sources/linux-kernel-worktree/6.2__media__arm64/arch/arm64/boot/dts/rockchip
and exit Kernel modification wizard from armbian compiler
!!!!!!!NOW YOU HAVE AN SD CARD v0.5 image!!!!!
28 minutes ago, Sunil sankar said:
Can you pls suggest how I can compile one with debian
Take your debian SD card image and:
any resemblance to this topic is mere adaptation
Mount that image virtual device like /media/armbian_boot
fdisk -l your-armbian-image-for-sd-card.img
mount -o loop your-armbian-image-for-sd-card.img /media/armbian_boot
if you can't "like WSL2"
sudo apt-get install kpartx
sudo kpartx -av your-armbian-image-for-sd-card.img
sudo mount -o loop /dev/mapper/loop0p1 /media/armbian_boot
Second Step:  prepare an sd card or usb flash dummy , can be anithing with 6gb
fdisk /dev/mmcblk1
N
default
default (lower this value to match the size of your root image)
T
1
W
third step: format that flash drive for ext4
mkfs.ext4 /dev/mmcblk1p1
fourth step: mount that clear partition and copy the entire virtual drive to the flash device
mount /dev/mmcblk1p1 /mnt/
rsync -avx /media/armbian_boot/ /mnt/
fifth Step: Edit your uuid From Armbian Boot config "uuid for /dev/mmcblk1p1"
blkid
nano -w /mnt/boot/extlinux/extlinux.conf
sync
umount /mnt
sixth step: make an hardware RAW.img from hardware flash drive with these parameters
sudo dd if=/dev/mmcblk1p1 of=~/root.img bs=4096 status=progress
PS: can be /dev/SDA" I do it on my h96max" so it's mmcblk1
now you have an ROOT v0.7 IMAGE MADE BY YOURSELF!
Edited by hotnikq
Combine a ROOT image with an UPDATE image and BOOM = v0.7 build firmware
i will finish this step in a week or two....
if you have an 8gb device, use the @hzdm method
UPDATE:
H96 MAX V56 RK3566 4gb and 8gb Ram SD-Card images:
Release Version v0.5DEBIAN12 BETA
Release Version v0.5ARMBIAN23 BETA
UPDATE:
H96 MAX V56 RK3566 4gb and 8gb EMMC images:
Release Version V0.7DEBIAN12 BETA
Release Version V0.7ARMBIAN23 BETA
Edited by hotnikq
On 10/7/2023 at 7:27 AM, hzdm said:
rkdeveloptool wl 0x0 start.img
@hzdm i create an Server image Based on your instructions.
but my device is an 4gb 32gb device
how can you change the GPT LBA from this files?
there is a source of this start.img file?
the initial error:
Trying to boot from MMC1
GPT: last_usable_lba incorrect: X > 747bfde
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: ***        Using Backup GPT ***
on device to repair the initial error, when "sudo gdisk  /dev/mmcblk1:" it reveals the GPT partition is 57gb
Disk /dev/mmcblk1: 61071360 sectors, 29.1 GiB
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): EC944974-E823-4B58-AEB7-A94651D008F8
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 122142686
Partitions will be aligned on 2048-sector boundaries
Total free space is 61407 sectors (30.0 MiB)
Number  Start (sector)    End (sector)  Size       Code  Name
   1           61440         2158590   1024.0 MiB  FFFF  bootfs
   2         2158592       122142686   57.2 GiB    FFFF  rootfs
Command (? for help): i 2
Partition number (1-2): 2
Partition GUID code: 1124E418-9008-41F8-9E3D-8D872216C8A1 (Unknown)
Partition unique GUID: 67AD7741-4638-47C6-A488-D396583E582A
First sector: 2158592 (at 1.0 GiB)
Last sector: 122142686 (at 58.2 GiB)
Partition size: 119984095 sectors (57.2 GiB)
Attribute flags: 0000000000000000
Partition name: 'rootfs'
Partition number (1-2): 1
Partition GUID code: 8DCD1602-5214-43F9-FFEF-C49A4EE450B7 (Unknown)
Partition unique GUID: 5A30833F-8C43-47B1-A41D-84D40883D0C6
First sector: 61440 (at 30.0 MiB)
Last sector: 2158590 (at 1.0 GiB)
Partition size: 2097151 sectors (1024.0 MiB)
Partition name: 'bootfs'
How i fix this initial problem:
boot from SD card..... and:
root@station-m2:~# sudo gdisk  /dev/mmcblk1
GPT fdisk (gdisk) version 1.0.8
Partition table scan:
  MBR: protective
  BSD: not present
  APM: not present
  GPT: present
Found valid GPT with protective MBR; using GPT.
Command (? for help): p
First usable sector is 34, last usable sector is 61071326
Total free space is 58974142 sectors (28.1 GiB)
Command (? for help): n
Partition number (2-128, default 2):
First sector (34-61071326, default = 2158592) or {+-}size{KMGTP}:
Last sector (2158592-61071326, default = 61071326) or {+-}size{KMGTP}:
Current type is 8300 (Linux filesystem)
Hex code or GUID (L to show codes, Enter = 8300): 1124E418-9008-41F8-9E3D-8D872216C8A1
Changed type of partition to 'Unknown'
Command (? for help): x
Expert command (? for help): c
Enter the partition's new unique GUID ('R' to randomize): 67AD7741-4638-47C6-A488-D396583E582A
New GUID is 67AD7741-4638-47C6-A488-D396583E582A
Expert command (? for help): w
Final checks complete. About to write GPT data. THIS WILL OVERWRITE EXISTING
PARTITIONS!!
Do you want to proceed? (Y/N): y
After solution:
  MBR: protective
  BSD: not present
  APM: not present
  GPT: present
   2         2158592        61071326   28.1 GiB    FFFF  Unknown
 I will try soon:
https://opensource.rock-chips.com/wiki_Partitions
it works!
to flash your method over 4gb 32gb devices
Just flash the gpt.img inside the start.img
located on 0x00000000
GPT 4gb to use in 8gb HZDM images
gpt.img
Edited by hotnikq
I've been busy lately.
Strange that the Armbian Server image didn't work. I tested it on my device. USB 2.0 worked. I did it in a hurry. I'll see what's wrong with it soon.
Edited by hzdm
16 hours ago, MeJune said:
Is it possible to display a digital clock on the box? (like android mode)
On 10/8/2023 at 11:38 AM, hotnikq said:
if you want this extra features, it can be solved by editing the DTB file
mipi DSi, display 7seg and infrared controller, all can be translated from android DTB to Linux DTB.
in my case it can be found on /boot/dtb/rockchip/rk3566-firefly-roc-pc.dtb
and the setup are made by the /boot/extlinux/extlinux.conf
an example how to manipulate this files
Feel free to share to the community your experiences with 7seg GPIO on H96 MAX.
it can be used to other things like digital output to automation!
Edited by hotnikq
33 minutes ago, Sunil sankar said:
the new images don't work  .
Thank you for the feedback.
This is board difference, factory change components without documentation.
The new images work here, but the @hzdm don't
On 10/7/2023 at 7:27 PM, hzdm said:
2. The /boot directory was moved to a separate bootfs partition.
Please tell me the process of making bootfs.img  in more detail.
@blust0ne don't use my images for safety reasons, Please to sensitive content, compile your own SD-card image from the armbian repo.
if you have any doubts about the image creation process please ask.
Like I said, create 2 partitions on your drive,
On 10/24/2023 at 9:28 AM, hotnikq said:
based on @hzdm method i will make this image using Distro Boot with Boot.scr
https://wiki.trenz-electronic.de/display/PD/Distro+Boot+with+Boot.scr
mount the H96MAX update.img
Files that will help
1. MiniLoaderAll.bin and U-boot are taken from Armbian image from Orange Pi 3B board.
3. Rename  file /boot/extlinux/extlinux.conf in extlinux.conf.bak
4. In /boot directory boot.cmd and boot.scr files were created with the following contents
sudo apt-get update
sudo apt install u-boot-tools
setenv docker_optimizations "on"
setenv bootlogo "false"
echo "Boot script loaded from ${devtype} ${devnum}"
if test "${docker_optimizations}" = "on"; then setenv bootargs "${bootargs} cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1"; fi
if test "${bootlogo}" = "true"; then
        setenv consoleargs "splash plymouth.ignore-serial-consoles ${consoleargs}"
else
        setenv consoleargs "splash=verbose ${consoleargs}"
fi
part uuid mmc 1:2 partuuid
setenv bootargs   androidboot.console=ttyFIQ0 root=PARTUUID=${partuuid} rootwait  rw rootfstype=ext4 ${consoleargs}   no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash p>
load mmc 1:1 0x42000000 Image
load mmc 1:1 0x44000000 dtb/rockchip/rk3566-firefly-roc-pc.dtb
load mmc 1:1 0x46000000 uInitrd
booti 0x42000000 0x46000000 0x44000000
# Recompile with:
fdisk /dev/mmcblk1
N
default
T
1
W
drop the content of your Armbian v0.5 SD card on it, (same as v0.7 tutorial)
in the first partition, drop the boot folder content to the root of the drive.
Drop on rootfs.img just the files from root of SD image (files without folder),
Drop the 2 files that you create and compile it from @hzdm tutorial.
And create a image with DD like the v0.7 tutorial. That's your rootfs.img
Edited by hotnikq
@Sunil sankar @Kenneth Hidalgo @wootje @beiqidai
@maka @SteeMan @paradigman
The 8gb device arrived!
Since my images was build on 4gb device.
it doesnt works more than a single boot on 8gb device. 😅
on installation, armbian expands the EFI disk to a Linux disk.
So, today i have generated a fix to v1.0 images work on 8gb devices.
First Boot Comand:
fdisk /dev/mmcblk1
t
4
1
w
What you will see on screen if you do the First Boot Comand:
fdisk
Welcome to fdisk (util-linux 2.37.2).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
This disk is currently in use - repartitioning is probably a bad idea.
It's recommended to umount all file systems, and swapoff all swap
partitions on this disk.
Command (m for help): t
Partition number (1-4, default 4): 4
Partition type or alias (type L to list all): 1
Changed type of partition 'Linux filesystem' to 'EFI System'.
Command (m for help): w
The partition table has been altered.
Syncing disks.
Now if you reboot the 8gb device, it will find the linux partition without problem.
Edited by hotnikq
Hey, everybody!
I haven't replied in a while because I've been moving from one house to another.
Now I have some free time and I have prepared an automatic Armbian build. You won't have to do any more extra steps with the image. You need to copy the files to the build directory with the git armbian repo ( Build Armbian )
1. Copy the h96-max-v56 directory to build/packages/blobs/  directory
2. Copy the h96-max-v56.conf file to the build/config/boards/ directory
3. Run the image build
From server
./compile.sh build BOARD=h96-max-v56 BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=jammy
From  Desktop
cinnamon
./compile.sh build BOARD=h96-max-v56 BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=jammy DESKTOP_APPGROUPS_SELECTED='3dsupport browsers desktop_tools email multimedia internet office' DESKTOP_ENVIRONMENT=cinnamon DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base
xfce
./compile.sh build BOARD=h96-max-v56 BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED='3dsupport browsers desktop_tools email multimedia internet office' DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=no RELEASE=jammy
https://drive.google.com/file/d/1oYK4EhbfcThfBs3F1Ri582jf6PYYp5x2/view?usp=drive_link
How to install this Armbian:
On Windows OS:
1. Download, unzip and install the software: RKDevTool_Release_v3.15_and_DriverAssitant_v5.12
https://drive.google.com/file/d/14HWcHYHDrgUBFWholrDCKUWDPHw1r4F1/view?usp=drive_link
2. Run RKDevTool. Right-click in the partition list window (1). Select "Load Config". Open armbian.cfg file (2)
https://drive.google.com/file/d/1MhmUJ8DaikZzwjBliY-PrOrvSrcBPwSA/view?usp=drive_link
4. Shutting down H96 MAX. Press the Reset button. Turn on the H96 MAX. The message "Found One MASKROM Device" or "Found One LOADER Device" should appear. (1)
Mark all 2 sections with check marks (2)
Open 2 files for each section (3)
Check "Write by Address" (4).
Press the "Run" button (5). The download will start.
When the message "Download image OK" appears, the download is finished (6).
H96 MAX will automatically reboot.
Done.
On Linux OS
rkdeveloptool db MiniLoaderAll.bin   # If this is not your first time flashing with this firmware, an error may appear here\. It\'s not a big deal
rkdeveloptool wl 0x0 Armbian_23.11.0-trunk_H96-max-v56_jammy_current_6.1.62.img
rkdeveloptool rd
PS: This image is functionally the same as the previous ones. It is still the same Station M2 image, only it already has all the past improvements built in and is easier to install!
Edited by hzdm
I have collected several images using this methodology. On my 8Gb RAM - 60Gb console everything started.
Check if you have other consoles. Maybe these images will work for all H96-max-v56 modifications.
Server Standard -  Armbian_23.11.0-trunk_H96-max-v56_jammy_current_6.1.62.zip
https://drive.google.com/file/d/19jFhGDuej2k7XkAqkh7Cuz3AhWRG8C0D/view?usp=drive_link
(./compile.sh build BOARD=h96-max-v56 BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=jammy)
Server Minimal - Armbian_23.11.0-trunk_H96-max-v56_jammy_current_6.1.62_minimal.zip
https://drive.google.com/file/d/1c0UajTtfiZ1dAcT2f4tHdxZf6sYd2r9m/view?usp=drive_link
(./compile.sh build BOARD=h96-max-v56 BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=jammy)
Desktop Cinnamon -  Armbian_23.11.0-trunk_H96-max-v56_jammy_current_6.1.62_cinnamon_desktop.zip
https://drive.google.com/file/d/1CFdI3YhHNPCXUbyXPXTdlaPZMAsrg9lv/view?usp=drive_link
(./compile.sh build BOARD=h96-max-v56 BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no KERNEL_CONFIGURE=no RELEASE=jammy DESKTOP_APPGROUPS_SELECTED='3dsupport browsers desktop_tools email multimedia internet office' DESKTOP_ENVIRONMENT=cinnamon DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base)
Desktop XFCE -  Armbian_23.11.0-trunk_H96-max-v56_jammy_current_6.1.62_xfce_desktop.zip
https://drive.google.com/file/d/1yfnWlUcot578PJ2fU8khfj7TBC1kU6GU/view?usp=drive_link
(./compile.sh build BOARD=h96-max-v56 BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED='3dsupport browsers desktop_tools email multimedia internet office' DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=no RELEASE=jammy)
Edited by hzdm
Eventually I plan to add H96-max-v56 to the official Armbian repository.
What else doesn't work in our images?
What could be made better in them?
1. VFD display.
2. Temperature is not displayed in htop.
