How to install, enable and start watchdog in H3
Go to solution Solved by rufik,
Try to add the following in the watchdog.service file. For me it works
ControlGroup=cpu:/
root@orangepipc:~# cat /lib/systemd/system/watchdog.service
[Unit]
Description=watchdog daemon
Conflicts=wd_keepalive.service
After=multi-user.target
OnFailure=wd_keepalive.service
[Service]
Type=forking
ControlGroup=cpu:/
EnvironmentFile=/etc/default/watchdog
ExecStartPre=/bin/sh -c '[ -z "${watchdog_module}" ] || [ "${watchdog_module}" = "none" ] || /sbin/modprobe $watchdog_module'
ExecStart=/bin/sh -c '[ $run_watchdog != 1 ] || exec /usr/sbin/watchdog $watchdog_options'
ExecStopPost=/bin/sh -c '[ $run_wd_keepalive != 1 ] || false'
[Install]
WantedBy=default.target
  • Solution
ControlGroup=cpu:/
This directive is deprecated now. But I've set realtime=no and this error has gone.
Hi There !
I have a Orange Pi 3 (H6 SOC I suppose) and I am trying to enable watchdog reset.
As far I can see, there is no kernel module for it, and, as result, there is no /dev/watchdog device file.
root@orangepi3:~# uname -a
Linux orangepi3 5.2.5-sunxi64 #5.92 SMP Fri Aug 2 07:51:38 CEST 2019 aarch64 aarch64 aarch64 GNU/Linux
root@orangepi3:~# lsmod
zstd                   16384  4
zram                   28672  2
btsdio                 16384  0
bluetooth             360448  2 btsdio
brcmfmac              204800  0
brcmutil               16384  1 brcmfmac
snd_soc_hdmi_codec     16384  0
snd_soc_core          135168  1 snd_soc_hdmi_codec
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_pcm                94208  3 snd_soc_hdmi_codec,snd_soc_core,snd_pcm_dmaengine
snd_timer              32768  1 snd_pcm
snd                    57344  4 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm
soundcore              16384  1 snd
cfg80211              319488  1 brcmfmac
rfkill                 28672  5 bluetooth,cfg80211
sun50i_h6_ths          16384  0
cpufreq_dt             16384  0
realtek                20480  1
dw_hdmi_i2s_audio      16384  0
dw_hdmi_cec            16384  0
i2c_mv64xxx            20480  0
dwmac_sun8i            24576  0
mdio_mux               16384  1 dwmac_sun8i
root@orangepi3:~# ls /dev/watchdog
ls: cannot access '/dev/watchdog': No such file or directory
root@orangepi3:~#
I've installed watchdog package and added the line "extraarg=sunxi_wdt.nowayout=1" to /boot/armbianEnv.txt
What am I missing ?
I've my OPi3 with 5.3.0-rc3, and watchdog is compiled inside kernel, not as a module.
Therefore, I've the /dev/watchdog and "dmesg | grep -i watchdog" is reporting the following :
[    1.830851] sunxi-wdt 7020400.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
hey guys,
can someone help me, maybe I forgot something. My watchdog.service doesn't work :(
watchdog.service - watchdog daemon
   Loaded: loaded (/lib/systemd/system/watchdog.service; enabled; vendor preset: ena
bled)
   Active: inactive (dead) since Mon 2019-10-28 23:58:27 CET; 15h ago
  Process: 2836 ExecStart=/bin/sh -c [ $run_watchdog != 1 ] || exec /usr/sbin/watchd
og $watchdog_options (code=exited, status=2)
  Process: 2833 ExecStartPre=/bin/sh -c [ -z "${watchdog_module}" ] || [ "${watchdog
_module}" = "none" ] || /sbin/modprobe $watchdog_module (code=exited, status=0/SUCCE
SS)
      CPU: 24ms
Warning: Journal has been rotated since unit was started. Log output is incomplete o
r unavailable.
echo 1 > /dev/watchdog
it works, orange pi zero restarts
my /etc/default/watchdog
# Start watchdog at boot time? 0 or 1
run_watchdog=1
# Start wd_keepalive after stopping watchdog? 0 or 1
run_wd_keepalive=1
# Load module before starting watchdog
watchdog_module="none"
# Specify additional watchdog options here (see manpage).
my /etc/watchdog.conf
ping                    = 1.1.1.1
ping                    = 192.168.178.1
interface               = wlan0
#file                   = /var/log/messages
#change                 = 1407
# Uncomment to enable test. Setting one of these values to '0' disables it.
# These values will hopefully never reboot your machine during normal use
# (if your machine is really hung, the loadavg will go much higher than 25)
#max-load-1             = 24
#max-load-5             = 18
#max-load-15            = 12
# Note that this is the number of pages!
# To get the real size, check how large the pagesize is on your machine.
#min-memory             = 1
#allocatable-memory     = 1
#repair-binary          = /usr/sbin/repair
#repair-timeout         = 60
test-binary             = /usr/local/bin/watchdog_led.sh
test-timeout            = 60
# The retry-timeout and repair limit are used to handle errors in a more robust
# manner. Errors must persist for longer than retry-timeout to action a repair
# or reboot, and if repair-maximum attempts are made without the test passing a
# reboot is initiated anyway.
#retry-timeout          = 60
#repair-maximum         = 1
watchdog-device = /dev/watchdog
# Defaults compiled into the binary
temperature-sensor      =/sys/class/thermal/thermal_zone0/temp
max-temperature = 90
#admin                  = root
interval                = 20
#logtick                = 1
#log-dir                = /var/log/watchdog
# This greatly decreases the chance that watchdog won't be scheduled before
# your machine is really loaded
realtime                = yes
priority                = 1
# Check if rsyslogd is still running by enabling the following line
#pidfile                = /var/run/rsyslogd.pid
pidfile         = /var/lib/zerotier-one/zerotier-one.pid
my  /etc/systemd/system.conf
RuntimeWatchdogSec=16
ShutdownWatchdogSec=10min
my /boot/armbianEnv.txt
verbosity=7
logo=disabled
console=none
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
overlays=usbhost2 usbhost3
rootdev=UUID=***
rootfstype=ext4
extraarg=thiswatchdogparameter=value
lsmod
xt_nat                 16384  7
xt_tcpudp              16384  21
veth                   20480  0
xt_conntrack           16384  1
ipt_MASQUERADE         16384  8
nf_conntrack_netlink    32768  0
nfnetlink              16384  2 nf_conntrack_netlink
xt_addrtype            16384  2
iptable_filter         16384  1
iptable_nat            16384  1
nf_nat_ipv4            16384  2 ipt_MASQUERADE,iptable_nat
nf_nat                 24576  2 xt_nat,nf_nat_ipv4
nf_conntrack           77824  6 xt_nat,ipt_MASQUERADE,nf_conntrack_netlink,xt_conntrack,nf_nat_ipv4,nf_nat
nf_defrag_ipv6         16384  1 nf_conntrack
nf_defrag_ipv4         16384  1 nf_conntrack
br_netfilter           20480  0
aufs                  167936  0
aes_arm_bs             20480  0
crypto_simd            16384  1 aes_arm_bs
cryptd                 20480  1 crypto_simd
ccm                    20480  9
overlay                77824  5
sun8i_codec_analog     24576  0
sun8i_adda_pr_regmap    16384  1 sun8i_codec_analog
snd_soc_simple_card    16384  0
sun4i_i2s              20480  0
snd_soc_simple_card_utils    16384  1 snd_soc_simple_card
snd_soc_core          114688  4 sun4i_i2s,sun8i_codec_analog,snd_soc_simple_card_utils,snd_soc_simple_card
snd_pcm                69632  3 sun4i_i2s,snd_pcm_dmaengine,snd_soc_core
lima                   40960  0
xradio_wlan            94208  1
sun4i_gpadc_iio        16384  0
snd_timer              24576  1 snd_pcm
gpu_sched              20480  1 lima
snd                    45056  3 snd_timer,snd_soc_core,snd_pcm
ttm                    57344  1 lima
industrialio           49152  1 sun4i_gpadc_iio
mac80211              450560  1 xradio_wlan
sun8i_ths              16384  0
cfg80211              393216  2 mac80211,xradio_wlan
cpufreq_dt             16384  0
uio_pdrv_genirq        16384  0
uio                    16384  1 uio_pdrv_genirq
thermal_sys            57344  3 cpufreq_dt,sun8i_ths,sun4i_gpadc_iio
usb_f_acm              16384  1
u_serial               20480  1 usb_f_acm
g_serial               16384  0
libcomposite           40960  2 g_serial,usb_f_acm
ip_tables              20480  2 iptable_filter,iptable_nat
x_tables               20480  7 xt_nat,ip_tables,iptable_filter,xt_tcpudp,ipt_MASQUERADE,xt_addrtype,xt_conntrack
pwrseq_simple          16384  1
i figured out, this conflicts with watchdog.service.
