TRay Posted July 26 Posted July 26 15 minutes ago, Werner said: I assume it is some debugging left-over. Dealing with sbc families and sunxi in particular it is a ongoing fight against regressions and having a debug kernel can help to identify such. It is not ideal having this on end-user sbcs enabled but to limit resources we cannot afford having two current branches with and without debugging. Thank you for the explanation 0 Quote
robertoj Posted July 26 Posted July 26 4 hours ago, Gabriel Negrisiolo Righi said: I've run into similar problems and checking the bash history, what i used was Thank you. I found that libllvmspirvlb 19 is only available in trixie... can you confirm? In bookworm, I needed to replace llvm-18-dev libclang-18-dev libllvmspirvlib-18-dev with llvm-19-dev libclang-19-dev libllvmspirvlib-15-dev But tomorrow I will try again with trixie 0 Quote
Gabriel Negrisiolo Righi Posted July 26 Posted July 26 (edited) On 7/26/2025 at 7:11 AM, robertoj said: 19-dev libclang-19-dev libllvmspirvlib-15-dev yes, thats it... you need to instal libllvmspirvlib-19-dev though about kodi... it worked? altough im getting the same artifacs on some videos, its stable and with hw decode on internal player, because the ffmpeg provided by the v4l2 repo is 6.11 had to compile version 21.2 omega gbm platform without internal ffmpeg, then go to video player settings and activate DRM you need to install jdk11 and select with "sudo update-alternatives --config java" to compile run cmake with the options -DCORE_PLATFORM_NAME=gbm -DAPP_RENDER_SYSTEM=gles -DENABLE_INTERNAL_FFMPEG=OFF -DWITH_FFMPEG=/usr/bin/ffmpeg you should see cmake telling you that ffmpeg version check was disabled and externally selected After installed you need to launch from a tty gonna keep testing... the ss bellow is from one episode that i wasnt being able to watch Quote Those gliches seems to be only happening with low resolution videos... soo tested it some more, its working great, when it works, but appart from those artifacts it is buggy with some others videos and it wont play: i'm testing with online streams also i dont have any movies stored, and this also happens with sw decode on x11 platform btw... i finally got inputstream.adaptative to compile (if you compile the same version of available kodi on apt you dont have to do this, will be able to just use inputstream from apt, though kodi versions higher than omega requires ffmpeg 7+) and testing with 1080p 60fps Quote 60fps with PRIME render method set to direct to plane, low cpu usage, video seems smooth but it glitches constantly like a frame drop where it goes back some frames (fps is 12 but it is wrong, video is glitching) and ss is black for some reason) The entire system crashes when I press stop. with render method to EGL, smooth 60fps with a bit higher (it goes up to 80%) cpu usage It says hardware decode and with kodi from apt im not able to get 1080 60fps smooth so I assume it's working? Definitely better than mpv 👌 Edited July 27 by Gabriel Negrisiolo Righi 0 Quote
robertoj Posted July 28 Posted July 28 Thank you for the information I have completed the build dependencies step, for mesa 25.2, in Debian Trixie. However, when I build it, my orange pi zero 3 with 1 GB or RAM, it runs out of memory... even when I make a swap file of 2GB. I keep rebooting the opiz3, and continue the compilation job. Is this normal? In the raspberry forum, they told me that my LCD driver panel-mipi-dbi.ko doesn't work with X11... so I give up on this, and continue my development with labwc/wayland (easily installed in Trixie) 0 Quote
mantouboji Posted August 8 Posted August 8 pps-gpio.dts /* * PPS-GPIO for H616/618 * * for Zero2, use PC9 * for Zero3, use PC11 * for Zero2W, use PI5, not success * * feiyao@me.com */ /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&pio>; __overlay__ { pps_pins: pps_pins { pins = "PC11"; /* Zero3 */ function = "gpio_in"; }; }; }; fragment@1 { target-path = "/"; __overlay__ { pps@0 { compatible = "pps-gpio"; pinctrl-names = "default"; /* pinctrl-0 = <&pps_pins>; */ gpios = <&pio 2 11 0>; /* PC11 @ Zero3 */ status = "okay"; }; }; }; }; compile and install: armbian-add-overlay pps-gpio.dts 0 Quote
Frans Hettinga Posted August 9 Posted August 9 I'm trying to use a USB disk to boot from, can i use this guide: https://raymii.org/s/tutorials/Netboot_PXE_Armbian_on_an_Orange_Pi_Zero_3_from_SPI_with_NFS_root_filesystem.html And after the "flashrom -p linux_spi:dev=/dev/spidev0.0 -w spi.img" insert the usb drive with armbian on it? Or are there any other steps that need to be done? 0 Quote
Gabriel Negrisiolo Righi Posted August 11 Posted August 11 Latest edge kernel update to 6.16 breaks boot 0 Quote
robertoj Posted August 11 Posted August 11 Boot while looking at the serial output, what do you see? 0 Quote
mantouboji Posted Tuesday at 01:24 PM Posted Tuesday at 01:24 PM Zero3 root on NFS ,pxlinux cfg: LABEL linux KERNEL /zero3/vmlinuz-6.15.4-edge-sunxi64 FDTDIR /zero3/dtb-6.15.4-edge-sunxi64 DEVICETREE-OVERLAY /zero3/dtb-6.15.4-edge-sunxi64/allwinner/overlay/sun50i-h616-uart5.dtbo /zero3/dtb-6.15.4-edge-sunxi64/allwinner/overlay/sun50i-h616-spi-spidev.dtbo /zero3/overlay-user/spidev1_1.dtbo APPEND root=/dev/nfs initrd=/zero3/initrd.img-6.15.4-edge-sunxi64 nfsroot=192.168.20.20:/mnt/mass/data/linux/zero3/zero31 ip=dhcp rw rootwait DEFAULT linux 0 Quote
subhan Posted Wednesday at 06:45 PM Posted Wednesday at 06:45 PM On 7/11/2023 at 1:32 PM, ag123 said: has anyone ordered and/or played with this https://www.cnx-software.com/2023/07/03/orange-pi-zero-3-allwinner-h618-sbc-ships-with-up-to-4gb-ram/ https://liliputing.com/orange-pi-zero-3-is-a-cheap-tiny-single-board-pc-with-up-to-4gb-ram-gigabit-ethernet-and-allwinner-h618/ http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/details/Orange-Pi-Zero-3.html even the linux images is very 'fresh' as in that they are just released *yesterday* 😄 Yep, I’ve been testing the 1.5GB version with Armbian. Images are still rough—some issues with AdGuard Home not starting properly after reboot, and a few quirks with networking. Promising board though, especially for the price. 0 Quote
