15 minutes ago, Werner said:
I assume it is some debugging left-over. Dealing with sbc families and sunxi in particular it is a ongoing fight against regressions and having a debug kernel can help to identify such. It is not ideal having this on end-user sbcs enabled but to limit resources we cannot afford having two current branches with and without debugging.
Thank you for the explanation
4 hours ago, Gabriel Negrisiolo Righi said:
I've run into similar problems and checking the bash history, what i used was
Thank you.
I found that libllvmspirvlb 19 is only available in trixie... can you confirm?
In bookworm, I needed to replace llvm-18-dev libclang-18-dev libllvmspirvlib-18-dev with llvm-19-dev libclang-19-dev libllvmspirvlib-15-dev
But tomorrow I will try again with trixie
Posted (edited)
yes, thats it... you need to instal libllvmspirvlib-19-dev though
about kodi... it worked? altough im getting the same artifacs on some videos, its stable and with hw decode on internal player, because the ffmpeg provided by the v4l2 repo is 6.11 had to compile version 21.2 omega gbm platform without internal ffmpeg, then go to video player settings and activate DRM
you need to install jdk11 and select with "sudo update-alternatives --config java"
to compile run cmake with the options
-DCORE_PLATFORM_NAME=gbm -DAPP_RENDER_SYSTEM=gles -DENABLE_INTERNAL_FFMPEG=OFF -DWITH_FFMPEG=/usr/bin/ffmpeg
you should see cmake telling you that ffmpeg version check was disabled and externally selected
After installed you need to launch from a tty
gonna keep testing... the ss bellow is from one episode that i wasnt being able to watch
Quote
Those gliches seems to be only happening with low resolution videos...
soo tested it some more, its working great, when it works, but appart from those artifacts it is buggy with some others videos and it wont play:
i'm testing with online streams also i dont have any movies stored, and this also happens with sw decode on x11 platform btw...
i finally got inputstream.adaptative to compile (if you compile the same version of available kodi on apt you dont have to do this, will be able to just use inputstream from apt, though kodi versions higher than omega requires ffmpeg 7+) and testing with 1080p 60fps
Quote
60fps with PRIME render method set to direct to plane, low cpu usage, video seems smooth but it glitches constantly like a frame drop where it goes back some frames (fps is 12 but it is wrong, video is glitching) and ss is black for some reason)
The entire system crashes when I press stop.
with render method to EGL, smooth 60fps with a bit higher (it goes up to 80%)  cpu usage
It says hardware decode and with kodi from apt im not able to get 1080 60fps smooth so I assume it's working?
Definitely better than mpv 👌
Edited by Gabriel Negrisiolo Righi
Thank you for the information :) I have completed the build dependencies step, for mesa 25.2, in Debian Trixie.
However, when I build it, my orange pi zero 3 with 1 GB or RAM, it runs out of memory... even when I make a swap file of 2GB.
I keep rebooting the opiz3, and continue the compilation job. Is this normal?
In the raspberry forum, they told me that my LCD driver panel-mipi-dbi.ko doesn't work with X11... so I give up on this, and continue my development with labwc/wayland (easily installed in Trixie)
pps-gpio.dts
 * PPS-GPIO for H616/618
 * for Zero2, use PC9
 * for Zero3, use PC11
 * for Zero2W, use PI5, not success
 * feiyao@me.com
/dts-v1/;
/plugin/;
	compatible = "allwinner,sun50i-h616";
	fragment@0 {
		target = <&pio>;
		__overlay__ {
        		pps_pins: pps_pins {
                  		pins = "PC11";  /*  Zero3 */
                  		function = "gpio_in";
	fragment@1 {
		target-path = "/";
		__overlay__ {
			pps@0 {
                		compatible = "pps-gpio";
                		pinctrl-names = "default";
				/* pinctrl-0 = <&pps_pins>; */
                		gpios = <&pio 2 11 0>;  /* PC11 @ Zero3 */
                		status = "okay";
compile and install:
armbian-add-overlay pps-gpio.dts
Zero3 root on NFS ,pxlinux cfg:
LABEL linux
KERNEL  /zero3/vmlinuz-6.15.4-edge-sunxi64
FDTDIR  /zero3/dtb-6.15.4-edge-sunxi64
DEVICETREE-OVERLAY /zero3/dtb-6.15.4-edge-sunxi64/allwinner/overlay/sun50i-h616-uart5.dtbo /zero3/dtb-6.15.4-edge-sunxi64/allwinner/overlay/sun50i-h616-spi-spidev.dtbo /zero3/overlay-user/spidev1_1.dtbo
APPEND  root=/dev/nfs initrd=/zero3/initrd.img-6.15.4-edge-sunxi64 nfsroot=192.168.20.20:/mnt/mass/data/linux/zero3/zero31 ip=dhcp rw rootwait
DEFAULT linux
On 7/11/2023 at 1:32 PM, ag123 said:
Yep, I’ve been testing the 1.5GB version with Armbian. Images are still rough—some issues with AdGuard Home not starting properly after reboot, and a few quirks with networking. Promising board though, especially for the price.
Posted (edited)
What the hell is kernel 6.16 ( linux-image-edge-sunxi64 (25.8.1)  )?
Never seen it in git main , no all overlays ,  who did it?
After upgrade, no wifi .
Edited by Guest
Revert to 6.15. The 6.16 package is useful for A523 only atm.
Don't use bleeding edge and complain about things breaking the same time.
1 hour ago, mantouboji said:
What the hell
To answer on your level: Either help fixing things or fuck off and move along.
Why not test it in a github branch , but release into public directly without any comment and test?
Why did you bypassed the github repository?
4 hours ago, mantouboji said:
What the hell
MOD: Your attitude of taking but not contributing and being abrasive is not welcome here.  You received a warning now and will be unable to post to this forum for a few days.  You were warned by several people many times before.  If you still don't get the message and do not change course, expect to be blocked completely from Armbian.
Be constructive, contribute or be gone.
7 hours ago, Gabriel Negrisiolo Righi said:
Latest armbian update 25.11 trunk 45 also breaks boot...
If you used edge, revert to 6.15
If I run a update after changing kernel to edge it doesn't matter the version, it breaks boot, idk why, but it is installing dtb for kernel 6.16 even with kernel 6.13 or 14 installed, current kernel does not support analog audio out of the box and I managed to get it working a few times, so I'm stuck with edge kernel, did a update then changed to edge kernel and disabled armbian updates until this bug is fixed
hdmi audio doesn't work with the latest linux kernel 6.16.8 (edge). OS: Armbian Bookworm, latest build (v26.2.0-trunk.32).
revert to 6.15.4 helps.
Test Output (aplay -l):
Kernel 6.16.8 (BROKEN):
card 0: Codec [H616 Audio Codec], device 0: CDC PCM Codec-0 [CDC PCM Codec-0]
Kernel 6.15.4 (WORKING):
card 1: HDMI [HDMI], device 0: ahub_plat-i2s-hifi i2s-hifi-0 [ahub_plat-i2s-hifi i2s-hifi-0]
P.S. I am using the edge kernel branch because support for the analog audio jack on H616/H618 requires kernel 6.13 or newer. Currently, kernel 6.15.4 is the latest working version that provides both analog and HDMI audio.
Posted (edited)
I know of a way to install a specific kernel version:
sudo apt install linux-image-edge-sunxi64=25.5.1  --> installs linux 6.14.8
But how do you install specifically linux 6.15.4?
Also, have you checked if the newest linux version requires a dtbo to be activated in armbian-config?
If you still can: compare the output of lsmod under 6.15.4 and under 6.16.8
Edited by robertoj
5 часов назад, robertoj сказал:
go armbian-config - Wait warning message "The current OS (bookworm) is not a officially supported distro!"  - Kernel - KER001 Use alternative kernels - Would you like to continue?  <Yes> - Show only mainstream kernels on the list? <No>
And there the list:
Скрытый текст
┤ Select kernel ├───────────────────────────────┐
                                     │              linux-image-legacy-sunxi64=25.11.2        v6.6.75               │
                                     │              linux-image-legacy-sunxi64=25.8.2         v6.6.75               │
                                     │              linux-image-legacy-sunxi64=25.8.1         v6.6.75               │
                                     │              linux-image-legacy-sunxi64=25.5.1         v6.6.75               │
                                     │              linux-image-legacy-sunxi64=25.2.3         v6.6.75               │
                                     │              linux-image-legacy-sunxi64=25.2.2         v6.1.104              │
                                     │              linux-image-legacy-sunxi64=24.11.1        v6.1.104              │
                                     │              linux-image-legacy-sunxi64=24.8.2         v6.1.104              │
                                     │              linux-image-legacy-sunxi64=24.5.1         v6.1.92               │
                                     │              linux-image-legacy-sunxi64=24.2.1         v6.1.77               │
                                     │              linux-image-current-sunxi64=25.11.2       v6.12.58              │
                                     │              linux-image-current-sunxi64=25.8.2        v6.12.47              │
                                     │              linux-image-current-sunxi64=25.8.1        v6.12.43              │
                                     │              linux-image-current-sunxi64=25.5.2        v6.12.35              │
                                     │              linux-image-current-sunxi64=25.5.1        v6.12.30              │
                                     │              linux-image-current-sunxi64=25.2.3        v6.12.20              │
                                     │              linux-image-current-sunxi64=25.2.2        v6.6.75               │
                                     │              linux-image-current-sunxi64=24.11.1       v6.6.62               │
                                     │              linux-image-current-sunxi64=24.8.4        v6.6.44               │
                                     │              linux-image-current-sunxi64=24.5.4        v6.6.36               │
                                     │              linux-image-current-sunxi64=24.5.1        v6.6.31               │
                                     │              linux-image-current-sunxi64=24.2.1        v6.6.16               │
                                     │              linux-image-edge-sunxi64=25.8.2           v6.16.8               │
                                     │              linux-image-edge-sunxi64=25.8.1           v6.15.4               │
                                     │              linux-image-edge-sunxi64=25.5.1           v6.14.8               │
                                     │              linux-image-edge-sunxi64=25.2.3           v6.13.7               │
                                     │              linux-image-edge-sunxi64=25.2.2           v6.12.16              │
                                     │              linux-image-edge-sunxi64=24.11.1          v6.11.9               │
                                     │              linux-image-edge-sunxi64=24.8.3           v6.10.9               │
                                     │              linux-image-edge-sunxi64=24.5.1           v6.7.12               │
                                     │              linux-image-edge-sunxi64=24.2.1           v6.7.4
then choose "linux-image-edge-sunxi64=25.8.1           v6.15.4    "
mainstream kernels:
linux-image-current-sunxi64/bookworm 25.8.2 arm64 Armbian Linux current kernel image 6.12.47-current-sunxi64
linux-image-edge-sunxi64/now 26.02.0-trunk arm64 [installed,local] Armbian Linux edge kernel image 6.16.8-edge-sunxi64
linux-image-legacy-sunxi64/bookworm 25.8.2 arm64 Armbian Linux legacy kernel image 6.6.75-legacy-sunxi64
6.16.8:
Скрытый текст
~# uname -r
6.16.8-edge-sunxi64
~# lsmod
Module                  Size  Used by
cdc_ether              12288  0
usbnet                 28672  1 cdc_ether
uas                    20480  0
sprdwl_ng             323584  0
zram                   36864  2
842_decompress         12288  1 zram
842_compress           16384  1 zram
snd_soc_hdmi_codec     16384  0
sun50i_h6_prcm_ppu     12288  0
binfmt_misc            16384  1
cmdlinepart            12288  0
spi_nor                86016  0
dw_hdmi_i2s_audio      12288  0
dw_hdmi_cec            12288  0
sun8i_ce               36864  0
panfrost               69632  3
crypto_engine          12288  1 sun8i_ce
governor_simpleondemand    12288  0
drm_shmem_helper       20480  1 panfrost
gpu_sched              28672  1 panfrost
display_connector      12288  0
cfg80211              368640  1 sprdwl_ng
rfkill                 24576  2 cfg80211
uio_pdrv_genirq        12288  0
uio                    16384  1 uio_pdrv_genirq
dm_mod                110592  0
dax                    28672  1 dm_mod
fuse                  135168  1
configfs               36864  1
ip_tables              24576  0
x_tables               28672  1 ip_tables
sunxi                  16384  0
musb_hdrc              77824  1 sunxi
phy_generic            12288  2 sunxi
6.15.4:
Скрытый текст
~# uname -r
6.15.4-edge-sunxi64
~# lsmod
Module                  Size  Used by
cdc_ether              12288  0
uas                    20480  0
bnep                   16384  2
hci_uart              106496  1
btqca                  16384  1 hci_uart
btrtl                  20480  1 hci_uart
btintel                36864  1 hci_uart
btbcm                  20480  1 hci_uart
bluetooth             491520  29 btrtl,btqca,btintel,hci_uart,btbcm,bnep
ecdh_generic           12288  2 bluetooth
ecc                    32768  1 ecdh_generic
sprdwl_ng             323584  0
sunxi_addr             12288  1 sprdwl_ng
zram                   32768  2
snd_soc_hdmi_codec     16384  1
snd_soc_sunxi_machine    16384  0
snd_soc_sunxi_ahub     20480  2
binfmt_misc            16384  1
dw_hdmi_cec            12288  0
cmdlinepart            12288  0
snd_soc_sunxi_ahub_dam    12288  1 snd_soc_sunxi_ahub
spi_nor                81920  0
panfrost               69632  3
sun8i_ce               36864  1
drm_shmem_helper       16384  1 panfrost
cfg80211              364544  1 sprdwl_ng
sprdbt_tty             24576  2
uwe5622_bsp_sdio      188416  2 sprdbt_tty,sprdwl_ng
rfkill                 24576  5 sprdbt_tty,bluetooth,cfg80211
dm_mod                110592  0
fuse                  139264  1
dax                    28672  1 dm_mod
configfs               36864  1
sunxi                  16384  0
musb_hdrc              73728  1 sunxi
In the working kernel 6.15.4, the following audio-related modules are loaded:
snd_soc_sunxi_machine, snd_soc_sunxi_ahub, snd_soc_sunxi_ahub_dam
In the broken kernel 6.16.8, these three modules are completely missing. Only the generic snd_soc_hdmi_codec is present, but it doesn't seem to bind to the hardware correctly without the sunxi-specific modules.
I don't know how, but there the list in 6.16.8:
Скрытый текст
~# ls /boot/dtb/allwinner/
overlay                             sun50i-a64-pinephone-1.1.dtb            sun50i-h5-nanopi-neo2.dtb              sun50i-h616-orangepi-zero2.dtb
sun50i-a100-allwinner-perf1.dtb     sun50i-a64-pinephone-1.2.dtb            sun50i-h5-nanopi-r1s-h5.dtb            sun50i-h616-x96-mate.dtb
sun50i-a133-liontron-h-a133l.dtb    sun50i-a64-pinephone-1.2b.dtb           sun50i-h5-orangepi-pc2.dtb             sun50i-h618-bananapi-m4-berry.dtb
sun50i-a64-amarula-relic.dtb        sun50i-a64-pinetab-early-adopter.dtb    sun50i-h5-orangepi-prime.dtb           sun50i-h618-bananapi-m4-zero.dtb
sun50i-a64-bananapi-m64.dtb         sun50i-a64-pinetab.dtb                  sun50i-h5-orangepi-zero-plus.dtb       sun50i-h618-kickpi-k2b.dtb
sun50i-a64-nanopi-a64.dtb           sun50i-a64-sopine-baseboard.dtb         sun50i-h5-orangepi-zero-plus2.dtb      sun50i-h618-longanpi-3h.dtb
sun50i-a64-oceanic-5205-5inmfd.dtb  sun50i-a64-teres-i.dtb                  sun50i-h6-beelink-gs1.dtb              sun50i-h618-orangepi-zero2w.dtb
sun50i-a64-olinuxino-1G.dtb         sun50i-h313-tanix-tx1.dtb               sun50i-h6-inovato-quadra.dtb           sun50i-h618-orangepi-zero3.dtb
sun50i-a64-olinuxino-1Ge16GW.dtb    sun50i-h313-x96q-lpddr3.dtb             sun50i-h6-orangepi-3-lts.dtb           sun50i-h618-transpeed-8k618-t.dtb
sun50i-a64-olinuxino-1Ge4GW.dtb     sun50i-h5-bananapi-m2-plus-v1.2.dtb     sun50i-h6-orangepi-3.dtb               sun50i-h618-yuzukihd-chameleon.dtb
sun50i-a64-olinuxino-1Gs16M.dtb     sun50i-h5-bananapi-m2-plus.dtb          sun50i-h6-orangepi-lite2.dtb           sun50i-h64-remix-mini-pc.dtb
sun50i-a64-olinuxino-2Ge8G.dtb      sun50i-h5-emlid-neutis-n5-devboard.dtb  sun50i-h6-orangepi-one-plus.dtb        sun50i-h700-anbernic-rg35xx-2024.dtb
sun50i-a64-olinuxino-emmc.dtb       sun50i-h5-libretech-all-h3-cc.dtb       sun50i-h6-pine-h64-model-b.dtb         sun50i-h700-anbernic-rg35xx-h.dtb
sun50i-a64-olinuxino.dtb            sun50i-h5-libretech-all-h3-it.dtb       sun50i-h6-pine-h64.dtb                 sun50i-h700-anbernic-rg35xx-plus.dtb
sun50i-a64-orangepi-win.dtb         sun50i-h5-libretech-all-h5-cc.dtb       sun50i-h6-tanix-tx6-mini.dtb           sun50i-h700-anbernic-rg35xx-sp.dtb
sun50i-a64-pine64-lts.dtb           sun50i-h5-nanopi-k1-plus.dtb            sun50i-h6-tanix-tx6.dtb                sun55i-a527-cubie-a5e.dtb
sun50i-a64-pine64-plus.dtb          sun50i-h5-nanopi-m1-plus2.dtb           sun50i-h616-bigtreetech-cb1-emmc.dtb   sun55i-h728-x96qpro+.dtb
sun50i-a64-pine64.dtb               sun50i-h5-nanopi-neo-core2.dtb          sun50i-h616-bigtreetech-cb1-manta.dtb  sun55i-t527-avaota-a1.dtb
sun50i-a64-pinebook.dtb             sun50i-h5-nanopi-neo-plus2.dtb          sun50i-h616-bigtreetech-cb1-sd.dtb
sun50i-a64-pinephone-1.0.dtb        sun50i-h5-nanopi-neo2-v1.1.dtb          sun50i-h616-bigtreetech-pi.dtb
~# ls /boot/dtb/allwinner/overlay/
README.sun50i-a64-overlays            sun50i-h5-usbhost2.dtbo                              sun50i-h616-i2c3-ph.dtbo
README.sun50i-h5-overlays             sun50i-h5-usbhost3.dtbo                              sun50i-h616-i2c4-pg.dtbo
sun50i-a64-i2c0.dtbo                  sun50i-h5-w1-gpio.dtbo                               sun50i-h616-i2c4-ph.dtbo
sun50i-a64-i2c1.dtbo                  sun50i-h6-i2c0.dtbo                                  sun50i-h616-ir.dtbo
sun50i-a64-pine64-7inch-lcd.dtbo      sun50i-h6-i2c1.dtbo                                  sun50i-h616-keys.dtbo
sun50i-a64-pps-gpio.dtbo              sun50i-h6-i2c2.dtbo                                  sun50i-h616-light.dtbo
sun50i-a64-spi-add-cs1.dtbo           sun50i-h6-pwm.dtbo                                   sun50i-h616-mcp2515.dtbo
sun50i-a64-spi-jedec-nor.dtbo         sun50i-h6-ruart.dtbo                                 sun50i-h616-pwm1-ph3.dtbo
sun50i-a64-spi-spidev.dtbo            sun50i-h6-spi-add-cs1.dtbo                           sun50i-h616-pwm1-pi11.dtbo
sun50i-a64-uart1.dtbo                 sun50i-h6-spi-jedec-nor.dtbo                         sun50i-h616-pwm2-ph2.dtbo
sun50i-a64-uart2.dtbo                 sun50i-h6-spi-spidev.dtbo                            sun50i-h616-pwm2-pi12.dtbo
sun50i-a64-uart3.dtbo                 sun50i-h6-spi-spidev1.dtbo                           sun50i-h616-pwm3-ph0.dtbo
sun50i-a64-uart4.dtbo                 sun50i-h6-uart1.dtbo                                 sun50i-h616-pwm3-pi13.dtbo
sun50i-a64-w1-gpio.dtbo               sun50i-h6-uart2.dtbo                                 sun50i-h616-pwm4-ph1.dtbo
sun50i-h5-analog-codec.dtbo           sun50i-h6-uart3.dtbo                                 sun50i-h616-pwm4-pi14.dtbo
sun50i-h5-cir.dtbo                    sun50i-h6-w1-gpio.dtbo                               sun50i-h616-spi-spidev.dtbo
sun50i-h5-cpu-clock-1.0GHz-1.1v.dtbo  sun50i-h616-bananapi-m4-pg-15-16-i2c4.dtbo           sun50i-h616-spidev0_0.dtbo
sun50i-h5-cpu-clock-1.2GHz-1.3v.dtbo  sun50i-h616-bananapi-m4-pg-17-18-i2c3.dtbo           sun50i-h616-spidev1_0.dtbo
sun50i-h5-cpu-clock-1.3GHz-1.3v.dtbo  sun50i-h616-bananapi-m4-pg-6-7-uart1.dtbo            sun50i-h616-spidev1_1.dtbo
sun50i-h5-gpio-regulator-1.3v.dtbo    sun50i-h616-bananapi-m4-pg-8-9-rts-cts-uart1.dtbo    sun50i-h616-spidev1_2.dtbo
sun50i-h5-i2c0.dtbo                   sun50i-h616-bananapi-m4-ph-2-3-uart5.dtbo            sun50i-h616-tft35_spi.dtbo
sun50i-h5-i2c1.dtbo                   sun50i-h616-bananapi-m4-pi-13-14-uart4.dtbo          sun50i-h616-uart2-pg-rts-cts.dtbo
sun50i-h5-i2c2.dtbo                   sun50i-h616-bananapi-m4-pi-15-16-rts-cts-uart4.dtbo  sun50i-h616-uart2-pg.dtbo
sun50i-h5-pps-gpio.dtbo               sun50i-h616-bananapi-m4-pi-5-6-i2c0.dtbo             sun50i-h616-uart2-ph-rts-cts.dtbo
sun50i-h5-pwm.dtbo                    sun50i-h616-bananapi-m4-pi-7-8-i2c1.dtbo             sun50i-h616-uart2-ph.dtbo
sun50i-h5-spdif-out.dtbo              sun50i-h616-bananapi-m4-sdio-wifi-bt.dtbo            sun50i-h616-uart2-pi-rts-cts.dtbo
sun50i-h5-spi-add-cs1.dtbo            sun50i-h616-bananapi-m4-spi1-cs0-cs1-spidev.dtbo     sun50i-h616-uart2-pi.dtbo
sun50i-h5-spi-jedec-nor.dtbo          sun50i-h616-bananapi-m4-spi1-cs0-spidev.dtbo         sun50i-h616-uart3-pi-rts-cts.dtbo
sun50i-h5-spi-spidev.dtbo             sun50i-h616-bananapi-m4-spi1-cs1-spidev.dtbo         sun50i-h616-uart3-pi.dtbo
sun50i-h5-tve.dtbo                    sun50i-h616-gpu.dtbo                                 sun50i-h616-uart4-pi-rts-cts.dtbo
sun50i-h5-uart1.dtbo                  sun50i-h616-i2c0-pi.dtbo                             sun50i-h616-uart4-pi.dtbo
sun50i-h5-uart2.dtbo                  sun50i-h616-i2c1-pi.dtbo                             sun50i-h616-uart5.dtbo
sun50i-h5-uart3.dtbo                  sun50i-h616-i2c2-ph.dtbo                             sun50i-h616-ws2812.dtbo
sun50i-h5-usbhost0.dtbo               sun50i-h616-i2c2-pi.dtbo
sun50i-h5-usbhost1.dtbo               sun50i-h616-i2c3-pg.dtbo
~# cat /boot/armbianEnv.txt
verbosity=1
bootlogo=false
console=serial
disp_mode=1920x1080p60
overlay_prefix=sun50i-h616
overlays=gpu
extraargs=cma=256M
extraargs=quiet loglevel=3 splash
rootdev=UUID=bd56ff6d-...
rootfstype=ext4
usbstoragequirks=0x2537....
tried to activate all dtbs in armbian-config - DTO001   -  Manage device tree overlays
noghing happend
Urgently go back to the previous selection of dtbos in armbian-config.
Just having 1 undesired dtbo may interfere with everything else.
Then try adding:
overlays=analog-codec
in armbianEnv.txt
And check the lsmod again
these modules/configs are missing in 6.16.8 (vs 6.15.4):
CONFIG_SND_SUN9I_HDMI_AUDIO=y
CONFIG_SND_SOC_SUNXI_MACH=m
CONFIG_SND_SOC_SUNXI_AHUB=m
CONFIG_SND_SOC_SUNXI_AHUB_DAM=m
CONFIG_SND_SOC_SUNXI_INTERNALCODEC=m
CONFIG_SND_SOC_SUNXI_AAUDIO=m
Could this be a problem?
