TRay Posted July 26, 2025 Posted July 26, 2025 15 minutes ago, Werner said: I assume it is some debugging left-over. Dealing with sbc families and sunxi in particular it is a ongoing fight against regressions and having a debug kernel can help to identify such. It is not ideal having this on end-user sbcs enabled but to limit resources we cannot afford having two current branches with and without debugging. Thank you for the explanation 0 Quote
robertoj Posted July 26, 2025 Posted July 26, 2025 4 hours ago, Gabriel Negrisiolo Righi said: I've run into similar problems and checking the bash history, what i used was Thank you. I found that libllvmspirvlb 19 is only available in trixie... can you confirm? In bookworm, I needed to replace llvm-18-dev libclang-18-dev libllvmspirvlib-18-dev with llvm-19-dev libclang-19-dev libllvmspirvlib-15-dev But tomorrow I will try again with trixie 0 Quote
Gabriel Negrisiolo Righi Posted July 26, 2025 Posted July 26, 2025 (edited) On 7/26/2025 at 7:11 AM, robertoj said: 19-dev libclang-19-dev libllvmspirvlib-15-dev yes, thats it... you need to instal libllvmspirvlib-19-dev though about kodi... it worked? altough im getting the same artifacs on some videos, its stable and with hw decode on internal player, because the ffmpeg provided by the v4l2 repo is 6.11 had to compile version 21.2 omega gbm platform without internal ffmpeg, then go to video player settings and activate DRM you need to install jdk11 and select with "sudo update-alternatives --config java" to compile run cmake with the options -DCORE_PLATFORM_NAME=gbm -DAPP_RENDER_SYSTEM=gles -DENABLE_INTERNAL_FFMPEG=OFF -DWITH_FFMPEG=/usr/bin/ffmpeg you should see cmake telling you that ffmpeg version check was disabled and externally selected After installed you need to launch from a tty gonna keep testing... the ss bellow is from one episode that i wasnt being able to watch Quote Those gliches seems to be only happening with low resolution videos... soo tested it some more, its working great, when it works, but appart from those artifacts it is buggy with some others videos and it wont play: i'm testing with online streams also i dont have any movies stored, and this also happens with sw decode on x11 platform btw... i finally got inputstream.adaptative to compile (if you compile the same version of available kodi on apt you dont have to do this, will be able to just use inputstream from apt, though kodi versions higher than omega requires ffmpeg 7+) and testing with 1080p 60fps Quote 60fps with PRIME render method set to direct to plane, low cpu usage, video seems smooth but it glitches constantly like a frame drop where it goes back some frames (fps is 12 but it is wrong, video is glitching) and ss is black for some reason) The entire system crashes when I press stop. with render method to EGL, smooth 60fps with a bit higher (it goes up to 80%) cpu usage It says hardware decode and with kodi from apt im not able to get 1080 60fps smooth so I assume it's working? Definitely better than mpv 👌 Edited July 27, 2025 by Gabriel Negrisiolo Righi 0 Quote
robertoj Posted July 28, 2025 Posted July 28, 2025 Thank you for the information I have completed the build dependencies step, for mesa 25.2, in Debian Trixie. However, when I build it, my orange pi zero 3 with 1 GB or RAM, it runs out of memory... even when I make a swap file of 2GB. I keep rebooting the opiz3, and continue the compilation job. Is this normal? In the raspberry forum, they told me that my LCD driver panel-mipi-dbi.ko doesn't work with X11... so I give up on this, and continue my development with labwc/wayland (easily installed in Trixie) 0 Quote
Guest Posted August 8, 2025 Posted August 8, 2025 pps-gpio.dts /* * PPS-GPIO for H616/618 * * for Zero2, use PC9 * for Zero3, use PC11 * for Zero2W, use PI5, not success * * feiyao@me.com */ /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&pio>; __overlay__ { pps_pins: pps_pins { pins = "PC11"; /* Zero3 */ function = "gpio_in"; }; }; }; fragment@1 { target-path = "/"; __overlay__ { pps@0 { compatible = "pps-gpio"; pinctrl-names = "default"; /* pinctrl-0 = <&pps_pins>; */ gpios = <&pio 2 11 0>; /* PC11 @ Zero3 */ status = "okay"; }; }; }; }; compile and install: armbian-add-overlay pps-gpio.dts 0 Quote
Frans Hettinga Posted August 9, 2025 Posted August 9, 2025 I'm trying to use a USB disk to boot from, can i use this guide: https://raymii.org/s/tutorials/Netboot_PXE_Armbian_on_an_Orange_Pi_Zero_3_from_SPI_with_NFS_root_filesystem.html And after the "flashrom -p linux_spi:dev=/dev/spidev0.0 -w spi.img" insert the usb drive with armbian on it? Or are there any other steps that need to be done? 0 Quote
Gabriel Negrisiolo Righi Posted August 11, 2025 Posted August 11, 2025 Latest edge kernel update to 6.16 breaks boot 0 Quote
robertoj Posted August 11, 2025 Posted August 11, 2025 Boot while looking at the serial output, what do you see? 0 Quote
Guest Posted August 12, 2025 Posted August 12, 2025 Zero3 root on NFS ,pxlinux cfg: LABEL linux KERNEL /zero3/vmlinuz-6.15.4-edge-sunxi64 FDTDIR /zero3/dtb-6.15.4-edge-sunxi64 DEVICETREE-OVERLAY /zero3/dtb-6.15.4-edge-sunxi64/allwinner/overlay/sun50i-h616-uart5.dtbo /zero3/dtb-6.15.4-edge-sunxi64/allwinner/overlay/sun50i-h616-spi-spidev.dtbo /zero3/overlay-user/spidev1_1.dtbo APPEND root=/dev/nfs initrd=/zero3/initrd.img-6.15.4-edge-sunxi64 nfsroot=192.168.20.20:/mnt/mass/data/linux/zero3/zero31 ip=dhcp rw rootwait DEFAULT linux 0 Quote
subhan Posted August 13, 2025 Posted August 13, 2025 On 7/11/2023 at 1:32 PM, ag123 said: has anyone ordered and/or played with this https://www.cnx-software.com/2023/07/03/orange-pi-zero-3-allwinner-h618-sbc-ships-with-up-to-4gb-ram/ https://liliputing.com/orange-pi-zero-3-is-a-cheap-tiny-single-board-pc-with-up-to-4gb-ram-gigabit-ethernet-and-allwinner-h618/ http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/details/Orange-Pi-Zero-3.html even the linux images is very 'fresh' as in that they are just released *yesterday* 😄 Yep, I’ve been testing the 1.5GB version with Armbian. Images are still rough—some issues with AdGuard Home not starting properly after reboot, and a few quirks with networking. Promising board though, especially for the price. 0 Quote
Guest Posted August 18, 2025 Posted August 18, 2025 (edited) What the hell is kernel 6.16 ( linux-image-edge-sunxi64 (25.8.1) )? Never seen it in git main , no all overlays , who did it? After upgrade, no wifi . Edited August 18, 2025 by Guest 0 Quote
Werner Posted August 18, 2025 Posted August 18, 2025 Revert to 6.15. The 6.16 package is useful for A523 only atm. Don't use bleeding edge and complain about things breaking the same time. 1 hour ago, mantouboji said: What the hell To answer on your level: Either help fixing things or fuck off and move along. 1 Quote
Guest Posted August 18, 2025 Posted August 18, 2025 Why not test it in a github branch , but release into public directly without any comment and test? 0 Quote
Guest Posted August 18, 2025 Posted August 18, 2025 32 minutes ago, Werner said: To answer on your level: Either help fixing things or fuck off and move along. Why did you bypassed the github repository? 0 Quote
Werner Posted August 18, 2025 Posted August 18, 2025 https://github.com/armbian/build/pull/8447#issuecomment-3195333910 0 Quote
Guest Posted August 18, 2025 Posted August 18, 2025 35 minutes ago, Werner said: https://github.com/armbian/build/pull/8447#issuecomment-3195333910 I don't want to say anymore. What a mess. 0 Quote
laibsch Posted August 18, 2025 Posted August 18, 2025 4 hours ago, mantouboji said: What the hell MOD: Your attitude of taking but not contributing and being abrasive is not welcome here. You received a warning now and will be unable to post to this forum for a few days. You were warned by several people many times before. If you still don't get the message and do not change course, expect to be blocked completely from Armbian. Be constructive, contribute or be gone. 0 Quote
Gabriel Negrisiolo Righi Posted August 19, 2025 Posted August 19, 2025 Latest armbian update 25.11 trunk 45 also breaks boot... 0 Quote
Werner Posted August 20, 2025 Posted August 20, 2025 7 hours ago, Gabriel Negrisiolo Righi said: Latest armbian update 25.11 trunk 45 also breaks boot... If you used edge, revert to 6.15 0 Quote
Gabriel Negrisiolo Righi Posted August 20, 2025 Posted August 20, 2025 If I run a update after changing kernel to edge it doesn't matter the version, it breaks boot, idk why, but it is installing dtb for kernel 6.16 even with kernel 6.13 or 14 installed, current kernel does not support analog audio out of the box and I managed to get it working a few times, so I'm stuck with edge kernel, did a update then changed to edge kernel and disabled armbian updates until this bug is fixed 0 Quote
vd3 Posted December 4, 2025 Posted December 4, 2025 hdmi audio doesn't work with the latest linux kernel 6.16.8 (edge). OS: Armbian Bookworm, latest build (v26.2.0-trunk.32). revert to 6.15.4 helps. Test Output (aplay -l): Kernel 6.16.8 (BROKEN): card 0: Codec [H616 Audio Codec], device 0: CDC PCM Codec-0 [CDC PCM Codec-0] Kernel 6.15.4 (WORKING): card 0: Codec [H616 Audio Codec], device 0: CDC PCM Codec-0 [CDC PCM Codec-0] card 1: HDMI [HDMI], device 0: ahub_plat-i2s-hifi i2s-hifi-0 [ahub_plat-i2s-hifi i2s-hifi-0] P.S. I am using the edge kernel branch because support for the analog audio jack on H616/H618 requires kernel 6.13 or newer. Currently, kernel 6.15.4 is the latest working version that provides both analog and HDMI audio. 0 Quote
robertoj Posted December 5, 2025 Posted December 5, 2025 (edited) I know of a way to install a specific kernel version: sudo apt install linux-image-edge-sunxi64=25.5.1 --> installs linux 6.14.8 But how do you install specifically linux 6.15.4? Also, have you checked if the newest linux version requires a dtbo to be activated in armbian-config? If you still can: compare the output of lsmod under 6.15.4 and under 6.16.8 Edited December 5, 2025 by robertoj 0 Quote
vd3 Posted December 6, 2025 Posted December 6, 2025 5 часов назад, robertoj сказал: how do you install specifically linux 6.15.4 go armbian-config - Wait warning message "The current OS (bookworm) is not a officially supported distro!" - Kernel - KER001 Use alternative kernels - Would you like to continue? <Yes> - Show only mainstream kernels on the list? <No> And there the list: Скрытый текст ┤ Select kernel ├───────────────────────────────┐ │ │ │ linux-image-legacy-sunxi64=25.11.2 v6.6.75 │ │ linux-image-legacy-sunxi64=25.8.2 v6.6.75 │ │ linux-image-legacy-sunxi64=25.8.1 v6.6.75 │ │ linux-image-legacy-sunxi64=25.5.1 v6.6.75 │ │ linux-image-legacy-sunxi64=25.2.3 v6.6.75 │ │ linux-image-legacy-sunxi64=25.2.2 v6.1.104 │ │ linux-image-legacy-sunxi64=24.11.1 v6.1.104 │ │ linux-image-legacy-sunxi64=24.8.2 v6.1.104 │ │ linux-image-legacy-sunxi64=24.5.1 v6.1.92 │ │ linux-image-legacy-sunxi64=24.2.1 v6.1.77 │ │ linux-image-current-sunxi64=25.11.2 v6.12.58 │ │ linux-image-current-sunxi64=25.8.2 v6.12.47 │ │ linux-image-current-sunxi64=25.8.1 v6.12.43 │ │ linux-image-current-sunxi64=25.5.2 v6.12.35 │ │ linux-image-current-sunxi64=25.5.1 v6.12.30 │ │ linux-image-current-sunxi64=25.2.3 v6.12.20 │ │ linux-image-current-sunxi64=25.2.2 v6.6.75 │ │ linux-image-current-sunxi64=24.11.1 v6.6.62 │ │ linux-image-current-sunxi64=24.8.4 v6.6.44 │ │ linux-image-current-sunxi64=24.5.4 v6.6.36 │ │ linux-image-current-sunxi64=24.5.1 v6.6.31 │ │ linux-image-current-sunxi64=24.2.1 v6.6.16 │ │ linux-image-edge-sunxi64=25.8.2 v6.16.8 │ │ linux-image-edge-sunxi64=25.8.1 v6.15.4 │ │ linux-image-edge-sunxi64=25.5.1 v6.14.8 │ │ linux-image-edge-sunxi64=25.2.3 v6.13.7 │ │ linux-image-edge-sunxi64=25.2.2 v6.12.16 │ │ linux-image-edge-sunxi64=24.11.1 v6.11.9 │ │ linux-image-edge-sunxi64=24.8.3 v6.10.9 │ │ linux-image-edge-sunxi64=24.5.1 v6.7.12 │ │ linux-image-edge-sunxi64=24.2.1 v6.7.4 then choose "linux-image-edge-sunxi64=25.8.1 v6.15.4 " mainstream kernels: linux-image-current-sunxi64/bookworm 25.8.2 arm64 Armbian Linux current kernel image 6.12.47-current-sunxi64 linux-image-edge-sunxi64/now 26.02.0-trunk arm64 [installed,local] Armbian Linux edge kernel image 6.16.8-edge-sunxi64 linux-image-legacy-sunxi64/bookworm 25.8.2 arm64 Armbian Linux legacy kernel image 6.6.75-legacy-sunxi64 5 часов назад, robertoj сказал: compare the output of lsmod under 6.15.4 and under 6.16.8 6.16.8: Скрытый текст ~# uname -r 6.16.8-edge-sunxi64 ~# lsmod Module Size Used by cdc_ether 12288 0 usbnet 28672 1 cdc_ether uas 20480 0 sprdwl_ng 323584 0 zram 36864 2 842_decompress 12288 1 zram 842_compress 16384 1 zram snd_soc_hdmi_codec 16384 0 sun50i_h6_prcm_ppu 12288 0 binfmt_misc 16384 1 cmdlinepart 12288 0 spi_nor 86016 0 dw_hdmi_i2s_audio 12288 0 dw_hdmi_cec 12288 0 sun8i_ce 36864 0 panfrost 69632 3 crypto_engine 12288 1 sun8i_ce governor_simpleondemand 12288 0 drm_shmem_helper 20480 1 panfrost gpu_sched 28672 1 panfrost display_connector 12288 0 cfg80211 368640 1 sprdwl_ng rfkill 24576 2 cfg80211 uio_pdrv_genirq 12288 0 uio 16384 1 uio_pdrv_genirq dm_mod 110592 0 dax 28672 1 dm_mod fuse 135168 1 configfs 36864 1 ip_tables 24576 0 x_tables 28672 1 ip_tables sunxi 16384 0 musb_hdrc 77824 1 sunxi phy_generic 12288 2 sunxi 6.15.4: Скрытый текст ~# uname -r 6.15.4-edge-sunxi64 ~# lsmod Module Size Used by cdc_ether 12288 0 usbnet 28672 1 cdc_ether uas 20480 0 bnep 16384 2 hci_uart 106496 1 btqca 16384 1 hci_uart btrtl 20480 1 hci_uart btintel 36864 1 hci_uart btbcm 20480 1 hci_uart bluetooth 491520 29 btrtl,btqca,btintel,hci_uart,btbcm,bnep ecdh_generic 12288 2 bluetooth ecc 32768 1 ecdh_generic sprdwl_ng 323584 0 sunxi_addr 12288 1 sprdwl_ng zram 32768 2 snd_soc_hdmi_codec 16384 1 snd_soc_sunxi_machine 16384 0 snd_soc_sunxi_ahub 20480 2 sun50i_h6_prcm_ppu 12288 0 binfmt_misc 16384 1 dw_hdmi_i2s_audio 12288 0 dw_hdmi_cec 12288 0 cmdlinepart 12288 0 snd_soc_sunxi_ahub_dam 12288 1 snd_soc_sunxi_ahub spi_nor 81920 0 panfrost 69632 3 governor_simpleondemand 12288 0 sun8i_ce 36864 1 drm_shmem_helper 16384 1 panfrost gpu_sched 28672 1 panfrost crypto_engine 12288 1 sun8i_ce cfg80211 364544 1 sprdwl_ng display_connector 12288 0 uio_pdrv_genirq 12288 0 uio 16384 1 uio_pdrv_genirq sprdbt_tty 24576 2 uwe5622_bsp_sdio 188416 2 sprdbt_tty,sprdwl_ng rfkill 24576 5 sprdbt_tty,bluetooth,cfg80211 dm_mod 110592 0 fuse 139264 1 dax 28672 1 dm_mod configfs 36864 1 sunxi 16384 0 musb_hdrc 73728 1 sunxi phy_generic 12288 2 sunxi In the working kernel 6.15.4, the following audio-related modules are loaded: snd_soc_sunxi_machine, snd_soc_sunxi_ahub, snd_soc_sunxi_ahub_dam In the broken kernel 6.16.8, these three modules are completely missing. Only the generic snd_soc_hdmi_codec is present, but it doesn't seem to bind to the hardware correctly without the sunxi-specific modules. 5 часов назад, robertoj сказал: have you checked if the newest linux version requires a dtbo to be activated in armbian-config I don't know how, but there the list in 6.16.8: Скрытый текст ~# ls /boot/dtb/allwinner/ overlay sun50i-a64-pinephone-1.1.dtb sun50i-h5-nanopi-neo2.dtb sun50i-h616-orangepi-zero2.dtb sun50i-a100-allwinner-perf1.dtb sun50i-a64-pinephone-1.2.dtb sun50i-h5-nanopi-r1s-h5.dtb sun50i-h616-x96-mate.dtb sun50i-a133-liontron-h-a133l.dtb sun50i-a64-pinephone-1.2b.dtb sun50i-h5-orangepi-pc2.dtb sun50i-h618-bananapi-m4-berry.dtb sun50i-a64-amarula-relic.dtb sun50i-a64-pinetab-early-adopter.dtb sun50i-h5-orangepi-prime.dtb sun50i-h618-bananapi-m4-zero.dtb sun50i-a64-bananapi-m64.dtb sun50i-a64-pinetab.dtb sun50i-h5-orangepi-zero-plus.dtb sun50i-h618-kickpi-k2b.dtb sun50i-a64-nanopi-a64.dtb sun50i-a64-sopine-baseboard.dtb sun50i-h5-orangepi-zero-plus2.dtb sun50i-h618-longanpi-3h.dtb sun50i-a64-oceanic-5205-5inmfd.dtb sun50i-a64-teres-i.dtb sun50i-h6-beelink-gs1.dtb sun50i-h618-orangepi-zero2w.dtb sun50i-a64-olinuxino-1G.dtb sun50i-h313-tanix-tx1.dtb sun50i-h6-inovato-quadra.dtb sun50i-h618-orangepi-zero3.dtb sun50i-a64-olinuxino-1Ge16GW.dtb sun50i-h313-x96q-lpddr3.dtb sun50i-h6-orangepi-3-lts.dtb sun50i-h618-transpeed-8k618-t.dtb sun50i-a64-olinuxino-1Ge4GW.dtb sun50i-h5-bananapi-m2-plus-v1.2.dtb sun50i-h6-orangepi-3.dtb sun50i-h618-yuzukihd-chameleon.dtb sun50i-a64-olinuxino-1Gs16M.dtb sun50i-h5-bananapi-m2-plus.dtb sun50i-h6-orangepi-lite2.dtb sun50i-h64-remix-mini-pc.dtb sun50i-a64-olinuxino-2Ge8G.dtb sun50i-h5-emlid-neutis-n5-devboard.dtb sun50i-h6-orangepi-one-plus.dtb sun50i-h700-anbernic-rg35xx-2024.dtb sun50i-a64-olinuxino-emmc.dtb sun50i-h5-libretech-all-h3-cc.dtb sun50i-h6-pine-h64-model-b.dtb sun50i-h700-anbernic-rg35xx-h.dtb sun50i-a64-olinuxino.dtb sun50i-h5-libretech-all-h3-it.dtb sun50i-h6-pine-h64.dtb sun50i-h700-anbernic-rg35xx-plus.dtb sun50i-a64-orangepi-win.dtb sun50i-h5-libretech-all-h5-cc.dtb sun50i-h6-tanix-tx6-mini.dtb sun50i-h700-anbernic-rg35xx-sp.dtb sun50i-a64-pine64-lts.dtb sun50i-h5-nanopi-k1-plus.dtb sun50i-h6-tanix-tx6.dtb sun55i-a527-cubie-a5e.dtb sun50i-a64-pine64-plus.dtb sun50i-h5-nanopi-m1-plus2.dtb sun50i-h616-bigtreetech-cb1-emmc.dtb sun55i-h728-x96qpro+.dtb sun50i-a64-pine64.dtb sun50i-h5-nanopi-neo-core2.dtb sun50i-h616-bigtreetech-cb1-manta.dtb sun55i-t527-avaota-a1.dtb sun50i-a64-pinebook.dtb sun50i-h5-nanopi-neo-plus2.dtb sun50i-h616-bigtreetech-cb1-sd.dtb sun50i-a64-pinephone-1.0.dtb sun50i-h5-nanopi-neo2-v1.1.dtb sun50i-h616-bigtreetech-pi.dtb ~# ls /boot/dtb/allwinner/overlay/ README.sun50i-a64-overlays sun50i-h5-usbhost2.dtbo sun50i-h616-i2c3-ph.dtbo README.sun50i-h5-overlays sun50i-h5-usbhost3.dtbo sun50i-h616-i2c4-pg.dtbo sun50i-a64-i2c0.dtbo sun50i-h5-w1-gpio.dtbo sun50i-h616-i2c4-ph.dtbo sun50i-a64-i2c1.dtbo sun50i-h6-i2c0.dtbo sun50i-h616-ir.dtbo sun50i-a64-pine64-7inch-lcd.dtbo sun50i-h6-i2c1.dtbo sun50i-h616-keys.dtbo sun50i-a64-pps-gpio.dtbo sun50i-h6-i2c2.dtbo sun50i-h616-light.dtbo sun50i-a64-spi-add-cs1.dtbo sun50i-h6-pwm.dtbo sun50i-h616-mcp2515.dtbo sun50i-a64-spi-jedec-nor.dtbo sun50i-h6-ruart.dtbo sun50i-h616-pwm1-ph3.dtbo sun50i-a64-spi-spidev.dtbo sun50i-h6-spi-add-cs1.dtbo sun50i-h616-pwm1-pi11.dtbo sun50i-a64-uart1.dtbo sun50i-h6-spi-jedec-nor.dtbo sun50i-h616-pwm2-ph2.dtbo sun50i-a64-uart2.dtbo sun50i-h6-spi-spidev.dtbo sun50i-h616-pwm2-pi12.dtbo sun50i-a64-uart3.dtbo sun50i-h6-spi-spidev1.dtbo sun50i-h616-pwm3-ph0.dtbo sun50i-a64-uart4.dtbo sun50i-h6-uart1.dtbo sun50i-h616-pwm3-pi13.dtbo sun50i-a64-w1-gpio.dtbo sun50i-h6-uart2.dtbo sun50i-h616-pwm4-ph1.dtbo sun50i-h5-analog-codec.dtbo sun50i-h6-uart3.dtbo sun50i-h616-pwm4-pi14.dtbo sun50i-h5-cir.dtbo sun50i-h6-w1-gpio.dtbo sun50i-h616-spi-spidev.dtbo sun50i-h5-cpu-clock-1.0GHz-1.1v.dtbo sun50i-h616-bananapi-m4-pg-15-16-i2c4.dtbo sun50i-h616-spidev0_0.dtbo sun50i-h5-cpu-clock-1.2GHz-1.3v.dtbo sun50i-h616-bananapi-m4-pg-17-18-i2c3.dtbo sun50i-h616-spidev1_0.dtbo sun50i-h5-cpu-clock-1.3GHz-1.3v.dtbo sun50i-h616-bananapi-m4-pg-6-7-uart1.dtbo sun50i-h616-spidev1_1.dtbo sun50i-h5-gpio-regulator-1.3v.dtbo sun50i-h616-bananapi-m4-pg-8-9-rts-cts-uart1.dtbo sun50i-h616-spidev1_2.dtbo sun50i-h5-i2c0.dtbo sun50i-h616-bananapi-m4-ph-2-3-uart5.dtbo sun50i-h616-tft35_spi.dtbo sun50i-h5-i2c1.dtbo sun50i-h616-bananapi-m4-pi-13-14-uart4.dtbo sun50i-h616-uart2-pg-rts-cts.dtbo sun50i-h5-i2c2.dtbo sun50i-h616-bananapi-m4-pi-15-16-rts-cts-uart4.dtbo sun50i-h616-uart2-pg.dtbo sun50i-h5-pps-gpio.dtbo sun50i-h616-bananapi-m4-pi-5-6-i2c0.dtbo sun50i-h616-uart2-ph-rts-cts.dtbo sun50i-h5-pwm.dtbo sun50i-h616-bananapi-m4-pi-7-8-i2c1.dtbo sun50i-h616-uart2-ph.dtbo sun50i-h5-spdif-out.dtbo sun50i-h616-bananapi-m4-sdio-wifi-bt.dtbo sun50i-h616-uart2-pi-rts-cts.dtbo sun50i-h5-spi-add-cs1.dtbo sun50i-h616-bananapi-m4-spi1-cs0-cs1-spidev.dtbo sun50i-h616-uart2-pi.dtbo sun50i-h5-spi-jedec-nor.dtbo sun50i-h616-bananapi-m4-spi1-cs0-spidev.dtbo sun50i-h616-uart3-pi-rts-cts.dtbo sun50i-h5-spi-spidev.dtbo sun50i-h616-bananapi-m4-spi1-cs1-spidev.dtbo sun50i-h616-uart3-pi.dtbo sun50i-h5-tve.dtbo sun50i-h616-gpu.dtbo sun50i-h616-uart4-pi-rts-cts.dtbo sun50i-h5-uart1.dtbo sun50i-h616-i2c0-pi.dtbo sun50i-h616-uart4-pi.dtbo sun50i-h5-uart2.dtbo sun50i-h616-i2c1-pi.dtbo sun50i-h616-uart5.dtbo sun50i-h5-uart3.dtbo sun50i-h616-i2c2-ph.dtbo sun50i-h616-ws2812.dtbo sun50i-h5-usbhost0.dtbo sun50i-h616-i2c2-pi.dtbo sun50i-h5-usbhost1.dtbo sun50i-h616-i2c3-pg.dtbo ~# cat /boot/armbianEnv.txt verbosity=1 bootlogo=false console=serial disp_mode=1920x1080p60 overlay_prefix=sun50i-h616 overlays=gpu extraargs=cma=256M extraargs=quiet loglevel=3 splash rootdev=UUID=bd56ff6d-... rootfstype=ext4 usbstoragequirks=0x2537.... tried to activate all dtbs in armbian-config - DTO001 - Manage device tree overlays noghing happend 0 Quote
robertoj Posted December 8, 2025 Posted December 8, 2025 Urgently go back to the previous selection of dtbos in armbian-config. Just having 1 undesired dtbo may interfere with everything else. Then try adding: overlays=analog-codec in armbianEnv.txt And check the lsmod again 0 Quote
vd3 Posted December 9, 2025 Posted December 9, 2025 these modules/configs are missing in 6.16.8 (vs 6.15.4): CONFIG_SND_SUN9I_HDMI_AUDIO=y CONFIG_SND_SOC_SUNXI_MACH=m CONFIG_SND_SOC_SUNXI_AHUB=m CONFIG_SND_SOC_SUNXI_AHUB_DAM=m CONFIG_SND_SOC_SUNXI_INTERNALCODEC=m CONFIG_SND_SOC_SUNXI_AAUDIO=m Could this be a problem? 0 Quote
robertoj Posted December 10, 2025 Posted December 10, 2025 Yes, One/some/all of those kernel configs may be needed for analog audio. Start with the activating configs that correlate with the missing kernel modules * snd_soc_sunxi_machine * snd_soc_sunxi_ahub * snd_soc_sunxi_ahub_dam If it still doesn't work, activate all the 2 other linux kernel configs: internalcodec and aaudio 0 Quote
vd3 Posted December 11, 2025 Posted December 11, 2025 I am talking about hdmi audio. Analog audio works fine on both kernels. HDMI-Audio doesn't work in 6.16.8 kernel. I'll keep using v25.11.0-trunk.190 with kernel 6.15.4 for now since HDMI works there. I might experiment with those configs later, or perhaps it will get fixed in a future version. Thanks. 0 Quote
robertoj Posted December 15, 2025 Posted December 15, 2025 On 12/11/2025 at 3:27 AM, vd3 said: I am talking about hdmi audio. Analog audio works fine on both kernels. HDMI-Audio doesn't work in 6.16.8 kernel. I'll keep using v25.11.0-trunk.190 with kernel 6.15.4 for now since HDMI works there. I might experiment with those configs later, or perhaps it will get fixed in a future version. Thanks. Posting this interesting event, in case someone can see why it worked: Banana Pi M4 zero (H618) gained HDMI audio when upgrading to Linux 6.12.30 https://forum.armbian.com/topic/50773-bpi-m4-zero-hdmi-audio/ But in this thread, there's a report that upgrading to 6.16.8 (from 6.15.4) lost HDMI audio 0 Quote
Refaz Saleem Posted December 26, 2025 Posted December 26, 2025 (edited) This is totally offtopic from the thread, but looking for people who have the device to identify. I have an orange pi zero 3, 2GB variant. I absent mindedly plugged a 12VDC power supply. And I obviously fried the marked SMD. Can anyone help me with the part number? I am figuring out a way to revive the board. Edited December 26, 2025 by Refaz Saleem 0 Quote
