going Posted February 25, 2024 Posted February 25, 2024 46 минут назад, greg396 сказал: And the fan wouldn't be active all the time and only if the cpu temperature raises to 50 degrees? These settings are located in the dtb file. To change them, you will have to make an overlay file with your settings. Read the messages above. 0 Quote
Michael Robinson Posted April 3, 2024 Posted April 3, 2024 https://manpages.ubuntu.com/manpages/noble/en/man8/fancontrol.8.html May help 0 Quote
Manuel Carvajal Posted June 15, 2024 Posted June 15, 2024 Hello, I bought the op5+ with the normal fan with 2 pin, but when starting the SBC, it starts at 100% speed keeping the chip at 32°C, is there a way to program the fan to only turn on from 45° ? I understand that it is not a programmable fan, just a simple one, I read earlier other posts about changing the stb file and editing the armbianenv file, is anything else needed? Thanks for the help 0 Quote
royk Posted June 15, 2024 Posted June 15, 2024 @Manuel Carvajal https://forum.armbian.com/topic/29253-temperature-and-fan-control-on-opi5/?do=findComment&comment=170261 0 Quote
Manuel Carvajal Posted June 16, 2024 Posted June 16, 2024 @royk thanks for answering, My system is: <Armbian 24.5.1 Bookworm with bleeding edge Linux 6.8.11-edge-rockchip-rk3588> I moved the file to /boot then run the command in terminal so that the line was added to the armbianEnv file, then I gave the poweroff order and when I restarted the system there was no change, the fan continued at 100% and kept the chip below 35°, is there anything else I can try? ArmbianEnv.txt GNU nano 7.2 verbosity=1 bootlogo=false Console=both overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588-orangepi-5-plus.dtb rootdey=UUID=2 c94c41f-b026-4717-82a6-3c0d968e559e rootfstype=ext4 user_overlays=orangepi-5-plus-pwmfan overlays=pwm0-m0 pwm0-m1 pwm0-m2 pwm1 -m0 pwm1-m1 pwm1-m2 sata1 sata2 usbstoragequirks=0x2537:0x1 066:u,0x2537:0x1068:u, 0x0bc2:0xab45:u, 0x0bc2:0xab44:u 0 Quote
royk Posted June 16, 2024 Posted June 16, 2024 (edited) @Manuel Carvajal Perhaps the overlays are interfering, you could try to remove all pwm overlays from ArmbianEnv.txt. How did you connect the fan? If you connected it correctly it should by default go on when it reaches 50 degrees celsius. If you use the overlay from here you could also change the temperature: https://forum.armbian.com/topic/29253-temperature-and-fan-control-on-opi5/?do=findComment&comment=170456 Edited June 16, 2024 by royk 0 Quote
Manuel Carvajal Posted June 16, 2024 Posted June 16, 2024 @royk Hello Edit the file back to: verbosity=1 bootlogo=false console=both overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588-orangepi-5-plus.dtb rootdev=UUID=2c94c41f-b026-4717-82a6-3c0d968e559e rootfstype=ext4 overlays=sata1 sata2 user_overlays=orangepi-5-plus-pwmfan usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u,0x0bc2:0xab45:u,0x0bc2:0xab44:u #overlays=pwm0-m0 pwm0-m1 pwm0-m2 pwm1-m0 pwm1-m1 pwm1-m2 sata1 sata2 And also I attach a picture of how the fan is connected. Rebooted the system without showing any change 🥲 Thanks for your help 0 Quote
royk Posted June 16, 2024 Posted June 16, 2024 @Manuel Carvajal Sorry I didn't read that you were using the 6.8 kernel. With the mainline kernel not everything works yet. With the Rockchip kernel (5.10.x and 6.1) it will work. 0 Quote
Manuel Carvajal Posted June 16, 2024 Posted June 16, 2024 And when changing kernel to 5.1 or the other you mention, is there any known error in the Orange pi5+? Since I installed open media vault 7 and with the previous isos with other kernel could not run docker compose 🥲 0 Quote
royk Posted June 16, 2024 Posted June 16, 2024 @Manuel Carvajal With the 6.1 kernel I don't have issues with docker compose: Home Assistant and Frigate 0 Quote
Manuel Carvajal Posted June 16, 2024 Posted June 16, 2024 @royk I will try another ISO that has the kernel you mention Armbian 24.5.1 bookworm vendor 6.1.43 minimal. Thanks Can I suggest some guide showing which isos are working or the ones that have less problems with this type of sbc? 0 Quote
MiikaS Posted July 12, 2024 Posted July 12, 2024 Just came here to say thanks! 😁 I have Orange Pi 5 Pro 16GB now with Armbian Ubuntu 24.04 XFCE and I have been struggling to get pwm to work on 40pin connector to put some fans on my case. Tried all of scripts etc. that I can found on the internet but none of them worked. And today found this thread tested overlay mentioned here and got it working instant! Below is my code that I put to test. Maybe some fine tuning with temps / fan pwm as I get it to daily use to see how it behaves. Try to get it as silent as I can on low loads. Now my CPU temps (celsius) has gone down from 49-51 to 40-41 on low loads and from 82-84 to 70-71 on full load. /dts-v1/; /plugin/; / { fragment@0 { target = <&fan>; __overlay__ { pwms = <&pwm13 0 255 0>; cooling-levels = <0 96 128 160 192 224 255>; rockchip,temp-trips = < 40000 1 50000 2 60000 3 65000 4 70000 5 75000 6 >; }; }; fragment@1 { target = <&pwm13>; __overlay__ { status = "okay"; pinctrl-0 = <&pwm13m2_pins>; }; }; }; Also I'm supper impressed how well this OS works compared to Orange Pi Ubuntu 22.04 and others that I have tested. So far just positive experience! I came from Linux Mint x64_64 world to ARM, with small side step while testing Raspberry Pi 5 and end up to Orange Pi 5 Pro as Raspberry Pi had too many problems on it. 0 Quote
haajee Posted December 4, 2024 Posted December 4, 2024 I read here something for the orangepi 5 and the orangepi 5 plus. But i has always without anyproblem running the script below. But it looks like PWM is not working or something? Even if i have enabled the option under device-tree-overlay in armbian-config: rk3588-pwm1-m0. orangepi5:pwm:# ls orangepi5:pwm:# I am running this Armbian version: orangepi5:/:# neofetch ##### root@orangepi5 ####### -------------- ##O#O## OS: Armbian 24.11.2 noble aarch64 ####### Host: Orange Pi 5 ########### Kernel: 6.1.75-vendor-rk35xx ############# Uptime: 14 mins ############### Packages: 1055 (dpkg) ################ Shell: zsh 5.9 ################# Terminal: /dev/pts/0 ##################### CPU: (8) @ 1.800GHz ##################### Memory: 1901MiB / 7937MiB ################# What do i wrong? #!/bin/bash if [ ! -d /sys/class/pwm/pwmchip1/pwm0 ]; then echo 0 > /sys/class/pwm/pwmchip1/export fi sleep 1 while [ ! -d /sys/class/pwm/pwmchip1/pwm0 ]; do sleep 1 done ISENABLE=`cat /sys/class/pwm/pwmchip1/pwm0/enable` if [ $ISENABLE -eq 1 ]; then echo 0 > /sys/class/pwm/pwmchip1/pwm0/enable fi echo 50000 > /sys/class/pwm/pwmchip1/pwm0/period echo 1 > /sys/class/pwm/pwmchip1/pwm0/enable # max speed run 60s echo 0 > /sys/class/pwm/pwmchip1/pwm0/duty_cycle sleep 5 echo 50000 > /sys/class/pwm/pwmchip1/pwm0/duty_cycle declare -a CpuTemps=(45000 40000 38000 30000 28000 0) declare -a PwmDutyCycles=(1000 5000 10000 15000 30000) while true do temp=$(cat /sys/class/thermal/thermal_zone0/temp) for i in 0 1 2 3 4 5; do if [ $temp -gt ${CpuTemps[$i]} ]; then DUTY=${PwmDutyCycles[$i]} echo $DUTY > "/sys/class/pwm/pwmchip1/pwm0/duty_cycle"; echo "temp: $temp, target: ${CpuTemps[$i]}, duty: $DUTY" break fi done sleep 1s; 0 Quote
Pharizna Posted June 3, 2025 Posted June 3, 2025 I have an Orange Pi 5 Ultra with Debian 12 (since there is no ARMBIAN version available for this model yet), and I would like to use the connected fan so that it turns on when it reaches a certain temperature and turns off when it cools down. Thank you in advance for your help 0 Quote
Werner Posted June 4, 2025 Posted June 4, 2025 11 hours ago, Pharizna said: since there is no ARMBIAN version available for this model yet config is there: https://github.com/armbian/build/blob/main/config/boards/orangepi5-ultra.csc DIY: https://docs.armbian.com/Developer-Guide_Overview/ Go for edge 0 Quote
JohnU Posted 5 hours ago Posted 5 hours ago I have several Orange Pi 5 Plus SBCs, and I have found that the fan works correctly if I install the Ubuntu desktop (Noble/XFCE) version of Armbian. But if I install the Minimal/IOT version of Ubuntu (Noble) the fan stays on constantly. I have not had any success trying to build my own orangepi-5-plus-pwmfan.dtbo (overlay), and I also tried copying the /boot/dtb/rockchip/rk3588-orangepi-5-plus.dtb file from the desktop version over top of the minimal version and rebooting, but my orangepi-5-plus would not even boot. it would be really nice if one of the maintainers could take a look at this and see if the minimal version is missing some component. I did see the following error in the journalctl -xe output after booting the minimal version: Jan 12 15:07:56 orangepi5-plus kernel: fan53555-regulator 0-0042: FAN53555 Option[10] Rev[1] Detected! Jan 12 15:07:56 orangepi5-plus kernel: rockchip-thermal fec00000.tsadc: Missing rockchip,grf property Jan 12 15:07:56 orangepi5-plus kernel: fan53555-regulator 0-0043: FAN53555 Option[10] Rev[1] Detected! Thank you, John 0 Quote
royk Posted 2 hours ago Posted 2 hours ago @JohnU Which kernel version of the desktop installation and which with the minimal? 0 Quote
JohnU Posted 2 hours ago Posted 2 hours ago desktop: $ uname -a Linux opi5p-cl1 6.1.115-vendor-rk35xx #1 SMP Fri Nov 21 14:02:48 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux minimal/iot: $ uname -a Linux orangepi5-plus 6.12.58-current-rockchip64 #3 SMP PREEMPT Thu Nov 13 20:34:41 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux Good call, I'm going to download the other Minimal/IoT image that uses kernel 6.1 and give it a try. Will let you know what happens. 0 Quote
JohnU Posted 1 hour ago Posted 1 hour ago So I tried running Armbian Minimal/IoT version with kernel 6.1 and the fan is operating normally (tested it with the stress command). I didn't realize i was working with two different kernel versions. Sometimes you just need another set of eyes to look at a problem. Thanks for the help, cheers! 0 Quote
