stephengrenfell Posted November 21, 2016 Posted November 21, 2016 Is there a Xenial image for NanoPi M1, or a way to “easily†build one ?. I see here https://www.armbian.com/nanopi-neo/ that there is a Xenial image for NanoPi Neo. I am asking because I would like to run HQPlayer's Network Audio Adapter on my NanoPi M1. And this doesn't run on Debian Jessie legacy as it needs libstdc++6 (>=5.2), but it does run on a NanoPi Neo with Xenial. Any advice appreciated. Thanks
tkaiser Posted November 21, 2016 Posted November 21, 2016 Is there a Xenial image for NanoPi M1, or a way to “easily†build one ?. http://image.armbian.com/betaimages/ But I've to admit I don't understand why there are no normal Xenial images available on the download page.
Igor Posted November 22, 2016 Posted November 22, 2016 But I've to admit I don't understand why there are no normal Xenial images available on the download page. It was added / corrected some time ago but we hadn't rebuild images since. @stephengrenfell Beta, wait until next image rebuild which is almost the same as Beta or DIY.
stephengrenfell Posted November 22, 2016 Author Posted November 22, 2016 Thanks for your prompt replies tkaiser and Igor. It was added / corrected some time ago but we hadn't rebuild images since. @stephengrenfell Beta, wait until next image rebuild which is almost the same as Beta or DIY. @Igor I am a bit confused by the phrase "wait until next image rebuild which is almost the same as Beta or DIY" Are you saying I should avoid using the Armbian_5.24.161121_Nanopim1_Ubuntu_xenial_3.4.113.7z image ?. ​"Next image rebuild" would mean a newer beta version, or beta becomes "standard" image, or both ?. Sorry if these are stupid questions.
Igor Posted November 22, 2016 Posted November 22, 2016 Just use "Beta" since there will not be much changes in here before we will put out a new regular v5.25 - in any case you will get an update to next version, when released.
stephengrenfell Posted November 22, 2016 Author Posted November 22, 2016 Just use "Beta" since there will not be much changes in here before we will put out a new regular v5.25 - in any case you will get an update to next version, when released. Ok, thanks.
