Hello
I use a ondroid c2 with armbian jammy.
Sometimes it hangs/freeze (i don't know what happends correctly....) I can't connect it via ssh. And if i connect it on hdmi port, i don't get any screen.....
So i read the syslogs and journalctl..... Mostly i can`t see what happens.
but today i see it and im wondering why some service try to run....
I had install motioneye and vncserver, but i tried to uninstall this for a long time......
today in the logs is a red line, that the services tried to run.
how can i remove this fully?????
Is it possible, that this error messages are the reason for the freezing?
(sorry for the image quality)
The first entry in the journyctl shows UEFI not found..... is this normaly???
thank you for your help!!!!
You are using some old randomly assembled development kernel. It is miracle that it worked this far. No development kernels receive end user support, because costs of supporting you goes sky high and you are involved in cost covering with cold 0%.
Free hint: use unchanged OS from download section, which comes with a kernel that received things 6.2.3-RC3 never will = stabilisation. That is troublesome enough.
