Machinist_Nick Posted November 27, 2016 Posted November 27, 2016 Hello, I have Debian 8 with XFCE Desktop installed on my Orange Pi 2. I downloaded the OS image from the orangepi.org a while ago and everything works OK except the WiFi. Does Armbian support the onboard WiFi of the OP2 ? If yes then I will change the OS today Thank you
Igor Posted November 27, 2016 Posted November 27, 2016 Wireless works, except some minor issues, on all boards that we support.
rufik Posted November 27, 2016 Posted November 27, 2016 On 11/27/2016 at 2:56 PM, Machinist_Nick said: Does Armbian support the onboard WiFi of the OP2 ? If yes then I will change the OS today Thank you Yes, it does. I have one running fine with wifi right now :-)
Machinist_Nick Posted November 27, 2016 Author Posted November 27, 2016 After formatting and copying Armbian image on my SD card I can verify that my Orange Pi 2 wifi works 100% correct ! I really needed that wifi as I use my OP2 to control my CNC machine which is in a place without any LAN network. Thank you very much! PS. Also installed Java 8 (JRE) an works good ! 1
