Today my second OPi arrived, a +2E. I already have an OPi PC which is working like a charm. So I ordered a +2E as well. I have an older monitor (Dell 2007WFP) with DVI connector and a native resolution of 1680x1050.
From previous experience from the OPi PC, I know that I had to run the 'h3disp' tool to set up this resolution and to make it work via an HDMI-DVI cable.
So I connected my new +2E through a normal HDMI cable to my 1080p TV, installed Armbian (Jessie desktop, with legacy kernel), updated to the latest release through 'apt-get update && apt-get dist-upgrade' and after a reboot ran 'h3disp -m 36 -d', just as I had with the OPi PC. After rebooting the +2E, the 1080p TV showed that the +2E was running in 1680x1050 mode and the green haze informed me that it was ready for DVI output. So far all looked well.
But to my (unfortunate) surprise, when I connected it to the Dell 2007WFP monitor, the monitor just went into sleep mode because it didn't recognize the signal. Trying from a cold boot didn't change the monitor's mind and stayed completely blank/off/sleep.
Since the monitor is very picky in what resolutions it can handle, I eventually found one that worked (-m 33, 1280x1024) but this is of course far from perfect.
So now I'm wondering why my PC is working perfectly in 'h3disp -m 36 -d', but this new +2E won't. Both systems are connected with the same cables and same power supply to the same monitor.
Both systems are updated to the latest available release.
Question
Patsie
Hi all,
Any tips and/or suggestions?
Link to comment
Share on other sites
23 answers to this question
