Helios64 - Armbian 23.08 Bookworm issues (solved)
ebin-dev
Go to solution Solved by ebin-dev,
Hi,
Not change millivolt value because i afraid to do a mistake
I just setting differentes values of freq
For moment i am at 400-1200Mhz and not lose connection...
Can you explain me command to change milivolt setting if i have futur courage or crazy spirit to try this idea?
And i have question, i install my 6.6.27 Kernel .deb build my self with official framework, then i reboot and do my pattern 3 times without crash...
Today i reboot and lose connection approximately 10min after boot when i set upper than 1400mhz... milivolt value work before reboot why not after, setting not change?
Now i do:
 git clone --depth=1 --branch=main https://github.com/armbian/build ; cd build/
./compile.sh kernel BOARD=helios64 BRANCH=current
dpkg -i *.deb to install Kernel 6.6.28 4 packages
reboot
and... uptime 18min... not loose connection ! i become crazy !
Edited by BipBip1981
@ebin-devnearly, I do not change the max value of the voltage (only the min and the central value):
change opp-microvolt = <0xc96a8 0xc96a8 0x1312d0>; to opp-microvolt = <0xdbba0 0xdbba0 0x1312d0>
though it could be you could be able to increase the max value, only I don't know if it is safe and how to know if so.
Note that in the edited dts (be it via armbian-config or else) you can replace the hex numbers by decimals. Ie you can write:
opp-microvolt = <900000 900000 0x1312d0>
It is way easier than computing the hex of the initial voltage with 75mV added.
@BipBip1981 best is to have a reproducible way to trigger the crash. Then you can tell when the issue is gone.
My test case is https://gist.github.com/prahal/316111da0a9b8cc0d0791d26659dc682
If you can run it without a crash with any kernel it is new to me. (I Believe I even got the linux 4.4 helios64  first kernel to crash with this test case).
With this patch to increase the min and "central" voltage (I believe requested voltage) by 75mV I cannot get my above test case to crash helios64 (mind there are other helios64 crashers so it best to run the test case in systemd emergency mode, but I managed to run it 100 times in "full" session mode):
EDIT: this patch is incomplete: since then I have added opp-00 an opp-01 with the same values as opp-02 (ir 900000 and the appropriate frequencies)
diff --git a/arch/arm64/boot/dts/rockchip/rk3399-kobol-helios64.dts b/arch/arm64/boot/dts/rockchip/rk3399-kobol-helios64.dts
index 77844650e2fe..34d94e4d6ada 100644
--- a/arch/arm64/boot/dts/rockchip/rk3399-kobol-helios64.dts
+++ b/arch/arm64/boot/dts/rockchip/rk3399-kobol-helios64.dts
@@ -1160,10 +1160,36 @@ &cluster0_opp {
        /delete-node/ opp06;
 &cluster1_opp {
        /delete-node/ opp08;
+       /delete-node/ opp02;
+       /delete-node/ opp03;
+       /delete-node/ opp04;
+       /delete-node/ opp05;
+       /delete-node/ opp06;
+       opp02 {
+               opp-hz = /bits/ 64 <816000000>;
+               opp-microvolt = <900000 900000 1250000>;
+       opp03 {
+               opp-hz = /bits/ 64 <1008000000>;
+               opp-microvolt = <950000 950000 1250000>;
+       opp04 {
+               opp-hz = /bits/ 64 <1200000000>;
+               opp-microvolt = <1025000 1025000 1250000>;
+       opp05 {
+               opp-hz = /bits/ 64 <1416000000>;
+               opp-microvolt = <1100000 1100000 1250000>;
+       opp06 {
+               opp-hz = /bits/ 64 <1608000000>;
+               opp-microvolt = <1175000 1175000 1250000>;
 &cpu_thermal {
        trips {
                cpu_warm: cpu_warm {
Mind this patch will not apply  (the cpu_thermal is from another patch of mine. But it gives you an idea of what you should write.
Also, you should account that crashes might be related to the load or the speed between transitions in the load. So a kernel version might help but will merely hide or render a crash less frequent. But it is not even a workaround, merely it makes the crash more or less frequent. It might be there is still a bug in the kernel that only affects helios64, but it is unlikely.
I think I always had the helios64 (even on the first boot after I mounted the box) because I have a mdadm raid10 with ext4 setup. The raid10 stress the board (and especially the big cpus).
If you could try my stress with your stable kernel that would help decipher if this kernel is really stable with regards to big cpu.
Mind that even with this cpu-b 75mV  workaround I still get crashes from my board, but not with my test case, and way less often. I don't have a test case or know what triggered these remaining crashes yet.
Also, the fact that upping by 75mV workaround crashes when cpufreq switching the big cpus might not fix the root cause. I am not able to analyze the schematic on my own. We would need someone to do so to get a clearer clue as to why this helps and why it could be required.
Finally the rk339 is told to be very robust. So it could be it sometimes works with invalid voltages but not all the time.
Edited by prahal
note that the patch is incomplete - ie missing opp-00 and opp-01
Hi,
This morning, i do cold boot and crash after few minutes (less than 10min...)
Boot is okok but lose ssh connection and to same with usb wire console, i have login and password ask but then i am block... (i can't find if problem hardware... systemd... software...)
I use reset bottom and after 15min uptime, i try the same and not lose connection, (i don't understand why not lose connection, i do nothing and  Helios64 seem Okok...)
i do: (3 times)
root@helios64:/tmp# ./cpufreq-switching
allocated 64MB
test: toggle freq before write
99/100
test: toggle freq before read
9/10, 99/100
allocated 64MB
99/100
9/10, 99/100
allocated 64MB
99/100
9/10, 99/100
root@helios64:/tmp#
Not crash/freeze and during this test, i have samba Time Machine backup work and lot of I/O Network and 1GO of data pass from my mac to helios.
I don't tune voltage, juste use 6.6.28 Kernel and my standard configuaration....
I run again you program and, i have again Time Machine Backup (samba share in background):
| | | | ___| (_) ___  ___ / /_ | || |
| |_| |/ _ \ | |/ _ \/ __| '_ \| || |_
|  _  |  __/ | | (_) \__ \ (_) |__   _|
|_| |_|\___|_|_|\___/|___/\___/   |_|
Welcome to Armbian-unofficial 24.5.0-trunk Bookworm with Linux 6.6.28-current-rockchip64
No end-user support: built from trunk
System load:   86%               Up time:       27 min    Local users:   2
Memory usage:  11% of 3.77G      IP:           10.0.0.155
CPU temp:      41°C               Usage of /:    47% of 14G
RX today:      1.5 GiB
[ General system configuration (beta): armbian-config ]
Web console: https://helios64:9090/
You have no mail.
helios64@helios64:~$ su -
Mot de passe :
root@helios64:~# cd /tmp/
root@helios64:/tmp# uptime ; ./cpufreq-switching ; uptime
 06:34:39 up 28 min,  3 users,  load average: 5.87, 4.75, 3.61
allocated 64MB
99/100
9/10, 99/100
 06:36:12 up 29 min,  3 users,  load average: 4.99, 4.71, 3.70
root@helios64:/tmp#
No Problem,
To conclude for moment, to my side; 6.6.28 stable but not at cold boot... stable after.
Something (hardware or software) when cold boot crash or do bug in linux software... and after reset buttom is Okok...
It's crazy i know ! (Possible problem in cold ramlog boot is /var/log full... i view is full just now... i will investigate next week...)
If you want next week, i build a Vanilla armbian from source with official framework and run your cpufreq-switching on it, i think i will have same this day with my standard configuration but maybe not with crash at cold boot
If you read my history message about Helios64 since about 3 years... it never stable with standard parameter.
I do many tests and to change Kernel and this day the Best Kernel i never use is 6.6.27 and upper because not crash at standard frequency Schedutil Governor
The very bad Kernel was 6.X branch, with thing kernel, Helios crash often just when i unlock my raid10 with LUKS cryptosetup
And le 5.15.(something)69 or just before was the best stable Kernel with 400-1400Mhz schelutil (i speak about this in very old post)
I try again you program, Time Machine Backup is finish...
 06:51:25 up 44 min,  3 users,  load average: 3.98, 4.58, 4.24
allocated 64MB
99/100
9/10, 99/100
 06:53:01 up 46 min,  3 users,  load average: 3.03, 4.09, 4.10
root@helios64:/tmp#
Not crash, now i go to work office and then pass a weekend with my familly, keep in touch next week
During this weekend, i run on my helios64 a script  do in loop:
echo check > /sys/block/md0/md/sync_action
and:
btrfs check --readonly  --check-data-csum  --progress /dev/disk/by-uuid/1d4e2c84-1c43-4d73-8acb-XXXXXXXXXXXXXX
If Monday morning when i back my Helios64 not crash/freeze, for me 6.6.28 is good Kernel.
Have a good day
OK - I am currently testing your opp-table-1 values (added the missing ones):
     opp-table-1 {
                compatible = "operating-points-v2";
                opp-shared;
                phandle = <0x0d>;
                opp00 {
                        opp-hz = <0x00 0x18519600>;
                        opp-microvolt = <0xdbba0 0xdbba0 0x1312d0>;
                        clock-latency-ns = <0x9c40>;
                opp01 {
                        opp-hz = <0x00 0x23c34600>;
                opp02 {
                        opp-hz = <0x00 0x30a32c00>;
                opp03 {
                        opp-hz = <0x00 0x3c14dc00>;
                        opp-microvolt = <0xe7ef0 0xe7ef0 0x1312d0>;
                opp04 {
                        opp-hz = <0x00 0x47868c00>;
                        opp-microvolt = <0xfa3e8 0xfa3e8 0x1312d0>;
                opp05 {
                        opp-hz = <0x00 0x54667200>;
                        opp-microvolt = <0x10c8e0 0x10c8e0 0x1312d0>;
                opp06 {
                        opp-hz = <0x00 0x5fd82200>;
                        opp-microvolt = <0x11edd8 0x11edd8 0x1312d0>;
                opp07 {
                        opp-hz = <0x00 0x6b49d200>;
                        opp-microvolt = <0x1312d0 0x1312d0 0x1312d0>;
Posted (edited)
2 hours ago, Trillien said:
I notice an error at the beginning of linux boot.
"mdadm: initramfs boot message: /scripts/local-bottom/mdadm: rm: not found"
can't confirm (my system is now based on Armbian 23.5.4):
# cat /var/log/syslog | grep mdadm
Edited by ebin-dev
allocated 64MB
99/100
9/10, 99/100
could you try my older test case code:
Turns out I did not compile my test case anew before pasting it to github gist and could be the new one I pasted there is not testing what I expected (in that it could be I changed it to try testing CPU frequency changes from max to min instead of each step).
Mind I use a binary of the test case I made long ago for my tests which is the one in the link above. I did not feel like sharing a binary test case was a good idea. I prefer you to be able to audit the code (or have someone audit it for you). , I did not have much time to devote to sharing my findings so I checked the source was fine but not if the test was the same as the one I used on my side to stress test the big cpu. Sorry.
It looks normal for you the test case I shared to you working fine as as far as I know 1.8GHz 1.2V and 408MHz at 825mV are pretty stable. They could crash I am not sure of that, but it would take more than 50 runs of the test for it to happen (at least it took 80 of them for the 600MHz to fail at 825mV).
Mind you should do at least 5 runs of the above test case to be somewhat confident you cannot get the cpu b to crash. The fact that it does not crash is not the point of the test. Its usefulness is that it nearly always crashes the big cpu on the first run.
EDIT: the previous gists I gave you as a test case was my v1. The current test case is https://gist.github.com/prahal/8fab73325eb0d7091ad7c4627bf8e25a which is in the other thread I linked in this comment.
Edited by prahal
tell why the first test case code was not the correct test case for the current issue
@ebin-devI believe initramfs messages are not written to syslog.
@Trillien you see that message on the serial console?
/usr/share/initramfs-tools/scripts/local-bottom/mdadm is part of the mdadm package which pcakaged by Debian. "dpkg -S /usr/share/initramfs-tools/scripts/local-bottom/mdadm", "apt policy mdadm"
Though it could be the fact that the generated initramfs lack/bin/rm is armbian specific. You might want to open a bug against armbian or at least open a topic in the forum. But nothing helios64 specific as far as I know. Could even be a Debian bug.
I don't even know if we ought to fix this missing /bin/rm for mdadm at the board level, even as a workaround.
Hi @prahal,
Yes, for few weeks I took the habit to use the serial console to better understand whether the boot crashes or is stuck at some steps (I've got a long long network config step with systemd-networkd).
The message appears after u-boot gives the hand to linux, and is part of the very first lines where linux checks the hard drive filesystem.
Hi,
For moment not crash with my pattern test.
Tthis evening i run cpufreq-switching-2-b and post result
Keep in touch
root@helios64:~#  btrfs check --readonly  --check-data-csum  --progress /dev/disk/by-uuid/1d4e2c84-1c43-4d73-8acb-14d5a7aa1c4d
Opening filesystem to check...
Checking filesystem on /dev/disk/by-uuid/1d4e2c84-1c43-4d73-8acb-14d5a7aa1c4d
UUID: 1d4e2c84-1c43-4d73-8acb-14d5a7aa1c4d
[1/7] checking root items                      (0:04:20 elapsed, 6258640 items checked)
[2/7] checking extents                         (0:22:26 elapsed, 613032 items checked)
[3/7] checking free space cache                (0:08:50 elapsed, 5519 items checked)
[4/7] checking fs roots                        (8:40:20 elapsed, 169002 items checked)
[5/7] checking csums against data              (35:54:03 elapsed, 2619191 items checked)
helios64@helios64:~$ cat /proc/mdstat
Personalities : [raid10] [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4]
md0 : active raid10 sdd1[0] sdc1[5] sde1[4] sda1[2]
      15627581440 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU]
      [=>...................]  check =  5.2% (821480320/15627581440) finish=1681.3min speed=146770K/sec
      bitmap: 0/117 pages [0KB], 65536KB chunk
unused devices: <none>
helios64@helios64:~$ uptime
 11:05:34 up 1 day, 22:02,  3 users,  load average: 2,98, 2,82, 2,78
Hi, i use cpufreq-switching-2-b and... Full Crash and reboot automatic after less than 15s...
After reboot not crash second try just after reboot...
for moment, my test pattern not crash, cpufreq-switching-2-b continu to do crash with cpufreq-switching-2-b.
I test 2 version here soon:
14 minutes ago, magostinelli said:
Any update regarding the new kernel? I'm on 6.6.8-edge, any time I powered up the helios64 I must reset it, nbecause it doesnb't start on the first attempt.
I am using 6.6.8 with the modified dtb (cache awareness, emmc with hs400, 75 mV bump for the big cores). It works perfectly fine. For your convenience I attach the dtb.
Since Helios64 is used throughout the day by several people - time for tests is very limited. Everybody is invited to test kernels and provide feedback here.
rk3399-kobol-helios64.dtb-6.6.8-L2-hs400-opp
Posted (edited)
37 minutes ago, prahal said:
@ebin-dev note that for a few days, I have upped the cpub opp3 and above to all 1.2V. I still had the box crash around once a day with 75mV.
But isn't that quite an improvement for your box ? Your latest suggestion (voltage increase of 75mV for the big cores) had a very positive effect !
It seems that also my helios benefits from that (but too early to be sure about it).
Edited by ebin-dev
TLDR; yes upping 75mV helps drastically, but is not enough at least for all frequencies.
Indeed, before upping by 75mV I could not boot most of the time (only "emergency" mode boot was reliable, ie no raid10 and services off).
But it seems 75mV is not enough to compensate for the issue at stake all the time.
The thing is I don't know what the root issue upping 75mV workaround is. Could be 100mV is enough, but this is a value based on testing, not a theory that requires 75mV (could be the proper value is upper or could be upping the voltage only helps to cope with voltage drops, making them less frequently drop below a certain value where cpub crashes).
The datasheet for the cpub regulator requires a bigger capacitor on voltage input than the helios64 one. But the weird thing is most rk3399 boards also use the same weak below-spec capacitor value at this place.
At my level (without understanding the hardware interactions or barely) the next step would be to test if my test case also crashes these other boxes with the same vin too low capacitor ... if they crash we could guess that the design is bad and without a bigger capacitor the regulator cannot deliver the voltage for cpub reliably.
Could be we could workaround this in software, but I am not qualified to tell that, at least at this point (I read about how these components work, but I am not an expert.
Mind also I tested the board way less for the time to come as now that it is quite reliable I started using it again (been down for months, then I extracted the motherboard to test with the less complex setup possible, in emergency mode).
NB: upping the voltage makes the CPU hotter, you might want to check the temperature values (with "sensors"). Mine were fine, way below the throttling temp of 80°C for the rk3399. Even with all opp3 and above at 1.2V. The issue seems mostly of keeping the power consumption low. But I wonder if it has a noticeable effect on helios64 power consumption.
Posted (edited)
There are only a few frequencies involved - at least on my board (see the transition tables in my other message in the parallel thread).
Upping the voltage by 75mV - as you suggested - helped my board to get rid of remaining few occasional issues during the boot process !
I am measuring the combined power consumption of Helios64 and two 2.5G switches (together 12.66W idle) - it does not seem to be affected at all by that small change.
Temperature reported by the Armbian welcome screen is 44 °C (ambient temp 19°C in the basement).
Is the remaining crash - once a day on your Helios64 - positively affected by upping the voltage to 1.2V for all states ?
If not it may be caused by something else.
Edit: I am currently testing 6.6.29 using a modified dtb (L2, hs400, opp up by 75mV)
Edited by ebin-dev
Linux 6.6.29 is stable on my system so far when used with the modified dtb (in particular applying the 75mV bump for the big cores, dtb attached below).
Could you give it a try ?
rk3399-kobol-helios64.dtb-6.6.29-L2-hs400-opp
Posted (edited)
I am using the default values (after various tests).
# cat /etc/default/cpufrequtils
ENABLE=true
MIN_SPEED=408000
MAX_SPEED=1800000
GOVERNOR=ondemand
Edit:
I would love to use schedutil but low priority tasks take three times as long with it to complete compared to ondemand (!!) (I tested that with a complete file scan of my nextcloud installation).
There was a lot discussion going on in armbian/build on github. Finally the Armbian default governor was set to schedutil again instead to ondemand. But schedutil parameters need to be fine-tuned such that EAS works correctly and from my own observations I can confirm that this is clearly not (yet) the case at least for the rk3399-kobol-helios64.dtb.
Anyway - you can set min_speed to 600000 for all cores (ondemand): it does not affect power consumption at all, but it renders your Helios64 more responsive.
And disable armbian-hardware-optimize - it degrades performance.
Edited by ebin-dev
Posted (edited)
It is not only about setting default cpufreq governors - there are also other settings essential for the network performance (see here).
And for Helios64 it is essential to set the irq smp_affinity:
for i in $(awk -F":" "/xhci/ {print \$1}" < /proc/interrupts | sed 's/\ //g'); do
        echo 20 > /proc/irq/$i/smp_affinity
done
for i in $(awk -F":" "/ahci/ {print \$1}" < /proc/interrupts | sed 's/\ //g'); do
        echo 30 > /proc/irq/$i/smp_affinity
done
If armbian-hardware-optimization is disabled or has vanished at least the irq smp_affinity should be set for sata (ahci) and for the 2.5G LAN interface (xhci) (i.e. in /etc/rc.local)
Edited by ebin-dev
Posted (edited)
In my case the new kernel runs fine!
Now I'm trying your last suggestion, i wrote here the command, so any users can try:
echo "ENABLE=true
MIN_SPEED=600000
MAX_SPEED=1800000
GOVERNOR=ondemand" > /etc/default/cpufrequtils
systemctl disable --now armbian-hardware-optimize.service
vi /etc/rc.local and insert before exit 0:
done
done
Edited by magostinelli
Posted (edited)
I gave up on 6.6.29/30: in general they are stable but the 2.5G interface causes trouble again (NETDEV WATCHDOG: end1 (r8152): transmit queue 0 timed out 8584 ms) although the code for the r8152 driver did not change since the release of 6.6.8.
Therefore I am back again on 6.6.8. It runs fine with the kernel defaults, irq smp_affinity set for ahci and xhci (see above) (armbian-hardware-optimize.service disabled) and it also benefits from the 75 mV opp increase (dtb attached).
Edited by ebin-dev
Posted (edited)
Hi,
On post below i report i have a stable helios64 with ebin-dev's file dtb for 6.6.29 with ondemand 408-1800mhz
Whereis a post explain how dtb file change for understand how that work?
You speak about end of cpufreq, armbian-hardware-optimize.service, irq smp_affinity, xhci and ahci... anyone have enough knowlege to explain this change ?
It's specific for helios64 support or that will be include on futur armbian for every boards/versions ?
Posted (edited)
TLDR;
The dtb contains a 75 mV bump for all fast cores as suggested by @prahal. You can find the opp-table-1 in this thread above (posted April 19). Use device tree compiler 'dtc' to apply your own changes (link).
The dtb further contains a fix that enables hs400 speed on emmc also proposed by prahal.
There is also a change for providing L2 cache information (this is all explained in this post) - and there is also a note that 6.6.29 is stable with those modifications.
However, 6.6.29 and 6.6.30 bugs me with frequent transmit queue timeouts while using the 2.5G interface (NETDEV WATCHDOG: end1 (r8152): transmit queue 0 timed out 8584 ms). I could not find any combination of settings to get rid of this. Therefore I switched back to 6.6.8 - it works perfectly fine - absolutely no issues.
I am on linux 6.6.30 with the following configuration were armbian-hardware-optimize.service is disabled and NAS performance is restored:
(The transfer rate from Helios64 to a MacBook Pro is 280MByte/s using a 2.5G switch in between and a 2.5G USB-C Dongle (StarTech US2GC30 (rtl8156bg)) attached to the Mac)
root@helios64:~# cat /etc/default/cpufrequtils
ENABLE=true
MIN_SPEED=600000
MAX_SPEED=1800000
GOVERNOR=ondemand
root@helios64:~# cat /etc/rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
for cpufreqpolicy in 0 4 ; do
    echo 1 > /sys/devices/system/cpu/cpufreq/policy${cpufreqpolicy}/ondemand/io_is_busy
    echo 25 > /sys/devices/system/cpu/cpufreq/policy${cpufreqpolicy}/ondemand/up_threshold
    echo 10 > /sys/devices/system/cpu/cpufreq/policy${cpufreqpolicy}/ondemand/sampling_down_factor
    echo $(cat /sys/devices/system/cpu/cpufreq/policy${cpufreqpolicy}/cpuinfo_transition_latency) > /sys/devices/system/cpu/cpufreq/policy${cpufreqpolicy}/ondemand/sampling_rate
done
done
done
exit 0
root@helios64:~# systemctl disable armbian-hardware-optimize.service
root@helios64:~# reboot
Edit: 'sampling_rate' reduced, it was not responsive enough - now 49000 (big cores) and 40000 (little cores) in microseconds. The nominal value is the same as 'cpuinfo_transition_latency'.
If you are happy with 6.6.29 or 6.6.30 go ahead. For your convenience I attach the modified dtbs.
rk3399-kobol-helios64.dtb-6.6.8-L2-hs400-opp rk3399-kobol-helios64.dtb-6.6.29-L2-hs400-opp rk3399-kobol-helios64.dtb-6.6.30-L2-hs400-opp
Edited by ebin-dev
Posted (edited)
Hi,
Thank for your files and informations.
To my side i don't use 2.5G interface because i don't have router 2.5G (and i don't do this tune: https://blog.kobol.io/2020/11/13/helios64-2-5g-ethernet-issue/ ).
For moment, no problem with armbian-hardware-monitor.service enable, i stay with this setting, if one day armbian version will be change to use your workaround upper, i use it.
I keep my 6.6.29 build and i build 6.6.30 for futur
Keep in touch
    echo 0 > /sys/devices/system/cpu/cpufreq/policy${cpufreqpolicy}/ondemand/io_is_busy
    echo 200000 > /sys/devices/system/cpu/cpufreq/policy${cpufreqpolicy}/ondemand/sampling_rate
done
FYI.  This is now included in armbian-hardware-optimization as of the 24.05 release of Armbian. which I no you are disabling.  Why are you disabling armbian-hardware-optimization?  What is it doing that is conflicting with your settings?
Posted (edited)
@SteeMan  I tested the latest changes in armbian-hardware-optimize with linux 6.6.8, 6.6.29 and 6.6.30 on a Helios64.
The above cpufreqpolicy does not work if 'io_is_busy' is set to 1 on Helios64 at least if the 2.5G interface is used (transmit queue timeouts). In armbian-hardware-optimize (a-h-o) it is set to 1. It must be set to 0 (kernel default).  If the sampling_rate is set to a more responsive value of 50000 the issues vanish with io_is_busy set to 1.
The optimizations for the 1G interface (eth0/end0) in the armbian script (see below) have the effect that those tasks are not performed in the NIC anymore (hardware) but on the CPUs in software. The effect is a huge additional load on the CPUs. Anyway such settings are not necessary with the new EEVDF scheduler anymore.
The reason why I am disabling armbian-hardware-optimize is that I need a stable system and I want to avoid any random and untested changes on my system.
echo 8 > /proc/irq/$(awk -F":" "/eth0/ {print \$1}" < /proc/interrupts | sed 's/\ //g')/smp_affinity
echo 7 > /sys/class/net/eth0/queues/rx-0/rps_cpus
echo 32768 > /proc/sys/net/core/rps_sock_flow_entries
echo 32768 > /sys/class/net/eth0/queues/rx-0/rps_flow_cnt
Edited by ebin-dev
