please provide me with link where can I download OS - armbian or ubuntu built for the board OrangePi 3B with RK3566 CPU.
http://www.orangepi.org/…tml
Thank you very much.
last image burned my ethernet port 😐
installed apt-get update / apt-get upgrade / reboot
and it stopped linking to my router even with static IP
tried my last ubuntu image and it's still not working
[    9.795160] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[    9.795199] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply property in node /ethernet@fe010000 failed
[    9.795234] rk_gmac-dwmac fe010000.ethernet: no regulator found
[    9.795246] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    9.795259] rk_gmac-dwmac fe010000.ethernet: TX delay(0x30).
[    9.795270] rk_gmac-dwmac fe010000.ethernet: RX delay(0x10).
[    9.795291] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    9.795367] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    9.795650] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    9.796042] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    9.796060] rk_gmac-dwmac fe010000.ethernet:         DWMAC4/5
[    9.796074] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    9.796083] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    9.796091] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    9.796099] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    9.796210] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    9.796222] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    9.796237] rk_gmac-dwmac fe010000.ethernet: rk_get_eth_addr: use serial to generate eth mac address: 00:00:a4:ab:5f:fd
[    9.796247] rk_gmac-dwmac fe010000.ethernet: rk_get_eth_addr: mac address: 00:00:a4:ab:5f:fd
[    9.796256] rk_gmac-dwmac fe010000.ethernet: device MAC address 00:00:a4:ab:5f:fd
[    9.796266] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    9.796277] rk_gmac-dwmac fe010000.ethernet: Using 32 bits DMA width
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 00:00:a4:ab:5f:fd  txqueuelen 1000  (Ethernet)
        RX packets 16  bytes 1710 (1.7 KB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 114  bytes 11820 (11.8 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 41
Edited by David Parushev
As a datapoint, I tried one of the archive images and it booted successfully (bookwork edge 6.5.2 xfce) on my sd card. However when I attempted armbian-config install to NVMe (with bootloader written to MTD of course) it did not boot.
Thanks for the image, I'm using the November 30 2023 release (Bookworm Kernel 6.6); everything is working fine except ethernet port:
- router shows a bunch of RX FCS errors, after some hours it's getting disconnect but works back if disconnect and reconnect cable
- I'm using two VLANs and for some reason packets always goes trough both VLANs, ignoring the routing table metric
Using it for SMB and Emby with external HDD (via USB 3.0) and it's working good.
I saw the debian CLI release, but was looking for the Ubuntu 22.04 CLI release.  So I tried to build my own (1st time) and when I got as far as the Armbian menu to choose the board, I didn't see the Orange Pi 3b in the list.  I checked github and could see it listed here
https://github.com/armbian/build/blob/main/config/boards/orangepi3b.csc
Not sure if this is what is used during the compile...
I also noted that Joshua Reik is going to start building for this board under his latest commits
Comparing v1.32...main · Joshua-Riek/ubuntu-rockchip (github.com)
Hopefully this will bring this board onto  Standard support soon.  It seems like a great price / performance SBC.
@magus  What ethernet issues are you getting?  Does it not work at all or just some times?
