Armbian for Amlogic S805 and S802/S812
masteripper
vor einer Stunde schrieb Rohaaq:
I see. But how exactly can I resolve these errors then?
what do you see ? what do mean resolve error ?
you do not need toothpick , you do not need recovery , only insert SD-Card and start the box
befor patch
bootloader-->internal memory-->android
after patch
without sd-card
bootloader-->sd-card-->usb-->internal memory-->android
or with sd-card
bootloader-->sdcard-->debian
@Rohaaq  A further comment that might help clarify.  Applying 'multiboot' is a one time operation.  It changes the boot environment which only needs to be done once.  So if you have properly applied multiboot (through either toothpick or update methods) then you are done and subsequently all you need to do is insert your sd card and it should first try to boot from there before falling back to booting android from emmc.  If it doesn't boot what you have on your sd card, you either haven't properly installed multiboot or your sd card is incorrectly setup.
befor patch
after patch
without sd-card
or with sd-card
Ohhh. Sorry, I didn't quite understand this the first time. Installing the .zip file definitely did something, so I reckon that's probably fine. I suppose then there's something wrong with how I've formatted the SD card, but as far as I understand the only thing I need to do is edit the one line of the uEnv.txt file. What else could I be missing?
Thanks for the help so far, I really appreciate it.
vor 7 Stunden schrieb Rohaaq:
this is still a beta for this tv-box.
yes when boot from sd-card you should edit uEnv.txt with right dtb file,
but it could happen that none of the dtb work.
if this happen, than please try one of the older Armbian S812 Version 5.xx with Kernel 3.10.xxx there is a higher chance that one dtb is correct for your box.
be aware the dtb files not changeable between 5.xx Kernel and 3.10.xx Kernel
Does anyone know this board?
I bought it from  TAOBAO in China.
It has S805 CPU.
SD Card Write Armbian_21.02.0-trunk_Aml-s812_bullseye_current_5.10.0_.img and meson8b-mxq.dtb, the network works, but the screen does not appear.
(At Armbian_5.67_Aml-s805_Debian_stretch_default_3.10.108_desktop_20181207.img & meson8b-mxq.dtb,  Display screen on.)
Someone helps the screen appear on Debian Bullseye.
Or I'd appreciate it if you could help me install the Retropie & Lakka.
Edited by 심승보
vor einer Stunde schrieb 심승보:
How about other dtb files from armbian 21.02.0 any other with display , its more easy to look at dtb files from same Kernel.
dtb files from 3.10.0 to 5.10 are more difference -->that why there are not compatible .
Thank you for your interest!
As you said, I tried other DTB files.
meson8b-odroidc1.dtb   The display is finally ON! But the network is dead.
meson8b-mxq.dtb   The display output is still dead. But the network works, so I can access SSH.
So I changed DTB to DTS and tried to fix it. But there's an error message like the picture below.
Can you give me some advice?
There is an error even if I don't fix the file and just do a two-way conversion.
DTB -> DTS -> DTB
vor 8 Stunden schrieb ArtSHIM:
your secound dtc string is wrong from dts to dtb
-I = input type you have dtb should  dts
-O = output type you have dts should dtb
-o = output file = ok
also odroid use realtek LAN but many HDMI CRC and HDMI i2c
ODROID C1 source file
mxq use internal(amlogic) LAN and standart HDMI output
MXQ source file
i thing your box need also the HDMI Communication CRC and i2c pins to work
Probably I ask really stupid/blindman question, but where do you guys download these old S805 images from?
Like recently mentioned "Armbian_5.67_Aml-s805_Debian_stretch_default_3.10.108_desktop_20181207.img"
I have really old MXQ_S805_V03 with WiFi: RTL8189ETV, and I want to use it as TV box for my grandma with Transmission and videoplayer onboard, but with WiFi enabled.
Years ago I managed to make it multiboot and installed on it Armbian desktop with dts which provided Eth only (I needed it these days, didn't care for Wifi)
Is such setup possible with old (3.1 kernel) images or should I think of converting box back to (buggy/luggy) Android one (if it's possible too)?
vor einer Stunde schrieb greenais:
look at this thread somewhere are the yandisk link
normally nand install was not possible because no nand driver in the old builds, impressive if you did it
why not test the new image with 5.xx kernel also RTL8189 should maybe now work
--> which Android One (11.x 9.x 8.x...) ? Never saw someone do this because android 4.4 was last build for S805 , this why android one had no driver for this box
That's the thing - I couldn't find anything relevant as "S805" is in the tread's name... My hope to find some reply with actual links to existing images just dissolved as a tiny puff)
I really don't remember how I achieved nand-install, probably - manually as @balbes150suggested somewhere...
I really don't mind to give try to modern (5.x kernel) images for S805, but can't find any - seems like only S812 are everywhere, could you give a hand, please?
Hey,
right now i´m running an Debian Buster lite (ownhanded dist. upgrade from Armbian_5.67_Aml-s805_Debian_stretch_default_3.10.108_20181207.img) on S805 on a 128gb SD Card.
Is it possible to clone this running System from the SD to the intern 128GB flash? Or is it better to run it on a fast SD Card?
Hey @all
i´m trying to connect a USB Webcam but i´m not getting video0 available.
The webcam is a Logitech C270. Is it not possible to run USB Webcams with this kernel?
Or is there a hidden switch that i didn't know about?
Quote
pi@aml:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 2c99:0002
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pi@aml:~$
Quote
pi@aml:~$ usb-devices
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480 MxCh= 1
😧 Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=01 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0002 Rev=03.10
S:  Manufacturer=Linux 3.10.108 dwc_otg_hcd
S:  Product=DWC OTG Controller
S:  SerialNumber=lm1
😄 #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=0mA
I:  If#=0x0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
T:  Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480 MxCh= 1
S:  SerialNumber=lm0
T:  Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  2 Spd=12  MxCh= 0
😧 Ver= 1.10 Cls=02(commc) Sub=00 Prot=00 MxPS= 8 #Cfgs=  1
P:  Vendor=2c99 ProdID=0002 Rev=01.00
S:  Manufacturer=Prusa Research (prusa3d.com)
S:  Product=Original Prusa i3 MK3
😄 #Ifs= 2 Cfg#= 1 Atr=c0 MxPwr=100mA
I:  If#=0x0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=02 Prot=01 Driver=cdc_acm
I:  If#=0x1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_acm
pi@aml:~$
My printer is working but as i wrote not the USB Webcams.
Best
i thing its a missing driver/modul , you should search on github for one and than "make" and "install" the driver because usb had recognize the right device
most Armbian build are very short in the addon package to be small in size and many funktion can be add later
