dg4gg8cb9s Posted September 15, 2023 Posted September 15, 2023 Hello! I’m trying to get a RockPi S connected by a slow ethernet connection with 10mbps (half or full duplex) but it doesn’t seem to work. If I test with a 100mbps connection, everything works fine and as expected. Using 10mbps, it seems to look fine, e.g. ethtool shows a link with 10mpbs, advertised modes look fine but the RockPi S doesn’t even retrieve an IP via DHCP. If configuring a static IP, no ping to any address beside the own IP address is possible. I’m using latest debian-based armbian 23.8.1 stable and performed apt-get update & upgrade. Anyone encountered the same problem and has some hints? Unfortunately I’m not a linux pro so unfortunately I’m a bit stuck but I’m happy to provide any missing information or execute commands on the RockPi S and post the results here. Cheers 0 Quote
SUNDraK Posted October 3, 2023 Posted October 3, 2023 (edited) I encountered the same issue. Armbian 23.8.1 Bullseye with Linux 6.1.50-current-rockchip64 Armbian 23.02.2 Buster with Linux 5.15.93-rockchip64 Working fine: Armbian 21.08.1 Bullseye with Linux 5.10.60-rockchip64 Armbian 21.08.1 Buster with Linux 5.10.60-rockchip64 using this to test: ethtool -s eth0 speed 10 duplex full autoneg on Edited October 3, 2023 by SUNDraK 0 Quote
dg4gg8cb9s Posted October 10, 2023 Author Posted October 10, 2023 Hi, great to know that it is obviously not a hardware problem with my board. How to proceed with this now? I'm quite new to armbian and not very familiar with Linux at all, so I'm willing to support solving the problem but I don't know what to do next. Any help or hint is greatly appreciated. 🙂 0 Quote
dg4gg8cb9s Posted October 30, 2023 Author Posted October 30, 2023 (edited) Hi, I created a bug: https://armbian.atlassian.net/browse/AR-1904 Rock Pi S Ethernet with 10mbps broken Edited October 30, 2023 by dg4gg8cb9s 0 Quote
brentr Posted November 27, 2023 Posted November 27, 2023 I confirmed that the RockPI-S built-in ethernet will not communicate at 10Mbit/s. (tested with an embedded board whose Ethernet is limited to 10Mbit/s) Will look into this in the coming weeks. Thanks for the report. 0 Quote
dg4gg8cb9s Posted February 23, 2024 Author Posted February 23, 2024 Hi, I noticed, that the bug has been fixed, many thanks and kudos to @brentr! 😃 I'm uncertain how to proceed now. Just looking at the dates, I suppose that the fix is not included in the current stable release as the release is from November and the fix has been merged end of December. Do I need to use the rolling image with the current and not the edge kernel in order to get 10MBit running again? Or is there any other way to include the fix in the current stable release? Cheers 0 Quote
SteeMan Posted February 23, 2024 Posted February 23, 2024 My understanding is that post 23.11, only supported boards get stable releases. All community maintained boards, like this one, only get rolling releases going forward. 0 Quote
Igor Posted February 23, 2024 Posted February 23, 2024 4 hours ago, SteeMan said: All community maintained boards, like this one, only get rolling releases going forward. Rockpi S was reverted back to supported as @brentr agreed to maintain it further. Latest Images at the download page https://www.armbian.com/rockpi-s/ should have this fix in, while kernel updates were not pushed to repository yet. For any kernel family. 0 Quote
dg4gg8cb9s Posted 11 hours ago Author Posted 11 hours ago Hi, sorry to bother you again. I recently tried to use latest Armbian 25.2.2 Bookworm and unfortunately 10mbps mode is not working. I suppose there is a regression. @brentr May I kindly ask you to have a look again at this topic? Cheers 0 Quote
