sooperior Posted December 28, 2016 Posted December 28, 2016 Hi! Is it only me or there are no updates to packages? Let me explain, I'm running jessie server on A20 latest stable kernel and when I run apt-get update, apt-get upgrade there are never updates available. I have experienced this for some of the latest releases and now I'm starting to thing that something is wrong with my system. Especially because I have a raspberry pi and that (yes, I know is raspbian) is getting updates to packages from time to time. I haven't modified or customized anything in the sources list. And the thing is that I'm getting updates for firmware/kernel when they are available. Any ideas? Is it something normal for armbian (/debian)?
Igor Posted December 28, 2016 Posted December 28, 2016 apt-get update / upgrade could be temporally broken at certain locations since we changed main download servers to another address yesterday. Actually not, since old is still working. Updates to kernel are 1-2 month or daily if you hook yourself to beta repository. For rest of the packages, they are comming from stock Debian / Ubuntu base and they should get updates from time to time. Just double check if your /etc/apt/sources.list looks similar to this and actually your system could be updated automatically. At least update / download part should be set to auto by default.
apollon77 Posted December 29, 2016 Posted December 29, 2016 Do an "apt-get update" and look if all repositories could be read successfully. I had the topic on a Wheezy Legacy system that because of the repo move to HTTPS the old configured HTTP URLS did not worked any longer. I needed to change them in /etc/apt/sources.list to https
sooperior Posted December 29, 2016 Author Posted December 29, 2016 Hi! Apollon77: Yes, all of them seem to download properly, no errors, timeouts, etc And I have checked the sources.list and looks pretty much the seem, I just miss backports, could that be the reason? armbian.list.txt sources.list.txt
sooperior Posted December 29, 2016 Author Posted December 29, 2016 Just in case I have added backports and same result, no updates available
wahlm Posted January 4, 2017 Posted January 4, 2017 Hi, unattended-upgrade is active by default. So updates (except kernel) are installed automatically. Have a look at /var/log/apt/history.log* for the installation history. Bye, wahlm From my a20lime2 jessie headless server: Start-Date: 2016-12-14 06:31:10Commandline: /usr/bin/unattended-upgradeUpgrade: apt:armhf (1.0.9.8.3, 1.0.9.8.4), libapt-pkg4.12:armhf (1.0.9.8.3, 1.0.9.8.4), apt-utils:armhf (1.0.9.8.3, 1.0.9.8.4), libapt-inst1.5:armhf (1.0.9.8.3, 1.0.9.8.4), apt-transport-https:armhf (1.0.9.8.3, 1.0.9.8.4)End-Date: 2016-12-14 06:31:25Start-Date: 2016-12-24 06:38:47Commandline: /usr/bin/unattended-upgradeUpgrade: libxml2:armhf (2.9.1+dfsg1-5+deb8u3, 2.9.1+dfsg1-5+deb8u4)End-Date: 2016-12-24 06:38:49 1
sooperior Posted January 4, 2017 Author Posted January 4, 2017 That was it, you really hit the point. When i check history.log (.1 .2) there are traces of the updated packages. Thank you very much for the tip. And by the way, I'm gladly suprised that armbian has this feature turned on, I could never imagine that (and I love to keep my system updated) Hi, unattended-upgrade is active by default. So updates (except kernel) are installed automatically. Have a look at /var/log/apt/history.log* for the installation history. Bye, wahlm From my a20lime2 jessie headless server: Start-Date: 2016-12-14 06:31:10Commandline: /usr/bin/unattended-upgradeUpgrade: apt:armhf (1.0.9.8.3, 1.0.9.8.4), libapt-pkg4.12:armhf (1.0.9.8.3, 1.0.9.8.4), apt-utils:armhf (1.0.9.8.3, 1.0.9.8.4), libapt-inst1.5:armhf (1.0.9.8.3, 1.0.9.8.4), apt-transport-https:armhf (1.0.9.8.3, 1.0.9.8.4)End-Date: 2016-12-14 06:31:25Start-Date: 2016-12-24 06:38:47Commandline: /usr/bin/unattended-upgradeUpgrade: libxml2:armhf (2.9.1+dfsg1-5+deb8u3, 2.9.1+dfsg1-5+deb8u4)End-Date: 2016-12-24 06:38:49
Igor Posted January 4, 2017 Posted January 4, 2017 I'm gladly suprised that armbian has this feature turned on, Yep. It's so long here, since early days, that I forgot about
sooperior Posted January 5, 2017 Author Posted January 5, 2017 Then I will disable /etc/update-motd.d/40-updates and save some miliseconds in the login process
olekvi Posted January 12, 2017 Posted January 12, 2017 Then I will disable /etc/update-motd.d/40-updates and save some miliseconds in the login process Speaking of update-motd.d, sorry for a bit off topic. Am I the only one feeling 30-sysinfo uses too much time? We're talking seconds on my Zero.
sooperior Posted January 13, 2017 Author Posted January 13, 2017 Is it really 30-sysinfo? My login takes also time but there are several processes involved in the login
olekvi Posted January 13, 2017 Posted January 13, 2017 Is it really 30-sysinfo? My login takes also time but there are several processes involved in the login Yes, disabling it in /etc/pam.d/sshd makes things go way faster, still not blistering fast, tough. Disable pam all together really helps, but that is not very useful :-)
