Hi there,
  I am trying to build the image using docker, but I get several "Segmentation fault (core dumped)" error messages and as result the build gets interrupted.
Would like to stick to docker build (I am running of fedora 39, and it automatically selects docker), as it looks to be far more efficient rather than running it into a VM.
Any idea on how could I get rid of this issue?
Thanks is advance!
Andrea
you can try
compile.sh PREFER_DOCKER=no
note that the docs specify  Ubuntu Jammy 22.04
https://docs.armbian.com/Developer-Guide_Build-Preparation/
I did this:
the catch is, building it in a systemd-nspawn container cannot use loop devices, hence, the build will fail at building the image, but it does the other 90% compiling things.
and fail to make the image at the end
Edited by ag123
On 11/28/2023 at 2:31 PM, Andrea said:
However the build seems to fail while installing packages, not building the image.
I think the problem is Qemu on host machine. If host is not exactly what its recommended, something like that could cause issues. Try PREFER_DOCKER=yes
Hi @Igor,
  thanks for the hint.
I thought PREFER_DOCKER=yes was the default, however I will give it a try.
Host OS is Fedora 39, kernel 6.5.12-300.fc39.x86_64 and qemu version 2:8.1.1-1.fc39.
Kind regards
