Skip to content
View in the app
Armbian Community Forums
Data Acquisition and processing on Orange Pi Zero
Featured Replies
I receive 16 bytes every 0.5 seconds. This should be saved as text or as MySQL table data.
Need to compare with all existing records , process and display it on 3.5 inch TFT LCD on SPI ( Notro fbtft ) and also save to SD Card . It should be broadcasted to a fixed Ip using TCPIP.
Can I use Orange Pi Zero with 512MB Ram ?
Can I partition Ram as RAMFS OR TMPFS to do all read only tasks thus save time for slow SD CARD writes ?
Can I first copy boot files and my app,tables to Ram and start from Ram ?
Any suggestions ?
Thanks
Hi, Orange Pi Zero could be a good choise.
I don't know what are the process exactly but may be Redis (all in RAM) with nodejs can do the job.
Redis save the database periodically on disk.
- https://redis.io/
- https://www.npmjs.com/package/ioredis
This looks like a bottleneck. Define "all".
16 bytes every half second will fill up 512 MB RAM in a approx. half a year. Not taking into account overhead, compression, other processes that use RAM.
You should plan for a maximum measurement duration significantly lower than that. And check the performance of your DAQ system for the end of the planned measurement period, i.e. with a large set of simulated data already in memory.
  • Author
Hi Newbie,
Thanks for your suggestion.
Idea is to save the AQ logs to SD card of Pi-Zero.
Part of RAM is planned to be used as RAMFS where the application resides and gets executed from there. ( say 128MB) . This may be needed to minimise the SDIO read/write and give max time to SD ONLY to save AQ logs.
The Balance RAM ( 512-128) = 384MB be used as Program area.
The questions are:
a. Can the Kernel and application be transferred to RAMFS on first boot ?
b. If yes or No, what can be transferred to RAMFS to give minimum load to SDIO ( SD card) to avoid any crashes due to excessive resources usage.
Is there any other way that can be thought of ?
Thanks
Nbird
a and b are already optimised to more or less full degree, we have 10 minutes fs commit time by default - fstab: commit=600. Further put logs to tmpfs - ram, we used to have this by default too, but since we upgraded to systemd, we would need to rewrite scripting ...
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
