Werner Posted November 16 Posted November 16 6 minutes ago, Assilsa said: Supervised works perfectly with add-ons on this image? We don't know if it works perfectly. We cannot afford doing extensive testing. We rely on user feedback in that matter. 1 Quote
Assilsa Posted November 16 Posted November 16 Sounds Good, will Try it 🙂 Thank u for the fast response 0 Quote
Igor Posted November 21 Author Posted November 21 New version (v24.11) with even more targets has been released. Home assistant takes few minutes and might require reboot at first install or there will be some errors related to privileges. This gets away after waiting few minutes and reboot. Testing was done on Odroid M1. Latest: https://github.com/armbian/distribution/releases/tag/24.11.1 Previous: https://github.com/armbian/distribution/releases/tag/24.8.4 0 Quote
Dang Ky Posted Friday at 05:07 AM Posted Friday at 05:07 AM After I run Home Asssistant on Rock 5C, do install in ssd USB, sometime error "compile.sh[5185]: Unhealthy detected, restarting". And my Home Assistant not stable, sometime self-restart. How to fix? 0 Quote
Igor Posted Friday at 01:20 PM Author Posted Friday at 01:20 PM 8 hours ago, Dang Ky said: How to fix? This is fix, just perhaps too noisy. If you don't want to see those messages, change this on your system: https://github.com/armbian/os/commit/36fc679bbb38cdff4223e14a0552c638f577d56b Without you will have your HA always unhealthy. Background: https://github.com/home-assistant/supervisor/issues/4381 8 hours ago, Dang Ky said: Unhealthy detected, restarting This should happen only once after reboot. As we are running a vendor kernel on those devices, there could be issues beyond our control. Once LTS kernel will be available for this HW, we recommend to switch to it. I am running HA, with the exact same method, on Odroid N2 running mainline kernel. Everything works perfectly stable for months. 0 Quote
