pkfox Posted January 31 Share Posted January 31 Hi all, I've just booted my NanoPi M4 V2 after not using it for a year or so and when I log in via ssh I'm told the / usage is at 100% - I've deleted all logs and the usual suspects but to no avail uname gives Linux M4V203 5.10.63-rockchip64 #21.08.2 SMP PREEMPT Wed Sep 8 10:57:23 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux I'm using a 32gb SD card df -h gives Filesystem Size Used Avail Use% Mounted on udev 1.9G 0 1.9G 0% /dev tmpfs 387M 41M 346M 11% /run /dev/mmcblk1p1 29G 29G 0 100% / tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup tmpfs 1.9G 4.0K 1.9G 1% /tmp /dev/nvme0n1p1 458G 73M 434G 1% /mnt/Docker /dev/nvme0n1p2 458G 280G 155G 65% /mnt/music /dev/zram0 49M 20M 26M 44% /var/log tmpfs 387M 0 387M 0% /run/user/0 any ideas ? 0 Quote Link to comment Share on other sites More sharing options...
going Posted January 31 Share Posted January 31 1 час назад, pkfox сказал: any ideas ? Remove the SD card and use the SD-USB adapter. Use another computer with a Linux OS. Check the file system on the sections of the SD card. This is a common Linux issue. There are a lot of instructions on the Internet. 0 Quote Link to comment Share on other sites More sharing options...
pkfox Posted January 31 Author Share Posted January 31 Thanks @going what command do I use to check the file system once I have the sdcard in an adapter ? 0 Quote Link to comment Share on other sites More sharing options...
going Posted January 31 Share Posted January 31 26 минут назад, pkfox сказал: what command do I use to check the file system set command: > ls /usr/sbin | grep fsck > sudo fsck --help > man fsck dmesg | tail ..... [29283.479644] sdf: sdf1 [29283.482102] sd 4:0:0:0: [sdf] Attached SCSI removable disk [29283.882104] EXT4-fs (sdf1): mounted filesystem with writeback data mode. Opts: errors=remount-ro. Quota mode: none. fs is mounted!! > df -h .... /dev/sdf1 7,2G 1004M 6,1G 14% /run/media/leo/armbi_root > sudo umount /run/media/leo/armbi_root > sudo fsck.ext4 /dev/sdf1 e2fsck 1.46.4 (18-Aug-2021) armbi_root: clean, 28006/470112 files, 295400/1907712 blocks it is good The first three lines are for reference dmesg | tail - Get information where the SD card was mounted The disk with the SD card file system must be unmounted. If the fsck team finds bad blocks, it will ask questions. They must be answered in the affirmative. Sometimes it takes a long time. > sudo fsck.ext4 -fcy /dev/sdf1 e2fsck 1.46.4 (18-Aug-2021) Checking for bad blocks (read-only test): done armbi_root: Updating bad block inode. Pass 1: Checking inodes, blocks, and sizes Pass 2: Checking directory structure Pass 3: Checking directory connectivity Pass 4: Checking reference counts Pass 5: Checking group summary information armbi_root: ***** FILE SYSTEM WAS MODIFIED ***** armbi_root: 28006/470112 files (0.1% non-contiguous), 295400/1907712 blocks fsck.ext4 -fcy - it is forced to check and fix (It took about 7 minutes). 0 Quote Link to comment Share on other sites More sharing options...
pkfox Posted January 31 Author Share Posted January 31 Thank you very much for your detailed instructions I will try them when I get home and let you know how I get on 0 Quote Link to comment Share on other sites More sharing options...
pkfox Posted February 1 Author Share Posted February 1 Hi @going I ran fsck fsck.ext4 -fcy /dev/sdb1 e2fsck 1.44.5 (15-Dec-2018) Checking for bad blocks (read-only test): done /dev/sdb1: Updating bad block inode. Pass 1: Checking inodes, blocks, and sizes Pass 2: Checking directory structure Pass 3: Checking directory connectivity Pass 4: Checking reference counts Pass 5: Checking group summary information /dev/sdb1: ***** FILE SYSTEM WAS MODIFIED ***** /dev/sdb1: 87173/1869120 files (0.8% non-contiguous), 7650362/7709728 blocks so I mounted it mount /dev/sdb1 /mnt/m4v203 and checked disk space df -h /mnt/m4v203/ Filesystem Size Used Avail Use% Mounted on /dev/sdb1 29G 29G 0 100% /mnt/m4v20 0 Quote Link to comment Share on other sites More sharing options...
going Posted February 1 Share Posted February 1 1 час назад, pkfox сказал: mount /dev/sdb1 /mnt/m4v203 and checked disk space df -h /mnt/m4v203/ Filesystem Size Used Avail Use% Mounted on /dev/sdb1 29G 29G 0 100% /mnt/m4v20 du -hs /mnt/m4v20/home ls -al /mnt/m4v20/ 0 Quote Link to comment Share on other sites More sharing options...
pkfox Posted February 1 Author Share Posted February 1 (edited) @going the card is now back in the NanoPi and still reports that it is full up - thank you for your time and patience When I ssh into m4v203 I see this Quote Welcome to Ubuntu 18.04.6 LTS with Linux 5.10.63-rockchip64 System load: 0.26 0.53 0.54 Up time: 3:48 Memory usage: 5 % of 3863MB IP: 10.10.1.16 CPU temp: 35°C Usage of /: 100% of 29G [ General system configuration (beta): armbian-config ] Edited February 1 by pkfox Add text 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted February 1 Share Posted February 1 It reports it is full, probably because it is full. The last set of commands @going suggested you run are to try to figure out what has filled up the storage. du -s will be your tool in looking as where the storage is being used. Google for how others use this command for this purpose. 0 Quote Link to comment Share on other sites More sharing options...
going Posted February 1 Share Posted February 1 1 час назад, pkfox сказал: When I ssh into m4v203 I see this du -hs /home ls -al / 😄 🤣 😁 0 Quote Link to comment Share on other sites More sharing options...
pkfox Posted February 2 Author Share Posted February 2 Hi @going I gave up an reflashed in the end - the du -hs /home command gave me 200k all I had in /home was a folder with .bashrc in it - there is no way that card was full - thanks for trying to help me 0 Quote Link to comment Share on other sites More sharing options...
going Posted February 2 Share Posted February 2 (edited) 1 час назад, pkfox сказал: I gave up an reflashed in the end - the du -hs /home command gave me 200k all I had in /home was a folder with .bashrc in it - there is no way that card was full - thanks for trying to help me Sometimes there may be large files in the root (/*). sometimes a lot of files can accumulate in the /var folder, for example, in the apt cache. Just go through them all. Run the 'mc' command. Go to the root of the file system. - find "show size" in the menu. Find the folder with the maximum size. Go to it. Repeat "show size" Edited February 2 by going add screenshot_mc 0 Quote Link to comment Share on other sites More sharing options...
pkfox Posted February 3 Author Share Posted February 3 Pretty sure I did all that (without mc) and couldn't find anything of note - I've had this before and ended up reflashing - i would like to get to the bottom of it though. 0 Quote Link to comment Share on other sites More sharing options...
