Andrea Posted February 12, 2024 Posted February 12, 2024 Hello all, I am receiving this error while building the image: Error: Partition(s) 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64 on /dev/loop0 have been written, but we have been unable to inform the kernel of the change, probably because it/they are in use. As a result, the old partition(s) will remain in use. You should reboot now before making further changes. I am . This happens in the partitioning phase (lib/functions/image/partitioning.sh line 229, using branch "v23.11" commit bba856bb57823556e12fa180284c7490fdd3708d😞 run_host_command_logged partprobe "${LOOP}" Investigated a lot, tried to unmont the image, losetup -d the loop device but nothing helped. Can you please help me? Kind regards, Andrea
Andrea Posted February 12, 2024 Author Posted February 12, 2024 Hi @Werner, yes of course: https://paste.next.armbian.com/pakisigigu
Igor Posted February 12, 2024 Posted February 12, 2024 Perhaps this ? https://github.com/armbian/build/issues/6132
Andrea Posted February 12, 2024 Author Posted February 12, 2024 Despite the fact the problem is very similar, I am not using WSL2 to build. I am using a Ubuntu VM : Ubuntu 22.04.3 LTS (GNU/Linux 5.15.0-94-generic x86_64) andrea@armbian:~$ uname -a Linux armbian 5.15.0-94-generic #104-Ubuntu SMP Tue Jan 9 15:25:40 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux User adeepn confirms that it happens also on Ubuntu w/kernel 5.15. I will try to upgrade to 6.1 and let you know. Thanks for the hint
Solution Andrea Posted February 12, 2024 Author Solution Posted February 12, 2024 I confirm that using an updated kernel (6.7.3) the build succeds. Linux armbian 6.7.3-060703-generic #202401311935 SMP PREEMPT_DYNAMIC Thu Feb 1 00:46:47 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux Thank you very much!
going Posted February 15, 2024 Posted February 15, 2024 12.02.2024 в 14:35, Andrea сказал: Can you please help me? partprobe /dev/loop2 Error: Partition(s) 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16,........ ........... This is the result of incorrect processing of operations with the loop device in the assembly system itself. Some versions of Linux kernels have a delay with these operations, and the BASH script continues without waiting for the operation to complete. As a result, we see a lot of open loop devices. @Igor Are further explanations required?
Igor Posted February 15, 2024 Posted February 15, 2024 27 minutes ago, going said: Are further explanations required? I don't know why / when this bug was introduced but kernel upgrade workarounds it.
going Posted February 15, 2024 Posted February 15, 2024 37 минут назад, Igor сказал: I don't know why / when this bug was introduced but kernel upgrade workarounds it. Working with loop devices in BASH is similar to opening a file for reading and closing it after completing the operation in the C language. In the build system, there is a code that remembers the open loop device and there is a code that should delete\close the loop device. But for some reason this does not happen. May it be necessary to wait for the operation to complete? The problem is in the build system. Perhaps the new kernel is faster?
