On 7/31/2025 at 8:40 AM, lebestnoob said:
I've started using an MXQ-4K box as a file server, but writing files over the network is slow, with speeds in the 3-5 MB/s range. Reads cap out at the fast ethernet link speed (~11 MB/s). I don't believe there's a CPU, disc, or RAM bottleneck as the speeds are the same regardless of file size or transfer protocol as SMB, FTP, and WebDAV all give me the same speeds, and checking in htop, they are never at 100%. These speeds are also observed when downloading a file from another device on the local network using wget or aria2 while sshed into it, with faster speeds on other devices. As far as I can tell, iostat doesn't suggest high io wait times are the culprit. If it matters, I'm writing to an external USB HDD, but the write speeds are the same when writing to the SD card through the network, which makes me believe this is not an issue. If I write a ~1.0GB file using dd to the HDD while sshed into it with `dd if=/dev/random of=/mnt/disk/tmp.bin bs=64k count=16500 conv=fdatasync`, it gives a local disk speed of ~20 MB/s, which is more than enough to saturate the 100 mbps link. Has anyone else experienced similar results? Are the slow network speeds just a limitation of the onboard nic/hardware? I'm open to suggestions.
what filesystem your drive using? usually if its WIndows Filesystem, that's where you get some performance penalty and NTFS is the one being the worst of all. Last time I tried using a ext4 formatted usb3 flash drive and was able to read/write to drive at 11MB/sec over wired LAN, no tweaks on samba server were done other than setting up some shares.
I'm using an ext4 formatted 1TB drive, connected with a usb 3.0 ASMedia SATA controller. The drive reads and writes faster on other machines connected with the same adapter, so I'm confident it's not the hard drive or adapter. I also tried using BTRFS on the drive and it provides similar results. Now that I'm thinking about it, could it be the uas driver? I'll have to experiment with that.
this device has only usb2.0 , also when usb3.0 connector only usb2.0 pinout . also lan is most only 100mbit still with 1gbit label ,  the interface by chip only 100mbit so 11MB/s are in spec
Posted (edited)
its probably just your client side OS. try using the "use sendfile = yes" option on your smb.conf and see if theres performance improvement.
else, try using the legacy image (if your board is old enough to support it) as that one im using.
Edited by remlei
Posted (edited)
Hello, I really messed up, flashed on eMMC a rk3399 armbian image on my rk322x and now the LED is just blue with a hint of red, tried to short the eMMC 7-8th pins/reset button+usb but nothing.
The device doesn't boot form sd card either, neither multitool nor any flashed image, just stuck on blue LED.
I really don't know what to do.
Edited by BernardoT
vor 1 Stunde schrieb BernardoT:
that because this is the wrong thread , here we are at Rk322x ,also our multitool are the wrong one , maybe multitool for rk33xx helps
Edited my post for clarification, I've flashed a 3399 image on my 322x
Hello
Then you're doing it wrong. Bypassing the eMMC shorting the CLK pin to ground will definitely force the boot from sdcard, or fall into maskrom mode if no sdcard is in the slot.
I wonder what debug info is prompted on the serial port (if any) and if the device is recognize if you connect the OTG USB port to a PC with a male-to-male cable
Posted (edited)
I've made it! I hard to press really hard on the pins to make it work. Thank you.
Edited by BernardoT
Posted (edited)
Hello, I am new to arm board, I had this android tv stick called S moon mx10 5G, it have rk322x cpu, 2GB Ram, and ap6330 wifi chip. I tried armbian on this device but wifi chip was not detected, I tried using "rockchip-rk3318-box-wlan-ap6330.dtbo" as user_overlays, but still not working, could anyone tell me how to make this wifi chip working on rk322x armbian?.
I attached some files for information:
dmesg.txt s_moon_mx10_5g.dts
Edited by tofamus30
Try different LED-config then its also changing the hardware for the SD-Card interfaces = WiFi module but prepare that it can ending with not booteball system.
@hexdump hey mate , do you know if new armbian image still uses an offset of 8192 sector ? i'm trying the workaround you proveded in first page for linux hanging excatly after 60 seconds , but it only worked with multitool.img . with new armbian images it doesn't even boot after applying the trick 🙁
thanks
rk322x armbian images never used the offset of 8192 sectors, only the multitool has such offset to increase compatibility with stock images
@jock well thanks but I already figured that part out 😊  my problem right now is that i can't find a single distro that works with my box . almost every one (even multitool) goes to a black screen and freezes excatly after 60 seconds . the best thing i could find was a android rom that have the same problem but in excatly 30 minute after booting up ! i did this stupid thing that did not backed up my original rom before writing to internal emcp flash 🤦‍♂️ if i can find any version that doesn't have this problem , i know how to merge armbian rootfs with it !
thank you again !
Hi @jock,
Thanks a lot for your work on these RK322x boards.
I have an MXQ Pro (RK3229, 2GB RAM / 16GB eMMC). I was able to boot Multitool from SD and successfully create a backup of the eMMC. However, when I burn an Armbian image to flash, the box doesn’t boot—LED blinks, but nothing shows up on HDMI. I’ve tried a few different images with the same result.
Could you please guide me on how to debug this?
Open the box, read the silkscreen on the board, run rk322x-config and configure according to silkscreen name.
Probably you have a r29/h20 board
Hi @jock,
Thanks for the quick response. I’ve opened the box and attached the board images. On the back it says R29-MXQ-V2.1-221#.
Sorry if I’m missing something—I’m a beginner. I thought rk322x-config runs only after Armbian boots. In my case, after flashing the image to eMMC and removing the SD, the box just blinks LED with no HDMI output. Only Multitool runs fine from SD. How can I run rk322x-config in this situation?
Thanks again.
Posted (edited)
44 minutes ago, fabiobassa said:
I guess you  have a box with NAND  , not emmc
Hi @fabiobassa
Thanks for your input. I believe this board has eMMC only—the storage chip is KLMAG1JENB-B041 (image attached, RAM visible too). Multitool also confirms eMMC when attempting to burn an image.
Interestingly, CPU-Z shows Rockchip 3066 logo, while ADB reports RK3229. I trusted the ADB output more, and seeing Multitool running, I believe it’s an RK3229 only. I haven’t removed the heatsink yet to verify physically. I am attaching hardware report that i could extract using adb.
Any idea why Multitool runs fine but no Armbian image boots? I’ve tried 2024 Ubuntu/Debian builds and a latest self-compiled Armbian image using Armbian Build, tried both flashing to eMMC and run from SD, including using the hidden button, nothing works—LED blinks, but no HDMI output.
I really want to run linux on this :(
Again thanks for all your contribution in the thread.
Edit1- Attaching Multitool Dmesg too, if it helps.
rk3229_hardware_profile.txt
dmesg.multitool.log
Edited by Kiranmoy Saha
Attached Multitool dmesg
login via ssh
