jock Posted May 25, 2021 Author Share Posted May 25, 2021 @Khoa Nguyen The kernel crash does not look specific to a device, but it is happening when a core exit the idle state handling an interrupt. I suspect stability issues, so I suggest you these two things: sun sudo rk322x-config and select rk3228a soc from the list. This limits the highest frequency to 1.2ghz edit /boot/armbianEnv.txt and append cpu-stability to overlays= line do both of them, then reboot the board and try again to install the desktop environment. I have a board with similar issues like yours, and cpu-stability overlay solved my issues so far, I hope it solves yours too! 0 Quote Link to comment Share on other sites More sharing options...
jock Posted May 25, 2021 Author Share Posted May 25, 2021 On 5/22/2021 at 10:21 PM, ArkhanLK said: And second, the errors are in/with the armsoc install from media framework, because it changes some stuff with xorg, that makes it break. And this has nothing todo with lightdm because it was the first problem I had in first plance when first talked to you about it. The armsoc .deb package actually installs the armsoc X.org .so driver (the same as .dll in windows) and places armsoc.conf it in /etc/X11/xorg.conf.d to enable it. Looking at the logs you provided I now see something that actually should not be there... a reference to "Lima" driver, which is not expected in non-mainline kernel... now I'm starting to understand that maybe you got 40-serverflags.conf in /etc/X11/xorg.conf.d directory. If so, remove that file and try again. I will double check this, because the way desktop packages are assembled changed recently in armbian and maybe I did a mistake with some configuration. 1 Quote Link to comment Share on other sites More sharing options...
Khoa Nguyen Posted May 25, 2021 Share Posted May 25, 2021 1 hour ago, jock said: @Khoa Nguyen The kernel crash does not look specific to a device, but it is happening when a core exit the idle state handling an interrupt. I suspect stability issues, so I suggest you these two things: sun sudo rk322x-config and select rk3228a soc from the list. This limits the highest frequency to 1.2ghz edit /boot/armbianEnv.txt and append cpu-stability to overlays= line do both of them, then reboot the board and try again to install the desktop environment. I have a board with similar issues like yours, and cpu-stability overlay solved my issues so far, I hope it solves yours too! I edited armbianEnv.txt file, overlays= emmc led-conf1 cpu-stability, then reboot and tried install desktop interface but it still not work sometimes it crashed, sometimes it just freezed 0 Quote Link to comment Share on other sites More sharing options...
jock Posted May 25, 2021 Author Share Posted May 25, 2021 34 minutes ago, Khoa Nguyen said: I edited armbianEnv.txt file, overlays= emmc led-conf1 cpu-stability, then reboot and tried install desktop interface but it still not work sometimes it crashed, sometimes it just freezed Can't say anything more without further details. Please provide photos of the board (both sides), maybe the original dtb or the original firmware (or a link to a firmware upgrade supplied by manufacturer), the link provided by armbianmonitor -u command. As already said, eMCP boards are quite unknown at the moment, so every detail is essential. 0 Quote Link to comment Share on other sites More sharing options...
jock Posted May 27, 2021 Author Share Posted May 27, 2021 @ArkhanLK I made some further investigation and it seems that lightdm-gtk-greeter is the great offender: the package in Ubuntu Focal seems to be broken for armhf architecture: https://bugs.launchpad.net/ubuntu/+source/lightdm-gtk-greeter/+bug/1897491 I just tried to install the lightdm-autologin-greeter and uninstall lightdm-gtk-greeter and, after a reboot, it looks like it works: apt install lightdm-autologin-greeter && apt remove lightdm-gtk-greeter If apt is lamenting issues about armsoc, that's because of a previous package upgrade. I don't know why, but it tries to install armsoc-exynos as a dependency of Kodi. It is unclear to me why it tries to install packaged Kodi instead of keeping the one from media-framework, but probably I made some mess with versioning. However, to try to get back the media framework situation, first uninstall the wrong armsoc driver: apt remove xserver-xorg-video-armsoc The install the media framework packages manually: apt install armsoc/*.deb apt install kodi/*.deb apt install ffmpeg/*.deb And finally mark the packages as hold, so apt upgrade won't try to update them: apt-mark hold xserver-xorg-video-armsoc apt-mark hold kodi kodi-addon-dev kodi-bin kodi-data kodi-tools-texturepacker apt-mark hold ffmpeg libavutil56 libpostproc55 libswscale5 libavutil-dev libpostproc-dev libswresample3 libavresample4 libswscale-dev libavcodec58 libavcodec-dev libavresample-dev libavformat-dev libavfilter7 libavfilter-dev libavdevice58 libavdevice-dev If you start from a fresh system, just run the apt-mark hold commands after installing the media framework and you should be fine enough. This is not exactly tested, because I'm headless right now, so if you feel comfortable enough, it may be a wise idea to start from a fresh system. I will update the media framework in the next days to include the apt-mark commands automatically, so this further step won't be needed. edit: ah, another thing about /etc/X11/xorg.conf.d directory... The stable image from the download page include 40-serverflags.conf file which should not be there! Curiously a freshly built image by me instead does not include that file, which should be there only on mainline images... so please delete it. I will ask the high towers what happened, maybe fix the lightdm greeter thing and ask for a stable image rebuild. 1 Quote Link to comment Share on other sites More sharing options...
hexdump Posted May 27, 2021 Share Posted May 27, 2021 @jock - just in case: the slick greeter is also working well on armhf 2 Quote Link to comment Share on other sites More sharing options...
ArkhanLK Posted May 28, 2021 Share Posted May 28, 2021 Hi @jock ! Thanks for all the help and ways to fix and/or bypass these issues! I took some time to replay back exactly as I was investigating it myself! And got to some findings similar to yours: the only thing I need to set as hold is the xserver-xorg-video-armsoc. The rest will update and upgrade just fine. Doing this, I am able to run some stuff. The gears are working on glxgears. I manage to play quake 1 and 2 (tho I had to add some params, LD_LIBRARY_PATH=/opt/gl4es LIBGL_GL=15 LIBGL_FB=3 LIBGL_MIPMAP=3 LIBGL_FORCENPOT=1 LIBGL_FPS=1 LIBGL_POTFRAMEBUFFER=1 LIBGL_FORCE16BITS=1 quake2) I also had to change one thing on the install media framework: allow downgrades. Some of the stuff there I had newer versions and the install would just stop. So, in order to avoid it, I allowed downgrades and then upgraded them. Some of the entries on the enxynos were right or interesting, so I merged them on the armsoc config and so far so good. All went ok! And I am still happily using the minimal image you compiled for me + lubuntu. It is working quite well! I am now with 2 errors but I think they're unrelated to any of these events: 1. For the sake of it, I decided to take a look at armbianmonitor -v and got "It appears you may have corrupt packages.", pointing to "a symptom of filesystem corruption caused by SD cards or eMMC dying", which makes that first suggestion of yours to remain true, but also that it could be "burning the OS image to the installation media went wrong", which I don't think to be the case. It also says, " The following changes from packaged state files were detected: /usr/lib/arm-linux-gnueabihf/libgbm.so.1.0.0 /usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf" Is this an entirely new problem or may have something to do with video and whatnot? 2. There is something wrong, I think, with the rk322x-config. When I select rk3229, the wifi doesn't work. If I choose rk3228a/b, everything works. Well, after I remove the emmc from overlays, that is. So, is this a thing you've noticed before? Actually, this might not be true. I just reverted the config the wifi is not turning on again! This is what I get from dmesg | grep ssv Quote [ 8.620941] redirect to /lib/firmware/ssv6051-wifi.cfg [ 8.624426] WARNING: CPU: 3 PID: 359 at drivers/net/wireless/rockchip_wlan/ssv6xxx/ssvdevice/ssvdevice.c:169 sta_cfg_set+0xc0/0x220 [ssv6051]() [ 8.624441] Modules linked in: lz4 lz4_compress ssv6051(+) mali snd_soc_rk3228 lzo zram sch_fq_codel ip_tables autofs4 [ 8.624744] [<b00277c8>] (warn_slowpath_null) from [<af0a5b00>] (sta_cfg_set+0xc0/0x220 [ssv6051]) [ 8.624900] [<af0a5b00>] (sta_cfg_set [ssv6051]) from [<af08a4b4>] (ssvdevice_init+0xf4/0x12c [ssv6051]) [ 8.625051] [<af08a4b4>] (ssvdevice_init [ssv6051]) from [<af0a59c4>] (initWlan+0x40/0x8c [ssv6051]) [ 8.625187] [<af0a59c4>] (initWlan [ssv6051]) from [<af0bf020>] (generic_wifi_init_module+0x20/0x1000 [ssv6051]) [ 8.625278] [<af0bf020>] (generic_wifi_init_module [ssv6051]) from [<b0009a68>] (do_one_initcall+0xa0/0x1f8) [ 8.625808] ssv6xxx_sdio_init [ 8.626181] ssv6xxx_set_sdio_clk:set sdio clk 25000000Hz [ 8.725161] ssv6xxx_sdio_power_on [ 8.745760] ssv6xxx_dev_probe(): ssv6200 device found ! [ 8.746030] WARNING: CPU: 0 PID: 359 at drivers/net/wireless/rockchip_wlan/ssv6xxx/smac/init.c:1471 ssv6xxx_dev_probe+0x2b8/0x1c70 [ssv6051]() [ 8.746045] Modules linked in: gpio_ir_recv lz4 lz4_compress ssv6051(+) mali snd_soc_rk3228 lzo zram sch_fq_codel ip_tables autofs4 [ 8.746278] [<b00277c8>] (warn_slowpath_null) from [<af0910a4>] (ssv6xxx_dev_probe+0x2b8/0x1c70 [ssv6051]) [ 8.746409] [<af0910a4>] (ssv6xxx_dev_probe [ssv6051]) from [<b066b11c>] (platform_drv_probe+0x60/0xbc) [ 8.746626] [<b066af34>] (platform_device_add) from [<af0aa34c>] (ssv6xxx_sdio_probe+0x358/0x3bc [ssv6051]) [ 8.746743] [<af0aa34c>] (ssv6xxx_sdio_probe [ssv6051]) from [<b09011a8>] (sdio_bus_probe+0x9c/0x12c) [ 8.746954] [<b09013f8>] (sdio_register_driver) from [<af0a9e08>] (ssv6xxx_sdio_init+0x2c/0x30 [ssv6051]) [ 8.747120] [<af0a9e08>] (ssv6xxx_sdio_init [ssv6051]) from [<af08a4d8>] (ssvdevice_init+0x118/0x12c [ssv6051]) [ 8.747276] [<af08a4d8>] (ssvdevice_init [ssv6051]) from [<af0a59c4>] (initWlan+0x40/0x8c [ssv6051]) [ 8.747413] [<af0a59c4>] (initWlan [ssv6051]) from [<af0bf020>] (generic_wifi_init_module+0x20/0x1000 [ssv6051]) [ 8.747497] [<af0bf020>] (generic_wifi_init_module [ssv6051]) from [<b0009a68>] (do_one_initcall+0xa0/0x1f8) [ 8.747666] SSV WLAN driver ssv6200: Failed to initialize device [ 8.747748] SSV WLAN driver: probe of ssv6200 failed with error -12 Well, I ran a bunch of stuff from armbian-config and it is working again... Here is the last log: Quote [ 8.528862] redirect to /lib/firmware/ssv6051-wifi.cfg [ 8.570261] ssv6xxx_sdio_init [ 8.572794] ssv6xxx_set_sdio_clk:set sdio clk 25000000Hz [ 8.646940] ssv6xxx_sdio_power_on [ 8.669819] ssv6xxx_dev_probe(): ssv6200 device found ! [ 8.693045] ssv6xxx_sdio_irq_disable [ 8.755147] SSV WLAN driver ssv6200: Crypto task 448 running with priority 120. [ 8.757019] SSV WLAN driver ssv6200: Crypto task 449 running with priority 120. [ 8.765543] SSV WLAN driver ssv6200: Crypto task 450 running with priority 120. [ 8.777224] SSV WLAN driver ssv6200: Crypto task 452 running with priority 120. [ 8.839754] ieee80211 phy0: Selected rate control algorithm 'ssv6xxx_rate_control' [ 29.168139] SVN ROOT URL http://192.168.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx [ 29.316423] Firmware "/lib/firmware/ssv6051-sw.bin" loaded [ 29.424934] Firmware name sh->cfg.firmware_path=/lib/firmware/ssv6051-sw.bin [ 29.425524] ssv6xxx_watchdog_controller 6 [ 29.448922] ssv6xxx_sdio_irq_enable [ 29.615759] ssv6200_start(): current channel: 1,sc->ps_status=0 [ 29.619391] ssv6200_add_interface(): vif->type = 2, NL80211_IFTYPE_AP=3 [ 29.619420] ssv6xxx_config_vif_res id[0]. [ 29.619444] SSV WLAN driver ssv6200: VIF a4:7d:9f:31:c7:74 of type 2 is added. [ 29.620244] ssv6200_bss_info_changed(): leave [ 29.621807] ssv6200_bss_info_changed(): leave And my main question is: assuming I can make it all work nice and well... Can I "clone" this system and install on another box exactly equal to this one? Like, if I go to multitool and do a "backup" then try to install this on a different box, will it work? I suppose the only way would be to compile a image of my system, but using the multitool would be so much easier, haha. On 5/25/2021 at 1:46 PM, Khoa Nguyen said: I edited armbianEnv.txt file, overlays= emmc led-conf1 cpu-stability, then reboot and tried install desktop interface but it still not work sometimes it crashed, sometimes it just freezed And hey, @Khoa Nguyen , maybe I'm mistaken and should not be giving advice as I'm very noob, but I think your overlays is still wrong. You have to remove the word "emmc" from it entirely. At least, for me, that's the only way it works... 0 Quote Link to comment Share on other sites More sharing options...
jock Posted May 28, 2021 Author Share Posted May 28, 2021 11 hours ago, hexdump said: @jock - just in case: the slick greeter is also working well on armhf Yeah I wanted to mention in the previous post but I forgot! However today had access to the box and it was still not logging in. I'll check further later, but this lightdm thing is very annoying 7 hours ago, ArkhanLK said: For the sake of it, I decided to take a look at armbianmonitor -v Uh, to be honest I never tried armbianmonitor -v. Actually the packages installed by media framework are "overwriting" those from armbian/ubuntu, I don't really know how armbianmonitor -v reacts to. 7 hours ago, ArkhanLK said: There is something wrong, I think, with the rk322x-config. When I select rk3229, the wifi doesn't work. If I choose rk3228a/b, everything works. Well, after I remove the emmc from overlays, that is. So, is this a thing you've noticed before? Actually, this might not be true. I just reverted the config the wifi is not turning on again! This is what I get from dmesg | grep ssv rk3228b and rk3229 are enabling exactly the same overlay, which brings the cpu to 1.4ghz, nothing else. emmc overlay enabled the ddr mode for eMMC and some other configuration bits. eMMC, sdcard and Wifi share the same subsystem since they are all controlled by mmc controllers, so it is very possibile that a malfunction/misconfiguration on eMMC reflects also over Wifi; usually badly designed boards do this. 7 hours ago, ArkhanLK said: And my main question is: assuming I can make it all work nice and well... Can I "clone" this system and install on another box exactly equal to this one? Like, if I go to multitool and do a "backup" then try to install this on a different box, will it work? I suppose the only way would be to compile a image of my system, but using the multitool would be so much easier, haha. Usually it will work fine even if the board is slightly different; you can however clone the thing and, if it boots, run rk322x-config to reconfigure the overlays for the other board 1 Quote Link to comment Share on other sites More sharing options...
ArkhanLK Posted May 28, 2021 Share Posted May 28, 2021 1 hour ago, jock said: Usually it will work fine even if the board is slightly different; you can however clone the thing and, if it boots, run rk322x-config to reconfigure the overlays for the other board Oh, that's very cool to know! It will be very helpful if it works this way indeed ^^ One thing I noticed but haven't looked into yet: kodi is installing without the "install from repositories option", so I can't really use it... I will try to reinstall or something. But I have encountered this error on 2 or 3 other times when I freshly installed everything... Only once, so far, I managed to install Kodi and it actually worked well (at least on twitch I could watch normally at 720p). 0 Quote Link to comment Share on other sites More sharing options...
jock Posted May 29, 2021 Author Share Posted May 29, 2021 @ArkhanLK I confirm that slick-greeter is a much better choice, X.org now works and I'm able to login finally! 1 Quote Link to comment Share on other sites More sharing options...
ArkhanLK Posted May 30, 2021 Share Posted May 30, 2021 On 5/29/2021 at 6:21 AM, jock said: @ArkhanLK I confirm that slick-greeter is a much better choice, X.org now works and I'm able to login finally! HI @jock! I tried slick-greeter with icewm and that was super fast! Very nice, but not that user friendly. But, you know, consumed 120mb ram to have it up and running, so very decent choice for limited boards! Also, I figured out a solution for the kodi part on the media framework: hold on 3 packages only: xserver-xorg-video-armsoc, kodi, and kodi-bin. But the other packages don't need the hold. Tested on twitch, 1080p smooth! I am now going to test kodi and lxde... Should be faster and lighter than both xfce and lxqt! I will keep you all updated o/ Thanks for the incredible support!!! 1 Quote Link to comment Share on other sites More sharing options...
beretas Posted June 2, 2021 Share Posted June 2, 2021 Sorry for late reply. For the record: MXQ PRO 4K 5G, announced on sitck as 4GB Ram, 32GB ROM, Rk3229. Inside it was Rk3228A, 1GB DDR3L Ram and 8GB NAND ROM of unknown chinesse manufacturer. @jock definitely, Nand is not detected with multitool, only armbian can be loaded from SD Card after erasing Nand. for the record or anyone with same system: 1.- Rom detection with rkdeveloptool: rkdeveloptool rfi Flash Info: Manufacturer: SAMSUNG, value=00 Flash Size: 7301 MB Flash Size: 14952960 Sectors Block Size: 16384 KB Page Size: 16 KB ECC Bits: 40 Access Time: 32 Flash CS: Flash<0> 2.- Flash cant be erased directly, on new system, if you do "rkdeveloptool ef" it writes: "Starting to erase flash..." and got stuck there, blocked, forever (i waited 24h, think its enough). So working method to get flash erased, its: rkdeveloptool wl 0x4000 u-boot-main.img (you can download and check command on first post) Write LBA from file (100%) after it, disconnect and reconnect again with the toothpick and Male-Male usb again. I tried to do "rkdeveloptool rd 3" which is supposed to reset device on MaskRoom mode, it responds: "Reset Device OK." but things cant be done, with errors like: "Getting flash info from device failed!". So after writing u-boot, disconnect and reconnect. rkdeveloptool ef Erasing flash complete. after it, plug SD card with Armbian and it boots ok. NAND is not useable from it, as it recognizes but can be accessed. if it helps someone, loading system with thoothpick method and Male-Male usb gives this result also: rkdeveloptool ld DevNo=1 Vid=0x2207,Pid=0x320b,LocationID=301 Loader Hope this helps someone. Best Regards, Beretas 0 Quote Link to comment Share on other sites More sharing options...
jock Posted June 2, 2021 Author Share Posted June 2, 2021 3 hours ago, beretas said: I tried to do "rkdeveloptool rd 3" which is supposed to reset device on MaskRoom mode, it responds: "Reset Device OK." but things cant be done, with errors like: "Getting flash info from device failed!". So after writing u-boot, disconnect and reconnect. It is right that after rkdeveloptool rd 3 you are not able to execute any other command: that's because the board is in maskrom mode. Once there, you must run rkdeveloptool db loader.img to have access to further commands. When done, rkdeveloptool ef will clean the existing data, and finally you need also upgrade_tool binary to finally install the new bootloader in the NAND. This is the procedure to upgrade to NAND bootloader: https://forum.armbian.com/topic/12656-csc-armbian-for-rk322x-tv-boxes/page/28/?tab=comments#comment-121103 If you don't install a bootloader, you will never be able to boot from NAND neither the Multitool will detect it. 0 Quote Link to comment Share on other sites More sharing options...
beretas Posted June 3, 2021 Share Posted June 3, 2021 @jock don't know if i did it as it should, but upgrade_tool was giving me an error: upgrade_tool ul rk322x_loader_v1.10.256.bin Not found config.ini Program Data in /home/me/rkbin/tools Loading loader... Support Type:RK322A Loader ver:2.56 Loader Time:2021-03-13 16:06:57 Prepare IDB Fail so checked: rkdeveloptool ld DevNo=1 Vid=0x2207,Pid=0x320b,LocationID=301 Maskrom and did: rkdeveloptool ul rk322x_loader_v1.10.256.bin Upgrading loader succeeded. armbianmonitor -U Spoiler 1 2 ### Activated 1 lzo zram swap devices with 481 MB each 3 4 ### Activated Armbian ramlog partition with lz4 compression 5 6 ### Activated lzo compressed /tmp 7 8 Fri 07 May 2021 08:24:09 PM UTC | rk322x-box | 21.05.1 | armhf | armv7l | 4.4.194-rk322x 9 10 ### dmesg: 11 12 [ 0.000000] Booting Linux on physical CPU 0xf00 13 [ 0.000000] Initializing cgroup subsys cpuset 14 [ 0.000000] Initializing cgroup subsys cpu 15 [ 0.000000] Initializing cgroup subsys cpuacct 16 [ 0.000000] Linux version 4.4.194-rk322x (root@hirsute) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #3 SMP Thu May 6 22:00:38 UTC 2021 17 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d 18 [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache 19 [ 0.000000] Machine model: Generic RK322x TV Box board 20 [ 0.000000] cma: Reserved 16 MiB at 0x9f000000 21 [ 0.000000] Memory policy: Data cache writealloc 22 [ 0.000000] On node 0 totalpages: 253952 23 [ 0.000000] free_area_init_node: node 0, pgdat b1253b40, node_mem_map ee6f1000 24 [ 0.000000] Normal zone: 2304 pages used for memmap 25 [ 0.000000] Normal zone: 0 pages reserved 26 [ 0.000000] Normal zone: 253952 pages, LIFO batch:31 27 [ 0.000000] psci: probing for conduit method from DT. 28 [ 0.000000] psci: PSCIv1.0 detected in firmware. 29 [ 0.000000] psci: Using standard PSCI v0.2 function IDs 30 [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. 31 [ 0.000000] PERCPU: Embedded 14 pages/cpu @ee68f000 s24856 r8192 d24296 u57344 32 [ 0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096 33 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 34 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 251648 35 [ 0.000000] Kernel command line: earlyprintk root=UUID=2ca5ad18-5d1f-4279-8d1e-6c805b6be8db console=ttyS2,115200n8 console=tty1 rootwait rootfstype=ext4 consoleblank=0 loglevel=1 ubootpart=73c5b759-01 usb-storage.quirks= coherent_pool=2M cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 36 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) 37 [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) 38 [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) 39 [ 0.000000] Memory: 962664K/1015808K available (12862K kernel code, 919K rwdata, 3240K rodata, 808K init, 1219K bss, 36760K reserved, 16384K cma-reserved, 0K highmem) 40 [ 0.000000] Virtual kernel memory layout: 41 vector : 0xffff0000 - 0xffff1000 ( 4 kB) 42 fixmap : 0xffc00000 - 0xfff00000 (3072 kB) 43 vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) 44 lowmem : 0xb0000000 - 0xf0000000 (1024 MB) 45 pkmap : 0xafe00000 - 0xb0000000 ( 2 MB) 46 modules : 0xaf000000 - 0xafe00000 ( 14 MB) 47 .text : 0xb0008000 - 0xb0c97c6c (12864 kB) 48 .init : 0xb10b0000 - 0xb117a000 ( 808 kB) 49 .data : 0xb117a000 - 0xb125fe94 ( 920 kB) 50 .bss : 0xb1261000 - 0xb1391f14 (1220 kB) 51 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 52 [ 0.000000] Hierarchical RCU implementation. 53 [ 0.000000] Build-time adjustment of leaf fanout to 32. 54 [ 0.000000] NR_IRQS:16 nr_irqs:16 16 55 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). 56 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 57 [ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 58 [ 0.000022] Switching to timer-based delay loop, resolution 41ns 59 [ 0.001779] Console: colour dummy device 80x30 60 [ 0.001962] console [tty1] enabled 61 [ 0.001987] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 62 [ 0.002005] pid_max: default: 32768 minimum: 301 63 [ 0.002135] Security Framework initialized 64 [ 0.002148] Yama: becoming mindful. 65 [ 0.002223] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) 66 [ 0.002239] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) 67 [ 0.003122] Initializing cgroup subsys io 68 [ 0.003156] Initializing cgroup subsys memory 69 [ 0.003198] Initializing cgroup subsys devices 70 [ 0.003218] Initializing cgroup subsys freezer 71 [ 0.003235] Initializing cgroup subsys net_cls 72 [ 0.003253] Initializing cgroup subsys perf_event 73 [ 0.003270] Initializing cgroup subsys net_prio 74 [ 0.003299] Initializing cgroup subsys pids 75 [ 0.003366] CPU: Testing write buffer coherency: ok 76 [ 0.003413] ftrace: allocating 41892 entries in 123 pages 77 [ 0.082701] /cpus/cpu@f00 missing clock-frequency property 78 [ 0.082733] /cpus/cpu@f01 missing clock-frequency property 79 [ 0.082751] /cpus/cpu@f02 missing clock-frequency property 80 [ 0.082771] /cpus/cpu@f03 missing clock-frequency property 81 [ 0.082783] CPU0: update cpu_capacity 430 82 [ 0.082794] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00 83 [ 0.082880] Setting up static identity map for 0x60008280 - 0x600082d8 84 [ 0.094092] CPU1: update cpu_capacity 430 85 [ 0.094100] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01 86 [ 0.103560] CPU2: update cpu_capacity 430 87 [ 0.103569] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02 88 [ 0.113014] CPU3: update cpu_capacity 430 89 [ 0.113022] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03 90 [ 0.113160] Brought up 4 CPUs 91 [ 0.113199] SMP: Total of 4 processors activated (192.00 BogoMIPS). 92 [ 0.113207] CPU: All CPU(s) started in SVC mode. 93 [ 0.114723] devtmpfs: initialized 94 [ 0.134213] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 95 [ 0.134801] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 96 [ 0.134840] futex hash table entries: 1024 (order: 4, 65536 bytes) 97 [ 0.136177] xor: measuring software checksum speed 98 [ 0.174729] arm4regs : 1011.000 MB/sec 99 [ 0.214834] 8regs : 705.000 MB/sec 100 [ 0.254937] 32regs : 684.000 MB/sec 101 [ 0.295037] neon : 1018.000 MB/sec 102 [ 0.295047] xor: using function: neon (1018.000 MB/sec) 103 [ 0.295089] pinctrl core: initialized pinctrl subsystem 104 [ 0.296629] NET: Registered protocol family 16 105 [ 0.299160] DMA: preallocated 2048 KiB pool for atomic coherent allocations 106 [ 0.311190] cpuidle: using governor ladder 107 [ 0.323205] cpuidle: using governor menu 108 [ 0.339880] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0 109 [ 0.340041] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1 110 [ 0.340194] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2 111 [ 0.340355] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3 112 [ 0.346585] console [pstore-1] enabled 113 [ 0.346596] pstore: Registered ramoops as persistent store backend 114 [ 0.346608] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0 115 [ 0.349934] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. 116 [ 0.349954] hw-breakpoint: maximum watchpoint size is 8 bytes. 117 [ 0.350174] sip_firmware_init: set rockchip sip version v2 failed 118 [ 0.448055] raid6: int32x1 gen() 133 MB/s 119 [ 0.516169] raid6: int32x1 xor() 131 MB/s 120 [ 0.584392] raid6: int32x2 gen() 166 MB/s 121 [ 0.652660] raid6: int32x2 xor() 137 MB/s 122 [ 0.720808] raid6: int32x4 gen() 163 MB/s 123 [ 0.789056] raid6: int32x4 xor() 137 MB/s 124 [ 0.857209] raid6: int32x8 gen() 166 MB/s 125 [ 0.925467] raid6: int32x8 xor() 113 MB/s 126 [ 0.993597] raid6: neonx1 gen() 382 MB/s 127 [ 1.061712] raid6: neonx1 xor() 290 MB/s 128 [ 1.129929] raid6: neonx2 gen() 519 MB/s 129 [ 1.198064] raid6: neonx2 xor() 376 MB/s 130 [ 1.266274] raid6: neonx4 gen() 581 MB/s 131 [ 1.334481] raid6: neonx4 xor() 400 MB/s 132 [ 1.402677] raid6: neonx8 gen() 559 MB/s 133 [ 1.470929] raid6: neonx8 xor() 391 MB/s 134 [ 1.470941] raid6: using algorithm neonx4 gen() 581 MB/s 135 [ 1.470951] raid6: .... xor() 400 MB/s, rmw enabled 136 [ 1.470962] raid6: using intx1 recovery algorithm 137 [ 1.471951] rockchip-pm rockchip-suspend: not set wakeup-config 138 [ 1.471975] rockchip-pm rockchip-suspend: not set pwm-regulator-config 139 [ 1.472341] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]' 140 [ 1.472830] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]' 141 [ 1.473453] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0) 142 [ 1.474050] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0) 143 [ 1.474556] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]' 144 [ 1.475466] iommu: Adding device 20020000.vpu-service to group 0 145 [ 1.475573] iommu: Adding device 20030000.rkvdec to group 1 146 [ 1.475669] iommu: Adding device 20050000.vop to group 2 147 [ 1.475761] iommu: Adding device 20070000.iep to group 3 148 [ 1.476298] rk_iommu 20020800.iommu: can't get sclk 149 [ 1.476889] rk_iommu 20030480.iommu: can't get sclk 150 [ 1.477137] rk_iommu 20053f00.iommu: can't get sclk 151 [ 1.477282] rk_iommu 20070800.iommu: can't get aclk 152 [ 1.477301] rk_iommu 20070800.iommu: can't get hclk 153 [ 1.477317] rk_iommu 20070800.iommu: can't get sclk 154 [ 1.478063] SCSI subsystem initialized 155 [ 1.478478] usbcore: registered new interface driver usbfs 156 [ 1.478577] usbcore: registered new interface driver hub 157 [ 1.478693] usbcore: registered new device driver usb 158 [ 1.478969] media: Linux media interface: v0.10 159 [ 1.479076] Linux video capture interface: v2.00 160 [ 1.479329] pps_core: LinuxPPS API ver. 1 registered 161 [ 1.479345] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 162 [ 1.479387] PTP clock support registered 163 [ 1.481295] Advanced Linux Sound Architecture Driver Initialized. 164 [ 1.482283] Bluetooth: Core ver 2.21 165 [ 1.482350] NET: Registered protocol family 31 166 [ 1.482364] Bluetooth: HCI device and connection manager initialized 167 [ 1.482385] Bluetooth: HCI socket layer initialized 168 [ 1.482403] Bluetooth: L2CAP socket layer initialized 169 [ 1.482456] Bluetooth: SCO socket layer initialized 170 [ 1.483263] NetLabel: Initializing 171 [ 1.483285] NetLabel: domain hash size = 128 172 [ 1.483294] NetLabel: protocols = UNLABELED CIPSOv4 173 [ 1.483367] NetLabel: unlabeled traffic allowed by default 174 [ 1.484706] clocksource: Switched to clocksource arch_sys_counter 175 [ 1.579545] NET: Registered protocol family 2 176 [ 1.580387] TCP established hash table entries: 8192 (order: 3, 32768 bytes) 177 [ 1.580503] TCP bind hash table entries: 8192 (order: 5, 163840 bytes) 178 [ 1.580940] TCP: Hash tables configured (established 8192 bind 8192) 179 [ 1.581043] UDP hash table entries: 512 (order: 2, 24576 bytes) 180 [ 1.581113] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes) 181 [ 1.581465] NET: Registered protocol family 1 182 [ 1.582099] RPC: Registered named UNIX socket transport module. 183 [ 1.582122] RPC: Registered udp transport module. 184 [ 1.582133] RPC: Registered tcp transport module. 185 [ 1.582143] RPC: Registered tcp NFSv4.1 backchannel transport module. 186 [ 1.582467] Trying to unpack rootfs image as initramfs... 187 [ 1.955293] Freeing initrd memory: 5564K 188 [ 1.956316] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available 189 [ 1.959287] Initialise system trusted keyring 190 [ 1.973170] VFS: Disk quotas dquot_6.6.0 191 [ 1.973484] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) 192 [ 1.976164] squashfs: version 4.0 (2009/01/31) Phillip Lougher 193 [ 1.979591] NFS: Registering the id_resolver key type 194 [ 1.979662] Key type id_resolver registered 195 [ 1.979674] Key type id_legacy registered 196 [ 1.979709] nfs4filelayout_init: NFSv4 File Layout Driver Registering... 197 [ 1.979818] ntfs: driver 2.1.32 [Flags: R/W]. 198 [ 1.980867] JFS: nTxBlock = 7692, nTxLock = 61538 199 [ 1.989484] SGI XFS with security attributes, no debug enabled 200 [ 1.998636] NET: Registered protocol family 38 201 [ 1.998688] Key type asymmetric registered 202 [ 1.998708] Asymmetric key parser 'x509' registered 203 [ 1.999105] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) 204 [ 1.999503] io scheduler noop registered 205 [ 1.999534] io scheduler deadline registered 206 [ 1.999617] io scheduler cfq registered (default) 207 [ 2.002806] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator 208 [ 2.007885] rk-vcodec 20020000.vpu-service: no regulator for vcodec 209 [ 2.008286] rk-vcodec 20020000.vpu-service: probe device 210 [ 2.008741] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled 211 [ 2.009933] rk-vcodec 20020000.vpu-service: could not find power_model node 212 [ 2.009958] rk-vcodec 20020000.vpu-service: init success 213 [ 2.010276] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry 214 [ 2.014549] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330 215 [ 2.014579] dma-pl330 110f0000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 216 [ 2.015700] rockchip-system-monitor rockchip-system-monitor: system monitor probe 217 [ 2.016181] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable 218 [ 2.016201] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup 219 [ 2.016218] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]' 220 [ 2.016233] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]' 221 [ 2.016247] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup 222 [ 2.016262] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed 223 [ 2.016983] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable 224 [ 2.017005] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup 225 [ 2.017021] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]' 226 [ 2.017036] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]' 227 [ 2.017049] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup 228 [ 2.017065] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed 229 [ 2.018107] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled 230 [ 2.018893] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A 231 [ 2.019718] console [ttyS2] enabled 232 [ 2.021574] [drm] Initialized drm 1.1.0 20060810 233 [ 2.024025] [drm] Rockchip DRM driver version: v1.0.1 234 [ 2.024262] rockchip-drm display-subsystem: devfreq is not set 235 [ 2.025076] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d1b2b0) 236 [ 2.025464] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports 237 [ 2.025491] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver 238 [ 2.025601] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy) 239 [ 2.026868] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d13808) 240 [ 2.026893] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). 241 [ 2.026904] [drm] No driver support for vblank timestamp query. 242 [ 2.027017] rockchip-drm display-subsystem: failed to parse display resources 243 [ 2.649880] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11 244 [ 2.650488] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13 245 [ 2.650496] dwhdmi-rockchip 200a0000.hdmi: colorspace: RGB 246 [ 2.650502] dwhdmi-rockchip 200a0000.hdmi: scan mode: Underscan 247 [ 2.650509] dwhdmi-rockchip 200a0000.hdmi: colorimetry: No Data 248 [ 2.650515] dwhdmi-rockchip 200a0000.hdmi: picture aspect: 16:9 249 [ 2.650522] dwhdmi-rockchip 200a0000.hdmi: active aspect: Same as Picture 250 [ 2.650528] dwhdmi-rockchip 200a0000.hdmi: itc: IT Content 251 [ 2.650535] dwhdmi-rockchip 200a0000.hdmi: extended colorimetry: xvYCC 601 252 [ 2.650541] dwhdmi-rockchip 200a0000.hdmi: quantization range: Full 253 [ 2.650547] dwhdmi-rockchip 200a0000.hdmi: nups: Unknown Non-uniform Scaling 254 [ 2.650554] dwhdmi-rockchip 200a0000.hdmi: video code: 16 255 [ 2.650560] dwhdmi-rockchip 200a0000.hdmi: ycc quantization range: Full 256 [ 2.650567] dwhdmi-rockchip 200a0000.hdmi: hdmi content type: Graphics 257 [ 2.650573] dwhdmi-rockchip 200a0000.hdmi: pixel repeat: 0 258 [ 2.650580] dwhdmi-rockchip 200a0000.hdmi: bar top 0, bottom 0, left 0, right 0 259 [ 2.724866] Console: switching to colour frame buffer device 240x67 260 [ 2.774870] rockchip-drm display-subsystem: fb0: frame buffer device 261 [ 2.793287] Registered IR keymap rc-cec 262 [ 2.793539] rc rc0: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0 263 [ 2.794213] input: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0/input0 264 [ 2.796546] brd: module loaded 265 [ 2.808098] loop: module loaded 266 [ 2.808187] lkdtm: No crash points registered, enable through debugfs 267 [ 2.810801] libphy: Fixed MDIO Bus: probed 268 [ 2.810834] tun: Universal TUN/TAP device driver, 1.6 269 [ 2.810846] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> 270 [ 2.811181] CAN device driver interface 271 [ 2.812582] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output). 272 [ 2.812610] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30). 273 [ 2.812626] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10). 274 [ 2.812667] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes). 275 [ 2.812986] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed 276 [ 2.818073] rk_gmac-dwmac 30200000.ethernet: init for RMII 277 [ 2.852817] stmmac - user ID: 0x10, Synopsys ID: 0x35 278 [ 2.852832] Ring mode enabled 279 [ 2.852843] DMA HW capability register supported 280 [ 2.852852] Normal descriptors 281 [ 2.852864] RX Checksum Offload Engine supported (type 2) 282 [ 2.852874] TX Checksum insertion supported 283 [ 2.852882] Wake-Up On Lan supported 284 [ 2.852978] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: f6:b4:e0:5a:1e:3a 285 [ 2.852992] eth%d: device MAC address f6:b4:e0:5a:1e:3a 286 [ 2.853001] Enable RX Mitigation via HW Watchdog Timer 287 [ 2.853195] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0) 288 [ 3.262396] libphy: stmmac: probed 289 [ 3.262427] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active 290 [ 3.262440] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01) 291 [ 3.262453] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02) 292 [ 3.262466] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03) 293 [ 3.262478] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04) 294 [ 3.262490] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05) 295 [ 3.262503] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06) 296 [ 3.262515] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07) 297 [ 3.262527] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08) 298 [ 3.262540] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09) 299 [ 3.262552] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a) 300 [ 3.262565] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b) 301 [ 3.262577] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c) 302 [ 3.262589] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d) 303 [ 3.262601] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e) 304 [ 3.262614] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f) 305 [ 3.262626] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10) 306 [ 3.262639] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11) 307 [ 3.262651] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12) 308 [ 3.262664] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13) 309 [ 3.262676] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14) 310 [ 3.262688] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15) 311 [ 3.262700] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16) 312 [ 3.262713] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17) 313 [ 3.262725] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18) 314 [ 3.262737] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19) 315 [ 3.262750] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a) 316 [ 3.262762] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b) 317 [ 3.262775] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c) 318 [ 3.262787] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d) 319 [ 3.262799] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e) 320 [ 3.262811] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f) 321 [ 3.264246] PPP generic driver version 2.4.2 322 [ 3.264631] Atmel at76x USB Wireless LAN Driver 0.17 loading 323 [ 3.264845] usbcore: registered new interface driver at76c50x-usb 324 [ 3.264986] usbcore: registered new interface driver rtl8187 325 [ 3.265105] usbcore: registered new interface driver rndis_wlan 326 [ 3.265213] usbcore: registered new interface driver zd1201 327 [ 3.265601] usbcore: registered new interface driver rt2800usb 328 [ 3.265715] Rockchip WiFi SYS interface (V1.00) ... 329 [ 3.265794] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver 330 [ 3.265882] usbcore: registered new interface driver pegasus 331 [ 3.265970] usbcore: registered new interface driver rtl8150 332 [ 3.266051] usbcore: registered new interface driver r8152 333 [ 3.266150] usbcore: registered new interface driver asix 334 [ 3.266232] usbcore: registered new interface driver ax88179_178a 335 [ 3.266314] usbcore: registered new interface driver cdc_ether 336 [ 3.266395] usbcore: registered new interface driver dm9601 337 [ 3.266504] usbcore: registered new interface driver smsc75xx 338 [ 3.266609] usbcore: registered new interface driver smsc95xx 339 [ 3.266700] usbcore: registered new interface driver net1080 340 [ 3.266785] usbcore: registered new interface driver rndis_host 341 [ 3.266868] usbcore: registered new interface driver MOSCHIP usb-ethernet driver 342 [ 3.267004] usbcore: registered new interface driver cdc_ncm 343 [ 3.267088] usbcore: registered new interface driver cdc_mbim 344 [ 3.267594] 30040000.usb supply vusb_d not found, using dummy regulator 345 [ 3.267703] 30040000.usb supply vusb_a not found, using dummy regulator 346 [ 3.280924] dwc2 30040000.usb: DWC OTG Controller 347 [ 3.280976] dwc2 30040000.usb: new USB bus registered, assigned bus number 1 348 [ 3.281033] dwc2 30040000.usb: irq 49, io mem 0x30040000 349 [ 3.281387] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 350 [ 3.281406] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 351 [ 3.281421] usb usb1: Product: DWC OTG Controller 352 [ 3.281435] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg 353 [ 3.281448] usb usb1: SerialNumber: 30040000.usb 354 [ 3.282404] hub 1-0:1.0: USB hub found 355 [ 3.282476] hub 1-0:1.0: 1 port detected 356 [ 3.283996] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 357 [ 3.284024] ehci-platform: EHCI generic platform driver 358 [ 3.286535] ehci-platform 30080000.usb: EHCI Host Controller 359 [ 3.286893] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2 360 [ 3.287195] ehci-platform 30080000.usb: irq 50, io mem 0x30080000 361 [ 3.296729] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00 362 [ 3.297029] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 363 [ 3.297048] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 364 [ 3.297062] usb usb2: Product: EHCI Host Controller 365 [ 3.297076] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd 366 [ 3.297090] usb usb2: SerialNumber: 30080000.usb 367 [ 3.298049] hub 2-0:1.0: USB hub found 368 [ 3.298121] hub 2-0:1.0: 1 port detected 369 [ 3.300814] ehci-platform 300c0000.usb: EHCI Host Controller 370 [ 3.301185] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3 371 [ 3.301463] ehci-platform 300c0000.usb: irq 52, io mem 0x300c0000 372 [ 3.312728] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00 373 [ 3.313048] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 374 [ 3.313069] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 375 [ 3.313083] usb usb3: Product: EHCI Host Controller 376 [ 3.313097] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd 377 [ 3.313110] usb usb3: SerialNumber: 300c0000.usb 378 [ 3.314053] hub 3-0:1.0: USB hub found 379 [ 3.314125] hub 3-0:1.0: 1 port detected 380 [ 3.316811] ehci-platform 30100000.usb: EHCI Host Controller 381 [ 3.317204] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4 382 [ 3.317504] ehci-platform 30100000.usb: irq 54, io mem 0x30100000 383 [ 3.328726] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00 384 [ 3.329020] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 385 [ 3.329040] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 386 [ 3.329054] usb usb4: Product: EHCI Host Controller 387 [ 3.329068] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd 388 [ 3.329081] usb usb4: SerialNumber: 30100000.usb 389 [ 3.330064] hub 4-0:1.0: USB hub found 390 [ 3.330145] hub 4-0:1.0: 1 port detected 391 [ 3.330952] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 392 [ 3.331023] ohci-platform: OHCI generic platform driver 393 [ 3.331422] ohci-platform 300a0000.usb: Generic Platform OHCI controller 394 [ 3.331812] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5 395 [ 3.332078] ohci-platform 300a0000.usb: irq 51, io mem 0x300a0000 396 [ 3.388987] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001 397 [ 3.389011] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 398 [ 3.389026] usb usb5: Product: Generic Platform OHCI controller 399 [ 3.389040] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd 400 [ 3.389053] usb usb5: SerialNumber: 300a0000.usb 401 [ 3.390047] hub 5-0:1.0: USB hub found 402 [ 3.390121] hub 5-0:1.0: 1 port detected 403 [ 3.390965] ohci-platform 300e0000.usb: Generic Platform OHCI controller 404 [ 3.391338] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6 405 [ 3.391585] ohci-platform 300e0000.usb: irq 53, io mem 0x300e0000 406 [ 3.448990] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 407 [ 3.449014] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 408 [ 3.449029] usb usb6: Product: Generic Platform OHCI controller 409 [ 3.449043] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd 410 [ 3.449056] usb usb6: SerialNumber: 300e0000.usb 411 [ 3.449983] hub 6-0:1.0: USB hub found 412 [ 3.450054] hub 6-0:1.0: 1 port detected 413 [ 3.450865] ohci-platform 30120000.usb: Generic Platform OHCI controller 414 [ 3.451214] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7 415 [ 3.451496] ohci-platform 30120000.usb: irq 55, io mem 0x30120000 416 [ 3.509022] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001 417 [ 3.509044] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 418 [ 3.509059] usb usb7: Product: Generic Platform OHCI controller 419 [ 3.509073] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd 420 [ 3.509087] usb usb7: SerialNumber: 30120000.usb 421 [ 3.510041] hub 7-0:1.0: USB hub found 422 [ 3.510116] hub 7-0:1.0: 1 port detected 423 [ 3.511018] usbcore: registered new interface driver cdc_acm 424 [ 3.511035] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters 425 [ 3.511144] usbcore: registered new interface driver cdc_wdm 426 [ 3.511437] usbcore: registered new interface driver usb-storage 427 [ 3.511619] usbcore: registered new interface driver usbserial 428 [ 3.511709] usbcore: registered new interface driver usbserial_generic 429 [ 3.511772] usbserial: USB Serial support registered for generic 430 [ 3.511881] usbcore: registered new interface driver keyspan 431 [ 3.511941] usbserial: USB Serial support registered for Keyspan - (without firmware) 432 [ 3.511999] usbserial: USB Serial support registered for Keyspan 1 port adapter 433 [ 3.512056] usbserial: USB Serial support registered for Keyspan 2 port adapter 434 [ 3.512112] usbserial: USB Serial support registered for Keyspan 4 port adapter 435 [ 3.512224] usbcore: registered new interface driver option 436 [ 3.512285] usbserial: USB Serial support registered for GSM modem (1-port) 437 [ 3.513083] usbcore: registered new interface driver oti6858 438 [ 3.513153] usbserial: USB Serial support registered for oti6858 439 [ 3.513257] usbcore: registered new interface driver qcserial 440 [ 3.513317] usbserial: USB Serial support registered for Qualcomm USB modem 441 [ 3.513501] usbcore: registered new interface driver sierra 442 [ 3.513562] usbserial: USB Serial support registered for Sierra USB modem 443 [ 3.514940] usbcore: registered new interface driver iforce 444 [ 3.515105] usbcore: registered new interface driver xpad 445 [ 3.515375] usbcore: registered new interface driver usbtouchscreen 446 [ 3.516553] i2c /dev entries driver 447 [ 3.518560] IR NEC protocol handler initialized 448 [ 3.518586] IR RC5(x/sz) protocol handler initialized 449 [ 3.518604] IR RC6 protocol handler initialized 450 [ 3.518621] IR JVC protocol handler initialized 451 [ 3.518638] IR Sony protocol handler initialized 452 [ 3.518655] IR SANYO protocol handler initialized 453 [ 3.518671] IR Sharp protocol handler initialized 454 [ 3.518689] IR MCE Keyboard/mouse protocol handler initialized 455 [ 3.518706] IR XMP protocol handler initialized 456 [ 3.520440] usbcore: registered new interface driver uvcvideo 457 [ 3.520454] USB Video Class driver (1.1.1) 458 [ 3.522438] Boot mode: normal 459 [ 3.523612] rockchip-thermal 11150000.tsadc: tsadc is probed successfully! 460 [ 3.525347] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com 461 [ 3.525686] Bluetooth: Virtual HCI driver ver 1.5 462 [ 3.525967] Bluetooth: HCI UART driver ver 2.3 463 [ 3.525986] Bluetooth: HCI UART protocol H4 registered 464 [ 3.525997] Bluetooth: HCI UART protocol LL registered 465 [ 3.526008] Bluetooth: HCI UART protocol ATH3K registered 466 [ 3.526019] Bluetooth: HCI UART protocol Three-wire (H5) registered 467 [ 3.526191] Bluetooth: HCI UART protocol BCM registered 468 [ 3.526342] usbcore: registered new interface driver bfusb 469 [ 3.526486] usbcore: registered new interface driver btusb 470 [ 3.526509] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 471 [ 3.527107] cpu cpu0: leakage=6 472 [ 3.527139] cpu cpu0: leakage-volt-sel=0 473 [ 3.527346] cpu cpu0: Failed to get pvtm 474 [ 3.528790] cpu cpu0: avs=0 475 [ 3.529142] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 476 [ 3.529175] cpu cpu0: failed to read out thermal zone (-22) 477 [ 3.529882] cpu cpu0: failed to find power_model node 478 [ 3.530525] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset 479 [ 3.530544] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup 480 [ 3.530566] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0) 481 [ 3.530918] Synopsys Designware Multimedia Card Interface Driver 482 [ 3.531521] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode. 483 [ 3.531624] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller. 484 [ 3.531641] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a 485 [ 3.531702] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo 486 [ 3.531783] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found 487 [ 3.531795] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found 488 [ 3.531817] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd 489 [ 3.531826] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup 490 [ 3.531853] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0) 491 [ 3.531888] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations 492 [ 3.531899] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO 493 [ 3.531911] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp 494 [ 3.531920] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup 495 [ 3.531930] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]' 496 [ 3.531940] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]' 497 [ 3.531949] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup 498 [ 3.531959] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed 499 [ 3.544783] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) 500 [ 3.557691] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized 501 [ 3.558045] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available 502 [ 3.558129] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode. 503 [ 3.558228] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller. 504 [ 3.558246] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a 505 [ 3.558307] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo 506 [ 3.558357] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found 507 [ 3.558368] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found 508 [ 3.558387] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp 509 [ 3.558397] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup 510 [ 3.558409] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]' 511 [ 3.558419] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]' 512 [ 3.558428] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup 513 [ 3.558438] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed 514 [ 3.558506] dwmmc_rockchip 30010000.dwmmc: allocated mmc-pwrseq 515 [ 3.571289] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2) 516 [ 3.583981] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized 517 [ 3.584379] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode. 518 [ 3.584485] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller. 519 [ 3.584503] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a 520 [ 3.584567] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo 521 [ 3.584618] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found 522 [ 3.584630] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found 523 [ 3.584648] dwmmc_rockchip 30020000.dwmmc: GPIO lookup for consumer wp 524 [ 3.584658] dwmmc_rockchip 30020000.dwmmc: using device tree for GPIO lookup 525 [ 3.584670] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30020000[0]' 526 [ 3.584755] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30020000[0]' 527 [ 3.584768] dwmmc_rockchip 30020000.dwmmc: using lookup tables for GPIO lookup 528 [ 3.584856] dwmmc_rockchip 30020000.dwmmc: lookup for GPIO wp failed 529 [ 3.589423] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) 530 [ 3.589511] mmc0: new high speed SDXC card at address 59b4 531 [ 3.590261] mmcblk0: mmc0:59b4 SD 57.8 GiB 532 [ 3.591842] mmcblk0: p1 533 [ 3.596776] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) 534 [ 3.609278] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized 535 [ 3.610378] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/working[0]' - status (0) 536 [ 3.611509] ledtrig-cpu: registered to indicate activity on CPUs 537 [ 3.611856] hidraw: raw HID events driver (C) Jiri Kosina 538 [ 3.613166] usbcore: registered new interface driver usbhid 539 [ 3.613198] usbhid: USB HID core driver 540 [ 3.614288] ashmem: initialized 541 [ 3.619794] rknandbase v1.2 2018-05-08 542 [ 3.620469] rknand 30030000.nandc: rknand_probe clk rate = 150000000 543 [ 3.621104] ftl_init fffffffe 544 [ 3.621130] rk_ftl_init fail 545 [ 3.623345] usbcore: registered new interface driver snd-usb-audio 546 [ 3.623618] usbcore: registered new interface driver snd-ua101 547 [ 3.623986] usbcore: registered new interface driver snd-usb-caiaq 548 [ 3.624325] usbcore: registered new interface driver snd-usb-6fire 549 [ 3.624608] usbcore: registered new interface driver snd-usb-hiface 550 [ 3.625007] usbcore: registered new interface driver snd-bcd2000 551 [ 3.625239] usbcore: registered new interface driver snd_usb_pod 552 [ 3.625529] usbcore: registered new interface driver snd_usb_podhd 553 [ 3.625743] usbcore: registered new interface driver snd_usb_toneport 554 [ 3.626016] usbcore: registered new interface driver snd_usb_variax 555 [ 3.630762] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) 556 [ 3.634004] mmc1: new high speed SDIO card at address 0001 557 [ 3.640960] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0) 558 [ 3.641612] u32 classifier 559 [ 3.641641] input device check on 560 [ 3.641659] Actions configured 561 [ 3.641701] Netfilter messages via NETLINK v0.30. 562 [ 3.641764] nfnl_acct: registering with nfnetlink. 563 [ 3.641965] nf_conntrack version 0.5.0 (15384 buckets, 61536 max) 564 [ 3.643647] Initializing XFRM netlink socket 565 [ 3.646051] NET: Registered protocol family 10 566 [ 3.648678] ip6_tables: (C) 2000-2006 Netfilter Core Team 567 [ 3.649563] sit: IPv6 over IPv4 tunneling driver 568 [ 3.651343] NET: Registered protocol family 17 569 [ 3.651435] NET: Registered protocol family 15 570 [ 3.651567] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. 571 [ 3.651677] Bridge firewalling registered 572 [ 3.651717] can: controller area network core (rev 20120528 abi 9) 573 [ 3.651900] NET: Registered protocol family 29 574 [ 3.651949] can: raw protocol (rev 20120528) 575 [ 3.651986] can: broadcast manager protocol (rev 20120528 t) 576 [ 3.652035] can: netlink gateway (rev 20130117) max_hops=1 577 [ 3.653050] Bluetooth: RFCOMM TTY layer initialized 578 [ 3.653112] Bluetooth: RFCOMM socket layer initialized 579 [ 3.653174] Bluetooth: RFCOMM ver 1.11 580 [ 3.653236] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 581 [ 3.653276] Bluetooth: HIDP socket layer initialized 582 [ 3.653444] 8021q: 802.1Q VLAN Support v1.8 583 [ 3.653533] lib80211: common routines for IEEE802.11 drivers 584 [ 3.653669] lib80211_crypt: registered algorithm 'NULL' 585 [ 3.653722] lib80211_crypt: registered algorithm 'WEP' 586 [ 3.653764] lib80211_crypt: registered algorithm 'CCMP' 587 [ 3.653805] lib80211_crypt: registered algorithm 'TKIP' 588 [ 3.653839] [WLAN_RFKILL]: Enter rfkill_wlan_init 589 [ 3.654367] [BT_RFKILL]: Enter rfkill_rk_init 590 [ 3.654866] Key type dns_resolver registered 591 [ 3.655564] flash vendor_init_thread! 592 [ 3.655600] flash vendor storage:20170308 ret = -1 593 [ 3.655776] Error: Driver 'sc031gs' is already registered, aborting... 594 [ 3.657774] Registering SWP/SWPB emulation handler 595 [ 3.660145] registered taskstats version 1 596 [ 3.660210] Loading compiled-in X.509 certificates 597 [ 3.666633] Btrfs loaded 598 [ 3.668471] rga2: Driver loaded successfully ver:4.01 599 [ 3.668989] rga2: Module initialized. 600 [ 3.669067] pvtm list NULL 601 [ 3.671176] rk-vcodec 20030000.rkvdec: leakage=5 602 [ 3.671236] rk-vcodec 20030000.rkvdec: leakage-volt-sel=0 603 [ 3.671431] rk-vcodec 20030000.rkvdec: Failed to get pvtm 604 [ 3.672284] rk-vcodec 20030000.rkvdec: avs=0 605 [ 3.672970] rk-vcodec 20030000.rkvdec: probe device 606 [ 3.673800] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled 607 [ 3.676167] rk-vcodec 20030000.rkvdec: init success 608 [ 3.678287] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]' 609 [ 3.678330] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]' 610 [ 3.680312] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok 611 [ 3.683752] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]' 612 [ 3.683794] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]' 613 [ 3.685049] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0) 614 [ 3.685773] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok 615 [ 3.687928] hctosys: unable to open rtc device (rtc0) 616 [ 3.701531] ALSA device list: 617 [ 3.701557] #0: DW-I2S-HDMI 618 [ 3.701566] #1: SPDIF 619 [ 3.702585] Freeing unused kernel memory: 808K 620 [ 3.702597] This architecture does not have kernel memory protection. 621 [ 3.728900] mmc_host mmc2: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0) 622 [ 3.884792] usb 7-1: new low-speed USB device number 2 using ohci-platform 623 [ 4.089840] usb 7-1: New USB device found, idVendor=04f3, idProduct=0103 624 [ 4.089865] usb 7-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 625 [ 4.099819] input: HID 04f3:0103 as /devices/platform/30120000.usb/usb7/7-1/7-1:1.0/0003:04F3:0103.0001/input/input1 626 [ 4.100977] hid-generic 0003:04F3:0103.0001: input,hidraw0: USB HID v1.11 Keyboard [HID 04f3:0103] on usb-30120000.usb-1/input0 627 [ 4.110398] input: HID 04f3:0103 as /devices/platform/30120000.usb/usb7/7-1/7-1:1.1/0003:04F3:0103.0002/input/input2 628 [ 4.110995] hid-generic 0003:04F3:0103.0002: input,hidraw1: USB HID v1.11 Device [HID 04f3:0103] on usb-30120000.usb-1/input1 629 [ 4.296583] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11 630 [ 4.297367] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13 631 [ 4.297388] dwhdmi-rockchip 200a0000.hdmi: colorspace: RGB 632 [ 4.297399] dwhdmi-rockchip 200a0000.hdmi: scan mode: Underscan 633 [ 4.297409] dwhdmi-rockchip 200a0000.hdmi: colorimetry: No Data 634 [ 4.297418] dwhdmi-rockchip 200a0000.hdmi: picture aspect: 16:9 635 [ 4.297427] dwhdmi-rockchip 200a0000.hdmi: active aspect: Same as Picture 636 [ 4.297437] dwhdmi-rockchip 200a0000.hdmi: itc: IT Content 637 [ 4.297446] dwhdmi-rockchip 200a0000.hdmi: extended colorimetry: xvYCC 601 638 [ 4.297456] dwhdmi-rockchip 200a0000.hdmi: quantization range: Full 639 [ 4.297465] dwhdmi-rockchip 200a0000.hdmi: nups: Unknown Non-uniform Scaling 640 [ 4.297474] dwhdmi-rockchip 200a0000.hdmi: video code: 16 641 [ 4.297484] dwhdmi-rockchip 200a0000.hdmi: ycc quantization range: Full 642 [ 4.297493] dwhdmi-rockchip 200a0000.hdmi: hdmi content type: Graphics 643 [ 4.297502] dwhdmi-rockchip 200a0000.hdmi: pixel repeat: 0 644 [ 4.297512] dwhdmi-rockchip 200a0000.hdmi: bar top 0, bottom 0, left 0, right 0 645 [ 4.875166] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) 646 [ 5.621861] systemd[1]: System time before build time, advancing clock. 647 [ 5.647052] systemd[1]: Inserted module 'autofs4' 648 [ 5.653466] ip_tables: (C) 2000-2006 Netfilter Core Team 649 [ 5.664336] cgroup: cgroup2: unknown option "nsdelegate" 650 [ 5.681137] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 651 [ 5.682750] systemd[1]: Detected architecture arm. 652 [ 5.697591] systemd[1]: Set hostname to <rk322x-box>. 653 [ 5.926013] ttyS2 - failed to request DMA, use interrupt mode 654 [ 6.049694] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. 655 [ 6.049758] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) 656 [ 6.490178] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available) 657 [ 6.504004] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available) 658 [ 6.508467] systemd[1]: Created slice system-serial\x2dgetty.slice. 659 [ 6.509546] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. 660 [ 6.509661] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available) 661 [ 6.510447] systemd[1]: Listening on Syslog Socket. 662 [ 6.511122] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available) 663 [ 6.511542] systemd[1]: Started Forward Password Requests to Wall Directory Watch. 664 [ 6.523987] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. 665 [ 6.524154] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available) 666 [ 6.524268] systemd[1]: Reached target Swap. 667 [ 6.525056] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available) 668 [ 6.526058] systemd[1]: Listening on Journal Socket. 669 [ 6.527248] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available) 670 [ 6.533047] systemd[1]: Mounting Kernel Debug File System... 671 [ 6.534745] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available) 672 [ 6.541983] systemd[1]: Starting Create list of required static device nodes for the current kernel... 673 [ 6.544409] systemd[1]: Condition check resulted in Huge Pages File System being skipped. 674 [ 6.545046] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available) 675 [ 6.552303] systemd[1]: Starting Set the console keyboard layout... 676 [ 6.553537] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available) 677 [ 6.561849] systemd[1]: Starting Nameserver information manager... 678 [ 6.562972] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. 679 [ 6.565151] systemd[1]: Listening on udev Control Socket. 680 [ 6.566760] systemd[1]: Reached target Remote File Systems. 681 [ 6.568101] systemd[1]: Reached target Paths. 682 [ 6.587700] systemd[1]: Starting Restore / save the current clock... 683 [ 6.589796] systemd[1]: Listening on udev Kernel Socket. 684 [ 6.599947] systemd[1]: Starting udev Coldplug all Devices... 685 [ 6.605107] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. 686 [ 6.629831] systemd[1]: Starting Load Kernel Modules... 687 [ 6.631984] systemd[1]: Listening on Journal Socket (/dev/log). 688 [ 6.633277] systemd[1]: Reached target Local Encrypted Volumes. 689 [ 6.636298] systemd[1]: Listening on fsck to fsckd communication Socket. 690 [ 6.638256] systemd[1]: Listening on initctl Compatibility Named Pipe. 691 [ 6.649790] systemd[1]: Mounting POSIX Message Queue File System... 692 [ 6.651267] systemd[1]: Reached target System Time Synchronized. 693 [ 6.656409] systemd[1]: Created slice User and Session Slice. 694 [ 6.659160] systemd[1]: Reached target Slices. 695 [ 6.660371] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. 696 [ 6.671165] systemd[1]: Starting Remount Root and Kernel File Systems... 697 [ 6.676849] vendor storage:20190527 ret = -1 698 [ 6.696104] systemd[1]: Mounted Kernel Debug File System. 699 [ 6.702431] systemd[1]: Started Create list of required static device nodes for the current kernel. 700 [ 6.728094] systemd[1]: Started Restore / save the current clock. 701 [ 6.730583] systemd[1]: Mounted POSIX Message Queue File System. 702 [ 6.744204] systemd[1]: Started Load Kernel Modules. 703 [ 6.759422] systemd[1]: Started Nameserver information manager. 704 [ 6.763659] systemd[1]: Condition check resulted in FUSE Control File System being skipped. 705 [ 6.772624] systemd[1]: Starting Apply Kernel Variables... 706 [ 6.778356] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro 707 [ 6.797687] systemd[1]: Mounting Kernel Configuration File System... 708 [ 6.816782] systemd[1]: Started Remount Root and Kernel File Systems. 709 [ 6.821187] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. 710 [ 6.828487] systemd[1]: Starting Load/Save Random Seed... 711 [ 6.861758] systemd[1]: Starting Create System Users... 712 [ 6.879397] systemd[1]: Started Apply Kernel Variables. 713 [ 6.881319] systemd[1]: Mounted Kernel Configuration File System. 714 [ 6.959097] systemd[1]: Started Load/Save Random Seed. 715 [ 7.081052] systemd[1]: Started Set the console keyboard layout. 716 [ 7.138365] systemd[1]: Started Create System Users. 717 [ 7.145541] systemd[1]: Starting Create Static Device Nodes in /dev... 718 [ 7.217529] systemd[1]: Started Create Static Device Nodes in /dev. 719 [ 7.218879] systemd[1]: Reached target Local File Systems (Pre). 720 [ 7.225893] systemd[1]: Mounting /tmp... 721 [ 7.234095] systemd[1]: Starting udev Kernel Device Manager... 722 [ 7.247948] systemd[1]: Mounted /tmp. 723 [ 7.249641] systemd[1]: Reached target Local File Systems. 724 [ 7.257763] systemd[1]: Starting Armbian ZRAM config... 725 [ 7.259121] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. 726 [ 7.267847] systemd[1]: Starting Set console font and keymap... 727 [ 7.293094] systemd[1]: Starting Mark the need to relabel after reboot... 728 [ 7.306834] systemd[1]: Started udev Coldplug all Devices. 729 [ 7.320573] systemd[1]: Started Mark the need to relabel after reboot. 730 [ 7.332500] systemd[1]: Started Set console font and keymap. 731 [ 7.353978] systemd[1]: Starting Helper to synchronize boot up for ifupdown... 732 [ 7.387568] systemd[1]: Started Helper to synchronize boot up for ifupdown. 733 [ 7.403454] systemd[1]: Starting Raise network interfaces... 734 [ 7.433969] random: nonblocking pool is initialized 735 [ 7.477712] systemd[1]: Started udev Kernel Device Manager. 736 [ 7.573129] zram: Added device: zram0 737 [ 7.578812] zram: Added device: zram1 738 [ 7.585451] zram: Added device: zram2 739 [ 7.841365] zram0: detected capacity change from 0 to 504537088 740 [ 7.901782] systemd[1]: Found device /dev/ttyS2. 741 [ 7.917606] rk3228-codec 12010000.codec: GPIO lookup for consumer spk-en 742 [ 7.917649] rk3228-codec 12010000.codec: using device tree for GPIO lookup 743 [ 7.917690] of_get_named_gpiod_flags: can't parse 'spk-en-gpios' property of node '/codec@12010000[0]' 744 [ 7.917749] of_get_named_gpiod_flags: parsed 'spk-en-gpio' property of node '/codec@12010000[0]' - status (0) 745 [ 7.917848] rk3228-codec 12010000.codec: spk_depop_time use default value. 746 [ 7.919527] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]' 747 [ 7.919580] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]' 748 [ 7.920420] Adding 492708k swap on /dev/zram0. Priority:5 extents:1 across:492708k SS 749 [ 7.945367] asoc-simple-card sound: rk3228-hifi <-> 100b0000.i2s1 mapping ok 750 [ 7.959856] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '22:00:07', on 'May 6 2021'. 751 [ 7.960233] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13 752 [ 7.960263] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000 753 [ 7.960277] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000 754 [ 7.960288] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000 755 [ 7.960298] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000 756 [ 7.960310] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000 757 [ 7.960320] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000 758 [ 7.960330] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000 759 [ 7.960364] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000020 760 [ 7.960393] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000021 761 [ 7.960417] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000022 762 [ 7.960430] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000021 763 [ 7.960442] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000022 764 [ 7.960453] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000021 765 [ 7.960467] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali. 766 [ 7.967250] mali-utgard 20001000.gpu: leakage=5 767 [ 7.967292] mali-utgard 20001000.gpu: leakage-volt-sel=0 768 [ 7.967471] mali-utgard 20001000.gpu: Failed to get pvtm 769 [ 7.968147] mali-utgard 20001000.gpu: avs=0 770 [ 7.974575] mali-utgard 20001000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 771 [ 8.012095] Mali: Mali device driver loaded 772 [ 8.072922] devfreq 20001000.gpu: Couldn't update frequency transition information. 773 [ 8.207670] gpio_ir_recv ir-receiver: GPIO lookup for consumer (null) 774 [ 8.207704] gpio_ir_recv ir-receiver: using device tree for GPIO lookup 775 [ 8.207759] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ir-receiver[0]' - status (0) 776 [ 8.207911] Registered IR keymap rc-rktvbox 777 [ 8.208213] rc rc1: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1 778 [ 8.209167] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1/input3 779 [ 8.485667] systemd[1]: Started Raise network interfaces. 780 [ 8.674338] zram1: detected capacity change from 0 to 52428800 781 [ 8.758278] cfg80211: World regulatory domain updated: 782 [ 8.758296] cfg80211: DFS Master region: unset 783 [ 8.758297] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time) 784 [ 8.758311] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) 785 [ 8.758320] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A) 786 [ 8.758324] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A) 787 [ 8.758330] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A) 788 [ 8.758338] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s) 789 [ 8.758343] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s) 790 [ 8.758348] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A) 791 [ 8.758352] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A) 792 [ 8.830930] zram2: detected capacity change from 0 to 504537088 793 [ 8.888281] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. 794 [ 8.906424] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. 795 [ 8.907888] systemd[1]: Condition check resulted in FUSE Control File System being skipped. 796 [ 8.908302] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. 797 [ 8.909136] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. 798 [ 8.909557] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. 799 [ 8.911107] systemd[1]: Condition check resulted in Huge Pages File System being skipped. 800 [ 8.912024] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. 801 [ 8.912929] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. 802 [ 8.915473] EXT4-fs (zram2): mounted filesystem without journal. Opts: discard 803 [ 8.955804] systemd[1]: Started Armbian ZRAM config. 804 [ 8.974142] systemd[1]: Starting Armbian memory supported logging... 805 [ 9.093290] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard 806 [ 12.698524] systemd[1]: Started Armbian memory supported logging. 807 [ 12.714247] systemd[1]: Starting Journal Service... 808 [ 13.176468] systemd[1]: Started Journal Service. 809 [ 13.257243] systemd-journald[570]: Received request to flush runtime journal from PID 1 810 811 ### armbian-release: 812 813 # PLEASE DO NOT EDIT THIS FILE 814 BOARD=rk322x-box 815 BOARD_NAME="rk322x-box" 816 BOARDFAMILY=rk322x 817 BUILD_REPOSITORY_URL=git@github.com:armbian/build.git 818 BUILD_REPOSITORY_COMMIT=08297378c-dirty 819 DISTRIBUTION_CODENAME=buster 820 DISTRIBUTION_STATUS=supported 821 VERSION=21.05.1 822 LINUXFAMILY=rk322x 823 ARCH=arm 824 IMAGE_TYPE=stable 825 BOARD_TYPE=tvb 826 INITRD_ARCH=arm 827 KERNEL_IMAGE_TYPE=Image 828 829 ### boot environment: 830 831 verbosity=1 832 extraargs=coherent_pool=2M 833 bootlogo=false 834 overlay_prefix=rk322x 835 fdtfile=rk322x-box.dtb 836 rootdev=UUID=2ca5ad18-5d1f-4279-8d1e-6c805b6be8db 837 rootfstype=ext4 838 839 ### lsusb: 840 841 Fri 07 May 2021 08:24:09 PM UTC | rk322x-box | 21.05.1 | armhf | armv7l | 4.4.194-rk322x 842 Bus 007 Device 002: ID 04f3:0103 Elan Microelectronics Corp. ActiveJet K-2024 Multimedia Keyboard 843 Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 844 Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 845 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 846 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 847 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 848 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 849 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 850 851 ### lscpu: 852 853 Architecture: armv7l 854 Byte Order: Little Endian 855 CPU(s): 4 856 On-line CPU(s) list: 0-3 857 Thread(s) per core: 1 858 Core(s) per socket: 4 859 Socket(s): 1 860 Vendor ID: ARM 861 Model: 5 862 Model name: Cortex-A7 863 Stepping: r0p5 864 CPU max MHz: 1200.0000 865 CPU min MHz: 408.0000 866 BogoMIPS: 70.58 867 Flags: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 868 869 ### cpuinfo: 870 871 processor : 0 872 model name : ARMv7 Processor rev 5 (v7l) 873 BogoMIPS : 70.58 874 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 875 CPU implementer : 0x41 876 CPU architecture: 7 877 CPU variant : 0x0 878 CPU part : 0xc07 879 CPU revision : 5 880 881 processor : 1 882 model name : ARMv7 Processor rev 5 (v7l) 883 BogoMIPS : 70.58 884 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 885 CPU implementer : 0x41 886 CPU architecture: 7 887 CPU variant : 0x0 888 CPU part : 0xc07 889 CPU revision : 5 890 891 processor : 2 892 model name : ARMv7 Processor rev 5 (v7l) 893 BogoMIPS : 70.58 894 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 895 CPU implementer : 0x41 896 CPU architecture: 7 897 CPU variant : 0x0 898 CPU part : 0xc07 899 CPU revision : 5 900 901 processor : 3 902 model name : ARMv7 Processor rev 5 (v7l) 903 BogoMIPS : 70.58 904 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 905 CPU implementer : 0x41 906 CPU architecture: 7 907 CPU variant : 0x0 908 CPU part : 0xc07 909 CPU revision : 5 910 911 Hardware : Generic DT based system 912 Revision : 0000 913 Serial : cd1d5ffa03aecfa2 914 915 ### meminfo: 916 917 MemTotal: 985420 kB 918 MemFree: 897072 kB 919 MemAvailable: 923752 kB 920 Buffers: 8768 kB 921 Cached: 34840 kB 922 SwapCached: 0 kB 923 Active: 28284 kB 924 Inactive: 21916 kB 925 Active(anon): 6748 kB 926 Inactive(anon): 10764 kB 927 Active(file): 21536 kB 928 Inactive(file): 11152 kB 929 Unevictable: 0 kB 930 Mlocked: 0 kB 931 HighTotal: 0 kB 932 HighFree: 0 kB 933 LowTotal: 985420 kB 934 LowFree: 897072 kB 935 SwapTotal: 492708 kB 936 SwapFree: 492708 kB 937 Dirty: 816 kB 938 Writeback: 0 kB 939 AnonPages: 6704 kB 940 Mapped: 8312 kB 941 Shmem: 10908 kB 942 Slab: 18744 kB 943 SReclaimable: 10068 kB 944 SUnreclaim: 8676 kB 945 KernelStack: 1016 kB 946 PageTables: 312 kB 947 NFS_Unstable: 0 kB 948 Bounce: 0 kB 949 WritebackTmp: 0 kB 950 CommitLimit: 985416 kB 951 Committed_AS: 28668 kB 952 VmallocTotal: 245760 kB 953 VmallocUsed: 0 kB 954 VmallocChunk: 0 kB 955 CmaTotal: 16384 kB 956 CmaFree: 12200 kB 957 958 ### virtual memory: 959 960 vm.admin_reserve_kbytes = 8192 961 vm.block_dump = 0 962 vm.dirty_background_bytes = 0 963 vm.dirty_background_ratio = 10 964 vm.dirty_bytes = 0 965 vm.dirty_expire_centisecs = 3000 966 vm.dirty_ratio = 20 967 vm.dirtytime_expire_seconds = 43200 968 vm.dirty_writeback_centisecs = 500 969 vm.drop_caches = 0 970 vm.extra_free_kbytes = 0 971 vm.highmem_is_dirtyable = 0 972 973 ### [resize2fs] Leaving 1% spare area. Start resizing partition /dev/mmcblk0p1 now: 974 975 vm.laptop_mode = 0 976 major minor #blocks name 977 978 1 0 4096 ram0 979 179 0 60620800 mmcblk0 980 179 1 1290240 mmcblk0p1 981 253 0 492712 zram0 982 253 1 51200 zram1 983 253 2 492712 zram2 984 985 Executing fdisk, fsck and partprobe: 986 vm.legacy_va_layout = 0 987 vm.lowmem_reserve_ratio = 32 32 988 989 Welcome to fdisk (util-linux 2.33.1). 990 Changes will remain in memory only, until you decide to write them. 991 Be careful before using the write command. 992 993 994 Command (m for help): Selected partition 1 995 Partition 1 has been deleted. 996 997 Command (m for help): Partition type 998 p primary (0 primary, 0 extended, 4 free) 999 e extended (container for logical partitions) 1000 Select (default p): Partition number (1-4, default 1): First sector (2048-121241599, default 2048): Last sector, +/-sectors or +/-size{K,M,G,T,P} (8192-121241599, default 121241599): vm.max_map_count = 65530 1001 1002 Created a new partition 1 of type 'Linux' and of size 57.2 GiB. 1003 Partition #1 contains a ext4 signature. 1004 1005 Command (m for help): vm.min_free_kbytes = 3924 1006 vm.mmap_min_addr = 32768 1007 vm.mmap_rnd_bits = 8 1008 vm.nr_pdflush_threads = 0 1009 vm.oom_dump_tasks = 1 1010 1011 The partition table has been altered. 1012 Syncing disks. 1013 1014 vm.oom_kill_allocating_task = 0 1015 vm.overcommit_kbytes = 0 1016 vm.overcommit_memory = 0 1017 vm.overcommit_ratio = 50 1018 vm.page-cluster = 0 1019 vm.panic_on_oom = 0 1020 vm.percpu_pagelist_fraction = 0 1021 New partition table: 1022 1023 major minor #blocks name 1024 1025 1 0 4096 ram0 1026 179 0 60620800 mmcblk0 1027 179 1 60010496 mmcblk0p1 1028 253 0 492712 zram0 1029 253 1 51200 zram1 1030 253 2 492712 zram2 1031 1032 Now trying to resize ext4 filesystem on /dev/mmcblk0p1 to the limits: 1033 1034 vm.stat_interval = 1 1035 resize2fs 1.44.5 (15-Dec-2018) 1036 vm.swappiness = 100 1037 vm.user_reserve_kbytes = 30422 1038 vm.vfs_cache_pressure = 100 1039 1040 ### ip addr: 1041 1042 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1 1043 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 1044 inet XXX.XXX.0.1/8 scope host lo 1045 valid_lft forever preferred_lft forever 1046 inet6 ::1/128 scope host 1047 valid_lft forever preferred_lft forever 1048 2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000 1049 link/ether 62:4f:b2:6d:a6:71 brd ff:ff:ff:ff:ff:ff 1050 3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 1051 link/ether f6:b4:e0:5a:1e:3a brd ff:ff:ff:ff:ff:ff 1052 4: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1 1053 link/sit XXX.XXX.0.0 brd XXX.XXX.0.0 1054 1055 ### partitions: 1056 1057 major minor #blocks name 1058 1059 179 0 60620800 mmcblk0 1060 179 1 60010496 mmcblk0p1 1061 253 0 492712 zram0 1062 253 1 51200 zram1 1063 253 2 492712 zram2 1064 1065 ### df: 1066 1067 udev 471M 0 471M 0% /dev 1068 tmpfs 97M 2.8M 94M 3% /run 1069 /dev/mmcblk0p1 2.0G 1.1G 882M 54% / 1070 tmpfs 482M 0 482M 0% /dev/shm 1071 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 1072 tmpfs 482M 0 482M 0% /sys/fs/cgroup 1073 /dev/zram2 467M 756K 432M 1% /tmp 1074 /dev/zram1 49M 640K 45M 2% /var/log 1075 1076 ### lsblk: 1077 1078 NAME FSTYPE SIZE MOUNTPOINT UUID 1079 mmcblk0 57.8G 1080 └─mmcblk0p1 ext4 57.2G / 2ca5ad18-5d1f-4279-8d1e-6c805b6be8db 1081 zram1 50M /var/log 1082 zram2 481.2M /tmp 1083 1084 ### zramctl: 1085 1086 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 1087 /dev/zram2 lzo 481.2M 444K 6.2K 96K 4 /tmp 1088 /dev/zram1 lz4 50M 724K 148.6K 428K 4 /var/log 1089 /dev/zram0 lzo 481.2M 4K 76B 4K 4 [SWAP] 1090 1091 ### mtab: 1092 1093 /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 1094 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 1095 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 1096 /dev/zram2 /tmp ext4 rw,nosuid,relatime,discard 0 0 1097 1098 ### mmc0:59b4 info: 1099 1100 cid: 1d41445344202020100000002c015287 1101 csd: 400e00325b590001ce7f7f800a4000cf 1102 scr: 0245804300000000 1103 date: 02/2021 1104 name: SD 1105 type: SD 1106 preferred_erase_size: 4194304 1107 fwrev: 0x0 1108 hwrev: 0x1 1109 oemid: 0x4144 1110 manfid: 0x00001d 1111 serial: 0x0000002c 1112 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD MODALIAS=mmc:block 1113 erase_size: 512 1114 1115 ### Boot system health: 1116 1117 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 1118 20:24:12: 1200MHz 0.69 50% 28% 17% 0% 2% 1% 54.0°C 0/4 1119 20:24:12: 1200MHz 0.69 78% 35% 12% 2% 19% 9% 54.0°C 0/4 1120 20:24:12: 1200MHz 0.69 68% 34% 12% 1% 9% 10% 53.0°C 0/4 1121 20:24:13: 1200MHz 0.69 76% 33% 13% 1% 17% 10% 53.0°C 0/4 1122 20:24:13: 1200MHz 0.69 75% 36% 11% 1% 16% 9% 54.0°C 0/4 1123 Filesystem at /dev/mmcblk0p1 is mounted on /; on-line resizing required 1124 old_desc_blocks = 1, new_desc_blocks = 4 1125 The filesystem on /dev/mmcblk0p1 is now 15002624 (4k) blocks long. 1126 1127 1128 ### [resize2fs] Start resizing ext4 partition /dev/mmcblk0p1 now 1129 1130 resize2fs 1.44.5 (15-Dec-2018) 1131 The filesystem is already 15002624 (4k) blocks long. Nothing to do! 1132 1133 1134 ### quick iozone test: 4 690 823 4215 4523 4502 1097 1135 1136 ### [firstrun] Recreated SSH keys (entropy: 1943 1894) 1137 1138 ### Activated 1 lzo zram swap devices with 481 MB each 1139 1140 ### Activated Armbian ramlog partition with lz4 compression 1141 1142 Fri 07 May 2021 08:33:23 PM UTC | rk322x-box | 21.05.1 | armhf | armv7l | 4.4.194-rk322x 1143 1144 ### dmesg: 1145 1146 [ 0.000000] Booting Linux on physical CPU 0xf00 1147 [ 0.000000] Initializing cgroup subsys cpuset 1148 [ 0.000000] Initializing cgroup subsys cpu 1149 [ 0.000000] Initializing cgroup subsys cpuacct 1150 [ 0.000000] Linux version 4.4.194-rk322x (root@hirsute) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #3 SMP Thu May 6 22:00:38 UTC 2021 1151 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d 1152 [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache 1153 [ 0.000000] Machine model: Generic RK322x TV Box board 1154 [ 0.000000] cma: Reserved 16 MiB at 0x9f000000 1155 [ 0.000000] Memory policy: Data cache writealloc 1156 [ 0.000000] On node 0 totalpages: 253952 1157 [ 0.000000] free_area_init_node: node 0, pgdat b1253b40, node_mem_map ee6f1000 1158 [ 0.000000] Normal zone: 2304 pages used for memmap 1159 [ 0.000000] Normal zone: 0 pages reserved 1160 [ 0.000000] Normal zone: 253952 pages, LIFO batch:31 1161 [ 0.000000] psci: probing for conduit method from DT. 1162 [ 0.000000] psci: PSCIv1.0 detected in firmware. 1163 [ 0.000000] psci: Using standard PSCI v0.2 function IDs 1164 [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. 1165 [ 0.000000] PERCPU: Embedded 14 pages/cpu @ee68f000 s24856 r8192 d24296 u57344 1166 [ 0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096 1167 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 1168 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 251648 1169 [ 0.000000] Kernel command line: earlyprintk root=UUID=2ca5ad18-5d1f-4279-8d1e-6c805b6be8db console=ttyS2,115200n8 console=tty1 rootwait rootfstype=ext4 consoleblank=0 loglevel=1 ubootpart=73c5b759-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u coherent_pool=2M cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 1170 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) 1171 [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) 1172 [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) 1173 [ 0.000000] Memory: 962664K/1015808K available (12862K kernel code, 919K rwdata, 3240K rodata, 808K init, 1219K bss, 36760K reserved, 16384K cma-reserved, 0K highmem) 1174 [ 0.000000] Virtual kernel memory layout: 1175 vector : 0xffff0000 - 0xffff1000 ( 4 kB) 1176 fixmap : 0xffc00000 - 0xfff00000 (3072 kB) 1177 vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) 1178 lowmem : 0xb0000000 - 0xf0000000 (1024 MB) 1179 pkmap : 0xafe00000 - 0xb0000000 ( 2 MB) 1180 modules : 0xaf000000 - 0xafe00000 ( 14 MB) 1181 .text : 0xb0008000 - 0xb0c97c6c (12864 kB) 1182 .init : 0xb10b0000 - 0xb117a000 ( 808 kB) 1183 .data : 0xb117a000 - 0xb125fe94 ( 920 kB) 1184 .bss : 0xb1261000 - 0xb1391f14 (1220 kB) 1185 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 1186 [ 0.000000] Hierarchical RCU implementation. 1187 [ 0.000000] Build-time adjustment of leaf fanout to 32. 1188 [ 0.000000] NR_IRQS:16 nr_irqs:16 16 1189 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). 1190 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 1191 [ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 1192 [ 0.000023] Switching to timer-based delay loop, resolution 41ns 1193 [ 0.001779] Console: colour dummy device 80x30 1194 [ 0.001963] console [tty1] enabled 1195 [ 0.001989] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 1196 [ 0.002007] pid_max: default: 32768 minimum: 301 1197 [ 0.002137] Security Framework initialized 1198 [ 0.002151] Yama: becoming mindful. 1199 [ 0.002226] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) 1200 [ 0.002242] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) 1201 [ 0.003125] Initializing cgroup subsys io 1202 [ 0.003159] Initializing cgroup subsys memory 1203 [ 0.003202] Initializing cgroup subsys devices 1204 [ 0.003222] Initializing cgroup subsys freezer 1205 [ 0.003239] Initializing cgroup subsys net_cls 1206 [ 0.003256] Initializing cgroup subsys perf_event 1207 [ 0.003273] Initializing cgroup subsys net_prio 1208 [ 0.003303] Initializing cgroup subsys pids 1209 [ 0.003371] CPU: Testing write buffer coherency: ok 1210 [ 0.003420] ftrace: allocating 41892 entries in 123 pages 1211 [ 0.082730] /cpus/cpu@f00 missing clock-frequency property 1212 [ 0.082762] /cpus/cpu@f01 missing clock-frequency property 1213 [ 0.082781] /cpus/cpu@f02 missing clock-frequency property 1214 [ 0.082800] /cpus/cpu@f03 missing clock-frequency property 1215 [ 0.082813] CPU0: update cpu_capacity 430 1216 [ 0.082825] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00 1217 [ 0.082909] Setting up static identity map for 0x60008280 - 0x600082d8 1218 [ 0.094124] CPU1: update cpu_capacity 430 1219 [ 0.094133] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01 1220 [ 0.103630] CPU2: update cpu_capacity 430 1221 [ 0.103638] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02 1222 [ 0.113070] CPU3: update cpu_capacity 430 1223 [ 0.113078] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03 1224 [ 0.113211] Brought up 4 CPUs 1225 [ 0.113251] SMP: Total of 4 processors activated (192.00 BogoMIPS). 1226 [ 0.113259] CPU: All CPU(s) started in SVC mode. 1227 [ 0.114773] devtmpfs: initialized 1228 [ 0.134250] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 1229 [ 0.134837] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 1230 [ 0.134876] futex hash table entries: 1024 (order: 4, 65536 bytes) 1231 [ 0.136210] xor: measuring software checksum speed 1232 [ 0.174761] arm4regs : 1011.000 MB/sec 1233 [ 0.214864] 8regs : 705.000 MB/sec 1234 [ 0.254967] 32regs : 684.000 MB/sec 1235 [ 0.295067] neon : 1018.000 MB/sec 1236 [ 0.295077] xor: using function: neon (1018.000 MB/sec) 1237 [ 0.295119] pinctrl core: initialized pinctrl subsystem 1238 [ 0.296661] NET: Registered protocol family 16 1239 [ 0.299189] DMA: preallocated 2048 KiB pool for atomic coherent allocations 1240 [ 0.311220] cpuidle: using governor ladder 1241 [ 0.323236] cpuidle: using governor menu 1242 [ 0.339952] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0 1243 [ 0.340115] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1 1244 [ 0.340270] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2 1245 [ 0.340429] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3 1246 [ 0.346645] console [pstore-1] enabled 1247 [ 0.346657] pstore: Registered ramoops as persistent store backend 1248 [ 0.346669] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0 1249 [ 0.349994] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. 1250 [ 0.350014] hw-breakpoint: maximum watchpoint size is 8 bytes. 1251 [ 0.350233] sip_firmware_init: set rockchip sip version v2 failed 1252 [ 0.448081] raid6: int32x1 gen() 133 MB/s 1253 [ 0.516228] raid6: int32x1 xor() 131 MB/s 1254 [ 0.584427] raid6: int32x2 gen() 166 MB/s 1255 [ 0.652490] raid6: int32x2 xor() 136 MB/s 1256 [ 0.720835] raid6: int32x4 gen() 163 MB/s 1257 [ 0.788980] raid6: int32x4 xor() 137 MB/s 1258 [ 0.857229] raid6: int32x8 gen() 166 MB/s 1259 [ 0.925492] raid6: int32x8 xor() 113 MB/s 1260 [ 0.993629] raid6: neonx1 gen() 382 MB/s 1261 [ 1.061769] raid6: neonx1 xor() 290 MB/s 1262 [ 1.129953] raid6: neonx2 gen() 519 MB/s 1263 [ 1.198081] raid6: neonx2 xor() 376 MB/s 1264 [ 1.266291] raid6: neonx4 gen() 581 MB/s 1265 [ 1.334496] raid6: neonx4 xor() 400 MB/s 1266 [ 1.402796] raid6: neonx8 gen() 560 MB/s 1267 [ 1.470953] raid6: neonx8 xor() 391 MB/s 1268 [ 1.470965] raid6: using algorithm neonx4 gen() 581 MB/s 1269 [ 1.470975] raid6: .... xor() 400 MB/s, rmw enabled 1270 [ 1.470985] raid6: using intx1 recovery algorithm 1271 [ 1.471975] rockchip-pm rockchip-suspend: not set wakeup-config 1272 [ 1.471997] rockchip-pm rockchip-suspend: not set pwm-regulator-config 1273 [ 1.472371] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]' 1274 [ 1.472858] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]' 1275 [ 1.473478] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0) 1276 [ 1.474078] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0) 1277 [ 1.474586] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]' 1278 [ 1.475495] iommu: Adding device 20020000.vpu-service to group 0 1279 [ 1.475604] iommu: Adding device 20030000.rkvdec to group 1 1280 [ 1.475698] iommu: Adding device 20050000.vop to group 2 1281 [ 1.475791] iommu: Adding device 20070000.iep to group 3 1282 [ 1.476316] rk_iommu 20020800.iommu: can't get sclk 1283 [ 1.476908] rk_iommu 20030480.iommu: can't get sclk 1284 [ 1.477149] rk_iommu 20053f00.iommu: can't get sclk 1285 [ 1.477296] rk_iommu 20070800.iommu: can't get aclk 1286 [ 1.477315] rk_iommu 20070800.iommu: can't get hclk 1287 [ 1.477331] rk_iommu 20070800.iommu: can't get sclk 1288 [ 1.478081] SCSI subsystem initialized 1289 [ 1.478495] usbcore: registered new interface driver usbfs 1290 [ 1.478593] usbcore: registered new interface driver hub 1291 [ 1.478708] usbcore: registered new device driver usb 1292 [ 1.478934] media: Linux media interface: v0.10 1293 [ 1.479097] Linux video capture interface: v2.00 1294 [ 1.479350] pps_core: LinuxPPS API ver. 1 registered 1295 [ 1.479365] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 1296 [ 1.479409] PTP clock support registered 1297 [ 1.481330] Advanced Linux Sound Architecture Driver Initialized. 1298 [ 1.482326] Bluetooth: Core ver 2.21 1299 [ 1.482394] NET: Registered protocol family 31 1300 [ 1.482407] Bluetooth: HCI device and connection manager initialized 1301 [ 1.482428] Bluetooth: HCI socket layer initialized 1302 [ 1.482445] Bluetooth: L2CAP socket layer initialized 1303 [ 1.482499] Bluetooth: SCO socket layer initialized 1304 [ 1.483348] NetLabel: Initializing 1305 [ 1.483369] NetLabel: domain hash size = 128 1306 [ 1.483378] NetLabel: protocols = UNLABELED CIPSOv4 1307 [ 1.483452] NetLabel: unlabeled traffic allowed by default 1308 [ 1.484791] clocksource: Switched to clocksource arch_sys_counter 1309 [ 1.579727] NET: Registered protocol family 2 1310 [ 1.580572] TCP established hash table entries: 8192 (order: 3, 32768 bytes) 1311 [ 1.580687] TCP bind hash table entries: 8192 (order: 5, 163840 bytes) 1312 [ 1.581121] TCP: Hash tables configured (established 8192 bind 8192) 1313 [ 1.581227] UDP hash table entries: 512 (order: 2, 24576 bytes) 1314 [ 1.581296] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes) 1315 [ 1.581643] NET: Registered protocol family 1 1316 [ 1.582312] RPC: Registered named UNIX socket transport module. 1317 [ 1.582336] RPC: Registered udp transport module. 1318 [ 1.582347] RPC: Registered tcp transport module. 1319 [ 1.582357] RPC: Registered tcp NFSv4.1 backchannel transport module. 1320 [ 1.582675] Trying to unpack rootfs image as initramfs... 1321 [ 1.955432] Freeing initrd memory: 5564K 1322 [ 1.956457] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available 1323 [ 1.959405] Initialise system trusted keyring 1324 [ 1.973283] VFS: Disk quotas dquot_6.6.0 1325 [ 1.973596] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) 1326 [ 1.976249] squashfs: version 4.0 (2009/01/31) Phillip Lougher 1327 [ 1.979676] NFS: Registering the id_resolver key type 1328 [ 1.979740] Key type id_resolver registered 1329 [ 1.979752] Key type id_legacy registered 1330 [ 1.979788] nfs4filelayout_init: NFSv4 File Layout Driver Registering... 1331 [ 1.979901] ntfs: driver 2.1.32 [Flags: R/W]. 1332 [ 1.980944] JFS: nTxBlock = 7692, nTxLock = 61538 1333 [ 1.989607] SGI XFS with security attributes, no debug enabled 1334 [ 1.998768] NET: Registered protocol family 38 1335 [ 1.998821] Key type asymmetric registered 1336 [ 1.998842] Asymmetric key parser 'x509' registered 1337 [ 1.999241] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) 1338 [ 1.999655] io scheduler noop registered 1339 [ 1.999686] io scheduler deadline registered 1340 [ 1.999768] io scheduler cfq registered (default) 1341 [ 2.002955] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator 1342 [ 2.008001] rk-vcodec 20020000.vpu-service: no regulator for vcodec 1343 [ 2.008404] rk-vcodec 20020000.vpu-service: probe device 1344 [ 2.008871] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled 1345 [ 2.010094] rk-vcodec 20020000.vpu-service: could not find power_model node 1346 [ 2.010121] rk-vcodec 20020000.vpu-service: init success 1347 [ 2.010441] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry 1348 [ 2.014706] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330 1349 [ 2.014733] dma-pl330 110f0000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 1350 [ 2.015854] rockchip-system-monitor rockchip-system-monitor: system monitor probe 1351 [ 2.016335] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable 1352 [ 2.016355] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup 1353 [ 2.016372] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]' 1354 [ 2.016387] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]' 1355 [ 2.016400] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup 1356 [ 2.016415] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed 1357 [ 2.017132] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable 1358 [ 2.017157] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup 1359 [ 2.017173] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]' 1360 [ 2.017188] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]' 1361 [ 2.017201] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup 1362 [ 2.017216] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed 1363 [ 2.018254] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled 1364 [ 2.019047] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A 1365 [ 2.019870] console [ttyS2] enabled 1366 [ 2.021716] [drm] Initialized drm 1.1.0 20060810 1367 [ 2.024197] [drm] Rockchip DRM driver version: v1.0.1 1368 [ 2.024432] rockchip-drm display-subsystem: devfreq is not set 1369 [ 2.025238] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d1b2b0) 1370 [ 2.025627] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports 1371 [ 2.025654] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver 1372 [ 2.025764] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy) 1373 [ 2.027025] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d13808) 1374 [ 2.027050] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). 1375 [ 2.027060] [drm] No driver support for vblank timestamp query. 1376 [ 2.027175] rockchip-drm display-subsystem: failed to parse display resources 1377 [ 2.027238] rockchip-drm display-subsystem: No connectors reported connected with modes 1378 [ 2.027325] [drm] Cannot find any crtc or sizes - going 1024x768 1379 [ 2.049646] Console: switching to colour frame buffer device 128x48 1380 [ 2.065034] rockchip-drm display-subsystem: fb0: frame buffer device 1381 [ 2.081353] Registered IR keymap rc-cec 1382 [ 2.081622] rc rc0: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0 1383 [ 2.082282] input: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0/input0 1384 [ 2.084408] brd: module loaded 1385 [ 2.095567] loop: module loaded 1386 [ 2.095658] lkdtm: No crash points registered, enable through debugfs 1387 [ 2.098209] libphy: Fixed MDIO Bus: probed 1388 [ 2.098241] tun: Universal TUN/TAP device driver, 1.6 1389 [ 2.098253] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> 1390 [ 2.098601] CAN device driver interface 1391 [ 2.099992] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output). 1392 [ 2.100020] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30). 1393 [ 2.100035] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10). 1394 [ 2.100077] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes). 1395 [ 2.100248] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed 1396 [ 2.105327] rk_gmac-dwmac 30200000.ethernet: init for RMII 1397 [ 2.140929] stmmac - user ID: 0x10, Synopsys ID: 0x35 1398 [ 2.140945] Ring mode enabled 1399 [ 2.140956] DMA HW capability register supported 1400 [ 2.140965] Normal descriptors 1401 [ 2.140977] RX Checksum Offload Engine supported (type 2) 1402 [ 2.140986] TX Checksum insertion supported 1403 [ 2.140994] Wake-Up On Lan supported 1404 [ 2.141087] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: f6:b4:e0:5a:1e:3a 1405 [ 2.141101] eth%d: device MAC address f6:b4:e0:5a:1e:3a 1406 [ 2.141110] Enable RX Mitigation via HW Watchdog Timer 1407 [ 2.141312] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0) 1408 [ 2.546537] libphy: stmmac: probed 1409 [ 2.546567] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active 1410 [ 2.546580] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01) 1411 [ 2.546593] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02) 1412 [ 2.546606] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03) 1413 [ 2.546619] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04) 1414 [ 2.546631] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05) 1415 [ 2.546643] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06) 1416 [ 2.546656] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07) 1417 [ 2.546668] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08) 1418 [ 2.546681] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09) 1419 [ 2.546693] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a) 1420 [ 2.546706] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b) 1421 [ 2.546718] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c) 1422 [ 2.546731] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d) 1423 [ 2.546743] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e) 1424 [ 2.546756] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f) 1425 [ 2.546768] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10) 1426 [ 2.546780] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11) 1427 [ 2.546793] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12) 1428 [ 2.546805] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13) 1429 [ 2.546818] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14) 1430 [ 2.546830] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15) 1431 [ 2.546842] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16) 1432 [ 2.546855] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17) 1433 [ 2.546867] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18) 1434 [ 2.546879] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19) 1435 [ 2.546892] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a) 1436 [ 2.546904] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b) 1437 [ 2.546916] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c) 1438 [ 2.546929] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d) 1439 [ 2.546941] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e) 1440 [ 2.546953] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f) 1441 [ 2.548402] PPP generic driver version 2.4.2 1442 [ 2.548852] Atmel at76x USB Wireless LAN Driver 0.17 loading 1443 [ 2.548999] usbcore: registered new interface driver at76c50x-usb 1444 [ 2.549132] usbcore: registered new interface driver rtl8187 1445 [ 2.549250] usbcore: registered new interface driver rndis_wlan 1446 [ 2.549372] usbcore: registered new interface driver zd1201 1447 [ 2.549774] usbcore: registered new interface driver rt2800usb 1448 [ 2.549890] Rockchip WiFi SYS interface (V1.00) ... 1449 [ 2.549957] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver 1450 [ 2.550043] usbcore: registered new interface driver pegasus 1451 [ 2.550130] usbcore: registered new interface driver rtl8150 1452 [ 2.550213] usbcore: registered new interface driver r8152 1453 [ 2.550326] usbcore: registered new interface driver asix 1454 [ 2.550411] usbcore: registered new interface driver ax88179_178a 1455 [ 2.550492] usbcore: registered new interface driver cdc_ether 1456 [ 2.550573] usbcore: registered new interface driver dm9601 1457 [ 2.550676] usbcore: registered new interface driver smsc75xx 1458 [ 2.550781] usbcore: registered new interface driver smsc95xx 1459 [ 2.550863] usbcore: registered new interface driver net1080 1460 [ 2.550946] usbcore: registered new interface driver rndis_host 1461 [ 2.551056] usbcore: registered new interface driver MOSCHIP usb-ethernet driver 1462 [ 2.551198] usbcore: registered new interface driver cdc_ncm 1463 [ 2.551285] usbcore: registered new interface driver cdc_mbim 1464 [ 2.551779] 30040000.usb supply vusb_d not found, using dummy regulator 1465 [ 2.551878] 30040000.usb supply vusb_a not found, using dummy regulator 1466 [ 2.565079] dwc2 30040000.usb: DWC OTG Controller 1467 [ 2.565131] dwc2 30040000.usb: new USB bus registered, assigned bus number 1 1468 [ 2.565189] dwc2 30040000.usb: irq 49, io mem 0x30040000 1469 [ 2.565526] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 1470 [ 2.565544] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1471 [ 2.565558] usb usb1: Product: DWC OTG Controller 1472 [ 2.565572] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg 1473 [ 2.565586] usb usb1: SerialNumber: 30040000.usb 1474 [ 2.566577] hub 1-0:1.0: USB hub found 1475 [ 2.566646] hub 1-0:1.0: 1 port detected 1476 [ 2.568184] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 1477 [ 2.568211] ehci-platform: EHCI generic platform driver 1478 [ 2.570749] ehci-platform 30080000.usb: EHCI Host Controller 1479 [ 2.571136] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2 1480 [ 2.571421] ehci-platform 30080000.usb: irq 50, io mem 0x30080000 1481 [ 2.580838] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00 1482 [ 2.581137] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 1483 [ 2.581156] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1484 [ 2.581171] usb usb2: Product: EHCI Host Controller 1485 [ 2.581184] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd 1486 [ 2.581198] usb usb2: SerialNumber: 30080000.usb 1487 [ 2.582175] hub 2-0:1.0: USB hub found 1488 [ 2.582248] hub 2-0:1.0: 1 port detected 1489 [ 2.585146] ehci-platform 300c0000.usb: EHCI Host Controller 1490 [ 2.585568] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3 1491 [ 2.585844] ehci-platform 300c0000.usb: irq 52, io mem 0x300c0000 1492 [ 2.596837] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00 1493 [ 2.597150] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 1494 [ 2.597170] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1495 [ 2.597184] usb usb3: Product: EHCI Host Controller 1496 [ 2.597198] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd 1497 [ 2.597212] usb usb3: SerialNumber: 300c0000.usb 1498 [ 2.598182] hub 3-0:1.0: USB hub found 1499 [ 2.598249] hub 3-0:1.0: 1 port detected 1500 [ 2.601161] ehci-platform 30100000.usb: EHCI Host Controller 1501 [ 2.601536] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4 1502 [ 2.601832] ehci-platform 30100000.usb: irq 54, io mem 0x30100000 1503 [ 2.612832] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00 1504 [ 2.613121] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 1505 [ 2.613140] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1506 [ 2.613154] usb usb4: Product: EHCI Host Controller 1507 [ 2.613168] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd 1508 [ 2.613181] usb usb4: SerialNumber: 30100000.usb 1509 [ 2.614183] hub 4-0:1.0: USB hub found 1510 [ 2.614253] hub 4-0:1.0: 1 port detected 1511 [ 2.615062] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 1512 [ 2.615135] ohci-platform: OHCI generic platform driver 1513 [ 2.615531] ohci-platform 300a0000.usb: Generic Platform OHCI controller 1514 [ 2.615937] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5 1515 [ 2.616205] ohci-platform 300a0000.usb: irq 51, io mem 0x300a0000 1516 [ 2.673081] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001 1517 [ 2.673104] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1518 [ 2.673118] usb usb5: Product: Generic Platform OHCI controller 1519 [ 2.673132] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd 1520 [ 2.673146] usb usb5: SerialNumber: 300a0000.usb 1521 [ 2.674183] hub 5-0:1.0: USB hub found 1522 [ 2.674256] hub 5-0:1.0: 1 port detected 1523 [ 2.675105] ohci-platform 300e0000.usb: Generic Platform OHCI controller 1524 [ 2.675482] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6 1525 [ 2.675730] ohci-platform 300e0000.usb: irq 53, io mem 0x300e0000 1526 [ 2.733079] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 1527 [ 2.733101] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1528 [ 2.733116] usb usb6: Product: Generic Platform OHCI controller 1529 [ 2.733130] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd 1530 [ 2.733143] usb usb6: SerialNumber: 300e0000.usb 1531 [ 2.734120] hub 6-0:1.0: USB hub found 1532 [ 2.734196] hub 6-0:1.0: 1 port detected 1533 [ 2.734977] ohci-platform 30120000.usb: Generic Platform OHCI controller 1534 [ 2.735357] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7 1535 [ 2.735617] ohci-platform 30120000.usb: irq 55, io mem 0x30120000 1536 [ 2.793111] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001 1537 [ 2.793133] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 1538 [ 2.793148] usb usb7: Product: Generic Platform OHCI controller 1539 [ 2.793161] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd 1540 [ 2.793175] usb usb7: SerialNumber: 30120000.usb 1541 [ 2.794149] hub 7-0:1.0: USB hub found 1542 [ 2.794217] hub 7-0:1.0: 1 port detected 1543 [ 2.795120] usbcore: registered new interface driver cdc_acm 1544 [ 2.795137] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters 1545 [ 2.795245] usbcore: registered new interface driver cdc_wdm 1546 [ 2.795548] usbcore: registered new interface driver usb-storage 1547 [ 2.795723] usbcore: registered new interface driver usbserial 1548 [ 2.795801] usbcore: registered new interface driver usbserial_generic 1549 [ 2.795865] usbserial: USB Serial support registered for generic 1550 [ 2.795977] usbcore: registered new interface driver keyspan 1551 [ 2.796038] usbserial: USB Serial support registered for Keyspan - (without firmware) 1552 [ 2.796095] usbserial: USB Serial support registered for Keyspan 1 port adapter 1553 [ 2.796152] usbserial: USB Serial support registered for Keyspan 2 port adapter 1554 [ 2.796210] usbserial: USB Serial support registered for Keyspan 4 port adapter 1555 [ 2.796322] usbcore: registered new interface driver option 1556 [ 2.796390] usbserial: USB Serial support registered for GSM modem (1-port) 1557 [ 2.797142] usbcore: registered new interface driver oti6858 1558 [ 2.797216] usbserial: USB Serial support registered for oti6858 1559 [ 2.797321] usbcore: registered new interface driver qcserial 1560 [ 2.797384] usbserial: USB Serial support registered for Qualcomm USB modem 1561 [ 2.797544] usbcore: registered new interface driver sierra 1562 [ 2.797605] usbserial: USB Serial support registered for Sierra USB modem 1563 [ 2.799079] usbcore: registered new interface driver iforce 1564 [ 2.799236] usbcore: registered new interface driver xpad 1565 [ 2.799548] usbcore: registered new interface driver usbtouchscreen 1566 [ 2.800730] i2c /dev entries driver 1567 [ 2.802747] IR NEC protocol handler initialized 1568 [ 2.802775] IR RC5(x/sz) protocol handler initialized 1569 [ 2.802793] IR RC6 protocol handler initialized 1570 [ 2.802809] IR JVC protocol handler initialized 1571 [ 2.802827] IR Sony protocol handler initialized 1572 [ 2.802843] IR SANYO protocol handler initialized 1573 [ 2.802860] IR Sharp protocol handler initialized 1574 [ 2.802878] IR MCE Keyboard/mouse protocol handler initialized 1575 [ 2.802895] IR XMP protocol handler initialized 1576 [ 2.804609] usbcore: registered new interface driver uvcvideo 1577 [ 2.804623] USB Video Class driver (1.1.1) 1578 [ 2.806591] Boot mode: normal 1579 [ 2.807776] rockchip-thermal 11150000.tsadc: tsadc is probed successfully! 1580 [ 2.809531] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com 1581 [ 2.809885] Bluetooth: Virtual HCI driver ver 1.5 1582 [ 2.810150] Bluetooth: HCI UART driver ver 2.3 1583 [ 2.810168] Bluetooth: HCI UART protocol H4 registered 1584 [ 2.810179] Bluetooth: HCI UART protocol LL registered 1585 [ 2.810190] Bluetooth: HCI UART protocol ATH3K registered 1586 [ 2.810201] Bluetooth: HCI UART protocol Three-wire (H5) registered 1587 [ 2.810366] Bluetooth: HCI UART protocol BCM registered 1588 [ 2.810516] usbcore: registered new interface driver bfusb 1589 [ 2.810660] usbcore: registered new interface driver btusb 1590 [ 2.810683] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 1591 [ 2.811283] cpu cpu0: leakage=6 1592 [ 2.811316] cpu cpu0: leakage-volt-sel=0 1593 [ 2.811522] cpu cpu0: Failed to get pvtm 1594 [ 2.812946] cpu cpu0: avs=0 1595 [ 2.813023] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 1596 [ 2.813047] cpu cpu0: failed to read out thermal zone (-22) 1597 [ 2.813682] cpu cpu0: failed to find power_model node 1598 [ 2.814317] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset 1599 [ 2.814335] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup 1600 [ 2.814357] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0) 1601 [ 2.814698] Synopsys Designware Multimedia Card Interface Driver 1602 [ 2.815311] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode. 1603 [ 2.815434] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller. 1604 [ 2.815451] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a 1605 [ 2.815514] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo 1606 [ 2.815582] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found 1607 [ 2.815593] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found 1608 [ 2.815615] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd 1609 [ 2.815625] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup 1610 [ 2.815652] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0) 1611 [ 2.815687] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations 1612 [ 2.815698] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO 1613 [ 2.815710] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp 1614 [ 2.815719] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup 1615 [ 2.815729] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]' 1616 [ 2.815739] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]' 1617 [ 2.815748] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup 1618 [ 2.815758] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed 1619 [ 2.828573] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) 1620 [ 2.841476] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized 1621 [ 2.841827] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available 1622 [ 2.841913] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode. 1623 [ 2.842002] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller. 1624 [ 2.842018] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a 1625 [ 2.842072] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo 1626 [ 2.842123] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found 1627 [ 2.842133] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found 1628 [ 2.842151] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp 1629 [ 2.842161] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup 1630 [ 2.842174] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]' 1631 [ 2.842184] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]' 1632 [ 2.842193] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup 1633 [ 2.842203] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed 1634 [ 2.842270] dwmmc_rockchip 30010000.dwmmc: allocated mmc-pwrseq 1635 [ 2.855029] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2) 1636 [ 2.867671] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized 1637 [ 2.868039] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode. 1638 [ 2.868207] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller. 1639 [ 2.868226] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a 1640 [ 2.868302] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo 1641 [ 2.868353] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found 1642 [ 2.868364] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found 1643 [ 2.868381] dwmmc_rockchip 30020000.dwmmc: GPIO lookup for consumer wp 1644 [ 2.868392] dwmmc_rockchip 30020000.dwmmc: using device tree for GPIO lookup 1645 [ 2.868404] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30020000[0]' 1646 [ 2.868416] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30020000[0]' 1647 [ 2.868425] dwmmc_rockchip 30020000.dwmmc: using lookup tables for GPIO lookup 1648 [ 2.868436] dwmmc_rockchip 30020000.dwmmc: lookup for GPIO wp failed 1649 [ 2.873208] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) 1650 [ 2.873297] mmc0: new high speed SDXC card at address 59b4 1651 [ 2.874020] mmcblk0: mmc0:59b4 SD 57.8 GiB 1652 [ 2.875707] mmcblk0: p1 1653 [ 2.880885] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) 1654 [ 2.893078] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized 1655 [ 2.893904] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/working[0]' - status (0) 1656 [ 2.894468] ledtrig-cpu: registered to indicate activity on CPUs 1657 [ 2.894753] hidraw: raw HID events driver (C) Jiri Kosina 1658 [ 2.895461] usbcore: registered new interface driver usbhid 1659 [ 2.895482] usbhid: USB HID core driver 1660 [ 2.896081] ashmem: initialized 1661 [ 2.899645] rknandbase v1.2 2018-05-08 1662 [ 2.900075] rknand 30030000.nandc: rknand_probe clk rate = 150000000 1663 [ 2.900425] ftl_init fffffffe 1664 [ 2.900443] rk_ftl_init fail 1665 [ 2.901918] usbcore: registered new interface driver snd-usb-audio 1666 [ 2.902126] usbcore: registered new interface driver snd-ua101 1667 [ 2.902307] usbcore: registered new interface driver snd-usb-caiaq 1668 [ 2.902475] usbcore: registered new interface driver snd-usb-6fire 1669 [ 2.902656] usbcore: registered new interface driver snd-usb-hiface 1670 [ 2.902793] usbcore: registered new interface driver snd-bcd2000 1671 [ 2.902929] usbcore: registered new interface driver snd_usb_pod 1672 [ 2.903066] usbcore: registered new interface driver snd_usb_podhd 1673 [ 2.903214] usbcore: registered new interface driver snd_usb_toneport 1674 [ 2.903352] usbcore: registered new interface driver snd_usb_variax 1675 [ 2.910997] u32 classifier 1676 [ 2.911023] input device check on 1677 [ 2.911037] Actions configured 1678 [ 2.911067] Netfilter messages via NETLINK v0.30. 1679 [ 2.911111] nfnl_acct: registering with nfnetlink. 1680 [ 2.911255] nf_conntrack version 0.5.0 (15384 buckets, 61536 max) 1681 [ 2.912033] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) 1682 [ 2.912597] Initializing XFRM netlink socket 1683 [ 2.914348] NET: Registered protocol family 10 1684 [ 2.914643] mmc1: new high speed SDIO card at address 0001 1685 [ 2.916264] ip6_tables: (C) 2000-2006 Netfilter Core Team 1686 [ 2.916934] sit: IPv6 over IPv4 tunneling driver 1687 [ 2.918266] NET: Registered protocol family 17 1688 [ 2.918333] NET: Registered protocol family 15 1689 [ 2.918431] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. 1690 [ 2.918508] Bridge firewalling registered 1691 [ 2.918533] can: controller area network core (rev 20120528 abi 9) 1692 [ 2.918651] NET: Registered protocol family 29 1693 [ 2.918682] can: raw protocol (rev 20120528) 1694 [ 2.918708] can: broadcast manager protocol (rev 20120528 t) 1695 [ 2.918741] can: netlink gateway (rev 20130117) max_hops=1 1696 [ 2.919389] Bluetooth: RFCOMM TTY layer initialized 1697 [ 2.919436] Bluetooth: RFCOMM socket layer initialized 1698 [ 2.919486] Bluetooth: RFCOMM ver 1.11 1699 [ 2.919529] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 1700 [ 2.919557] Bluetooth: HIDP socket layer initialized 1701 [ 2.919674] 8021q: 802.1Q VLAN Support v1.8 1702 [ 2.919746] lib80211: common routines for IEEE802.11 drivers 1703 [ 2.919766] lib80211_crypt: registered algorithm 'NULL' 1704 [ 2.919795] lib80211_crypt: registered algorithm 'WEP' 1705 [ 2.919822] lib80211_crypt: registered algorithm 'CCMP' 1706 [ 2.919850] lib80211_crypt: registered algorithm 'TKIP' 1707 [ 2.919873] [WLAN_RFKILL]: Enter rfkill_wlan_init 1708 [ 2.920277] [BT_RFKILL]: Enter rfkill_rk_init 1709 [ 2.920623] Key type dns_resolver registered 1710 [ 2.921186] flash vendor_init_thread! 1711 [ 2.921213] flash vendor storage:20170308 ret = -1 1712 [ 2.921304] Error: Driver 'sc031gs' is already registered, aborting... 1713 [ 2.922511] Registering SWP/SWPB emulation handler 1714 [ 2.924174] registered taskstats version 1 1715 [ 2.924218] Loading compiled-in X.509 certificates 1716 [ 2.924965] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0) 1717 [ 2.927498] Btrfs loaded 1718 [ 2.928447] rga2: Driver loaded successfully ver:4.01 1719 [ 2.928675] rga2: Module initialized. 1720 [ 2.928712] pvtm list NULL 1721 [ 2.929795] rk-vcodec 20030000.rkvdec: leakage=5 1722 [ 2.929826] rk-vcodec 20030000.rkvdec: leakage-volt-sel=0 1723 [ 2.929934] rk-vcodec 20030000.rkvdec: Failed to get pvtm 1724 [ 2.930315] rk-vcodec 20030000.rkvdec: avs=0 1725 [ 2.930577] rk-vcodec 20030000.rkvdec: probe device 1726 [ 2.930986] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled 1727 [ 2.932120] rk-vcodec 20030000.rkvdec: init success 1728 [ 2.933118] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]' 1729 [ 2.933139] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]' 1730 [ 2.934032] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok 1731 [ 2.935701] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]' 1732 [ 2.935723] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]' 1733 [ 2.936652] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok 1734 [ 2.938841] hctosys: unable to open rtc device (rtc0) 1735 [ 2.952163] ALSA device list: 1736 [ 2.952191] #0: DW-I2S-HDMI 1737 [ 2.952200] #1: SPDIF 1738 [ 2.953302] Freeing unused kernel memory: 808K 1739 [ 2.953318] This architecture does not have kernel memory protection. 1740 [ 2.964935] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0) 1741 [ 3.008966] mmc_host mmc2: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0) 1742 [ 4.072272] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) 1743 [ 4.825632] systemd[1]: System time before build time, advancing clock. 1744 [ 4.848081] systemd[1]: Inserted module 'autofs4' 1745 [ 4.853698] ip_tables: (C) 2000-2006 Netfilter Core Team 1746 [ 4.862762] cgroup: cgroup2: unknown option "nsdelegate" 1747 [ 4.877222] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 1748 [ 4.878341] systemd[1]: Detected architecture arm. 1749 [ 4.889759] systemd[1]: Set hostname to <rk322x-box>. 1750 [ 5.062845] ttyS2 - failed to request DMA, use interrupt mode 1751 [ 5.234923] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. 1752 [ 5.234968] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) 1753 [ 5.652492] random: systemd: uninitialized urandom read (16 bytes read, 41 bits of entropy available) 1754 [ 5.677076] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. 1755 [ 5.677220] random: systemd: uninitialized urandom read (16 bytes read, 41 bits of entropy available) 1756 [ 5.678018] systemd[1]: Listening on Journal Socket (/dev/log). 1757 [ 5.678862] random: systemd: uninitialized urandom read (16 bytes read, 41 bits of entropy available) 1758 [ 5.681623] systemd[1]: Created slice User and Session Slice. 1759 [ 5.682278] random: systemd: uninitialized urandom read (16 bytes read, 41 bits of entropy available) 1760 [ 5.682668] systemd[1]: Started Forward Password Requests to Wall Directory Watch. 1761 [ 5.683346] random: systemd: uninitialized urandom read (16 bytes read, 41 bits of entropy available) 1762 [ 5.684091] systemd[1]: Listening on Journal Socket. 1763 [ 5.685237] random: systemd: uninitialized urandom read (16 bytes read, 41 bits of entropy available) 1764 [ 5.691662] systemd[1]: Mounting Kernel Debug File System... 1765 [ 5.692565] random: systemd: uninitialized urandom read (16 bytes read, 41 bits of entropy available) 1766 [ 5.698908] systemd[1]: Starting Nameserver information manager... 1767 [ 5.699853] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. 1768 [ 5.703647] random: systemd: uninitialized urandom read (16 bytes read, 41 bits of entropy available) 1769 [ 5.710999] systemd[1]: Starting Load Kernel Modules... 1770 [ 5.712002] random: systemd: uninitialized urandom read (16 bytes read, 41 bits of entropy available) 1771 [ 5.712158] systemd[1]: Reached target Paths. 1772 [ 5.713035] random: systemd: uninitialized urandom read (16 bytes read, 41 bits of entropy available) 1773 [ 5.714056] systemd[1]: Listening on udev Control Socket. 1774 [ 5.716596] systemd[1]: Created slice system-getty.slice. 1775 [ 5.718129] systemd[1]: Listening on udev Kernel Socket. 1776 [ 5.726627] systemd[1]: Starting udev Coldplug all Devices... 1777 [ 5.730725] systemd[1]: Created slice system-serial\x2dgetty.slice. 1778 [ 5.739260] systemd[1]: Mounting POSIX Message Queue File System... 1779 [ 5.740367] systemd[1]: Reached target Slices. 1780 [ 5.752702] systemd[1]: Starting Set the console keyboard layout... 1781 [ 5.753988] systemd[1]: Reached target System Time Synchronized. 1782 [ 5.756479] systemd[1]: Listening on Syslog Socket. 1783 [ 5.769727] systemd[1]: Starting Restore / save the current clock... 1784 [ 5.770996] systemd[1]: Reached target Local Encrypted Volumes. 1785 [ 5.772304] systemd[1]: Reached target Swap. 1786 [ 5.773519] systemd[1]: Reached target Remote File Systems. 1787 [ 5.774695] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. 1788 [ 5.777500] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. 1789 [ 5.778686] systemd[1]: Condition check resulted in Huge Pages File System being skipped. 1790 [ 5.780225] systemd[1]: Listening on fsck to fsckd communication Socket. 1791 [ 5.781380] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. 1792 [ 5.790280] systemd[1]: Starting Remount Root and Kernel File Systems... 1793 [ 5.791968] systemd[1]: Listening on initctl Compatibility Named Pipe. 1794 [ 5.801558] systemd[1]: Starting Create list of required static device nodes for the current kernel... 1795 [ 5.811015] systemd[1]: Mounted Kernel Debug File System. 1796 [ 5.821394] systemd[1]: Started Load Kernel Modules. 1797 [ 5.846467] systemd[1]: Mounted POSIX Message Queue File System. 1798 [ 5.852598] systemd[1]: Started Create list of required static device nodes for the current kernel. 1799 [ 5.858918] systemd[1]: Started Nameserver information manager. 1800 [ 5.871172] systemd[1]: Started Restore / save the current clock. 1801 [ 5.887090] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro 1802 [ 5.890866] systemd[1]: Starting Apply Kernel Variables... 1803 [ 5.899201] systemd[1]: Condition check resulted in FUSE Control File System being skipped. 1804 [ 5.907670] systemd[1]: Mounting Kernel Configuration File System... 1805 [ 5.944910] vendor storage:20190527 ret = -1 1806 [ 5.946183] systemd[1]: Started Remount Root and Kernel File Systems. 1807 [ 5.953458] systemd[1]: Mounted Kernel Configuration File System. 1808 [ 5.974461] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. 1809 [ 5.980941] systemd[1]: Starting Create System Users... 1810 [ 5.994239] systemd[1]: Starting Load/Save Random Seed... 1811 [ 6.010377] systemd[1]: Started Apply Kernel Variables. 1812 [ 6.066076] systemd[1]: Started Create System Users. 1813 [ 6.075492] systemd[1]: Started Load/Save Random Seed. 1814 [ 6.087933] systemd[1]: Starting Create Static Device Nodes in /dev... 1815 [ 6.171244] systemd[1]: Started Create Static Device Nodes in /dev. 1816 [ 6.182173] systemd[1]: Starting udev Kernel Device Manager... 1817 [ 6.227943] systemd[1]: Started Set the console keyboard layout. 1818 [ 6.234314] systemd[1]: Reached target Local File Systems (Pre). 1819 [ 6.247954] systemd[1]: Mounting /tmp... 1820 [ 6.268045] systemd[1]: Mounted /tmp. 1821 [ 6.276029] systemd[1]: Reached target Local File Systems. 1822 [ 6.282780] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped. 1823 [ 6.283200] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. 1824 [ 6.292213] systemd[1]: Starting Armbian ZRAM config... 1825 [ 6.311363] systemd[1]: Starting Set console font and keymap... 1826 [ 6.331789] systemd[1]: Started udev Kernel Device Manager. 1827 [ 6.365376] systemd[1]: Started Set console font and keymap. 1828 [ 6.405915] systemd[1]: Started udev Coldplug all Devices. 1829 [ 6.428070] systemd[1]: Starting Helper to synchronize boot up for ifupdown... 1830 [ 6.484556] systemd[1]: Started Helper to synchronize boot up for ifupdown. 1831 [ 6.501330] systemd[1]: Starting Raise network interfaces... 1832 [ 6.646941] zram: Added device: zram0 1833 [ 6.650419] zram: Added device: zram1 1834 [ 6.655207] zram: Added device: zram2 1835 [ 6.707878] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '22:00:07', on 'May 6 2021'. 1836 [ 6.708138] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13 1837 [ 6.708158] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000 1838 [ 6.708170] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000 1839 [ 6.708180] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000 1840 [ 6.708190] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000 1841 [ 6.708200] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000 1842 [ 6.708210] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000 1843 [ 6.708220] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000 1844 [ 6.708230] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000020 1845 [ 6.708246] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000021 1846 [ 6.708263] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000022 1847 [ 6.708273] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000021 1848 [ 6.708282] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000022 1849 [ 6.708293] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000021 1850 [ 6.708304] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali. 1851 [ 6.708580] mali-utgard 20001000.gpu: leakage=5 1852 [ 6.708608] mali-utgard 20001000.gpu: leakage-volt-sel=0 1853 [ 6.708714] mali-utgard 20001000.gpu: Failed to get pvtm 1854 [ 6.709307] mali-utgard 20001000.gpu: avs=0 1855 [ 6.709674] mali-utgard 20001000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 1856 [ 6.718545] Mali: Mali device driver loaded 1857 [ 6.726957] systemd[1]: Found device /dev/ttyS2. 1858 [ 6.728437] rk3228-codec 12010000.codec: GPIO lookup for consumer spk-en 1859 [ 6.728444] rk3228-codec 12010000.codec: using device tree for GPIO lookup 1860 [ 6.728453] of_get_named_gpiod_flags: can't parse 'spk-en-gpios' property of node '/codec@12010000[0]' 1861 [ 6.728483] of_get_named_gpiod_flags: parsed 'spk-en-gpio' property of node '/codec@12010000[0]' - status (0) 1862 [ 6.728535] rk3228-codec 12010000.codec: spk_depop_time use default value. 1863 [ 6.733468] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]' 1864 [ 6.733476] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]' 1865 [ 6.760145] asoc-simple-card sound: rk3228-hifi <-> 100b0000.i2s1 mapping ok 1866 [ 6.809012] devfreq 20001000.gpu: Couldn't update frequency transition information. 1867 [ 6.903195] gpio_ir_recv ir-receiver: GPIO lookup for consumer (null) 1868 [ 6.903233] gpio_ir_recv ir-receiver: using device tree for GPIO lookup 1869 [ 6.903291] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ir-receiver[0]' - status (0) 1870 [ 6.903429] Registered IR keymap rc-rktvbox 1871 [ 6.903698] rc rc1: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1 1872 [ 6.904275] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1/input1 1873 [ 7.093272] zram0: detected capacity change from 0 to 504537088 1874 [ 7.435941] systemd[1]: Started Raise network interfaces. 1875 [ 7.550331] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. 1876 [ 7.555428] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. 1877 [ 7.555983] systemd[1]: Condition check resulted in Huge Pages File System being skipped. 1878 [ 7.556459] systemd[1]: Condition check resulted in FUSE Control File System being skipped. 1879 [ 7.556673] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. 1880 [ 7.557195] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. 1881 [ 7.557431] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. 1882 [ 7.557561] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. 1883 [ 7.557874] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. 1884 [ 7.862425] cfg80211: World regulatory domain updated: 1885 [ 7.862456] cfg80211: DFS Master region: unset 1886 [ 7.862467] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time) 1887 [ 7.862485] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) 1888 [ 7.862502] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A) 1889 [ 7.862515] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A) 1890 [ 7.862531] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A) 1891 [ 7.862546] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s) 1892 [ 7.862560] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s) 1893 [ 7.862574] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A) 1894 [ 7.862587] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A) 1895 [ 8.174155] Adding 492708k swap on /dev/zram0. Priority:5 extents:1 across:492708k SS 1896 [ 8.403888] zram1: detected capacity change from 0 to 52428800 1897 [ 10.495965] systemd[1]: Started Armbian ZRAM config. 1898 [ 10.514681] systemd[1]: Starting Armbian memory supported logging... 1899 [ 10.639460] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard 1900 [ 14.202643] systemd[1]: Started Armbian memory supported logging. 1901 [ 14.216753] systemd[1]: Starting Journal Service... 1902 [ 14.625873] systemd[1]: Started Journal Service. 1903 [ 14.697141] systemd-journald[574]: Received request to flush runtime journal from PID 1 1904 1905 ### armbian-release: 1906 1907 # PLEASE DO NOT EDIT THIS FILE 1908 BOARD=rk322x-box 1909 BOARD_NAME="rk322x-box" 1910 BOARDFAMILY=rk322x 1911 BUILD_REPOSITORY_URL=git@github.com:armbian/build.git 1912 BUILD_REPOSITORY_COMMIT=08297378c-dirty 1913 DISTRIBUTION_CODENAME=buster 1914 DISTRIBUTION_STATUS=supported 1915 VERSION=21.05.1 1916 LINUXFAMILY=rk322x 1917 ARCH=arm 1918 IMAGE_TYPE=stable 1919 BOARD_TYPE=tvb 1920 INITRD_ARCH=arm 1921 KERNEL_IMAGE_TYPE=Image 1922 1923 ### boot environment: 1924 1925 verbosity=1 1926 extraargs=coherent_pool=2M 1927 bootlogo=false 1928 overlay_prefix=rk322x 1929 fdtfile=rk322x-box.dtb 1930 rootdev=UUID=2ca5ad18-5d1f-4279-8d1e-6c805b6be8db 1931 rootfstype=ext4 1932 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 1933 1934 ### lsusb: 1935 1936 Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 1937 Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 1938 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 1939 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 1940 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 1941 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 1942 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 1943 1944 ### lscpu: 1945 1946 Architecture: armv7l 1947 Byte Order: Little Endian 1948 CPU(s): 4 1949 On-line CPU(s) list: 0-3 1950 Thread(s) per core: 1 1951 Core(s) per socket: 4 1952 Socket(s): 1 1953 Vendor ID: ARM 1954 Model: 5 1955 Model name: Cortex-A7 1956 Stepping: r0p5 1957 CPU max MHz: 1200.0000 1958 CPU min MHz: 408.0000 1959 BogoMIPS: 70.58 1960 Flags: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 1961 1962 ### cpuinfo: 1963 1964 processor : 0 1965 model name : ARMv7 Processor rev 5 (v7l) 1966 BogoMIPS : 70.58 1967 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 1968 CPU implementer : 0x41 1969 CPU architecture: 7 1970 CPU variant : 0x0 1971 CPU part : 0xc07 1972 CPU revision : 5 1973 1974 processor : 1 1975 model name : ARMv7 Processor rev 5 (v7l) 1976 BogoMIPS : 70.58 1977 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 1978 CPU implementer : 0x41 1979 CPU architecture: 7 1980 CPU variant : 0x0 1981 CPU part : 0xc07 1982 CPU revision : 5 1983 1984 processor : 2 1985 model name : ARMv7 Processor rev 5 (v7l) 1986 BogoMIPS : 70.58 1987 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 1988 CPU implementer : 0x41 1989 CPU architecture: 7 1990 CPU variant : 0x0 1991 CPU part : 0xc07 1992 CPU revision : 5 1993 1994 processor : 3 1995 model name : ARMv7 Processor rev 5 (v7l) 1996 BogoMIPS : 70.58 1997 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 1998 CPU implementer : 0x41 1999 CPU architecture: 7 2000 CPU variant : 0x0 2001 CPU part : 0xc07 2002 CPU revision : 5 2003 2004 Hardware : Generic DT based system 2005 Revision : 0000 2006 Serial : cd1d5ffa03aecfa2 2007 2008 ### meminfo: 2009 2010 MemTotal: 985420 kB 2011 MemFree: 905472 kB 2012 MemAvailable: 931444 kB 2013 Buffers: 8720 kB 2014 Cached: 29232 kB 2015 SwapCached: 0 kB 2016 Active: 27008 kB 2017 Inactive: 16840 kB 2018 Active(anon): 6112 kB 2019 Inactive(anon): 5708 kB 2020 Active(file): 20896 kB 2021 Inactive(file): 11132 kB 2022 Unevictable: 0 kB 2023 Mlocked: 0 kB 2024 HighTotal: 0 kB 2025 HighFree: 0 kB 2026 LowTotal: 985420 kB 2027 LowFree: 905472 kB 2028 SwapTotal: 492708 kB 2029 SwapFree: 492708 kB 2030 Dirty: 1276 kB 2031 Writeback: 0 kB 2032 AnonPages: 5988 kB 2033 Mapped: 7952 kB 2034 Shmem: 5836 kB 2035 Slab: 18256 kB 2036 SReclaimable: 9972 kB 2037 SUnreclaim: 8284 kB 2038 KernelStack: 928 kB 2039 PageTables: 232 kB 2040 NFS_Unstable: 0 kB 2041 Bounce: 0 kB 2042 WritebackTmp: 0 kB 2043 CommitLimit: 985416 kB 2044 Committed_AS: 21552 kB 2045 VmallocTotal: 245760 kB 2046 VmallocUsed: 0 kB 2047 VmallocChunk: 0 kB 2048 CmaTotal: 16384 kB 2049 CmaFree: 12204 kB 2050 2051 ### virtual memory: 2052 2053 vm.admin_reserve_kbytes = 8192 2054 vm.block_dump = 0 2055 vm.dirty_background_bytes = 0 2056 vm.dirty_background_ratio = 10 2057 vm.dirty_bytes = 0 2058 vm.dirty_expire_centisecs = 3000 2059 vm.dirty_ratio = 20 2060 vm.dirtytime_expire_seconds = 43200 2061 vm.dirty_writeback_centisecs = 500 2062 vm.drop_caches = 0 2063 vm.extra_free_kbytes = 0 2064 vm.highmem_is_dirtyable = 0 2065 vm.laptop_mode = 0 2066 vm.legacy_va_layout = 0 2067 vm.lowmem_reserve_ratio = 32 32 2068 vm.max_map_count = 65530 2069 vm.min_free_kbytes = 3924 2070 vm.mmap_min_addr = 32768 2071 vm.mmap_rnd_bits = 8 2072 vm.nr_pdflush_threads = 0 2073 vm.oom_dump_tasks = 1 2074 vm.oom_kill_allocating_task = 0 2075 vm.overcommit_kbytes = 0 2076 vm.overcommit_memory = 0 2077 vm.overcommit_ratio = 50 2078 vm.page-cluster = 0 2079 vm.panic_on_oom = 0 2080 vm.percpu_pagelist_fraction = 0 2081 vm.stat_interval = 1 2082 vm.swappiness = 100 2083 vm.user_reserve_kbytes = 30422 2084 vm.vfs_cache_pressure = 100 2085 2086 ### ip addr: 2087 2088 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1 2089 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 2090 inet XXX.XXX.0.1/8 scope host lo 2091 valid_lft forever preferred_lft forever 2092 inet6 ::1/128 scope host 2093 valid_lft forever preferred_lft forever 2094 2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000 2095 link/ether f2:16:49:d5:79:1e brd ff:ff:ff:ff:ff:ff 2096 3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 2097 link/ether f6:b4:e0:5a:1e:3a brd ff:ff:ff:ff:ff:ff 2098 4: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1 2099 link/sit XXX.XXX.0.0 brd XXX.XXX.0.0 2100 2101 ### partitions: 2102 2103 major minor #blocks name 2104 2105 179 0 60620800 mmcblk0 2106 179 1 60010496 mmcblk0p1 2107 253 0 492712 zram0 2108 253 1 51200 zram1 2109 2110 ### df: 2111 2112 udev 471M 0 471M 0% /dev 2113 tmpfs 97M 2.8M 94M 3% /run 2114 /dev/mmcblk0p1 56G 1.1G 55G 2% / 2115 tmpfs 482M 0 482M 0% /dev/shm 2116 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 2117 tmpfs 482M 0 482M 0% /sys/fs/cgroup 2118 tmpfs 482M 0 482M 0% /tmp 2119 /dev/zram1 49M 1.3M 44M 3% /var/log 2120 2121 ### lsblk: 2122 2123 NAME FSTYPE SIZE MOUNTPOINT UUID 2124 mmcblk0 57.8G 2125 └─mmcblk0p1 ext4 57.2G / 2ca5ad18-5d1f-4279-8d1e-6c805b6be8db 2126 zram1 50M /var/log 2127 2128 ### zramctl: 2129 2130 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 2131 /dev/zram1 lz4 50M 132K 868B 32K 4 /var/log 2132 /dev/zram0 lzo 481.2M 4K 76B 4K 4 [SWAP] 2133 2134 ### mtab: 2135 2136 /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 2137 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 2138 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 2139 2140 ### mmc0:59b4 info: 2141 2142 cid: 1d41445344202020100000002c015287 2143 csd: 400e00325b590001ce7f7f800a4000cf 2144 scr: 0245804300000000 2145 date: 02/2021 2146 name: SD 2147 type: SD 2148 preferred_erase_size: 4194304 2149 fwrev: 0x0 2150 hwrev: 0x1 2151 oemid: 0x4144 2152 manfid: 0x00001d 2153 serial: 0x0000002c 2154 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD MODALIAS=mmc:block 2155 erase_size: 512 2156 2157 ### Boot system health: 2158 2159 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 2160 20:33:25: 1200MHz 1.28 38% 21% 14% 0% 2% 0% 45.8°C 0/4 2161 20:33:25: 1200MHz 1.28 56% 23% 31% 1% 0% 0% 45.0°C 0/4 2162 20:33:26: 816MHz 1.28 34% 20% 12% 1% 0% 0% 43.0°C 0/4 2163 20:33:26: 1008MHz 1.28 33% 19% 11% 1% 0% 0% 43.0°C 0/4 2164 20:33:27: 816MHz 1.28 34% 18% 14% 2% 0% 0% 43.0°C 0/4 2165 2166 ### Activated 1 lzo zram swap devices with 481 MB each 2167 2168 ### Activated Armbian ramlog partition with lz4 compression 2169 2170 Thu 03 Jun 2021 10:37:05 PM UTC | rk322x-box | 21.05.1 | armhf | armv7l | 4.4.194-rk322x 2171 2172 ### dmesg: 2173 2174 [ 0.000000] Booting Linux on physical CPU 0xf00 2175 [ 0.000000] Initializing cgroup subsys cpuset 2176 [ 0.000000] Initializing cgroup subsys cpu 2177 [ 0.000000] Initializing cgroup subsys cpuacct 2178 [ 0.000000] Linux version 4.4.194-rk322x (root@hirsute) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #3 SMP Thu May 6 22:00:38 UTC 2021 2179 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d 2180 [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache 2181 [ 0.000000] Machine model: Generic RK322x TV Box board 2182 [ 0.000000] cma: Reserved 16 MiB at 0x9f000000 2183 [ 0.000000] Memory policy: Data cache writealloc 2184 [ 0.000000] On node 0 totalpages: 253952 2185 [ 0.000000] free_area_init_node: node 0, pgdat b1253b40, node_mem_map ee6f1000 2186 [ 0.000000] Normal zone: 2304 pages used for memmap 2187 [ 0.000000] Normal zone: 0 pages reserved 2188 [ 0.000000] Normal zone: 253952 pages, LIFO batch:31 2189 [ 0.000000] psci: probing for conduit method from DT. 2190 [ 0.000000] psci: PSCIv1.0 detected in firmware. 2191 [ 0.000000] psci: Using standard PSCI v0.2 function IDs 2192 [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. 2193 [ 0.000000] PERCPU: Embedded 14 pages/cpu @ee68f000 s24856 r8192 d24296 u57344 2194 [ 0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096 2195 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 2196 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 251648 2197 [ 0.000000] Kernel command line: earlyprintk root=UUID=2ca5ad18-5d1f-4279-8d1e-6c805b6be8db console=ttyS2,115200n8 console=tty1 rootwait rootfstype=ext4 consoleblank=0 loglevel=1 ubootpart=73c5b759-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u coherent_pool=2M cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 2198 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) 2199 [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) 2200 [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) 2201 [ 0.000000] Memory: 962664K/1015808K available (12862K kernel code, 919K rwdata, 3240K rodata, 808K init, 1219K bss, 36760K reserved, 16384K cma-reserved, 0K highmem) 2202 [ 0.000000] Virtual kernel memory layout: 2203 vector : 0xffff0000 - 0xffff1000 ( 4 kB) 2204 fixmap : 0xffc00000 - 0xfff00000 (3072 kB) 2205 vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) 2206 lowmem : 0xb0000000 - 0xf0000000 (1024 MB) 2207 pkmap : 0xafe00000 - 0xb0000000 ( 2 MB) 2208 modules : 0xaf000000 - 0xafe00000 ( 14 MB) 2209 .text : 0xb0008000 - 0xb0c97c6c (12864 kB) 2210 .init : 0xb10b0000 - 0xb117a000 ( 808 kB) 2211 .data : 0xb117a000 - 0xb125fe94 ( 920 kB) 2212 .bss : 0xb1261000 - 0xb1391f14 (1220 kB) 2213 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 2214 [ 0.000000] Hierarchical RCU implementation. 2215 [ 0.000000] Build-time adjustment of leaf fanout to 32. 2216 [ 0.000000] NR_IRQS:16 nr_irqs:16 16 2217 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). 2218 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns 2219 [ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns 2220 [ 0.000023] Switching to timer-based delay loop, resolution 41ns 2221 [ 0.001792] Console: colour dummy device 80x30 2222 [ 0.001976] console [tty1] enabled 2223 [ 0.002001] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) 2224 [ 0.002018] pid_max: default: 32768 minimum: 301 2225 [ 0.002150] Security Framework initialized 2226 [ 0.002164] Yama: becoming mindful. 2227 [ 0.002239] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) 2228 [ 0.002255] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) 2229 [ 0.003142] Initializing cgroup subsys io 2230 [ 0.003175] Initializing cgroup subsys memory 2231 [ 0.003217] Initializing cgroup subsys devices 2232 [ 0.003237] Initializing cgroup subsys freezer 2233 [ 0.003254] Initializing cgroup subsys net_cls 2234 [ 0.003271] Initializing cgroup subsys perf_event 2235 [ 0.003289] Initializing cgroup subsys net_prio 2236 [ 0.003318] Initializing cgroup subsys pids 2237 [ 0.003386] CPU: Testing write buffer coherency: ok 2238 [ 0.003434] ftrace: allocating 41892 entries in 123 pages 2239 [ 0.082718] /cpus/cpu@f00 missing clock-frequency property 2240 [ 0.082751] /cpus/cpu@f01 missing clock-frequency property 2241 [ 0.082770] /cpus/cpu@f02 missing clock-frequency property 2242 [ 0.082789] /cpus/cpu@f03 missing clock-frequency property 2243 [ 0.082802] CPU0: update cpu_capacity 430 2244 [ 0.082813] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00 2245 [ 0.082895] Setting up static identity map for 0x60008280 - 0x600082d8 2246 [ 0.094098] CPU1: update cpu_capacity 430 2247 [ 0.094107] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01 2248 [ 0.103563] CPU2: update cpu_capacity 430 2249 [ 0.103572] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02 2250 [ 0.113014] CPU3: update cpu_capacity 430 2251 [ 0.113021] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03 2252 [ 0.113154] Brought up 4 CPUs 2253 [ 0.113194] SMP: Total of 4 processors activated (192.00 BogoMIPS). 2254 [ 0.113203] CPU: All CPU(s) started in SVC mode. 2255 [ 0.114720] devtmpfs: initialized 2256 [ 0.134345] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 2257 [ 0.134927] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns 2258 [ 0.134968] futex hash table entries: 1024 (order: 4, 65536 bytes) 2259 [ 0.136300] xor: measuring software checksum speed 2260 [ 0.174743] arm4regs : 1011.000 MB/sec 2261 [ 0.214847] 8regs : 705.000 MB/sec 2262 [ 0.254950] 32regs : 684.000 MB/sec 2263 [ 0.295051] neon : 1018.000 MB/sec 2264 [ 0.295061] xor: using function: neon (1018.000 MB/sec) 2265 [ 0.295101] pinctrl core: initialized pinctrl subsystem 2266 [ 0.296656] NET: Registered protocol family 16 2267 [ 0.299187] DMA: preallocated 2048 KiB pool for atomic coherent allocations 2268 [ 0.311205] cpuidle: using governor ladder 2269 [ 0.323217] cpuidle: using governor menu 2270 [ 0.339630] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0 2271 [ 0.339792] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1 2272 [ 0.339953] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2 2273 [ 0.340104] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3 2274 [ 0.346648] console [pstore-1] enabled 2275 [ 0.346660] pstore: Registered ramoops as persistent store backend 2276 [ 0.346672] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0 2277 [ 0.350043] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. 2278 [ 0.350064] hw-breakpoint: maximum watchpoint size is 8 bytes. 2279 [ 0.350273] sip_firmware_init: set rockchip sip version v2 failed 2280 [ 0.448073] raid6: int32x1 gen() 133 MB/s 2281 [ 0.516162] raid6: int32x1 xor() 131 MB/s 2282 [ 0.584418] raid6: int32x2 gen() 166 MB/s 2283 [ 0.652687] raid6: int32x2 xor() 137 MB/s 2284 [ 0.720838] raid6: int32x4 gen() 163 MB/s 2285 [ 0.788992] raid6: int32x4 xor() 137 MB/s 2286 [ 0.857228] raid6: int32x8 gen() 166 MB/s 2287 [ 0.925497] raid6: int32x8 xor() 113 MB/s 2288 [ 0.993623] raid6: neonx1 gen() 382 MB/s 2289 [ 1.061750] raid6: neonx1 xor() 290 MB/s 2290 [ 1.129947] raid6: neonx2 gen() 519 MB/s 2291 [ 1.198094] raid6: neonx2 xor() 376 MB/s 2292 [ 1.266296] raid6: neonx4 gen() 581 MB/s 2293 [ 1.334511] raid6: neonx4 xor() 400 MB/s 2294 [ 1.402798] raid6: neonx8 gen() 560 MB/s 2295 [ 1.470954] raid6: neonx8 xor() 391 MB/s 2296 [ 1.470966] raid6: using algorithm neonx4 gen() 581 MB/s 2297 [ 1.470976] raid6: .... xor() 400 MB/s, rmw enabled 2298 [ 1.470986] raid6: using intx1 recovery algorithm 2299 [ 1.471964] rockchip-pm rockchip-suspend: not set wakeup-config 2300 [ 1.471988] rockchip-pm rockchip-suspend: not set pwm-regulator-config 2301 [ 1.472350] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]' 2302 [ 1.472838] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]' 2303 [ 1.473475] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0) 2304 [ 1.474074] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0) 2305 [ 1.474568] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]' 2306 [ 1.475480] iommu: Adding device 20020000.vpu-service to group 0 2307 [ 1.475602] iommu: Adding device 20030000.rkvdec to group 1 2308 [ 1.475698] iommu: Adding device 20050000.vop to group 2 2309 [ 1.475791] iommu: Adding device 20070000.iep to group 3 2310 [ 1.476314] rk_iommu 20020800.iommu: can't get sclk 2311 [ 1.476889] rk_iommu 20030480.iommu: can't get sclk 2312 [ 1.477146] rk_iommu 20053f00.iommu: can't get sclk 2313 [ 1.477291] rk_iommu 20070800.iommu: can't get aclk 2314 [ 1.477310] rk_iommu 20070800.iommu: can't get hclk 2315 [ 1.477326] rk_iommu 20070800.iommu: can't get sclk 2316 [ 1.478077] SCSI subsystem initialized 2317 [ 1.478490] usbcore: registered new interface driver usbfs 2318 [ 1.478591] usbcore: registered new interface driver hub 2319 [ 1.478709] usbcore: registered new device driver usb 2320 [ 1.478929] media: Linux media interface: v0.10 2321 [ 1.479086] Linux video capture interface: v2.00 2322 [ 1.479340] pps_core: LinuxPPS API ver. 1 registered 2323 [ 1.479355] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> 2324 [ 1.479397] PTP clock support registered 2325 [ 1.481305] Advanced Linux Sound Architecture Driver Initialized. 2326 [ 1.482296] Bluetooth: Core ver 2.21 2327 [ 1.482365] NET: Registered protocol family 31 2328 [ 1.482378] Bluetooth: HCI device and connection manager initialized 2329 [ 1.482399] Bluetooth: HCI socket layer initialized 2330 [ 1.482416] Bluetooth: L2CAP socket layer initialized 2331 [ 1.482471] Bluetooth: SCO socket layer initialized 2332 [ 1.483320] NetLabel: Initializing 2333 [ 1.483341] NetLabel: domain hash size = 128 2334 [ 1.483350] NetLabel: protocols = UNLABELED CIPSOv4 2335 [ 1.483425] NetLabel: unlabeled traffic allowed by default 2336 [ 1.484764] clocksource: Switched to clocksource arch_sys_counter 2337 [ 1.579751] NET: Registered protocol family 2 2338 [ 1.580616] TCP established hash table entries: 8192 (order: 3, 32768 bytes) 2339 [ 1.580732] TCP bind hash table entries: 8192 (order: 5, 163840 bytes) 2340 [ 1.581168] TCP: Hash tables configured (established 8192 bind 8192) 2341 [ 1.581265] UDP hash table entries: 512 (order: 2, 24576 bytes) 2342 [ 1.581334] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes) 2343 [ 1.581684] NET: Registered protocol family 1 2344 [ 1.582353] RPC: Registered named UNIX socket transport module. 2345 [ 1.582376] RPC: Registered udp transport module. 2346 [ 1.582387] RPC: Registered tcp transport module. 2347 [ 1.582397] RPC: Registered tcp NFSv4.1 backchannel transport module. 2348 [ 1.582718] Trying to unpack rootfs image as initramfs... 2349 [ 1.955842] Freeing initrd memory: 5564K 2350 [ 1.956989] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available 2351 [ 1.959892] Initialise system trusted keyring 2352 [ 1.973812] VFS: Disk quotas dquot_6.6.0 2353 [ 1.974119] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) 2354 [ 1.976802] squashfs: version 4.0 (2009/01/31) Phillip Lougher 2355 [ 1.980139] NFS: Registering the id_resolver key type 2356 [ 1.980230] Key type id_resolver registered 2357 [ 1.980242] Key type id_legacy registered 2358 [ 1.980278] nfs4filelayout_init: NFSv4 File Layout Driver Registering... 2359 [ 1.980389] ntfs: driver 2.1.32 [Flags: R/W]. 2360 [ 1.981436] JFS: nTxBlock = 7692, nTxLock = 61538 2361 [ 1.990031] SGI XFS with security attributes, no debug enabled 2362 [ 1.998857] NET: Registered protocol family 38 2363 [ 1.998908] Key type asymmetric registered 2364 [ 1.998929] Asymmetric key parser 'x509' registered 2365 [ 1.999327] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) 2366 [ 1.999702] io scheduler noop registered 2367 [ 1.999731] io scheduler deadline registered 2368 [ 1.999832] io scheduler cfq registered (default) 2369 [ 2.003035] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator 2370 [ 2.008053] rk-vcodec 20020000.vpu-service: no regulator for vcodec 2371 [ 2.008451] rk-vcodec 20020000.vpu-service: probe device 2372 [ 2.008928] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled 2373 [ 2.010127] rk-vcodec 20020000.vpu-service: could not find power_model node 2374 [ 2.010153] rk-vcodec 20020000.vpu-service: init success 2375 [ 2.010596] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry 2376 [ 2.014832] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330 2377 [ 2.014859] dma-pl330 110f0000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 2378 [ 2.015962] rockchip-system-monitor rockchip-system-monitor: system monitor probe 2379 [ 2.016426] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable 2380 [ 2.016444] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup 2381 [ 2.016461] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]' 2382 [ 2.016477] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]' 2383 [ 2.016490] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup 2384 [ 2.016505] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed 2385 [ 2.017208] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable 2386 [ 2.017231] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup 2387 [ 2.017247] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]' 2388 [ 2.017261] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]' 2389 [ 2.017275] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup 2390 [ 2.017290] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed 2391 [ 2.018346] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled 2392 [ 2.019147] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A 2393 [ 2.019973] console [ttyS2] enabled 2394 [ 2.021808] [drm] Initialized drm 1.1.0 20060810 2395 [ 2.024178] [drm] Rockchip DRM driver version: v1.0.1 2396 [ 2.024432] rockchip-drm display-subsystem: devfreq is not set 2397 [ 2.025216] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d1b2b0) 2398 [ 2.025614] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports 2399 [ 2.025641] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver 2400 [ 2.025761] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy) 2401 [ 2.026998] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d13808) 2402 [ 2.027022] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). 2403 [ 2.027034] [drm] No driver support for vblank timestamp query. 2404 [ 2.027148] rockchip-drm display-subsystem: failed to parse display resources 2405 [ 2.027211] rockchip-drm display-subsystem: No connectors reported connected with modes 2406 [ 2.027295] [drm] Cannot find any crtc or sizes - going 1024x768 2407 [ 2.049574] Console: switching to colour frame buffer device 128x48 2408 [ 2.064926] rockchip-drm display-subsystem: fb0: frame buffer device 2409 [ 2.081300] Registered IR keymap rc-cec 2410 [ 2.081555] rc rc0: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0 2411 [ 2.082225] input: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0/input0 2412 [ 2.084363] brd: module loaded 2413 [ 2.095588] loop: module loaded 2414 [ 2.095679] lkdtm: No crash points registered, enable through debugfs 2415 [ 2.098200] libphy: Fixed MDIO Bus: probed 2416 [ 2.098233] tun: Universal TUN/TAP device driver, 1.6 2417 [ 2.098244] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> 2418 [ 2.098599] CAN device driver interface 2419 [ 2.099947] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output). 2420 [ 2.099975] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30). 2421 [ 2.099990] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10). 2422 [ 2.100047] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes). 2423 [ 2.100219] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed 2424 [ 2.105298] rk_gmac-dwmac 30200000.ethernet: init for RMII 2425 [ 2.140889] stmmac - user ID: 0x10, Synopsys ID: 0x35 2426 [ 2.140906] Ring mode enabled 2427 [ 2.140916] DMA HW capability register supported 2428 [ 2.140926] Normal descriptors 2429 [ 2.140937] RX Checksum Offload Engine supported (type 2) 2430 [ 2.140946] TX Checksum insertion supported 2431 [ 2.140954] Wake-Up On Lan supported 2432 [ 2.141049] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: f6:b4:e0:5a:1e:3a 2433 [ 2.141062] eth%d: device MAC address f6:b4:e0:5a:1e:3a 2434 [ 2.141072] Enable RX Mitigation via HW Watchdog Timer 2435 [ 2.141267] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0) 2436 [ 2.546294] libphy: stmmac: probed 2437 [ 2.546324] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active 2438 [ 2.546338] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01) 2439 [ 2.546351] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02) 2440 [ 2.546364] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03) 2441 [ 2.546376] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04) 2442 [ 2.546388] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05) 2443 [ 2.546401] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06) 2444 [ 2.546413] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07) 2445 [ 2.546425] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08) 2446 [ 2.546437] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09) 2447 [ 2.546450] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a) 2448 [ 2.546462] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b) 2449 [ 2.546475] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c) 2450 [ 2.546487] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d) 2451 [ 2.546500] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e) 2452 [ 2.546512] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f) 2453 [ 2.546524] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10) 2454 [ 2.546536] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11) 2455 [ 2.546549] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12) 2456 [ 2.546561] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13) 2457 [ 2.546574] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14) 2458 [ 2.546586] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15) 2459 [ 2.546598] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16) 2460 [ 2.546611] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17) 2461 [ 2.546623] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18) 2462 [ 2.546635] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19) 2463 [ 2.546648] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a) 2464 [ 2.546660] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b) 2465 [ 2.546672] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c) 2466 [ 2.546684] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d) 2467 [ 2.546696] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e) 2468 [ 2.546708] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f) 2469 [ 2.548146] PPP generic driver version 2.4.2 2470 [ 2.548542] Atmel at76x USB Wireless LAN Driver 0.17 loading 2471 [ 2.548681] usbcore: registered new interface driver at76c50x-usb 2472 [ 2.548887] usbcore: registered new interface driver rtl8187 2473 [ 2.549012] usbcore: registered new interface driver rndis_wlan 2474 [ 2.549122] usbcore: registered new interface driver zd1201 2475 [ 2.549500] usbcore: registered new interface driver rt2800usb 2476 [ 2.549628] Rockchip WiFi SYS interface (V1.00) ... 2477 [ 2.549698] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver 2478 [ 2.549784] usbcore: registered new interface driver pegasus 2479 [ 2.549871] usbcore: registered new interface driver rtl8150 2480 [ 2.549955] usbcore: registered new interface driver r8152 2481 [ 2.550056] usbcore: registered new interface driver asix 2482 [ 2.550138] usbcore: registered new interface driver ax88179_178a 2483 [ 2.550219] usbcore: registered new interface driver cdc_ether 2484 [ 2.550311] usbcore: registered new interface driver dm9601 2485 [ 2.550419] usbcore: registered new interface driver smsc75xx 2486 [ 2.550526] usbcore: registered new interface driver smsc95xx 2487 [ 2.550608] usbcore: registered new interface driver net1080 2488 [ 2.550690] usbcore: registered new interface driver rndis_host 2489 [ 2.550774] usbcore: registered new interface driver MOSCHIP usb-ethernet driver 2490 [ 2.550913] usbcore: registered new interface driver cdc_ncm 2491 [ 2.551006] usbcore: registered new interface driver cdc_mbim 2492 [ 2.551481] 30040000.usb supply vusb_d not found, using dummy regulator 2493 [ 2.551579] 30040000.usb supply vusb_a not found, using dummy regulator 2494 [ 2.564723] dwc2 30040000.usb: DWC OTG Controller 2495 [ 2.564835] dwc2 30040000.usb: new USB bus registered, assigned bus number 1 2496 [ 2.564895] dwc2 30040000.usb: irq 48, io mem 0x30040000 2497 [ 2.565264] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 2498 [ 2.565282] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2499 [ 2.565296] usb usb1: Product: DWC OTG Controller 2500 [ 2.565310] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg 2501 [ 2.565323] usb usb1: SerialNumber: 30040000.usb 2502 [ 2.566309] hub 1-0:1.0: USB hub found 2503 [ 2.566382] hub 1-0:1.0: 1 port detected 2504 [ 2.567890] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver 2505 [ 2.567919] ehci-platform: EHCI generic platform driver 2506 [ 2.570433] ehci-platform 30080000.usb: EHCI Host Controller 2507 [ 2.570799] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2 2508 [ 2.571097] ehci-platform 30080000.usb: irq 49, io mem 0x30080000 2509 [ 2.580807] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00 2510 [ 2.581149] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 2511 [ 2.581168] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2512 [ 2.581182] usb usb2: Product: EHCI Host Controller 2513 [ 2.581196] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd 2514 [ 2.581210] usb usb2: SerialNumber: 30080000.usb 2515 [ 2.582183] hub 2-0:1.0: USB hub found 2516 [ 2.582253] hub 2-0:1.0: 1 port detected 2517 [ 2.585160] ehci-platform 300c0000.usb: EHCI Host Controller 2518 [ 2.585553] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3 2519 [ 2.585848] ehci-platform 300c0000.usb: irq 51, io mem 0x300c0000 2520 [ 2.596808] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00 2521 [ 2.597096] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 2522 [ 2.597115] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2523 [ 2.597130] usb usb3: Product: EHCI Host Controller 2524 [ 2.597144] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd 2525 [ 2.597157] usb usb3: SerialNumber: 300c0000.usb 2526 [ 2.598133] hub 3-0:1.0: USB hub found 2527 [ 2.598202] hub 3-0:1.0: 1 port detected 2528 [ 2.601121] ehci-platform 30100000.usb: EHCI Host Controller 2529 [ 2.601512] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4 2530 [ 2.601797] ehci-platform 30100000.usb: irq 53, io mem 0x30100000 2531 [ 2.612808] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00 2532 [ 2.613102] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 2533 [ 2.613120] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2534 [ 2.613136] usb usb4: Product: EHCI Host Controller 2535 [ 2.613149] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd 2536 [ 2.613163] usb usb4: SerialNumber: 30100000.usb 2537 [ 2.614137] hub 4-0:1.0: USB hub found 2538 [ 2.614205] hub 4-0:1.0: 1 port detected 2539 [ 2.615019] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver 2540 [ 2.615093] ohci-platform: OHCI generic platform driver 2541 [ 2.615499] ohci-platform 300a0000.usb: Generic Platform OHCI controller 2542 [ 2.615895] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5 2543 [ 2.616154] ohci-platform 300a0000.usb: irq 50, io mem 0x300a0000 2544 [ 2.673054] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001 2545 [ 2.673078] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2546 [ 2.673092] usb usb5: Product: Generic Platform OHCI controller 2547 [ 2.673106] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd 2548 [ 2.673120] usb usb5: SerialNumber: 300a0000.usb 2549 [ 2.674144] hub 5-0:1.0: USB hub found 2550 [ 2.674212] hub 5-0:1.0: 1 port detected 2551 [ 2.675068] ohci-platform 300e0000.usb: Generic Platform OHCI controller 2552 [ 2.675453] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6 2553 [ 2.675712] ohci-platform 300e0000.usb: irq 52, io mem 0x300e0000 2554 [ 2.733047] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 2555 [ 2.733071] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2556 [ 2.733086] usb usb6: Product: Generic Platform OHCI controller 2557 [ 2.733100] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd 2558 [ 2.733113] usb usb6: SerialNumber: 300e0000.usb 2559 [ 2.734095] hub 6-0:1.0: USB hub found 2560 [ 2.734171] hub 6-0:1.0: 1 port detected 2561 [ 2.734967] ohci-platform 30120000.usb: Generic Platform OHCI controller 2562 [ 2.735326] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7 2563 [ 2.735592] ohci-platform 30120000.usb: irq 54, io mem 0x30120000 2564 [ 2.793061] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001 2565 [ 2.793085] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 2566 [ 2.793100] usb usb7: Product: Generic Platform OHCI controller 2567 [ 2.793114] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd 2568 [ 2.793127] usb usb7: SerialNumber: 30120000.usb 2569 [ 2.794092] hub 7-0:1.0: USB hub found 2570 [ 2.794161] hub 7-0:1.0: 1 port detected 2571 [ 2.795073] usbcore: registered new interface driver cdc_acm 2572 [ 2.795089] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters 2573 [ 2.795197] usbcore: registered new interface driver cdc_wdm 2574 [ 2.795505] usbcore: registered new interface driver usb-storage 2575 [ 2.795676] usbcore: registered new interface driver usbserial 2576 [ 2.795755] usbcore: registered new interface driver usbserial_generic 2577 [ 2.795827] usbserial: USB Serial support registered for generic 2578 [ 2.795933] usbcore: registered new interface driver keyspan 2579 [ 2.795994] usbserial: USB Serial support registered for Keyspan - (without firmware) 2580 [ 2.796052] usbserial: USB Serial support registered for Keyspan 1 port adapter 2581 [ 2.796111] usbserial: USB Serial support registered for Keyspan 2 port adapter 2582 [ 2.796169] usbserial: USB Serial support registered for Keyspan 4 port adapter 2583 [ 2.796285] usbcore: registered new interface driver option 2584 [ 2.796345] usbserial: USB Serial support registered for GSM modem (1-port) 2585 [ 2.797098] usbcore: registered new interface driver oti6858 2586 [ 2.797170] usbserial: USB Serial support registered for oti6858 2587 [ 2.797275] usbcore: registered new interface driver qcserial 2588 [ 2.797351] usbserial: USB Serial support registered for Qualcomm USB modem 2589 [ 2.797514] usbcore: registered new interface driver sierra 2590 [ 2.797575] usbserial: USB Serial support registered for Sierra USB modem 2591 [ 2.799054] usbcore: registered new interface driver iforce 2592 [ 2.799220] usbcore: registered new interface driver xpad 2593 [ 2.799521] usbcore: registered new interface driver usbtouchscreen 2594 [ 2.800691] i2c /dev entries driver 2595 [ 2.802700] IR NEC protocol handler initialized 2596 [ 2.802726] IR RC5(x/sz) protocol handler initialized 2597 [ 2.802744] IR RC6 protocol handler initialized 2598 [ 2.802761] IR JVC protocol handler initialized 2599 [ 2.802778] IR Sony protocol handler initialized 2600 [ 2.802795] IR SANYO protocol handler initialized 2601 [ 2.802812] IR Sharp protocol handler initialized 2602 [ 2.802829] IR MCE Keyboard/mouse protocol handler initialized 2603 [ 2.802847] IR XMP protocol handler initialized 2604 [ 2.804548] usbcore: registered new interface driver uvcvideo 2605 [ 2.804562] USB Video Class driver (1.1.1) 2606 [ 2.806500] Boot mode: normal 2607 [ 2.807651] rockchip-thermal 11150000.tsadc: tsadc is probed successfully! 2608 [ 2.809380] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com 2609 [ 2.809739] Bluetooth: Virtual HCI driver ver 1.5 2610 [ 2.810017] Bluetooth: HCI UART driver ver 2.3 2611 [ 2.810035] Bluetooth: HCI UART protocol H4 registered 2612 [ 2.810046] Bluetooth: HCI UART protocol LL registered 2613 [ 2.810057] Bluetooth: HCI UART protocol ATH3K registered 2614 [ 2.810068] Bluetooth: HCI UART protocol Three-wire (H5) registered 2615 [ 2.810245] Bluetooth: HCI UART protocol BCM registered 2616 [ 2.810397] usbcore: registered new interface driver bfusb 2617 [ 2.810542] usbcore: registered new interface driver btusb 2618 [ 2.810564] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 2619 [ 2.811144] cpu cpu0: leakage=6 2620 [ 2.811176] cpu cpu0: leakage-volt-sel=0 2621 [ 2.811382] cpu cpu0: Failed to get pvtm 2622 [ 2.812729] cpu cpu0: avs=0 2623 [ 2.812882] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 2624 [ 2.812908] cpu cpu0: failed to read out thermal zone (-22) 2625 [ 2.813537] cpu cpu0: failed to find power_model node 2626 [ 2.814170] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset 2627 [ 2.814190] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup 2628 [ 2.814212] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0) 2629 [ 2.814559] Synopsys Designware Multimedia Card Interface Driver 2630 [ 2.815161] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode. 2631 [ 2.815281] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller. 2632 [ 2.815299] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a 2633 [ 2.815364] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo 2634 [ 2.815415] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found 2635 [ 2.815426] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found 2636 [ 2.815447] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd 2637 [ 2.815457] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup 2638 [ 2.815483] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0) 2639 [ 2.815520] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations 2640 [ 2.815531] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO 2641 [ 2.815543] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp 2642 [ 2.815552] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup 2643 [ 2.815562] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]' 2644 [ 2.815572] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]' 2645 [ 2.815581] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup 2646 [ 2.815591] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed 2647 [ 2.828408] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) 2648 [ 2.841349] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized 2649 [ 2.841723] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available 2650 [ 2.841808] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode. 2651 [ 2.841895] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller. 2652 [ 2.841912] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a 2653 [ 2.841969] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo 2654 [ 2.842020] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found 2655 [ 2.842030] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found 2656 [ 2.842048] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp 2657 [ 2.842058] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup 2658 [ 2.842070] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]' 2659 [ 2.842081] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]' 2660 [ 2.842090] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup 2661 [ 2.842100] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed 2662 [ 2.842168] dwmmc_rockchip 30010000.dwmmc: allocated mmc-pwrseq 2663 [ 2.854929] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2) 2664 [ 2.867574] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized 2665 [ 2.868170] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/auxiliary[0]' - status (0) 2666 [ 2.868383] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/working[0]' - status (0) 2667 [ 2.868716] ledtrig-cpu: registered to indicate activity on CPUs 2668 [ 2.868902] hidraw: raw HID events driver (C) Jiri Kosina 2669 [ 2.869375] usbcore: registered new interface driver usbhid 2670 [ 2.869389] usbhid: USB HID core driver 2671 [ 2.870090] ashmem: initialized 2672 [ 2.873455] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) 2673 [ 2.873639] mmc0: new high speed SDXC card at address 59b4 2674 [ 2.874497] rknandbase v1.2 2018-05-08 2675 [ 2.874922] mmcblk0: mmc0:59b4 SD 57.8 GiB 2676 [ 2.875894] rknand 30030000.nandc: rknand_probe clk rate = 150000000 2677 [ 2.876261] No.1 FLASH ID:ec de 94 c3 a4 ca 2678 [ 2.876336] No.1 FLASH ID:ec de 94 c3 a4 ca 2679 [ 2.877084] mmcblk0: p1 2680 [ 2.879482] FlashLoadPhyInfo fail 800!! 2681 [ 2.879515] ftl_init ffffffff 2682 [ 2.879527] rk_ftl_init fail 2683 [ 2.881132] usbcore: registered new interface driver snd-usb-audio 2684 [ 2.881348] usbcore: registered new interface driver snd-ua101 2685 [ 2.881536] usbcore: registered new interface driver snd-usb-caiaq 2686 [ 2.881712] usbcore: registered new interface driver snd-usb-6fire 2687 [ 2.881894] usbcore: registered new interface driver snd-usb-hiface 2688 [ 2.882030] usbcore: registered new interface driver snd-bcd2000 2689 [ 2.882170] usbcore: registered new interface driver snd_usb_pod 2690 [ 2.882320] usbcore: registered new interface driver snd_usb_podhd 2691 [ 2.882465] usbcore: registered new interface driver snd_usb_toneport 2692 [ 2.882604] usbcore: registered new interface driver snd_usb_variax 2693 [ 2.890402] u32 classifier 2694 [ 2.890431] input device check on 2695 [ 2.890443] Actions configured 2696 [ 2.890474] Netfilter messages via NETLINK v0.30. 2697 [ 2.890521] nfnl_acct: registering with nfnetlink. 2698 [ 2.890663] nf_conntrack version 0.5.0 (15384 buckets, 61536 max) 2699 [ 2.891868] Initializing XFRM netlink socket 2700 [ 2.893552] NET: Registered protocol family 10 2701 [ 2.895406] ip6_tables: (C) 2000-2006 Netfilter Core Team 2702 [ 2.895853] sit: IPv6 over IPv4 tunneling driver 2703 [ 2.897238] NET: Registered protocol family 17 2704 [ 2.897320] NET: Registered protocol family 15 2705 [ 2.897425] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. 2706 [ 2.897504] Bridge firewalling registered 2707 [ 2.897530] can: controller area network core (rev 20120528 abi 9) 2708 [ 2.897652] NET: Registered protocol family 29 2709 [ 2.897687] can: raw protocol (rev 20120528) 2710 [ 2.897712] can: broadcast manager protocol (rev 20120528 t) 2711 [ 2.897747] can: netlink gateway (rev 20130117) max_hops=1 2712 [ 2.898410] Bluetooth: RFCOMM TTY layer initialized 2713 [ 2.898454] Bluetooth: RFCOMM socket layer initialized 2714 [ 2.898503] Bluetooth: RFCOMM ver 1.11 2715 [ 2.898546] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 2716 [ 2.898575] Bluetooth: HIDP socket layer initialized 2717 [ 2.898692] 8021q: 802.1Q VLAN Support v1.8 2718 [ 2.898755] lib80211: common routines for IEEE802.11 drivers 2719 [ 2.898773] lib80211_crypt: registered algorithm 'NULL' 2720 [ 2.898802] lib80211_crypt: registered algorithm 'WEP' 2721 [ 2.898830] lib80211_crypt: registered algorithm 'CCMP' 2722 [ 2.898858] lib80211_crypt: registered algorithm 'TKIP' 2723 [ 2.898882] [WLAN_RFKILL]: Enter rfkill_wlan_init 2724 [ 2.899289] [BT_RFKILL]: Enter rfkill_rk_init 2725 [ 2.899649] Key type dns_resolver registered 2726 [ 2.900099] flash vendor_init_thread! 2727 [ 2.900127] flash vendor storage:20170308 ret = -1 2728 [ 2.900216] Error: Driver 'sc031gs' is already registered, aborting... 2729 [ 2.901511] Registering SWP/SWPB emulation handler 2730 [ 2.903071] registered taskstats version 1 2731 [ 2.903115] Loading compiled-in X.509 certificates 2732 [ 2.907601] Btrfs loaded 2733 [ 2.909098] rga2: Driver loaded successfully ver:4.01 2734 [ 2.909422] rga2: Module initialized. 2735 [ 2.909477] pvtm list NULL 2736 [ 2.910963] rk-vcodec 20030000.rkvdec: leakage=5 2737 [ 2.911007] rk-vcodec 20030000.rkvdec: leakage-volt-sel=0 2738 [ 2.911169] rk-vcodec 20030000.rkvdec: Failed to get pvtm 2739 [ 2.911754] rk-vcodec 20030000.rkvdec: avs=0 2740 [ 2.912150] rk-vcodec 20030000.rkvdec: probe device 2741 [ 2.912837] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled 2742 [ 2.914517] rk-vcodec 20030000.rkvdec: init success 2743 [ 2.915888] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]' 2744 [ 2.915917] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]' 2745 [ 2.917283] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok 2746 [ 2.919892] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]' 2747 [ 2.919923] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]' 2748 [ 2.920146] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) 2749 [ 2.922378] mmc1: new high speed SDIO card at address 0001 2750 [ 2.923944] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok 2751 [ 2.926340] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/reset[0]' - status (0) 2752 [ 2.926423] gpio-121 (reset): gpiod_set_debounce: missing set() or set_debounce() operations 2753 [ 2.926808] input: gpio-keys as /devices/platform/gpio-keys/input/input1 2754 [ 2.927250] hctosys: unable to open rtc device (rtc0) 2755 [ 2.940289] ALSA device list: 2756 [ 2.940318] #0: DW-I2S-HDMI 2757 [ 2.940327] #1: SPDIF 2758 [ 2.941400] Freeing unused kernel memory: 808K 2759 [ 2.941415] This architecture does not have kernel memory protection. 2760 [ 4.071143] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) 2761 [ 4.820521] systemd[1]: System time before build time, advancing clock. 2762 [ 4.845773] systemd[1]: Inserted module 'autofs4' 2763 [ 4.851274] ip_tables: (C) 2000-2006 Netfilter Core Team 2764 [ 4.860403] cgroup: cgroup2: unknown option "nsdelegate" 2765 [ 4.874979] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) 2766 [ 4.876092] systemd[1]: Detected architecture arm. 2767 [ 4.887668] systemd[1]: Set hostname to <rk322x-box>. 2768 [ 5.083690] ttyS2 - failed to request DMA, use interrupt mode 2769 [ 5.220216] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. 2770 [ 5.220262] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) 2771 [ 5.630486] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available) 2772 [ 5.643573] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available) 2773 [ 5.644028] systemd[1]: Listening on initctl Compatibility Named Pipe. 2774 [ 5.645171] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available) 2775 [ 5.645293] systemd[1]: Reached target System Time Synchronized. 2776 [ 5.645869] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available) 2777 [ 5.649867] systemd[1]: Created slice system-getty.slice. 2778 [ 5.650536] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available) 2779 [ 5.650644] systemd[1]: Reached target Remote File Systems. 2780 [ 5.651236] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. 2781 [ 5.651366] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available) 2782 [ 5.652224] systemd[1]: Listening on Journal Socket. 2783 [ 5.653451] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available) 2784 [ 5.658758] systemd[1]: Mounting Kernel Debug File System... 2785 [ 5.662725] random: systemd: uninitialized urandom read (16 bytes read, 40 bits of entropy available) 2786 [ 5.668528] systemd[1]: Starting Load Kernel Modules... 2787 [ 5.669469] random: systemd: uninitialized urandom read (16 bytes read, 41 bits of entropy available) 2788 [ 5.675896] systemd[1]: Starting Nameserver information manager... 2789 [ 5.677124] random: systemd: uninitialized urandom read (16 bytes read, 41 bits of entropy available) 2790 [ 5.684099] systemd[1]: Starting Set the console keyboard layout... 2791 [ 5.685249] systemd[1]: Reached target Swap. 2792 [ 5.704211] systemd[1]: Starting Restore / save the current clock... 2793 [ 5.705289] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. 2794 [ 5.705939] systemd[1]: Started Forward Password Requests to Wall Directory Watch. 2795 [ 5.707092] systemd[1]: Reached target Local Encrypted Volumes. 2796 [ 5.708160] systemd[1]: Reached target Paths. 2797 [ 5.709969] systemd[1]: Condition check resulted in Huge Pages File System being skipped. 2798 [ 5.711731] systemd[1]: Created slice system-serial\x2dgetty.slice. 2799 [ 5.721312] systemd[1]: Starting Create list of required static device nodes for the current kernel... 2800 [ 5.723608] systemd[1]: Listening on fsck to fsckd communication Socket. 2801 [ 5.724454] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. 2802 [ 5.734187] systemd[1]: Starting Remount Root and Kernel File Systems... 2803 [ 5.736380] systemd[1]: Listening on Journal Socket (/dev/log). 2804 [ 5.739020] systemd[1]: Listening on udev Control Socket. 2805 [ 5.741060] systemd[1]: Listening on udev Kernel Socket. 2806 [ 5.763431] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. 2807 [ 5.765607] systemd[1]: Created slice User and Session Slice. 2808 [ 5.766469] systemd[1]: Reached target Slices. 2809 [ 5.773734] systemd[1]: Starting udev Coldplug all Devices... 2810 [ 5.775836] systemd[1]: Listening on Syslog Socket. 2811 [ 5.782906] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. 2812 [ 5.792661] systemd[1]: Mounting POSIX Message Queue File System... 2813 [ 5.802261] systemd[1]: Mounted Kernel Debug File System. 2814 [ 5.808327] systemd[1]: Started Load Kernel Modules. 2815 [ 5.813318] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro 2816 [ 5.838230] systemd[1]: Started Restore / save the current clock. 2817 [ 5.842571] systemd[1]: Started Create list of required static device nodes for the current kernel. 2818 [ 5.846788] systemd[1]: Started Remount Root and Kernel File Systems. 2819 [ 5.852567] systemd[1]: Mounted POSIX Message Queue File System. 2820 [ 5.862034] systemd[1]: Started Nameserver information manager. 2821 [ 5.878083] systemd[1]: Starting Load/Save Random Seed... 2822 [ 5.890071] systemd[1]: Starting Create System Users... 2823 [ 5.908210] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. 2824 [ 5.920947] vendor storage:20190527 ret = -1 2825 [ 5.927178] systemd[1]: Mounting Kernel Configuration File System... 2826 [ 5.933727] systemd[1]: Condition check resulted in FUSE Control File System being skipped. 2827 [ 5.953432] systemd[1]: Starting Apply Kernel Variables... 2828 [ 5.970359] systemd[1]: Started Load/Save Random Seed. 2829 [ 5.986815] systemd[1]: Mounted Kernel Configuration File System. 2830 [ 6.029997] systemd[1]: Started Apply Kernel Variables. 2831 [ 6.041048] systemd[1]: Started Create System Users. 2832 [ 6.054789] systemd[1]: Starting Create Static Device Nodes in /dev... 2833 [ 6.123988] systemd[1]: Started Set the console keyboard layout. 2834 [ 6.144354] systemd[1]: Started Create Static Device Nodes in /dev. 2835 [ 6.149973] systemd[1]: Reached target Local File Systems (Pre). 2836 [ 6.160736] systemd[1]: Mounting /tmp... 2837 [ 6.172405] systemd[1]: Starting udev Kernel Device Manager... 2838 [ 6.183601] systemd[1]: Mounted /tmp. 2839 [ 6.189832] systemd[1]: Reached target Local File Systems. 2840 [ 6.201172] systemd[1]: Starting Set console font and keymap... 2841 [ 6.206734] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped. 2842 [ 6.207113] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. 2843 [ 6.213326] systemd[1]: Starting Armbian ZRAM config... 2844 [ 6.236213] systemd[1]: Started Set console font and keymap. 2845 [ 6.357992] systemd[1]: Started udev Kernel Device Manager. 2846 [ 6.381725] systemd[1]: Started udev Coldplug all Devices. 2847 [ 6.396356] systemd[1]: Starting Helper to synchronize boot up for ifupdown... 2848 [ 6.440938] systemd[1]: Started Helper to synchronize boot up for ifupdown. 2849 [ 6.457849] systemd[1]: Starting Raise network interfaces... 2850 [ 6.547378] zram: Added device: zram0 2851 [ 6.548924] zram: Added device: zram1 2852 [ 6.550497] zram: Added device: zram2 2853 [ 6.744103] rk3228-codec 12010000.codec: GPIO lookup for consumer spk-en 2854 [ 6.744135] rk3228-codec 12010000.codec: using device tree for GPIO lookup 2855 [ 6.744152] of_get_named_gpiod_flags: can't parse 'spk-en-gpios' property of node '/codec@12010000[0]' 2856 [ 6.744187] of_get_named_gpiod_flags: parsed 'spk-en-gpio' property of node '/codec@12010000[0]' - status (0) 2857 [ 6.744255] rk3228-codec 12010000.codec: spk_depop_time use default value. 2858 [ 6.745309] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]' 2859 [ 6.745348] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]' 2860 [ 6.765854] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '22:00:07', on 'May 6 2021'. 2861 [ 6.766188] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13 2862 [ 6.766218] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000 2863 [ 6.766230] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000 2864 [ 6.766240] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000 2865 [ 6.766252] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000 2866 [ 6.766262] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000 2867 [ 6.766273] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000 2868 [ 6.766284] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000 2869 [ 6.766295] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000020 2870 [ 6.766304] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000021 2871 [ 6.766315] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000022 2872 [ 6.766326] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000021 2873 [ 6.766398] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000022 2874 [ 6.766410] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000021 2875 [ 6.766423] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali. 2876 [ 6.766835] mali-utgard 20001000.gpu: leakage=5 2877 [ 6.766876] mali-utgard 20001000.gpu: leakage-volt-sel=0 2878 [ 6.767000] mali-utgard 20001000.gpu: Failed to get pvtm 2879 [ 6.767586] mali-utgard 20001000.gpu: avs=0 2880 [ 6.768017] mali-utgard 20001000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 2881 [ 6.784685] Mali: Mali device driver loaded 2882 [ 6.788072] systemd[1]: Found device /dev/ttyS2. 2883 [ 6.818379] asoc-simple-card sound: rk3228-hifi <-> 100b0000.i2s1 mapping ok 2884 [ 6.864981] devfreq 20001000.gpu: Couldn't update frequency transition information. 2885 [ 6.875521] zram0: detected capacity change from 0 to 504537088 2886 [ 6.893686] generic_wifi_init_module 2887 [ 6.960636] gpio_ir_recv ir-receiver: GPIO lookup for consumer (null) 2888 [ 6.960668] gpio_ir_recv ir-receiver: using device tree for GPIO lookup 2889 [ 6.960713] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ir-receiver[0]' - status (0) 2890 [ 6.961006] Registered IR keymap rc-rktvbox 2891 [ 6.961276] rc rc1: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1 2892 [ 6.961786] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1/input2 2893 [ 7.173027] 2894 *** sta_cfg_set, (null) *** 2895 2896 [ 7.173075] redirect to /lib/firmware/ssv6051-wifi.cfg 2897 [ 7.181393] ssv6xxx_sdio_init 2898 [ 7.183442] ======================================= 2899 [ 7.183482] == RUN SDIO == 2900 [ 7.183507] ======================================= 2901 [ 7.183536] ssv6xxx_set_sdio_clk:set sdio clk 25000000Hz 2902 [ 7.183637] mmc_host mmc1: Bus speed (slot 0) = 25000000Hz (slot req 25000000Hz, actual 25000000HZ div = 0) 2903 [ 7.239355] SSV6XXX_SDIO mmc1:0001:1: vendor = 0x3030 device = 0x3030 2904 [ 7.274694] ssv6xxx_sdio_power_on 2905 [ 7.301205] SSV6XXX_SDIO mmc1:0001:1: dataIOPort 0x10000 regIOPort 0x10020 2906 [ 7.301783] ssv6xxx_dev_probe(): ssv6200 device found ! 2907 [ 7.311890] ssv6xxx_sdio_irq_disable 2908 [ 7.312321] Read open File fail[/data/wifimac]!!!! 2909 [ 7.312391] Write open File fail!!!![/data/wifimac] 2910 [ 7.312404] MAC address from Software MAC mode[2] 2911 [ 7.312413] EFUSE configuration 2912 [ 7.312421] Read efuse chip identity[00000000] 2913 [ 7.312429] r_calbration_result- 0 2914 [ 7.312437] sar_result- 0 2915 [ 7.312445] crystal_frequency_offset- 0 2916 [ 7.312452] tx_power_index_1- 0 2917 [ 7.312459] tx_power_index_2- 0 2918 [ 7.312469] MAC address - 00:00:00:00:00:00 2919 [ 7.321278] Registering Vendor80211 2920 [ 7.321321] Register SSV cfg80211 vendor cmd(0x67) interface 2921 [ 7.321625] [MT-ENCRYPT]: create kthread ecd80000 for CPU 0, ret = 0 2922 [ 7.321849] SSV WLAN driver ssv6200: Crypto task 451 running with priority 120. 2923 [ 7.321949] [MT-ENCRYPT]: create kthread ecd807c0 for CPU 1, ret = 0 2924 [ 7.323446] [MT-ENCRYPT]: create kthread ecd80f80 for CPU 2, ret = 0 2925 [ 7.323700] [MT-ENCRYPT]: create kthread ecd81740 for CPU 3, ret = 0 2926 [ 7.323964] SSV6XXX TX Task started. 2927 [ 7.324037] Pre-load cipher 2928 [ 7.324153] flash_file /tmp/flash.bin not found, disable sar 2929 [ 7.324171] SSV6051Q setting 2930 [ 7.324183] SSV6XXX_IQK_CFG_XTAL_24M 2931 [ 7.324194] SSV6051Q setting [0x5B606C72] 2932 [ 7.324202] TX power setting 0x5b606c72 2933 [ 7.324209] Volt regulator LDO 2934 [ 7.325035] SSV WLAN driver ssv6200: Crypto task 454 running with priority 120. 2935 [ 7.326159] reset PLL 2936 [ 7.327638] SSV WLAN driver ssv6200: Crypto task 456 running with priority 120. 2937 [ 7.332910] SSV WLAN driver ssv6200: Crypto task 452 running with priority 120. 2938 [ 7.336533] SSV6XXX RX Task started. 2939 [ 7.342562] @@@@@@@@@@@@ 2940 [ 7.342589] SDIO issue -- please check 0xCE01008C 00000000!! 2941 [ 7.342600] It shouble be 0xEAAAAAAA!! 2942 [ 7.342607] @@@@@@@@@@@@ 2943 [ 7.372070] calibation fail:[1] 2944 [ 7.399362] calibation fail:[2] 2945 [ 7.424234] calibation fail:[3] 2946 [ 7.434415] systemd[1]: Started Raise network interfaces. 2947 [ 7.448020] calibation fail:[4] 2948 [ 7.471499] calibation fail:[5] 2949 [ 7.496995] calibation fail:[6] 2950 [ 7.522221] calibation fail:[7] 2951 [ 7.548498] calibation fail:[8] 2952 [ 7.569835] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. 2953 [ 7.572199] calibation fail:[9] 2954 [ 7.575265] systemd[1]: Condition check resulted in Huge Pages File System being skipped. 2955 [ 7.575619] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. 2956 [ 7.575791] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. 2957 [ 7.575893] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. 2958 [ 7.576086] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. 2959 [ 7.576198] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. 2960 [ 7.576732] systemd[1]: Condition check resulted in FUSE Control File System being skipped. 2961 [ 7.577126] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. 2962 [ 7.594425] calibation fail:[10] 2963 [ 7.616389] calibation fail:[11] 2964 [ 7.638369] calibation fail:[12] 2965 [ 7.660302] calibation fail:[13] 2966 [ 7.682244] calibation fail:[14] 2967 [ 7.704171] calibation fail:[15] 2968 [ 7.726146] calibation fail:[16] 2969 [ 7.748066] calibation fail:[17] 2970 [ 7.769992] calibation fail:[18] 2971 [ 7.792546] calibation fail:[19] 2972 [ 7.815394] calibation fail:[20] 2973 [ 7.837530] calibation fail:[21] 2974 [ 7.859444] cfg80211: World regulatory domain updated: 2975 [ 7.859468] cfg80211: DFS Master region: unset 2976 [ 7.859476] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time) 2977 [ 7.859488] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) 2978 [ 7.859500] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A) 2979 [ 7.859509] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A) 2980 [ 7.859520] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A) 2981 [ 7.859530] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s) 2982 [ 7.859540] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s) 2983 [ 7.859549] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A) 2984 [ 7.859559] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A) 2985 [ 7.859874] calibation fail:[22] 2986 [ 7.882030] calibation fail:[23] 2987 [ 7.904012] calibation fail:[24] 2988 [ 7.927441] calibation fail:[25] 2989 [ 7.933025] Adding 492708k swap on /dev/zram0. Priority:5 extents:1 across:492708k SS 2990 [ 7.952077] calibation fail:[26] 2991 [ 7.976481] calibation fail:[27] 2992 [ 7.999422] calibation fail:[28] 2993 [ 7.999744] random: nonblocking pool is initialized 2994 [ 8.023032] calibation fail:[29] 2995 [ 8.046502] calibation fail:[30] 2996 [ 8.070022] calibation fail:[31] 2997 [ 8.093541] calibation fail:[32] 2998 [ 8.116945] calibation fail:[33] 2999 [ 8.124087] zram1: detected capacity change from 0 to 52428800 3000 [ 8.139905] calibation fail:[34] 3001 [ 8.163117] calibation fail:[35] 3002 [ 8.186577] calibation fail:[36] 3003 [ 8.193169] systemd[1]: Started Armbian ZRAM config. 3004 [ 8.203367] systemd[1]: Starting Armbian memory supported logging... 3005 [ 8.210324] calibation fail:[37] 3006 [ 8.234175] calibation fail:[38] 3007 [ 8.258050] calibation fail:[39] 3008 [ 8.282077] calibation fail:[40] 3009 [ 8.304081] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard 3010 [ 8.306197] calibation fail:[41] 3011 [ 8.331237] calibation fail:[42] 3012 [ 8.354738] calibation fail:[43] 3013 [ 8.379478] calibation fail:[44] 3014 [ 8.404364] calibation fail:[45] 3015 [ 8.429018] calibation fail:[46] 3016 [ 8.453027] calibation fail:[47] 3017 [ 8.477046] calibation fail:[48] 3018 [ 8.501016] calibation fail:[49] 3019 [ 8.525037] calibation fail:[50] 3020 [ 8.549027] calibation fail:[51] 3021 [ 8.573009] calibation fail:[52] 3022 [ 8.596649] calibation fail:[53] 3023 [ 8.621507] calibation fail:[54] 3024 [ 8.646447] calibation fail:[55] 3025 [ 8.671267] calibation fail:[56] 3026 [ 8.695259] calibation fail:[57] 3027 [ 8.719706] calibation fail:[58] 3028 [ 8.744073] calibation fail:[59] 3029 [ 8.768323] calibation fail:[60] 3030 [ 8.791360] calibation fail:[61] 3031 [ 8.814241] calibation fail:[62] 3032 [ 8.837387] calibation fail:[63] 3033 [ 8.860588] calibation fail:[64] 3034 [ 8.883569] calibation fail:[65] 3035 [ 8.905924] calibation fail:[66] 3036 [ 8.928287] calibation fail:[67] 3037 [ 8.950851] calibation fail:[68] 3038 [ 8.973274] calibation fail:[69] 3039 [ 8.995692] calibation fail:[70] 3040 [ 9.018129] calibation fail:[71] 3041 [ 9.040516] calibation fail:[72] 3042 [ 9.062958] calibation fail:[73] 3043 [ 9.085386] calibation fail:[74] 3044 [ 9.107775] calibation fail:[75] 3045 [ 9.130226] calibation fail:[76] 3046 [ 9.152635] calibation fail:[77] 3047 [ 9.175095] calibation fail:[78] 3048 [ 9.197482] calibation fail:[79] 3049 [ 9.219864] calibation fail:[80] 3050 [ 9.242287] calibation fail:[81] 3051 [ 9.264676] calibation fail:[82] 3052 [ 9.287096] calibation fail:[83] 3053 [ 9.309521] calibation fail:[84] 3054 [ 9.331939] calibation fail:[85] 3055 [ 9.354328] calibation fail:[86] 3056 [ 9.376732] calibation fail:[87] 3057 [ 9.399221] calibation fail:[88] 3058 [ 9.421594] calibation fail:[89] 3059 [ 9.444025] calibation fail:[90] 3060 [ 9.466435] calibation fail:[91] 3061 [ 9.488859] calibation fail:[92] 3062 [ 9.511270] calibation fail:[93] 3063 [ 9.533657] calibation fail:[94] 3064 [ 9.556093] calibation fail:[95] 3065 [ 9.578544] calibation fail:[96] 3066 [ 9.600910] calibation fail:[97] 3067 [ 9.623356] calibation fail:[98] 3068 [ 9.645758] calibation fail:[99] 3069 [ 9.668122] calibation fail:[100] 3070 [ 9.669771] ieee80211 phy0: Selected rate control algorithm 'ssv6xxx_rate_control' 3071 [ 9.671321] ieee80211 phy0: SSV6200 of South Silicon Valley 3072 [ 9.675507] systemd[1]: Starting Load/Save RF Kill Switch Status... 3073 [ 10.200341] systemd[1]: Started Load/Save RF Kill Switch Status. 3074 [ 11.826590] systemd[1]: Started Armbian memory supported logging. 3075 [ 11.838053] systemd[1]: Starting Journal Service... 3076 [ 12.265003] systemd[1]: Started Journal Service. 3077 [ 12.336318] systemd-journald[592]: Received request to flush runtime journal from PID 1 3078 3079 ### armbian-release: 3080 3081 # PLEASE DO NOT EDIT THIS FILE 3082 BOARD=rk322x-box 3083 BOARD_NAME="rk322x-box" 3084 BOARDFAMILY=rk322x 3085 BUILD_REPOSITORY_URL=git@github.com:armbian/build.git 3086 BUILD_REPOSITORY_COMMIT=08297378c-dirty 3087 DISTRIBUTION_CODENAME=buster 3088 DISTRIBUTION_STATUS=supported 3089 VERSION=21.05.1 3090 LINUXFAMILY=rk322x 3091 ARCH=arm 3092 IMAGE_TYPE=stable 3093 BOARD_TYPE=tvb 3094 INITRD_ARCH=arm 3095 KERNEL_IMAGE_TYPE=Image 3096 3097 ### boot environment: 3098 3099 verbosity=1 3100 extraargs=coherent_pool=2M 3101 bootlogo=false 3102 overlay_prefix=rk322x 3103 fdtfile=rk322x-box.dtb 3104 rootdev=UUID=2ca5ad18-5d1f-4279-8d1e-6c805b6be8db 3105 rootfstype=ext4 3106 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 3107 overlays=nand led-conf2 3108 3109 ### lsusb: 3110 3111 Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 3112 Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 3113 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 3114 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 3115 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 3116 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 3117 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 3118 3119 ### lscpu: 3120 3121 Architecture: armv7l 3122 Byte Order: Little Endian 3123 CPU(s): 4 3124 On-line CPU(s) list: 0-3 3125 Thread(s) per core: 1 3126 Core(s) per socket: 4 3127 Socket(s): 1 3128 Vendor ID: ARM 3129 Model: 5 3130 Model name: Cortex-A7 3131 Stepping: r0p5 3132 CPU max MHz: 1200.0000 3133 CPU min MHz: 408.0000 3134 BogoMIPS: 70.58 3135 Flags: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 3136 3137 ### cpuinfo: 3138 3139 processor : 0 3140 model name : ARMv7 Processor rev 5 (v7l) 3141 BogoMIPS : 70.58 3142 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 3143 CPU implementer : 0x41 3144 CPU architecture: 7 3145 CPU variant : 0x0 3146 CPU part : 0xc07 3147 CPU revision : 5 3148 3149 processor : 1 3150 model name : ARMv7 Processor rev 5 (v7l) 3151 BogoMIPS : 70.58 3152 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 3153 CPU implementer : 0x41 3154 CPU architecture: 7 3155 CPU variant : 0x0 3156 CPU part : 0xc07 3157 CPU revision : 5 3158 3159 processor : 2 3160 model name : ARMv7 Processor rev 5 (v7l) 3161 BogoMIPS : 70.58 3162 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 3163 CPU implementer : 0x41 3164 CPU architecture: 7 3165 CPU variant : 0x0 3166 CPU part : 0xc07 3167 CPU revision : 5 3168 3169 processor : 3 3170 model name : ARMv7 Processor rev 5 (v7l) 3171 BogoMIPS : 70.58 3172 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm 3173 CPU implementer : 0x41 3174 CPU architecture: 7 3175 CPU variant : 0x0 3176 CPU part : 0xc07 3177 CPU revision : 5 3178 3179 Hardware : Generic DT based system 3180 Revision : 0000 3181 Serial : cd1d5ffa03aecfa2 3182 3183 ### meminfo: 3184 3185 MemTotal: 985420 kB 3186 MemFree: 900356 kB 3187 MemAvailable: 927648 kB 3188 Buffers: 8744 kB 3189 Cached: 30396 kB 3190 SwapCached: 0 kB 3191 Active: 28892 kB 3192 Inactive: 18748 kB 3193 Active(anon): 8632 kB 3194 Inactive(anon): 5732 kB 3195 Active(file): 20260 kB 3196 Inactive(file): 13016 kB 3197 Unevictable: 0 kB 3198 Mlocked: 0 kB 3199 HighTotal: 0 kB 3200 HighFree: 0 kB 3201 LowTotal: 985420 kB 3202 LowFree: 900356 kB 3203 SwapTotal: 492708 kB 3204 SwapFree: 492708 kB 3205 Dirty: 1704 kB 3206 Writeback: 0 kB 3207 AnonPages: 8568 kB 3208 Mapped: 10620 kB 3209 Shmem: 5868 kB 3210 Slab: 18884 kB 3211 SReclaimable: 10120 kB 3212 SUnreclaim: 8764 kB 3213 KernelStack: 1128 kB 3214 PageTables: 696 kB 3215 NFS_Unstable: 0 kB 3216 Bounce: 0 kB 3217 WritebackTmp: 0 kB 3218 CommitLimit: 985416 kB 3219 Committed_AS: 31508 kB 3220 VmallocTotal: 245760 kB 3221 VmallocUsed: 0 kB 3222 VmallocChunk: 0 kB 3223 CmaTotal: 16384 kB 3224 CmaFree: 12208 kB 3225 3226 ### virtual memory: 3227 3228 vm.admin_reserve_kbytes = 8192 3229 vm.block_dump = 0 3230 vm.dirty_background_bytes = 0 3231 vm.dirty_background_ratio = 10 3232 vm.dirty_bytes = 0 3233 vm.dirty_expire_centisecs = 3000 3234 vm.dirty_ratio = 20 3235 vm.dirtytime_expire_seconds = 43200 3236 vm.dirty_writeback_centisecs = 500 3237 vm.drop_caches = 0 3238 vm.extra_free_kbytes = 0 3239 vm.highmem_is_dirtyable = 0 3240 vm.laptop_mode = 0 3241 vm.legacy_va_layout = 0 3242 vm.lowmem_reserve_ratio = 32 32 3243 vm.max_map_count = 65530 3244 vm.min_free_kbytes = 3924 3245 vm.mmap_min_addr = 32768 3246 vm.mmap_rnd_bits = 8 3247 vm.nr_pdflush_threads = 0 3248 vm.oom_dump_tasks = 1 3249 vm.oom_kill_allocating_task = 0 3250 vm.overcommit_kbytes = 0 3251 vm.overcommit_memory = 0 3252 vm.overcommit_ratio = 50 3253 vm.page-cluster = 0 3254 vm.panic_on_oom = 0 3255 vm.percpu_pagelist_fraction = 0 3256 vm.stat_interval = 1 3257 vm.swappiness = 100 3258 vm.user_reserve_kbytes = 30419 3259 vm.vfs_cache_pressure = 100 3260 3261 ### ip addr: 3262 3263 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1 3264 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 3265 inet XXX.XXX.0.1/8 scope host lo 3266 valid_lft forever preferred_lft forever 3267 inet6 ::1/128 scope host 3268 valid_lft forever preferred_lft forever 3269 2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000 3270 link/ether e2:c8:cc:5f:46:26 brd ff:ff:ff:ff:ff:ff 3271 3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 3272 link/ether f6:b4:e0:5a:1e:3a brd ff:ff:ff:ff:ff:ff 3273 4: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1 3274 link/sit XXX.XXX.0.0 brd XXX.XXX.0.0 3275 5: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 3276 link/ether 70:73:72:f7:f1:cf brd ff:ff:ff:ff:ff:ff 3277 3278 ### partitions: 3279 3280 major minor #blocks name 3281 3282 179 0 60620800 mmcblk0 3283 179 1 60010496 mmcblk0p1 3284 253 0 492712 zram0 3285 253 1 51200 zram1 3286 3287 ### df: 3288 3289 udev 471M 0 471M 0% /dev 3290 tmpfs 97M 2.8M 94M 3% /run 3291 /dev/mmcblk0p1 56G 1.1G 55G 2% / 3292 tmpfs 482M 0 482M 0% /dev/shm 3293 tmpfs 5.0M 4.0K 5.0M 1% /run/lock 3294 tmpfs 482M 0 482M 0% /sys/fs/cgroup 3295 tmpfs 482M 0 482M 0% /tmp 3296 /dev/zram1 49M 1.7M 44M 4% /var/log 3297 3298 ### lsblk: 3299 3300 NAME FSTYPE SIZE MOUNTPOINT UUID 3301 mmcblk0 57.8G 3302 └─mmcblk0p1 ext4 57.2G / 2ca5ad18-5d1f-4279-8d1e-6c805b6be8db 3303 zram1 50M /var/log 3304 3305 ### zramctl: 3306 3307 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 3308 /dev/zram1 lz4 50M 132K 867B 32K 4 /var/log 3309 /dev/zram0 lzo 481.2M 4K 76B 4K 4 [SWAP] 3310 3311 ### mtab: 3312 3313 /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 3314 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 3315 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 3316 3317 ### mmc0:59b4 info: 3318 3319 cid: 1d41445344202020100000002c015287 3320 csd: 400e00325b590001ce7f7f800a4000cf 3321 scr: 0245804300000000 3322 date: 02/2021 3323 name: SD 3324 type: SD 3325 preferred_erase_size: 4194304 3326 fwrev: 0x0 3327 hwrev: 0x1 3328 oemid: 0x4144 3329 manfid: 0x00001d 3330 serial: 0x0000002c 3331 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD MODALIAS=mmc:block 3332 erase_size: 512 3333 3334 ### Boot system health: 3335 3336 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 3337 22:37:08: 1200MHz 1.44 48% 29% 16% 0% 2% 0% 61.0°C 0/4 3338 22:37:08: 1200MHz 1.80 58% 25% 31% 1% 0% 0% 60.0°C 0/4 3339 22:37:08: 816MHz 1.80 34% 20% 12% 1% 0% 0% 58.0°C 0/4 3340 22:37:09: 816MHz 1.80 33% 20% 11% 1% 0% 0% 57.0°C 0/4 3341 22:37:09: 816MHz 1.80 35% 19% 15% 1% 0% 0% 58.0°C 0/4 3342 3343 ### lsusb: 3344 3345 Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 3346 Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 3347 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 3348 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 3349 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub 3350 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 3351 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub 3352 3353 /: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 3354 /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 3355 /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M 3356 /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 3357 /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 3358 /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M 3359 /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc2/1p, 480M 3360 3361 ### Installed packages: 3362 3363 ii armbian-bsp-cli-rk322x-box 21.05.1 armhf Tweaks for Armbian buster on rk322x-box 3364 ii armbian-config 21.05.1 all Armbian configuration utility 3365 ii armbian-firmware 21.05.1 all Linux firmware 3366 ii armbian-zsh 21.05.1 all Armbian improved ZShell 3367 ii hostapd 3:2.9-102~armbian20.05.2+1 armhf IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator 3368 ii htop 3.1.0-0~armbian20.08.2+1 armhf interactive processes viewer 3369 ii linux-base 4.6 all Linux image base package 3370 ii linux-dtb-legacy-rk322x 21.05.1 armhf Linux DTB, version 4.4.194-rk322x 3371 ii linux-image-legacy-rk322x 21.05.1 armhf Linux kernel, version 4.4.194-rk322x 3372 ii linux-libc-dev:armhf 4.19.181-1 armhf Linux support headers for userspace development 3373 ii linux-u-boot-rk322x-box-legacy 21.05.1 armhf Uboot loader 2021.04 3374 3375 ### Loaded modules: 3376 3377 Module Size Used by 3378 lz4 16384 4 3379 lz4_compress 16384 1 lz4 3380 gpio_ir_recv 16384 0 3381 ssv6051 212992 0 3382 lzo 16384 4 3383 mali 229376 0 3384 snd_soc_rk3228 16384 1 3385 zram 24576 2 3386 ip_tables 24576 0 3387 autofs4 32768 0 3388 3389 ### nand-sata-install.log: 3390 3391 Thu 03 Jun 2021 10:36:28 PM UTC: Start nand-sata-install. 3392 3393 ### Current system health: 3394 3395 Time CPU load %cpu %sys %usr %nice %io %irq CPU C.St. 3396 22:57:07: 1200MHz 4.09 14% 2% 11% 0% 0% 0% 57.0°C 0/4 3397 22:57:07: 1200MHz 4.09 6% 5% 0% 1% 0% 0% 57.0°C 0/4 3398 22:57:07: 1200MHz 4.09 6% 4% 0% 1% 0% 0% 57.0°C 0/4 3399 22:57:08: 1200MHz 4.09 7% 5% 0% 2% 0% 0% 56.0°C 0/4 3400 22:57:08: 1200MHz 4.09 6% 5% 0% 1% 0% 0% 56.0°C 0/4 3401 22:57:11: 1200MHz 4.09 14% 2% 11% 0% 0% 0% 64.0°C 0/4 3402 22:57:12: 1200MHz 4.48 87% 0% 87% 0% 0% 0% 60.0°C 0/4 3403 22:57:12: 1200MHz 4.48 6% 5% 0% 1% 0% 0% 59.0°C 0/4 3404 22:57:13: 1200MHz 4.48 6% 5% 0% 0% 0% 0% 58.0°C 0/4 3405 22:57:13: 1200MHz 4.48 6% 5% 0% 1% 0% 0% 58.0°C 0/4 3406 3407 ### resolv.conf 3408 3409 -rw-r--r-- 1 root root 74 Jun 3 22:37 /etc/resolv.conf 3410 # Generated by NetworkManager 3411 nameserver XXX.XXX.9.196 3412 nameserver XXX.XXX.9.164 3413 3414 ### Current sysinfo: 3415 3416 Linux 4.4.194-rk322x (rk322x-box) 06/03/2021 _armv7l_ (4 CPU) 3417 3418 avg-cpu: %user %nice %system %iowait %steal %idle 3419 11.40 0.01 2.22 0.71 0.00 85.66 3420 3421 Device tps kB_read/s kB_wrtn/s kB_read kB_wrtn 3422 ram0 0.00 0.00 0.00 0 0 3423 mmcblk0 10.55 138.04 243.77 165753 292712 3424 mmcblk0p1 10.42 135.43 243.77 162617 292712 3425 zram0 0.47 1.89 0.00 2264 4 3426 zram1 0.62 0.37 2.11 444 2532 3427 zram2 0.00 0.00 0.00 0 0 3428 3429 procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu-------- 3430 r b swpd free buff cache si so bi bo in cs us sy id wa st 3431 0 0 0 596672 33188 293000 0 0 35 62 280 286 11 2 86 1 0 3432 3433 total used free shared buff/cache available 3434 Mem: 962Mi 61Mi 582Mi 7.0Mi 318Mi 878Mi 3435 Swap: 481Mi 0B 481Mi 3436 3437 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT 3438 /dev/zram1 lz4 50M 2.1M 574.4K 932K 4 /var/log 3439 /dev/zram0 lzo 481.2M 4K 76B 4K 4 [SWAP] 3440 3441 22:57:14 up 20 min, 1 user, load average: 4.48, 4.53, 3.43 3442 3443 [ 8.163117] calibation fail:[35] 3444 [ 8.186577] calibation fail:[36] 3445 [ 8.193169] systemd[1]: Started Armbian ZRAM config. 3446 [ 8.203367] systemd[1]: Starting Armbian memory supported logging... 3447 [ 8.210324] calibation fail:[37] 3448 [ 8.234175] calibation fail:[38] 3449 [ 8.258050] calibation fail:[39] 3450 [ 8.282077] calibation fail:[40] 3451 [ 8.304081] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard 3452 [ 8.306197] calibation fail:[41] 3453 [ 8.331237] calibation fail:[42] 3454 [ 8.354738] calibation fail:[43] 3455 [ 8.379478] calibation fail:[44] 3456 [ 8.404364] calibation fail:[45] 3457 [ 8.429018] calibation fail:[46] 3458 [ 8.453027] calibation fail:[47] 3459 [ 8.477046] calibation fail:[48] 3460 [ 8.501016] calibation fail:[49] 3461 [ 8.525037] calibation fail:[50] 3462 [ 8.549027] calibation fail:[51] 3463 [ 8.573009] calibation fail:[52] 3464 [ 8.596649] calibation fail:[53] 3465 [ 8.621507] calibation fail:[54] 3466 [ 8.646447] calibation fail:[55] 3467 [ 8.671267] calibation fail:[56] 3468 [ 8.695259] calibation fail:[57] 3469 [ 8.719706] calibation fail:[58] 3470 [ 8.744073] calibation fail:[59] 3471 [ 8.768323] calibation fail:[60] 3472 [ 8.791360] calibation fail:[61] 3473 [ 8.814241] calibation fail:[62] 3474 [ 8.837387] calibation fail:[63] 3475 [ 8.860588] calibation fail:[64] 3476 [ 8.883569] calibation fail:[65] 3477 [ 8.905924] calibation fail:[66] 3478 [ 8.928287] calibation fail:[67] 3479 [ 8.950851] calibation fail:[68] 3480 [ 8.973274] calibation fail:[69] 3481 [ 8.995692] calibation fail:[70] 3482 [ 9.018129] calibation fail:[71] 3483 [ 9.040516] calibation fail:[72] 3484 [ 9.062958] calibation fail:[73] 3485 [ 9.085386] calibation fail:[74] 3486 [ 9.107775] calibation fail:[75] 3487 [ 9.130226] calibation fail:[76] 3488 [ 9.152635] calibation fail:[77] 3489 [ 9.175095] calibation fail:[78] 3490 [ 9.197482] calibation fail:[79] 3491 [ 9.219864] calibation fail:[80] 3492 [ 9.242287] calibation fail:[81] 3493 [ 9.264676] calibation fail:[82] 3494 [ 9.287096] calibation fail:[83] 3495 [ 9.309521] calibation fail:[84] 3496 [ 9.331939] calibation fail:[85] 3497 [ 9.354328] calibation fail:[86] 3498 [ 9.376732] calibation fail:[87] 3499 [ 9.399221] calibation fail:[88] 3500 [ 9.421594] calibation fail:[89] 3501 [ 9.444025] calibation fail:[90] 3502 [ 9.466435] calibation fail:[91] 3503 [ 9.488859] calibation fail:[92] 3504 [ 9.511270] calibation fail:[93] 3505 [ 9.533657] calibation fail:[94] 3506 [ 9.556093] calibation fail:[95] 3507 [ 9.578544] calibation fail:[96] 3508 [ 9.600910] calibation fail:[97] 3509 [ 9.623356] calibation fail:[98] 3510 [ 9.645758] calibation fail:[99] 3511 [ 9.668122] calibation fail:[100] 3512 [ 9.669771] ieee80211 phy0: Selected rate control algorithm 'ssv6xxx_rate_control' 3513 [ 9.671321] ieee80211 phy0: SSV6200 of South Silicon Valley 3514 [ 9.675507] systemd[1]: Starting Load/Save RF Kill Switch Status... 3515 [ 10.200341] systemd[1]: Started Load/Save RF Kill Switch Status. 3516 [ 11.826590] systemd[1]: Started Armbian memory supported logging. 3517 [ 11.838053] systemd[1]: Starting Journal Service... 3518 [ 12.265003] systemd[1]: Started Journal Service. 3519 [ 12.336318] systemd-journald[592]: Received request to flush runtime journal from PID 1 3520 [ 13.400283] nr_pdflush_threads exported in /proc is scheduled for removal 3521 [ 23.703735] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready 3522 [ 23.830223] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready 3523 [ 23.830642] SVN version 16529 3524 [ 23.830662] SVN ROOT URL http://XXX.XXX.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx 3525 [ 23.830671] COMPILER HOST icomm-buildserver-T320 3526 [ 23.830678] COMPILER DATE 12-08-2017-10:34:54 3527 [ 23.830685] COMPILER OS linux 3528 [ 23.830692] COMPILER OS ARCH x86_64-linux-gnu-thread-multi 3529 [ 23.830852] CHIP TAG: 0 3530 [ 23.831190] CHIP ID: SSV6006C0 3531 [ 23.833749] 0x800e0000 3532 [ 23.858257] ERROR!!Please check interface! 3533 [ 23.858283] [0xca000200]: 0x0c000000!=0x00000000 3534 [ 23.858290] SOS!SOS! 3535 [ 23.858296] Initialize ssv6200 mac fail!! 3536 [ 24.020558] SVN version 16529 3537 [ 24.020598] SVN ROOT URL http://XXX.XXX.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx 3538 [ 24.020621] COMPILER HOST icomm-buildserver-T320 3539 [ 24.020638] COMPILER DATE 12-08-2017-10:34:54 3540 [ 24.020653] COMPILER OS linux 3541 [ 24.020662] COMPILER OS ARCH x86_64-linux-gnu-thread-multi 3542 [ 24.032908] CHIP TAG: 0 3543 [ 24.035074] CHIP ID: SSV6006C0 3544 [ 24.046396] 0x800e0000 3545 [ 24.089463] ERROR!!Please check interface! 3546 [ 24.089491] [0xca000200]: 0x0c000000!=0x00000000 3547 [ 24.089498] SOS!SOS! 3548 [ 24.089505] Initialize ssv6200 mac fail!! 3549 [ 24.094865] SVN version 16529 3550 [ 24.094889] SVN ROOT URL http://XXX.XXX.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx 3551 [ 24.094898] COMPILER HOST icomm-buildserver-T320 3552 [ 24.094905] COMPILER DATE 12-08-2017-10:34:54 3553 [ 24.094912] COMPILER OS linux 3554 [ 24.094918] COMPILER OS ARCH x86_64-linux-gnu-thread-multi 3555 [ 24.095663] CHIP TAG: 0 3556 [ 24.101513] CHIP ID: SSV6006C0 3557 [ 24.106158] 0x800e0000 3558 [ 24.142696] ERROR!!Please check interface! 3559 [ 24.142722] [0xca000200]: 0x0c000000!=0x00000000 3560 [ 24.142729] SOS!SOS! 3561 [ 24.142736] Initialize ssv6200 mac fail!! 3562 [ 25.765283] rk_gmac-dwmac 30200000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx 3563 [ 34.049409] SVN version 16529 3564 [ 34.049434] SVN ROOT URL http://XXX.XXX.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx 3565 [ 34.049443] COMPILER HOST icomm-buildserver-T320 3566 [ 34.049450] COMPILER DATE 12-08-2017-10:34:54 3567 [ 34.049456] COMPILER OS linux 3568 [ 34.049463] COMPILER OS ARCH x86_64-linux-gnu-thread-multi 3569 [ 34.049726] CHIP TAG: 0 3570 [ 34.049997] CHIP ID: SSV6006C0 3571 [ 34.053238] 0x800e0000 3572 [ 34.095744] ERROR!!Please check interface! 3573 [ 34.095770] [0xca000200]: 0x0c000000!=0x00000000 3574 [ 34.095777] SOS!SOS! 3575 [ 34.095784] Initialize ssv6200 mac fail!! 3576 [ 34.098424] SVN version 16529 3577 [ 34.098448] SVN ROOT URL http://XXX.XXX.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx 3578 [ 34.098460] COMPILER HOST icomm-buildserver-T320 3579 [ 34.098473] COMPILER DATE 12-08-2017-10:34:54 3580 [ 34.098480] COMPILER OS linux 3581 [ 34.098487] COMPILER OS ARCH x86_64-linux-gnu-thread-multi 3582 [ 34.098723] CHIP TAG: 0 3583 [ 34.098998] CHIP ID: SSV6006C0 3584 [ 34.102525] 0x800e0000 3585 [ 34.144416] ERROR!!Please check interface! 3586 [ 34.144442] [0xca000200]: 0x0c000000!=0x00000000 3587 [ 34.144449] SOS!SOS! 3588 [ 34.144456] Initialize ssv6200 mac fail!! 3589 [ 44.051925] SVN version 16529 3590 [ 44.051960] SVN ROOT URL http://XXX.XXX.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx 3591 [ 44.051974] COMPILER HOST icomm-buildserver-T320 3592 [ 44.051988] COMPILER DATE 12-08-2017-10:34:54 3593 [ 44.052000] COMPILER OS linux 3594 [ 44.052013] COMPILER OS ARCH x86_64-linux-gnu-thread-multi 3595 [ 44.052343] CHIP TAG: 0 3596 [ 44.052736] CHIP ID: SSV6006C0 3597 [ 44.057460] 0x800e0000 3598 [ 44.122949] ERROR!!Please check interface! 3599 [ 44.122982] [0xca000200]: 0x0c000000!=0x00000000 3600 [ 44.122996] SOS!SOS! 3601 [ 44.123008] Initialize ssv6200 mac fail!! 3602 [ 44.126948] SVN version 16529 3603 [ 44.126982] SVN ROOT URL http://XXX.XXX.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx 3604 [ 44.126997] COMPILER HOST icomm-buildserver-T320 3605 [ 44.127010] COMPILER DATE 12-08-2017-10:34:54 3606 [ 44.127023] COMPILER OS linux 3607 [ 44.127036] COMPILER OS ARCH x86_64-linux-gnu-thread-multi 3608 [ 44.127338] CHIP TAG: 0 3609 [ 44.127849] CHIP ID: SSV6006C0 3610 [ 44.132891] 0x800e0000 3611 [ 44.198420] ERROR!!Please check interface! 3612 [ 44.198456] [0xca000200]: 0x0c000000!=0x00000000 3613 [ 44.198469] SOS!SOS! 3614 [ 44.198481] Initialize ssv6200 mac fail!! 3615 [ 54.050317] SVN version 16529 3616 [ 54.050351] SVN ROOT URL http://XXX.XXX.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx 3617 [ 54.050365] COMPILER HOST icomm-buildserver-T320 3618 [ 54.050379] COMPILER DATE 12-08-2017-10:34:54 3619 [ 54.050391] COMPILER OS linux 3620 [ 54.050404] COMPILER OS ARCH x86_64-linux-gnu-thread-multi 3621 [ 54.050715] CHIP TAG: 0 3622 [ 54.051106] CHIP ID: SSV6006C0 3623 [ 54.056114] 0x800e0000 3624 [ 54.119955] ERROR!!Please check interface! 3625 [ 54.119989] [0xca000200]: 0x0c000000!=0x00000000 3626 [ 54.120001] SOS!SOS! 3627 [ 54.120014] Initialize ssv6200 mac fail!! 3628 [ 54.123923] SVN version 16529 3629 [ 54.123963] SVN ROOT URL http://XXX.XXX.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx 3630 [ 54.123980] COMPILER HOST icomm-buildserver-T320 3631 [ 54.123994] COMPILER DATE 12-08-2017-10:34:54 3632 [ 54.124007] COMPILER OS linux 3633 [ 54.124021] COMPILER OS ARCH x86_64-linux-gnu-thread-multi 3634 [ 54.124399] CHIP TAG: 0 3635 [ 54.124851] CHIP ID: SSV6006C0 3636 [ 54.129682] 0x800e0000 3637 [ 54.195350] ERROR!!Please check interface! 3638 [ 54.195385] [0xca000200]: 0x0c000000!=0x00000000 3639 [ 54.195398] SOS!SOS! 3640 [ 54.195410] Initialize ssv6200 mac fail!! 3641 [ 64.045337] SVN version 16529 3642 [ 64.045361] SVN ROOT URL http://XXX.XXX.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx 3643 [ 64.045370] COMPILER HOST icomm-buildserver-T320 3644 [ 64.045377] COMPILER DATE 12-08-2017-10:34:54 3645 [ 64.045383] COMPILER OS linux 3646 [ 64.045390] COMPILER OS ARCH x86_64-linux-gnu-thread-multi 3647 [ 64.045604] CHIP TAG: 0 3648 [ 64.045838] CHIP ID: SSV6006C0 3649 [ 64.049446] 0x800e0000 3650 [ 64.098162] ERROR!!Please check interface! 3651 [ 64.098191] [0xca000200]: 0x0c000000!=0x00000000 3652 [ 64.098200] SOS!SOS! 3653 [ 64.098212] Initialize ssv6200 mac fail!! 3654 [ 64.101684] SVN version 16529 3655 [ 64.101719] SVN ROOT URL http://XXX.XXX.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx 3656 [ 64.101733] COMPILER HOST icomm-buildserver-T320 3657 [ 64.101740] COMPILER DATE 12-08-2017-10:34:54 3658 [ 64.101748] COMPILER OS linux 3659 [ 64.101756] COMPILER OS ARCH x86_64-linux-gnu-thread-multi 3660 [ 64.102055] CHIP TAG: 0 3661 [ 64.102466] CHIP ID: SSV6006C0 3662 [ 64.106790] 0x800e0000 3663 [ 64.148371] ERROR!!Please check interface! 3664 [ 64.148396] [0xca000200]: 0x0c000000!=0x00000000 3665 [ 64.148404] SOS!SOS! 3666 [ 64.148411] Initialize ssv6200 mac fail!! 3667 [ 74.059189] SVN version 16529 3668 [ 74.059224] SVN ROOT URL http://XXX.XXX.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx 3669 [ 74.059239] COMPILER HOST icomm-buildserver-T320 3670 [ 74.059253] COMPILER DATE 12-08-2017-10:34:54 3671 [ 74.059265] COMPILER OS linux 3672 [ 74.059278] COMPILER OS ARCH x86_64-linux-gnu-thread-multi 3673 [ 74.059727] CHIP TAG: 0 3674 [ 74.060248] CHIP ID: SSV6006C0 3675 [ 74.065159] 0x800e0000 3676 [ 74.127242] ERROR!!Please check interface! 3677 [ 74.127275] [0xca000200]: 0x0c000000!=0x00000000 3678 [ 74.127288] SOS!SOS! 3679 [ 74.127301] Initialize ssv6200 mac fail!! 3680 [ 74.131431] SVN version 16529 3681 [ 74.131463] SVN ROOT URL http://XXX.XXX.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx 3682 [ 74.131478] COMPILER HOST icomm-buildserver-T320 3683 [ 74.131491] COMPILER DATE 12-08-2017-10:34:54 3684 [ 74.131503] COMPILER OS linux 3685 [ 74.131517] COMPILER OS ARCH x86_64-linux-gnu-thread-multi 3686 [ 74.131976] CHIP TAG: 0 3687 [ 74.132472] CHIP ID: SSV6006C0 3688 [ 74.137520] 0x800e0000 3689 [ 74.197666] ERROR!!Please check interface! 3690 [ 74.197701] [0xca000200]: 0x0c000000!=0x00000000 3691 [ 74.197714] SOS!SOS! 3692 [ 74.197726] Initialize ssv6200 mac fail!! 3693 3694 3695 vm.admin_reserve_kbytes = 8192 3696 vm.block_dump = 0 3697 vm.dirty_background_bytes = 0 3698 vm.dirty_background_ratio = 10 3699 vm.dirty_bytes = 0 3700 vm.dirty_expire_centisecs = 3000 3701 vm.dirty_ratio = 20 3702 vm.dirtytime_expire_seconds = 43200 3703 vm.dirty_writeback_centisecs = 500 3704 vm.drop_caches = 0 3705 vm.extra_free_kbytes = 0 3706 vm.highmem_is_dirtyable = 0 3707 vm.laptop_mode = 0 3708 vm.legacy_va_layout = 0 3709 vm.lowmem_reserve_ratio = 32 32 3710 vm.max_map_count = 65530 3711 vm.min_free_kbytes = 3924 3712 vm.mmap_min_addr = 32768 3713 vm.mmap_rnd_bits = 8 3714 vm.nr_pdflush_threads = 0 3715 vm.oom_dump_tasks = 1 3716 vm.oom_kill_allocating_task = 0 3717 vm.overcommit_kbytes = 0 3718 vm.overcommit_memory = 0 3719 vm.overcommit_ratio = 50 3720 vm.page-cluster = 0 3721 vm.panic_on_oom = 0 3722 vm.percpu_pagelist_fraction = 0 3723 vm.stat_interval = 1 3724 vm.swappiness = 100 3725 vm.user_reserve_kbytes = 30419 3726 vm.vfs_cache_pressure = 100 3727 3728 ### interrupts: 3729 CPU0 CPU1 CPU2 CPU3 3730 16: 0 0 0 0 GIC 29 Edge arch_timer 3731 17: 57476 53456 53017 55292 GIC 30 Edge arch_timer 3732 20: 0 0 0 0 GIC 75 Level rk_timer 3733 21: 0 0 0 0 GIC 32 Level 110f0000.pdma 3734 22: 0 0 0 0 GIC 33 Level 110f0000.pdma 3735 30: 11 0 0 0 GIC 89 Level serial 3736 31: 0 0 0 0 GIC 90 Level rockchip_thermal 3737 32: 0 0 0 0 GIC 38 Level Mali_GP 3738 33: 0 0 0 0 GIC 37 Level Mali_GP_MMU, Mali_PP0_MMU, Mali_PP1_MMU 3739 34: 0 0 0 0 GIC 36 Level Mali_PP0, Mali_PP1 3740 35: 0 0 0 0 GIC 41 Level 20020000.vpu-service 3741 36: 0 0 0 0 GIC 43 Level 20020000.vpu-service 3742 38: 0 0 0 0 GIC 39 Level 20030000.rkvdec 3743 40: 0 0 0 0 GIC 64 Level 20050000.vop 3744 41: 0 0 0 0 GIC 65 Level rga 3745 43: 0 0 0 0 GIC 67 Level 200a0000.hdmi, dw-hdmi-cec 3746 45: 695051 0 0 0 GIC 44 Level dw-mci 3747 46: 51216 0 0 0 GIC 45 Level dw-mci 3748 47: 22 0 0 0 GIC 47 Level nandc 3749 48: 0 0 0 0 GIC 55 Level 30040000.usb, dwc2_hsotg:usb1 3750 49: 0 0 0 0 GIC 48 Level ehci_hcd:usb2 3751 50: 0 0 0 0 GIC 49 Level ohci_hcd:usb5 3752 51: 0 0 0 0 GIC 51 Level ehci_hcd:usb3 3753 52: 0 0 0 0 GIC 52 Level ohci_hcd:usb6 3754 53: 0 0 0 0 GIC 98 Level ehci_hcd:usb4 3755 54: 0 0 0 0 GIC 99 Level ohci_hcd:usb7 3756 55: 12581 0 0 0 GIC 56 Level eth0 3757 104: 0 0 0 0 gpio1 11 Edge gpio-ir-recv-irq 3758 110: 0 0 0 0 gpio1 17 Edge � 3759 182: 0 0 0 0 gpio3 25 Edge reset 3760 189: 0 0 0 0 GIC 94 Level rockchip_usb2phy 3761 190: 0 0 0 0 GIC 100 Level rockchip_usb2phy 3762 IPI0: 0 0 0 0 CPU wakeup interrupts 3763 IPI1: 0 0 0 0 Timer broadcast interrupts 3764 IPI2: 13364 290985 32142 27986 Rescheduling interrupts 3765 IPI3: 12 1338 209 12 Function call interrupts 3766 IPI4: 0 0 0 0 CPU stop interrupts 3767 IPI5: 0 0 0 0 IRQ work interrupts 3768 IPI6: 0 0 0 0 completion interrupts 3769 Err: 0 Please upload the whole output above to an online pasteboard service and provide the URL in the forum where you have been asked for this. 0 Quote Link to comment Share on other sites More sharing options...
RaptorSDS Posted June 5, 2021 Share Posted June 5, 2021 @jock i have a small request is it possible to get a 4 led config ? i got with Ledconfig 1 -power =first red than red and blue on ( i thing its not good for Led) -kernel = blue on -power off = red and blue on ledconfig 2 -power =red on -kernel = red on ,blue disk work status -power off = red on ledconfig3 -power = red on -kernel = red off , blue off my request ledconfig4 power= red on kernel = red off, blue on also after ledconfig3 the box did not get back to ledconfig1 mode at reboot only with power off ledconfig3 to ledconfig2 work with reboot 0 Quote Link to comment Share on other sites More sharing options...
jock Posted June 5, 2021 Author Share Posted June 5, 2021 @beretas Can't say anything about upgrade_tool error. I have only one board with NAND and it always worked so far. I asked @fabiobassa to do some tests with his NAND board and AFAIK it worked there too. rkdeveloptool ul with NAND boards often tell you everything went well, but does not always work (on my board it does not do anything). Did you try the other bootloaders available in the instructions post? Do you have any serial log? 0 Quote Link to comment Share on other sites More sharing options...
jock Posted June 5, 2021 Author Share Posted June 5, 2021 @RaptorSDS The led configurations are not for intended as on/off switches, you should use the one and only that is suitable for your board because the led GPIO pins changes among boards (ie: the leds are connected to different "ports" on the SoC). You have to spot the led configuration that works for your board, or just read the board signature and find a match in rk322x-config proposals. Once you do that, the leds can be controlled independently via /sys/class/leds/working and /sys/class/leds/auxiliary sysfs paths. By default the working led is set to stay always on and auxiliary is set to blink when there is MMC access, but you can change writing into trigger file you find in those paths. Use cat trigger to show the list of possible values that you can write into and search google for documentation. 0 Quote Link to comment Share on other sites More sharing options...
Luiz Rocha Posted June 10, 2021 Share Posted June 10, 2021 Hi everyone, I've been following this topic for a while. I've been working with environment settings for a few years and I'm really enjoying these single board computers (raspberry, banana, orange). And reading your content, I decided to purchase a rock-chip rk3228a. I tried to change the ROM of it, but I was unsuccessful. https://photos.google.com/share/AF1QipPl7CExQWOgwruHVVWZplC76vnzXTkNJpeCMlNMQdqSTPExIVibc5hO6v2LXVq9kQ?key=VzBQUTk4ZFk3a3VRZjhjQVZzRHNYLWxTMS1NQU13 Can anyone help? I shared the photos from the tv box on the link above. 0 Quote Link to comment Share on other sites More sharing options...
fabiobassa Posted June 11, 2021 Share Posted June 11, 2021 @Luiz Rocha Quote "I tried to change the ROM of it" if you speak about android rom this isn 't the right place since here we discuss about linux-armbian on those board If you instead speak of linux-armbian you are in the right place but apart from photos you didn't describe what the problem is ( no boot ? - have you a uart , have you logs ?) 0 Quote Link to comment Share on other sites More sharing options...
Luiz Rocha Posted June 11, 2021 Share Posted June 11, 2021 3 hours ago, fabiobassa said: @Luiz Rocha if you speak about android rom this isn 't the right place since here we discuss about linux-armbian on those board If you instead speak of linux-armbian you are in the right place but apart from photos you didn't describe what the problem is ( no boot ? - have you a uart , have you logs ?) I did the procedures using multitool.img and couldn't find eMMC, so I tried to enter maskrom mode and change the linux-armbian image. My machine is Ubuntu 20.04.2 LTS, I believe that I have not properly installed rkdeveloptool and upgrade_tool or even has an old version including multitool.img. What official repository are you using on github or gitlab? Where can I download updated versions of this project to try again to switch to linux-armbian? 0 Quote Link to comment Share on other sites More sharing options...
ArkhanLK Posted June 12, 2021 Share Posted June 12, 2021 Hi everyone, I'm doing really well on the board I have! I am sure this is a really capable board! So far I have: . Played emulator games and some old/retro games such as quake 1, 2, and doom; . Web-browesed on Firefox to almost any website (netflix doesn't work, some issues with google meet as well); . Edited photos and pdf with gimp, libreoffice draw, kolourpaint... Flawlessly!; . Draw 2d cad with librecad and will be testing leocad soon!; . When videos work, like in YouTube or twitch, I can watch them decent at 480p, very decent at 360p; . Watched 1080p on kodi (at least on twitch), but the other services (Amazon, Netflix, Disney, YouTube...) I wasn't able to try yet. Overall, this makes for a REALLY good and cheap basic desktop. But just to be sure, let me ask something: is there any way to dual boot with android + armbian? That'd be possible with, I suppose, partitioning the emmc... I am aware that there is a way to install linux in Android and then ssh into it. But that's not the same thing I'm asking about! As always, thanks a lot for the help and support here. You guys are awesome. Much love <3 1 Quote Link to comment Share on other sites More sharing options...
jaum20 Posted June 12, 2021 Share Posted June 12, 2021 It is possible to enable S/PDIF digital audio output? 0 Quote Link to comment Share on other sites More sharing options...
jock Posted June 12, 2021 Author Share Posted June 12, 2021 @ArkhanLK Glad you're finding the box useful and thanks for reporting! Netflix and friends usually have other issues related to Digital Rights Management, but never really dig into. I know that on LibreELEC you need to download the Widevine plugin. @jaum20 It should be already enabled, but honestly I never checked the coaxial SPDIF output. Will check right now edit: just checked on both mainline and legacy kernel and it is working fine up to 192khz! Maybe you need to tell pulseaudio to use SPDIF (IEC958) from the speaker icon in the upper right corner 3 Quote Link to comment Share on other sites More sharing options...
fabiobassa Posted June 12, 2021 Share Posted June 12, 2021 @ArkhanLK ad Jock already said is not a problem of the soc per se , but netflix and other need DRM and this must be enabled in some way as libreelec already did. I am very but very happy that you found this little black box usefull, I use plenty of those for the most wide purposes 1 Quote Link to comment Share on other sites More sharing options...
markosc Posted June 15, 2021 Share Posted June 15, 2021 12 V88 1gb ram http://ix.io/3q3b system load 151% ? img : https://ibb.co/h1vp5DW 0 Quote Link to comment Share on other sites More sharing options...
ArkhanLK Posted June 15, 2021 Share Posted June 15, 2021 Thanks @jock and @fabiobassa! Yeah, it is partially due to these limitations and also the limitations of how I am currently using Kodi that I am trying that dual boot alternative. You guys don't happen to know anything about it, do you? Even if it'd mean run android on eMMC and Linux from the sdcard, it'd still be very helpful! If things keep running as they are, I think I can turn this into a product soon enough - and then help with donations! ^^ 0 Quote Link to comment Share on other sites More sharing options...
jock Posted June 15, 2021 Author Share Posted June 15, 2021 22 minutes ago, ArkhanLK said: Thanks @jock and @fabiobassa! Yeah, it is partially due to these limitations and also the limitations of how I am currently using Kodi that I am trying that dual boot alternative. You guys don't happen to know anything about it, do you? Even if it'd mean run android on eMMC and Linux from the sdcard, it'd still be very helpful! If things keep running as they are, I think I can turn this into a product soon enough - and then help with donations! ^^ Running android from eMMC and Linux from sdcard is very possible, LibreELEC does that, but also the multitool works that way also. Armbian images are not provided in that way for very specific reason: support is more difficult since we can't know what kind of software (bootloader version, ddrbin, etc...) booted the box extended boot features (like USB boot or network boot) are impossible to implement plenty of outdated binary blobs are involved (you don't know what happens in that code) limited speed for DDR ram memories in mainline kernel Since Armbian is intended for general and stable usage and work is done towards the mainline kernel, the "dual boot" choice has been dropped almost instantly. 1 Quote Link to comment Share on other sites More sharing options...
RaptorSDS Posted June 17, 2021 Share Posted June 17, 2021 i do not know if something change in last apt upgrade for rk332x root or image but i got today kernel faults and emmc problem emmc problems like the one i report when i config emmc in armbianEnv.txt my box tell me 398% CPU usage kernel panic kernel:[ 519.498786] Internal error: Oops: 805 [#1] PREEMPT SMP ARM Message from syslogd@rk322x-box at Jun 17 21:45:02 ... kernel:[ 519.645677] Process kworker/0:3 (pid: 1159, stack limit = 0x6b325425) Message from syslogd@rk322x-box at Jun 17 21:45:02 ... kernel:[ 519.652911] Stack: (0xb38ffc80 to 0xb3900000) Message from syslogd@rk322x-box at Jun 17 21:45:02 ... kernel:[ 519.657808] fc80: 200e0013 00000001 b38ffcac b38ffc98 b103e600 b01879f4 b1d04938 00000001 Message from syslogd@rk322x-box at Jun 17 21:45:02 ... kernel:[ 519.667000] fca0: b38ffcd4 b38ffcb0 b089a0d0 b103e5f0 ffffffff b0899f80 00000001 b38ffd08 Message from syslogd@rk322x-box at Jun 17 21:45:02 ... kernel:[ 519.676192] fcc0: b1d11824 00000000 b38ffd04 b38ffcd8 b014ba44 b0899f8c b1d05b40 b1d11800 Message from syslogd@rk322x-box at Jun 17 21:45:02 ... kernel:[ 519.685385] fce0: b1780e90 b1c05e40 b1606808 00000001 00000000 b4737080 b38ffd3c b38ffd08 Message from syslogd@rk322x-box at Jun 17 21:45:02 ... kernel:[ 519.694577] fd00: b088ce80 b014b9d8 b1d05b40 23c34600 30a32c00 d4a8b198 b088f660 b1c05e40 Message from syslogd@rk322x-box at Jun 17 21:45:02 ... kernel:[ 519.703770] fd20: b1c05e40 00000000 00000001 b1c05300 b38ffd5c b38ffd40 b088cf4c b088ce04 Message from syslogd@rk322x-box at Jun 17 21:45:02 ... kernel:[ 519.712962] fd40: b1c05e40 b1c05240 00000000 00000001 b38ffd7c b38ffd60 b088cf10 b088ceb0 Message from syslogd@rk322x-box at Jun 17 21:45:02 ... kernel:[ 519.722155] fd60: b1c05240 b1c05300 00000000 00000001 b38ffd9c b38ffd80 b088cf10 b088ceb0 Message from syslogd@rk322x-box at Jun 17 21:45:02 ... kernel:[ 519.731348] fd80: b1d1ca80 b1606808 30a32c00 30a32c00 b38ffddc b38ffda0 b0892dd4 b088ceb0 Message from syslogd@rk322x-box at Jun 17 21:45:02 ... kernel:[ 519.740539] fda0: 30a32c00 00000000 ffffffff 30a32c00 b1d04000 d4a8b198 b38ffddc b30fadc0 Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.592688] [<b0892e54>] (clk_set_rate) from [<b0c21ae0>] (dev_pm_opp_set_rate+0x28c/0x588) Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.602072] r5:30a32c00 r4:b81ae800 Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.606113] [<b0c21854>] (dev_pm_opp_set_rate) from [<af0970a4>] (set_target+0x38/0x3c [cpufreq_dt]) Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.616380] r10:00000000 r9:00000000 r8:00000001 r7:00000000 r6:b18a0a8c r5:b1606808 Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.625174] r4:b48c2200 Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.628042] [<af09706c>] (set_target [cpufreq_dt]) from [<b0c277d8>] (__cpufreq_driver_target+0x1bc/0x540) Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.638895] [<b0c2761c>] (__cpufreq_driver_target) from [<b0c2b7d0>] (cs_dbs_update+0xd8/0x14c) Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.648674] r10:b1800a20 r9:00000000 r8:b4a6f5c0 r7:b4a73600 r6:000cd140 r5:b48c2200 Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.657469] r4:b4a73100 Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.660334] [<b0c2b6f8>] (cs_dbs_update) from [<b0c2bd44>] (dbs_work_handler+0x3c/0x64) Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.669333] r9:00000000 r8:b17c03e0 r7:b48c2200 r6:b4a73104 r5:00000000 r4:b4a73148 Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.678047] [<b0c2bd08>] (dbs_work_handler) from [<b0142bc4>] (process_one_work+0x224/0x60c) Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.687535] r9:00000000 r8:00000000 r7:eedd7d00 r6:eedd4980 r5:b1fcd280 r4:b4a73148 Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.696254] [<b01429a0>] (process_one_work) from [<b0143018>] (worker_thread+0x6c/0x584) Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.705354] r10:eedd4980 r9:b1604900 r8:eedd49a4 r7:00000008 r6:eedd4980 r5:b1fcd294 Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.714151] r4:b1fcd280 Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.717017] [<b0142fac>] (worker_thread) from [<b014a12c>] (kthread+0x19c/0x1b4) Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.725335] r10:b1de1e68 r9:00000000 r8:b1fcd280 r7:b0142fac r6:b3096000 r5:b1fe7000 Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.734130] r4:b1fcd200 Message from syslogd@rk322x-box at Jun 17 22:03:33 ... kernel:[ 63.736993] [<b0149f90>] (kthread) from [<b0100148>] (ret_from_fork+0x14/0x2c) 0 Quote Link to comment Share on other sites More sharing options...
jock Posted June 18, 2021 Author Share Posted June 18, 2021 @RaptorSDS No particular updates recently. If you're on legacy kernel, it is the same 4.4.194 kernel as it was long ago. Mainline kernel still should be a subversion of 5.10 Can't say anything about, I just see a kernel panic but can't say if it is related to emmc. Maybe it is just a "common" stability issue of the board due to crap quality. 0 Quote Link to comment Share on other sites More sharing options...
RaptorSDS Posted June 18, 2021 Share Posted June 18, 2021 i am on mainline kernel 5.10 i had befor set cpu from 400MHz to limit 1.2GHz max -> to limit thermal output after that kernel panic i switch back to 600Mhz to 1.39GHz ( after kernel panic armbian-config has no 400Mhz option) now its little bit better (could a app like php3 , nginx, mariadb do a kernel panic like above ? ) but i hope i will not be get worse 0 Quote Link to comment Share on other sites More sharing options...
