does anyone tried adding a usb gigabit lan to make your smb server transfer speed fast? I am not quite sure that it will get its full speed since the box only have a usb 2.0
Edited by speed21
On 2/21/2023 at 2:37 PM, fabiobassa said:
@n3o
Have you read the whole topic ?
Sure?
Because at the beginning Is clear that multitool will warn you if inside the box there is a nand
That said , go read First post
Hi, I have write multitool image to microsd with rufus, but when I have turnon the device multitool menu isn't been showed and only an android menu has been showed... What should I do?
Best hope is that it will go around 400mbit/s, more reasonably around 300/350mbit/s; surely you won't get anything near the full gigabit.
Paste the serial output logs here; without them, we're blind
do You mean the voice "View recovery logs"?
This is an example of screenshot of android recovery mode
No, I mean the serial output logs. If you don't know what I'm talking about, read the rest of the thread or search with google.
Here are my impressions after some weekend tests:
Overall, it's all working better than I expected !
Despite some things I have read here, the desktop experience is fine to me, maybe my
standards are too low? chromium is loading first time in about 10
seconds, after that it's faster. It's not super responsive to the commands, but
it's not too laggy either.
Youtube in Chromium is almost OK to watch, which surprised me, I expected much
worse. But there is some stuttering. I think it can work much better with some
external app. I installed smtube, but it depends on youtube-dl which was failing,
but now I found a 2023 version of it that seems to work, to be tested later.
I installed many window managers, jwm, icewm, wmaker and lxde, all working well,
but I now mostly like icewm which combines a very light ram usage and some nice
windows-looking menus. Ideal to show your friends who think linux is an OS that only
can be used by wizards.
My parents like printing so I put there cups with hplip, and libreoffice showed
a nice preview, remote printing worked, which made them impressed, they asked me how I did
that, funny, right.
Ethernet worked for most of the time but suddenly stopped one or two times, I
am not sure if this is a driver issue or network-manager related, to be verified.
Wifi was failing to load, I now found out that ssv6051 was looking for a .conf
file and it was named .cfg in the filesystem, to verify later if it works after correcting it.
The internal storage was detected as mmcblk2 and some partitions mmcblk2boot0 and boot1,
however I couldn't mount them, I am not sure what goes on here, maybe it's
a different rockchip filesystem because of the boot files and with the correct
offset it can be mounted, to be checked later.
IN my opinion it truly makes a little pc in your tv, thumbs up ...
from first post I have read the followng post
What do You mean for serial output logs?
@n3o
....... Serial UART (configured at 115200 bps, not 1.5Mbps!) ....   that means serial output logs
if really you have read CAREFULLY the first post you should have read this too !
Anyway here is described all, exactly in the first post
if somethings is still not clear, here is not a ready food store but you should proceed by trials and errors, andmostly study by yourself
And you didn't even read the post of another user:
hi
eMCP is RAM and Flash on one Chip most time  , --> when you have only one big chip beside the CPU
since you DON'T HAVE a big chip beside the cpu, then you have nand or emmc. Easy , isn't it
Multitool will say what it is, if a emmc or a nand
But you come back again asking and asking, and asking again
This usually is not a right approach to a forum
my apologies, I'm newbie with hardware... I have this device
https://it.aliexpress.com/item/32962644145.html?spm=a2g0o.order_list.order_list_main.15.7fdb3696WhwPEr&gatewayAdapt=glo2ita
it's useful to reach the goal? if not can you post the device to buy?
If yes, can you post photo of how link cable dupont from board to that device? I ask just of little patience
Hello, I have a smart speaker, RK3229CPU, and the sound card is AMK’s AK7755EN. The firmware of the box can be flashed normally, but there is no sound driver. How can I recognize the AK7755EN normally? If it needs to be developed separately, I am willing to pay for the relevant fees . Thank you very much.
The following is the introduction of this speaker:
https://www.52audio.com/archives/534.html
AK7755EN
ak7755_f01e.pdf (akm.com)
I extracted the dts file of smart speaker android for your reference.
my email is:2823609@qq.com
smart speak R1 android.dts
Edited by Prioner
moved inlined file to spoiler
1 hour ago, fabiobassa said:
is a 329q1
how do You have discovered that is a 329q1? how do You have discovered that is nand and not emmc?
what do You tell about item linked? it's useful or I shoult buy another uart? and the dupont link?
hello @Prioner
If the driver has no source available, I don't think it can work with a compiled kernel.
The only way I see a closed source driver could work, would be if you used your original kernel and used it to boot a linux file system.
Have a good week,
Hi everyone, Im triying to boot multitool but it doesnt work. When I put the SD card with multiboot for RK322X box doesnt show anything on display (display stays standby) and blue led doesnt blink. I also tried booting it with the toothpick method (like I do with LibreElec 9.2 just fine) and same behavior. Box specs:
OTT MXQ 4K (not Pro) device with these specs (real and verified by me with my camera):
RK3229 CBBKM43012 1552 CPU
SanDisk P553072141 SDTNRGAMA-008G CP0813618 NAND
NANYA NT5CC256M16DP-DI RAM (DDR3)
Pulse H1102NL 1549-M ETH
Espressif ESP8089 05215 P27X03 WiFi
Board name T066-V1
Firmware MXQ-4K_ota_20160308
For the sake of adding more info, LibreElec 10 doesnt boot (but shows some stuff on display) like I posted here: https://forum.libreelec.tv/thread/25236-unofficial-rk3228-rk3229-libreelec-10-x-builds/?postID=177493#post177493
Maybe LibreElec 10 and Multiboot issues are related.
Would LOVE to try Armbian on this little device.
@ochentay4
What do you mean " inspected by my camera"
Have read, again, the whole post ( no, i Guess)
Because already discussed that even if marked 3229 sometimes are fake and they really are amlogic or allwinner.
Heve you skills to get a USB TTL converter and give us a serial log ?
@fabiobassa
I think he meant that he took some pics with his camera.
And, please correct if i'm wrong, but, @ochentay4 if you can boot libreelec I think you can boot armbian , at least by doing a mixed image, as proposed by user "hexdump" in the first posts, that's how I prepared my sdcard image too.
good luck
@jock@fabiobassa and others
Thanks for great support for RK322x.
I had x96mate with h616, after booting arch, its HDMI gave up on me, so after reading your post got the RK3229 box.
I don't intend too use as a desktop but as a kiosk.
Mainly I use chromium, nodejs, and mpv/ffplay/cvlc (anyone)
Box I got is rk3229 with nand, so teste 3 legacy images, one without DE and two with xfce from OP. Everything works as expected on horizontal mode.
As I need mpv to run smoothly, installed media package by @jock
after installing media support, i no longer able to rotate my display, before installing the media support display rotate worked.
cannot use xrandr to rotate also option in settings ---- display, rotate option is not there.
DISPLAY=:0 xrandr --output HDMI-1 --rotate right
any clue how to sort this out ?
Edited by BigZero
On 3/1/2023 at 4:49 PM, fangis said:
can you still boot to android ?
I do not more tried because I don't know if device that I already have is useful to connect to UART. Moreover, even if somebody confirm that is useful, I don't know  how connect UART on the 329q -1 board to that interface (it's better post a photo because with electronic I'm noob).
However I'm not interested to use Android TV 7 current firmware ... because when I want use acestream I cannnot use my smartphone as bluetooth keyboard to insert link.
Hope that somebody answer me
@fabiobassa
I will try to get a USB TTL converter and give you a serial log but it will take time, as I dont have the neccesarry stuff to do it myself and I cant get one so easily online where I live.
What I meant to say was that I took photos with my camera and took note of all chip descriptions.
I can confirm its a real RK3229 and I already managed to boot LibreELEC 10 thanks to "ilmich" here: https://forum.libreelec.tv/thread/25236-unofficial-rk3228-rk3229-libreelec-10-x-builds/?postID=177599#post177599 that fixed it.
I also tried to boot several armbian images, even legacy ones, and same beahavior as multitool, black screen (stand by) and no blinking leds.
I also tried to scan my network to see if multitool booted but had no display and no, it doesnt how (of course my DHCP is working and cable plugged on ethernet port).
Tried with tootchpick, no toothpick, tried both holes, it doesnt show anything on screen, only blue led on.
@fangis
I read the post by "hexdump" and its really complicated for me at the moment, I need to learn more. Thats why I wanted to test armbian on this device so I can "play" with linux.
Something else: I dont know why my profle is still "Validating"... and cant post more than 1 post a day and cant change my avatar... Some help would be welcome.
Edited by ochentay4
@fabiobassa I have searched for photo and I have found that model is R329Q_V3.1. Do you confirn that UART consist in only 3 cable link:
1. TXD (on CH341A board) - RX (on R329Q board)
2. RXD (on CH341A board) - TX (on R329Q board)
3. GND (the pin on CH341A board below RXD) - GND (on R329Q board)
in red circle there are link to UART, right? ... for the install of image the usb port to link to linux pc is the green circle port?
In putty window, when I choose "Serial" on connection type, in "Serial line" label it's showed "COM1" as default ...Leave it and set only Speed to "115200" ?
To use multiboot only (to search what error there's) it's necessary also link usb cable male - male?
@ochentay4
Il Mich , jock, and me we are actual studiers/developers in those rk322x and thanks to a Little " intuition" Mich discovered a missing piece in dtb and this Is  the reason libreelec booting and armbian or multitool NO.
We must build a " Frankenstein" boot with multitool kernel and libreelec dtb.
And yours Is a tipical case study
@n3o
And all your questions again confirm me that people try explain and give you hint and you dont even read or follow the answer.
In the First post there Is written that uart is 1.5 m (1.500.000) and you asking if 115200 Is good ?????????
Serious ???
On 2/28/2023 at 2:06 PM, fabiobassa said:
@n3o
@fabiobassa this is your post .... you have written 115200 bps, not 1.5Mbps
I have read the first post, moreover You have told that I have only Nand (without eMMC), so I must follow procedure NAND and installation from SD. Before this, I should also update bootloader as described here
Edited by n3o
Serious ???
I'm asking if  it's right how I have trying to link UART to usb and how set putty parameters to see the output.
In first post (inside section what works) is written "Serial UART (configured at 115200 bps, not 1.5Mbps!)", you in an older post have written the same thing, now You tell me that 115200 is wrong... What is the right value?
Hi N3O
i think there a missunderstanding  both are right
it depends on what you want
the real first boot loader talk at 1.5M than the UART get change by the bootloader from NAND or SD card or android to 115200
you only need to UART -> UART-USB-> USB of windowsPC or linux and a tool like Putty or Kitty
you dont need connect UART back to box or male male cable for normal Logs
the male male cable only for hard flash new bootloader or recovery with another PC with a rockchip tool
