16 hours ago, occams razor said:
@n3o  The members trying to help you are highly experienced. The important point here is for you not to treat their specific instructions as merely "suggestions" after which you go off and do your own thing.   That is where the frustration lies.
Based on the energy other users and you have spent on this, I would just buy some other TV box or SBC that is already known to run Armbian without any issues instead of trying to resurrect an old tired piece of hardware.   Unless you are really short on cash,  this is what I would do.  However, if you really are so short on cash that you cannot afford another $20USD on something else, then I believe your priorities are all wrong.
I have an H20 RK3228A tv box that is in transit that has some documented booting issues with Armbian.  In a way, I am happy to see how this whole episode has progressed.  I'm happy because now I know what NOT to do.
no doubt about the fact that are highly experienced, but they think that I'm not execute their istructions that is false. For the UART initially I don' knew what was it, after I have asked for the correct bitrate value. When I have post the first log I believed that it was something related to hardware (such a bios) and so if believed to all image, only after I have discovered about that was related to image. Same thing about image, in first post the last image was about kernel , and I have understood that armbian 22.11 was the legacy. Only yesterday I have discovered that kernel 4.4 is legacy.
However I have flashed the legacy image Armbian_21.08.1_Rk322x-box_buster_legacy_4.4.194_xfce_desktop.img.xz, system still doesn't boot but it's present the log UART, @RaptorSDS here there is the log UART
q,x▒▒▒▒y▒▒▒▒ݵ▒▒▒▒▒▒▒*▒▒*▒▒͍ժ▒(v,:▒▒▒▒ݥbŕݩ▒▒▒/▒
U-Boot 2017.09-g4fa8fb7-dirty (May 24 2020 - 12:08:53 +0000)
Model: Rockchip RK322x SoC (NAND)
DRAM:  1010 MiB
Sysmem: init
Relocation Offset is: 00000000
MMC:   dwmmc@30000000: 0
Using default environment
In:    serial@11030000
Out:   serial@11030000
Err:   serial@11030000
MMC Device 1 not found
no mmc device at slot 1
MMC: no card present
mmc_init: -123, time 2
Device 0: No.1 FLASH ID:2c 64 44 32 a5 0
ECC:60
FTL version: 5.0.53 20190107
FtlInit 0
Vendor: 0x2207 Rev: V1.00 Prod: rknand
            Type: Hard Disk
            Capacity: 7488.0 MB = 7.3 GB (15335424 x 512)
... is now current device
Bootdev: rknand 0
PartType: EFI
get part misc fail -1
boot mode: None
CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 0N/A)
  apll 600000 KHz
  dpll 600000 KHz
  cpll 500000 KHz
  gpll 594000 KHz
  armclk 600000 KHz
  aclk_bus 74250 KHz
  hclk_bus 37125 KHz
  pclk_bus 37125 KHz
  aclk_peri 74250 KHz
  hclk_peri 37125 KHz
  pclk_peri 37125 KHz
Net:   eth0: ethernet@30200000
Hit key to stop autoboot('CTRL+C'):  0
starting USB...
USB0:   Core Release: 3.10a
scanning bus 0 for devices... 1 USB Device(s) found
Device 0: unknown device
Device 0: Vendor: 0x2207 Rev: V1.00 Prod: rknand
            Type: Hard Disk
Scanning rknand 0:1...
2909 bytes read in 153 ms (18.6 KiB/s)
## Executing script at 60000000
Wrong image format for "source" command
SCRIPT FAILED: continuing...
Card did not respond to voltage select!
mmc_init: -95, time 10
DMA reset timeout
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-96-01-0c-35-23-2d
DMA reset timeout
Retrieving file: pxelinux.cfg/00000000
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
Retrieving file: pxelinux.cfg/default-arm-rockchip
DMA reset timeout
DMA reset timeout
DMA reset timeout
Config file not found
DMA reset timeout
DMA reset timeout
Edited by n3o
vor 34 Minuten schrieb n3o:
you have the USB Stick still insert thats a problem (like with sd-card only) it will interrupt bootloader
what about 4.4 on nand and no SD-card and no USB stick ?
no, there isn't USB stick... usb are all empty, only HDMI cable is plugged but it's unplugged from monitor.
the last log it's related to install on NAND ... I haven't use jumpstart option of multitool
vor 6 Minuten schrieb n3o:
ok soory
was irretated by usb init direct befor rknand init
than we can try "jumpstart" and hope that we can  start than armbian for SD-card ,
else we can try the more complex like write new bootloader but than someone else has to help ( i hadnt any box with need of rktool)
when I try to execute steps here https://forum.armbian.com/topic/12656-csc-armbian-for-rk322x-tv-boxes/?do=findComment&comment=121103 the box automaticaaly go to maskrom mode (I can see it because on linux vm with lsusb commands it's clearly written). I can't execute command "rkflashtool e 0 8192" because I'll get "fatal: cannot open device" on windows. It's important execute that command? Why it's already in maskrom mode?
after set jumpstart and made flash legacy image, led of the box is blue and nothing happen.... now I wait other 2 minutes and make uart log, but my opinion is that bootloader should be changed
Hi @n3o, are you using Windows? Linux ? OpenBSD? binary or compiled rkflashtool?
This is because
* on Linux maybe you don't have the right USB permission. You can switch to the super user account (super easy), or write an udev rule that chmod the USB node(easy if you know what are you doing)
* my rkflashtool uses libusb which on Windows needs the generic USB driver called WinUsb. With Windows 7 you need to right-click and install this file https://raw.githubusercontent.com/ilmich/rkflashtool/master/rockwinusb.inf. With Windows > 7 there is no need to install a driver, but you need to associate the unknown device with the USB generic driver WinUsb (I'm not a Windows user so try starting reading this link https://github.com/libusb/libusb/wiki/Windows#user-content-How_to_use_libusb_on_Windows)
* there is a bug on Windows (fixed with the latest alpha version) with multiple USB devices connected. Try, if you can, to have only the box connected with USB.
About your experiments, you wrote a lot, but I'm sorry, I'm too lazy to read:).
So if I can give you some advice, format the internal storage and forget it. Write the Armbian version you like on the SD card and stop.
This is because in addition to having a few problems, sd cards with 64/128GB are cheap and for Linux use are better than the 'little' 8 GB of internal storage that you often find in our boxes.
Cheers
Michele
edit: rkflashtool is an external tool made with love by volunteers. Obviously, there is also the contribution of @jock and @fabiobassa, but for any problem with the tool, I ask you the courtesy of opening an issue here https://github.com/ilmich/rkflashtool/issues
Edited by ilmich
Hi, i want share the experiences with my MXQ_R2B_LP3_V2.62_20225, the picture is the MASKROM pads, in my board i put a switch button to do easy, this board enter in MASKROM mode when hold on jumper in pads and conect USB cabe in compunter!  I did so much try, with multitools and rkdeveloptools, I did learn use the SSH terminal, and the board is working but without HDMI,  it do boot with Multitool card and i use with ssh terminal, i saved a dmesg log, and xorg log too! What more logs i can get it? I try install Armbian legacy buster, the original and my backup from other board (R329 Ver 8.0 that working fine) and don't boot from card this images don't work, but work it ok in R329, i only get  boot from card or flashdrive usb, installing  "jump start for NAND" from multitool card and downloading in board with rkdeveloptools!  Yet don't understand the rk3228 boot process, i like use the internal memory, i don't know how 'copy' from image or card, to memory and work! I'll use it without video, i understand that is a old problem like the MXQ R29 too!  I so much grate for this forum and the dedication of every one that contributed ! Thank you!!!
PS: The memory is a "eMCP", code: 7NA92 JYA42, like in R29, I don't found the real name!
log.dmesg.txt Xorg.0.log
vor 2 Stunden schrieb Benedito Portela:
eMCP some parts are not complete support at the moment --> eMCP is a more newer thing maybe actual kernel 6.10 running better ( eMCP is eMMC+DDR Ram )
the UART log is maybe better but DMESG is still ok , i see some clock and voltage not correct--> some gpio not registred
do you try other setting with rk322x-config? --> led-config this also thange some GPIO setting for diffirent boards?
@Benedito Portela Great work and you have finding all you was needing by reading and understanding it and learning little of Linux and SSH ;-)))
If like getting the device boot on all media you need to delete or upgrade the boot bin on the internal flash.
If you deleting the internal flash the ROM in the SOC is looking for it on the SD-card and then can booting USB and other storage by "jump starting". I prefer erasing the internal storage and writing one new updated boot bin on it => you can boot from every media also if having OS installed in the internal flash by putting in one USB drive and can "test drive" other versions.
Bad thing is only supporting new kernels and not 4.X ones that need the original one for working.
The HDMI is one long story and looks like not being solved but the box is working OK and its use less power then not connecting the HDMI so the SOC is not  running so hot.
Did you getting the WiFi working ??
I only using Eth then its more stable and is not making interference with my Ziggbe / Thread networks.
USB is not stable and can needing repower for getting device coming back if they is getting problems.
Great work done brave user !!!
RaptorSDS, I must use debian buster because i use a old program, but kernel can be new, i'll try new kernel versions! I only use the armbian-config to setup in performance mode, max clock, don't configured Leds, and other things. i run now the rk3228-config and only color leds change! It have three leds, blue, red and orange, before rk3228-config, only orange blink, now the blue is on! I don't use GPIO, I use USB port and audio out, Eth and HDMI just to setup, to change configs programs!
MattWestB, I tried some boot binarys, some memory address, combinations from card multitool and image original and my image already for use,  but only boot from card or USB work! The WIFI don't work, and i don't use and a think better not use! I'll pause for now, but I'll be following the posts!
Thank you!
@Benedito Portela in your dmesg i see
[   34.427778] dwhdmi-rockchip 200a0000.hdmi: failed to get edid
[   34.432114] dwhdmi-rockchip 200a0000.hdmi: failed to get edid
[   34.470696] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   34.470753] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   34.470795] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   34.470818] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   34.470842] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   34.470865] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Can you please indicate the model of the TV/monitor you are using?!
The problem seems to lie in the edid. Some old tv's have edid with problems. It may also depend on hardware configurations, but I imagine that with the original firmware it works.
ilmich, I use AOC monitor VGA, with adapter HDMI to VGA simple. but already used in LG TV 32LK450! The firth tvbox is MX9 5g 4k, board R329Q_V8.0, the segund is MX9 4k board R329q_v3.1 and last is MXQ Pro 5G 4K board MXQ-R2B-LP3_V2.62_220225! The firth work all fine, the segund work but it a very old and not is confiable, already some errors "segment faults" can is memory problems, i don't want use it this way, the third is that don't hdmi work and i want install armbian in internal memory! The android original work all! I want have a board like backup to firth box, and used it to do configs experiences, before put in firth box!
fabiobassa, i did backup used the android tools, many files apart, i can zipper and upload, it's ok? What uploda service is better for you?
Thank you!
@MattWestB    It doesn't surprise me that the USB ports on these tv boxes are dodgy.  In my experience with an RPI3 I found that poor power supply regulation caused all sort of headaches with anything more interesting than a mouse or keyboard on the USB ports.   I now almost exclusively power usb peripherals with a inline power supply/isolator  when using anything like a wireless dongle like zigbee or zwave since these have fairly significant RF amplifiers that have high power consumption peaks.   Running something lik an SSD off the usb ports was also painfully unreliable for me.
I have a H20 RK3228 box coming in today so I'll soon be able to experience how bad these are first hand.
vor 3 Stunden schrieb Benedito Portela:
but in backround also many other parameter change not only the LED (led-config is a old name because before it only change some led things , but nowaday many more are change like eth speed , wlan enable pin  etc)
GPIO is more a generale name for some Outputs of the tv box , there a still many thing thats parmater by gpio like wlan on/off or correct eth speed
example ( port AO pin 1and 2 ) are gpio and can configure to be i2a for SPDIF , also AO 2 has be configure as Clock and with a parameter of  speed , also some Ports need a specific voltage
i saw
[    2.058384] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup
[    2.058400] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed
[    2.059143] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable
[    2.059166] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup
[    2.059182] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]'
[    2.059197] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]'
in your log and maybe some missconfigure of GPIOS maybe some LED-Config could help
vor 1 Stunde schrieb Benedito Portela:
RaptorSDS, in this board, the rk3228-config have three configure screen, Chipset, Storage and Leds, it don't recognize wifi!  In R329Q, have the wifi! I tested both led setup, just leds change!
like i sad befor led are a old word it change some more
jock explain :
https://forum.armbian.com/topic/12656-csc-armbian-for-rk322x-tv-boxes/?do=findComment&comment=163046
what do you mean recognize wifi ? complete empty SDIO device or a wifi with unknow id like 024c:D724 ( RTL8723DS , because i solder it myself  and no one else has this chip inside a rk322x box, so its not recognice automaticly )
Is wifi another problem ?  i thing that HDMI was your problem ?
RaptorSDS, I don't need wifi! When exit of rk3228-config, it show this menseger: " Device tree overlays enabled: emmc led-conf1
Wifi chip 02d0:4334 has been detected, but currently it is unsupported "! I saw the post and didn't know of Led and WiFi relation, is did good know thank you!
I received my "H20" RK3228A tv box today.   Here are some board pictures and boot logs of multitool-2.  HDMI display out for multitool-2 only seems to work *after* I restart the tv box from android recovery.   If I cold start it, it appears to boot normally according to the logs, but without an active HDMI output.
This is the first time I've seen this board, it is similar to the H20 V1.5 board with the blue solder mask, but this one is V1.71 and has green solder mask and a different WIFI chip.  The WIFI from an unknown IC manufacturer with part number S9082H.  If someone recognizes the logo let us know who that is.
Link to the backed up EMMC via multitool if you want to look at how android is setting up HDMI.  https://file.io/sKaMNtcEbTie
Link to back up from RKDUMP  https://file.io/cwN4jYBlPLOX
The complete board name is H20_221_v1.71_230617
Pictures here:
Top of the boardBottom of the boardWIFI chip
This is the UART log when booting multitool-2 sdcard from a cold start.
q▒▒▒▒GVN^▒▒OwG▒FF▒'fNF▒_▒
U-Boot 2022.04-armbian (Mar 05 2023 - 18:36:47 +0000)
Model: Generic Rockchip rk322x TV Box board
DRAM:  1.5 GiB
Core:  98 devices, 19 uclasses, devicetree: separate
MMC:   dwmmc@30000000: 1, dwmmc@30020000: 0
Loading Environment from EXT4...
** Unable to use mmc 0:auto for loading the env **
In:    serial@11030000
starting USB...
Bus usb@30040000: USB DWC2
Bus usb@30080000: USB EHCI 1.00
Bus usb@300c0000: USB EHCI 1.00
Bus usb@30100000: USB EHCI 1.00
scanning bus usb@30040000 for devices... 1 USB Device(s) found
scanning bus usb@30080000 for devices... 1 USB Device(s) found
scanning bus usb@300c0000 for devices... 1 USB Device(s) found
scanning bus usb@30100000 for devices... 1 USB Device(s) found
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
1:      Multitool
Retrieving file: /kernel.img
append: boot=UUID=0963-7740 root=PARTUUID=f60a9c52-02 rootwait console=ttyS2,115200 verbose=1 consoleblank=0
Retrieving file: /rk322x-box.dtb
Kernel image @ 0x62000000 [ 0x000000 - 0x850ba8 ]
## Flattened Device Tree blob at 61f00000
   Booting using the fdt blob at 0x61f00000
EHCI failed to shut down host controller.
   Using Device Tree in place at 61f00000, end 61f0e679
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.194-rk322x (root@armbianbuild) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #47 SMP Thu Apr 9 17:37:46 UTC 2020
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Generic RK322x TV Box board
[    0.000000] cma: Reserved 128 MiB at 0xb8000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv65535.65535 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 14 pages/cpu @ef217000 s24856 r8192 d24296 u57344
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 387328
[    0.000000] Kernel command line: boot=UUID=0963-7740 root=PARTUUID=f60a9c52-02 rootwait console=ttyS2,115200 verbose=1 consoleblank=0
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1391624K/1558528K available (12820K kernel code, 875K rwdata, 3224K rodata, 796K init, 1219K bss, 35832K reserved, 131072K cma-reserved, 393216K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xb0000000 - 0xf0000000   (1024 MB)
[    0.000000]     pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
[    0.000000]     modules : 0xaf000000 - 0xafe00000   (  14 MB)
[    0.000000]       .text : 0xb0008000 - 0xb0c8d53c   (12822 kB)
[    0.000000]       .init : 0xb10a1000 - 0xb1168000   ( 796 kB)
[    0.000000]       .data : 0xb1168000 - 0xb1242e94   ( 876 kB)
[    0.000000]        .bss : 0xb1244000 - 0xb1374ee4   (1220 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000025] Switching to timer-based delay loop, resolution 41ns
[    0.001740] Console: colour dummy device 80x30
[    0.001787] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001808] pid_max: default: 32768 minimum: 301
[    0.001957] Security Framework initialized
[    0.001973] Yama: becoming mindful.
[    0.002062] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002079] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003103] Initializing cgroup subsys io
[    0.003148] Initializing cgroup subsys memory
[    0.003200] Initializing cgroup subsys devices
[    0.003222] Initializing cgroup subsys freezer
[    0.003242] Initializing cgroup subsys net_cls
[    0.003261] Initializing cgroup subsys perf_event
[    0.003279] Initializing cgroup subsys net_prio
[    0.003313] Initializing cgroup subsys pids
[    0.003396] CPU: Testing write buffer coherency: ok
[    0.003453] ftrace: allocating 41720 entries in 123 pages
[    0.086557] /cpus/cpu@f00 missing clock-frequency property
[    0.086598] /cpus/cpu@f01 missing clock-frequency property
[    0.086617] /cpus/cpu@f02 missing clock-frequency property
[    0.086637] /cpus/cpu@f03 missing clock-frequency property
[    0.086650] CPU0: update cpu_capacity 430
[    0.086662] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.086762] Setting up static identity map for 0x60008280 - 0x600082d8
[    0.090141] CPU1: update cpu_capacity 430
[    0.090151] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.091434] CPU2: update cpu_capacity 430
[    0.091443] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.092699] CPU3: update cpu_capacity 430
[    0.092708] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.092871] Brought up 4 CPUs
[    0.092913] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.092921] CPU: All CPU(s) started in SVC mode.
[    0.094724] devtmpfs: initialized
[    0.112946] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.113539] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.113586] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.120246] xor: measuring software checksum speed
[    0.158524]    arm4regs  :  1011.000 MB/sec
[    0.198630]    8regs     :   705.000 MB/sec
[    0.238733]    32regs    :   684.000 MB/sec
[    0.278839]    neon      :  1018.000 MB/sec
[    0.278850] xor: using function: neon (1018.000 MB/sec)
[    0.278898] pinctrl core: initialized pinctrl subsystem
[    0.280726] NET: Registered protocol family 16
[    0.283609] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.295043] cpuidle: using governor ladder
[    0.307052] cpuidle: using governor menu
[    0.330329] console [pstore-1] enabled
[    0.330343] pstore: Registered ramoops as persistent store backend
[    0.330356] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0
[    0.333364] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.333390] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.432236] raid6: int32x1  gen()   133 MB/s
[    0.500243] raid6: int32x1  xor()   131 MB/s
[    0.568459] raid6: int32x2  gen()   166 MB/s
[    0.636527] raid6: int32x2  xor()   136 MB/s
[    0.704906] raid6: int32x4  gen()   163 MB/s
[    0.773170] raid6: int32x4  xor()   137 MB/s
[    0.841336] raid6: int32x8  gen()   166 MB/s
[    0.909600] raid6: int32x8  xor()   113 MB/s
[    0.977603] raid6: neonx1   gen()   381 MB/s
[    1.045872] raid6: neonx1   xor()   290 MB/s
[    1.114119] raid6: neonx2   gen()   519 MB/s
[    1.182269] raid6: neonx2   xor()   376 MB/s
[    1.250563] raid6: neonx4   gen()   581 MB/s
[    1.318739] raid6: neonx4   xor()   400 MB/s
[    1.387026] raid6: neonx8   gen()   559 MB/s
[    1.455233] raid6: neonx8   xor()   391 MB/s
[    1.455248] raid6: using algorithm neonx4 gen() 581 MB/s
[    1.455258] raid6: .... xor() 400 MB/s, rmw enabled
[    1.455269] raid6: using intx1 recovery algorithm
[    1.456396] rockchip-pm rockchip-suspend: not set wakeup-config
[    1.456422] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.460351] iommu: Adding device 20020000.vpu-service to group 0
[    1.460465] iommu: Adding device 20030000.rkvdec to group 1
[    1.460559] iommu: Adding device 20050000.vop to group 2
[    1.460653] iommu: Adding device 20070000.iep to group 3
[    1.461277] rk_iommu 20020800.iommu: can't get sclk
[    1.462014] rk_iommu 20030480.iommu: can't get sclk
[    1.462280] rk_iommu 20053f00.iommu: can't get sclk
[    1.462433] rk_iommu 20070800.iommu: can't get aclk
[    1.462453] rk_iommu 20070800.iommu: can't get hclk
[    1.462470] rk_iommu 20070800.iommu: can't get sclk
[    1.463436] SCSI subsystem initialized
[    1.463868] usbcore: registered new interface driver usbfs
[    1.463972] usbcore: registered new interface driver hub
[    1.464135] usbcore: registered new device driver usb
[    1.464360] media: Linux media interface: v0.10
[    1.464443] Linux video capture interface: v2.00
[    1.464656] pps_core: LinuxPPS API ver. 1 registered
[    1.464672] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.464713] PTP clock support registered
[    1.466850] Advanced Linux Sound Architecture Driver Initialized.
[    1.468114] Bluetooth: Core ver 2.21
[    1.468198] NET: Registered protocol family 31
[    1.468212] Bluetooth: HCI device and connection manager initialized
[    1.468236] Bluetooth: HCI socket layer initialized
[    1.468254] Bluetooth: L2CAP socket layer initialized
[    1.468320] Bluetooth: SCO socket layer initialized
[    1.469306] NetLabel: Initializing
[    1.469332] NetLabel:  domain hash size = 128
[    1.469341] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.469429] NetLabel:  unlabeled traffic allowed by default
[    1.470623] clocksource: Switched to clocksource arch_sys_counter
[    1.573408] NET: Registered protocol family 2
[    1.574413] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.574537] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    1.575009] TCP: Hash tables configured (established 8192 bind 8192)
[    1.575153] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    1.575226] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    1.575639] NET: Registered protocol family 1
[    1.576495] RPC: Registered named UNIX socket transport module.
[    1.576523] RPC: Registered udp transport module.
[    1.576534] RPC: Registered tcp transport module.
[    1.576545] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.577579] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.580859] Initialise system trusted keyring
[    1.595707] VFS: Disk quotas dquot_6.6.0
[    1.596043] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.598961] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.602715] NFS: Registering the id_resolver key type
[    1.602813] Key type id_resolver registered
[    1.602826] Key type id_legacy registered
[    1.602862] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.602967] ntfs: driver 2.1.32 [Flags: R/W].
[    1.603947] JFS: nTxBlock = 8192, nTxLock = 65536
[    1.616987] SGI XFS with security attributes, no debug enabled
[    1.626886] NET: Registered protocol family 38
[    1.626954] Key type asymmetric registered
[    1.626976] Asymmetric key parser 'x509' registered
[    1.627116] bounce: pool size: 64 pages
[    1.627518] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.627999] io scheduler noop registered
[    1.628033] io scheduler deadline registered
[    1.628159] io scheduler cfq registered (default)
[    1.631871] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator
[    1.637567] rk-vcodec 20020000.vpu-service: no regulator for vcodec
[    1.638104] rk-vcodec 20020000.vpu-service: probe device
[    1.638711] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled
[    1.640235] rk-vcodec 20020000.vpu-service: could not find power_model node
[    1.640265] rk-vcodec 20020000.vpu-service: init success
[    1.640804] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry
[    1.645126] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330
[    1.645158] dma-pl330 110f0000.pdma:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.646390] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    1.649087] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.650024] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A
[    2.685740] console [ttyS2] enabled
[    2.691350] [drm] Initialized drm 1.1.0 20060810
[    2.698667] [drm] Rockchip DRM driver version: v1.0.1
[    2.704043] rockchip-drm display-subsystem: devfreq is not set
[    2.710829] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d111b0)
[    2.718679] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports
[    2.725344] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.733234] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy)
[    2.744377] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d09708)
[    2.751894] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.758538] [drm] No driver support for vblank timestamp query.
[    2.764619] rockchip-drm display-subsystem: failed to parse display resources
[    3.395112] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1200p60, type: 11
[    3.395959] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    3.395967] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    3.395975] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    3.395982] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    3.395989] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: No Data
[    3.395995] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    3.396002] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    3.396009] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    3.396015] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    3.396022] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    3.396028] dwhdmi-rockchip 200a0000.hdmi:     video code: 0
[    3.396035] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    3.396042] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    3.396048] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    3.396056] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    3.481801] Console: switching to colour frame buffer device 240x75
[    3.666440] rockchip-drm display-subsystem: fb0:  frame buffer device
[    3.691955] brd: module loaded
[    3.710152] loop: module loaded
[    3.713532] lkdtm: No crash points registered, enable through debugfs
[    3.723598] libphy: Fixed MDIO Bus: probed
[    3.727837] tun: Universal TUN/TAP device driver, 1.6
[    3.732934] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    3.739684] CAN device driver interface
[    3.745572] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output).
[    3.752802] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30).
[    3.758500] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10).
[    3.764243] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes).
[    3.770734] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed
[    3.782809] rk_gmac-dwmac 30200000.ethernet: init for RMII
[    3.822790] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    3.827906]  Ring mode enabled
[    3.830999]  DMA HW capability register supported
[    3.835549]  Normal descriptors
[    3.838900]  RX Checksum Offload Engine supported (type 2)
[    3.844401]  TX Checksum insertion supported
[    3.848688]  Wake-Up On Lan supported
[    3.852520] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: da:98:3a:02:23:96
[    3.861001] eth%d: device MAC address da:98:3a:02:23:96
[    3.866249]  Enable RX Mitigation via HW Watchdog Timer
[    3.893225] libphy: stmmac: probed
[    3.896746] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active
[    3.903243] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[    3.909109] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[    3.914971] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
[    3.920830] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
[    3.926681] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
[    3.932538] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
[    3.938391] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[    3.944248] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[    3.950102] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
[    3.955958] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
[    3.961900] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[    3.967843] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[    3.973778] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[    3.979714] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e)
[    3.985651] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
[    3.991588] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[    3.997526] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[    4.003465] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[    4.009403] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[    4.015377] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14)
[    4.021330] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[    4.027281] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[    4.033236] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[    4.039183] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[    4.045128] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
[    4.051075] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
[    4.057016] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
[    4.062953] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[    4.068898] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[    4.074837] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[    4.080779] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
[    4.088705] PPP generic driver version 2.4.2
[    4.093697] Atmel at76x USB Wireless LAN Driver 0.17 loading
[    4.099699] usbcore: registered new interface driver at76c50x-usb
[    4.106115] usbcore: registered new interface driver rtl8187
[    4.111977] usbcore: registered new interface driver rndis_wlan
[    4.118082] usbcore: registered new interface driver zd1201
[    4.124276] usbcore: registered new interface driver rt2800usb
[    4.130401] Rockchip WiFi SYS interface (V1.00) ...
[    4.135526] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    4.143090] usbcore: registered new interface driver pegasus
[    4.148907] usbcore: registered new interface driver rtl8150
[    4.154711] usbcore: registered new interface driver r8152
[    4.160346] usbcore: registered new interface driver asix
[    4.165897] usbcore: registered new interface driver ax88179_178a
[    4.172124] usbcore: registered new interface driver cdc_ether
[    4.178102] usbcore: registered new interface driver dm9601
[    4.183845] usbcore: registered new interface driver smsc75xx
[    4.189736] usbcore: registered new interface driver smsc95xx
[    4.195606] usbcore: registered new interface driver net1080
[    4.201383] usbcore: registered new interface driver rndis_host
[    4.207442] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    4.215079] usbcore: registered new interface driver cdc_ncm
[    4.220878] usbcore: registered new interface driver cdc_mbim
[    4.227416] 30040000.usb supply vusb_d not found, using dummy regulator
[    4.234264] 30040000.usb supply vusb_a not found, using dummy regulator
[    4.254756] dwc2 30040000.usb: DWC OTG Controller
[    4.259586] dwc2 30040000.usb: new USB bus registered, assigned bus number 1
[    4.266749] dwc2 30040000.usb: irq 49, io mem 0x30040000
[    4.272559] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.279415] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.286673] usb usb1: Product: DWC OTG Controller
[    4.291404] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg
[    4.297687] usb usb1: SerialNumber: 30040000.usb
[    4.303793] hub 1-0:1.0: USB hub found
[    4.307742] hub 1-0:1.0: 1 port detected
[    4.313710] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.320362] ehci-platform: EHCI generic platform driver
[    4.328496] ehci-platform 30080000.usb: EHCI Host Controller
[    4.334870] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2
[    4.343249] ehci-platform 30080000.usb: irq 50, io mem 0x30080000
[    4.358728] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00
[    4.365394] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    4.372260] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.379515] usb usb2: Product: EHCI Host Controller
[    4.384424] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    4.390544] usb usb2: SerialNumber: 30080000.usb
[    4.396451] hub 2-0:1.0: USB hub found
[    4.400406] hub 2-0:1.0: 1 port detected
[    4.407648] ehci-platform 300c0000.usb: EHCI Host Controller
[    4.414142] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3
[    4.422520] ehci-platform 300c0000.usb: irq 52, io mem 0x300c0000
[    4.438709] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00
[    4.445317] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    4.452167] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.459427] usb usb3: Product: EHCI Host Controller
[    4.464328] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    4.470441] usb usb3: SerialNumber: 300c0000.usb
[    4.476363] hub 3-0:1.0: USB hub found
[    4.480256] hub 3-0:1.0: 1 port detected
[    4.487520] ehci-platform 30100000.usb: EHCI Host Controller
[    4.493808] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4
[    4.502207] ehci-platform 30100000.usb: irq 54, io mem 0x30100000
[    4.518713] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00
[    4.525317] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    4.532173] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.539426] usb usb4: Product: EHCI Host Controller
[    4.544336] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    4.550447] usb usb4: SerialNumber: 30100000.usb
[    4.556363] hub 4-0:1.0: USB hub found
[    4.560311] hub 4-0:1.0: 1 port detected
[    4.565319] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.571650] ohci-platform: OHCI generic platform driver
[    4.577624] ohci-platform 300a0000.usb: Generic Platform OHCI controller
[    4.585259] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5
[    4.593648] ohci-platform 300a0000.usb: irq 51, io mem 0x300a0000
[    4.659072] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    4.665953] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.673224] usb usb5: Product: Generic Platform OHCI controller
[    4.679182] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    4.685310] usb usb5: SerialNumber: 300a0000.usb
[    4.691511] hub 5-0:1.0: USB hub found
[    4.695457] hub 5-0:1.0: 1 port detected
[    4.700592] ohci-platform 300e0000.usb: Generic Platform OHCI controller
[    4.707905] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6
[    4.716240] ohci-platform 300e0000.usb: irq 53, io mem 0x300e0000
[    4.779084] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    4.785950] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.793238] usb usb6: Product: Generic Platform OHCI controller
[    4.799197] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    4.805326] usb usb6: SerialNumber: 300e0000.usb
[    4.812100] hub 6-0:1.0: USB hub found
[    4.816055] hub 6-0:1.0: 1 port detected
[    4.821204] ohci-platform 30120000.usb: Generic Platform OHCI controller
[    4.828565] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7
[    4.836869] ohci-platform 30120000.usb: irq 55, io mem 0x30120000
[    4.903016] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    4.909874] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.917129] usb usb7: Product: Generic Platform OHCI controller
[    4.923099] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    4.929225] usb usb7: SerialNumber: 30120000.usb
[    4.935654] hub 7-0:1.0: USB hub found
[    4.939615] hub 7-0:1.0: 1 port detected
[    4.944853] usbcore: registered new interface driver cdc_acm
[    4.950647] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.958931] usbcore: registered new interface driver cdc_wdm
[    4.964987] usbcore: registered new interface driver usb-storage
[    4.971309] usbcore: registered new interface driver usbserial
[    4.977294] usbcore: registered new interface driver usbserial_generic
[    4.983932] usbserial: USB Serial support registered for generic
[    4.990088] usbcore: registered new interface driver keyspan
[    4.995850] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    5.003768] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    5.011157] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    5.018549] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    5.026030] usbcore: registered new interface driver option
[    5.031699] usbserial: USB Serial support registered for GSM modem (1-port)
[    5.039452] usbcore: registered new interface driver oti6858
[    5.045492] usbserial: USB Serial support registered for oti6858
[    5.051706] usbcore: registered new interface driver qcserial
[    5.057565] usbserial: USB Serial support registered for Qualcomm USB modem
[    5.064728] usbcore: registered new interface driver sierra
[    5.070399] usbserial: USB Serial support registered for Sierra USB modem
[    5.078550] usbcore: registered new interface driver iforce
[    5.084419] usbcore: registered new interface driver xpad
[    5.090185] usbcore: registered new interface driver usbtouchscreen
[    5.097962] i2c /dev entries driver
[    5.105006] usbcore: registered new interface driver uvcvideo
[    5.110838] USB Video Class driver (1.1.1)
[    5.117393] Boot mode: normal
[    5.122345] rockchip-thermal 11150000.tsadc: tsadc is probed successfully!
[    5.131549] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    5.140807] Bluetooth: Virtual HCI driver ver 1.5
[    5.146315] Bluetooth: HCI UART driver ver 2.3
[    5.150865] Bluetooth: HCI UART protocol H4 registered
[    5.156076] Bluetooth: HCI UART protocol LL registered
[    5.161286] Bluetooth: HCI UART protocol ATH3K registered
[    5.166733] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    5.173488] Bluetooth: HCI UART protocol BCM registered
[    5.179150] usbcore: registered new interface driver bfusb
[    5.184876] usbcore: registered new interface driver btusb
[    5.190419] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    5.197018] cpu cpu0: leakage=4
[    5.200288] cpu cpu0: leakage-volt-sel=0
[    5.204639] cpu cpu0: Failed to get pvtm
[    5.210921] cpu cpu0: avs=0
[    5.213820] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    5.220940] cpu cpu0: failed to read out thermal zone (-22)
[    5.227677] cpu cpu0: failed to find power_model node
[    5.233951] Synopsys Designware Multimedia Card Interface Driver
[    5.241060] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode.
[    5.248538] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller.
[    5.255394] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a
[    5.261272] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    5.271155] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found
[    5.277381] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found
[    5.283852] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO
[    5.302414] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    5.314678] usb 7-1: new low-speed USB device number 2 using ohci-platform
[    5.324857] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized
[    5.331461] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available
[    5.340904] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode.
[    5.348432] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller.
[    5.355324] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a
[    5.361248] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    5.371238] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found
[    5.377511] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found
[    5.396959] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[    5.419422] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized
[    5.425945] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode.
[    5.433724] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller.
[    5.440663] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a
[    5.446730] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo
[    5.456698] dwmmc_rockchip 30020000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    5.465053] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found
[    5.471318] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found
[    5.490963] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[    5.504282] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    5.514207] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    5.519012] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized
[    5.520731] ledtrig-cpu: registered to indicate activity on CPUs
[    5.520877] hidraw: raw HID events driver (C) Jiri Kosina
[    5.521651] usbcore: registered new interface driver usbhid
[    5.521657] usbhid: USB HID core driver
[    5.522258] ashmem: initialized
[    5.525104] rknandbase v1.2 2018-05-08
[    5.525587] rknand 30030000.nandc: rknand_probe clk rate = 150000000
[    5.525928] ftl_init fffffffe
[    5.525931] rk_ftl_init fail
[    5.527582] usbcore: registered new interface driver snd-usb-audio
[    5.527741] usbcore: registered new interface driver snd-ua101
[    5.527874] usbcore: registered new interface driver snd-usb-caiaq
[    5.527995] usbcore: registered new interface driver snd-usb-6fire
[    5.528115] usbcore: registered new interface driver snd-usb-hiface
[    5.528211] usbcore: registered new interface driver snd-bcd2000
[    5.528322] usbcore: registered new interface driver snd_usb_pod
[    5.528410] usbcore: registered new interface driver snd_usb_podhd
[    5.528519] usbcore: registered new interface driver snd_usb_toneport
[    5.528615] usbcore: registered new interface driver snd_usb_variax
[    5.536008] u32 classifier
[    5.536016]     input device check on
[    5.536017]     Actions configured
[    5.536032] Netfilter messages via NETLINK v0.30.
[    5.536060] nfnl_acct: registering with nfnetlink.
[    5.536185] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    5.537530] Initializing XFRM netlink socket
[    5.538879] NET: Registered protocol family 10
[    5.541029] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    5.541459] sit: IPv6 over IPv4 tunneling driver
[    5.543257] NET: Registered protocol family 17
[    5.543316] NET: Registered protocol family 15
[    5.543527] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    5.543592] Bridge firewalling registered
[    5.543600] can: controller area network core (rev 20120528 abi 9)
[    5.543707] NET: Registered protocol family 29
[    5.543726] can: raw protocol (rev 20120528)
[    5.543736] can: broadcast manager protocol (rev 20120528 t)
[    5.543774] can: netlink gateway (rev 20130117) max_hops=1
[    5.544420] Bluetooth: RFCOMM TTY layer initialized
[    5.544449] Bluetooth: RFCOMM socket layer initialized
[    5.544506] Bluetooth: RFCOMM ver 1.11
[    5.544540] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    5.544558] Bluetooth: HIDP socket layer initialized
[    5.544654] 8021q: 802.1Q VLAN Support v1.8
[    5.544702] lib80211: common routines for IEEE802.11 drivers
[    5.544754] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    5.545248] [BT_RFKILL]: Enter rfkill_rk_init
[    5.545557] Key type dns_resolver registered
[    5.546018] flash vendor_init_thread!
[    5.546028] flash vendor storage:20170308 ret = -1
[    5.546145] Error: Driver 'sc031gs' is already registered, aborting...
[    5.546917] Registering SWP/SWPB emulation handler
[    5.548521] registered taskstats version 1
[    5.548542] Loading compiled-in X.509 certificates
[    5.552644] Btrfs loaded
[    5.554457] rga2: Driver loaded successfully ver:4.01
[    5.555483] rga2: Module initialized.
[    5.555526] pvtm list NULL
[    5.560477] rk-vcodec 20030000.rkvdec: leakage=3
[    5.560503] rk-vcodec 20030000.rkvdec: leakage-volt-sel=0
[    5.560654] rk-vcodec 20030000.rkvdec: Failed to get pvtm
[    5.561200] rk-vcodec 20030000.rkvdec: avs=0
[    5.561601] rk-vcodec 20030000.rkvdec: probe device
[    5.562303] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled
[    5.564388] rk-vcodec 20030000.rkvdec: init success
[    5.565751] usb 7-1: New USB device found, idVendor=413c, idProduct=2113
[    5.565762] usb 7-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    5.565771] usb 7-1: Product: Dell KB216 Wired Keyboard
[    5.569015] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok
[    5.573727] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok
[    5.577106] hctosys: unable to open rtc device (rtc0)
[    5.595745] ALSA device list:
[    5.595760]   #0: DW-I2S-HDMI
[    5.595763]   #1: SPDIF
[    5.599807] input: Dell KB216 Wired Keyboard as /devices/platform/30120000.usb/usb7/7-1/7-1:1.0/0003:413C:2113.0001/input/input0
[    5.655934] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-30120000.usb-1/input0
[    5.684076] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    5.684558] input: Dell KB216 Wired Keyboard as /devices/platform/30120000.usb/usb7/7-1/7-1:1.1/0003:413C:2113.0002/input/input1
[    5.743305] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-30120000.usb-1/input1
[    5.808419] mmc2: error -84 whilst initialising MMC card
[    5.969013] ttyS2 - failed to request DMA, use interrupt mode
[    5.969912] mmc1: new high speed SDIO card at address 0001
[    5.970551] mmc0: new high speed SDHC card at address db5c
[    5.971863] mmcblk0: mmc0:db5c SU04G 3.69 GiB
[    5.974493]  mmcblk0: p1 p2
[    6.015067] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
[    6.022685] squashfs: SQUASHFS error: unable to read xattr id index table
[    6.042915] VFS: Mounted root (squashfs filesystem) readonly on device 179:2.
[    6.063920] devtmpfs: mounted
[    6.068391] Freeing unused kernel memory: 796K
[    6.072891] This architecture does not have kernel memory protection.
[    7.800446] random: dropbear: uninitialized urandom read (32 bytes read, 25 bits of entropy available)
Debian GNU/Linux 10 multitool ttyS2
multitool login: root (automatic login)
sh: 1: cannot create /run/motd.dynamic.new: Read-only file system
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
-bash: cannot set terminal process group (-1): Inappropriate ioctl for device
-bash: no job control in this shell
root@multitool:~# [    8.570738] vendor storage:20190527 ret = -1
[    8.721211] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[    9.690492] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Below is the log when android recovery restarts to the "bootloader" while the multitool-2 SD card is inserted.
DRAM:  1.5 GiB
In:    serial@11030000
starting USB...
Scanning mmc 1:1...
1:      Multitool
Starting kernel ...
I haven't done a diff but both look virtually the same.
Edited by occams razor
added link for RKDUMP backup
For the H20_221_v1.71 board I have worked out the uart connections and maskrom enable point.   For maskrom, this is shorting out either the data or clock line.  I have no way to determine which unless I take this thing to the office and look at it on a logic analyzer.  The test points are probably very similar to the v1.5 board with the blue solder mask.
vor 5 Stunden schrieb occams razor:
S9082H
https://forum.armbian.com/topic/12656-csc-armbian-for-rk322x-tv-boxes/page/58/#comment-158957
https://forum.armbian.com/topic/12656-csc-armbian-for-rk322x-tv-boxes/page/57/#comment-156548
there is a S9082C from SCL  , its a clone of some wifi rtl chips , its closse source , no linux support
its looks your is the next one S9082H from another SCL copy distributor
Edited by RaptorSDS
Probably your board is misconfigured with led-conf1, which are chiptrip brands.
The two r329q boards should go with led-conf2 (rk322x-config tells you which led-conf to use with which board):
The last board, which is unknown yet, perhaps may benefit from led-conf7 (R29), but your mileage may vary.
Anyway, getting wifi properly detected with the right led-conf:
1) helps us to put your board in the list
2) prevents possible malfunction of other hardware
If you pay attention (and please do!) to the Important paragraph in the above screen, it is clearly stated what is the purpose of the led/gpio configurations and what are the benefits of selecting the right one.
As @RaptorSDS said, your wifi chip is a broadcom 4334, but there are several variants around so perhaps the driver is not able to correctly make it work; anyway if you get the ID of the chip in rk322x-config (as you already do), then you should be ok with the led/gpio configuration
Hi Joke, the rk3228-config in this version, don't have the important paragraph and just two options, a guess because, i use the Armbian 21.02.1 Debian Buster Legacy 4.4.194! The chip is a 339S0205, wifi iphone 5 module, maybe reused from scrap!
vor 38 Minuten schrieb occams razor:
Do any of you know of an easy way to mount a raw android flash image in Windows?   I would like to look at the emmc multitool backup image.  Thanks.
i  know 3 ways
first sometimes 7zip can read img and iso
secound tools like ext4win or somthing but than the img / iso has to be mound as CD-ROM or with windows tools as HDD like a wim or vhd
third use of Windows Subsystem for Linux , install Debian or Ubuntu and use linux with all its tools
