Maybe you must install armbianmonitor (armbianmonitor -r if i remember it right) oraz just type armbianmonitor or armbianmonitor -h (it should display help)
Wysłane z mojego 2014811 przy użyciu Tapatalka
5 minutes ago, tristan said:
I've got the most recent image build linked from the nanopi neo 2 wiki, so I'm not sure what the issue is. http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO2#Make_an_Installation_TF_Card
Then you are not using the Armbian image. armbianmonitor is Armbian specific and we can control only our kernel configuration, so we can't help with changing FriendlyARM/FriendlyELEC kernel config.
Well, obviously you're not using Armbian what would explain the lack of both driver and the armbianmonitor command but not why you ask for support in Armbian forum?
Ohhhh. I thought the friendlyelec images was the armbian image... I'll try the actual armbian image and see if my problems vanish. Thanks!
Nope. I wasted some of my time trying to convince them to base their work on Armbian's build system but to no avail. Weidong decided to better fork mainline kernel, focus on 4.11 and rely on 'port and forget' coding style: http://wiki.friendlyarm.com/wiki/index.php/Mainline_U-boot_%26_Linux/zh
And their current OS images for NanoPi Neo 2 are based on crappy Allwinner BSP anyway :(  (BSP is the code name for 'ugly build scripts combined with horribly outdated and totally insecure kernel sources')
Got my Neo2, playing some early tests. The plastic enclosure is unfortunately useless: it's 3D printed, and it doesn't fixate the heatsink. Also I broke the enclosure while trying to insert the board. Fresh Armbian booted fine, and with a WiFi dongle, it's much more stable than OPI0 (OPI0 hanging up after less than an hour).
What I noticed, is that it doesn't come up after a reboot, and needs a power cycle.
here I wrote a short summary: https://txlab.wordpress.com/2017/04/16/friendlyelec-nanopi-neo2-a-better-sub-20-linux-computer/
Please be careful with such (wrong) conclusions, better try not to do 'reviews' based on nightly images and also try to be a bit more precise when you post about stuff (for OPi Zero you mixed legacy and mainline kernel and again: nightly images are for testing and reporting back in a constructive way to developers and distro maintainers and not for productive use or even basing 'reviews' on it).
I used my OPi Zero for days with a Ralink dongle in 5Ghz band and of course everything worked perfectly (using legacy kernel, my last tries with nightly builds weren't that great). Why should Linux fail with such a setup? It's either crappy drivers or what's more likely: power or SD card issues (and using 'same cables' doesn't help here since contact resistance might be different and consumption behaviour due to different settings).
Unfortunately all those small boards use Micro USB for powering but they also allow to be powered through GPIO pins which is the first thing that should be done in case 'stability' seems to be a problem (for obvious reasons!).
I'm just testing NANOPI NEO2 use as firewall/jumpstation. Network performance of Nanopi Neo2 with latest nightly Armbian is very pleasing.
Testing setup :
- NEO2, SDcard SANDISK 8Gb/Class10, RT8188EU Wifi-Dongle on USB-port, powered via MicroUSB from 5v/3A IKEA charger
- NEO2, SDcard SANDISK 8Gb/Class10, RT8153 GLAN-Dongle on USB-port, powered via 5V/GND UART-connector from 5v/3A IKEA charger
- Direct GLAN-link between NEOs
- Uplink to EXTERNAL GLAN via rt8153
- Uplink to WLAN Router via RT8188EU .
Results :
Direct link NEO2 to NEO2 via onboard RJ45  ( simulating 10 concurrent connections on GLAN ).
pi@neo2_182:~$ iperf3 -c 192.168.3.181 -P10;
Connecting to host 192.168.3.181, port 5201
[  4] local 192.168.3.182 port 45378 connected to 192.168.3.181 port 5201
[  6] local 192.168.3.182 port 45380 connected to 192.168.3.181 port 5201
[  8] local 192.168.3.182 port 45382 connected to 192.168.3.181 port 5201
[ 10] local 192.168.3.182 port 45384 connected to 192.168.3.181 port 5201
[ 12] local 192.168.3.182 port 45386 connected to 192.168.3.181 port 5201
[ 14] local 192.168.3.182 port 45388 connected to 192.168.3.181 port 5201
[ 16] local 192.168.3.182 port 45390 connected to 192.168.3.181 port 5201
[ 18] local 192.168.3.182 port 45392 connected to 192.168.3.181 port 5201
[ 20] local 192.168.3.182 port 45394 connected to 192.168.3.181 port 5201
[ 22] local 192.168.3.182 port 45396 connected to 192.168.3.181 port 5201
[ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
[  4]   0.00-1.00   sec  12.3 MBytes   103 Mbits/sec    0    167 KBytes
[  6]   0.00-1.00   sec  7.77 MBytes  65.2 Mbits/sec    0    124 KBytes
[  8]   0.00-1.00   sec  9.94 MBytes  83.4 Mbits/sec    0    165 KBytes
[ 10]   0.00-1.00   sec  10.8 MBytes  90.5 Mbits/sec    0    180 KBytes
[ 12]   0.00-1.00   sec  8.05 MBytes  67.5 Mbits/sec    0    129 KBytes
[ 14]   0.00-1.00   sec  14.5 MBytes   121 Mbits/sec    0    192 KBytes
[ 16]   0.00-1.00   sec  12.6 MBytes   106 Mbits/sec    0    184 KBytes
[ 18]   0.00-1.00   sec  9.75 MBytes  81.8 Mbits/sec    0    158 KBytes
[ 20]   0.00-1.00   sec  14.6 MBytes   122 Mbits/sec    0    194 KBytes
[ 22]   0.00-1.00   sec  12.5 MBytes   105 Mbits/sec    0    185 KBytes
[SUM]   0.00-1.00   sec   113 MBytes   945 Mbits/sec    0
[  4]   1.00-2.00   sec  10.9 MBytes  91.7 Mbits/sec    0    252 KBytes
[  6]   1.00-2.00   sec  10.9 MBytes  91.7 Mbits/sec    0    212 KBytes
[  8]   1.00-2.00   sec  10.9 MBytes  91.7 Mbits/sec    0    255 KBytes
[ 10]   1.00-2.00   sec  10.9 MBytes  91.2 Mbits/sec    0    249 KBytes
[ 12]   1.00-2.00   sec  11.2 MBytes  94.4 Mbits/sec    0    235 KBytes
[ 14]   1.00-2.00   sec  11.1 MBytes  92.8 Mbits/sec    0    247 KBytes
[ 16]   1.00-2.00   sec  10.6 MBytes  88.6 Mbits/sec    0    250 KBytes
[ 18]   1.00-2.00   sec  10.8 MBytes  90.7 Mbits/sec    0    238 KBytes
[ 20]   1.00-2.00   sec  10.3 MBytes  86.5 Mbits/sec    0    235 KBytes
[ 22]   1.00-2.00   sec  10.3 MBytes  86.5 Mbits/sec    0    233 KBytes
[SUM]   1.00-2.00   sec   108 MBytes   906 Mbits/sec    0
[  4]   2.00-3.00   sec  10.9 MBytes  91.7 Mbits/sec    0    252 KBytes
[  6]   2.00-3.00   sec  10.5 MBytes  88.1 Mbits/sec    0    212 KBytes
[  8]   2.00-3.00   sec  10.5 MBytes  88.1 Mbits/sec    0    255 KBytes
[ 10]   2.00-3.00   sec  10.6 MBytes  89.1 Mbits/sec    0    249 KBytes
[ 12]   2.00-3.00   sec  10.3 MBytes  86.0 Mbits/sec    0    235 KBytes
[ 14]   2.00-3.00   sec  10.5 MBytes  88.1 Mbits/sec    0    247 KBytes
[ 16]   2.00-3.00   sec  10.5 MBytes  88.1 Mbits/sec    0    250 KBytes
[ 18]   2.00-3.00   sec  10.6 MBytes  88.6 Mbits/sec    0    238 KBytes
[ 20]   2.00-3.00   sec  10.6 MBytes  89.1 Mbits/sec    0    235 KBytes
[ 22]   2.00-3.00   sec  10.9 MBytes  91.2 Mbits/sec    0    233 KBytes
[SUM]   2.00-3.00   sec   106 MBytes   888 Mbits/sec    0
[  4]   3.00-4.00   sec  10.6 MBytes  89.1 Mbits/sec    0    252 KBytes
[  6]   3.00-4.00   sec  10.4 MBytes  87.6 Mbits/sec    0    212 KBytes
[  8]   3.00-4.00   sec  10.7 MBytes  89.7 Mbits/sec    0    255 KBytes
[ 10]   3.00-4.00   sec  10.9 MBytes  91.7 Mbits/sec    0    249 KBytes
[ 12]   3.00-4.00   sec  10.4 MBytes  87.6 Mbits/sec    0    235 KBytes
[ 14]   3.00-4.00   sec  10.4 MBytes  87.1 Mbits/sec    0    247 KBytes
[ 16]   3.00-4.00   sec  10.6 MBytes  88.6 Mbits/sec    0    250 KBytes
[ 18]   3.00-4.00   sec  10.6 MBytes  88.6 Mbits/sec    0    238 KBytes
[ 20]   3.00-4.00   sec  10.9 MBytes  91.7 Mbits/sec    0    235 KBytes
[ 22]   3.00-4.00   sec  10.5 MBytes  88.1 Mbits/sec    0    233 KBytes
[SUM]   3.00-4.00   sec   106 MBytes   890 Mbits/sec    0
[  4]   4.00-5.00   sec  10.1 MBytes  85.0 Mbits/sec    0    252 KBytes
[  6]   4.00-5.00   sec  10.4 MBytes  87.6 Mbits/sec    0    212 KBytes
[  8]   4.00-5.00   sec  10.6 MBytes  89.1 Mbits/sec    0    255 KBytes
[ 10]   4.00-5.00   sec  10.4 MBytes  87.6 Mbits/sec    0    249 KBytes
[ 12]   4.00-5.00   sec  10.9 MBytes  91.7 Mbits/sec    0    235 KBytes
[ 14]   4.00-5.00   sec  10.4 MBytes  87.0 Mbits/sec    0    247 KBytes
[ 16]   4.00-5.00   sec  10.9 MBytes  91.7 Mbits/sec    0    250 KBytes
[ 18]   4.00-5.00   sec  10.9 MBytes  91.7 Mbits/sec    0    238 KBytes
[ 20]   4.00-5.00   sec  10.4 MBytes  87.6 Mbits/sec    0    235 KBytes
[ 22]   4.00-5.00   sec  10.4 MBytes  87.6 Mbits/sec    0    233 KBytes
[SUM]   4.00-5.00   sec   106 MBytes   887 Mbits/sec    0
[  4]   5.00-6.00   sec  10.6 MBytes  89.1 Mbits/sec    0    252 KBytes
[  6]   5.00-6.00   sec  10.9 MBytes  91.8 Mbits/sec    0    212 KBytes
[  8]   5.00-6.00   sec  10.6 MBytes  89.1 Mbits/sec    0    255 KBytes
[ 10]   5.00-6.00   sec  10.4 MBytes  87.6 Mbits/sec    0    249 KBytes
[ 12]   5.00-6.00   sec  10.4 MBytes  87.6 Mbits/sec    0    235 KBytes
[ 14]   5.00-6.00   sec  10.8 MBytes  90.2 Mbits/sec    0    247 KBytes
[ 16]   5.00-6.00   sec  10.4 MBytes  87.6 Mbits/sec    0    250 KBytes
[ 18]   5.00-6.00   sec  10.4 MBytes  87.6 Mbits/sec    0    238 KBytes
[ 20]   5.00-6.00   sec  10.4 MBytes  87.6 Mbits/sec    0    235 KBytes
[ 22]   5.00-6.00   sec  10.4 MBytes  87.6 Mbits/sec    0    233 KBytes
[SUM]   5.00-6.00   sec   106 MBytes   886 Mbits/sec    0
[  4]   6.00-7.00   sec  10.9 MBytes  91.7 Mbits/sec    0    252 KBytes
[  6]   6.00-7.00   sec  10.4 MBytes  87.6 Mbits/sec    0    212 KBytes
[  8]   6.00-7.00   sec  10.6 MBytes  89.1 Mbits/sec    0    255 KBytes
[ 10]   6.00-7.00   sec  10.4 MBytes  87.6 Mbits/sec    0    249 KBytes
[ 12]   6.00-7.00   sec  10.4 MBytes  87.6 Mbits/sec    0    235 KBytes
[ 14]   6.00-7.00   sec  10.7 MBytes  89.7 Mbits/sec    0    247 KBytes
[ 16]   6.00-7.00   sec  10.4 MBytes  87.6 Mbits/sec    0    250 KBytes
[ 18]   6.00-7.00   sec  10.4 MBytes  87.6 Mbits/sec    0    238 KBytes
[ 20]   6.00-7.00   sec  10.4 MBytes  87.6 Mbits/sec    0    235 KBytes
[ 22]   6.00-7.00   sec  10.9 MBytes  91.8 Mbits/sec    0    233 KBytes
[SUM]   6.00-7.00   sec   106 MBytes   888 Mbits/sec    0
[  4]   7.00-8.00   sec  10.4 MBytes  87.5 Mbits/sec    0    252 KBytes
[  6]   7.00-8.00   sec  10.4 MBytes  87.5 Mbits/sec    0    212 KBytes
[  8]   7.00-8.00   sec  10.6 MBytes  89.1 Mbits/sec    0    255 KBytes
[ 10]   7.00-8.00   sec  10.9 MBytes  91.7 Mbits/sec    0    249 KBytes
[ 12]   7.00-8.00   sec  10.4 MBytes  87.5 Mbits/sec    0    235 KBytes
[ 14]   7.00-8.00   sec  10.2 MBytes  85.4 Mbits/sec    0    247 KBytes
[ 16]   7.00-8.00   sec  10.4 MBytes  87.5 Mbits/sec    0    250 KBytes
[ 18]   7.00-8.00   sec  10.4 MBytes  87.5 Mbits/sec    0    238 KBytes
[ 20]   7.00-8.00   sec  10.9 MBytes  91.7 Mbits/sec    0    235 KBytes
[ 22]   7.00-8.00   sec  10.4 MBytes  87.5 Mbits/sec    0    233 KBytes
[SUM]   7.00-8.00   sec   105 MBytes   883 Mbits/sec    0
[  4]   8.00-9.00   sec  10.8 MBytes  90.2 Mbits/sec    0    252 KBytes
[  6]   8.00-9.00   sec  10.4 MBytes  87.6 Mbits/sec    0    212 KBytes
[  8]   8.00-9.00   sec  10.6 MBytes  89.1 Mbits/sec    0    255 KBytes
[ 10]   8.00-9.00   sec  10.4 MBytes  87.6 Mbits/sec    0    249 KBytes
[ 12]   8.00-9.00   sec  10.9 MBytes  91.7 Mbits/sec    0    235 KBytes
[ 14]   8.00-9.00   sec  10.9 MBytes  91.7 Mbits/sec    0    247 KBytes
[ 16]   8.00-9.00   sec  10.9 MBytes  91.7 Mbits/sec    0    250 KBytes
[ 18]   8.00-9.00   sec  10.9 MBytes  91.7 Mbits/sec    0    238 KBytes
[ 20]   8.00-9.00   sec  10.4 MBytes  87.6 Mbits/sec    0    235 KBytes
[ 22]   8.00-9.00   sec  10.4 MBytes  87.6 Mbits/sec    0    233 KBytes
[SUM]   8.00-9.00   sec   107 MBytes   897 Mbits/sec    0
[  4]   9.00-10.00  sec  10.4 MBytes  87.6 Mbits/sec    0    252 KBytes
[  6]   9.00-10.00  sec  10.9 MBytes  91.7 Mbits/sec    0    212 KBytes
[  8]   9.00-10.00  sec  10.6 MBytes  89.1 Mbits/sec    0    255 KBytes
[ 10]   9.00-10.00  sec  10.4 MBytes  87.6 Mbits/sec    0    249 KBytes
[ 12]   9.00-10.00  sec  10.4 MBytes  87.6 Mbits/sec    0    235 KBytes
[ 14]   9.00-10.00  sec  10.4 MBytes  87.0 Mbits/sec    0    247 KBytes
[ 16]   9.00-10.00  sec  10.4 MBytes  87.6 Mbits/sec    0    250 KBytes
[ 18]   9.00-10.00  sec  10.4 MBytes  87.6 Mbits/sec    0    238 KBytes
[ 20]   9.00-10.00  sec  10.4 MBytes  87.6 Mbits/sec    0    235 KBytes
[ 22]   9.00-10.00  sec  10.4 MBytes  87.6 Mbits/sec    0    233 KBytes
[SUM]   9.00-10.00  sec   105 MBytes   881 Mbits/sec    0
[  4]   0.00-10.00  sec   108 MBytes  90.7 Mbits/sec    0             sender
[  4]   0.00-10.00  sec   107 MBytes  89.6 Mbits/sec                  receiver
[  6]   0.00-10.00  sec   103 MBytes  86.6 Mbits/sec    0             sender
[  6]   0.00-10.00  sec   102 MBytes  85.6 Mbits/sec                  receiver
[  8]   0.00-10.00  sec   106 MBytes  88.8 Mbits/sec    0             sender
[  8]   0.00-10.00  sec   104 MBytes  87.6 Mbits/sec                  receiver
[ 10]   0.00-10.00  sec   106 MBytes  89.2 Mbits/sec    0             sender
[ 10]   0.00-10.00  sec   105 MBytes  88.2 Mbits/sec                  receiver
[ 12]   0.00-10.00  sec   104 MBytes  86.9 Mbits/sec    0             sender
[ 12]   0.00-10.00  sec   102 MBytes  86.0 Mbits/sec                  receiver
[ 14]   0.00-10.00  sec   110 MBytes  92.0 Mbits/sec    0             sender
[ 14]   0.00-10.00  sec   109 MBytes  91.1 Mbits/sec                  receiver
[ 16]   0.00-10.00  sec   108 MBytes  90.5 Mbits/sec    0             sender
[ 16]   0.00-10.00  sec   107 MBytes  89.5 Mbits/sec                  receiver
[ 18]   0.00-10.00  sec   105 MBytes  88.3 Mbits/sec    0             sender
[ 18]   0.00-10.00  sec   104 MBytes  87.3 Mbits/sec                  receiver
[ 20]   0.00-10.00  sec   110 MBytes  91.9 Mbits/sec    0             sender
[ 20]   0.00-10.00  sec   109 MBytes  91.0 Mbits/sec                  receiver
[ 22]   0.00-10.00  sec   107 MBytes  90.0 Mbits/sec    0             sender
[ 22]   0.00-10.00  sec   106 MBytes  89.3 Mbits/sec                  receiver
[SUM]   0.00-10.00  sec  1.04 GBytes   895 Mbits/sec    0             sender
[SUM]   0.00-10.00  sec  1.03 GBytes   885 Mbits/sec                  receiver
iperf Done.
Uplink NEO2 via RT8153 USB-LAN Adapter ( simulating 10 concurrent connections on Uplink GLAN ).
rsc@rs026:~$ iperf3 -c 192.168.2.234 -P10
Connecting to host 192.168.2.234, port 5201
[  4] local 192.168.2.26 port 48198 connected to 192.168.2.234 port 5201
[  6] local 192.168.2.26 port 48200 connected to 192.168.2.234 port 5201
[  8] local 192.168.2.26 port 48202 connected to 192.168.2.234 port 5201
[ 10] local 192.168.2.26 port 48204 connected to 192.168.2.234 port 5201
[ 12] local 192.168.2.26 port 48206 connected to 192.168.2.234 port 5201
[ 14] local 192.168.2.26 port 48208 connected to 192.168.2.234 port 5201
[ 16] local 192.168.2.26 port 48210 connected to 192.168.2.234 port 5201
[ 18] local 192.168.2.26 port 48212 connected to 192.168.2.234 port 5201
[ 20] local 192.168.2.26 port 48214 connected to 192.168.2.234 port 5201
[ 22] local 192.168.2.26 port 48216 connected to 192.168.2.234 port 5201
[  4]   0.00-1.00   sec  5.40 MBytes  45.3 Mbits/sec    0   73.5 KBytes
[  6]   0.00-1.00   sec  4.05 MBytes  34.0 Mbits/sec    0   55.1 KBytes
[  8]   0.00-1.00   sec  4.05 MBytes  34.0 Mbits/sec    0   45.2 KBytes
[ 10]   0.00-1.00   sec  4.08 MBytes  34.2 Mbits/sec    0   49.5 KBytes
[ 12]   0.00-1.00   sec  4.05 MBytes  34.0 Mbits/sec    0   49.5 KBytes
[ 14]   0.00-1.00   sec  3.99 MBytes  33.5 Mbits/sec    0   42.4 KBytes
[ 16]   0.00-1.00   sec  4.03 MBytes  33.8 Mbits/sec    0   46.7 KBytes
[ 18]   0.00-1.00   sec  3.90 MBytes  32.7 Mbits/sec    0   41.0 KBytes
[ 20]   0.00-1.00   sec  4.07 MBytes  34.1 Mbits/sec    0   45.2 KBytes
[ 22]   0.00-1.00   sec  3.65 MBytes  30.6 Mbits/sec    1   41.0 KBytes
[SUM]   0.00-1.00   sec  41.3 MBytes   346 Mbits/sec    1
[  4]   1.00-2.00   sec  5.28 MBytes  44.3 Mbits/sec    0   73.5 KBytes
[  6]   1.00-2.00   sec  3.97 MBytes  33.3 Mbits/sec    0   55.1 KBytes
[  8]   1.00-2.00   sec  3.99 MBytes  33.4 Mbits/sec    0   45.2 KBytes
[ 10]   1.00-2.00   sec  4.00 MBytes  33.6 Mbits/sec    0   49.5 KBytes
[ 12]   1.00-2.00   sec  3.97 MBytes  33.3 Mbits/sec    0   49.5 KBytes
[ 14]   1.00-2.00   sec  3.97 MBytes  33.3 Mbits/sec    0   42.4 KBytes
[ 16]   1.00-2.00   sec  3.98 MBytes  33.4 Mbits/sec    0   46.7 KBytes
[ 18]   1.00-2.00   sec  3.70 MBytes  31.0 Mbits/sec    0   41.0 KBytes
[ 20]   1.00-2.00   sec  3.99 MBytes  33.5 Mbits/sec    0   45.2 KBytes
[ 22]   1.00-2.00   sec  3.51 MBytes  29.4 Mbits/sec    0   41.0 KBytes
[SUM]   1.00-2.00   sec  40.4 MBytes   338 Mbits/sec    0
[  4]   2.00-3.00   sec  5.26 MBytes  44.1 Mbits/sec    0   73.5 KBytes
[  6]   2.00-3.00   sec  3.95 MBytes  33.1 Mbits/sec    0   55.1 KBytes
[  8]   2.00-3.00   sec  3.93 MBytes  32.9 Mbits/sec    0   45.2 KBytes
[ 10]   2.00-3.00   sec  3.98 MBytes  33.4 Mbits/sec    0   49.5 KBytes
[ 12]   2.00-3.00   sec  3.94 MBytes  33.1 Mbits/sec    0   49.5 KBytes
[ 14]   2.00-3.00   sec  3.98 MBytes  33.4 Mbits/sec    0   42.4 KBytes
[ 16]   2.00-3.00   sec  3.96 MBytes  33.2 Mbits/sec    0   46.7 KBytes
[ 18]   2.00-3.00   sec  3.79 MBytes  31.8 Mbits/sec    0   41.0 KBytes
[ 20]   2.00-3.00   sec  3.93 MBytes  33.0 Mbits/sec    0   45.2 KBytes
[ 22]   2.00-3.00   sec  3.63 MBytes  30.4 Mbits/sec    0   41.0 KBytes
[SUM]   2.00-3.00   sec  40.3 MBytes   338 Mbits/sec    0
[  4]   3.00-4.00   sec  5.28 MBytes  44.3 Mbits/sec    0   73.5 KBytes
[  6]   3.00-4.00   sec  3.89 MBytes  32.7 Mbits/sec    0   55.1 KBytes
[  8]   3.00-4.00   sec  3.95 MBytes  33.1 Mbits/sec    0   45.2 KBytes
[ 10]   3.00-4.00   sec  3.91 MBytes  32.8 Mbits/sec    0   49.5 KBytes
[ 12]   3.00-4.00   sec  3.95 MBytes  33.1 Mbits/sec    0   49.5 KBytes
[ 14]   3.00-4.00   sec  3.96 MBytes  33.2 Mbits/sec    0   42.4 KBytes
[ 16]   3.00-4.00   sec  3.99 MBytes  33.5 Mbits/sec    0   46.7 KBytes
[ 18]   3.00-4.00   sec  3.82 MBytes  32.0 Mbits/sec    0   41.0 KBytes
[ 20]   3.00-4.00   sec  3.97 MBytes  33.3 Mbits/sec    0   45.2 KBytes
[ 22]   3.00-4.00   sec  3.62 MBytes  30.3 Mbits/sec    0   41.0 KBytes
[SUM]   3.00-4.00   sec  40.3 MBytes   338 Mbits/sec    0
[  4]   4.00-5.00   sec  5.30 MBytes  44.4 Mbits/sec    0   73.5 KBytes
[  6]   4.00-5.00   sec  3.96 MBytes  33.2 Mbits/sec    0   55.1 KBytes
[  8]   4.00-5.00   sec  3.97 MBytes  33.3 Mbits/sec    0   45.2 KBytes
[ 10]   4.00-5.00   sec  3.97 MBytes  33.3 Mbits/sec    0   49.5 KBytes
[ 12]   4.00-5.00   sec  3.95 MBytes  33.1 Mbits/sec    0   49.5 KBytes
[ 14]   4.00-5.00   sec  3.96 MBytes  33.2 Mbits/sec    0   42.4 KBytes
[ 16]   4.00-5.00   sec  3.92 MBytes  32.9 Mbits/sec    0   46.7 KBytes
[ 18]   4.00-5.00   sec  3.87 MBytes  32.5 Mbits/sec    0   41.0 KBytes
[ 20]   4.00-5.00   sec  3.96 MBytes  33.2 Mbits/sec    0   45.2 KBytes
[ 22]   4.00-5.00   sec  3.53 MBytes  29.6 Mbits/sec    0   41.0 KBytes
[SUM]   4.00-5.00   sec  40.4 MBytes   339 Mbits/sec    0
[  4]   5.00-6.00   sec  5.27 MBytes  44.2 Mbits/sec    0   73.5 KBytes
[  6]   5.00-6.00   sec  3.98 MBytes  33.4 Mbits/sec    0   55.1 KBytes
[  8]   5.00-6.00   sec  3.94 MBytes  33.1 Mbits/sec    0   45.2 KBytes
[ 10]   5.00-6.00   sec  3.95 MBytes  33.1 Mbits/sec    0   49.5 KBytes
[ 12]   5.00-6.00   sec  3.96 MBytes  33.3 Mbits/sec    0   49.5 KBytes
[ 14]   5.00-6.00   sec  3.97 MBytes  33.3 Mbits/sec    0   42.4 KBytes
[ 16]   5.00-6.00   sec  3.96 MBytes  33.3 Mbits/sec    0   46.7 KBytes
[ 18]   5.00-6.00   sec  3.80 MBytes  31.9 Mbits/sec    0   41.0 KBytes
[ 20]   5.00-6.00   sec  3.96 MBytes  33.3 Mbits/sec    0   45.2 KBytes
[ 22]   5.00-6.00   sec  3.57 MBytes  30.0 Mbits/sec    0   41.0 KBytes
[SUM]   5.00-6.00   sec  40.4 MBytes   339 Mbits/sec    0
[  4]   6.00-7.00   sec  5.26 MBytes  44.1 Mbits/sec    0   73.5 KBytes
[  6]   6.00-7.00   sec  3.95 MBytes  33.1 Mbits/sec    0   55.1 KBytes
[  8]   6.00-7.00   sec  3.95 MBytes  33.2 Mbits/sec    0   45.2 KBytes
[ 10]   6.00-7.00   sec  3.94 MBytes  33.0 Mbits/sec    0   49.5 KBytes
[ 12]   6.00-7.00   sec  3.91 MBytes  32.8 Mbits/sec    0   49.5 KBytes
[ 14]   6.00-7.00   sec  3.94 MBytes  33.1 Mbits/sec    0   42.4 KBytes
[ 16]   6.00-7.00   sec  3.96 MBytes  33.2 Mbits/sec    0   46.7 KBytes
[ 18]   6.00-7.00   sec  3.72 MBytes  31.2 Mbits/sec    0   41.0 KBytes
[ 20]   6.00-7.00   sec  3.97 MBytes  33.3 Mbits/sec    0   45.2 KBytes
[ 22]   6.00-7.00   sec  3.75 MBytes  31.5 Mbits/sec    0   41.0 KBytes
[SUM]   6.00-7.00   sec  40.4 MBytes   338 Mbits/sec    0
[  4]   7.00-8.00   sec  5.26 MBytes  44.1 Mbits/sec    0   73.5 KBytes
[  6]   7.00-8.00   sec  3.98 MBytes  33.4 Mbits/sec    0   55.1 KBytes
[  8]   7.00-8.00   sec  3.94 MBytes  33.1 Mbits/sec    0   45.2 KBytes
[ 10]   7.00-8.00   sec  3.97 MBytes  33.3 Mbits/sec    0   49.5 KBytes
[ 12]   7.00-8.00   sec  3.95 MBytes  33.1 Mbits/sec    0   49.5 KBytes
[ 14]   7.00-8.00   sec  3.97 MBytes  33.3 Mbits/sec    0   42.4 KBytes
[ 16]   7.00-8.00   sec  4.02 MBytes  33.7 Mbits/sec    0   46.7 KBytes
[ 18]   7.00-8.00   sec  3.81 MBytes  32.0 Mbits/sec    0   41.0 KBytes
[ 20]   7.00-8.00   sec  3.96 MBytes  33.3 Mbits/sec    0   45.2 KBytes
[ 22]   7.00-8.00   sec  3.52 MBytes  29.5 Mbits/sec    0   41.0 KBytes
[SUM]   7.00-8.00   sec  40.4 MBytes   339 Mbits/sec    0
[  4]   8.00-9.00   sec  5.29 MBytes  44.4 Mbits/sec    0   73.5 KBytes
[  6]   8.00-9.00   sec  3.98 MBytes  33.4 Mbits/sec    0   55.1 KBytes
[  8]   8.00-9.00   sec  3.97 MBytes  33.3 Mbits/sec    0   45.2 KBytes
[ 10]   8.00-9.00   sec  3.98 MBytes  33.4 Mbits/sec    0   49.5 KBytes
[ 12]   8.00-9.00   sec  3.98 MBytes  33.4 Mbits/sec    0   49.5 KBytes
[ 14]   8.00-9.00   sec  4.00 MBytes  33.6 Mbits/sec    0   42.4 KBytes
[ 16]   8.00-9.00   sec  3.95 MBytes  33.2 Mbits/sec    0   46.7 KBytes
[ 18]   8.00-9.00   sec  3.66 MBytes  30.7 Mbits/sec    0   41.0 KBytes
[ 20]   8.00-9.00   sec  3.95 MBytes  33.2 Mbits/sec    0   45.2 KBytes
[ 22]   8.00-9.00   sec  3.60 MBytes  30.2 Mbits/sec    0   41.0 KBytes
[SUM]   8.00-9.00   sec  40.4 MBytes   339 Mbits/sec    0
[  4]   9.00-10.00  sec  5.33 MBytes  44.7 Mbits/sec    0   73.5 KBytes
[  6]   9.00-10.00  sec  3.99 MBytes  33.5 Mbits/sec    0   55.1 KBytes
[  8]   9.00-10.00  sec  3.96 MBytes  33.2 Mbits/sec    0   45.2 KBytes
[ 10]   9.00-10.00  sec  3.98 MBytes  33.4 Mbits/sec    0   49.5 KBytes
[ 12]   9.00-10.00  sec  4.00 MBytes  33.6 Mbits/sec    0   49.5 KBytes
[ 14]   9.00-10.00  sec  4.00 MBytes  33.5 Mbits/sec    0   42.4 KBytes
[ 16]   9.00-10.00  sec  3.94 MBytes  33.1 Mbits/sec    0   46.7 KBytes
[ 18]   9.00-10.00  sec  3.61 MBytes  30.2 Mbits/sec    0   41.0 KBytes
[ 20]   9.00-10.00  sec  3.97 MBytes  33.3 Mbits/sec    0   45.2 KBytes
[ 22]   9.00-10.00  sec  3.58 MBytes  30.0 Mbits/sec    0   41.0 KBytes
[SUM]   9.00-10.00  sec  40.4 MBytes   338 Mbits/sec    0
[  4]   0.00-10.00  sec  52.9 MBytes  44.4 Mbits/sec    0             sender
[  4]   0.00-10.00  sec  52.8 MBytes  44.3 Mbits/sec                  receiver
[  6]   0.00-10.00  sec  39.7 MBytes  33.3 Mbits/sec    0             sender
[  6]   0.00-10.00  sec  39.6 MBytes  33.2 Mbits/sec                  receiver
[  8]   0.00-10.00  sec  39.6 MBytes  33.3 Mbits/sec    0             sender
[  8]   0.00-10.00  sec  39.6 MBytes  33.2 Mbits/sec                  receiver
[ 10]   0.00-10.00  sec  39.8 MBytes  33.3 Mbits/sec    0             sender
[ 10]   0.00-10.00  sec  39.7 MBytes  33.3 Mbits/sec                  receiver
[ 12]   0.00-10.00  sec  39.7 MBytes  33.3 Mbits/sec    0             sender
[ 12]   0.00-10.00  sec  39.6 MBytes  33.2 Mbits/sec                  receiver
[ 14]   0.00-10.00  sec  39.7 MBytes  33.3 Mbits/sec    0             sender
[ 14]   0.00-10.00  sec  39.7 MBytes  33.3 Mbits/sec                  receiver
[ 16]   0.00-10.00  sec  39.7 MBytes  33.3 Mbits/sec    0             sender
[ 16]   0.00-10.00  sec  39.6 MBytes  33.3 Mbits/sec                  receiver
[ 18]   0.00-10.00  sec  37.7 MBytes  31.6 Mbits/sec    0             sender
[ 18]   0.00-10.00  sec  37.6 MBytes  31.5 Mbits/sec                  receiver
[ 20]   0.00-10.00  sec  39.7 MBytes  33.3 Mbits/sec    0             sender
[ 20]   0.00-10.00  sec  39.7 MBytes  33.3 Mbits/sec                  receiver
[ 22]   0.00-10.00  sec  36.0 MBytes  30.2 Mbits/sec    1             sender
[ 22]   0.00-10.00  sec  35.9 MBytes  30.1 Mbits/sec                  receiver
[SUM]   0.00-10.00  sec   404 MBytes   339 Mbits/sec    1             sender
[SUM]   0.00-10.00  sec   404 MBytes   339 Mbits/sec                  receiver
Uplink NEO2 via ( ultracheap ) RT8188EU USB-WiFi Adapter ( simulating 10 concurrent connections on Uplink WLAN in noisy 2.4Ghz mess ).
rsc@rs026:~$ iperf3 -c 192.168.2.182 -P10
Connecting to host 192.168.2.182, port 5201
[  4] local 192.168.2.26 port 34670 connected to 192.168.2.182 port 5201
[  6] local 192.168.2.26 port 34672 connected to 192.168.2.182 port 5201
[  8] local 192.168.2.26 port 34674 connected to 192.168.2.182 port 5201
[ 10] local 192.168.2.26 port 34676 connected to 192.168.2.182 port 5201
[ 12] local 192.168.2.26 port 34678 connected to 192.168.2.182 port 5201
[ 14] local 192.168.2.26 port 34680 connected to 192.168.2.182 port 5201
[ 16] local 192.168.2.26 port 34682 connected to 192.168.2.182 port 5201
[ 18] local 192.168.2.26 port 34684 connected to 192.168.2.182 port 5201
[ 20] local 192.168.2.26 port 34686 connected to 192.168.2.182 port 5201
[ 22] local 192.168.2.26 port 34688 connected to 192.168.2.182 port 5201
[  4]   0.00-1.00   sec  1.09 MBytes  9.11 Mbits/sec    3   48.1 KBytes
[  6]   0.00-1.00   sec   824 KBytes  6.75 Mbits/sec    0   53.7 KBytes
[  8]   0.00-1.00   sec  1.03 MBytes  8.60 Mbits/sec    1   67.9 KBytes
[ 10]   0.00-1.00   sec  1.22 MBytes  10.3 Mbits/sec    2   56.6 KBytes
[ 12]   0.00-1.00   sec  1.07 MBytes  8.98 Mbits/sec    3   46.7 KBytes
[ 14]   0.00-1.00   sec   826 KBytes  6.76 Mbits/sec    0   53.7 KBytes
[ 16]   0.00-1.00   sec  1.26 MBytes  10.6 Mbits/sec    0   87.7 KBytes
[ 18]   0.00-1.00   sec  1.01 MBytes  8.43 Mbits/sec    1   66.5 KBytes
[ 20]   0.00-1.00   sec  1.09 MBytes  9.10 Mbits/sec    3   49.5 KBytes
[ 22]   0.00-1.00   sec   752 KBytes  6.16 Mbits/sec    2   33.9 KBytes
[SUM]   0.00-1.00   sec  10.1 MBytes  84.7 Mbits/sec   15
[  4]   1.00-2.00   sec   769 KBytes  6.30 Mbits/sec   14   24.0 KBytes
[  6]   1.00-2.00   sec  1.09 MBytes  9.11 Mbits/sec   19   31.1 KBytes
[  8]   1.00-2.00   sec   870 KBytes  7.12 Mbits/sec   26   21.2 KBytes
[ 10]   1.00-2.00   sec  1.02 MBytes  8.55 Mbits/sec   16   24.0 KBytes
[ 12]   1.00-2.00   sec   615 KBytes  5.04 Mbits/sec   19   17.0 KBytes
[ 14]   1.00-2.00   sec  1.15 MBytes  9.61 Mbits/sec   10   29.7 KBytes
[ 16]   1.00-2.00   sec  1.07 MBytes  8.96 Mbits/sec   25   25.5 KBytes
[ 18]   1.00-2.00   sec  1.02 MBytes  8.57 Mbits/sec   23   26.9 KBytes
[ 20]   1.00-2.00   sec   844 KBytes  6.91 Mbits/sec   14   29.7 KBytes
[ 22]   1.00-2.00   sec   580 KBytes  4.75 Mbits/sec    9   19.8 KBytes
[SUM]   1.00-2.00   sec  8.93 MBytes  74.9 Mbits/sec  175
[  4]   2.00-3.00   sec  1008 KBytes  8.26 Mbits/sec    4   33.9 KBytes
[  6]   2.00-3.00   sec  1.24 MBytes  10.4 Mbits/sec    8   41.0 KBytes
[  8]   2.00-3.00   sec   720 KBytes  5.90 Mbits/sec    6   22.6 KBytes
[ 10]   2.00-3.00   sec  1.15 MBytes  9.68 Mbits/sec    0   46.7 KBytes
[ 12]   2.00-3.00   sec   747 KBytes  6.12 Mbits/sec    4   29.7 KBytes
[ 14]   2.00-3.00   sec   977 KBytes  8.01 Mbits/sec    4   29.7 KBytes
[ 16]   2.00-3.00   sec  1011 KBytes  8.29 Mbits/sec    4   36.8 KBytes
[ 18]   2.00-3.00   sec  1.07 MBytes  8.95 Mbits/sec    2   36.8 KBytes
[ 20]   2.00-3.00   sec  1.12 MBytes  9.40 Mbits/sec    2   36.8 KBytes
[ 22]   2.00-3.00   sec   868 KBytes  7.12 Mbits/sec    4   32.5 KBytes
[SUM]   2.00-3.00   sec  9.78 MBytes  82.1 Mbits/sec   38
[  4]   3.00-4.00   sec  1.06 MBytes  8.90 Mbits/sec    4   43.8 KBytes
[  6]   3.00-4.00   sec  1.20 MBytes  10.0 Mbits/sec    3   48.1 KBytes
[  8]   3.00-4.00   sec   826 KBytes  6.76 Mbits/sec    3   36.8 KBytes
[ 10]   3.00-4.00   sec  1.28 MBytes  10.7 Mbits/sec    4   50.9 KBytes
[ 12]   3.00-4.00   sec   977 KBytes  8.00 Mbits/sec    2   41.0 KBytes
[ 14]   3.00-4.00   sec   967 KBytes  7.92 Mbits/sec    4   41.0 KBytes
[ 16]   3.00-4.00   sec   977 KBytes  8.00 Mbits/sec    3   32.5 KBytes
[ 18]   3.00-4.00   sec   973 KBytes  7.97 Mbits/sec    4   32.5 KBytes
[ 20]   3.00-4.00   sec  1.10 MBytes  9.19 Mbits/sec    4   45.2 KBytes
[ 22]   3.00-4.00   sec   908 KBytes  7.43 Mbits/sec    4   31.1 KBytes
[SUM]   3.00-4.00   sec  10.1 MBytes  84.9 Mbits/sec   35
[  4]   4.00-5.00   sec  1.06 MBytes  8.90 Mbits/sec   11   36.8 KBytes
[  6]   4.00-5.00   sec   947 KBytes  7.77 Mbits/sec   15   22.6 KBytes
[  8]   4.00-5.00   sec  1010 KBytes  8.28 Mbits/sec    7   26.9 KBytes
[ 10]   4.00-5.00   sec  1010 KBytes  8.28 Mbits/sec   12   24.0 KBytes
[ 12]   4.00-5.00   sec   996 KBytes  8.16 Mbits/sec   14   24.0 KBytes
[ 14]   4.00-5.00   sec   996 KBytes  8.16 Mbits/sec   12   28.3 KBytes
[ 16]   4.00-5.00   sec   887 KBytes  7.27 Mbits/sec    5   25.5 KBytes
[ 18]   4.00-5.00   sec  1.03 MBytes  8.68 Mbits/sec   13   29.7 KBytes
[ 20]   4.00-5.00   sec  1.07 MBytes  9.00 Mbits/sec    9   29.7 KBytes
[ 22]   4.00-5.00   sec   839 KBytes  6.87 Mbits/sec   13   31.1 KBytes
[SUM]   4.00-5.00   sec  9.69 MBytes  81.4 Mbits/sec  111
[  4]   5.00-6.00   sec  1.14 MBytes  9.60 Mbits/sec    5   36.8 KBytes
[  6]   5.00-6.00   sec  1.00 MBytes  8.42 Mbits/sec    2   33.9 KBytes
[  8]   5.00-6.00   sec   930 KBytes  7.62 Mbits/sec    5   28.3 KBytes
[ 10]   5.00-6.00   sec   902 KBytes  7.39 Mbits/sec    4   33.9 KBytes
[ 12]   5.00-6.00   sec   901 KBytes  7.38 Mbits/sec    3   33.9 KBytes
[ 14]   5.00-6.00   sec  1.14 MBytes  9.55 Mbits/sec    1   45.2 KBytes
[ 16]   5.00-6.00   sec   822 KBytes  6.73 Mbits/sec    8   17.0 KBytes
[ 18]   5.00-6.00   sec  1.06 MBytes  8.89 Mbits/sec    4   26.9 KBytes
[ 20]   5.00-6.00   sec  1.02 MBytes  8.55 Mbits/sec    3   36.8 KBytes
[ 22]   5.00-6.00   sec  1.04 MBytes  8.69 Mbits/sec    3   38.2 KBytes
[SUM]   5.00-6.00   sec  9.87 MBytes  82.8 Mbits/sec   38
[  4]   6.00-7.00   sec  1.06 MBytes  8.86 Mbits/sec    4   36.8 KBytes
[  6]   6.00-7.00   sec  1.08 MBytes  9.08 Mbits/sec    4   35.4 KBytes
[  8]   6.00-7.00   sec   962 KBytes  7.88 Mbits/sec    5   35.4 KBytes
[ 10]   6.00-7.00   sec   949 KBytes  7.77 Mbits/sec    5   35.4 KBytes
[ 12]   6.00-7.00   sec   953 KBytes  7.81 Mbits/sec    4   33.9 KBytes
[ 14]   6.00-7.00   sec  1.14 MBytes  9.56 Mbits/sec   10   36.8 KBytes
[ 16]   6.00-7.00   sec   683 KBytes  5.60 Mbits/sec    3   28.3 KBytes
[ 18]   6.00-7.00   sec   987 KBytes  8.09 Mbits/sec    2   39.6 KBytes
[ 20]   6.00-7.00   sec  1.00 MBytes  8.40 Mbits/sec    5   36.8 KBytes
[ 22]   6.00-7.00   sec  1.00 MBytes  8.42 Mbits/sec    4   36.8 KBytes
[SUM]   6.00-7.00   sec  9.71 MBytes  81.5 Mbits/sec   46
[  4]   7.00-8.00   sec   983 KBytes  8.05 Mbits/sec    8   22.6 KBytes
[  6]   7.00-8.00   sec   916 KBytes  7.51 Mbits/sec   11   28.3 KBytes
[  8]   7.00-8.00   sec   926 KBytes  7.59 Mbits/sec    8   21.2 KBytes
[ 10]   7.00-8.00   sec   901 KBytes  7.38 Mbits/sec    8   31.1 KBytes
[ 12]   7.00-8.00   sec   926 KBytes  7.59 Mbits/sec    6   32.5 KBytes
[ 14]   7.00-8.00   sec   858 KBytes  7.03 Mbits/sec   17   17.0 KBytes
[ 16]   7.00-8.00   sec   802 KBytes  6.57 Mbits/sec    8   29.7 KBytes
[ 18]   7.00-8.00   sec  1.09 MBytes  9.14 Mbits/sec    4   25.5 KBytes
[ 20]   7.00-8.00   sec   928 KBytes  7.60 Mbits/sec   11   19.8 KBytes
[ 22]   7.00-8.00   sec   892 KBytes  7.31 Mbits/sec   11   19.8 KBytes
[SUM]   7.00-8.00   sec  9.03 MBytes  75.8 Mbits/sec   92
[  4]   8.00-9.00   sec   776 KBytes  6.36 Mbits/sec    4   18.4 KBytes
[  6]   8.00-9.00   sec   967 KBytes  7.92 Mbits/sec    5   22.6 KBytes
[  8]   8.00-9.00   sec   680 KBytes  5.57 Mbits/sec    3   22.6 KBytes
[ 10]   8.00-9.00   sec  1.09 MBytes  9.15 Mbits/sec    1   38.2 KBytes
[ 12]   8.00-9.00   sec  1.12 MBytes  9.37 Mbits/sec    4   25.5 KBytes
[ 14]   8.00-9.00   sec   563 KBytes  4.61 Mbits/sec    4   22.6 KBytes
[ 16]   8.00-9.00   sec  1.21 MBytes  10.1 Mbits/sec    4   28.3 KBytes
[ 18]   8.00-9.00   sec  1.13 MBytes  9.50 Mbits/sec    3   29.7 KBytes
[ 20]   8.00-9.00   sec  1.11 MBytes  9.30 Mbits/sec    2   29.7 KBytes
[ 22]   8.00-9.00   sec   954 KBytes  7.82 Mbits/sec    2   31.1 KBytes
[SUM]   8.00-9.00   sec  9.51 MBytes  79.8 Mbits/sec   32
[  4]   9.00-10.00  sec   561 KBytes  4.60 Mbits/sec    9   15.6 KBytes
[  6]   9.00-10.00  sec   932 KBytes  7.63 Mbits/sec    5   29.7 KBytes
[  8]   9.00-10.00  sec   771 KBytes  6.31 Mbits/sec    5   21.2 KBytes
[ 10]   9.00-10.00  sec  1.32 MBytes  11.1 Mbits/sec    6   36.8 KBytes
[ 12]   9.00-10.00  sec   734 KBytes  6.01 Mbits/sec    7   15.6 KBytes
[ 14]   9.00-10.00  sec   840 KBytes  6.88 Mbits/sec    5   29.7 KBytes
[ 16]   9.00-10.00  sec   891 KBytes  7.30 Mbits/sec   15   28.3 KBytes
[ 18]   9.00-10.00  sec  1.26 MBytes  10.6 Mbits/sec    6   33.9 KBytes
[ 20]   9.00-10.00  sec   952 KBytes  7.80 Mbits/sec    5   31.1 KBytes
[ 22]   9.00-10.00  sec  1.09 MBytes  9.12 Mbits/sec    3   29.7 KBytes
[SUM]   9.00-10.00  sec  9.21 MBytes  77.3 Mbits/sec   66
[  4]   0.00-10.00  sec  9.41 MBytes  7.90 Mbits/sec   66             sender
[  4]   0.00-10.00  sec  9.30 MBytes  7.80 Mbits/sec                  receiver
[  6]   0.00-10.00  sec  10.1 MBytes  8.46 Mbits/sec   72             sender
[  6]   0.00-10.00  sec  10.0 MBytes  8.40 Mbits/sec                  receiver
[  8]   0.00-10.00  sec  8.54 MBytes  7.16 Mbits/sec   69             sender
[  8]   0.00-10.00  sec  8.43 MBytes  7.07 Mbits/sec                  receiver
[ 10]   0.00-10.00  sec  10.8 MBytes  9.02 Mbits/sec   58             sender
[ 10]   0.00-10.00  sec  10.6 MBytes  8.93 Mbits/sec                  receiver
[ 12]   0.00-10.00  sec  8.88 MBytes  7.44 Mbits/sec   66             sender
[ 12]   0.00-10.00  sec  8.76 MBytes  7.35 Mbits/sec                  receiver
[ 14]   0.00-10.00  sec  9.31 MBytes  7.81 Mbits/sec   67             sender
[ 14]   0.00-10.00  sec  9.24 MBytes  7.75 Mbits/sec                  receiver
[ 16]   0.00-10.00  sec  9.46 MBytes  7.94 Mbits/sec   75             sender
[ 16]   0.00-10.00  sec  9.32 MBytes  7.82 Mbits/sec                  receiver
[ 18]   0.00-10.00  sec  10.6 MBytes  8.88 Mbits/sec   62             sender
[ 18]   0.00-10.00  sec  10.5 MBytes  8.80 Mbits/sec                  receiver
[ 20]   0.00-10.00  sec  10.2 MBytes  8.52 Mbits/sec   58             sender
[ 20]   0.00-10.00  sec  10.1 MBytes  8.44 Mbits/sec                  receiver
[ 22]   0.00-10.00  sec  8.78 MBytes  7.37 Mbits/sec   55             sender
[ 22]   0.00-10.00  sec  8.72 MBytes  7.32 Mbits/sec                  receiver
[SUM]   0.00-10.00  sec  96.0 MBytes  80.5 Mbits/sec  648             sender
[SUM]   0.00-10.00  sec  95.0 MBytes  79.7 Mbits/sec                  receiver
iperf Done.
No optimizations were done, just stock Armbian from nightly build. Power consumption idled at 300mA and reached 500mA (dual LAN) and 600mA (LAN+WiFi, but mainly due to silly microUSB power ) during full blast data transfers. Simple heatsinks ( 14x14 mm, not the original monsters with the silicon 'heating pad' ) were used on both boards to keep temperatures below 70.
I am very pleased with the results, especially the combination of onboard GLAN ( private network ) and USB-LAN dongle ( external uplink, WAN  ). With some simple firewall rules you've got a mighty little firewall/jumpstation. Next will be the addition of low-power fast msata-SSDs via USB headers for a tiny luxury NAS. Keep up the fun :) !
Update : Same old story but battery-buffered ( homebrew dual-18650 LIPO pass-through charging ...)
Stable operation while plugging/unplugging during data transfers. More fun to come.....
Edited by rodolfo
added battery-buffered operation
Can you please provide output from /proc/interrupts after running such a GbE test on a NEO 2 with both onboard NIC and RTL8153? Reason: I tried few days ago to add IRQ redistribution to H5 boards but wonder how that works (can't test myself currrently). So you would really need recent nightly (2 days ago since this commit
I just did a short upgrade/update/reboot on the NEO2 boards to make sure they run the latest builds and then did some short test with requested output
| \ | | __ _ _ __   ___ |  _ \(_) | \ | | ___  ___   |___ \
|  \| |/ _` | '_ \ / _ \| |_) | | |  \| |/ _ \/ _ \    __) |
| |\  | (_| | | | | (_) |  __/| | | |\  |  __/ (_) |  / __/
|_| \_|\__,_|_| |_|\___/|_|   |_| |_| \_|\___|\___/  |_____|
Welcome to ARMBIAN 5.27.170426 nightly Ubuntu 16.04.2 LTS 4.10.0-sun50iw2
System load:   0.21 0.11 0.04  	Up time:       1 min
Memory usage:  6 % of 483MB  	IP:            192.168.3.181,192.168.2.234
CPU temp:      58°C
Usage of /:    25% of 7.2G
[ General system configuration: armbian-config ]
Last login: Tue Apr 25 07:43:15 2017 from 192.168.2.26
pi@neo2_181:~$ uname -a
Linux neo2_181 4.10.0-sun50iw2 #3 SMP Tue Apr 25 03:48:23 CEST 2017 aarch64 aarch64 aarch64 GNU/Linux
pi@neo2_181:~$ cat /proc/interrupts
           CPU0       CPU1       CPU2       CPU3
  2:          0          0          0          0     GICv2  29 Level     arch_timer
  3:       8210       2398       2314       5307     GICv2  30 Level     arch_timer
  6:          0          0          0          0     GICv2  82 Level     1c02000.dma-controller
  7:       6146          0          0          0     GICv2  92 Level     sunxi-mmc
  8:          0          0          0          0     GICv2 106 Level     ehci_hcd:usb1
  9:          0          0          0          0     GICv2 107 Level     ohci_hcd:usb4
 10:          0          0          0          0     GICv2 108 Level     ehci_hcd:usb2
 11:          0          0          0          0     GICv2 109 Level     ohci_hcd:usb5
 12:       5144          0          0          0     GICv2 110 Level     ehci_hcd:usb3
 13:          0          0          0          0     GICv2 111 Level     ohci_hcd:usb6
 18:          4          0          0          0     GICv2  97 Level     sun6i-spi
 21:        272          0          0          0     GICv2  63 Level     1c25000.ths
 22:        415          0          0          0     GICv2  32 Level     serial
 23:          0          0          0          0     GICv2  72 Level     1f00000.rtc
 26:          2          0          0          0     GICv2  76 Level     mv64xxx_i2c
 28:         13          0          0          0     GICv2 114 Level     1c30000.ethernet
 32:          1          0          0          0  sunxi_pio_edge   3 Edge      sw4
 99:          0          0          0          0  sunxi_pio_edge  38 Edge      1c0f000.mmc cd
IPI0:      2834       2993       2261       2420       Rescheduling interrupts
IPI1:        82         87         93         23       Function call interrupts
IPI2:         0          0          0          0       CPU stop interrupts
IPI3:         0          0          0          0       Timer broadcast interrupts
IPI4:         0          0          0          0       IRQ work interrupts
IPI5:         0          0          0          0       CPU wake-up interrupts
Err:          0
pi@neo2_181:~$ iperf3 -c 192.168.3.182 -P10
Connecting to host 192.168.3.182, port 5201
[  4] local 192.168.3.181 port 58078 connected to 192.168.3.182 port 5201
[  6] local 192.168.3.181 port 58080 connected to 192.168.3.182 port 5201
[  8] local 192.168.3.181 port 58082 connected to 192.168.3.182 port 5201
[ 10] local 192.168.3.181 port 58084 connected to 192.168.3.182 port 5201
[ 12] local 192.168.3.181 port 58086 connected to 192.168.3.182 port 5201
[ 14] local 192.168.3.181 port 58088 connected to 192.168.3.182 port 5201
[ 16] local 192.168.3.181 port 58090 connected to 192.168.3.182 port 5201
[ 18] local 192.168.3.181 port 58092 connected to 192.168.3.182 port 5201
[ 20] local 192.168.3.181 port 58094 connected to 192.168.3.182 port 5201
[ 22] local 192.168.3.181 port 58096 connected to 192.168.3.182 port 5201
[  4]   0.00-1.00   sec  10.2 MBytes  85.9 Mbits/sec    0    144 KBytes
[  6]   0.00-1.00   sec  14.3 MBytes   120 Mbits/sec    0    209 KBytes
[  8]   0.00-1.00   sec  13.4 MBytes   112 Mbits/sec    0    181 KBytes
[ 10]   0.00-1.00   sec  11.0 MBytes  92.5 Mbits/sec    0    150 KBytes
[ 12]   0.00-1.00   sec  13.6 MBytes   114 Mbits/sec    0    164 KBytes
[ 14]   0.00-1.00   sec  7.02 MBytes  58.9 Mbits/sec    0    110 KBytes
[ 16]   0.00-1.00   sec  11.7 MBytes  97.9 Mbits/sec    0    150 KBytes
[ 18]   0.00-1.00   sec  11.8 MBytes  98.9 Mbits/sec    0    168 KBytes
[ 20]   0.00-1.00   sec  7.06 MBytes  59.2 Mbits/sec    0    107 KBytes
[ 22]   0.00-1.00   sec  9.03 MBytes  75.8 Mbits/sec    0    130 KBytes
[SUM]   0.00-1.00   sec   109 MBytes   915 Mbits/sec    0
/////////////////////edit:cut/////////////////////////////
[SUM]   0.00-10.00  sec  1.04 GBytes   893 Mbits/sec    0             sender
[SUM]   0.00-10.00  sec  1.02 GBytes   877 Mbits/sec                  receiver
iperf Done.
           CPU0       CPU1       CPU2       CPU3
  3:      13039       2741       2452       5869     GICv2  30 Level     arch_timer
  7:       6151          0          0          0     GICv2  92 Level     sunxi-mmc
 12:       7136          0          0          0     GICv2 110 Level     ehci_hcd:usb3
 21:        371          0          0          0     GICv2  63 Level     1c25000.ths
 28:      56039          0          0          0     GICv2 114 Level     1c30000.ethernet
IPI0:      2886       4594       3078       2942       Rescheduling interrupts
Err:          0
pi@neo2_181:~$
pi@neo2_181:~$ for ((i=0;i<10;i++)) do iperf3 -c 192.168.3.182;  done
[  4] local 192.168.3.181 port 58122 connected to 192.168.3.182 port 5201
[  4]   0.00-1.00   sec  89.9 MBytes   754 Mbits/sec   51    253 KBytes
[  4]   1.00-2.00   sec   104 MBytes   876 Mbits/sec    0    305 KBytes
[  4]   2.00-3.00   sec   100 MBytes   839 Mbits/sec  123    188 KBytes
[  4]   3.00-4.00   sec   106 MBytes   886 Mbits/sec    0    294 KBytes
[  4]   4.00-5.00   sec   107 MBytes   896 Mbits/sec    0    296 KBytes
[  4]   5.00-6.00   sec   107 MBytes   901 Mbits/sec    0    297 KBytes
[  4]   6.00-7.00   sec   106 MBytes   890 Mbits/sec    0    300 KBytes
[  4]   7.00-8.00   sec   107 MBytes   899 Mbits/sec    0    300 KBytes
[  4]   8.00-9.00   sec   107 MBytes   897 Mbits/sec    0    301 KBytes
[  4]   9.00-10.00  sec   106 MBytes   890 Mbits/sec    0    301 KBytes
[  4]   0.00-10.00  sec  1.02 GBytes   873 Mbits/sec  174             sender
[  4]   0.00-10.00  sec  1.01 GBytes   871 Mbits/sec                  receiver
[  4]   0.00-10.00  sec  1.03 GBytes   884 Mbits/sec   78             sender
[  4]   0.00-10.00  sec  1.03 GBytes   882 Mbits/sec                  receiver
iperf Done.
           CPU0       CPU1       CPU2       CPU3
  3:      51750       4471       4529      10037     GICv2  30 Level     arch_timer
  7:       7546          0          0          0     GICv2  92 Level     sunxi-mmc
 12:      21396          0          0          0     GICv2 110 Level     ehci_hcd:usb3
 21:       1119          0          0          0     GICv2  63 Level     1c25000.ths
 28:    1734921          0          0          0     GICv2 114 Level     1c30000.ethernet
IPI0:      3252      15585      22899       5366       Rescheduling interrupts
Hope this helps. Have a nice day.
On 22.3.2017 at 6:30 PM, tkaiser said:
surprisingly XR819 Wi-Fi as known from OPi Zero.
Talking back then about NanoPi NEO Plus 2. Not so surprisingly FriendlyELEC discovered what a shit show XR819 is and did what? Replaced it with AP6212A instead: https://github.com/friendlyarm/linux/commits/sunxi-4.11.y
On the bright side: We could convince them to focus on mainline kernel and for a certain amount of boards they're already at it :)
the serial console shows that it comes up, but the USB devices are not visible. I'll try more troubleshooting when I get the time.
Hi guys, I'm new to the forum, I just received the NanoPi Neo 2, small, pretty.
I downloaded the compilation tools and I created a debian jessie image, configured and installed all the needed packages.
Than I've noticed something strange: the energy consumption is much higher again to the standard ubuntu firmware 2x.
I tried to investigate but after fiew minutes i stopped.
Than I'm going to configure the led: with my surprise the LEDs are named as orangepi:red:status ... I do a check on the DTs and find out that the wrong DTS has loaded.
root@nanopineo2:~# cat /sys/class/leds/orangepi\:
orangepi:green:pwr/  orangepi:red:status/
root@nanopineo2:~# cat /sys/class/leds/orangepi\:red\:status/
brightness      max_brightness  subsystem/      uevent
device/         power/          trigger
root@nanopineo2:~# cat /sys/class/leds/orangepi\:red\:status/trigger
[none] kbd-scrolllock kbd-numlock kbd-capslock kbd-kanalock kbd-shiftlock kbd-altgrlock kbd-ctrllock kbd-altlock kbd-shiftllock kbd-shiftrlock kbd-ctrlllock kbd-ctrlrlock usbport usb-gadget usb-host mmc0 heartbeat cpu0 cpu1 cpu2 cpu3 rc-feedback 1c30000.ethernet-0:00:1Gbps 1c30000.ethernet-0:00:100Mbps 1c30000.ethernet-0:00:10Mbps rfkill-any
root@nanopineo2:~# echo heartbeat > /sys/class/leds/orangepi\:red\:status/trigge
root@nanopineo2:~# cat /proc/device-tree/
#address-cells    gmac-3v3/         psci/             thermal-zones/
aliases/          interrupt-parent  r-gpio-keys/      timer/
chosen/           leds/             serial-number     usb0-vbus/
clocks/           memory/           #size-cells       vcc3v3/
compatible        model             soc/
cpus/             name              __symbols__/
root@nanopineo2:~# cat /proc/device-tree/model
Xunlong Orange Pi PC 2
root@nanopineo2:~# cat /proc/device-tree/compatible
xunlong,orangepi-pc2allwinner,sun50i-h5r
root@nanopineo2:~#
Suggestions?
EDIT: Looks like that also the U-Boot is for the orange PI, not sure how the kernel / bootloader works on all winner so it maybe the bootloader that has the problem?
INFO:    PSCI Affinity Map:
INFO:      AffInst: Level 0, MPID 0x0, State ON
INFO:      AffInst: Level 0, MPID 0x1, State ON
INFO:      AffInst: Level 0, MPID 0x2, State ON
INFO:      AffInst: Level 0, MPID 0x3, State ON
U-Boot SPL 2017.01-rc1-g5df570f-dirty (May 09 2017 - 10:42:28)
DRAM: 512 MiB
Failed to set core voltage! Can't set CPU frequency
Trying to boot from MMC1NOTICE:  BL3-1: Running on H5 (1718) in SRAM A2 (@0x44000)
NOTICE:  Configuring SPC Controller
NOTICE:  BL3-1: v1.0(debug):aa75c8d
NOTICE:  BL3-1: Built : 10:42:22, May  9 2017
INFO:    BL3-1: Initializing runtime services
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9
U-Boot 2017.01-rc1-g5df570f-dirty (May 09 2017 - 10:42:37 +0200) Allwinner Technology
CPU:   Allwinner H5 (SUN50I)
Model: OrangePi PC 2
DRAM:  512 MiB
MMC:   SUNXI SD/MMC: 0
Setting up a 720x576i composite-pal console (overscan 32x20)
Error: no valid bmp image at 66000000
In:    serial
Out:   vga
Err:   vga
Net:   phy interface7
Could not get PHY for ethernet@1c30000: addr 1
No ethernet found.
38518 bytes read in 132 ms (284.2 KiB/s)
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2428 bytes read in 208 ms (10.7 KiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
116 bytes read in 169 ms (0 Bytes/s)
19253 bytes read in 325 ms (57.6 KiB/s)
4904371 bytes read in 531 ms (8.8 MiB/s)
11270152 bytes read in 743 ms (14.5 MiB/s)
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
   Image Name:   uInitrd
   Data Size:    4904307 Bytes = 4.7 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   reserving fdt memory region: addr=4fa00000 size=5000
   Loading Ramdisk to 49b52000, end 49fff573 ... OK
   Loading Device Tree to 0000000049b4a000, end 0000000049b51fff ... OK
Cannot setup simplefb: node not found
Starting kernel ...
Loading, please wait...
with 4.11, there's still an issue that an attached WiFi dongle is not visible after reboot, and it needs to be re-plugged (or the whole board needs a power-cycle). It looks like the USB device initialization is broken at soft reboot.
52 minutes ago, Stanislav Sinyagin said:
Now 4.11 kernel update is missing for nanopineo2.
This indicates that automated built process broke. Nothing unusual for development areas / work in progress ...
Development process is based on volunteer contributions / time and it  takes months before issues gets fixed.
This is my first time trying an Armbian image for the NEO2 but I noticed that there are only Ubuntu based images here, but would it be possible to add Debian images as well? just like this for example.
So it would be possible to run OpenMediaVault
Regards,
39 minutes ago, Timeless said:
Regards,
https://github.com/armbian/build/commit/0d00c0705e667635e1ed45f624d8d2c6f04ab85d
Will be there tomorrow morning at around 9 am CEST. But ... its still considered a preview build (kernel) since it's not well tested yet. Don't blame us for troubles or expect extensive help in case of them.
