An error occured while installing Home Assistant, check the logs below for more information. on the homeassistant image
Hi there,
Seems that you are trying to download an incorrect image for HASS:
2024-05-14 11:38:38.835 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/odroid-n2-homeassistant:2024.5.3: 404 Client Error for http+docker://localhost/v1.45/images/ghcr.io/home-assistant/odroid-n2-homeassistant:2024.5.3/json: Not Found ("No such image: ghcr.io/home-assistant/odroid-n2-homeassistant:2024.5.3")
2024-05-14 11:38:38.837 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
Looks like the HASS supervised installation is trying to install a docker image for an Odroid N2 instead of the Libre Renegade? According to Odroid, the N2 is based on an Amlogic SoC and not on a Rockchip SoC (like the Libre Renegade). Apart from that, it appears it cannot locate the docker image either.
Perhaps contact the HASS community?
You can also try to install Armbian on your SBC and use the regular Docker image for HASS.
Hope that helps,
Groetjes,
