dimaxus Posted January 25, 2021 Posted January 25, 2021 piter75 thanks a lot, now it works as it should. Be sure to ask the developer to fix this in the following distributions. Do you know how to get the standard audio output to work? Aplay -l command output: **** List of PLAYBACK Hardware Devices **** card 0: Dummy [Dummy], device 0: Dummy PCM [Dummy PCM] Subdevices: 7/8 Subdevice #0: subdevice #0 Subdevice #1: subdevice #1 Subdevice #2: subdevice #2 Subdevice #3: subdevice #3 Subdevice #4: subdevice #4 Subdevice #5: subdevice #5 Subdevice #6: subdevice #6 Subdevice #7: subdevice #7 card 1: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM] Subdevices: 7/8 Subdevice #0: subdevice #0 Subdevice #1: subdevice #1 Subdevice #2: subdevice #2 Subdevice #3: subdevice #3 Subdevice #4: subdevice #4 Subdevice #5: subdevice #5 Subdevice #6: subdevice #6 Subdevice #7: subdevice #7 card 1: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM] Subdevices: 8/8 Subdevice #0: subdevice #0 Subdevice #1: subdevice #1 Subdevice #2: subdevice #2 Subdevice #3: subdevice #3 Subdevice #4: subdevice #4 Subdevice #5: subdevice #5 Subdevice #6: subdevice #6 Subdevice #7: subdevice #7 card 2: realtekrt5651co [realtek,rt5651-codec], device 0: ff880000.i2s-rt5651-aif1 rt5651-aif1-0 [ff880000.i2s-rt5651-aif1 rt5651-aif1-0] Subdevices: 0/1 Subdevice #0: subdevice #0 card 3: rockchiphdmi [rockchip,hdmi], device 0: ff8a0000.i2s-i2s-hifi i2s-hifi-0 [ff8a0000.i2s-i2s-hifi i2s-hifi-0] Subdevices: 0/1 Subdevice #0: subdevice #0 card 4: ROCKCHIPSPDIF [ROCKCHIP,SPDIF], device 0: ff870000.spdif-dit-hifi dit-hifi-0 [ff870000.spdif-dit-hifi dit-hifi-0] Subdevices: 0/1 Subdevice #0: subdevice #0 0 Quote
dimaxus Posted May 20, 2021 Posted May 20, 2021 good day everyone. The situation with bluetooth was repeated again after the last update. Only now the service file is called not rk3399-bluetooth.service, but bluetooth.service and the content is different there. Please help fix the problem. 0 Quote
whitefox Posted June 21, 2022 Posted June 21, 2022 (edited) You can share instructions on how you build fresh kernels for orange pi rk3399 @martinayotte Maybe something from these kernels is like https://github.com/radxa/debos-radxa/releases with minimal patches? I lived on the official kernel for quite a long time with loading via eMMC, but something went wrong and I want to try a fresh kernel I also ask you to give a link to a fresh image of ubuntu. It is also not clear that the images from orange pi4 are suitable for the orange pi rk3399 board ? https://www.armbian.com/orange-pi-4/ PS. I don't need bluetooth and wifi Edited June 21, 2022 by whitefox 0 Quote
Werner Posted June 21, 2022 Posted June 21, 2022 2 hours ago, whitefox said: suitable for the orange pi rk3399 board They are not. Orangepi 4/4B and Orangepi RK3399 are independent boards. Latter does not have a maintainer to take care of it, therefore no automatic built images are available for download. However you can always use the build framework to build your own image. However no guarantee that everything works or boots at all. https://docs.armbian.com/Developer-Guide_Build-Preparation/ 0 Quote
whitefox Posted June 23, 2022 Posted June 23, 2022 21.06.2022 в 21:12, Werner сказал: They are not. Orangepi 4/4B and Orangepi RK3399 are independent boards. Latter does not have a maintainer to take care of it, therefore no automatic built images are available for download. However you can always use the build framework to build your own image. However no guarantee that everything works or boots at all. https://docs.armbian.com/Developer-Guide_Build-Preparation/ Thanks. I build current image total size is 45.84M speedup is 1.00 [ .... ] Updating initramfs... [ update-initramfs -uv -k 5.15.49-rockchip64 ] [ o.k. ] Updated initramfs. [ for details see: /root/build/output/debug/install.log ] [ .... ] Re-enabling [ initramfs-tools hook for kernel ] [ o.k. ] Unmounting [ /root/build/.tmp/mount-478cc97c-5aea-436e-a8f9-72514acb9f5b/ ] [ o.k. ] Free SD cache [ 11% ] [ o.k. ] Mount point [ 92% ] [ o.k. ] Writing U-boot bootloader [ /dev/loop5 ] [ o.k. ] SHA256 calculating [ Armbian_22.08.0-trunk_Orangepi-rk3399_jammy_current_5.15.49_minimal.img ] [ warn ] GPG signing skipped - no GPG_PASS [ Armbian_22.08.0-trunk_Orangepi-rk3399_jammy_current_5.15.49_minimal.img ] [ o.k. ] Done building [ /root/build/.tmp/image-478cc97c-5aea-436e-a8f9-72514acb9f5b/Armbian_22.08.0-trunk_Orangepi-rk3399_jammy_current_5.15.49_minimal.img ] [ o.k. ] Runtime [ 296 min ] [ o.k. ] Repeat Build Options [ ./compile.sh BOARD=orangepi-rk3399 BRANCH=current RELEASE=jammy BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,img ] 0 Quote
whitefox Posted June 24, 2022 Posted June 24, 2022 (edited) After installing the current kernel, I noticed that the processor became very hot when idle launched top 214 root 0 -20 0 0 0 R 48.8 0.0 1:46.14 kworker/u13:0-brcmf_wq/mmc0:0001:1 cat /proc/214/status Name: kworker/u13:0+brcmf_wq/mmc0:0001:1 Umask: 0000 State: D (disk sleep) Tgid: 214 Ngid: 0 Pid: 214 PPid: 2 TracerPid: 0 Uid: 0 0 0 0 Gid: 0 0 0 0 FDSize: 64 Groups: NStgid: 214 NSpid: 214 NSpgid: 0 NSsid: 0 Threads: 1 SigQ: 0/14866 SigPnd: 0000000000000000 ShdPnd: 0000000000000000 SigBlk: 0000000000000000 SigIgn: ffffffffffffffff SigCgt: 0000000000000000 CapInh: 0000000000000000 CapPrm: 000001ffffffffff CapEff: 000001ffffffffff CapBnd: 000001ffffffffff CapAmb: 0000000000000000 NoNewPrivs: 0 Seccomp: 0 Seccomp_filters: 0 Speculation_Store_Bypass: vulnerable SpeculationIndirectBranch: unknown Cpus_allowed: 3f Cpus_allowed_list: 0-5 Mems_allowed: 1 Mems_allowed_list: 0 voluntary_ctxt_switches: 11448782 nonvoluntary_ctxt_switches: 4691 What could be the problem of constant CPU consumption while idle? @Igor How to disable this module? update Now it's clear why Edited June 24, 2022 by whitefox 0 Quote
