Tomate Posted July 4, 2024 Posted July 4, 2024 Hello, I'm identifying myself has a newbie concerning linux. After some time I reboot my rock5c and it is not booting anymore. Here is what I've done initially: I bought a rock 5c and a penta sata hat. -I installed Armbian_24.5.1_Rock-5c_bookworm_edge_6.8.10_minimal. -I installed OMV (configure some samba shared folder) -I installed ZFS (for that I needed linux headers that I found online because there were not included) -I create a ZFS pull with two SSD. -I installed immich and setup a cloudflare tunel to use it. -I installed plex media server. That's pretty much all I have setup on my SBC. I've done apt upgrade multiple time & update some immich / Plex. Every time I did update I rebooted the SBC. And then yesterday I did an immich & plex update, apt upgrade and lastly rebooted. And my SBC never did come back online. I try to install a fresh armbian install to see if it still boot and it did boot. I'm not sure where to start to get it boot again with keeping has much stuff has I can. I wanted to try this: https://docs.armbian.com/User-Guide_Recovery/#replacing-boot But I'm not sure what Root file system, Kernel, Firmware & Device Tree Binary (DTB) version I should take. Or maybe someone could point me to an other path to fix my install? 0 Quote
Werner Posted July 4, 2024 Posted July 4, 2024 2 hours ago, Tomate said: edge Don't use bleeding edge if you expect stability. Use vendor until mainline is more matured. 0 Quote
Tomate Posted July 4, 2024 Author Posted July 4, 2024 Thanks for the advice. I will do next time but now what should I do? Can I rollback the version? 0 Quote
Werner Posted July 5, 2024 Posted July 5, 2024 I'd try with linux-image-vendor-rk35xx and linux-dtb-vendor-rk35xx and leave cli bsp package for now as it is. That being said it would be more useful to get an idea about WHAT is actually failing an attempting to fix before messing with the kernels. Hook up a serial console and set verbosity to 7. https://debug.armbian.de 0 Quote
Tomate Posted July 5, 2024 Author Posted July 5, 2024 Thanks, I'll try it. Just to be sure this is the two packages you recommend: https://uk.mirrors.naho.moe/armbian/pool/main/l/linux-6.1.43/linux-image-vendor-rk35xx_24.5.1_arm64__6.1.43-Sd06d-D440d-Pb426-Ccc84H5c21-HK01ba-Vc222-Bf15a-R448a.deb https://uk.mirrors.naho.moe/armbian/pool/main/l/linux-dtb-vendor-rk35xx/linux-dtb-vendor-rk35xx_24.5.1_arm64__6.1.43-Sd06d-D440d-Pb426-Ccc84H5c21-HK01ba-Vc222-Bf15a-R448a.deb After reading the recovery guide I'm not sure of the steps I should do. This one will work only changing the mnt path: ~/tmp/recovery # for f in *.deb; do dpkg -x $f /mnt/sdcard; done But this one I'm not sure but maybe after dpkg the deb files It will be obvious. ~/tmp/recovery # cd /mnt/sdcard/boot /mnt/sdcard/boot # ln -s vmlinuz-5.8.16-sunxi64 zImage /mnt/sdcard/boot # ln -s uInitrd-5.8.16-sunxi64 uInitrd /mnt/sdcard/boot # ln -s dtb-5.8.16 dtb In the mean time I order an usb uart it will certainly proved helpful in my journey. 0 Quote
Tomate Posted July 6, 2024 Author Posted July 6, 2024 I got my uart and connect to the rock5c console and I got this: ���������������>DDR 9fffbe1e78 cym 24/02/04-10:09:20,fwver: v1.16 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB Manufacturer ID:0xff CH0 RX Vref:26.7%, TX Vref:22.8%,0.0% CH1 RX Vref:28.3%, TX Vref:20.8%,0.0% CH2 RX Vref:28.5%, TX Vref:18.8%,0.0% CH3 RX Vref:28.5%, TX Vref:20.8%,0.0% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-armbian (Jun 30 2024 - 21:45:07) unrecognized JEDEC id bytes: 00, 00, 00 unknown raw ID 0 0 0 Trying to boot from MMC2 spl: partition error Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(a7d1d8d191...) + OK ## Checking uboot 0x00200000 ... sha256(5ecfc82c23...) + OK ## Checking fdt 0x0031e2e0 ... sha256(049e983a22...) + OK ## Checking atf-2 0xff100000 ... sha256(4b2065349b...) + OK ## Checking atf-3 0x000f0000 ... sha256(aa71013e72...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 200.400/400.957 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-682-g4ca8a8422:derrick.huang, fwver: v1.45 NOTICE: BL31: Built : 10:11:21, Dec 27 2023 INFO: spec: 0x13 INFO: code: 0x88 INFO: ext 32k is not valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian (Jun 30 2024 - 21:45:07 +0000) Model: Radxa ROCK 5C MPIDR: 0x81000000 PreSerial: 2, raw, 0xfeb50000 DRAM: 8 GiB Sysmem: init Relocation Offset: eda3f000 Relocation fdt: eb9f8fc0 - eb9fece0 CR: M/C/I Using default environment DM: v2 no mmc device at slot 1 mmc@fe2c0000: 1 (SD), mmc@fe2e0000: 0 Bootdev(atags): mmc 1 MMC1: Legacy, 52Mhz PartType: EFI No misc partition boot mode: None FIT: No boot partition Failed to load DTB, ret=-2 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 Model: Radxa ROCK 5C MPIDR: 0x81000000 CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz No misc partition Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 starting USB... Bus usb@fc800000: USB EHCI 1.00 Bus usb@fc840000: USB OHCI 1.0 Bus usb@fc880000: USB EHCI 1.00 Bus usb@fc8c0000: USB OHCI 1.0 scanning bus usb@fc800000 for devices... 2 USB Device(s) found scanning bus usb@fc840000 for devices... 1 USB Device(s) found scanning bus usb@fc880000 for devices... 1 USB Device(s) found scanning bus usb@fc8c0000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3920 bytes read in 11 ms (347.7 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 245 bytes read in 10 ms (23.4 KiB/s) 39687743 bytes read in 3202 ms (11.8 MiB/s) 32371200 bytes read in 2611 ms (11.8 MiB/s) 147231 bytes read in 41 ms (3.4 MiB/s) 259 bytes read in 13 ms (18.6 KiB/s) Applying user provided DT overlay pwm-fan.dtbo failed on fdt_overlay_apply(): FDT_ERR_NOTFOUND Error applying DT overlays, restoring original DT 147231 bytes read in 41 ms (3.4 MiB/s) Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 39687679 Bytes = 37.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 Using Device Tree in place at 0000000008300000, end 0000000008326f1e can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000) Adding bank: 0x2f0000000 - 0x300000000 (size: 0x10000000) Total: 12172.921/12630.205 ms Starting kernel ... And it kept hanging there, no more line after "Starting kernel ..." I will search a bit with this debug log and come back if I found something new. 0 Quote
Werner Posted July 6, 2024 Posted July 6, 2024 edit /boot/armbianEnv.txt and set verbosity to 7 to get more info after Starting kernel. 0 Quote
Tomate Posted July 6, 2024 Author Posted July 6, 2024 Thanks, I did not try that but I get it working again. I just copy the boot folder from a working install of the original release I installed. I did had to move /lib/modules/6.8.11-edge-rockchip-rk3588 to 6.8.10-edge-rockchip-rk3588 to get docker running again. Now a big thanks for your help. Just a couple questions. It seams I did start a kernel upgrade from 6.8.10 to 6.8.11 and to fix my issue I rolled back to 6.8.10 again. Can I prevent kernel upgrade from happening while doing apt upgrade? Can I and should I migrate to a more stable kernel branch like 6.1.43? And if yes how so? 0 Quote
Werner Posted July 7, 2024 Posted July 7, 2024 12 hours ago, Tomate said: Can I prevent kernel upgrade from happening while doing apt upgrade? Use armbian-config to freeze firmware. This will set the packages in question to hold. 12 hours ago, Tomate said: Can I and should I migrate to a more stable kernel branch like 6.1.43? You can. But if you should is up to you. Mainline support is maturing pretty nicely and I expect to have a decent set of working features in 6.11 which may (or may not) become next LTS kernel. 6.10 is a pretty good preview. If you are fine with having something older but most hw features working use rockchip bsp, 6.1.43 to say. 12 hours ago, Tomate said: And if yes how so? This should work with armbian-config as well. Go to Hardware and then Other. 0 Quote
Tomate Posted July 8, 2024 Author Posted July 8, 2024 Thanks for all this Insight. Quote This should work with armbian-config as well. Go to Hardware and then Other. It only suggesting me: 6.9.0 & 6.7.0 & 6.8.11 & 6.8.0-rc1 Juste last one question if I decide to downgrade the kernel (and I succeed to do it). Do I have to update the kernel header I installed ? and if yes Is it this one I should install? https://uk.mirrors.naho.moe/armbian/pool/main/l/linux-headers-vendor-rk35xx/linux-headers-vendor-rk35xx_24.5.1_arm64__6.1.43-Sd06d-D440d-Pb426-Ccc84H5c21-HK01ba-Vc222-Bf15a-R448a.deb 0 Quote
Werner Posted July 8, 2024 Posted July 8, 2024 46 minutes ago, Tomate said: Do I have to update the kernel header I installed ? If you need them to build like dkms kernel modules then yes, the headers MUST match the installed kernel version. armbian-config should be able to do that for you as well. 47 minutes ago, Tomate said: It only suggesting me: 6.9.0 & 6.7.0 & 6.8.11 & 6.8.0-rc1 Ah yes. Newer ones are in beta/nightly repository only. You may get 6.10 or 6.11-rc edge images and packages from repo after Armbian August release. 0 Quote
Tomate Posted July 27, 2024 Author Posted July 27, 2024 Hey, It's dumb me again. I did a new apt upgrade and this time I'm sure it did not upgrade kernel (it was freeze in armbian-config and no new kernel files in boot folder) but I'm stuck in with no boot again. Here is the log: LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB Manufacturer ID:0xff CH0 RX Vref:26.7%, TX Vref:23.8%,0.0% CH1 RX Vref:28.8%, TX Vref:20.8%,0.0% CH2 RX Vref:28.5%, TX Vref:19.8%,0.0% CH3 RX Vref:29.3%, TX Vref:19.8%,0.0% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-armbian (Jun 30 2024 - 21:45:07) unrecognized JEDEC id bytes: 00, 00, 00 unknown raw ID 0 0 0 Trying to boot from MMC2 spl: partition error Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(a7d1d8d191...) + OK ## Checking uboot 0x00200000 ... sha256(5ecfc82c23...) + OK ## Checking fdt 0x0031e2e0 ... sha256(049e983a22...) + OK ## Checking atf-2 0xff100000 ... sha256(4b2065349b...) + OK ## Checking atf-3 0x000f0000 ... sha256(aa71013e72...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 200.459/401.228 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-682-g4ca8a8422:derrick.huang, fwver: v1.45 NOTICE: BL31: Built : 10:11:21, Dec 27 2023 INFO: spec: 0x13 INFO: code: 0x88 INFO: ext 32k is not valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian (Jun 30 2024 - 21:45:07 +0000) Model: Radxa ROCK 5C MPIDR: 0x81000000 PreSerial: 2, raw, 0xfeb50000 DRAM: 8 GiB Sysmem: init Relocation Offset: eda3f000 Relocation fdt: eb9f8fc0 - eb9fece0 CR: M/C/I Using default environment DM: v2 no mmc device at slot 1 mmc@fe2c0000: 1 (SD), mmc@fe2e0000: 0 Bootdev(atags): mmc 1 MMC1: Legacy, 52Mhz PartType: EFI No misc partition boot mode: None FIT: No boot partition Failed to load DTB, ret=-2 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 Model: Radxa ROCK 5C MPIDR: 0x81000000 CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz No misc partition Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 starting USB... Bus usb@fc800000: USB EHCI 1.00 Bus usb@fc840000: USB OHCI 1.0 Bus usb@fc880000: USB EHCI 1.00 Bus usb@fc8c0000: USB OHCI 1.0 scanning bus usb@fc800000 for devices... 2 USB Device(s) found scanning bus usb@fc840000 for devices... 1 USB Device(s) found scanning bus usb@fc880000 for devices... 1 USB Device(s) found scanning bus usb@fc8c0000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3920 bytes read in 10 ms (382.8 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 223 bytes read in 8 ms (26.4 KiB/s) 39697637 bytes read in 3197 ms (11.8 MiB/s) 32371200 bytes read in 2612 ms (11.8 MiB/s) 147231 bytes read in 54 ms (2.6 MiB/s) Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 39697573 Bytes = 37.9 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 reserving fdt memory region: addr=8300000 size=8a000 Using Device Tree in place at 0000000008300000, end 000000000838cfff can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000) Adding bank: 0x2f0000000 - 0x300000000 (size: 0x10000000) Total: 12165.400/12622.998 ms Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 0.000000] Linux version 6.8.10-edge-rockchip-rk3588 (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT 4 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Radxa ROCK 5 Model C [ 0.000000] efi: UEFI not found. [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000002ffffffff] [ 0.000000] NUMA: NODE_DATA [mem 0x2fef28340-0x2fef2afff] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000002ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff] [ 0.000000] node 0: [mem 0x00000002f0000000-0x00000002ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000002ffffffff] [ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [ 0.000000] cma: Reserved 384 MiB at 0x00000000d8000000 on node -1 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 31 pages/cpu s88936 r8192 d29848 u126976 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: root=UUID=81d5c2b5-015e-40b6-a0c0-8e1aa1aa4288 rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 uboo4 [ 0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=d9dfe38e-209d-c14f-8956-2646606892a0 cgroup_enable=memory cgroup_memory=1", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2063880 [ 0.000000] Policy zone: Normal [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [ 0.000000] software IO TLB: area num 8. [ 0.000000] software IO TLB: mapped [mem 0x00000000d4000000-0x00000000d8000000] (64MB) [ 0.000000] Memory: 7694072K/8386560K available (17920K kernel code, 2876K rwdata, 5628K rodata, 5056K init, 775K bss, 299272K reserved, 393216K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 0.000000] trace event string verifier disabled [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 480 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: MBI range [424:479] [ 0.000000] GICv3: Using MBI frame 0x00000000fe610000 [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 0.000000] ITS [mem 0xfe640000-0xfe65ffff] [ 0.000000] GIC: enabling workaround for ITS: Rockchip erratum RK3588001 [ 0.000000] ITS@0x00000000fe640000: allocated 8192 Devices @100110000 (indirect, esz 8, psz 64K, shr 0) [ 0.000000] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100120000 (flat, esz 2, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] ITS [mem 0xfe660000-0xfe67ffff] [ 0.000000] GIC: enabling workaround for ITS: Rockchip erratum RK3588001 [ 0.000000] ITS@0x00000000fe660000: allocated 8192 Devices @100140000 (indirect, esz 8, psz 64K, shr 0) [ 0.000000] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100150000 (flat, esz 2, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000100160000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000100170000 [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@100[1] /cpus/cpu@200[2] /cpus/cpu@300[3] } [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@400[4] /cpus/cpu@500[5] /cpus/cpu@600[6] /cpus/cpu@700[7] } [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001081] Console: colour dummy device 80x25 [ 0.001091] printk: legacy console [tty1] enabled [ 0.003147] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 0.003172] pid_max: default: 32768 minimum: 301 [ 0.005841] LSM: initializing lsm=capability,yama,apparmor,integrity [ 0.006894] Yama: becoming mindful. [ 0.006984] AppArmor: AppArmor initialized [ 0.007906] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.007940] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.011721] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1. [ 0.011815] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1. [ 0.012075] rcu: Hierarchical SRCU implementation. [ 0.012090] rcu: Max phase no-delay instances is 1000. [ 0.012961] Platform MSI: msi-controller@fe640000 domain created [ 0.012990] Platform MSI: msi-controller@fe660000 domain created [ 0.013240] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 0.013276] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 0.013889] EFI services will not be available. [ 0.014269] smp: Bringing up secondary CPUs ... [ 0.014757] Detected VIPT I-cache on CPU1 [ 0.014808] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 0.014824] GICv3: CPU1: using allocated LPI pending table @0x0000000100180000 [ 0.014860] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 0.015398] Detected VIPT I-cache on CPU2 [ 0.015447] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 0.015463] GICv3: CPU2: using allocated LPI pending table @0x0000000100190000 [ 0.015497] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 0.016035] Detected VIPT I-cache on CPU3 [ 0.016083] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 0.016097] GICv3: CPU3: using allocated LPI pending table @0x00000001001a0000 [ 0.016129] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 0.016706] CPU features: detected: Spectre-v4 [ 0.016711] CPU features: detected: Spectre-BHB [ 0.016714] Detected PIPT I-cache on CPU4 [ 0.016741] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 0.016750] GICv3: CPU4: using allocated LPI pending table @0x00000001001b0000 [ 0.016770] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 0.017281] Detected PIPT I-cache on CPU5 [ 0.017313] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 0.017321] GICv3: CPU5: using allocated LPI pending table @0x00000001001c0000 [ 0.017342] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 0.017793] Detected PIPT I-cache on CPU6 [ 0.017824] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 0.017833] GICv3: CPU6: using allocated LPI pending table @0x00000001001d0000 [ 0.017853] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 0.018333] Detected PIPT I-cache on CPU7 [ 0.018365] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 0.018374] GICv3: CPU7: using allocated LPI pending table @0x00000001001e0000 [ 0.018394] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 0.018449] smp: Brought up 1 node, 8 CPUs [ 0.018701] SMP: Total of 8 processors activated. [ 0.018712] CPU: All CPU(s) started at EL2 [ 0.018722] CPU features: detected: 32-bit EL0 Support [ 0.018733] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 0.018749] CPU features: detected: Common not Private translations [ 0.018761] CPU features: detected: CRC32 instructions [ 0.018775] CPU features: detected: RCpc load-acquire (LDAPR) [ 0.018786] CPU features: detected: LSE atomic instructions [ 0.018798] CPU features: detected: Privileged Access Never [ 0.018809] CPU features: detected: RAS Extension Support [ 0.018822] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 0.018877] alternatives: applying system-wide alternatives [ 0.021740] CPU features: detected: Hardware dirty bit management on CPU4-7 [ 0.024388] devtmpfs: initialized [ 0.031764] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 0.031785] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.034453] pinctrl core: initialized pinctrl subsystem [ 0.034615] DMI not present or invalid. [ 0.035586] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.036261] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 0.036484] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.036719] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.036737] audit: initializing netlink subsys (disabled) [ 0.036831] audit: type=2000 audit(0.033:1): state=initialized audit_enabled=0 res=1 [ 0.037139] thermal_sys: Registered thermal governor 'fair_share' [ 0.037142] thermal_sys: Registered thermal governor 'bang_bang' [ 0.037148] thermal_sys: Registered thermal governor 'step_wise' [ 0.037153] thermal_sys: Registered thermal governor 'user_space' [ 0.037156] thermal_sys: Registered thermal governor 'power_allocator' [ 0.037172] cpuidle: using governor ladder [ 0.037183] cpuidle: using governor menu [ 0.037313] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.037398] ASID allocator initialised with 65536 entries [ 0.037795] Serial: AMBA PL011 UART driver [ 0.042242] platform fdd90000.vop: Fixed dependency cycle(s) with /hdmi@fde80000 [ 0.042275] platform fde80000.hdmi: Fixed dependency cycle(s) with /vop@fdd90000 [ 0.049828] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.049994] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 0.050088] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.050180] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 0.050260] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.050346] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 0.050453] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.050539] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 0.050622] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.050707] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 0.052069] Modules: 24656 pages in range for non-PLT usage [ 0.052072] Modules: 516176 pages in range for PLT usage [ 0.052509] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.052518] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.052523] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.052528] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.052533] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.052537] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.052542] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.052546] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.053286] cryptd: max_cpu_qlen set to 1000 [ 0.108504] raid6: neonx8 gen() 5937 MB/s [ 0.165236] raid6: neonx4 gen() 5833 MB/s [ 0.221960] raid6: neonx2 gen() 5571 MB/s [ 0.278686] raid6: neonx1 gen() 4527 MB/s [ 0.335406] raid6: int64x8 gen() 2697 MB/s [ 0.392133] raid6: int64x4 gen() 3048 MB/s [ 0.448860] raid6: int64x2 gen() 2639 MB/s [ 0.505582] raid6: int64x1 gen() 2168 MB/s [ 0.505586] raid6: using algorithm neonx8 gen() 5937 MB/s [ 0.562299] raid6: .... xor() 4667 MB/s, rmw enabled [ 0.562303] raid6: using neon recovery algorithm [ 0.562511] ACPI: Interpreter disabled. [ 0.562872] iommu: Default domain type: Translated [ 0.562878] iommu: DMA domain TLB invalidation policy: strict mode [ 0.563763] SCSI subsystem initialized [ 0.563927] usbcore: registered new interface driver usbfs [ 0.563939] usbcore: registered new interface driver hub [ 0.563951] usbcore: registered new device driver usb [ 0.564106] pps_core: LinuxPPS API ver. 1 registered [ 0.564111] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.564118] PTP clock support registered [ 0.564278] EDAC MC: Ver: 3.0.0 [ 0.564488] scmi_core: SCMI protocol bus registered [ 0.564661] FPGA manager framework [ 0.564970] NetLabel: Initializing [ 0.564975] NetLabel: domain hash size = 128 [ 0.564979] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.565004] NetLabel: unlabeled traffic allowed by default [ 0.565083] vgaarb: loaded [ 0.565288] clocksource: Switched to clocksource arch_sys_counter [ 0.566286] VFS: Disk quotas dquot_6.6.0 [ 0.566388] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.566684] AppArmor: AppArmor Filesystem Enabled [ 0.566719] pnp: PnP ACPI: disabled [ 0.570766] NET: Registered PF_INET protocol family [ 0.570890] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.574189] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear) [ 0.574275] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.574315] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.574745] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 0.575961] TCP: Hash tables configured (established 65536 bind 65536) [ 0.576015] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.576142] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.576356] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.576379] NET: Registered PF_XDP protocol family [ 0.576386] PCI: CLS 0 bytes, default 64 [ 0.576547] Trying to unpack rootfs image as initramfs... [ 0.582076] kvm [1]: IPA Size Limit: 40 bits [ 0.582099] kvm [1]: GICv3: no GICV resource entry [ 0.582105] kvm [1]: disabling GICv2 emulation [ 0.582118] kvm [1]: GIC system register CPU interface enabled [ 0.582138] kvm [1]: vgic interrupt IRQ18 [ 0.582161] kvm [1]: VHE mode initialized successfully [ 0.582947] Initialise system trusted keyrings [ 0.582975] Key type blacklist registered [ 0.583057] workingset: timestamp_bits=42 max_order=21 bucket_order=0 [ 0.583082] zbud: loaded [ 0.585946] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.587605] ntfs: driver 2.1.32 [Flags: R/W]. [ 0.587767] ntfs3: Max link count 4000 [ 0.587771] ntfs3: Enabled Linux POSIX ACLs support [ 0.587774] ntfs3: Read-only LZX/Xpress compression included [ 0.587863] fuse: init (API version 7.39) [ 0.589630] integrity: Platform Keyring initialized [ 0.614006] xor: measuring software checksum speed [ 0.615157] 8regs : 8582 MB/sec [ 0.616330] 32regs : 8447 MB/sec [ 0.617138] arm64_neon : 12238 MB/sec [ 0.617142] xor: using function: arm64_neon (12238 MB/sec) [ 0.617150] Key type asymmetric registered [ 0.617153] Asymmetric key parser 'x509' registered [ 0.617187] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.617292] io scheduler mq-deadline registered [ 0.617297] io scheduler kyber registered [ 0.617369] io scheduler bfq registered [ 0.622879] EINJ: ACPI disabled. [ 0.623841] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.623850] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.624410] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.624418] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.624977] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.624984] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.627500] Serial: 8250/16550 driver, 8 ports, IRQ sharing enabled [ 0.628774] printk: legacy console [ttyS2] disabled [ 0.628869] feb50000.serial: ttyS2 at MMIO 0xfeb50000 (irq = 40, base_baud = 1500000) is a 16550A [ 0.628936] printk: legacy console [ttyS2] enabled [ 0.773166] Serial: AMBA driver [ 0.778454] brd: module loaded [ 0.781055] loop: module loaded [ 0.783415] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/regulators/dcdc-reg7 [ 0.784208] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs3-null-pins [ 0.784932] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs2-null-pins [ 0.785667] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs1-null-pins [ 0.787299] thunder_xcv, ver 1.0 [ 0.787593] thunder_bgx, ver 1.0 [ 0.787881] nicpf, ver 1.0 [ 0.788321] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version [ 0.788960] hns3: Copyright (c) 2017 Huawei Corporation. [ 0.789445] hclge is initializing [ 0.790241] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 0.790847] rk_gmac-dwmac fe1c0000.ethernet: supply phy not found, using dummy regulator [ 0.791594] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 0.792236] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x3a). [ 0.792756] rk_gmac-dwmac fe1c0000.ethernet: RX delay(0x3e). [ 0.793272] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 0.798836] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII [ 0.799467] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 0.800093] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 0.800544] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 0.801197] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 0.801850] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 0.802480] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 0.803061] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 0.803540] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 0.804239] rk_gmac-dwmac fe1c0000.ethernet: Enabled L3L4 Flow TC (entries=2) [ 0.804863] rk_gmac-dwmac fe1c0000.ethernet: Enabled RFS Flow TC (entries=10) [ 0.805489] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 0.806014] rk_gmac-dwmac fe1c0000.ethernet: SPH feature enabled [ 0.806539] rk_gmac-dwmac fe1c0000.ethernet: Using 32/32 bits DMA host/device width [ 1.590319] Freeing initrd memory: 38760K [ 1.745550] VFIO - User Level meta-driver version: 0.3 [ 1.764049] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.764538] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 1.765280] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000008002000010 [ 1.766020] ehci-platform fc880000.usb: EHCI Host Controller [ 1.766030] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 1.766048] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 2 [ 1.766091] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 1.766099] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3 [ 1.766103] ehci-platform fc800000.usb: EHCI Host Controller [ 1.766119] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 4 [ 1.766151] ohci-platform fc8c0000.usb: irq 50, io mem 0xfc8c0000 [ 1.766155] xhci-hcd xhci-hcd.0.auto: irq 46, io mem 0xfc000000 [ 1.766161] ohci-platform fc840000.usb: irq 49, io mem 0xfc840000 [ 1.766215] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.766220] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5 [ 1.766224] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 1.766275] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08 [ 1.766279] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.766282] usb usb1: Product: xHCI Host Controller [ 1.766284] usb usb1: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 xhci-hcd [ 1.766287] usb usb1: SerialNumber: xhci-hcd.0.auto [ 1.766534] hub 1-0:1.0: USB hub found [ 1.766544] hub 1-0:1.0: 1 port detected [ 1.766643] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 6 [ 1.766654] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.766679] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08 [ 1.766683] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.766685] usb usb5: Product: xHCI Host Controller [ 1.766687] usb usb5: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 xhci-hcd [ 1.766690] usb usb5: SerialNumber: xhci-hcd.0.auto [ 1.766841] hub 5-0:1.0: USB hub found [ 1.766849] hub 5-0:1.0: 1 port detected [ 1.766986] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 1.766995] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7 [ 1.767053] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000008002000010 [ 1.767071] xhci-hcd xhci-hcd.1.auto: irq 47, io mem 0xfcd00000 [ 1.767121] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 1.767125] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8 [ 1.767128] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 1.767161] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08 [ 1.767165] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.767168] usb usb7: Product: xHCI Host Controller [ 1.767170] usb usb7: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 xhci-hcd [ 1.767172] usb usb7: SerialNumber: xhci-hcd.1.auto [ 1.767292] ehci-platform fc800000.usb: irq 51, io mem 0xfc800000 [ 1.767330] hub 7-0:1.0: USB hub found [ 1.767338] hub 7-0:1.0: 1 port detected [ 1.767431] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.767455] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08 [ 1.767458] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.767460] usb usb8: Product: xHCI Host Controller [ 1.767462] usb usb8: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 xhci-hcd [ 1.767465] usb usb8: SerialNumber: xhci-hcd.1.auto [ 1.767624] hub 8-0:1.0: USB hub found [ 1.767631] hub 8-0:1.0: 1 port detected [ 1.767733] usbcore: registered new interface driver usb-storage [ 1.767919] ehci-platform fc880000.usb: irq 48, io mem 0xfc880000 [ 1.768443] mousedev: PS/2 mouse device common for all mice [ 1.768544] i2c_dev: i2c /dev entries driver [ 1.781970] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 1.783441] platform fe470000.i2s: Fixed dependency cycle(s) with /i2c@fec90000/audio-codec@11 [ 1.783806] fan53555-regulator 2-0042: FAN53555 Option[10] Rev[1] Detected! [ 1.783961] fan53555-regulator 0-0043: FAN53555 Option[10] Rev[1] Detected! [ 1.784227] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08 [ 1.784428] fan53555-regulator 0-0042: FAN53555 Option[10] Rev[1] Detected! [ 1.784524] i2c 7-0011: Fixed dependency cycle(s) with /i2s@fe470000 [ 1.784998] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.786481] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 1.786989] usb usb4: Product: EHCI Host Controller [ 1.789444] sdhci: Secure Digital Host Controller Interface driver [ 1.789667] usb usb4: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 ehci_hcd [ 1.789995] sdhci: Copyright(c) Pierre Ossman [ 1.790072] Synopsys Designware Multimedia Card Interface Driver [ 1.790346] usb usb4: SerialNumber: fc800000.usb [ 1.791353] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.792205] hub 4-0:1.0: USB hub found [ 1.795348] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 1.795734] hub 4-0:1.0: 1 port detected [ 1.798702] ledtrig-cpu: registered to indicate activity on CPUs [ 1.799776] usb usb6: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08 [ 1.799866] No iBFT detected. [ 1.800392] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.800534] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16 [ 1.800951] usb usb6: Product: EHCI Host Controller [ 1.801057] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 1.801585] usb usb6: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 ehci_hcd [ 1.801608] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 1.802198] usb usb6: SerialNumber: fc880000.usb [ 1.806530] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 1.807174] hub 6-0:1.0: USB hub found [ 1.807352] hid: raw HID events driver (C) Jiri Kosina [ 1.808112] hub 6-0:1.0: 1 port detected [ 1.808334] usbcore: registered new interface driver usbhid [ 1.814494] usbhid: USB HID core driver [ 1.816578] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available [ 1.817914] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 counters available [ 1.819101] optee: probing for conduit method. [ 1.819494] optee: api uid mismatch [ 1.819799] optee: probe of firmware:optee failed with error -22 [ 1.821107] NET: Registered PF_INET6 protocol family [ 1.822017] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA [ 1.826222] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.08 [ 1.827021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.827667] usb usb2: Product: Generic Platform OHCI controller [ 1.828195] usb usb2: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 ohci_hcd [ 1.828328] mmc0: Failed to initialize a non-removable card [ 1.828859] usb usb2: SerialNumber: fc8c0000.usb [ 1.830323] hub 2-0:1.0: USB hub found [ 1.830689] hub 2-0:1.0: 1 port detected [ 1.831438] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.08 [ 1.832195] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.832840] usb usb3: Product: Generic Platform OHCI controller [ 1.833368] usb usb3: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 ohci_hcd [ 1.834011] usb usb3: SerialNumber: fc840000.usb [ 1.834965] hub 3-0:1.0: USB hub found [ 1.835346] hub 3-0:1.0: 1 port detected [ 1.841473] Segment Routing with IPv6 [ 1.841837] In-situ OAM (IOAM) with IPv6 [ 1.842253] NET: Registered PF_PACKET protocol family [ 1.842901] 8021q: 802.1Q VLAN Support v1.8 [ 1.843297] Key type dns_resolver registered [ 1.847097] registered taskstats version 1 [ 1.847561] Loading compiled-in X.509 certificates [ 1.856940] zswap: loaded using pool zstd/z3fold [ 1.857560] Key type .fscrypt registered [ 1.857906] Key type fscrypt-provisioning registered [ 1.860001] Btrfs loaded, zoned=yes, fsverity=yes [ 1.860496] Key type encrypted registered [ 1.860851] AppArmor: AppArmor sha256 policy hashing enabled [ 1.861354] ima: No TPM chip found, activating TPM-bypass! [ 1.861841] ima: Allocated hash algorithm: sha1 [ 1.862254] ima: No architecture policies found [ 1.862672] evm: Initialising EVM extended attributes: [ 1.863121] evm: security.selinux [ 1.863412] evm: security.SMACK64 [ 1.863702] evm: security.SMACK64EXEC [ 1.864023] evm: security.SMACK64TRANSMUTE [ 1.864381] evm: security.SMACK64MMAP [ 1.864701] evm: security.apparmor [ 1.864999] evm: security.ima [ 1.865260] evm: security.capability [ 1.865596] evm: HMAC attrs: 0x1 [ 1.888241] rockchip-dw-pcie a41000000.pcie: host bridge /pcie@fe190000 ranges: [ 1.888938] rockchip-dw-pcie a41000000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 1.889730] rockchip-dw-pcie a41000000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 1.890516] rockchip-dw-pcie a41000000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0040000000 [ 1.891430] rockchip-dw-pcie a41000000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G [ 2.048698] usb 4-1: new high-speed USB device number 2 using ehci-platform [ 2.196603] usb 4-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11 [ 2.197337] usb 4-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 2.197972] usb 4-1: Product: USB 2.0 Hub [ 2.198953] hub 4-1:1.0: USB hub found [ 2.199430] hub 4-1:1.0: 4 ports detected [ 2.578697] usb 4-1.3: new high-speed USB device number 3 using ehci-platform [ 2.777102] usb 4-1.3: New USB device found, idVendor=a69c, idProduct=8d80, bcdDevice= 1.00 [ 2.777850] usb 4-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 2.778502] usb 4-1.3: Product: AIC Wlan [ 2.778871] usb 4-1.3: Manufacturer: aicsemi [ 2.779254] usb 4-1.3: SerialNumber: 20220103 [ 2.985488] rockchip-dw-pcie a41000000.pcie: Phy link never came up [ 2.986403] rockchip-dw-pcie a41000000.pcie: PCI host bridge to bus 0004:40 [ 2.987028] pci_bus 0004:40: root bus resource [bus 40-4f] [ 2.987522] pci_bus 0004:40: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 2.988371] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 2.989007] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff] (bus address [0x40000000-0x7fffffff]) [ 2.989950] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 PCIe Root Port [ 2.990619] pci 0004:40:00.0: ROM [mem 0x00000000-0x0000ffff pref] [ 2.991172] pci 0004:40:00.0: PCI bridge to [bus 01-ff] [ 2.991644] pci 0004:40:00.0: bridge window [io 0x0000-0x0fff] [ 2.992198] pci 0004:40:00.0: bridge window [mem 0x00000000-0x000fffff] [ 2.992808] pci 0004:40:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref] [ 2.993542] pci 0004:40:00.0: supports D1 D2 [ 2.993927] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 3.000375] pci 0004:40:00.0: Primary bus is hard wired to 0 [ 3.000885] pci 0004:40:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring [ 3.001856] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 3.002479] pci 0004:40:00.0: ROM [mem 0xf4200000-0xf420ffff pref]: assigned [ 3.003111] pci 0004:40:00.0: PCI bridge to [bus 41] [ 3.006040] pcieport 0004:40:00.0: PME: Signaling with IRQ 72 [ 3.006979] pcieport 0004:40:00.0: AER: enabled with IRQ 73 [ 3.009004] printk: legacy console [netcon0] enabled [ 3.009444] netconsole: network logging started [ 3.009955] psci_checker: PSCI checker started using 8 CPUs [ 3.010444] psci_checker: Starting hotplug tests [ 3.010850] psci_checker: Trying to turn off and on again all CPUs [ 3.012144] psci: CPU0 killed (polled 0 ms) [ 3.014206] psci: CPU1 killed (polled 0 ms) [ 3.016468] psci: CPU2 killed (polled 0 ms) [ 3.018536] psci: CPU3 killed (polled 0 ms) [ 3.019744] psci: CPU4 killed (polled 0 ms) [ 3.021105] psci: CPU5 killed (polled 0 ms) [ 3.022449] psci: CPU6 killed (polled 0 ms) [ 3.023561] Detected VIPT I-cache on CPU0 [ 3.023945] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 3.024585] CPU0: Booted secondary processor 0x0000000000 [0x412fd050] [ 3.026294] Detected VIPT I-cache on CPU1 [ 3.026676] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 3.027332] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 3.028979] Detected VIPT I-cache on CPU2 [ 3.029357] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 3.030009] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 3.031610] Detected VIPT I-cache on CPU3 [ 3.031991] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 3.032640] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 3.034383] Detected PIPT I-cache on CPU4 [ 3.034749] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 3.035386] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 3.036898] Detected PIPT I-cache on CPU5 [ 3.037264] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 3.037901] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 3.039374] Detected PIPT I-cache on CPU6 [ 3.039740] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 3.040377] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 3.041328] psci_checker: Trying to turn off and on again group 0 (CPUs 0-7) [ 3.042617] psci: CPU0 killed (polled 0 ms) [ 3.044131] psci: CPU1 killed (polled 0 ms) [ 3.045686] psci: CPU2 killed (polled 0 ms) [ 3.047176] psci: CPU3 killed (polled 0 ms) [ 3.047958] psci: CPU4 killed (polled 0 ms) [ 3.048973] psci: CPU5 killed (polled 0 ms) [ 3.049739] psci: CPU6 killed (polled 0 ms) [ 3.050721] Detected VIPT I-cache on CPU0 [ 3.051098] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 3.051733] CPU0: Booted secondary processor 0x0000000000 [0x412fd050] [ 3.053258] Detected VIPT I-cache on CPU1 [ 3.053634] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 3.054284] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 3.055890] Detected VIPT I-cache on CPU2 [ 3.056267] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 3.056917] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 3.058493] Detected VIPT I-cache on CPU3 [ 3.058871] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 3.059521] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 3.061406] Detected PIPT I-cache on CPU4 [ 3.061772] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 3.062408] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 3.063762] Detected PIPT I-cache on CPU5 [ 3.064129] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 3.064767] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 3.066336] Detected PIPT I-cache on CPU6 [ 3.066702] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 3.067339] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 3.068321] psci_checker: Hotplug tests passed OK [ 3.068767] psci_checker: Starting suspend tests (10 cycles per state) [ 3.069764] psci_checker: CPU 6 entering suspend cycles, states 1 through 1 [ 3.069764] psci_checker: CPU 5 entering suspend cycles, states 1 through 1 [ 3.069765] psci_checker: CPU 4 entering suspend cycles, states 1 through 1 [ 3.069765] psci_checker: CPU 7 entering suspend cycles, states 1 through 1 [ 3.069766] psci_checker: CPU 2 entering suspend cycles, states 1 through 1 [ 3.069768] psci_checker: CPU 3 entering suspend cycles, states 1 through 1 [ 3.069769] psci_checker: CPU 1 entering suspend cycles, states 1 through 1 [ 3.069772] psci_checker: CPU 0 entering suspend cycles, states 1 through 1 [ 3.105366] psci_checker: CPU 0 suspend test results: success 10, shallow states 0, errors 0 [ 3.106159] psci_checker: CPU 1 suspend test results: success 10, shallow states 0, errors 0 [ 3.106963] psci_checker: CPU 2 suspend test results: success 10, shallow states 0, errors 0 [ 3.107758] psci_checker: CPU 3 suspend test results: success 10, shallow states 0, errors 0 [ 3.108546] psci_checker: CPU 4 suspend test results: success 10, shallow states 0, errors 0 [ 3.109318] psci_checker: CPU 5 suspend test results: success 10, shallow states 0, errors 0 [ 3.110085] psci_checker: CPU 6 suspend test results: success 10, shallow states 0, errors 0 [ 3.110851] psci_checker: CPU 7 suspend test results: success 10, shallow states 0, errors 0 [ 3.111614] psci_checker: Suspend tests passed OK [ 3.112053] psci_checker: PSCI checker completed [ 3.112611] clk: Disabling unused clocks [ 3.114949] Freeing unused kernel memory: 5056K [ 3.115623] Run /init as init process [ 3.348724] rk_gmac-dwmac fe1c0000.ethernet end0: renamed from eth0 [ 13.282684] platform cpufreq-dt: deferred probe pending: (reason unknown) [ 13.283307] platform fec10000.adc: deferred probe pending: platform: wait for supplier /spi@feb20000/pmic@0/regulators/pldo-reg1 [ 13.284332] platform fe2c0000.mmc: deferred probe pending: platform: wait for supplier /spi@feb20000/pmic@0/regulators/pldo-reg5 [ 78.901947] random: crng init done No more line after minutes waiting. I hope you can help me again. Just to let you know the SBC is not visible on local network. And the updated packages were some docker stuff and open media vault too. 0 Quote
Tomate Posted November 16, 2024 Author Posted November 16, 2024 And here I come again. Please help me The kernel keeps updating itself without doing any apt upgrade and when I have a powerloss my rock5c does not boot anymore. I have freeze my firmware with armbian-config but it seams to not work. I would really like to upgrade my firmware successfully and not having to roll it back every time. Here my last uart boot debug, it does not seams to be much different from previous one but maybe it will help: DDR 9fffbe1e78 cym 24/02/04-10:09:20,fwver: v1.16 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB Manufacturer ID:0xff CH0 RX Vref:27.1%, TX Vref:22.8%,0.0% CH1 RX Vref:28.8%, TX Vref:20.8%,0.0% CH2 RX Vref:27.9%, TX Vref:19.8%,0.0% CH3 RX Vref:29.3%, TX Vref:19.8%,0.0% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-armbian (Jun 30 2024 - 21:45:07) unrecognized JEDEC id bytes: 00, 00, 00 unknown raw ID 0 0 0 Trying to boot from MMC2 spl: partition error Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(a7d1d8d191...) + OK ## Checking uboot 0x00200000 ... sha256(5ecfc82c23...) + OK ## Checking fdt 0x0031e2e0 ... sha256(049e983a22...) + OK ## Checking atf-2 0xff100000 ... sha256(4b2065349b...) + OK ## Checking atf-3 0x000f0000 ... sha256(aa71013e72...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 200.439/399.688 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-682-g4ca8a8422:derrick.huang, fwver: v1.45 NOTICE: BL31: Built : 10:11:21, Dec 27 2023 INFO: spec: 0x13 INFO: code: 0x88 INFO: ext 32k is not valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will retu rn SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian (Jun 30 2024 - 21:45:07 +0000) Model: Radxa ROCK 5C MPIDR: 0x81000000 PreSerial: 2, raw, 0xfeb50000 DRAM: 8 GiB Sysmem: init Relocation Offset: eda3f000 Relocation fdt: eb9f8fc0 - eb9fece0 CR: M/C/I Using default environment DM: v2 no mmc device at slot 1 mmc@fe2c0000: 1 (SD), mmc@fe2e0000: 0 Bootdev(atags): mmc 1 MMC1: Legacy, 52Mhz PartType: EFI No misc partition boot mode: None FIT: No boot partition Failed to load DTB, ret=-2 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 Model: Radxa ROCK 5C MPIDR: 0x81000000 CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz No misc partition Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 starting USB... Bus usb@fc800000: USB EHCI 1.00 Bus usb@fc840000: USB OHCI 1.0 Bus usb@fc880000: USB EHCI 1.00 Bus usb@fc8c0000: USB OHCI 1.0 scanning bus usb@fc800000 for devices... 2 USB Device(s) found scanning bus usb@fc840000 for devices... 1 USB Device(s) found scanning bus usb@fc880000 for devices... 1 USB Device(s) found scanning bus usb@fc8c0000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3920 bytes read in 9 ms (424.8 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 223 bytes read in 8 ms (26.4 KiB/s) 39802409 bytes read in 3206 ms (11.8 MiB/s) 32371200 bytes read in 2610 ms (11.8 MiB/s) 147231 bytes read in 55 ms (2.6 MiB/s) Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 39802345 Bytes = 38 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 reserving fdt memory region: addr=8300000 size=8a000 Using Device Tree in place at 0000000008300000, end 000000000838cfff can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000) Adding bank: 0x2f0000000 - 0x300000000 (size: 0x10000000) Total: 12176.326/12632.391 ms Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 0.000000] Linux version 6.8.10-edge-rockchip-rk3588 (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Fri May 17 10:15:12 UTC 2024 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Radxa ROCK 5 Model C [ 0.000000] efi: UEFI not found. [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000002ffffffff] [ 0.000000] NUMA: NODE_DATA [mem 0x2fef28340-0x2fef2afff] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000002ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff] [ 0.000000] node 0: [mem 0x00000002f0000000-0x00000002ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000002ffffffff] [ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [ 0.000000] cma: Reserved 384 MiB at 0x00000000d8000000 on node -1 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 31 pages/cpu s88936 r8192 d29848 u126976 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: root=UUID=81d5c2b5-015e-40b6-a0c0-8e1aa1aa4288 rootwait rootfstype=ext4 splash=verbose con sole=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart=d9dfe38e-209d-c14f-8956-2646606892a0 usb-storage.quirks=0x 2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 androidboot.fwver=ddr- v1.16-9fffbe1e78,bl31-v1.45,uboot-rmbian-06/30/2024 [ 0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=d9dfe38e-209d-c14f-8956-2646606892a0 cgroup_en able=memory cgroup_memory=1", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2063880 [ 0.000000] Policy zone: Normal [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [ 0.000000] software IO TLB: area num 8. [ 0.000000] software IO TLB: mapped [mem 0x00000000d4000000-0x00000000d8000000] (64MB) [ 0.000000] Memory: 7693968K/8386560K available (17920K kernel code, 2876K rwdata, 5628K rodata, 5056K init, 775K bss, 2993 76K reserved, 393216K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 0.000000] trace event string verifier disabled [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 480 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: MBI range [424:479] [ 0.000000] GICv3: Using MBI frame 0x00000000fe610000 [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 0.000000] ITS [mem 0xfe640000-0xfe65ffff] [ 0.000000] GIC: enabling workaround for ITS: Rockchip erratum RK3588001 [ 0.000000] ITS@0x00000000fe640000: allocated 8192 Devices @100110000 (indirect, esz 8, psz 64K, shr 0) [ 0.000000] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100120000 (flat, esz 2, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] ITS [mem 0xfe660000-0xfe67ffff] [ 0.000000] GIC: enabling workaround for ITS: Rockchip erratum RK3588001 [ 0.000000] ITS@0x00000000fe660000: allocated 8192 Devices @100140000 (indirect, esz 8, psz 64K, shr 0) [ 0.000000] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100150000 (flat, esz 2, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000100160000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000100170000 [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@100[1] /cpus/cpu@200[2] /cpus/cpu @300[3] } [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@400[4] /cpus/cpu@500[5] /cpus/cpu@600[6] /cpus/c pu@700[7] } [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001077] Console: colour dummy device 80x25 [ 0.001088] printk: legacy console [tty1] enabled [ 0.003109] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 0.003166] pid_max: default: 32768 minimum: 301 [ 0.005836] LSM: initializing lsm=capability,yama,apparmor,integrity [ 0.006887] Yama: becoming mindful. [ 0.006977] AppArmor: AppArmor initialized [ 0.007898] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.007933] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.011711] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1. [ 0.011806] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1. [ 0.012061] rcu: Hierarchical SRCU implementation. [ 0.012076] rcu: Max phase no-delay instances is 1000. [ 0.012956] Platform MSI: msi-controller@fe640000 domain created [ 0.012985] Platform MSI: msi-controller@fe660000 domain created [ 0.013248] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created [ 0.013285] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created [ 0.013893] EFI services will not be available. [ 0.014259] smp: Bringing up secondary CPUs ... [ 0.014748] Detected VIPT I-cache on CPU1 [ 0.014799] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 0.014815] GICv3: CPU1: using allocated LPI pending table @0x0000000100180000 [ 0.014851] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 0.015384] Detected VIPT I-cache on CPU2 [ 0.015431] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 0.015446] GICv3: CPU2: using allocated LPI pending table @0x0000000100190000 [ 0.015480] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 0.016016] Detected VIPT I-cache on CPU3 [ 0.016062] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 0.016076] GICv3: CPU3: using allocated LPI pending table @0x00000001001a0000 [ 0.016107] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 0.016684] CPU features: detected: Spectre-v4 [ 0.016688] CPU features: detected: Spectre-BHB [ 0.016692] Detected PIPT I-cache on CPU4 [ 0.016719] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 0.016727] GICv3: CPU4: using allocated LPI pending table @0x00000001001b0000 [ 0.016748] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 0.017262] Detected PIPT I-cache on CPU5 [ 0.017294] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 0.017303] GICv3: CPU5: using allocated LPI pending table @0x00000001001c0000 [ 0.017324] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 0.017779] Detected PIPT I-cache on CPU6 [ 0.017810] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 0.017818] GICv3: CPU6: using allocated LPI pending table @0x00000001001d0000 [ 0.017839] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 0.018322] Detected PIPT I-cache on CPU7 [ 0.018354] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 0.018363] GICv3: CPU7: using allocated LPI pending table @0x00000001001e0000 [ 0.018382] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 0.018438] smp: Brought up 1 node, 8 CPUs [ 0.018689] SMP: Total of 8 processors activated. [ 0.018700] CPU: All CPU(s) started at EL2 [ 0.018710] CPU features: detected: 32-bit EL0 Support [ 0.018722] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 0.018738] CPU features: detected: Common not Private translations [ 0.018750] CPU features: detected: CRC32 instructions [ 0.018763] CPU features: detected: RCpc load-acquire (LDAPR) [ 0.018775] CPU features: detected: LSE atomic instructions [ 0.018787] CPU features: detected: Privileged Access Never [ 0.018798] CPU features: detected: RAS Extension Support [ 0.018811] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 0.018867] alternatives: applying system-wide alternatives [ 0.021726] CPU features: detected: Hardware dirty bit management on CPU4-7 [ 0.024373] devtmpfs: initialized [ 0.031733] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 0.031754] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.034420] pinctrl core: initialized pinctrl subsystem [ 0.034580] DMI not present or invalid. [ 0.035263] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.035937] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 0.036161] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.036398] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.036417] audit: initializing netlink subsys (disabled) [ 0.036509] audit: type=2000 audit(0.033:1): state=initialized audit_enabled=0 res=1 [ 0.036819] thermal_sys: Registered thermal governor 'fair_share' [ 0.036822] thermal_sys: Registered thermal governor 'bang_bang' [ 0.036828] thermal_sys: Registered thermal governor 'step_wise' [ 0.036832] thermal_sys: Registered thermal governor 'user_space' [ 0.036836] thermal_sys: Registered thermal governor 'power_allocator' [ 0.036851] cpuidle: using governor ladder [ 0.036862] cpuidle: using governor menu [ 0.036991] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.037076] ASID allocator initialised with 65536 entries [ 0.037475] Serial: AMBA PL011 UART driver [ 0.041915] platform fdd90000.vop: Fixed dependency cycle(s) with /hdmi@fde80000 [ 0.041946] platform fde80000.hdmi: Fixed dependency cycle(s) with /vop@fdd90000 [ 0.049488] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.049698] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 0.049792] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.049886] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 0.049965] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.050050] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 0.050157] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.050242] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 0.050325] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.050409] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 0.051759] Modules: 24656 pages in range for non-PLT usage [ 0.051762] Modules: 516176 pages in range for PLT usage [ 0.052208] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.052217] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.052222] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.052226] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.052231] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.052235] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.052240] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.052244] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.052987] cryptd: max_cpu_qlen set to 1000 [ 0.108510] raid6: neonx8 gen() 5944 MB/s [ 0.165247] raid6: neonx4 gen() 5813 MB/s [ 0.221970] raid6: neonx2 gen() 5579 MB/s [ 0.278696] raid6: neonx1 gen() 4505 MB/s [ 0.335416] raid6: int64x8 gen() 2698 MB/s [ 0.392144] raid6: int64x4 gen() 3049 MB/s [ 0.448870] raid6: int64x2 gen() 2641 MB/s [ 0.505592] raid6: int64x1 gen() 2171 MB/s [ 0.505595] raid6: using algorithm neonx8 gen() 5944 MB/s [ 0.562308] raid6: .... xor() 4678 MB/s, rmw enabled [ 0.562312] raid6: using neon recovery algorithm [ 0.562517] ACPI: Interpreter disabled. [ 0.562873] iommu: Default domain type: Translated [ 0.562878] iommu: DMA domain TLB invalidation policy: strict mode [ 0.563751] SCSI subsystem initialized [ 0.563939] usbcore: registered new interface driver usbfs [ 0.563951] usbcore: registered new interface driver hub [ 0.563963] usbcore: registered new device driver usb [ 0.564115] pps_core: LinuxPPS API ver. 1 registered [ 0.564120] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.564128] PTP clock support registered [ 0.564297] EDAC MC: Ver: 3.0.0 [ 0.564485] scmi_core: SCMI protocol bus registered [ 0.564655] FPGA manager framework [ 0.564963] NetLabel: Initializing [ 0.564968] NetLabel: domain hash size = 128 [ 0.564972] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.564997] NetLabel: unlabeled traffic allowed by default [ 0.565071] vgaarb: loaded [ 0.565283] clocksource: Switched to clocksource arch_sys_counter [ 0.566303] VFS: Disk quotas dquot_6.6.0 [ 0.566410] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.566698] AppArmor: AppArmor Filesystem Enabled [ 0.566728] pnp: PnP ACPI: disabled [ 0.569285] NET: Registered PF_INET protocol family [ 0.569397] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.572652] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear) [ 0.572735] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.572774] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.573204] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 0.574414] TCP: Hash tables configured (established 65536 bind 65536) [ 0.574468] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.574595] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.574821] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.574838] NET: Registered PF_XDP protocol family [ 0.574846] PCI: CLS 0 bytes, default 64 [ 0.575006] Trying to unpack rootfs image as initramfs... [ 0.578750] kvm [1]: IPA Size Limit: 40 bits [ 0.578773] kvm [1]: GICv3: no GICV resource entry [ 0.578779] kvm [1]: disabling GICv2 emulation [ 0.578791] kvm [1]: GIC system register CPU interface enabled [ 0.578811] kvm [1]: vgic interrupt IRQ18 [ 0.578834] kvm [1]: VHE mode initialized successfully [ 0.579582] Initialise system trusted keyrings [ 0.579617] Key type blacklist registered [ 0.579728] workingset: timestamp_bits=42 max_order=21 bucket_order=0 [ 0.579753] zbud: loaded [ 0.582623] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.584227] ntfs: driver 2.1.32 [Flags: R/W]. [ 0.584388] ntfs3: Max link count 4000 [ 0.584392] ntfs3: Enabled Linux POSIX ACLs support [ 0.584396] ntfs3: Read-only LZX/Xpress compression included [ 0.584485] fuse: init (API version 7.39) [ 0.586245] integrity: Platform Keyring initialized [ 0.610564] xor: measuring software checksum speed [ 0.611713] 8regs : 8595 MB/sec [ 0.612883] 32regs : 8466 MB/sec [ 0.613688] arm64_neon : 12305 MB/sec [ 0.613692] xor: using function: arm64_neon (12305 MB/sec) [ 0.613699] Key type asymmetric registered [ 0.613703] Asymmetric key parser 'x509' registered [ 0.613738] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.613860] io scheduler mq-deadline registered [ 0.613865] io scheduler kyber registered [ 0.613937] io scheduler bfq registered [ 0.619450] EINJ: ACPI disabled. [ 0.620410] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.620420] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.620974] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.620982] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.621538] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.621546] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.623404] Serial: 8250/16550 driver, 8 ports, IRQ sharing enabled [ 0.624508] printk: legacy console [ttyS2] disabled [ 0.624602] feb50000.serial: ttyS2 at MMIO 0xfeb50000 (irq = 40, base_baud = 1500000) is a 16550A [ 0.624671] printk: legacy console [ttyS2] enabled [ 0.768949] Serial: AMBA driver [ 0.774827] brd: module loaded [ 0.777278] loop: module loaded [ 0.779600] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/regulators/dcdc-reg7 [ 0.780395] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs3-null-pins [ 0.781120] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs2-null-pins [ 0.781843] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs1-null-pins [ 0.783513] thunder_xcv, ver 1.0 [ 0.783808] thunder_bgx, ver 1.0 [ 0.784101] nicpf, ver 1.0 [ 0.784551] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version [ 0.785182] hns3: Copyright (c) 2017 Huawei Corporation. [ 0.785683] hclge is initializing [ 0.786563] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 0.787175] rk_gmac-dwmac fe1c0000.ethernet: supply phy not found, using dummy regulator [ 0.787929] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 0.788554] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x3a). [ 0.789059] rk_gmac-dwmac fe1c0000.ethernet: RX delay(0x3e). [ 0.789557] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 0.795107] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII [ 0.795709] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 0.796333] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 0.796784] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 0.797436] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 0.798089] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 0.798709] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 0.799291] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 0.799770] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 0.800468] rk_gmac-dwmac fe1c0000.ethernet: Enabled L3L4 Flow TC (entries=2) [ 0.801091] rk_gmac-dwmac fe1c0000.ethernet: Enabled RFS Flow TC (entries=10) [ 0.801715] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 0.802255] rk_gmac-dwmac fe1c0000.ethernet: SPH feature enabled [ 0.802780] rk_gmac-dwmac fe1c0000.ethernet: Using 32/32 bits DMA host/device width [ 1.591556] Freeing initrd memory: 38864K [ 1.748912] VFIO - User Level meta-driver version: 0.3 [ 1.769412] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.769920] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 1.770702] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000008002000010 [ 1.770946] ehci-platform fc880000.usb: EHCI Host Controller [ 1.770958] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 1.770988] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 2 [ 1.771039] ehci-platform fc800000.usb: EHCI Host Controller [ 1.771047] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 3 [ 1.771052] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 1.771080] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 4 [ 1.771090] ohci-platform fc8c0000.usb: irq 51, io mem 0xfc8c0000 [ 1.771093] ehci-platform fc800000.usb: irq 49, io mem 0xfc800000 [ 1.771210] ohci-platform fc840000.usb: irq 50, io mem 0xfc840000 [ 1.771572] xhci-hcd xhci-hcd.0.auto: irq 46, io mem 0xfc000000 [ 1.772044] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 5 [ 1.772089] ehci-platform fc880000.usb: irq 48, io mem 0xfc880000 [ 1.772770] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.779661] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6 [ 1.780347] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 1.781069] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08 [ 1.781812] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.781945] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 1.782469] usb usb1: Product: xHCI Host Controller [ 1.783431] usb usb1: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 xhci-hcd [ 1.784074] usb usb1: SerialNumber: xhci-hcd.0.auto [ 1.784901] hub 1-0:1.0: USB hub found [ 1.785265] hub 1-0:1.0: 1 port detected [ 1.785920] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.786716] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08 [ 1.787454] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.788098] usb usb6: Product: xHCI Host Controller [ 1.788534] usb usb6: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 xhci-hcd [ 1.789189] usb usb6: SerialNumber: xhci-hcd.0.auto [ 1.789929] hub 6-0:1.0: USB hub found [ 1.790290] hub 6-0:1.0: 1 port detected [ 1.790955] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08 [ 1.790987] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 1.791682] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.792805] usb usb3: Product: EHCI Host Controller [ 1.793232] usb usb3: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 ehci_hcd [ 1.793863] usb usb3: SerialNumber: fc800000.usb [ 1.794433] hub 3-0:1.0: USB hub found [ 1.794776] hub 3-0:1.0: 1 port detected [ 1.795243] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7 [ 1.795280] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 1.796031] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000008002000010 [ 1.796520] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08 [ 1.797329] xhci-hcd xhci-hcd.1.auto: irq 47, io mem 0xfcd00000 [ 1.798016] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.798132] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 1.798544] usb usb5: Product: EHCI Host Controller [ 1.798547] usb usb5: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 ehci_hcd [ 1.800718] usb usb5: SerialNumber: fc880000.usb [ 1.801272] hub 5-0:1.0: USB hub found [ 1.801609] hub 5-0:1.0: 1 port detected [ 1.802067] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8 [ 1.802758] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 1.803445] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08 [ 1.804184] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.804828] usb usb7: Product: xHCI Host Controller [ 1.805266] usb usb7: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 xhci-hcd [ 1.805920] usb usb7: SerialNumber: xhci-hcd.1.auto [ 1.806643] hub 7-0:1.0: USB hub found [ 1.807003] hub 7-0:1.0: 1 port detected [ 1.807634] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.808430] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08 [ 1.809186] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.809832] usb usb8: Product: xHCI Host Controller [ 1.810268] usb usb8: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 xhci-hcd [ 1.810911] usb usb8: SerialNumber: xhci-hcd.1.auto [ 1.811652] hub 8-0:1.0: USB hub found [ 1.812029] hub 8-0:1.0: 1 port detected [ 1.812693] usbcore: registered new interface driver usb-storage [ 1.815039] mousedev: PS/2 mouse device common for all mice [ 1.815812] i2c_dev: i2c /dev entries driver [ 1.818311] fan53555-regulator 0-0042: FAN53555 Option[10] Rev[1] Detected! [ 1.818757] fan53555-regulator 0-0043: FAN53555 Option[10] Rev[1] Detected! [ 1.818903] fan53555-regulator 2-0042: FAN53555 Option[10] Rev[1] Detected! [ 1.819378] platform fe470000.i2s: Fixed dependency cycle(s) with /i2c@fec90000/audio-codec@11 [ 1.820947] i2c 7-0011: Fixed dependency cycle(s) with /i2s@fe470000 [ 1.823743] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 1.828200] sdhci: Secure Digital Host Controller Interface driver [ 1.828769] sdhci: Copyright(c) Pierre Ossman [ 1.829397] Synopsys Designware Multimedia Card Interface Driver [ 1.829496] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.08 [ 1.830667] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.830800] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.831310] usb usb2: Product: Generic Platform OHCI controller [ 1.832353] usb usb2: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 ohci_hcd [ 1.832997] usb usb2: SerialNumber: fc8c0000.usb [ 1.833847] ledtrig-cpu: registered to indicate activity on CPUs [ 1.833859] hub 2-0:1.0: USB hub found [ 1.834576] No iBFT detected. [ 1.834745] hub 2-0:1.0: 1 port detected [ 1.835327] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16 [ 1.836190] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.08 [ 1.836233] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 1.836930] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.836974] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 1.837520] usb usb4: Product: Generic Platform OHCI controller [ 1.839392] usb usb4: Manufacturer: Linux 6.8.10-edge-rockchip-rk3588 ohci_hcd [ 1.840036] usb usb4: SerialNumber: fc840000.usb [ 1.840902] hub 4-0:1.0: USB hub found [ 1.841284] hub 4-0:1.0: 1 port detected [ 1.844987] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 1.845578] hid: raw HID events driver (C) Jiri Kosina [ 1.846052] usbcore: registered new interface driver usbhid [ 1.846540] usbhid: USB HID core driver [ 1.848319] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available [ 1.849645] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 counters available [ 1.850799] optee: probing for conduit method. [ 1.851190] optee: api uid mismatch [ 1.851496] optee: probe of firmware:optee failed with error -22 [ 1.852808] NET: Registered PF_INET6 protocol family [ 1.861676] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA [ 1.867898] mmc0: Failed to initialize a non-removable card [ 1.880059] Segment Routing with IPv6 [ 1.880899] In-situ OAM (IOAM) with IPv6 [ 1.881292] NET: Registered PF_PACKET protocol family [ 1.881933] 8021q: 802.1Q VLAN Support v1.8 [ 1.882339] Key type dns_resolver registered [ 1.886213] registered taskstats version 1 [ 1.886696] Loading compiled-in X.509 certificates [ 1.899162] zswap: loaded using pool zstd/z3fold [ 1.899852] Key type .fscrypt registered [ 1.900198] Key type fscrypt-provisioning registered [ 1.902291] Btrfs loaded, zoned=yes, fsverity=yes [ 1.902781] Key type encrypted registered [ 1.903135] AppArmor: AppArmor sha256 policy hashing enabled [ 1.903639] ima: No TPM chip found, activating TPM-bypass! [ 1.904124] ima: Allocated hash algorithm: sha1 [ 1.904543] ima: No architecture policies found [ 1.904954] evm: Initialising EVM extended attributes: [ 1.905430] evm: security.selinux [ 1.905721] evm: security.SMACK64 [ 1.906012] evm: security.SMACK64EXEC [ 1.906333] evm: security.SMACK64TRANSMUTE [ 1.906691] evm: security.SMACK64MMAP [ 1.907012] evm: security.apparmor [ 1.907309] evm: security.ima [ 1.907570] evm: security.capability [ 1.907883] evm: HMAC attrs: 0x1 [ 1.930628] rockchip-dw-pcie a41000000.pcie: host bridge /pcie@fe190000 ranges: [ 1.931313] rockchip-dw-pcie a41000000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 1.932121] rockchip-dw-pcie a41000000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000 [ 1.932907] rockchip-dw-pcie a41000000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0040000000 [ 1.933819] rockchip-dw-pcie a41000000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G [ 2.042014] usb 3-1: new high-speed USB device number 2 using ehci-platform [ 2.189432] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11 [ 2.190167] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 2.190803] usb 3-1: Product: USB 2.0 Hub [ 2.191601] hub 3-1:1.0: USB hub found [ 2.192129] hub 3-1:1.0: 4 ports detected [ 2.572005] usb 3-1.3: new high-speed USB device number 3 using ehci-platform [ 2.770349] usb 3-1.3: New USB device found, idVendor=a69c, idProduct=8d80, bcdDevice= 1.00 [ 2.771084] usb 3-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 2.771724] usb 3-1.3: Product: AIC Wlan [ 2.772076] usb 3-1.3: Manufacturer: aicsemi [ 2.772452] usb 3-1.3: SerialNumber: 20220103 [ 3.030064] rockchip-dw-pcie a41000000.pcie: Phy link never came up [ 3.031015] rockchip-dw-pcie a41000000.pcie: PCI host bridge to bus 0004:40 [ 3.031642] pci_bus 0004:40: root bus resource [bus 40-4f] [ 3.032159] pci_bus 0004:40: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 3.033009] pci_bus 0004:40: root bus resource [mem 0xf4200000-0xf4ffffff] [ 3.033622] pci_bus 0004:40: root bus resource [mem 0xa00000000-0xa3fffffff] (bus address [0x40000000-0x7fffffff]) [ 3.034563] pci 0004:40:00.0: [1d87:3588] type 01 class 0x060400 PCIe Root Port [ 3.035232] pci 0004:40:00.0: ROM [mem 0x00000000-0x0000ffff pref] [ 3.035794] pci 0004:40:00.0: PCI bridge to [bus 01-ff] [ 3.036266] pci 0004:40:00.0: bridge window [io 0x0000-0x0fff] [ 3.036810] pci 0004:40:00.0: bridge window [mem 0x00000000-0x000fffff] [ 3.037418] pci 0004:40:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref] [ 3.038153] pci 0004:40:00.0: supports D1 D2 [ 3.038537] pci 0004:40:00.0: PME# supported from D0 D1 D3hot [ 3.044943] pci 0004:40:00.0: Primary bus is hard wired to 0 [ 3.045465] pci 0004:40:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring [ 3.046434] pci_bus 0004:41: busn_res: [bus 41-4f] end is updated to 41 [ 3.047044] pci 0004:40:00.0: ROM [mem 0xf4200000-0xf420ffff pref]: assigned [ 3.047676] pci 0004:40:00.0: PCI bridge to [bus 41] [ 3.050647] pcieport 0004:40:00.0: PME: Signaling with IRQ 72 [ 3.051559] pcieport 0004:40:00.0: AER: enabled with IRQ 73 [ 3.053862] printk: legacy console [netcon0] enabled [ 3.054302] netconsole: network logging started [ 3.054813] psci_checker: PSCI checker started using 8 CPUs [ 3.055314] psci_checker: Starting hotplug tests [ 3.055720] psci_checker: Trying to turn off and on again all CPUs [ 3.057107] psci: CPU0 killed (polled 0 ms) [ 3.059227] psci: CPU1 killed (polled 0 ms) [ 3.061301] psci: CPU2 killed (polled 0 ms) [ 3.064184] psci: CPU3 killed (polled 0 ms) [ 3.065382] psci: CPU4 killed (polled 0 ms) [ 3.066687] psci: CPU5 killed (polled 0 ms) [ 3.067644] psci: CPU6 killed (polled 0 ms) [ 3.068832] Detected VIPT I-cache on CPU0 [ 3.069217] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 3.069858] CPU0: Booted secondary processor 0x0000000000 [0x412fd050] [ 3.071443] Detected VIPT I-cache on CPU1 [ 3.071828] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 3.072484] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 3.074121] Detected VIPT I-cache on CPU2 [ 3.074504] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 3.075160] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 3.076934] Detected VIPT I-cache on CPU3 [ 3.077315] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 3.077968] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 3.079695] Detected PIPT I-cache on CPU4 [ 3.080061] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 3.080699] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 3.082022] Detected PIPT I-cache on CPU5 [ 3.082389] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 3.083025] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 3.084423] Detected PIPT I-cache on CPU6 [ 3.084790] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 3.085426] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 3.086429] psci_checker: Trying to turn off and on again group 0 (CPUs 0-7) [ 3.087603] psci: CPU0 killed (polled 0 ms) [ 3.089213] psci: CPU1 killed (polled 0 ms) [ 3.090618] psci: CPU2 killed (polled 0 ms) [ 3.091945] psci: CPU3 killed (polled 4 ms) [ 3.093092] psci: CPU4 killed (polled 0 ms) [ 3.093970] psci: CPU5 killed (polled 0 ms) [ 3.094869] psci: CPU6 killed (polled 0 ms) [ 3.095862] Detected VIPT I-cache on CPU0 [ 3.096237] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 3.096873] CPU0: Booted secondary processor 0x0000000000 [0x412fd050] [ 3.098343] Detected VIPT I-cache on CPU1 [ 3.098720] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 3.099371] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 3.100893] Detected VIPT I-cache on CPU2 [ 3.101272] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 3.101923] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 3.103527] Detected VIPT I-cache on CPU3 [ 3.103906] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 3.104556] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 3.106246] Detected PIPT I-cache on CPU4 [ 3.106611] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 3.107248] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 3.108547] Detected PIPT I-cache on CPU5 [ 3.108913] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 3.109550] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 3.110876] Detected PIPT I-cache on CPU6 [ 3.111244] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 3.111880] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 3.112937] psci_checker: Hotplug tests passed OK [ 3.113355] psci_checker: Starting suspend tests (10 cycles per state) [ 3.114523] psci_checker: CPU 7 entering suspend cycles, states 1 through 1 [ 3.114524] psci_checker: CPU 6 entering suspend cycles, states 1 through 1 [ 3.114525] psci_checker: CPU 4 entering suspend cycles, states 1 through 1 [ 3.114526] psci_checker: CPU 5 entering suspend cycles, states 1 through 1 [ 3.114525] psci_checker: CPU 0 entering suspend cycles, states 1 through 1 [ 3.114526] psci_checker: CPU 1 entering suspend cycles, states 1 through 1 [ 3.114526] psci_checker: CPU 2 entering suspend cycles, states 1 through 1 [ 3.114528] psci_checker: CPU 3 entering suspend cycles, states 1 through 1 [ 3.152010] psci_checker: CPU 0 suspend test results: success 10, shallow states 0, errors 0 [ 3.152805] psci_checker: CPU 1 suspend test results: success 10, shallow states 0, errors 0 [ 3.153599] psci_checker: CPU 2 suspend test results: success 10, shallow states 0, errors 0 [ 3.154385] psci_checker: CPU 3 suspend test results: success 10, shallow states 0, errors 0 [ 3.155168] psci_checker: CPU 4 suspend test results: success 10, shallow states 0, errors 0 [ 3.155937] psci_checker: CPU 5 suspend test results: success 10, shallow states 0, errors 0 [ 3.156700] psci_checker: CPU 6 suspend test results: success 10, shallow states 0, errors 0 [ 3.157458] psci_checker: CPU 7 suspend test results: success 10, shallow states 0, errors 0 [ 3.158212] psci_checker: Suspend tests passed OK [ 3.158640] psci_checker: PSCI checker completed [ 3.159119] clk: Disabling unused clocks [ 3.160973] Freeing unused kernel memory: 5056K [ 3.161421] Run /init as init process [ 3.388745] rk_gmac-dwmac fe1c0000.ethernet end0: renamed from eth0 [ 13.282968] platform cpufreq-dt: deferred probe pending: (reason unknown) [ 13.283573] platform fec10000.adc: deferred probe pending: platform: wait for supplier /spi@feb20000/pmic@0/regulators/pldo -reg1 [ 61.715273] random: crng init done Please someone help 0 Quote
lyazide yaz Posted January 5, 2025 Posted January 5, 2025 Hello, Did you find a solution. I have the same problem here. Never had any issue for a year. I am thinking something coming from zfs. 0 Quote
eselarm Posted January 6, 2025 Posted January 6, 2025 20 hours ago, lyazide yaz said: I have the same problem here I think I don't believe that unless you post a similar serial log where we can see what U-Boot, kernel, etc is used. Board is: https://radxa.com/products/rock5/5c I have a RK3588S board running mainline U-Boot 2024.10 and kernel 6.12.6. Is headless (serial console) but if I connect HDMI, it runs KDE6 Wayland really great. I avoid ZFS, but use Linux native Btrfs. All runs from eMMC and/or NVMe. So my advise is, upgrade, maybe first try extra separate latest image from downloads, see if that boots OK. Then merge kernel+U-Boot from that into you non-working setup. That is manually copying things, but then likely no need to re-install everything. 0 Quote
