Armbian Bookworm OMV7 OdroidHC4
Go to solution Solved by fscii,
I was running Armbian Bullseye for a while with OMV 6.  I happened to see OMV has gone to v7 and Armbian to bookworm.
I went here to get the SBC/IOT bare version of bookworm:  https://www.armbian.com/odroid-hc4/
Problem 1:  is it said: "You are using an automated version meant only for developers..."
Problem 2:  it did not come with Armbian-config which I had to install manually
Problem 3:  Armbian-config 'softy' refused to install OMV saying it can only be installed on Buster (OMV5) or Bullseye (OMV6)
Finally: https://wiki.omv-extras.org/doku.php?id=omv7:armbian_bookworm_install  states specifically not to use any developer versions of the OS.
Is there a stable version of the OS where it comes with Armbian-config and softy will install OMV-7?   (If so, url's please)
How do I proceed?  For now going back to Bullseye OMV6  :(
Much thanks in advance.
Expand
This board is community maintained, not by the Armbian team. Therefore only untested automated builds are provided. https://docs.armbian.com/Board_Maintainers_Procedures_and_Guidelines/
Expand
This is intended for a minimal image. https://docs.armbian.com/User-Guide_FAQ/#i-cannot-find-armbian-config-on-my-device
Expand
armbian-config did not receive much attention since it is undergoing a major rewrite. However at the bottom line it doesn't do much more than calling an official way of installing. https://forum.armbian.com/topic/40598-status-of-armbian-configng/
Expand
Most they can do if you ignore this advice is to refuse support if something goes wrong.
topic moved
Try this method:
Not sure if prebuild exists for this target but you can follow instructions and DIY.
