zeyoner Posted August 5 Share Posted August 5 (edited) Attempting to install ZFS. But it seems that the latest linux headers are linux-headers-5.10.0-31-arm64. I am not able to install ZFS. Pretty sure I need to lower the kernel to match. sudo modprobe zfs modprobe: FATAL: Module zfs not found in directory /lib/modules/6.6.39-current-rockchip64 Installed linux-image-5.10.0.31-arm64. I also sudo apt-mark hold linux-image-5.10.0.31-arm64. But I do not know how to set the kernel to boot. Search tells me to use armbian-config. Had to install it and after running it the "Other" option is missing. There isn't any options to change the kernel. Edited August 5 by zeyoner 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 5 Share Posted August 5 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 30 minutes ago, zeyoner said: linux-image-5.10.0.31-arm64 Doesn't look like a kernel that came from Armbian. 0 Quote Link to comment Share on other sites More sharing options...
zeyoner Posted August 5 Author Share Posted August 5 (edited) ### lsusb: Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub /: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M ### Group membership of *REDACTED* : *REDACTED* tty disk dialout sudo audio video plugdev games users systemd-journal input netdev ssh docker ### Userland: PRETTY_NAME="Armbian 23.8.1 bullseye" ARMBIAN_PRETTY_NAME="Armbian 23.8.1 bullseye" ### Installed packages: rc armbian-bsp-cli-rockpi-4c 23.8.1 arm64 Armbian CLI BSP for board 'rockpi-4c' - transitional package ii armbian-bsp-cli-rockpi-4c-current 23.8.1 arm64 Armbian CLI BSP for board 'rockpi-4c' branch 'current' ii armbian-config 24.5.5 all Armbian configuration utility ii armbian-firmware 24.5.6 all Armbian - Linux firmware ii armbian-plymouth-theme 24.5.5 all boot animation, logger and I/O multiplexer - Armbian theme ii hostapd 3:2.10-6~armbian22.02.3+1 arm64 IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator ii htop 3.1.0-0~armbian20.08.2+1 arm64 interactive processes viewer ii linux-base 4.6 all Linux image base package ii linux-dtb-current-rockchip64 24.5.3 arm64 Armbian Linux current DTBs in /boot/dtb-6.6.39-current-rockchip64 ii linux-headers-5.10.0-31-arm64 5.10.221-1 arm64 Header files for Linux 5.10.0-31-arm64 ii linux-headers-5.10.0-31-common 5.10.221-1 all Common header files for Linux 5.10.0-31 ii linux-headers-arm64 5.10.221-1 arm64 Header files for Linux arm64 configuration (meta-package) hi linux-image-5.10.0-31-arm64 5.10.221-1 arm64 Linux 5.10 for 64-bit ARMv8 machines (signed) ii linux-image-current-rockchip64 24.5.3 arm64 Armbian Linux current kernel image 6.6.39-current-rockchip64 ii linux-kbuild-5.10 5.10.221-1 arm64 Kbuild infrastructure for Linux 5.10 ii linux-libc-dev:arm64 23.02.2 arm64 Armbian Linux support headers for userspace development ii linux-u-boot-rockpi-4c-current 24.5.1 arm64 Das U-Boot for rockpi-4c ### Loaded modules: Module Size Used by dm_crypt 49152 1 trusted 12288 1 dm_crypt dm_mod 126976 3 dm_crypt xt_conntrack 12288 1 nft_chain_nat 12288 3 xt_MASQUERADE 16384 1 nf_nat 45056 2 nft_chain_nat,xt_MASQUERADE nf_conntrack_netlink 45056 0 nf_conntrack 118784 4 xt_conntrack,nf_nat,nf_conntrack_netlink,xt_MASQUERADE nf_defrag_ipv6 20480 1 nf_conntrack nf_defrag_ipv4 12288 1 nf_conntrack xfrm_user 40960 1 xfrm_algo 12288 1 xfrm_user xt_addrtype 12288 2 nft_compat 16384 4 nf_tables 225280 75 nft_compat,nft_chain_nat nfnetlink 16384 4 nft_compat,nf_conntrack_netlink,nf_tables br_netfilter 28672 0 bridge 241664 1 br_netfilter lz4hc 12288 0 lz4 12288 0 zram 32768 3 raid1 45056 1 snd_soc_hdmi_codec 20480 1 snd_soc_simple_card 20480 0 brcmfmac_wcc 12288 0 md_mod 151552 2 raid1 snd_soc_audio_graph_card 16384 0 snd_soc_simple_card_utils 24576 2 snd_soc_audio_graph_card,snd_soc_simple_card snd_soc_spdif_tx 12288 0 dw_hdmi_i2s_audio 12288 0 hci_uart 135168 0 panfrost 69632 0 dw_hdmi_cec 12288 0 gpu_sched 36864 1 panfrost drm_shmem_helper 16384 1 panfrost rk_crypto 28672 0 btqca 20480 1 hci_uart rng_core 16384 1 rk_crypto snd_soc_rockchip_i2s 24576 4 btsdio 16384 0 btrtl 28672 1 hci_uart btintel 40960 1 hci_uart hantro_vpu 249856 0 rockchip_vdec 77824 0 snd_soc_es8316 36864 1 brcmfmac 368640 1 brcmfmac_wcc btbcm 20480 1 hci_uart snd_soc_core 208896 7 snd_soc_spdif_tx,snd_soc_hdmi_codec,snd_soc_audio_graph_card,snd_soc_simple_card_utils,snd_soc_rockchip_i2s,snd_soc_simple_card,snd_soc_es8316 v4l2_vp9 20480 2 rockchip_vdec,hantro_vpu rockchip_rga 20480 0 brcmutil 16384 1 brcmfmac bluetooth 663552 7 btrtl,btqca,btsdio,btintel,hci_uart,btbcm videobuf2_dma_contig 20480 2 rockchip_vdec,hantro_vpu snd_compress 24576 1 snd_soc_core v4l2_h264 16384 2 rockchip_vdec,hantro_vpu snd_pcm_dmaengine 12288 1 snd_soc_core v4l2_mem2mem 24576 3 rockchip_vdec,hantro_vpu,rockchip_rga videobuf2_dma_sg 16384 1 rockchip_rga cfg80211 802816 1 brcmfmac realtek 32768 1 snd_pcm 106496 6 snd_soc_hdmi_codec,snd_compress,snd_soc_simple_card_utils,snd_soc_core,snd_soc_es8316,snd_pcm_dmaengine videobuf2_memops 16384 2 videobuf2_dma_contig,videobuf2_dma_sg videobuf2_v4l2 20480 4 rockchip_vdec,hantro_vpu,rockchip_rga,v4l2_mem2mem sg 28672 0 snd_timer 36864 1 snd_pcm videodev 229376 5 rockchip_vdec,videobuf2_v4l2,hantro_vpu,rockchip_rga,v4l2_mem2mem rfkill 24576 5 bluetooth,cfg80211 snd 77824 5 snd_soc_hdmi_codec,snd_timer,snd_compress,snd_soc_core,snd_pcm videobuf2_common 49152 8 rockchip_vdec,videobuf2_dma_contig,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_dma_sg,v4l2_mem2mem,videobuf2_memops mc 53248 6 rockchip_vdec,videodev,videobuf2_v4l2,hantro_vpu,videobuf2_common,v4l2_mem2mem soundcore 12288 1 snd dwmac_rk 28672 0 stmmac_platform 20480 1 dwmac_rk stmmac 233472 3 stmmac_platform,dwmac_rk pcs_xpcs 20480 1 stmmac cpufreq_dt 16384 0 ip_tables 28672 0 x_tables 36864 5 xt_conntrack,nft_compat,xt_addrtype,ip_tables,xt_MASQUERADE autofs4 40960 2 ### nand-sata-install.log: ### Current system health: Time CPU n/a load %cpu %sys %usr %nice %io %irq Tcpu 23:45:28 --- 1.36 3% 1% 1% 0% 0% 0% 38.1 °C 23:45:29 --- 1.36 13% 5% 0% 0% 6% 0% 38.8 °C 23:45:29 --- 1.36 5% 4% 0% 0% 0% 0% 38.8 °C 23:45:29 --- 1.36 7% 5% 0% 0% 0% 0% 38.8 °C 23:45:30 --- 1.36 6% 5% 0% 0% 0% 0% 38.8 °C 23:45:30 --- 1.36 3% 1% 1% 0% 0% 0% 38.1 °C 23:45:31 --- 1.36 15% 14% 0% 0% 0% 0% 38.8 °C 23:45:31 --- 1.36 18% 12% 3% 0% 0% 1% 38.8 °C 23:45:31 --- 1.36 10% 2% 0% 0% 6% 0% 38.1 °C 23:45:32 --- 1.36 12% 6% 0% 0% 5% 0% 38.8 °C ### resolv.conf -rw-r--r-- 1 root root 82 Aug 4 22:13 /etc/resolv.conf # Generated by NetworkManager search mynetworksettings.com nameserver XXX.XXX.1.1 ### Current sysinfo: Linux 6.6.39-current-rockchip64 (*REDACTED*) 08/04/2024 _aarch64_ (6 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 1.08 0.00 1.74 0.47 0.00 96.70 Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd mmcblk0 5.36 98.19 124.17 0.00 556727 704048 0 mmcblk0p1 5.33 97.59 124.17 0.00 553295 704048 0 mmcblk0boot0 0.03 0.13 0.00 0.00 760 0 0 mmcblk0boot1 0.03 0.13 0.00 0.00 760 0 0 sda 51.97 25080.47 364.52 0.00 142201730 2066762 0 sda1 51.94 25079.83 364.52 0.00 142198110 2066762 0 sdb 51.81 1.29 25441.61 0.00 7333 144249354 0 sdb1 51.79 0.87 25441.61 0.00 4929 144249354 0 md127 1.38 3.09 363.63 0.00 17520 2061704 0 zram0 0.03 0.63 0.00 0.00 3552 4 0 zram1 1.84 0.49 9.49 0.00 2768 53804 0 zram2 0.00 0.00 0.00 0.00 0 0 0 dm-0 1.31 1.31 362.87 0.00 7401 2057404 0 --procs-- -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu-------- r b swpd free buff cache si so bi bo in cs us sy id wa st 1 0 0 2852696 87652 758476 0 0 17 84 72 79 1 2 97 0 0 total used free shared buff/cache available Mem: 3.8Gi 249Mi 2.7Gi 6.0Mi 826Mi 3.4Gi Swap: 1.9Gi 0B 1.9Gi NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT /dev/zram0 lzo-rle 1.9G 4K 74B 12K 6 [SWAP] /dev/zram1 zstd 50M 1.6M 169.1K 748K 6 /var/log 23:45:32 up 1:34, 2 users, load average: 1.41, 1.34, 1.13 [ 11.029453] systemd[1]: Mounting Kernel Trace File System... [ 11.036976] systemd[1]: Starting Restore / save the current clock... [ 11.043059] systemd[1]: Starting Set the console keyboard layout... [ 11.049490] systemd[1]: Starting Create list of static device nodes for the current kernel... [ 11.055273] systemd[1]: Starting Load Kernel Module configfs... [ 11.061097] systemd[1]: Starting Load Kernel Module drm... [ 11.067007] systemd[1]: Starting Load Kernel Module fuse... [ 11.074905] systemd[1]: Started Nameserver information manager. [ 11.076390] systemd[1]: Reached target Network (Pre). [ 11.078239] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 11.078532] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 11.085766] systemd[1]: Starting Load Kernel Modules... [ 11.092078] systemd[1]: Starting Remount Root and Kernel File Systems... [ 11.098340] systemd[1]: Starting Coldplug All udev Devices... [ 11.109477] systemd[1]: Mounted Huge Pages File System. [ 11.110442] systemd[1]: Mounted POSIX Message Queue File System. [ 11.111668] systemd[1]: Mounted Kernel Debug File System. [ 11.112610] systemd[1]: Mounted Kernel Trace File System. [ 11.115214] systemd[1]: Finished Restore / save the current clock. [ 11.118234] systemd[1]: Finished Create list of static device nodes for the current kernel. [ 11.120119] systemd[1]: modprobe@configfs.service: Succeeded. [ 11.121741] systemd[1]: Finished Load Kernel Module configfs. [ 11.123734] systemd[1]: modprobe@drm.service: Succeeded. [ 11.125235] systemd[1]: Finished Load Kernel Module drm. [ 11.127108] systemd[1]: modprobe@fuse.service: Succeeded. [ 11.128707] systemd[1]: Finished Load Kernel Module fuse. [ 11.133332] systemd[1]: Finished Load Kernel Modules. [ 11.176850] systemd[1]: Mounting FUSE Control File System... [ 11.185205] systemd[1]: Mounting Kernel Configuration File System... [ 11.192924] EXT4-fs (mmcblk0p1): re-mounted 58156628-a1ec-48f7-971d-8c646a89e424 r/w. Quota mode: none. [ 11.193739] systemd[1]: Starting Apply Kernel Variables... [ 11.206913] systemd[1]: Finished Remount Root and Kernel File Systems. [ 11.208080] systemd[1]: Mounted FUSE Control File System. [ 11.208832] systemd[1]: Mounted Kernel Configuration File System. [ 11.211070] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 11.211572] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 11.219188] systemd[1]: Starting Load/Save Random Seed... [ 11.228196] systemd[1]: Starting Create System Users... [ 11.252755] systemd[1]: Finished Apply Kernel Variables. [ 11.299605] systemd[1]: Finished Load/Save Random Seed. [ 11.302490] systemd[1]: Finished Create System Users. [ 11.303527] systemd[1]: Condition check resulted in First Boot Complete being skipped. [ 11.308998] systemd[1]: Starting Create Static Device Nodes in /dev... [ 11.377873] systemd[1]: Finished Set the console keyboard layout. [ 11.380851] systemd[1]: Finished Create Static Device Nodes in /dev. [ 11.381677] systemd[1]: Reached target Local File Systems (Pre). [ 11.412109] systemd[1]: Mounting /tmp... [ 11.421698] systemd[1]: Starting Rule-based Manager for Device Events and Files... [ 11.430419] systemd[1]: Mounted /tmp. [ 11.539254] systemd[1]: Started Rule-based Manager for Device Events and Files. [ 11.688082] systemd[1]: Finished Coldplug All udev Devices. [ 11.732929] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 11.744740] systemd[1]: Starting Show Plymouth Boot Screen... [ 11.754511] systemd[1]: Starting Wait for udev To Complete Device Initialization... [ 11.767593] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 11.818605] cpu cpu0: OPP table can't be empty [ 11.819767] systemd[1]: Started Show Plymouth Boot Screen. [ 11.820700] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 11.821404] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch. [ 11.821630] systemd[1]: Reached target Paths. [ 11.913384] systemd[1]: Found device /dev/ttyS2. [ 11.930685] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found [ 11.930708] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found [ 11.930861] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock [ 11.931113] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ 11.931128] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ 11.931141] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11). [ 11.931159] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no). [ 11.931216] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ 11.947395] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ 11.947901] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35 [ 11.947926] rk_gmac-dwmac fe300000.ethernet: DWMAC1000 [ 11.947938] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported [ 11.947948] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported [ 11.947957] rk_gmac-dwmac fe300000.ethernet: COE Type 2 [ 11.947967] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported [ 11.947976] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported [ 11.948112] rk_gmac-dwmac fe300000.ethernet: Normal descriptors [ 11.948124] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled [ 11.948133] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 11.956858] mc: Linux media interface: v0.10 [ 12.006164] videodev: Linux video capture interface: v2.00 [ 12.024337] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 12.037495] sd 3:0:0:0: Attached scsi generic sg1 type 0 [ 12.086013] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 12.088325] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 12.089990] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 12.106142] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid [ 12.113244] rockchip-rga ff680000.rga: HW Version: 0x03.02 [ 12.116359] Bluetooth: Core ver 2.22 [ 12.119692] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0 [ 12.124169] NET: Registered PF_BLUETOOTH protocol family [ 12.124200] Bluetooth: HCI device and connection manager initialized [ 12.124230] Bluetooth: HCI socket layer initialized [ 12.124246] Bluetooth: L2CAP socket layer initialized [ 12.124312] Bluetooth: SCO socket layer initialized [ 12.152862] RTL8211E Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL) [ 12.152889] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL) [ 12.155279] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned. [ 12.163118] brcmfmac: F1 signature read @0x18000000=0x15294345 [ 12.165874] hantro-vpu ff650000.video-codec: Adding to iommu group 0 [ 12.167496] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1 [ 12.167575] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9 [ 12.169043] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.radxa,rockpi4c.bin failed with error -2 [ 12.179711] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2 [ 12.187906] usbcore: registered new interface driver brcmfmac [ 12.189377] rkvdec ff660000.video-codec: Adding to iommu group 1 [ 12.326236] rk3288-crypto ff8b0000.crypto: will run requests pump with realtime priority [ 12.326355] rk3288-crypto ff8b0000.crypto: Register ecb(aes) as ecb-aes-rk [ 12.326471] rk3288-crypto ff8b0000.crypto: Register cbc(aes) as cbc-aes-rk [ 12.326515] rk3288-crypto ff8b0000.crypto: Register ecb(des) as ecb-des-rk [ 12.326556] rk3288-crypto ff8b0000.crypto: Register cbc(des) as cbc-des-rk [ 12.326597] rk3288-crypto ff8b0000.crypto: Register ecb(des3_ede) as ecb-des3-ede-rk [ 12.326638] rk3288-crypto ff8b0000.crypto: Register cbc(des3_ede) as cbc-des3-ede-rk [ 12.326679] rk3288-crypto ff8b0000.crypto: Register sha1 as rk-sha1 [ 12.326722] rk3288-crypto ff8b0000.crypto: Register sha256 as rk-sha256 [ 12.326765] rk3288-crypto ff8b0000.crypto: Register md5 as rk-md5 [ 12.326806] rk3288-crypto ff8b0000.crypto: Register TRNG with sample=1200 [ 12.372159] panfrost ff9a0000.gpu: clock rate = 500000000 [ 12.375101] rk3288-crypto ff8b8000.crypto: will run requests pump with realtime priority [ 12.401373] Bluetooth: HCI UART driver ver 2.3 [ 12.401406] Bluetooth: HCI UART protocol H4 registered [ 12.401417] Bluetooth: HCI UART protocol BCSP registered [ 12.404734] Bluetooth: HCI UART protocol LL registered [ 12.404763] Bluetooth: HCI UART protocol ATH3K registered [ 12.404867] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 12.405167] Bluetooth: HCI UART protocol Intel registered [ 12.405545] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0 [ 12.405571] panfrost ff9a0000.gpu: features: 00000000,00000407, issues: 00000000,24040400 [ 12.405590] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 [ 12.405612] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1 [ 12.406923] Bluetooth: HCI UART protocol Broadcom registered [ 12.407046] Bluetooth: HCI UART protocol QCA registered [ 12.407059] Bluetooth: HCI UART protocol AG6XX registered [ 12.407149] Bluetooth: HCI UART protocol Marvell registered [ 12.412904] [drm] Initialized panfrost 1.2.0 20180908 for ff9a0000.gpu on minor 1 [ 12.523684] dw-apb-uart ff180000.serial: failed to request DMA [ 12.536248] asoc-audio-graph-card sound: ASoC: DAPM unknown pin Headphones [ 12.691413] asoc-audio-graph-card sound: ASoC: DAPM unknown pin Headphones [ 12.700558] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2) [ 12.701713] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Jun 16 2017 12:38:26 version XXX.XXX.96.2 (66c4e21@sh-git) (r) FWID 01-1813af84 [ 12.724993] input: Analog Headphones as /devices/platform/sound/sound/card0/input0 [ 12.775738] block device autoloading is deprecated and will be removed. [ 12.800391] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 12.801321] Bluetooth: hci0: BCM: chip id 130 [ 12.802223] Bluetooth: hci0: BCM: features 0x0f [ 12.805097] Bluetooth: hci0: BCM4345C5 [ 12.805136] Bluetooth: hci0: BCM4345C5 (003.006.006) build 0000 [ 12.807564] Bluetooth: hci0: BCM4345C5 'brcm/BCM4345C5.hcd' Patch [ 12.864598] systemd[1]: Starting Load/Save RF Kill Switch Status... [ 13.008216] md/raid1:md127: not clean -- starting background reconstruction [ 13.008246] md/raid1:md127: active with 2 out of 2 mirrors [ 13.042626] systemd[1]: Started Load/Save RF Kill Switch Status. [ 13.086290] systemd[1]: Started Timer to wait for more drives before activating degraded array md127.. [ 13.086513] systemd[1]: Reached target Bluetooth. [ 13.086647] systemd[1]: Reached target Sound Card. [ 13.186104] md127: detected capacity change from 0 to 1953257472 [ 13.334598] systemd[1]: mdadm-last-resort@md127.timer: Succeeded. [ 13.334645] systemd[1]: Stopped Timer to wait for more drives before activating degraded array md127.. [ 13.364253] systemd[1]: Started MD array monitor. [ 13.404853] systemd[1]: Finished Wait for udev To Complete Device Initialization. [ 13.718326] Bluetooth: hci0: BCM: features 0x0f [ 13.722257] Bluetooth: hci0: BCM4345C5 Ampak_CL1 UART 37.4 MHz BT 5.0 [Version: Version: 0039.0089] [ 13.722297] Bluetooth: hci0: BCM4345C5 (003.006.006) build 0089 [ 18.015740] systemd[1]: systemd-rfkill.service: Succeeded. [ 23.008896] platform sound-dit: deferred probe pending [ 101.050295] systemd[1]: dev-disk-by-uuid-1efe5ff5-c91e-4181-beb3-67d382095a5e.device: Job dev-disk-by-uuid-1efe5ff5-c91e-4181-beb3-67d382095a5e.device/start timed out. [ 101.050338] systemd[1]: Timed out waiting for device /dev/disk/by-uuid/1efe5ff5-c91e-4181-beb3-67d382095a5e. [ 101.050538] systemd[1]: Dependency failed for Cryptography Setup for luks-1efe5ff5-c91e-4181-beb3-67d382095a5e. [ 101.050651] systemd[1]: Dependency failed for Local Encrypted Volumes. [ 101.050756] systemd[1]: cryptsetup.target: Job cryptsetup.target/start failed with result 'dependency'. [ 101.050823] systemd[1]: systemd-cryptsetup@luks-1efe5ff5-c91e-4181-beb3-67d382095a5e.service: Job systemd-cryptsetup@luks-1efe5ff5-c91e-4181-beb3-67d382095a5e.service/start failed with result 'dependency'. [ 101.050869] systemd[1]: dev-disk-by-uuid-1efe5ff5-c91e-4181-beb3-67d382095a5e.device: Job dev-disk-by-uuid-1efe5ff5-c91e-4181-beb3-67d382095a5e.device/start failed with result 'timeout'. [ 101.050954] systemd[1]: dev-disk-by-uuid-30e48ec2-bb9f-49e0-afd1-71f5dccd2435.device: Job dev-disk-by-uuid-30e48ec2-bb9f-49e0-afd1-71f5dccd2435.device/start timed out. [ 101.050974] systemd[1]: Timed out waiting for device /dev/disk/by-uuid/30e48ec2-bb9f-49e0-afd1-71f5dccd2435. [ 101.051138] systemd[1]: Dependency failed for Cryptography Setup for luks-30e48ec2-bb9f-49e0-afd1-71f5dccd2435. [ 101.051284] systemd[1]: systemd-cryptsetup@luks-30e48ec2-bb9f-49e0-afd1-71f5dccd2435.service: Job systemd-cryptsetup@luks-30e48ec2-bb9f-49e0-afd1-71f5dccd2435.service/start failed with result 'dependency'. [ 101.051396] systemd[1]: dev-disk-by-uuid-30e48ec2-bb9f-49e0-afd1-71f5dccd2435.device: Job dev-disk-by-uuid-30e48ec2-bb9f-49e0-afd1-71f5dccd2435.device/start failed with result 'timeout'. [ 101.051548] systemd[1]: Reached target Block Device Preparation for /dev/mapper/luks-1efe5ff5-c91e-4181-beb3-67d382095a5e. [ 101.052379] systemd[1]: Reached target Block Device Preparation for /dev/mapper/luks-30e48ec2-bb9f-49e0-afd1-71f5dccd2435. [ 101.088408] systemd[1]: Starting Install ZFS kernel module... [ 101.089415] systemd[1]: Stopped target Block Device Preparation for /dev/mapper/luks-1efe5ff5-c91e-4181-beb3-67d382095a5e. [ 101.089623] systemd[1]: Stopped target Block Device Preparation for /dev/mapper/luks-30e48ec2-bb9f-49e0-afd1-71f5dccd2435. [ 101.100061] systemd[1]: zfs-load-module.service: Main process exited, code=exited, status=1/FAILURE [ 101.100924] systemd[1]: zfs-load-module.service: Failed with result 'exit-code'. [ 101.102723] systemd[1]: Failed to start Install ZFS kernel module. [ 101.102944] systemd[1]: Dependency failed for Import ZFS pools by cache file. [ 101.103070] systemd[1]: zfs-import-cache.service: Job zfs-import-cache.service/start failed with result 'dependency'. [ 101.103618] systemd[1]: Reached target ZFS pool import target. [ 101.103825] systemd[1]: Condition check resulted in Mount ZFS filesystems being skipped. [ 101.103918] systemd[1]: Reached target Local File Systems. [ 101.109267] systemd[1]: Starting Armbian leds state... [ 101.115048] systemd[1]: Starting Armbian ZRAM config... [ 101.121155] systemd[1]: Starting Set console font and keymap... [ 101.127712] systemd[1]: Starting Raise network interfaces... [ 101.134102] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 101.134557] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 101.134809] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 101.134956] systemd[1]: Condition check resulted in Wait for ZFS Volume (zvol) links in /dev being skipped. [ 101.135105] systemd[1]: Reached target ZFS volumes are ready. [ 101.150780] systemd[1]: Finished Set console font and keymap. [ 101.152479] systemd[1]: Received SIGRTMIN+20 from PID 270 (plymouthd). [ 101.158406] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 101.218457] systemd[1]: Finished Armbian leds state. [ 101.322310] zram: Added device: zram0 [ 101.323687] zram: Added device: zram1 [ 101.324852] zram: Added device: zram2 [ 101.421341] zram0: detected capacity change from 0 to 3952888 [ 101.461798] Adding 1976440k swap on /dev/zram0. Priority:5 extents:1 across:1976440k SS [ 101.484675] systemd[1]: Finished Raise network interfaces. [ 101.696246] zram1: detected capacity change from 0 to 102400 [ 101.755534] systemd[1]: Finished Armbian ZRAM config. [ 101.797108] systemd[1]: Starting Armbian memory supported logging... [ 101.897210] EXT4-fs (zram1): mounted filesystem 24de4176-fb3a-49d5-bf49-baf1c2b1b99b r/w without journal. Quota mode: none. [ 101.897287] ext4 filesystem being mounted at /var/log supports timestamps until 2038-01-19 (0x7fffffff) [ 117.158724] systemd[1]: Finished Armbian memory supported logging. [ 117.188825] systemd[1]: Starting Journal Service... [ 117.595993] systemd[1]: Started Journal Service. [ 117.680099] systemd-journald[657]: Received client request to flush runtime journal. [ 118.809081] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 120.219836] rk_gmac-dwmac fe300000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 120.229515] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211E Gigabit Ethernet] (irq=POLL) [ 120.229571] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found [ 120.229595] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW [ 120.231528] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode [ 124.295179] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 124.301982] Bridge firewalling registered [ 124.328027] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ 125.022086] Initializing XFRM netlink socket [ 128.462731] systemd-journald[657]: Received client request to flush runtime journal. [ 129.138946] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 198.475560] systemd[2453]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set [ 246.674030] systemd-journald[657]: Received client request to flush runtime journal. [ 246.750322] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 1146.740058] systemd-journald[657]: Received client request to flush runtime journal. [ 1146.808901] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 2046.709361] systemd-journald[657]: Received client request to flush runtime journal. [ 2046.789845] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 2946.702604] systemd-journald[657]: Received client request to flush runtime journal. [ 2946.775122] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 3846.684206] systemd-journald[657]: Received client request to flush runtime journal. [ 3846.776059] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 4184.598033] md: resync of RAID array md127 [ 4189.064476] device-mapper: uevent: version 1.0.3 [ 4189.065162] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com [ 4212.546008] EXT4-fs (dm-0): mounted filesystem 5602eb7e-12b3-42fb-9798-1556b2a90df5 r/w with ordered data mode. Quota mode: none. [ 4746.765355] systemd-journald[657]: Received client request to flush runtime journal. [ 4746.826781] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. [ 5462.651092] systemd-journald[657]: Received client request to flush runtime journal. [ 5462.716166] systemd-journald[657]: Received client request to relinquish /var/log/journal/515cf686f9604730835651798a8c6e08 access. vm.admin_reserve_kbytes = 8192 vm.compaction_proactiveness = 20 vm.compact_unevictable_allowed = 1 vm.dirty_background_bytes = 0 vm.dirty_background_ratio = 10 vm.dirty_bytes = 0 vm.dirty_expire_centisecs = 3000 vm.dirty_ratio = 20 vm.dirtytime_expire_seconds = 43200 vm.dirty_writeback_centisecs = 500 vm.extfrag_threshold = 500 vm.hugetlb_shm_group = 0 vm.laptop_mode = 0 vm.legacy_va_layout = 0 vm.lowmem_reserve_ratio = 256 256 32 0 vm.max_map_count = 65530 vm.memfd_noexec = 0 vm.min_free_kbytes = 22528 vm.min_slab_ratio = 5 vm.min_unmapped_ratio = 1 vm.mmap_min_addr = 4096 vm.mmap_rnd_bits = 18 vm.mmap_rnd_compat_bits = 11 vm.nr_hugepages = 0 vm.nr_hugepages_mempolicy = 0 vm.nr_overcommit_hugepages = 0 vm.numa_stat = 1 vm.numa_zonelist_order = Node vm.oom_dump_tasks = 1 vm.oom_kill_allocating_task = 0 vm.overcommit_kbytes = 0 vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.page-cluster = 0 vm.page_lock_unfairness = 5 vm.panic_on_oom = 0 vm.percpu_pagelist_high_fraction = 0 vm.stat_interval = 1 vm.swappiness = 100 vm.user_reserve_kbytes = 121725 vm.vfs_cache_pressure = 100 vm.watermark_boost_factor = 15000 vm.watermark_scale_factor = 10 vm.zone_reclaim_mode = 0 ### interrupts: CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 18: 0 0 0 0 0 0 GICv3 25 Level vgic 20: 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer 23: 54633 65433 62030 49947 115779 61484 GICv3 30 Level arch_timer 25: 83504 64289 75597 60595 90417 72349 GICv3 113 Level rk_timer 31: 0 0 0 0 0 0 GICv3 37 Level ff6d0000.dma-controller 32: 0 0 0 0 0 0 GICv3 38 Level ff6d0000.dma-controller 33: 0 0 0 0 0 0 GICv3 39 Level ff6e0000.dma-controller 34: 0 0 0 0 0 0 GICv3 40 Level ff6e0000.dma-controller 35: 1236 0 0 0 0 0 GICv3 131 Level ttyS0 36: 693 0 0 0 0 0 GICv3 132 Level ttyS2 37: 0 0 0 0 0 0 GICv3 147 Level ff650800.iommu 38: 0 0 0 0 0 0 GICv3 149 Level ff660480.iommu 39: 0 0 0 0 0 0 GICv3 151 Level ff8f3f00.iommu, ff8f0000.vop 40: 0 0 0 0 0 0 GICv3 150 Level ff903f00.iommu, ff900000.vop 41: 0 0 0 0 0 0 GICv3 75 Level ff914000.iommu 42: 0 0 0 0 0 0 GICv3 76 Level ff924000.iommu 43: 66 0 0 0 0 0 GICv3 91 Level ff110000.i2c 44: 0 0 0 0 0 0 GICv3 66 Level ff130000.i2c 45: 61977 0 0 0 0 0 GICv3 68 Level ff160000.i2c 46: 429 0 0 0 0 0 GICv3 89 Level ff3c0000.i2c 47: 0 0 0 0 0 0 GICv3 88 Level ff3d0000.i2c 48: 0 0 0 0 0 0 GICv3 129 Level rockchip_thermal 49: 0 0 0 0 0 0 GICv3 152 Edge ff848000.watchdog 50: 9719 0 0 0 0 0 GICv3 96 Level dw-mci 51: 0 0 0 0 0 0 GICv3 97 Level dw-mci 52: 36031 0 0 0 0 0 GICv3 43 Level mmc0 53: 3 0 0 0 0 0 GICv3 94 Level ff100000.saradc 54: 0 0 0 0 0 0 GICv3-23 0 Level arm-pmu 55: 0 0 0 0 0 0 GICv3-23 1 Level arm-pmu 56: 0 0 0 0 0 0 rockchip_gpio_irq 7 Edge fe320000.mmc cd 57: 0 0 0 0 0 0 GICv3 59 Level rockchip_usb2phy 58: 0 0 0 0 0 0 GICv3 63 Level rockchip_usb2phy 59: 0 0 0 0 0 0 GICv3 137 Level xhci-hcd:usb1 60: 0 0 0 0 0 0 GICv3 142 Level xhci-hcd:usb3 61: 0 0 0 0 0 0 GICv3 58 Level ehci_hcd:usb5 62: 0 0 0 0 0 0 GICv3 62 Level ehci_hcd:usb7 63: 0 0 0 0 0 0 GICv3 60 Level ohci_hcd:usb6 64: 0 0 0 0 0 0 rockchip_gpio_irq 21 Level rk808 70: 0 0 0 0 0 0 rk808 5 Edge RTC alarm 74: 0 0 0 0 0 0 GICv3 64 Level ohci_hcd:usb8 75: 0 0 0 0 0 0 GICv3 81 Level pcie-sys 77: 154 0 0 0 0 0 GICv3 83 Level pcie-client 79: 0 0 0 0 0 0 ITS-MSI 0 Edge PCIe PME, aerdrv 80: 0 300801 0 0 0 0 ITS-MSI 524288 Edge ahci0 81: 0 0 0 0 0 0 ITS-MSI 524289 Edge ahci1 82: 0 0 0 0 0 0 ITS-MSI 524290 Edge ahci2 83: 0 0 0 0 166292 0 ITS-MSI 524291 Edge ahci3 84: 0 0 0 0 0 0 ITS-MSI 524292 Edge ahci4 88: 0 0 0 0 0 0 GICv3 55 Level ff940000.hdmi, dw-hdmi-cec 89: 25429 0 0 0 0 0 GICv3 44 Level eth0 90: 0 0 0 0 0 0 GICv3 87 Level ff680000.rga 91: 0 0 0 0 0 0 rockchip_gpio_irq 1 Level es8316 92: 0 0 0 0 0 0 GICv3 146 Level ff650000.video-codec 93: 0 0 0 0 0 0 GICv3 145 Level ff650000.video-codec 94: 335 0 0 0 0 0 rockchip_gpio_irq 3 Level brcmf_oob_intr 95: 0 0 0 0 0 0 GICv3 148 Level ff660000.video-codec 96: 0 0 0 0 0 0 GICv3 32 Level rk-crypto 97: 0 0 0 0 0 0 GICv3 167 Level rk-crypto 98: 0 0 0 0 0 0 GICv3 51 Level panfrost-gpu 99: 0 0 0 0 0 0 GICv3 53 Level panfrost-mmu 100: 6 0 0 0 0 0 rockchip_gpio_irq 4 Edge host_wake 101: 0 0 0 0 0 0 GICv3 52 Level panfrost-job 102: 0 0 0 0 0 0 rockchip_gpio_irq 0 Edge Headphone detection IPI0: 7051 6118 5124 6091 4565 4011 Rescheduling interrupts IPI1: 142253 90762 189514 163483 115662 95731 Function call interrupts IPI2: 0 0 0 0 0 0 CPU stop interrupts IPI3: 0 0 0 0 0 0 CPU stop (for crash dump) interrupts IPI4: 22657 24662 28699 29222 29184 28897 Timer broadcast interrupts IPI5: 0 0 0 0 0 0 IRQ work interrupts IPI6: 0 0 0 0 0 0 CPU wake-up interrupts Err: 0 Edited August 5 by zeyoner 0 Quote Link to comment Share on other sites More sharing options...
zeyoner Posted August 5 Author Share Posted August 5 (edited) Did some more searching and came across a post of yours. Quote After sudo apt update && apt upgrade -y && linux-headers-current-rockchip64 Followed by some cleaning up and undoing of the other kernel. Reinstalled zfsutils-linux zfs-dkms zfs-zed packages and ran into errors. Setting up zfs-dkms (2.0.3-9+deb11u1) ... Removing old zfs-2.0.3 DKMS files... ------------------------------ Deleting module version: 2.0.3 completely from the DKMS tree. ------------------------------ Done. Loading new zfs-2.0.3 DKMS files... Building for 6.6.39-current-rockchip64 Building initial module for 6.6.39-current-rockchip64 configure: error: *** None of the expected "PDE_DATA" interfaces were detected. *** This may be because your kernel version is newer than what is *** supported, or you are using a patched custom kernel with *** incompatible modifications. *** *** ZFS Version: zfs-2.0.3-9+deb11u1 *** Compatible Kernels: 3.10 - 5.10 Error! Bad return status for module build on kernel: 6.6.39-current-rockchip64 (aarch64) Consult /var/lib/dkms/zfs/2.0.3/build/make.log for more information. dpkg: error processing package zfs-dkms (--configure): installed zfs-dkms package post-installation script subprocess returned error exit status 10 dpkg: dependency problems prevent configuration of zfs-zed: zfs-zed depends on zfs-modules | zfs-dkms; however: Package zfs-modules is not installed. Package zfs-dkms which provides zfs-modules is not configured yet. Package zfs-dkms is not configured yet. dpkg: error processing package zfs-zed (--configure): dependency problems - leaving unconfigured Processing triggers for initramfs-tools (0.140) ... update-initramfs: Generating /boot/initrd.img-6.6.39-current-rockchip64 update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.6.39-current-rockchip64 Image Name: uInitrd Created: Mon Aug 5 02:43:51 2024..............................................................................] Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 20403257 Bytes = 19925.06 KiB = 19.46 MiB Load Address: 00000000 Entry Point: 00000000 update-initramfs: Armbian: Symlinking /boot/uInitrd-6.6.39-current-rockchip64 to /boot/uInitrd '/boot/uInitrd' -> 'uInitrd-6.6.39-current-rockchip64' update-initramfs: Armbian: done. Errors were encountered while processing: zfs-dkms zfs-zed E: Sub-process /usr/bin/dpkg returned an error code (1) /var/lib/dkms/zfs/2.0.3/build/make.log: DKMS make.log for zfs-2.0.3 for kernel 6.6.39-current-rockchip64 (aarch64) Mon 05 Aug 2024 02:42:54 AM EDT make: *** No targets specified and no makefile found. Stop. Seems as though I have to use kernel 5.10...? Edited August 5 by zeyoner 0 Quote Link to comment Share on other sites More sharing options...
Solution Igor Posted August 5 Solution Share Posted August 5 2 hours ago, zeyoner said: I have to use kernel 5.10...? No. You need more recent ZFS, which comes with supported Armbian OS, which is Bookworm. Bullseye generally works, but we don't support it anymore as upstream is also deserting it. We ship ZFS v2.2.4, soon upgrading to 2.2.5, but only on: 5 hours ago, zeyoner said: ii linux-headers-5.10.0-31-arm64 5.10.221-1 arm64 Header files for Linux 5.10.0-31-arm64 ii linux-headers-5.10.0-31-common 5.10.221-1 all Common header files for Linux 5.10.0-31 ii linux-headers-arm64 5.10.221-1 arm64 Header files for Linux arm64 configuration (meta-package) hi linux-image-5.10.0-31-arm64 5.10.221-1 arm64 Linux 5.10 for 64-bit ARMv8 machines (signed) All those headers are useless, remove them, also generic kernel 5.10 as it probably won't even boot. You need: apt install linux-headers-current-rockchip64 Fresh Bookworm image, same (sub)arch: Spoiler Loading new zfs-2.2.4 DKMS files... Building for 6.6.39-current-rockchip64 Building initial module for 6.6.39-current-rockchip64 Done. zfs.ko: Running module version sanity check. - Original module - No original module exists within this kernel - Installation - Installing to /lib/modules/6.6.39-current-rockchip64/updates/dkms/ spl.ko: Running module version sanity check. - Original module - No original module exists within this kernel - Installation - Installing to /lib/modules/6.6.39-current-rockchip64/updates/dkms/ depmod..... root@odroidm1:/home/igorp# modinfo zfs filename: /lib/modules/6.6.39-current-rockchip64/updates/dkms/zfs.ko version: 2.2.4-1~bpo12+1 license: CDDL license: Dual BSD/GPL license: Dual MIT/GPL author: OpenZFS description: ZFS alias: zzstd alias: zcommon alias: zunicode alias: znvpair alias: zlua alias: icp alias: zavl alias: devname:zfs alias: char-major-10-249 srcversion: 0242C2AA732639906F5EB42 depends: spl name: zfs vermagic: 6.6.39-current-rockchip64 SMP preempt mod_unload aarch64 parm: zvol_inhibit_dev:Do not create zvol device nodes (uint) parm: zvol_major:Major number for zvol device (uint) parm: zvol_threads:Number of threads to handle I/O requests. Setto 0 to use all active CPUs (uint) parm: zvol_request_sync:Synchronously handle bio requests (uint) parm: zvol_max_discard_blocks:Max number of blocks to discard (ulong) parm: zvol_num_taskqs:Number of zvol taskqs (uint) parm: zvol_prefetch_bytes:Prefetch N bytes at zvol start+end (uint) parm: zvol_volmode:Default volmode property value (uint) parm: zvol_blk_mq_queue_depth:Default blk-mq queue depth (uint) parm: zvol_use_blk_mq:Use the blk-mq API for zvols (uint) parm: zvol_blk_mq_blocks_per_thread:Process volblocksize blocks per thread (uint) parm: zvol_open_timeout_ms:Timeout for ZVOL open retries (uint) parm: zfs_xattr_compat:Use legacy ZFS xattr naming for writing new user namespace xattrs parm: zfs_fallocate_reserve_percent:Percentage of length to use for the available capacity check (uint) parm: zfs_key_max_salt_uses:Max number of times a salt value can be used for generating encryption keys before it is rotated (ulong) parm: zfs_object_mutex_size:Size of znode hold array (uint) parm: zfs_unlink_suspend_progress:Set to prevent async unlinks (debug - leaks space into the unlinked set) (int) parm: zfs_delete_blocks:Delete files larger than N blocks async (ulong) parm: zfs_dbgmsg_enable:Enable ZFS debug message log (int) parm: zfs_dbgmsg_maxsize:Maximum ZFS debug log size (uint) parm: zfs_admin_snapshot:Enable mkdir/rmdir/mv in .zfs/snapshot (int) parm: zfs_expire_snapshot:Seconds to expire .zfs/snapshot (int) parm: vdev_file_logical_ashift:Logical ashift for file-based devices parm: vdev_file_physical_ashift:Physical ashift for file-based devices parm: zfs_vdev_scheduler:I/O scheduler parm: zfs_vdev_open_timeout_ms:Timeout before determining that a device is missing parm: zfs_vdev_failfast_mask:Defines failfast mask: 1 - device, 2 - transport, 4 - driver parm: zfs_vdev_disk_max_segs:Maximum number of data segments to add to an IO request (min 4) parm: zfs_vdev_disk_classic:Use classic BIO submission method parm: zfs_arc_shrinker_limit:Limit on number of pages that ARC shrinker can reclaim at once parm: zfs_abd_scatter_enabled:Toggle whether ABD allocations must be linear. (int) parm: zfs_abd_scatter_min_size:Minimum size of scatter allocations. (int) parm: zfs_abd_scatter_max_order:Maximum order allocation used for a scatter ABD. (uint) parm: zio_slow_io_ms:Max I/O completion time (milliseconds) before marking it as slow parm: zio_requeue_io_start_cut_in_line:Prioritize requeued I/O parm: zfs_sync_pass_deferred_free:Defer frees starting in this pass parm: zfs_sync_pass_dont_compress:Don't compress starting in this pass parm: zfs_sync_pass_rewrite:Rewrite new bps starting in this pass parm: zio_dva_throttle_enabled:Throttle block allocations in the ZIO pipeline parm: zio_deadman_log_all:Log all slow ZIOs, not just those with vdevs parm: zfs_commit_timeout_pct:ZIL block open timeout percentage parm: zil_replay_disable:Disable intent logging replay parm: zil_nocacheflush:Disable ZIL cache flushes parm: zil_slog_bulk:Limit in bytes slog sync writes per commit parm: zil_maxblocksize:Limit in bytes of ZIL log block size parm: zil_maxcopied:Limit in bytes WR_COPIED size parm: zfs_vnops_read_chunk_size:Bytes to read per chunk parm: zfs_bclone_enabled:Enable block cloning parm: zfs_bclone_wait_dirty:Wait for dirty blocks when cloning parm: zfs_zil_saxattr:Disable xattr=sa extended attribute logging in ZIL by settng 0. parm: zfs_immediate_write_sz:Largest data block to write to zil parm: zfs_max_nvlist_src_size:Maximum size in bytes allowed for src nvlist passed with ZFS ioctls parm: zfs_history_output_max:Maximum size in bytes of ZFS ioctl output that will be logged parm: zfs_zevent_retain_max:Maximum recent zevents records to retain for duplicate checking parm: zfs_zevent_retain_expire_secs:Expiration time for recent zevents records parm: zfs_lua_max_instrlimit:Max instruction limit that can be specified for a channel program parm: zfs_lua_max_memlimit:Max memory limit that can be specified for a channel program parm: zap_micro_max_size:Maximum micro ZAP size, before converting to a fat ZAP, in bytes parm: zap_iterate_prefetch:When iterating ZAP object, prefetch it parm: zfs_trim_extent_bytes_max:Max size of TRIM commands, larger will be split parm: zfs_trim_extent_bytes_min:Min size of TRIM commands, smaller will be skipped parm: zfs_trim_metaslab_skip:Skip metaslabs which have never been initialized parm: zfs_trim_txg_batch:Min number of txgs to aggregate frees before issuing TRIM parm: zfs_trim_queue_limit:Max queued TRIMs outstanding per leaf vdev parm: zfs_removal_ignore_errors:Ignore hard IO errors when removing device parm: zfs_remove_max_segment:Largest contiguous segment to allocate when removing device parm: vdev_removal_max_span:Largest span of free chunks a remap segment can span parm: zfs_removal_suspend_progress:Pause device removal after this many bytes are copied (debug use only - causes removal to hang) parm: zfs_rebuild_max_segment:Max segment size in bytes of rebuild reads parm: zfs_rebuild_vdev_limit:Max bytes in flight per leaf vdev for sequential resilvers parm: zfs_rebuild_scrub_enabled:Automatically scrub after sequential resilver completes parm: zfs_vdev_raidz_impl:Select raidz implementation. parm: zfs_vdev_aggregation_limit:Max vdev I/O aggregation size parm: zfs_vdev_aggregation_limit_non_rotating:Max vdev I/O aggregation size for non-rotating media parm: zfs_vdev_read_gap_limit:Aggregate read I/O over gap parm: zfs_vdev_write_gap_limit:Aggregate write I/O over gap parm: zfs_vdev_max_active:Maximum number of active I/Os per vdev parm: zfs_vdev_async_write_active_max_dirty_percent:Async write concurrency max threshold parm: zfs_vdev_async_write_active_min_dirty_percent:Async write concurrency min threshold parm: zfs_vdev_async_read_max_active:Max active async read I/Os per vdev parm: zfs_vdev_async_read_min_active:Min active async read I/Os per vdev parm: zfs_vdev_async_write_max_active:Max active async write I/Os per vdev parm: zfs_vdev_async_write_min_active:Min active async write I/Os per vdev parm: zfs_vdev_initializing_max_active:Max active initializing I/Os per vdev parm: zfs_vdev_initializing_min_active:Min active initializing I/Os per vdev parm: zfs_vdev_removal_max_active:Max active removal I/Os per vdev parm: zfs_vdev_removal_min_active:Min active removal I/Os per vdev parm: zfs_vdev_scrub_max_active:Max active scrub I/Os per vdev parm: zfs_vdev_scrub_min_active:Min active scrub I/Os per vdev parm: zfs_vdev_sync_read_max_active:Max active sync read I/Os per vdev parm: zfs_vdev_sync_read_min_active:Min active sync read I/Os per vdev parm: zfs_vdev_sync_write_max_active:Max active sync write I/Os per vdev parm: zfs_vdev_sync_write_min_active:Min active sync write I/Os per vdev parm: zfs_vdev_trim_max_active:Max active trim/discard I/Os per vdev parm: zfs_vdev_trim_min_active:Min active trim/discard I/Os per vdev parm: zfs_vdev_rebuild_max_active:Max active rebuild I/Os per vdev parm: zfs_vdev_rebuild_min_active:Min active rebuild I/Os per vdev parm: zfs_vdev_nia_credit:Number of non-interactive I/Os to allow in sequence parm: zfs_vdev_nia_delay:Number of non-interactive I/Os before _max_active parm: zfs_vdev_queue_depth_pct:Queue depth percentage for each top-level vdev parm: zfs_vdev_def_queue_depth:Default queue depth for each allocator parm: zfs_vdev_mirror_rotating_inc:Rotating media load increment for non-seeking I/Os parm: zfs_vdev_mirror_rotating_seek_inc:Rotating media load increment for seeking I/Os parm: zfs_vdev_mirror_rotating_seek_offset:Offset in bytes from the last I/O which triggers a reduced rotating media seek increment parm: zfs_vdev_mirror_non_rotating_inc:Non-rotating media load increment for non-seeking I/Os parm: zfs_vdev_mirror_non_rotating_seek_inc:Non-rotating media load increment for seeking I/Os parm: zfs_initialize_value:Value written during zpool initialize parm: zfs_initialize_chunk_size:Size in bytes of writes by zpool initialize parm: zfs_condense_indirect_vdevs_enable:Whether to attempt condensing indirect vdev mappings parm: zfs_condense_indirect_obsolete_pct:Minimum obsolete percent of bytes in the mapping to attempt condensing parm: zfs_condense_min_mapping_bytes:Don't bother condensing if the mapping uses less than this amount of memory parm: zfs_condense_max_obsolete_bytes:Minimum size obsolete spacemap to attempt condensing parm: zfs_condense_indirect_commit_entry_delay_ms:Used by tests to ensure certain actions happen in the middle of a condense. A maximum value of 1 should be sufficient. parm: zfs_reconstruct_indirect_combinations_max:Maximum number of combinations when reconstructing split segments parm: zfs_vdev_default_ms_count:Target number of metaslabs per top-level vdev parm: zfs_vdev_default_ms_shift:Default lower limit for metaslab size parm: zfs_vdev_max_ms_shift:Default upper limit for metaslab size parm: zfs_vdev_min_ms_count:Minimum number of metaslabs per top-level vdev parm: zfs_vdev_ms_count_limit:Practical upper limit of total metaslabs per top-level vdev parm: zfs_slow_io_events_per_second:Rate limit slow IO (delay) events to this many per second parm: zfs_checksum_events_per_second:Rate limit checksum events to this many checksum errors per second (do not set below ZED threshold). parm: zfs_scan_ignore_errors:Ignore errors during resilver/scrub parm: vdev_validate_skip:Bypass vdev_validate() parm: zfs_nocacheflush:Disable cache flushes parm: zfs_embedded_slog_min_ms:Minimum number of metaslabs required to dedicate one for log blocks parm: zfs_vdev_min_auto_ashift:Minimum ashift used when creating new top-level vdevs parm: zfs_vdev_max_auto_ashift:Maximum ashift used when optimizing for logical -> physical sector size on new top-level vdevs parm: zfs_txg_timeout:Max seconds worth of delta per txg parm: zfs_read_history:Historical statistics for the last N reads parm: zfs_read_history_hits:Include cache hits in read history parm: zfs_txg_history:Historical statistics for the last N txgs parm: zfs_multihost_history:Historical statistics for last N multihost writes parm: zfs_flags:Set additional debugging flags parm: zfs_recover:Set to attempt to recover from fatal errors parm: zfs_free_leak_on_eio:Set to ignore IO errors during free and permanently leak the space parm: zfs_deadman_checktime_ms:Dead I/O check interval in milliseconds parm: zfs_deadman_enabled:Enable deadman timer parm: spa_asize_inflation:SPA size estimate multiplication factor parm: zfs_ddt_data_is_special:Place DDT data into the special class parm: zfs_user_indirect_is_special:Place user data indirect blocks into the special class parm: zfs_deadman_failmode:Failmode for deadman timer parm: zfs_deadman_synctime_ms:Pool sync expiration time in milliseconds parm: zfs_deadman_ziotime_ms:IO expiration time in milliseconds parm: zfs_special_class_metadata_reserve_pct:Small file blocks in special vdevs depends on this much free space available parm: spa_slop_shift:Reserved free space in pool parm: zfs_unflushed_max_mem_amt:Specific hard-limit in memory that ZFS allows to be used for unflushed changes parm: zfs_unflushed_max_mem_ppm:Percentage of the overall system memory that ZFS allows to be used for unflushed changes (value is calculated over 1000000 for finer granularity) parm: zfs_unflushed_log_block_max:Hard limit (upper-bound) in the size of the space map log in terms of blocks. parm: zfs_unflushed_log_block_min:Lower-bound limit for the maximum amount of blocks allowed in log spacemap (see zfs_unflushed_log_block_max) parm: zfs_unflushed_log_txg_max:Hard limit (upper-bound) in the size of the space map log in terms of dirty TXGs. parm: zfs_unflushed_log_block_pct:Tunable used to determine the number of blocks that can be used for the spacemap log, expressed as a percentage of the total number of metaslabs in the pool (e.g. 400 means the number of log blocks is capped at 4 times the number of metaslabs) parm: zfs_max_log_walking:The number of past TXGs that the flushing algorithm of the log spacemap feature uses to estimate incoming log blocks parm: zfs_keep_log_spacemaps_at_export:Prevent the log spacemaps from being flushed and destroyed during pool export/destroy parm: zfs_max_logsm_summary_length:Maximum number of rows allowed in the summary of the spacemap log parm: zfs_min_metaslabs_to_flush:Minimum number of metaslabs to flush per dirty TXG parm: spa_upgrade_errlog_limit:Limit the number of errors which will be upgraded to the new on-disk error log when enabling head_errlog parm: spa_config_path:SPA config file (/etc/zfs/zpool.cache) parm: zfs_autoimport_disable:Disable pool import at module load parm: zfs_spa_discard_memory_limit:Limit for memory used in prefetching the checkpoint space map done on each vdev while discarding the checkpoint parm: metaslab_preload_pct:Percentage of CPUs to run a metaslab preload taskq parm: spa_load_verify_shift:log2 fraction of arc that can be used by inflight I/Os when verifying pool during import parm: spa_load_verify_metadata:Set to traverse metadata on pool import parm: spa_load_verify_data:Set to traverse data on pool import parm: spa_load_print_vdev_tree:Print vdev tree to zfs_dbgmsg during pool import parm: zio_taskq_batch_pct:Percentage of CPUs to run an IO worker thread parm: zio_taskq_batch_tpq:Number of threads per IO worker taskqueue parm: zfs_max_missing_tvds:Allow importing pool with up to this number of missing top-level vdevs (in read-only mode) parm: zfs_livelist_condense_zthr_pause:Set the livelist condense zthr to pause parm: zfs_livelist_condense_sync_pause:Set the livelist condense synctask to pause parm: zfs_livelist_condense_sync_cancel:Whether livelist condensing was canceled in the synctask parm: zfs_livelist_condense_zthr_cancel:Whether livelist condensing was canceled in the zthr function parm: zfs_livelist_condense_new_alloc:Whether extra ALLOC blkptrs were added to a livelist entry while it was being condensed parm: zio_taskq_read:Configure IO queues for read IO parm: zio_taskq_write:Configure IO queues for write IO parm: zfs_multilist_num_sublists:Number of sublists used in each multilist parm: zfs_multihost_interval:Milliseconds between mmp writes to each leaf parm: zfs_multihost_fail_intervals:Max allowed period without a successful mmp write parm: zfs_multihost_import_intervals:Number of zfs_multihost_interval periods to wait for activity parm: metaslab_aliquot:Allocation granularity (a.k.a. stripe size) parm: metaslab_debug_load:Load all metaslabs when pool is first opened parm: metaslab_debug_unload:Prevent metaslabs from being unloaded parm: metaslab_preload_enabled:Preload potential metaslabs during reassessment parm: metaslab_preload_limit:Max number of metaslabs per group to preload parm: metaslab_unload_delay:Delay in txgs after metaslab was last used before unloading parm: metaslab_unload_delay_ms:Delay in milliseconds after metaslab was last used before unloading parm: zfs_mg_noalloc_threshold:Percentage of metaslab group size that should be free to make it eligible for allocation parm: zfs_mg_fragmentation_threshold:Percentage of metaslab group size that should be considered eligible for allocations unless all metaslab groups within the metaslab class have also crossed this threshold parm: metaslab_fragmentation_factor_enabled:Use the fragmentation metric to prefer less fragmented metaslabs parm: zfs_metaslab_fragmentation_threshold:Fragmentation for metaslab to allow allocation parm: metaslab_lba_weighting_enabled:Prefer metaslabs with lower LBAs parm: metaslab_bias_enabled:Enable metaslab group biasing parm: zfs_metaslab_segment_weight_enabled:Enable segment-based metaslab selection parm: zfs_metaslab_switch_threshold:Segment-based metaslab selection maximum buckets before switching parm: metaslab_force_ganging:Blocks larger than this size are sometimes forced to be gang blocks parm: metaslab_force_ganging_pct:Percentage of large blocks that will be forced to be gang blocks parm: metaslab_df_max_search:Max distance (bytes) to search forward before using size tree parm: metaslab_df_use_largest_segment:When looking in size tree, use largest segment instead of exact fit parm: zfs_metaslab_max_size_cache_sec:How long to trust the cached max chunk size of a metaslab parm: zfs_metaslab_mem_limit:Percentage of memory that can be used to store metaslab range trees parm: zfs_metaslab_try_hard_before_gang:Try hard to allocate before ganging parm: zfs_metaslab_find_max_tries:Normally only consider this many of the best metaslabs in each vdev parm: zfs_zevent_len_max:Max event queue length parm: zfs_scan_vdev_limit:Max bytes in flight per leaf vdev for scrubs and resilvers parm: zfs_scrub_min_time_ms:Min millisecs to scrub per txg parm: zfs_obsolete_min_time_ms:Min millisecs to obsolete per txg parm: zfs_free_min_time_ms:Min millisecs to free per txg parm: zfs_resilver_min_time_ms:Min millisecs to resilver per txg parm: zfs_scan_suspend_progress:Set to prevent scans from progressing parm: zfs_no_scrub_io:Set to disable scrub I/O parm: zfs_no_scrub_prefetch:Set to disable scrub prefetching parm: zfs_async_block_max_blocks:Max number of blocks freed in one txg parm: zfs_max_async_dedup_frees:Max number of dedup blocks freed in one txg parm: zfs_free_bpobj_enabled:Enable processing of the free_bpobj parm: zfs_scan_blkstats:Enable block statistics calculation during scrub parm: zfs_scan_mem_lim_fact:Fraction of RAM for scan hard limit parm: zfs_scan_issue_strategy:IO issuing strategy during scrubbing. 0 = default, 1 = LBA, 2 = size parm: zfs_scan_legacy:Scrub using legacy non-sequential method parm: zfs_scan_checkpoint_intval:Scan progress on-disk checkpointing interval parm: zfs_scan_max_ext_gap:Max gap in bytes between sequential scrub / resilver I/Os parm: zfs_scan_mem_lim_soft_fact:Fraction of hard limit used as soft limit parm: zfs_scan_strict_mem_lim:Tunable to attempt to reduce lock contention parm: zfs_scan_fill_weight:Tunable to adjust bias towards more filled segments during scans parm: zfs_scan_report_txgs:Tunable to report resilver performance over the last N txgs parm: zfs_resilver_disable_defer:Process all resilvers immediately parm: zfs_scrub_error_blocks_per_txg:Error blocks to be scrubbed in one txg parm: zfs_dirty_data_max_percent:Max percent of RAM allowed to be dirty parm: zfs_dirty_data_max_max_percent:zfs_dirty_data_max upper bound as % of RAM parm: zfs_delay_min_dirty_percent:Transaction delay threshold parm: zfs_dirty_data_max:Determines the dirty space limit parm: zfs_wrlog_data_max:The size limit of write-transaction zil log data parm: zfs_dirty_data_max_max:zfs_dirty_data_max upper bound in bytes parm: zfs_dirty_data_sync_percent:Dirty data txg sync threshold as a percentage of zfs_dirty_data_max parm: zfs_delay_scale:How quickly delay approaches infinity parm: zfs_sync_taskq_batch_pct:Max percent of CPUs that are used to sync dirty data parm: zfs_zil_clean_taskq_nthr_pct:Max percent of CPUs that are used per dp_sync_taskq parm: zfs_zil_clean_taskq_minalloc:Number of taskq entries that are pre-populated parm: zfs_zil_clean_taskq_maxalloc:Max number of taskq entries that are cached parm: zvol_enforce_quotas:Enable strict ZVOL quota enforcment parm: zfs_livelist_max_entries:Size to start the next sub-livelist in a livelist parm: zfs_livelist_min_percent_shared:Threshold at which livelist is disabled parm: zfs_max_recordsize:Max allowed record size parm: zfs_allow_redacted_dataset_mount:Allow mounting of redacted datasets parm: zfs_snapshot_history_enabled:Include snapshot events in pool history/events parm: zfs_disable_ivset_guid_check:Set to allow raw receives without IVset guids parm: zfs_default_bs:Default dnode block shift parm: zfs_default_ibs:Default dnode indirect block shift parm: zfs_prefetch_disable:Disable all ZFS prefetching parm: zfetch_max_streams:Max number of streams per zfetch parm: zfetch_min_sec_reap:Min time before stream reclaim parm: zfetch_max_sec_reap:Max time before stream delete parm: zfetch_min_distance:Min bytes to prefetch per stream parm: zfetch_max_distance:Max bytes to prefetch per stream parm: zfetch_max_idistance:Max bytes to prefetch indirects for per stream parm: zfetch_max_reorder:Max request reorder distance within a stream parm: zfetch_hole_shift:Max log2 fraction of holes in a stream parm: zfs_pd_bytes_max:Max number of bytes to prefetch parm: zfs_traverse_indirect_prefetch_limit:Traverse prefetch number of blocks pointed by indirect block parm: ignore_hole_birth:Alias for send_holes_without_birth_time (int) parm: send_holes_without_birth_time:Ignore hole_birth txg for zfs send parm: zfs_send_corrupt_data:Allow sending corrupt data parm: zfs_send_queue_length:Maximum send queue length parm: zfs_send_unmodified_spill_blocks:Send unmodified spill blocks parm: zfs_send_no_prefetch_queue_length:Maximum send queue length for non-prefetch queues parm: zfs_send_queue_ff:Send queue fill fraction parm: zfs_send_no_prefetch_queue_ff:Send queue fill fraction for non-prefetch queues parm: zfs_override_estimate_recordsize:Override block size estimate with fixed size parm: zfs_recv_queue_length:Maximum receive queue length parm: zfs_recv_queue_ff:Receive queue fill fraction parm: zfs_recv_write_batch_size:Maximum amount of writes to batch into one transaction parm: zfs_recv_best_effort_corrective:Ignore errors during corrective receive parm: dmu_object_alloc_chunk_shift:CPU-specific allocator grabs 2^N objects at once parm: zfs_nopwrite_enabled:Enable NOP writes parm: zfs_per_txg_dirty_frees_percent:Percentage of dirtied blocks from frees in one TXG parm: zfs_dmu_offset_next_sync:Enable forcing txg sync to find holes parm: dmu_prefetch_max:Limit one prefetch call to this size parm: ddt_zap_default_bs:DDT ZAP leaf blockshift parm: ddt_zap_default_ibs:DDT ZAP indirect blockshift parm: zfs_dedup_prefetch:Enable prefetching dedup-ed blks parm: zfs_dbuf_state_index:Calculate arc header index parm: dbuf_cache_max_bytes:Maximum size in bytes of the dbuf cache. parm: dbuf_cache_hiwater_pct:Percentage over dbuf_cache_max_bytes for direct dbuf eviction. parm: dbuf_cache_lowater_pct:Percentage below dbuf_cache_max_bytes when dbuf eviction stops. parm: dbuf_metadata_cache_max_bytes:Maximum size in bytes of dbuf metadata cache. parm: dbuf_cache_shift:Set size of dbuf cache to log2 fraction of arc size. parm: dbuf_metadata_cache_shift:Set size of dbuf metadata cache to log2 fraction of arc size. parm: dbuf_mutex_cache_shift:Set size of dbuf cache mutex array as log2 shift. parm: zfs_btree_verify_intensity:Enable btree verification. Levels above 4 require ZFS be built with debugging parm: brt_zap_prefetch:Enable prefetching of BRT ZAP entries parm: brt_zap_default_bs:BRT ZAP leaf blockshift parm: brt_zap_default_ibs:BRT ZAP indirect blockshift parm: zfs_arc_min:Minimum ARC size in bytes parm: zfs_arc_max:Maximum ARC size in bytes parm: zfs_arc_meta_balance:Balance between metadata and data on ghost hits. parm: zfs_arc_grow_retry:Seconds before growing ARC size parm: zfs_arc_shrink_shift:log2(fraction of ARC to reclaim) parm: zfs_arc_pc_percent:Percent of pagecache to reclaim ARC to parm: zfs_arc_average_blocksize:Target average block size parm: zfs_compressed_arc_enabled:Disable compressed ARC buffers parm: zfs_arc_min_prefetch_ms:Min life of prefetch block in ms parm: zfs_arc_min_prescient_prefetch_ms:Min life of prescient prefetched block in ms parm: l2arc_write_max:Max write bytes per interval parm: l2arc_write_boost:Extra write bytes during device warmup parm: l2arc_headroom:Number of max device writes to precache parm: l2arc_headroom_boost:Compressed l2arc_headroom multiplier parm: l2arc_trim_ahead:TRIM ahead L2ARC write size multiplier parm: l2arc_feed_secs:Seconds between L2ARC writing parm: l2arc_feed_min_ms:Min feed interval in milliseconds parm: l2arc_noprefetch:Skip caching prefetched buffers parm: l2arc_feed_again:Turbo L2ARC warmup parm: l2arc_norw:No reads during writes parm: l2arc_meta_percent:Percent of ARC size allowed for L2ARC-only headers parm: l2arc_rebuild_enabled:Rebuild the L2ARC when importing a pool parm: l2arc_rebuild_blocks_min_l2size:Min size in bytes to write rebuild log blocks in L2ARC parm: l2arc_mfuonly:Cache only MFU data from ARC into L2ARC parm: l2arc_exclude_special:Exclude dbufs on special vdevs from being cached to L2ARC if set. parm: zfs_arc_lotsfree_percent:System free memory I/O throttle in bytes parm: zfs_arc_sys_free:System free memory target size in bytes parm: zfs_arc_dnode_limit:Minimum bytes of dnodes in ARC parm: zfs_arc_dnode_limit_percent:Percent of ARC meta buffers for dnodes parm: zfs_arc_dnode_reduce_percent:Percentage of excess dnodes to try to unpin parm: zfs_arc_eviction_pct:When full, ARC allocation waits for eviction of this % of alloc size parm: zfs_arc_evict_batch_limit:The number of headers to evict per sublist before moving to the next parm: zfs_arc_prune_task_threads:Number of arc_prune threads parm: zstd_earlyabort_pass:Enable early abort attempts when using zstd parm: zstd_abort_size:Minimal size of block to attempt early abort parm: zfs_max_dataset_nesting:Limit to the amount of nesting a path can have. Defaults to 50. parm: zfs_fletcher_4_impl:Select fletcher 4 implementation. parm: zfs_sha512_impl:Select SHA512 implementation. parm: zfs_sha256_impl:Select SHA256 implementation. parm: icp_gcm_impl:Select gcm implementation. parm: zfs_blake3_impl:Select BLAKE3 implementation. parm: icp_aes_impl:Select aes implementation. 0 Quote Link to comment Share on other sites More sharing options...
