Luis Daniel Posted May 29, 2017 Posted May 29, 2017 Hello ppl. I have an Orange Pi Zero, and I have some issues using UART interface, it give me an output like this: ▒▒▒I▒%E▒Y=7▒g!=7▒Y=5▒[s▒i-''▒Y-9/▒Y=▒▒▒RrR▒▒▒V▒▒ ▒▒▒I▒%E▒Y=7▒c5!e=#=15Q=-▒a#'-#5▒▒▒RrR▒▒▒V▒▒ ▒▒▒I▒%E▒[5=9/57▒=5▒c5!-▒a'▒7==;=5▒57=5%!#▒▒▒▒▒▒▒▒▒▒▒▒▒▒]▒m]▒▒▒▒gY{▒▒}=9/5▒▒5;▒5▒▒▒▒▒▒▒▒▒▒▒▒▒]▒m]▒▒▒▒gY{▒▒}7=#957▒muuu▒▒▒▒▒▒▒▒%=#=15%5#▒7=5%!#▒▒▒▒▒▒▒▒▒▒▒▒▒▒]▒m]▒▒▒▒gY{▒▒7-)▒5%5▒%!#-!▒7=5%!#▒▒▒▒▒▒▒▒▒▒▒▒▒▒]▒m]▒▒▒▒gY{▒▒Y=cW_▒7=5%!#▒▒▒▒▒RrR▒▒▒V▒▒ ▒▒▒I▒%E▒Y=7▒▒59▒▒'!9='▒y▒▒▒R▒%I▒▒▒▒%▒▒ai▒▒▒I▒%E▒Y=7▒gY{▒▒}7=#957▒muuu▒▒▒▒▒▒▒▒%=#=15%5#▒7=5%!#▒▒▒RrR▒▒▒V▒▒ Y▒▒▒▒R▒%I▒▒▒▒%▒▒ai▒▒▒I▒%E▒[5=9/57▒=5▒g!1-#▒_▒▒RrR▒▒▒V▒▒▒▒I▒%E▒Y=7▒Y5'▒q5 ▒▒▒I▒%E▒Y=7▒gY{▒▒Y=cW_▒7=▒▒▒▒▒U▒▒▒Q▒▒▒▒;]e▒!#15- Y▒▒▒▒▒H▒▒▒▒jZ▒▒ 5 ▒; ▒jZ▒ I already tried other speeds than 115200, even changed the charset of putty and nothing works. It shows the same issue with other PC. I'm connecting through serial port of PC, no USB-to-PC, using windows 7 64 bit and putty 0.63. It works fine through internet. Using ARMBIAN 5.25 stable Ubuntu 16.04.2 LTS 3.4.113-sun8i, as it outputs after login. Using the command: stty -F /dev/ttyS0 It outputs: speed 115200 baud; line = 0; min = 1; time = 0; -brkint -icrnl -imaxbel iutf8 -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke But if I change the interface: stty -F /dev/ttyGS0 I get: speed 9600 baud; line = 0; min = 1; time = 0; -brkint -icrnl -imaxbel iutf8 -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke Anyone can help me with this issue? Thanks for reading this.
umiddelb Posted May 29, 2017 Posted May 29, 2017 You may check if the ground wire is connected correctly ...
gnasch Posted May 29, 2017 Posted May 29, 2017 I think a directly connected RS-232 port expects voltages of +3..15V for a logic "0" and -3..15V for a logic "1". Your opi outputs signals that use 0V for "0" and 3.3V for "1". hth, gnasch
Luis Daniel Posted May 29, 2017 Author Posted May 29, 2017 Thank you ppl for your help. Now I get something more readable like this: Starting Load/Save RF Kill Switch Status... [ OK ] Started Load/Savd RF Kill Switch Status/ [ OK ] Started Network Manager Wait Online/ [&▒[z-▒ڴju▒▒U▒▒▒▒▒▒▒▒ɝ▒сr▒▒ݽɭ▒J́z▒▒▒▒▒▒j PTTY Startiog LSB: Apache2 web servdr... Starting /etc/rc.local Compatibilhty... Starting LSB: Start OTP daemon./. Stasting LSB: Start and stop the mysql database seqver daemo Starting LSB; Advanced IDEE 802.11 m`nagement dadmon... St`rting LSB: disk temperature monitorhng daemon../ [ OK ] Started /etc/rc.local Compatibilhty. [ OK ] Started LSB9 Advanced IDEE 802.11 lanagement d`em [ OK ] Started LSB: disk temperature lonitoring d`emon.[ OK ] Started LSB: Start NTP d`emon. [ OK ] Startdd Getty on tty1. [ OK \ Started Sesial Getty oo ttyS0. [ OK ] Started Sdrial Getty on ttyGS0. [ OK ] Seached targdt Login Prompts. Ubuntu 16.04.2 LTS orangepizero ttyS0 orangepizero login: As you can see, sometimes i get some error, that can be some communication error. I use a Chinese arduino as serial communication or maybe the arduino program, anyway, now I have an interface to read and interact. I have other issues to solve like copy from one SD to other, I already copied but need to create the boot. But this will be to other post or deep search. Again thanks and see you again ppl.
Luis Daniel Posted July 1, 2017 Author Posted July 1, 2017 Hello again. After some time waiting for RS232 to TTL, I can say, it works fine when receive data. But when I type something, the putty add garbage to each character. Anyone know how to solve this or know why? best regards, Luis Daniel
chwe Posted July 1, 2017 Posted July 1, 2017 chinese arduino with CHG340/341 or with FTDI. If FTDI, they are mostly fake and I had a lot of trouble on higher baudrates (more than 9600 ) with those fake FTDI (have also one surely faked FTDI which doesn't make trouble).
Luis Daniel Posted July 2, 2017 Author Posted July 2, 2017 I'm using this one: http://www.ebay.com/itm/2-PCS-Serial-Port-RS232-to-TTL-Converter-Module-Board-MAX3232-115200bps-Chic-/361760905462?hash=item543aa158f6:g:4WUAAOSw-vlVmgE2 it uses MAX3232.
martinayotte Posted July 2, 2017 Posted July 2, 2017 On 7/2/2017 at 1:38 AM, Luis Daniel said: it uses MAX3232 Expand Those are RS232-TTL converters. This means that your PC has a real RS232 DB9 port, and you're actually use it with a converter, right ? If you're using a USB-TTL dongle, you don't need such converters, since they are already TTL level.
Luis Daniel Posted July 2, 2017 Author Posted July 2, 2017 On 7/2/2017 at 1:08 PM, martinayotte said: Those are RS232-TTL converters. This means that your PC has a real RS232 DB9 port, and you're actually use it with a converter, right ? If you're using a USB-TTL dongle, you don't need such converters, since they are already TTL level. Expand Yes i'm using a RS232 port and MAX3232 between them to convert signal. What upset me is, now I have a clear message from orange pi, but when I try to send something trough putty (i didn't use any other) it add some garbage.
martinayotte Posted July 2, 2017 Posted July 2, 2017 This means that OPi TX is Ok, but RX isn't ... How do you power the MAX3232 ? If it is with 5V, you will need to add a voltage divider on RX output of the MAX, because OPi is 3.3V.
Luis Daniel Posted July 2, 2017 Author Posted July 2, 2017 Let me give you what I mean. root@orangepizero:~# ▒a▒p▒t▒-g▒et u▒p▒d▒a▒t▒e▒ Hit:1 http://ports.ubuntu.com xenial InRelease Get:2 http://ports.ubuntu.com xenial-security InRelease [102 kB] Hit:3 http://apt.armbian.com xenial InRelease Get:4 http://ports.ubuntu.com xenial-updates InRelease [102 kB] Get:5 http://ports.ubuntu.com xenial-backports InRelease [102 kB] Get:6 http://ports.ubuntu.com xenial-updates/main armhf Packages [510 kB] Get:7 http://ports.ubuntu.com xenial-updates/universe armhf Packages [446 kB] Fetched 1,263 kB in 5s (224 kB/s) Reading package lists... Done root@orangepizero:~#
Luis Daniel Posted July 2, 2017 Author Posted July 2, 2017 On 7/2/2017 at 2:06 PM, martinayotte said: This means that OPi TX is Ok, but RX isn't ... How do you power the MAX3232 ? If it is with 5V, you will need to add a voltage divider on RX output of the MAX, because OPi is 3.3V. Expand Using 5V the MAX3232 get's to hot and doesn't work, so, i'm using orange pi to power it with 3,3V.
martinayotte Posted July 2, 2017 Posted July 2, 2017 Then, I'm running out of ideas ... In the mean time, I can only suggest to purchase some USB-TTL (3V compatible) dongles to compare behaviours.
zador.blood.stained Posted July 2, 2017 Posted July 2, 2017 On 5/29/2017 at 1:28 AM, Luis Daniel said: I'm connecting through serial port of PC, no USB-to-PC, using windows 7 64 bit and putty 0.63. It works fine through internet. Expand Compared to other boards Orange Pi Zero doesn't have any protection on its serial console pins, and PC COM port voltage levels go way above H3/H2+ absolute maximum ratings recommended operating conditions, so you can't rule out that SoC was damaged because of that connection attempt.
Xalius Posted July 2, 2017 Posted July 2, 2017 On 7/2/2017 at 2:23 PM, zador.blood.stained said: Compared to other boards Orange Pi Zero doesn't have any protection on its serial console pins, and PC COM port voltage levels go way above H3/H2+ absolute maximum ratings recommended operating conditions, so you can't rule out that SoC was damaged because of that connection attempt. Expand Thas was my first thought after reading the OP. Best case that was only +-5V coming from the PC side, worst case +-12V... so the RX pin on OPi or at least it's ESD diodes could be shot...
