D_el Posted September 1 Share Posted September 1 (edited) Hello folks! I was experimenting with all ARM images (Manjaro, Fedora, Arch, etc) i could find to test with the Orange Pi 4 LTS SBC board, and when i was about to return to armbian, it didnt boot anymore, not even from the SD card flashed with a proper image. I' currently using UART USB to TTL debug device to see whats happening with the board and it returns this: NOTE: [At the moment of this screenshot the board was with a SD card flashed with the default orange pi debian server image] Does anyone know how to reset this board and get it booting again from any ARM images? Would really appreciate any help on this to discover what i did mess up... Thanks in advance Edited September 1 by D_el 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted September 2 Share Posted September 2 moved tried removing emmc? 0 Quote Link to comment Share on other sites More sharing options...
D_el Posted September 9 Author Share Posted September 9 Thanks! No, i did not. And don’t think i am skilled enough to physically remove the emmc from the board without compromising it lol Is there a way to erase all emmc contents from another machine? like, making the storage being recognized from another machine and erasing it via terminal? Idk... or a set of hard reset buttons? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted September 9 Share Posted September 9 Is the emmc soldered on the board? I don't know this board in particular but it might be simply just sit in a socket. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted September 9 Share Posted September 9 You need to find out how to put this SoC into Maskrom mode ... connecting eMMC clock pin to ground will force it to boot U-boot from SD card. Check forum if someone write instructions for this board. On 9/2/2024 at 12:50 AM, D_el said: and when i was about to return to armbian Some other distributions are dangerous to run It is known that Manjaro tried to lock down boot-loader to prevent you from going elsewhere once you got there. Here you can read some background. 0 Quote Link to comment Share on other sites More sharing options...
mimosius Posted 12 hours ago Share Posted 12 hours ago How to enter Maskrom mode is described in the manual at page 46. 0 Quote Link to comment Share on other sites More sharing options...
