Claes-Fredrik Mannby Posted Thursday at 06:33 PM Share Posted Thursday at 06:33 PM Armbianmonitor: http://sudo%3A%20armbianmonitor%3A%20command%20not%20found I have an Ubuntu 20.04.06 system where my /var/log zram mount ran out of space. I took a few steps to address this (see below), and after rebooting, /var/log is no longer a zram mount. I've tried to find mentions of zram or ramlog in log files, but can't find anything that looks like an error message. /etc/default/armbian-zram-config and /etc/default/armbian-ramlog both still show they're enabled. Any idea how I can fix ramlog to come back up? - mv auth.log ../log.hdd/auth.log.240912 - mv mail.log ../log.hdd/mail.log.240912 cd ../log.hdd gzip auth.log.240912 gzip mail.log.240912 df -h # df showed /var/log as still full # it seems the moved and deleted files were still open for writing by apps cd ../log touch auth.log touch mail.log shutdown -r now Now /var/log is 17M, and log.hdd is 940K. log.hdd used to be much bigger. 0 Quote Link to comment Share on other sites More sharing options...
Claes-Fredrik Mannby Posted Thursday at 07:12 PM Author Share Posted Thursday at 07:12 PM I found some errors: ./log/syslog:Sep 12 08:56:15 o2 systemd[1]: dev-zram1.device: Job dev-zram1.device/start timed out. ./log/syslog:Sep 12 08:56:15 o2 systemd[1]: Timed out waiting for device /dev/zram1. ./log/syslog:Sep 12 08:56:15 o2 systemd[1]: dev-zram1.device: Job dev-zram1.device/start failed with result 'timeout'. Searching this online, it seems it can be a kernel version mismatch issue (https://bbs.archlinux.org/viewtopic.php?id=278441). Everything in /boot is 6.6.44-current-sunxi, except uInitrd, which is 6.6.31-current-sunxi. Maybe this is the problem. If so, any idea how to fix it? 0 Quote Link to comment Share on other sites More sharing options...
Claes-Fredrik Mannby Posted Thursday at 08:00 PM Author Share Posted Thursday at 08:00 PM Maybe it's related to this: 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted Friday at 07:19 AM Share Posted Friday at 07:19 AM 12 hours ago, Claes-Fredrik Mannby said: I found some errors If you would provide all logs, not just what you think is the problem, armbianmonitor -u (its a part of board support package, armbian-bsp-BOARD-BRANCH), perhaps someone would see something. Approaching this blindly is very expensive for time. Which nobody has. Since it seems you have a very old build, it is recommended to start from scratch anyway. You can try to run this: update-initramfs 0 Quote Link to comment Share on other sites More sharing options...
Claes-Fredrik Mannby Posted Friday at 10:43 PM Author Share Posted Friday at 10:43 PM armbianmonitor doesn't exist on the system o2:~:% armbianmonitor -u zsh: command not found: armbianmonitor o2:~:% locate armbianmonitor /etc/armbianmonitor /etc/armbianmonitor/datasources /etc/armbianmonitor/datasources/soctemp Is it safe to run the following? version=6.6.44-current-sunxi mkimage -A arm -O linux -T ramdisk -C none -a 0 -e 0 -n uInitrd -d /boot/initrd.img-$version /boot/uInitrd-$version and then link to the generated uInitrd? I have no idea if Load Address: 00000000 Entry Point: 00000000 are safe/correct Which log files should I provide? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted Saturday at 05:40 AM Share Posted Saturday at 05:40 AM If armbianmonitor script is not present on your OS it is either VERY old or not a genuine Armbian image. Since Focal is just a few years I guess latter or it has been removed. Anyway grab the script from here, set chmod +x and ./armbianmonitor -u https://raw.githubusercontent.com/armbian/build/dfe8fc39e84f77718a86ab587b6851d872942e91/packages/bsp/common/usr/bin/armbianmonitor 0 Quote Link to comment Share on other sites More sharing options...
Claes-Fredrik Mannby Posted Saturday at 05:11 PM Author Share Posted Saturday at 05:11 PM Thanks! https://paste.armbian.com/ilawarucut 0 Quote Link to comment Share on other sites More sharing options...
