Hi
I installed  following image on Banana pi M5 on emmc. BananaPi does boot up but it shows "PI" username for which I am not able to find password anywhere and also tried ssh into the machine which was also denied.
Every time I installed the image same thing would happen with same username "PI" popping up every time. Would appreciate help if someone can share the password or what I am going wrong.
Armbian_24.8.1_Bananapim5_bookworm_current_6.6.47_xfce_desktop.img.xz
Cheers
IMG_6271.HEIC
Where did you get this image?
To my knowledge there's no pi username on Armbian images.
The first time you boot you should be asked to create a username + password.
If that doesn't happen you need to login with 'root' pw '1234'
I do know a lot of images from makers that have username 'pi' and pw 'pi'.
And why the file attached? Looks fishy...
4 hours ago, newtolinux said:
Attached image in the first post is what bootup screen looked like.
That is not Armbian. It must boot OS that is preinstalled on eMMC. You need to erase that somehow.
