Igor Posted June 23, 2017 Share Posted June 23, 2017 Armbian is community driven open source project. To keep it relevant and up to date it needs maintenance round the clock. This work is done by a small amateur contributor force which was under-powered since early days and it still is. For most basic tasks! Any help is more then welcome. https://forum.armbian.com/staffapplications/ (what do we need) https://docs.armbian.com/Quick_facts/ (overview) https://www.armbian.com/get-involved/ (how-to contribute) https://github.com/armbian (sources for build engine, documentation, scripts) <---- <---- <---- Also refactoring, better wording, code cleanup. General tips: plan to do things you understand. expect little to no guidance. focus on common needs and forget what is important only to you. start small. If you still don't know how to start, attach your questions below in the topic. 1 Quote Link to comment Share on other sites More sharing options...
Igor Posted January 14, 2020 Author Share Posted January 14, 2020 3 hours ago, jata said: Happy to help You know how to edit documentation, bash scripting, moderating forum? Perhaps some organising skills? Talking to other newbies? If yes to any, just do it. If no, keep on looking. There is a lot of things to do which does not require any deep technical knowledge but save us precious time. Which we don't have. I have to choose between fixing RC car for my kid or helping you ... 0 Quote Link to comment Share on other sites More sharing options...
jata Posted January 14, 2020 Share Posted January 14, 2020 I'm keen to help out with some scripting and get into more technical stuff. Can also edit docs etc. As a first step on the technical side, do I need to be able to compile a kernel/image myself? 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted January 14, 2020 Author Share Posted January 14, 2020 26 minutes ago, jata said: do I need to be able to compile a kernel/image myself? No, unless you want to improve documentations for that part. 0 Quote Link to comment Share on other sites More sharing options...
jata Posted January 15, 2020 Share Posted January 15, 2020 That's great so what can I do to help with the latest rock64 kernel 5.4? Should I get a setup with rock64 plugged into a monitor and then compare the boot info from Armbian_19.11.3_Rock64_buster_current_5.3.11 (working) vs Armbian_19.11.6_Rock64_buster_current_5.4.y (broken) If this is a good starting point then happy to assist... 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted January 15, 2020 Author Share Posted January 15, 2020 6 hours ago, jata said: If this is a good starting point then happy to assist... - do things you understand. - forget what is important to you. - start small. 0 Quote Link to comment Share on other sites More sharing options...
Shoka Posted March 22, 2020 Share Posted March 22, 2020 Igor, as far as I can tell your documentation omits mention of the SYNC_CLOCK parameter to the build scripts. If your build host is a system already synced to NTP, for example by systemd-timedated this fragment from general.sh 895 # sync clock 896 if [[ $SYNC_CLOCK != no ]]; then 897 display_alert "Syncing clock" "host" "info" 898 ntpdate -s ${NTP_SERVER:- pool.ntp.org} 899 fi seems to simply mess with the system clock to no purpose. What is the objective? To force an NTP synch or to force the time into the log? timedatectl seems to give correct answers about NTP status even when chrony is managing the clock. I don't have a system to test if it works reasonably with NTPD handling the clock, but if it does, possibly preceding the ntpdate with a check using timedatectl to check if we are already synched to NTP and if so skip the ntpdate would be a good idea? Document the parameter? If we add the check for NTP synch, possibly remove the parameter? Harry 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted March 22, 2020 Author Share Posted March 22, 2020 2 hours ago, Shoka said: What is the objective? To force an NTP synch We want to make sure clock is correct on start, nothing else. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted July 22, 2020 Share Posted July 22, 2020 13 hours ago, dhanushx012 said: I'm keen to help out with some scripting and get into more technical stuff. Can also edit docs etc. https://armbian.atlassian.net/projects/AR/issues/?filter=allissues&= https://github.com/armbian/build/issues Feel free to dig through some open issues and address some 0 Quote Link to comment Share on other sites More sharing options...
qiurui Posted May 6, 2022 Share Posted May 6, 2022 I want to join 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted May 6, 2022 Author Share Posted May 6, 2022 3 hours ago, qiurui said: I want to join Best way is to start here: https://forum.armbian.com/staffapplications/ Welcome! 0 Quote Link to comment Share on other sites More sharing options...
