Timple Posted July 13, 2017 Posted July 13, 2017 When I do a reboot the Olimex Lime2-emmc shuts down. No more information is shown on the display. This happens with the latest Armbian_5.31_Lime2_Debian_jessie_next_4.11.5 image from the website. It also happens with a self-build image with u-boot v2017.07 and v2017.05 Any ideas? Or debugging directions? I am out of options after 2 days...
Igor Posted July 13, 2017 Posted July 13, 2017 It's a problem within a U-boot ... we had similar problem with Cubieboard 1 but since upgrading to latest u-boot solved the issue, I didn't dig in further. Edit: I would double check config: https://github.com/armbian/build/blob/master/patch/u-boot/u-boot-sunxi/add-lime2-emmc.patch#L35-L72, Try with upstream Lime2 config and add the only important (?) diff: CONFIG_MMC_SUNXI_SLOT_EXTRA=2 to gain eMMC access
Timple Posted July 14, 2017 Author Posted July 14, 2017 You pointed me in the right direction. A lime2 image without emmc works (with sd card of course). I'll try to pinpoint the faulty code edit: let me revoke that statement, it rebooted fine two times. After 10 minutes it failed... edit2: reflashed same image, rebooted once, after that powerdown again. Any other options I can try?
Timple Posted July 17, 2017 Author Posted July 17, 2017 Trials until this far: Older Armbian_5.20_Lime2_Ubuntu_xenial_4.7.3 image: - rebooting works - rebooting after unattended upgrade works - rebooting after apt upgrade works once, no more thereafter Older Armbian_5.24_Lime2_Ubuntu_xenial_next_4.9.5 image: - rebooting works - apt-mark hold linux-u-boot-lime2-etc - rebooting after apt upgrade works once, no more thereafter Nighly Armbian_5.27.170614_Lime2_Ubuntu_xenial_next_4.11.4 image: - rebooting does not work Newest Armbian_5.31_Lime2_Ubuntu_xenial_next_4.11.5 image: - rebooting does not work
lampra Posted July 31, 2017 Posted July 31, 2017 Same here. reboot causes poweroff on lime2-emmc. ARMBIAN 5.31 stable Debian GNU/Linux 8 (jessie) 4.11.6-sunxi
